ADRV9009 JESD204B Testbench Build Issues on ZCU102 — HDL 2022_R2
The user encountered build issues with the testbench repository for the JESD204B interface framework targeting the ADRV9009 project on the ZCU102 evaluation board using tag version 2022_r2. The support engineer suggested that the issue might be due to the outdated tag and recommended using the latest main or release version of the repository, as 2022_R2 is no longer supported.
Software Version: Vivado 2022.2
I am building the HDL and testbench repositories for the JESD204B interface framework targeting the ADRV9009 project on the ZCU102 evaluation board.
HDL Repository The HDL repository has been built successfully using tag version 2022_R2. Reference: https://analogdevicesinc.github.io/hdl/projects/adrv9009/index.html
Testbench Repository The testbench repository (tag version 2022_r2) is encountering build issues. The details are as follows:
The suggested log file shows as following:
Vivado version: 2022.2
Is this a tag mismatch issue, and can it be solved by using a compatible version?
Thread Notes
