KCC's Quizzes AQQ261 about a rectangle area
A new challenge is there to enjoy your coming week-end! This time an easy one open to all of us (thus not only for electronical engineers)!
1. First, we start with the quote of the week: "You know you've reached middle age when you're cautioned to slow down by your doctor, instead of by the police" - Joan Rivers.
2. Quiz AQQ261 about a rectangle area puzzle:
Question:
With the information provided, calculate the area of the big rectangle ABCD.
Good luck!
P.S. Don't hesitate to forward those quizzes to colleagues and friends around you; we need more (active) participants!
Thanks
Kuo-Chang
Please share your answer to view other submitted answers
  • The area of the small rectangle is y*(y-8)
    y*(y-8) = 9
    y^2 -8y = 9
    y^2 -8y -9 = 0
    Factoring:
    (y - 9)(y + 1) = 0
    So y has to be 9 or -1, but in this case has to be the positive integer
    y + 2 = 11 so the length of side AD, x = 12
    The length of side AB = x - 4 = 8
    So the area of the big rectangle ABCD = 8*12 = 96
  • 1. Start by solving y using the smaller Rectangle's (Asmall) given Area. The Area will be:
    A_{\text{SMALL}}\text{ = y\lparen y - 8\rparen}
    Solving for y, we get:
    9=y^2-8y
    y=9,y=-1
    2. Of the two solutions for y, y=9 seems to make more sense when plugging it back. use this value for now.
    3. Solve for x by using the width of the rectangle:
    x=y-8+y+2
    x=2y-6
    substitute y's value and solve for x.
    \text{ }=\text{ }2(9)-6
    This yields x = 12
    4. Solve for area of recatangle ABCD (Abig). The Area will be:
    A_{\text{BIG}}\text{ = x\lparen x-4\rparen}
    substitute x's value into the equation and solve for Abig:
    A_{\text{big}}=12(12-4)
    Abig = 96 sq. units
    While above answer really seems to be bigger than the given rectangle area ( Asmall ) , the given figure doesn't seem to represent this rectangle. it looks more like below:
    otherwise if the values should conform to the figure, then it doesn't exist.
  • the Area9 is: (y-8)*y=9 => y=9
    because x=y-8+y+2=2*y-6 => x=12
    AreaABCD = |AB|*|BC|=(x-4)*x=8*12=96
  • (x-4) * x = area ABCD
    x = (y-8) + (y+2) = 2y-6
    (y-8) * y = 9
    y^2-8y-9 = 0
    (y-9)(y+1) = 0
    y = 9 or -1 *** (can't be -1; therefore, y = 9)
    x = 2y-6 = 2*9 - 6 = 12
    area ABCD = (12-4)*12 = 96
  • The area of ABCD is 96.
    You see that (y-8)*y=9, from which you get y=9 (the other solution of the quadratic equation is negative). Then x= (y-8)+(y+2)-->x=12. So BC=12 and AB=8, from which you get the result.
    Figure is not consistent with the data.
  • Fantastic Martin! You are, again, the first one, congratulations!
  • Bingo  , you get it, and with a crystal clear development!
  • Bravo  , correct (too easy for engineers like you...) but congratulation anyhow!
  • Félicitation  correct! (such quiz is too easy for people like you...)
