dear teams,
Now I porting ADI’s no-OS project to an HDL project based on Xilinx JESD204C. At present, the JESD204B link has not been established.
configuration of my jesd204c:
fpga jesd204c tx:
| Offset address | Register name | Parameter | Actual parameter |
| 0x03C | OFSADDR_CTRL_8B10_CFG | 0x03 0B 1F 03 | ILA multiframes:4 Enable Link Error counters : 1 Error Reporting via sync : 0 ILA Required: 1 Scrambling:1 Frames per Multiframe (K): 1F(32) Octets per Frame (F):3(4) |
| 0x050 | OFSADDR_CTRL_SYSREF | 0x01 | 1 = The core will align the LMFC/LEMC counter on all SYSREF events; no longer configured |
| 0x048 | OFSADDR_CTRL_TEST_MODE | GT loopback: (TX only)00: Normal operation | |
| 0x040 | OFSADDR_CTRL_LANE_ENA | 0x0f | |
| 0x034 | OFSADDR_CTRL_SUB_CLASS | 0x01 | 1 = Subclass 1 |
| 0x074 | CTRL_TX_ILA_CFG1 | 0x00170F07 -> 0x000F0F07 | Control bits per Sample:0 N'=16 N=16 M=8 |
| 0x078 | CTRL_TX_ILA_CFG2 | 0x00 | Control word per Sample:0x0 high density = 0 S=0(1) |
| 0x07C | CTRL_TX_ILA_CFG3 | 0x00 | ADJDIR:0 PHAD:0 ADJCNT:0 |
fpga jesd024c rx:
| Offset address | Register | Parameter | Actual parameter |
| 0x03C | OFSADDR_CTRL_8B10_CFG | 0x030B1F03 | ILA multiframes:4 |
| 0x050 | OFSADDR_CTRL_SYSREF | 0x01 | |
| 0x048 | OFSADDR_CTRL_TEST_MODE | 0x00 | |
adrv9029 framer:
\"framer\": [ \n\
{ \n\
\"serializerLaneCrossbar\": { \n\
\"lane0FramerOutSel\": 0, \n\
\"lane1FramerOutSel\": 1, \n\
\"lane2FramerOutSel\": 2, \n\
\"lane3FramerOutSel\": 3 \n\
}, \n\
\"adcCrossbar\": { \n\
\"conv0\": 1, \n\
\"conv1\": 0, \n\
\"conv2\": 3, \n\
\"conv3\": 2, \n\
\"conv4\": 5, \n\
\"conv5\": 4, \n\
\"conv6\": 7, \n\
\"conv7\": 6, \n\
\"conv8\": 127, \n\
\"conv9\": 127, \n\
\"conv10\": 127, \n\
\"conv11\": 127, \n\
\"conv12\": 127, \n\
\"conv13\": 127, \n\
\"conv14\": 127, \n\
\"conv15\": 127, \n\
\"conv16\": 127, \n\
\"conv17\": 127, \n\
\"conv18\": 127, \n\
\"conv19\": 127, \n\
\"conv20\": 127, \n\
\"conv21\": 127, \n\
\"conv22\": 127, \n\
\"conv23\": 127 \n\
}, \n\
\"enableJesd204C\": 0, \n\
\"bankId\": 0, \n\
\"deviceId\": 1, \n\
\"lane0Id\": 0, \n\
\"jesd204M\": 8, \n\
\"jesd204K\": 32, \n\
\"jesd204F\": 4, \n\
\"jesd204Np\": 16, \n\
\"jesd204E\": 0, \n\
\"scramble\": 1, \n\
\"serializerLanesEnabled\": 15, \n\
\"lmfcOffset\": 0, \n\
\"syncbInSelect\": 0, \n\
\"overSample\": 0, \n\
\"syncbInLvdsMode\": 1, \n\
\"syncbInLvdsPnInvert\": 1, \n\
\"newSysrefOnRelink\": 0, \n\
\"sysrefForStartup\": 0, \n\
\"sysrefNShotEnable\": 0, \n\
\"sysrefNShotCount\": 0, \n\
\"sysrefIgnoreWhenLinked\": 0 \n\
}, \n\
\"serCfg\": [ \n\
{ \n\
\"serAmplitude\": 0, \n\
\"serPreEmphasis\": 0, \n\
\"serPostEmphasis\": 0, \n\
\"serInvertLanePolarity\": 1 \n\
}, \n\
{ \n\
}, \n\
{ \n\
}, \n\
{ \n\
} \n\
], \n\
adrv9029 deframer:
\"deframer\": [ \n\
{ \n\
\"deserializerLaneCrossbar\": { \n\
\"deframerInput0LaneSel\": 0, \n\
\"deframerInput1LaneSel\": 1, \n\
\"deframerInput2LaneSel\": 2, \n\
\"deframerInput3LaneSel\": 3 \n\
}, \n\
\"bankId\": 0, \n\
\"lane0Id\": 0, \n\
\"deserializerLanesEnabled\": 15, \n\
\"syncbOutSelect\": 0, \n\
\"syncbOutLvdsMode\": 1, \n\
\"syncbOutLvdsPnInvert\": 0, \n\
\"syncbOutCmosSlewRate\": 0, \n\
\"syncbOutCmosDriveLevel\": 0, \n\
\"dacCrossbar\": { \n\
\"tx1DacChanI\": 1, \n\
\"tx1DacChanQ\": 0, \n\
\"tx2DacChanI\": 3, \n\
\"tx2DacChanQ\": 2, \n\
\"tx3DacChanI\": 5, \n\
\"tx3DacChanQ\": 4, \n\
\"tx4DacChanI\": 7, \n\
\"tx4DacChanQ\": 6 \n\
}, \n\
\"sysrefForStartup\": 1, \n\
}, \n\
\"desCfg\": [ \n\
{ \n\
\"highBoost\": 0, \n\
\"configOption1\": 0, \n\
\"configOption2\": 0, \n\
\"configOption3\": 0, \n\
\"configOption4\": 0, \n\
\"configOption5\": 0, \n\
\"configOption6\": 0, \n\
\"configOption7\": 0, \n\
\"configOption8\": 0, \n\
\"configOption9\": 0, \n\
\"configOption10\": 0, \n\
\"desInvertLanePolarity\": 0 \n\
}, \n\
{ \n\
\"desInvertLanePolarity\": 1 \n\
}, \n\
{ \n\
}, \n\
{ \n\
} \n\
], \n\
Debuging result:
| data | - |
| tx_sync | 1 |
| rx_reset_done | 1 |
FPGA TX_STAT_STATUS: 0x1002(SYSREF captured)
| bit | value | description |
| 15 | 1 | 8b10b 1= 8b10b rx misalignment has been detected. |
| 14 | 0 | 8b10b 1= the link has started outputting data on the axi-stream port |
| 13 | 0 | 8b10b 1 = The link has achieved Code Group Sync |
| 12 | 0 | 8b10b 1 = The receiver has signaled SYNC has been achieved. |
| 10 | 0 | 1 = The receiver buffer has overflowed. |
| 5 | 0 | 64B66B |
| 4 | 0 | 64B66B |
| 2 | 0 | SYSREF error |
| 1 | 1 | SYSREF captured |
| 0 | 0 | Interrupt pending |
adi_adrv9025_DeframerStatusGet() returned data: 0x12 (FS LOST, frame synchronization lost, sysref received; the correct value should be 0x87)
| status bit | value | description |
| 7 | 0 | Valid checksum |
| 6 | 0 | EOF Event |
| 5 | 0 | EOMF Event |
| 4 | 1 | FS lost; frame synchronization |
| 3 | 0 | user data valid |
| 2 | 0 | reserved |
| 1 | 1 | sysref received |
| 0 | 0 |
RX ADC Link (ADRV9029 ADC FRAMER -> FPGA RX DEFRAMER)
Data captured by FPGA ILA:
| rx_sync | 0 |
| data | - |
| rx_reset_done | 1 |
FPGA RX_STAT_STATUS:0x2 (SYSREF capturedd)
| 15 | 0 | 8b10b 1= 8b10b rx misalignment has been detected. |
| 5 | 0 | 64B66B |
| 4 | 0 | 64B66B |
adi_adrv9025_FramerStatusGet() returned data: 0x0A (SYNCIN LEVEL 1, SYSREF phase established by framer; the correct value should be 0x0A)
| 7 | 0 | reserved |
| 6 | 0 | reserved |
| 5 | 0 | reserved |
| 4 | 0 | reserved |
| 3 | 1 | SYNCIN LEVEL(1 high 0 low) |
| 2 | 0 | SYSREF phase error |
| 1 | 1 | SYSREF phase established by framer |
| 0 | 0 | Configuration error: 1 |
my hdl prj(vivado2025.1):drive.google.com/.../view
my noos prj and cfg file:https://drive.google.com/file/d/1QK4T439lnm6Kb3SLwF1wWA0J9sXEjrMb/view?usp=drive_link
Where should I start troubleshooting this issue?
best regards,
zjy
