We would like to use the MAX17320X2EVKIT development kit software to generate a basic configuration for the MAX17320 Fuel Gauge. We are using a LiFePO4 2S1P battery.
The configuration wizard notes that we should contact the manufacturer if we are using a LiFePO4 battery:
We are using 3.2V 2560mAh cells in a 2S1P configuration (ANR26650m1B). The cell datasheet recommends a minimum voltage of 2.5V and a charge voltage of 3.65V.
Are we able to create or download an additional profile/model for this type of battery?
We plan to use two of the thermistors, however this isn't absolutely required.
Thank you for any help in advance!
