A funny algebra puzzle!
a and b are real numbers
We have the following expressions:
a² - b² = 9
a.b = 3
Question: what are the value(s) for a and b ?
Good luck! And try to be among the first ones!
Hide replies until user replies.
[edited by: emassa at 2:37 PM (GMT -5) on 20 Feb 2023]
Please share your answer to view other submitted answers
  • From a.b=3: a=3/b
    Substitute a=3/b to a^2-b^2=9
    (3/b)^2 - b^2 = 9
    9/b^2 - b^2 = 9
    Multiply both sides by b^2
    9 - b^4 = 9b^2
    b^4 + 9b^2 - 9 = 0
    Solving for the roots will obtain the following:
    b1 = √[(-9+3√13)/2]
    b2 = -√[(-9+3√13)/2]
    b3 = √[(-9-3√13)/2]
    b4 = -√[(-9-3√13)/2]
    Since the square root of a negative number is imaginary, b3 and b4 are not answers
    Substitute the values of b to obtain a:
    a1 = 3/√[(-9+3√13)/2]
    a2 = -3/√[(-9+3√13)/2]
    The values for a and b are the following:
    b1 = √[(-9+3√13)/2]
  • a² - b² = (a+b)(a-b) = 9 =3x3
    (a+b) = 3
    (a-b) = 3
    2a = 6
    a=3
    b=0
    cannot be true as b=3/a = 1
  • Starting with:
    a2 – b2 = 9
    a.b = 3
    From second equation:
    b = 3/a
    b2 = 9/a2
    Substitute into first equation:
    a2 – 9/a2 = 9
    Subtract 9 from both sides:
    a2 – 9/a2 – 9 = 0
    Multiply top and bottom by a2
    a4 – 9a2 – 9 = 0
    Let a2 = x
    x2 – 9x – 9 = 0
    General quadratic equation ax2 + bx + c = 0
    a = 1; b = – 9; c = – 9
    Solved by formula x = [–b ± √ (b2 – 4ac)] / 2a
    x = (9 ± √(81+36)) / 2 = (9 ± √(117)) / 2
    Take out a factor of 3 from top
    x = 3(3 + √13) / 2 or x = 3(3 – √13) / 2
    So
    x = 9.908…
    x = –0.908
    As x = a2
    a = √x
    so a = 3.148
    b = 3 / a
    b = 0.953
  • Thank you Gaetano! As recommended by our Engineer Zone administrators, the final answers will be confirmed later (just before the new quiz launch; this always in order to not influence or perturb our other participants who are still trying to answer...
  • Many thanks Fons! It's indeed a little bit more complex with the dot line in a.b not being a simple decimal point...As stated for Gaetano, the final answer will be confirmed in a few days...
  • Thanks a lot Sona for your prompt reply! Your answer will be confirmed in a few days! Stay tuned!
  • Thanks Joachim for your prompt reply! You are right with a=5, b=4 for the first equation (a²-b²=9). But they are not OK for the second equation a*b=3 since 4*5= 20 !
    May be you want to retry?
  • Thanks Mark for your extensive math development. As stated earlier, all the answers will be confirmed (or not) in a few days when the new quiz will be launched. This, mainly to let everybody the chance to try to solve the puzzle....
  • Hello Rajesh! Happy to hear from you again! Thanks to have proposed your answers to this math puzzle (not so simple at the end!). However, what I can say here is : there well real solutions for these equations! Your development is correct but you started with an incomplete assumption already from the beginning. In effect a²-b² can be split as (a-b)*(a+b). BUT then, it is very limitative to just say a+b = 3 and a-b=3. This was because you have assumed only integer values in the equation. There are infinite number of real values a and b satisfying a²-b²=9. May be you want to retry?
  • Thanks Martin for your so detailed development:! As stated previously: "rendez-vous" in few days to see if the anwers are confirmed!
