Functional simulation Testing the axi_ad9361 IP core error.
Product Number: AD9364
Software Version: Vivado 2021.1
****** Vivado v2021.1 (64-bit)
  **** SW Build 3247384 on Thu Jun 10 19:36:07 MDT 2021
  **** IP Build 3246043 on Fri Jun 11 00:30:35 MDT 2021
    ** Copyright 1986-2021 Xilinx, Inc. All Rights Reserved.
source system_project.tcl
# source ../../../scripts/adi_sim.tcl
## variable adi_sim_defines {}
## variable design_name "test_harness"
## global ad_hdl_dir
## global ad_tb_dir
## source ../../../scripts/adi_tb_env.tcl
### if [info exists ::env(ADI_HDL_DIR)] {
###   set ad_hdl_dir [file normalize $::env(ADI_HDL_DIR)]
### } else {
###   error "Missing ADI_HDL_DIR environment variable definition!"
### set ad_tb_dir [file normalize [file join [file dirname [info script]] "../"]]
### if [info exists ::env(ADI_TB_DIR)] {
###   set ad_tb_dir [file normalize $::env(ADI_TB_DIR)]
### source $ad_hdl_dir/scripts/adi_env.tcl
#### set ad_hdl_dir [file normalize [file join [file dirname [info script]] "../"]]
#### if [info exists ::env(ADI_HDL_DIR)] {
####   set ad_hdl_dir [file normalize $::env(ADI_HDL_DIR)]
#### if [info exists ::env(ADI_GHDL_DIR)] {
####   set ad_ghdl_dir [file normalize $::env(ADI_GHDL_DIR)]
#### set required_vivado_version "2023.2"
#### if {[info exists ::env(REQUIRED_VIVADO_VERSION)]} {
####   set required_vivado_version $::env(REQUIRED_VIVADO_VERSION)
#### } elseif {[info exists REQUIRED_VIVADO_VERSION]} {
####   set required_vivado_version $REQUIRED_VIVADO_VERSION
#### if {[info exists ::env(ADI_IGNORE_VERSION_CHECK)]} {
####   set IGNORE_VERSION_CHECK 1
#### } elseif {![info exists IGNORE_VERSION_CHECK]} {
####   set IGNORE_VERSION_CHECK 0
#### if {![info exists REQUIRED_QUARTUS_VERSION]} {
####   set REQUIRED_QUARTUS_VERSION "23.2.0"
#### set required_lattice_version "2023.2"
#### if {[info exists ::env(REQUIRED_LATTICE_VERSION)]} {
####   set required_lattice_version $::env(REQUIRED_LATTICE_VERSION)
#### } elseif {[info exists REQUIRED_LATTICE_VERSION]} {
####   set required_lattice_version $REQUIRED_LATTICE_VERSION
#### proc get_env_param {name default_value} {
####   if [info exists ::env($name)] {
####     puts "Getting from environment the parameter: $name=$::env($name) "
####     return $::env($name)
####   } else {
####     return $default_value
## source $ad_hdl_dir/projects/scripts/adi_board.tcl
### package require math
### set sys_cpu_interconnect_index 0
### set sys_hpc0_interconnect_index -1
### set sys_hpc1_interconnect_index -1
### set sys_hp0_interconnect_index -1
### set sys_hp1_interconnect_index -1
### set sys_hp2_interconnect_index -1
### set sys_hp3_interconnect_index -1
### set sys_mem_interconnect_index -1
### set sys_mem_clk_index 0
### set xcvr_index -1
### set xcvr_tx_index 0
### set xcvr_rx_index 0
### set xcvr_instance NONE
### set use_smartconnect 1
### proc ad_ip_instance {i_ip i_name {i_params {}}} {
###   set cell [create_bd_cell -type ip -vlnv [get_ipdefs -all -filter "VLNV =~ *:${i_ip}:* && \
###     design_tool_contexts =~ *IPI* && UPGRADE_VERSIONS == \"\""] ${i_name}]
###   if {$i_params != {}} {
###     set config {}
###     # Add CONFIG. prefix to all config options
###     foreach {k v} $i_params {
###       lappend config "CONFIG.$k" $v
###     set_property -dict $config $cell
### proc ad_ip_parameter {i_name i_param i_value} {
###   set_property ${i_param} ${i_value} [get_bd_cells ${i_name}]
### proc ad_connect_type {p_name} {
###   set m_name ""
###   if {$m_name eq ""} {set m_name [get_bd_intf_pins  -quiet $p_name]}
###   if {$m_name eq ""} {set m_name [get_bd_pins       -quiet $p_name]}
###   if {$m_name eq ""} {set m_name [get_bd_intf_ports -quiet $p_name]}
###   if {$m_name eq ""} {set m_name [get_bd_ports      -quiet $p_name]}
###   if {$m_name eq ""} {set m_name [get_bd_intf_nets  -quiet $p_name]}
###   if {$m_name eq ""} {set m_name [get_bd_nets       -quiet $p_name]}
###   return $m_name
### proc ad_connect_int_class {p_name} {
###   set m_name ""
###   # All ports can be handled as pins
###   # if {$m_name eq ""} {set m_name [get_bd_intf_ports -quiet $p_name]}
###   # if {$m_name eq ""} {set m_name [get_bd_ports      -quiet $p_name]}
###   if {!($m_name eq "")} {
###     return [get_property CLASS $m_name]
###   if {$p_name eq "GND" || $p_name eq "VCC"} {
###     return "const"
###   return "newnet"
### proc ad_connect_int_get_const {name width} {
###   switch $name {
###     GND {
###       set value 0
###     VCC {
###       set value [expr (1 << $width) - 1]
###     default {
###       error "ERROR: ad_connect_int_get_const: Unhandled constant name $name"
###   set cell_name "$name\_$width"
###   set cell [get_bd_cells -quiet $cell_name]
###   if {$cell eq ""} {
###     # Create new constant source
###     ad_ip_instance xlconstant $cell_name
###     set_property CONFIG.CONST_WIDTH $width $cell
###     set_property CONFIG.CONST_VAL $value $cell
###   return $cell
### proc ad_connect_int_width {obj} {
###   if {$obj eq ""} {
###     error "ERROR: ad_connect_int_width: No object provided."
###   set classname [get_property -quiet CLASS $obj]
###   if {$classname eq ""} {
###     error "ERROR: ad_connect_int_width: Cannot determine width of class-less object: $obj"
###   if {[string first intf $classname] != -1} {
###     error "ERROR: ad_connect_int_width: Cannot determine width of interface object: $obj ($classname)"
###   if {([get_property -quiet LEFT $obj] eq "") || ([get_property -quiet RIGHT $obj] eq "")} {
###     return 1
###   set left [get_property LEFT $obj]
###   set right [get_property RIGHT $obj]
###   set high [::math::max $left $right]
###   set low [::math::min $left $right]
###   return [expr {1 + $high - $low}]
### proc ad_connect {name_a name_b} {
###   set type_a [ad_connect_int_class $name_a]
###   set type_b [ad_connect_int_class $name_b]
###   set obj_a [ad_connect_type $name_a]
###   set obj_b [ad_connect_type $name_b]
###   if {!([string first intf $type_a]+1) != !([string first intf $type_b]+1)} {
###     error "ERROR: ad_connect: Cannot connect non-interface to interface: $name_a ($type_a) <-/-> $name_b ($type_b)"
###   switch $type_a,$type_b {
###     newnet,newnet {
###       error "ERROR: ad_connect: Cannot create connection between two new nets: $name_a <-/-> $name_b"
###     const,const {
###       error "ERROR: ad_connect: Cannot connect constant to constant: $name_a <-/-> $name_b"
###     bd_net,bd_net -
###     bd_intf_net,bd_intf_net {
###       error "ERROR: ad_connect: Cannot connect (intf) net to (intf) net: $name_a ($type_a) <-/-> $name_b ($type_b)"
###     bd_net,newnet -
###     newnet,bd_net {
###       error "ERROR: ad_connect: Cannot connect existing net to new net: $name_a ($type_a) <-/-> $name_b ($type_b)"
###     const,newnet -
###     newnet,const {
###       error "ERROR: ad_connect: Cannot connect new network to constant, instead you should connect to the constant directly: $name_a ($type_a) <-/-> $name_b ($type_b)"
###     bd_pin,bd_pin {
###       connect_bd_net $obj_a $obj_b
###       puts "connect_bd_net $obj_a $obj_b"
###       return
###     bd_net,bd_pin {
###       connect_bd_net -net $obj_a $obj_b
###       puts "connect_bd_net -net $obj_a $obj_b"
###       return
###     bd_pin,bd_net {
###       connect_bd_net -net $obj_b $obj_a
###       puts "connect_bd_net -net $obj_b $obj_a"
###       return
###     bd_pin,newnet {
###       connect_bd_net -net $name_b $obj_a
###       puts "connect_bd_net -net $name_b $obj_a"
###       return
###     newnet,bd_pin {
###       connect_bd_net -net $name_a $obj_b
###       puts "connect_bd_net -net $name_a $obj_b"
###       return
###     bd_intf_pin,bd_intf_pin {
###       connect_bd_intf_net $obj_a $obj_b
###       puts "connect_bd_intf_net $obj_a $obj_b"
###       return
###     const,bd_pin -
###     const,bd_net {
###       # Handled after the switch statement
###     bd_net,const -
###     bd_pin,const {
###       # Swap vars
###       set tmp $obj_a
###       set obj_a $obj_b
###       set obj_b $tmp
###       set tmp $name_a
###       set name_a $name_b
###       set name_b $tmp
###     default {
###       error "ERROR: ad_connect: Cannot connect, case unhandled: $name_a ($type_a) <-/-> $name_b ($type_b)"
###   # Continue working on nets that connect to constant. obj_b is the net/pin
###   set width [ad_connect_int_width $obj_b]
###   set cell [ad_connect_int_get_const $name_a $width]
###   connect_bd_net [get_bd_pin $cell/dout] $obj_b
###   puts "connect_bd_net [get_bd_pin $cell/dout] $obj_b"
### proc ad_disconnect {p_name_1 p_name_2} {
###   set m_name_1 [ad_connect_type $p_name_1]
###   set m_name_2 [ad_connect_type $p_name_2]
###   if {[get_property CLASS $m_name_1] eq "bd_net"} {
###     disconnect_bd_net $m_name_1 $m_name_2
###     return
###   if {[get_property CLASS $m_name_1] eq "bd_port"} {
###     delete_bd_objs -quiet [get_bd_nets -quiet -of_objects \
###       [find_bd_objs -relation connected_to $m_name_1]]
###     delete_bd_objs -quiet $m_name_1
###     return
###   if {[get_property CLASS $m_name_1] eq "bd_pin"} {
###     return
### proc ad_xcvrcon {u_xcvr a_xcvr a_jesd {lane_map {}} {link_clk {}} {device_clk {}} {num_of_max_lanes -1} {partial_lane_map {}} {connect_empty_lanes 1}} {
###   global xcvr_index
###   global xcvr_tx_index
###   global xcvr_rx_index
###   global xcvr_instance
###   set qpll_enable [get_property CONFIG.QPLL_ENABLE [get_bd_cells $a_xcvr]]
###   set tx_or_rx_n [get_property CONFIG.TX_OR_RX_N [get_bd_cells $a_xcvr]]
###   set xcvr_type [get_property CONFIG.XCVR_TYPE [get_bd_cells $u_xcvr]]
###   set link_mode_u [get_property CONFIG.LINK_MODE [get_bd_cells $u_xcvr]]
###   set link_mode_a [get_property CONFIG.LINK_MODE [get_bd_cells $a_xcvr]]
###   if {$link_mode_u != $link_mode_a} {
###      puts "CRITICAL WARNING: LINK_MODE parameter mismatch between $u_xcvr ($link_mode_u) and $a_xcvr ($link_mode_a)"
###   set link_mode $link_mode_u
###   set jesd204_bd_type [get_property TYPE [get_bd_cells $a_jesd]]
###   if {$jesd204_bd_type == "hier"} {
###     set jesd204_type 0
###   } else {
###     set jesd204_type 1
###   if {$xcvr_instance ne $u_xcvr} {
###     set xcvr_index [expr ($xcvr_index + 1)]
###     set xcvr_instance $u_xcvr
###   set txrx "rx"
###   set data_dir "I"
###   set ctrl_dir "O"
###   set index $xcvr_rx_index
###   if {$tx_or_rx_n == 1} {
###     set txrx "tx"
###     set data_dir "O"
###     set ctrl_dir "I"
###     set index $xcvr_tx_index
###   set m_sysref ${txrx}_sysref_${index}
###   set m_sync ${txrx}_sync_${index}
###   set m_data ${txrx}_data
###   if {$xcvr_index >= 1} {
###     set m_sysref ${txrx}_sysref_${xcvr_index}_${index}
###     set m_sync ${txrx}_sync_${xcvr_index}_${index}
###     set m_data ${txrx}_data_${xcvr_index}
###   if {$jesd204_type == 0} {
###     set num_of_links [get_property CONFIG.NUM_LINKS [get_bd_cells $a_jesd/$txrx]]
###   } else {
###     set num_of_links 1
###   set no_of_lanes [get_property CONFIG.NUM_LANES [get_bd_cells $a_jesd/$txrx]]
###   set max_no_of_lanes $no_of_lanes
###   if {$num_of_max_lanes != -1} {
###     set max_no_of_lanes $num_of_max_lanes
###   create_bd_port -dir I $m_sysref
###   create_bd_port -from [expr $num_of_links - 1] -to 0 -dir ${ctrl_dir} $m_sync
###   set use_2x_clk 0
###   if {$link_clk == {}} {
###     # For 204C modes on GTH a 2x clock is required to drive the PCS
###     # In such case set the xcvr out clock to be the double of the lane rate/66(40)
###     # and use the secondary div2 clock output for the link clock
###     if {$link_mode == 2 && ($xcvr_type == 5 || $xcvr_type == 8)} {
###       set link_clk ${u_xcvr}/${txrx}_out_clk_div2_${index}
###       set link_clk_2x ${u_xcvr}/${txrx}_out_clk_${index}
###       set use_2x_clk 1
###     } else {
###       if {$partial_lane_map != {}} {
###         set cur_index [lindex $partial_lane_map $index]
###         set link_clk ${u_xcvr}/${txrx}_out_clk_${cur_index}
###       } else {
###         set link_clk ${u_xcvr}/${txrx}_out_clk_${index}
###     set rst_gen [regsub -all "/" ${a_jesd}_rstgen "_"]
###     set create_rst_gen 1
###   } else {
###     set rst_gen ${link_clk}_rstgen
###     # Only create one reset gen per clock
###     set create_rst_gen [expr {[get_bd_cells -quiet ${rst_gen}] == {}}]
###   if {$device_clk == {}} {
###     set device_clk $link_clk
###   } else {
###     set rst_gen ${device_clk}_rstgen
###   if {${create_rst_gen}} {
###     ad_ip_instance proc_sys_reset ${rst_gen}
###     ad_connect ${device_clk} ${rst_gen}/slowest_sync_clk
###     ad_connect sys_cpu_resetn ${rst_gen}/ext_reset_in
###     for {set n 0} {$n < $no_of_lanes} {incr n} {
###       set phys_lane [lindex $partial_lane_map $n]
###       if {$phys_lane != {}} {
###           ad_connect  ${u_xcvr}/${txrx}_${phys_lane} ${a_jesd}/${txrx}_phy${n}
###         } else {
###           ad_connect  ${u_xcvr}/${txrx}_${phys_lane} ${a_jesd}/gt${n}_${txrx}
###       if {$tx_or_rx_n == 0} {
###           if {$link_mode == 1} {
###             ad_connect  ${a_jesd}/phy_en_char_align ${u_xcvr}/${txrx}_calign_${phys_lane}
###         } else {
###           ad_connect  ${a_jesd}/rxencommaalign_out ${u_xcvr}/${txrx}_calign_${phys_lane}
###     if {$connect_empty_lanes == 1} {
###       for {set n 0} {$n < $max_no_of_lanes} {incr n} {
###         set m [expr ($n + $index)]
###         if {$lane_map != {}} {
###           set phys_lane [lindex $lane_map $n]
###         } else {
###           set phys_lane $m
###           ad_connect  ${a_xcvr}/up_es_${n} ${u_xcvr}/up_es_${phys_lane}
###         if {(($n%4) == 0) && ($qpll_enable == 1)} {
###           ad_connect  ${a_xcvr}/up_cm_${n} ${u_xcvr}/up_cm_${m}
###         ad_connect  ${a_xcvr}/up_ch_${n} ${u_xcvr}/up_${txrx}_${phys_lane}
###         ad_connect  ${link_clk} ${u_xcvr}/${txrx}_clk_${phys_lane}
###         if {$use_2x_clk == 1} {
###           ad_connect  ${link_clk_2x} ${u_xcvr}/${txrx}_clk_2x_${phys_lane}
###         create_bd_port -dir ${data_dir} ${m_data}_${m}_p
###         create_bd_port -dir ${data_dir} ${m_data}_${m}_n
###         ad_connect  ${u_xcvr}/${txrx}_${m}_p ${m_data}_${m}_p
###         ad_connect  ${u_xcvr}/${txrx}_${m}_n ${m_data}_${m}_n
###     } else {
###       ## Do nothing, the connections will be done manually
###   } else {
###       } else {
###         } else {
###         } else {
###     for {set n $no_of_lanes} {$n < $max_no_of_lanes} {incr n} {
###       } else {
###     ad_connect  ${a_jesd}/sysref $m_sysref
###       ad_connect  ${a_jesd}/sync $m_sync
###     ad_connect  ${device_clk} ${a_jesd}/device_clk
###     ad_connect  ${link_clk} ${a_jesd}/link_clk
###   } else {
###     ad_connect  ${a_jesd}/${txrx}_sysref $m_sysref
###     ad_connect  ${a_jesd}/${txrx}_sync $m_sync
###     ad_connect  ${device_clk} ${a_jesd}/${txrx}_core_clk
###     ad_connect  ${a_xcvr}/up_status ${a_jesd}/${txrx}_reset_done
###     ad_connect  ${rst_gen}/peripheral_reset ${a_jesd}/${txrx}_reset
###     set xcvr_rx_index [expr ($xcvr_rx_index + $max_no_of_lanes)]
###     set xcvr_tx_index [expr ($xcvr_tx_index + $max_no_of_lanes)]
### proc ad_xcvrpll {m_src m_dst} {
###   foreach p_dst [get_bd_pins -quiet $m_dst] {
###     connect_bd_net [ad_connect_type $m_src] $p_dst
### proc ad_mem_hpc0_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HPC0" $p_clk $p_name}
### proc ad_mem_hpc1_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HPC1" $p_clk $p_name}
### proc ad_mem_hp0_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {($sys_zynq != 1 && $sys_zynq != 2) && ($p_name eq "sys_ps7/S_AXI_HP0")} {return}
###   if {$sys_zynq == -1} {ad_mem_hpx_interconnect "SIM" $p_clk $p_name}
###   if {$sys_zynq == 0} {ad_mem_hpx_interconnect "MEM" $p_clk $p_name}
###   if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP0" $p_clk $p_name}
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HP0" $p_clk $p_name}
###   if {$sys_zynq == 3} {ad_mem_hpx_interconnect "NOC" $p_clk $p_name}
### proc ad_mem_hp1_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {($sys_zynq != 1 && $sys_zynq != 2) && ($p_name eq "sys_ps7/S_AXI_HP1")} {return}
###   if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP1" $p_clk $p_name}
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HP1" $p_clk $p_name}
### proc ad_mem_hp2_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {($sys_zynq != 1 && $sys_zynq != 2) && ($p_name eq "sys_ps7/S_AXI_HP2")} {return}
###   if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP2" $p_clk $p_name}
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HP2" $p_clk $p_name}
### proc ad_mem_hp3_interconnect {p_clk p_name} {
###   global sys_zynq
###   if {($sys_zynq != 1 && $sys_zynq != 2) && ($p_name eq "sys_ps7/S_AXI_HP3")} {return}
###   if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP3" $p_clk $p_name}
###   if {$sys_zynq == 2} {ad_mem_hpx_interconnect "HP3" $p_clk $p_name}
### proc ad_mem_hpx_interconnect {p_sel p_clk p_name} {
###   global sys_zynq
###   global sys_ddr_addr_seg
###   global sys_hpc0_interconnect_index
###   global sys_hpc1_interconnect_index
###   global sys_hp0_interconnect_index
###   global sys_hp1_interconnect_index
###   global sys_hp2_interconnect_index
###   global sys_hp3_interconnect_index
###   global sys_mem_interconnect_index
###   global sys_mem_clk_index
###   global use_smartconnect
###   set p_name_int $p_name
###   set p_clk_source [get_bd_pins -filter {DIR == O} -of_objects [get_bd_nets $p_clk]]
###   set connect_type "smartconnect"
###   if {$use_smartconnect == 0} {
###     set connect_type "axi_interconnect"
###   if {$p_sel eq "SIM"} {
###     if {$sys_mem_interconnect_index < 0} {
###       ad_ip_instance $connect_type axi_mem_interconnect
###     set m_interconnect_index $sys_mem_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_mem_interconnect]
###     set m_addr_seg [get_bd_addr_segs -of_objects [get_bd_cells ddr_axi_vip]]
###   if {$p_sel eq "MEM"} {
###     set m_addr_seg [get_bd_addr_segs -of_objects [get_bd_cells axi_ddr_cntrl] -filter "USAGE == memory"]
###   if {($p_sel eq "HP0") && ($sys_zynq == 1)} {
###     if {$sys_hp0_interconnect_index < 0} {
###       set p_name_int sys_ps7/S_AXI_HP0
###       set_property CONFIG.PCW_USE_S_AXI_HP0 {1} [get_bd_cells sys_ps7]
###       ad_ip_instance $connect_type axi_hp0_interconnect
###     set m_interconnect_index $sys_hp0_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hp0_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP0/HP0_DDR_LOWOCM]
###   if {($p_sel eq "HP1") && ($sys_zynq == 1)} {
###     if {$sys_hp1_interconnect_index < 0} {
###       set p_name_int sys_ps7/S_AXI_HP1
###       set_property CONFIG.PCW_USE_S_AXI_HP1 {1} [get_bd_cells sys_ps7]
###       ad_ip_instance $connect_type axi_hp1_interconnect
###     set m_interconnect_index $sys_hp1_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hp1_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP1/HP1_DDR_LOWOCM]
###   if {($p_sel eq "HP2") && ($sys_zynq == 1)} {
###     if {$sys_hp2_interconnect_index < 0} {
###       set p_name_int sys_ps7/S_AXI_HP2
###       set_property CONFIG.PCW_USE_S_AXI_HP2 {1} [get_bd_cells sys_ps7]
###       ad_ip_instance $connect_type axi_hp2_interconnect
###     set m_interconnect_index $sys_hp2_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hp2_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP2/HP2_DDR_LOWOCM]
###   if {($p_sel eq "HP3") && ($sys_zynq == 1)} {
###     if {$sys_hp3_interconnect_index < 0} {
###       set p_name_int sys_ps7/S_AXI_HP3
###       set_property CONFIG.PCW_USE_S_AXI_HP3 {1} [get_bd_cells sys_ps7]
###       ad_ip_instance $connect_type axi_hp3_interconnect
###     set m_interconnect_index $sys_hp3_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hp3_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP3/HP3_DDR_LOWOCM]
###   if {($p_sel eq "HPC0") && ($sys_zynq == 2)} {
###     if {$sys_hpc0_interconnect_index < 0} {
###       set p_name_int sys_ps8/S_AXI_HPC0_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP0 {1} [get_bd_cells sys_ps8]
###       set_property CONFIG.PSU__AFI0_COHERENCY {1} [get_bd_cells sys_ps8]
###       ad_ip_instance $connect_type axi_hpc0_interconnect
###     set m_interconnect_index $sys_hpc0_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hpc0_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP0/HPC0_DDR_*]
###   if {($p_sel eq "HPC1") && ($sys_zynq == 2)} {
###     if {$sys_hpc1_interconnect_index < 0} {
###       set p_name_int sys_ps8/S_AXI_HPC1_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP1 {1} [get_bd_cells sys_ps8]
###       set_property CONFIG.PSU__AFI1_COHERENCY {1} [get_bd_cells sys_ps8]
###       ad_ip_instance $connect_type axi_hpc1_interconnect
###     set m_interconnect_index $sys_hpc1_interconnect_index
###     set m_interconnect_cell [get_bd_cells axi_hpc1_interconnect]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP1/HPC1_DDR_*]
###   if {($p_sel eq "HP0") && ($sys_zynq == 2)} {
###       set p_name_int sys_ps8/S_AXI_HP0_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP2 {1} [get_bd_cells sys_ps8]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP2/HP0_DDR_*]
###   if {($p_sel eq "HP1") && ($sys_zynq == 2)} {
###       set p_name_int sys_ps8/S_AXI_HP1_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP3 {1} [get_bd_cells sys_ps8]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP3/HP1_DDR_*]
###   if {($p_sel eq "HP2") && ($sys_zynq == 2)} {
###       set p_name_int sys_ps8/S_AXI_HP2_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP4 {1} [get_bd_cells sys_ps8]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP4/HP2_DDR_*]
###   if {($p_sel eq "HP3") && ($sys_zynq == 2)} {
###       set p_name_int sys_ps8/S_AXI_HP3_FPD
###       set_property CONFIG.PSU__USE__S_AXI_GP5 {1} [get_bd_cells sys_ps8]
###     set m_addr_seg [get_bd_addr_segs sys_ps8/SAXIGP5/HP3_DDR_*]
###   if {$p_sel eq "NOC"} {
###     set m_interconnect_index [get_property CONFIG.NUM_SI [get_bd_cells axi_noc_0]]
###     set m_interconnect_cell [get_bd_cells axi_noc_0]
###     set m_addr_seg [get_bd_addr_segs  axi_noc_0/S[format "%02s" [expr $m_interconnect_index +1]]_AXI/C0_DDR_LOW0]
###     set sys_mem_clk_index [expr [get_property CONFIG.NUM_CLKS [get_bd_cells axi_noc_0]]-1]
###   set i_str "S$m_interconnect_index"
###   if {$m_interconnect_index < 10} {
###     set i_str "S0$m_interconnect_index"
###   set m_interconnect_index [expr $m_interconnect_index + 1]
###   set p_intf_name [lrange [split $p_name_int "/"] end end]
###   set p_cell_name [lrange [split $p_name_int "/"] 0 0]
###   set p_intf_clock [get_bd_pins -filter "TYPE == clk && (CONFIG.ASSOCIATED_BUSIF == ${p_intf_name} || \
###     CONFIG.ASSOCIATED_BUSIF =~ ${p_intf_name}:* || CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name} || \
###     CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name}:*)" -quiet -of_objects [get_bd_cells $p_cell_name]]
###   if {[find_bd_objs -quiet -relation connected_to $p_intf_clock] ne "" ||
###       $p_intf_clock eq $p_clk_source} {
###     set p_intf_clock ""
###   regsub clk $p_clk resetn p_rst
###   if {[get_bd_nets -quiet $p_rst] eq ""} {
###     set p_rst sys_cpu_resetn
###   if {$m_interconnect_index == 0} {
###     set_property CONFIG.NUM_MI 1 $m_interconnect_cell
###     set_property CONFIG.NUM_SI 1 $m_interconnect_cell
###     ad_connect $p_rst $m_interconnect_cell/ARESETN
###     ad_connect $p_clk $m_interconnect_cell/ACLK
###     ad_connect $m_interconnect_cell/M00_AXI $p_name_int
###       ad_connect $p_rst $m_interconnect_cell/M00_ARESETN
###       ad_connect $p_clk $m_interconnect_cell/M00_ACLK
###     if {$p_intf_clock ne ""} {
###       ad_connect $p_clk $p_intf_clock
###   } else {
###     set_property CONFIG.NUM_SI $m_interconnect_index $m_interconnect_cell
###     if {$use_smartconnect == 1} {
###       set clk_index [lsearch [get_bd_nets -of_object [get_bd_pins $m_interconnect_cell/ACLK*]] [get_bd_nets $p_clk]]
###       if { $clk_index == -1 } {
###           incr sys_mem_clk_index
###           set_property CONFIG.NUM_CLKS [expr $sys_mem_clk_index +1] $m_interconnect_cell
###           ad_connect $p_clk $m_interconnect_cell/ACLK$sys_mem_clk_index
###           set asocc_clk_pin  $m_interconnect_cell/ACLK$sys_mem_clk_index
###       } else {
###         set asocc_clk_pin [lindex [get_bd_pins $m_interconnect_cell/ACLK*] $clk_index]
###     } else {
###       ad_connect $p_rst $m_interconnect_cell/${i_str}_ARESETN
###       ad_connect $p_clk $m_interconnect_cell/${i_str}_ACLK
###     ad_connect $m_interconnect_cell/${i_str}_AXI $p_name_int
###       set_property -dict [list CONFIG.CONNECTIONS {MC_0 { read_bw {1720} write_bw {1720} read_avg_burst {4} write_avg_burst {4}} }] [get_bd_intf_pins /axi_noc_0/${i_str}_AXI]
###       # Add the new bus as associated to the clock pin, append new if other exists
###       set clk_asoc_port [get_property CONFIG.ASSOCIATED_BUSIF [get_bd_pins $asocc_clk_pin]]
###       if {$clk_asoc_port != {}} {
###        set clk_asoc_port ${clk_asoc_port}:
###       set_property -dict [list CONFIG.ASSOCIATED_BUSIF ${clk_asoc_port}${i_str}_AXI] [get_bd_pins $asocc_clk_pin]
###     set mem_mapped ""
###       # Search a DDR segment that is at least 16MB
###       set mem_mapped [get_bd_addr_segs -of [get_bd_addr_spaces -of  [get_bd_intf_pins -filter {NAME=~ *DLMB*} -of [get_bd_cells /sys_mb]]] -regexp -filter {NAME=~ ".*ddr.*" && RANGE=~".*0{6}$"}]
###       set mem_mapped [get_bd_addr_segs -of [get_bd_addr_spaces -of  [get_bd_intf_pins -filter {NAME=~ *M_AXI*} -of [get_bd_cells /mng_axi_vip]]] -filter {NAME=~ *DDR* || NAME=~ *ddr*}]
###     if {$mem_mapped eq ""} {
###       assign_bd_address $m_addr_seg
###     } else {
###       assign_bd_address -offset [get_property OFFSET $mem_mapped] \
###                         -range  [get_property RANGE $mem_mapped] $m_addr_seg
###   if {($use_smartconnect == 0) && ($m_interconnect_index > 1)} {
###     set_property CONFIG.STRATEGY {2} $m_interconnect_cell
###   if {$p_sel eq "SIM"} {set sys_mem_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "MEM"} {set sys_mem_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HPC0"} {set sys_hpc0_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HPC1"} {set sys_hpc1_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HP0"} {set sys_hp0_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HP1"} {set sys_hp1_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HP2"} {set sys_hp2_interconnect_index $m_interconnect_index}
###   if {$p_sel eq "HP3"} {set sys_hp3_interconnect_index $m_interconnect_index}
### proc ad_cpu_interconnect {p_address p_name {p_intf_name {}}} {
###   global sys_zynq
###   global sys_cpu_interconnect_index
###   set i_str "M$sys_cpu_interconnect_index"
###   if {$sys_cpu_interconnect_index < 10} {
###     set i_str "M0$sys_cpu_interconnect_index"
###   if {$sys_cpu_interconnect_index == 0} {
###       ad_ip_instance smartconnect axi_cpu_interconnect [ list \
###         NUM_MI 1 \
###         NUM_SI 1 \
###       ad_connect sys_cpu_clk axi_cpu_interconnect/aclk
###       ad_connect sys_cpu_resetn axi_cpu_interconnect/aresetn
###     } else {
###       ad_ip_instance axi_interconnect axi_cpu_interconnect
###       ad_connect sys_cpu_clk axi_cpu_interconnect/ACLK
###       ad_connect sys_cpu_clk axi_cpu_interconnect/S00_ACLK
###       ad_connect sys_cpu_resetn axi_cpu_interconnect/ARESETN
###       ad_connect sys_cpu_resetn axi_cpu_interconnect/S00_ARESETN
###       ad_connect sys_cpu_clk sys_cips/m_axi_fpd_aclk
###       ad_connect axi_cpu_interconnect/S00_AXI sys_cips/M_AXI_FPD
###       ad_connect sys_cpu_clk sys_ps8/maxihpm0_lpd_aclk
###       ad_connect axi_cpu_interconnect/S00_AXI sys_ps8/M_AXI_HPM0_LPD
###       ad_connect sys_cpu_clk sys_ps7/M_AXI_GP0_ACLK
###       ad_connect axi_cpu_interconnect/S00_AXI sys_ps7/M_AXI_GP0
###       ad_connect axi_cpu_interconnect/S00_AXI sys_mb/M_AXI_DP
###       ad_connect axi_cpu_interconnect/S00_AXI mng_axi_vip/M_AXI
###     set sys_addr_cntrl_space [get_bd_addr_spaces /sys_cips/M_AXI_FPD]
###     set sys_addr_cntrl_space [get_bd_addr_spaces sys_ps8/Data]
###     set sys_addr_cntrl_space [get_bd_addr_spaces sys_ps7/Data]
###     set sys_addr_cntrl_space [get_bd_addr_spaces sys_mb/Data]
###     set sys_addr_cntrl_space [get_bd_addr_spaces mng_axi_vip/Master_AXI]
###   set sys_cpu_interconnect_index [expr $sys_cpu_interconnect_index + 1]
###   set p_cell [get_bd_cells $p_name]
###   set p_intf [get_bd_intf_pins -filter \
###     "MODE == Slave && VLNV == xilinx.com:interface:aximm_rtl:1.0 && NAME =~ *$p_intf_name*"\
###     -of_objects $p_cell]
###   set p_hier_cell $p_cell
###   set p_hier_intf $p_intf
###   while {$p_hier_intf != "" && [get_property TYPE $p_hier_cell] == "hier"} {
###     set p_hier_intf [find_bd_objs -boundary_type lower \
###       -relation connected_to $p_hier_intf]
###     if {$p_hier_intf != {}} {
###       set p_hier_cell [get_bd_cells -of_objects $p_hier_intf]
###     } else {
###       set p_hier_cell {}
###   set p_intf_reset ""
###   if {$p_hier_cell != {}} {
###     set p_intf_name [lrange [split $p_hier_intf "/"] end end]
###     set p_intf_clock [get_bd_pins -filter "TYPE == clk && \
###       (CONFIG.ASSOCIATED_BUSIF == ${p_intf_name} || \
###       CONFIG.ASSOCIATED_BUSIF =~ ${p_intf_name}:* || \
###       CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name} || \
###       CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name}:*)" \
###       -quiet -of_objects $p_hier_cell]
###     set p_intf_reset [get_bd_pins -filter "TYPE == rst && \
###     if {($p_intf_clock ne "") && ($p_intf_reset eq "")} {
###       set p_intf_reset [get_property CONFIG.ASSOCIATED_RESET [get_bd_pins ${p_intf_clock}]]
###       if {$p_intf_reset ne ""} {
###         set p_intf_reset [get_bd_pins -filter "NAME == $p_intf_reset" -of_objects $p_hier_cell]
###     # Trace back up
###     set p_hier_cell2 $p_hier_cell
###     while {$p_intf_clock != {} && $p_hier_cell2 != $p_cell && $p_hier_cell2 != {}} {
###       puts $p_intf_clock
###       puts $p_hier_cell2
###       set p_intf_clock [find_bd_objs -boundary_type upper \
###         -relation connected_to $p_intf_clock]
###       if {$p_intf_clock != {}} {
###         set p_intf_clock [get_bd_pins [get_property PATH $p_intf_clock]]
###         set p_hier_cell2 [get_bd_cells -of_objects $p_intf_clock]
###     while {$p_intf_reset != {} && $p_hier_cell2 != $p_cell && $p_hier_cell2 != {}} {
###       set p_intf_reset [find_bd_objs -boundary_type upper \
###         -relation connected_to $p_intf_reset]
###       if {$p_intf_reset != {}} {
###         set p_intf_reset [get_bd_pins [get_property PATH $p_intf_reset]]
###         set p_hier_cell2 [get_bd_cells -of_objects $p_intf_reset]
###   if {[find_bd_objs -quiet -relation connected_to $p_intf_clock] ne ""} {
###     if {[find_bd_objs -quiet -relation connected_to $p_intf_reset] ne ""} {
###   set_property CONFIG.NUM_MI $sys_cpu_interconnect_index [get_bd_cells axi_cpu_interconnect]
###     ad_connect sys_cpu_clk axi_cpu_interconnect/${i_str}_ACLK
###     ad_connect sys_cpu_resetn axi_cpu_interconnect/${i_str}_ARESETN
###     ad_connect sys_cpu_clk ${p_intf_clock}
###     ad_connect sys_cpu_resetn ${p_intf_reset}
###   ad_connect axi_cpu_interconnect/${i_str}_AXI ${p_intf}
###   set p_seg [get_bd_addr_segs -of [get_bd_addr_spaces -of [get_bd_intf_pins -filter "NAME=~ *${p_intf_name}*" -of $p_hier_cell]]]
###   set p_index 0
###   foreach p_seg_name $p_seg {
###     if {$p_index == 0} {
###       set p_seg_range [get_property range $p_seg_name]
###       if {$p_seg_range < 0x1000} {
###         set p_seg_range 0x1000
###         if {($p_address >= 0x44000000) && ($p_address <= 0x4fffffff)} {
###           # place axi peripherics in A400_0000-AFFF_FFFF range
###           set p_address [expr ($p_address + 0x60000000)]
###         } elseif {($p_address >= 0x70000000) && ($p_address <= 0x7fffffff)} {
###           # place axi peripherics in B000_0000-BFFF_FFFF range
###           set p_address [expr ($p_address + 0x40000000)]
###         } else {
###           error "ERROR: ad_cpu_interconnect : Cannot map ($p_address) to aperture, \
###                 Addess out of range 0x4400_0000 - 0X4FFF_FFFF; 0x7000_0000 - 0X7FFF_FFFF !"
###         if {($p_address >= 0x40000000) && ($p_address <= 0x4fffffff)} {
###         if {($p_address >= 0x70000000) && ($p_address <= 0x7fffffff)} {
###           set p_address [expr ($p_address + 0x20000000)]
###       create_bd_addr_seg -range $p_seg_range \
###         -offset $p_address $sys_addr_cntrl_space \
###         $p_seg_name "SEG_data_${p_name}"
###     } else {
###       assign_bd_address $p_seg_name
###     incr p_index
### proc ad_cpu_interrupt {p_ps_index p_mb_index p_name} {
###   global sys_zynq
###   if {$sys_zynq <= 0} {set p_index_int $p_mb_index}
###   if {$sys_zynq >= 1} {set p_index_int $p_ps_index}
###   set p_index [regsub -all {[^0-9]} $p_index_int ""]
###   set m_index [expr ($p_index - 8)]
###    if {$p_index < 0 || $p_index > 15} {
###       error "ERROR: ad_cpu_interrupt : Interrupt index ($p_index) out of range 0-15 "
###     ad_connect $p_name sys_cips/pl_ps_irq$p_index
###   if {($sys_zynq == 2) && ($p_index <= 7)} {
###     set p_net [get_bd_nets -of_objects [get_bd_pins sys_concat_intc_0/In$p_index]]
###     set p_pin [get_bd_pins sys_concat_intc_0/In$p_index]
###     puts "disconnect_bd_net $p_net $p_pin"
###     disconnect_bd_net $p_net $p_pin
###     ad_connect sys_concat_intc_0/In$p_index $p_name
###   if {($sys_zynq == 2) && ($p_index >= 8)} {
###     set p_net [get_bd_nets -of_objects [get_bd_pins sys_concat_intc_1/In$m_index]]
###     set p_pin [get_bd_pins sys_concat_intc_1/In$m_index]
###     ad_connect sys_concat_intc_1/In$m_index $p_name
###   if {$sys_zynq <= 1} {
###     set p_net [get_bd_nets -of_objects [get_bd_pins sys_concat_intc/In$p_index]]
###     set p_pin [get_bd_pins sys_concat_intc/In$p_index]
###     ad_connect sys_concat_intc/In$p_index $p_name
## proc adi_sim_add_define {value} {
##   global adi_sim_defines
##   lappend adi_sim_defines $value
## proc adi_sim_project_xilinx {project_name {part "xc7vx485tffg1157-1"}} {
##   global design_name
##   global ad_project_params
##   global ad_tb_dir
##   # Create project
##   create_project ${project_name} ./runs/${project_name} -part $part -force
##   # Set project properties
##   set_property -name "default_lib" -value "xil_defaultlib" -objects [current_project]
##   # Set IP repository paths
##   set lib_dirs $ad_hdl_dir/library
##   lappend lib_dirs "$ad_tb_dir/library"
##   set_property ip_repo_paths $lib_dirs \
##     [get_filesets sources_1]
##   # Rebuild user ip_repo's index before adding any source files
##   update_ip_catalog -rebuild
##   ## Create the bd
##   create_bd_design $design_name
##   global sys_zynq
##   set sys_zynq -1
##   if { ![info exists ad_project_params(CACHE_COHERENCY)] } {
##     set CACHE_COHERENCY false
##   if { ![info exists ad_project_params(CUSTOM_HARNESS)] || !$ad_project_params(CUSTOM_HARNESS) } {
##     source $ad_tb_dir/library/utilities/test_harness_system_bd.tcl
##   # transfer tcl parameters as defines to verilog
##   foreach {k v} [array get ad_project_params] {
##     if { [llength $ad_project_params($k)] == 1} {
##       adi_sim_add_define $k=$v
##     } else {
##       foreach {h v} $ad_project_params($k) {
##         adi_sim_add_define ${k}_${h}=$v
##   # write tcl parameters into a file
##   set outfile [open "./runs/${project_name}/parameters.log" w+]
##   puts $outfile "Configuration parameters\n"
##   foreach name [array names ad_project_params] {
##     if { [llength $ad_project_params($name)] == 1} {
##       puts $outfile "$name : $ad_project_params($name)"
##     } else {
##       puts $outfile "$name :"
##       foreach {k v} $ad_project_params($name) {
##         puts $outfile "  $k : $v"
##   close $outfile
##   # Build the test harness based on the topology
##   source system_bd.tcl
##   save_bd_design
##   validate_bd_design
##   # Pass the test harness instance name to the simulation
##   adi_sim_add_define "TH=$design_name"
##   # Use a define for the top module
##   adi_sim_add_define "TB=system_tb"
##   source $ad_tb_dir/library/includes/sp_include_common.tcl
## proc adi_sim_project_files {project_files} {
##   add_files -fileset sim_1 $project_files
##   # Set 'sim_1' fileset properties
##   set_property -name "top" -value "system_tb" -objects [get_filesets sim_1]
## proc adi_sim_generate {project_name } {
##   # Set the defines for simulation
##   set_property verilog_define $adi_sim_defines [get_filesets sim_1]
##   set_property -name {xsim.simulate.runtime} -value {} -objects [get_filesets sim_1]
##   # Show all Xilinx primitives e.g GTYE4_COMMON
##   set_property -name {xsim.elaborate.debug_level} -value {all} -objects [get_filesets sim_1]
##   # Log all waves
##   set_property -name {xsim.simulate.log_all_signals} -value {true} -objects [get_filesets sim_1]
##   set_property -name {xsim.simulate.xsim.more_options} -value {-sv_seed random} -objects [get_filesets sim_1]
##   set project_system_dir "./runs/$project_name/$project_name.srcs/sources_1/bd/$design_name"
##   generate_target Simulation [get_files $project_system_dir/$design_name.bd]
##   set_property include_dirs . [get_filesets sim_1]
##   set_msg_config -string mb_reset -suppress
## proc adi_open_project {project_path} {
##   open_project $project_path
## proc adi_update_define {name value} {
##   set defines [get_property verilog_define [get_filesets sim_1]]
##   set defines_new {}
##   foreach def $defines {
##     set def [split $def {=}]
##     if {[lindex $def 0] == $name} {
##       set def [lreplace $def 1 1 $value]
##       puts "reaplacing"
##     lappend defines_new "[lindex $def 0]=[lindex $def 1]"
##   set_property verilog_define $defines_new [get_filesets sim_1]
## proc adi_project_files {project_files} {
##   foreach pfile $project_files {
##     if {[string range $pfile [expr 1 + [string last . $pfile]] end] == "xdc"} {
##       add_files -norecurse -fileset constrs_1 $pfile
##     } else {
##       add_files -norecurse -fileset sources_1 $pfile
# if {$argc < 1} {
#   puts "Expecting at least one argument that specifies the test configuration"
#   exit 1
# } else {
#   set cfg_file [lindex $argv 0]
# source "cfgs/${cfg_file}"
# set project_name [file rootname $cfg_file]
# adi_sim_project_xilinx $project_name "xczu9eg-ffvb1156-2-e"
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/rtl/kalainan/golden_file/hdl-2023_R2_p1/library'.
INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/library'.
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/tools/Xilinx/Vivado/2021.1/data/ip'.
Wrote  : </home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/testbenches/project/fmcomms2/runs/cfg1/cfg1.srcs/sources_1/bd/test_harness/test_harness.bd>
## set mng_axi_cfg [ list \
##    ADDR_WIDTH {32} \
##    ARUSER_WIDTH {0} \
##    AWUSER_WIDTH {0} \
##    BUSER_WIDTH {0} \
##    DATA_WIDTH {32} \
##    HAS_BRESP {1} \
##    HAS_BURST {0} \
##    HAS_CACHE {0} \
##    HAS_LOCK {0} \
##    HAS_PROT {1} \
##    HAS_QOS {0} \
##    HAS_REGION {0} \
##    HAS_RRESP {1} \
##    HAS_WSTRB {1} \
##    ID_WIDTH {0} \
##    INTERFACE_MODE {MASTER} \
##    PROTOCOL {AXI4LITE} \
##    READ_WRITE_MODE {READ_WRITE} \
##    RUSER_BITS_PER_BYTE {0} \
##    RUSER_WIDTH {0} \
##    SUPPORTS_NARROW {0} \
##    WUSER_BITS_PER_BYTE {0} \
##    WUSER_WIDTH {0} \
## set ddr_axi_cfg [list \
##  INTERFACE_MODE {SLAVE} \
##  DATA_WIDTH {512} \
## ad_ip_instance axi_vip mng_axi_vip $mng_axi_cfg
## adi_sim_add_define "MNG_AXI=mng_axi_vip"
## ad_ip_instance axi_vip ddr_axi_vip $ddr_axi_cfg
## adi_sim_add_define "DDR_AXI=ddr_axi_vip"
## ad_ip_instance axi_intc axi_intc [list \
##   C_IRQ_CONNECTION 1 \
##   C_HAS_FAST 0 \
## ad_ip_instance xlconcat sys_concat_intc
## ad_ip_parameter sys_concat_intc CONFIG.NUM_PORTS 16
## ad_ip_instance clk_vip sys_clk_vip [ list \
##   FREQ_HZ 100000000 \
## adi_sim_add_define "SYS_CLK=sys_clk_vip"
## ad_ip_instance clk_vip dma_clk_vip [ list \
##   FREQ_HZ 200000000 \
## adi_sim_add_define "DMA_CLK=dma_clk_vip"
## ad_ip_instance clk_vip ddr_clk_vip [ list \
##   FREQ_HZ 400000000 \
## adi_sim_add_define "DDR_CLK=ddr_clk_vip"
## ad_connect sys_cpu_clk sys_clk_vip/clk_out
connect_bd_net -net sys_cpu_clk /sys_clk_vip/clk_out
## ad_connect sys_dma_clk dma_clk_vip/clk_out
connect_bd_net -net sys_dma_clk /dma_clk_vip/clk_out
## ad_connect sys_mem_clk ddr_clk_vip/clk_out
connect_bd_net -net sys_mem_clk /ddr_clk_vip/clk_out
## ad_ip_instance rst_vip sys_rst_vip [ list \
##   RST_POLARITY {ACTIVE_HIGH} \
## adi_sim_add_define "SYS_RST=sys_rst_vip"
## ad_ip_instance proc_sys_reset sys_rstgen
## ad_ip_parameter sys_rstgen CONFIG.C_EXT_RST_WIDTH 1
## ad_ip_instance proc_sys_reset sys_dma_rstgen
## ad_ip_parameter sys_dma_rstgen CONFIG.C_EXT_RST_WIDTH 1
## ad_ip_instance proc_sys_reset sys_mem_rstgen
## ad_ip_parameter sys_mem_rstgen CONFIG.C_EXT_RST_WIDTH 1
## ad_connect sys_rst_vip/rst_out sys_rstgen/ext_reset_in
connect_bd_net /sys_rst_vip/rst_out /sys_rstgen/ext_reset_in
## ad_connect sys_rst_vip/rst_out sys_dma_rstgen/ext_reset_in
connect_bd_net /sys_rst_vip/rst_out /sys_dma_rstgen/ext_reset_in
## ad_connect sys_rst_vip/rst_out sys_mem_rstgen/ext_reset_in
connect_bd_net /sys_rst_vip/rst_out /sys_mem_rstgen/ext_reset_in
## ad_connect sys_cpu_clk sys_rstgen/slowest_sync_clk
connect_bd_net -net /sys_cpu_clk /sys_rstgen/slowest_sync_clk
## ad_connect sys_dma_clk sys_dma_rstgen/slowest_sync_clk
connect_bd_net -net /sys_dma_clk /sys_dma_rstgen/slowest_sync_clk
## ad_connect sys_mem_clk sys_mem_rstgen/slowest_sync_clk
connect_bd_net -net /sys_mem_clk /sys_mem_rstgen/slowest_sync_clk
## ad_connect sys_cpu_reset sys_rstgen/peripheral_reset
connect_bd_net -net sys_cpu_reset /sys_rstgen/peripheral_reset
## ad_connect sys_cpu_resetn sys_rstgen/peripheral_aresetn
connect_bd_net -net sys_cpu_resetn /sys_rstgen/peripheral_aresetn
## ad_connect sys_dma_reset sys_dma_rstgen/peripheral_reset
connect_bd_net -net sys_dma_reset /sys_dma_rstgen/peripheral_reset
## ad_connect sys_dma_resetn sys_dma_rstgen/peripheral_aresetn
connect_bd_net -net sys_dma_resetn /sys_dma_rstgen/peripheral_aresetn
## ad_connect sys_mem_reset sys_mem_rstgen/peripheral_reset
connect_bd_net -net sys_mem_reset /sys_mem_rstgen/peripheral_reset
## ad_connect sys_mem_resetn sys_mem_rstgen/peripheral_aresetn
connect_bd_net -net sys_mem_resetn /sys_mem_rstgen/peripheral_aresetn
## ad_connect sys_cpu_clk /mng_axi_vip/aclk
connect_bd_net -net /sys_cpu_clk /mng_axi_vip/aclk
## ad_connect sys_cpu_resetn /mng_axi_vip/aresetn
connect_bd_net -net /sys_cpu_resetn /mng_axi_vip/aresetn
## ad_connect sys_mem_resetn /ddr_axi_vip/aresetn
connect_bd_net -net /sys_mem_resetn /ddr_axi_vip/aresetn
## set sys_mem_clk sys_mem_clk
## set sys_cpu_clk sys_cpu_clk
## set sys_cpu_reset sys_cpu_reset
## set sys_cpu_resetn sys_cpu_resetn
## set sys_dma_clk sys_dma_clk
## set sys_dma_clk_source dma_clk_vip/clk_out
## set sys_dma_reset sys_dma_reset
## set sys_dma_resetn sys_dma_resetn
## set sys_mem_reset sys_mem_reset
## set sys_mem_resetn sys_mem_resetn
## ad_connect axi_intc/intr sys_concat_intc/dout
connect_bd_net /axi_intc/intr /sys_concat_intc/dout
## set sys_iodelay_clk sys_mem_clk
## ad_connect sys_concat_intc/In0    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In0
## ad_connect sys_concat_intc/In1    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In1
## ad_connect sys_concat_intc/In2    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In2
## ad_connect sys_concat_intc/In3    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In3
## ad_connect sys_concat_intc/In4    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In4
## ad_connect sys_concat_intc/In5    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In5
## ad_connect sys_concat_intc/In6    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In6
## ad_connect sys_concat_intc/In7    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In7
## ad_connect sys_concat_intc/In8    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In8
## ad_connect sys_concat_intc/In9    GND
connect_bd_net /GND_1/dout /sys_concat_intc/In9
## ad_connect sys_concat_intc/In10   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In10
## ad_connect sys_concat_intc/In11   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In11
## ad_connect sys_concat_intc/In12   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In12
## ad_connect sys_concat_intc/In13   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In13
## ad_connect sys_concat_intc/In14   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In14
## ad_connect sys_concat_intc/In15   GND
connect_bd_net /GND_1/dout /sys_concat_intc/In15
## ad_cpu_interconnect 0x41200000 axi_intc
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/aresetn
connect_bd_intf_net /axi_cpu_interconnect/S00_AXI /mng_axi_vip/M_AXI
connect_bd_net -net /sys_cpu_clk /axi_intc/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_intc/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M00_AXI /axi_intc/s_axi
## ad_mem_hp0_interconnect sys_mem_clk ddr_axi_vip/S_AXI
connect_bd_net -net /sys_mem_resetn /axi_mem_interconnect/aresetn
connect_bd_net -net /sys_mem_clk /axi_mem_interconnect/aclk
connect_bd_intf_net /axi_mem_interconnect/M00_AXI /ddr_axi_vip/S_AXI
connect_bd_net -net /sys_mem_clk /ddr_axi_vip/aclk
WARNING: [BD 5-230] No cells matched 'get_bd_cells axi_axi_interconnect'
## set_property -dict [list CONFIG.NUM_MI {2}] [get_bd_cells axi_axi_interconnect]
INFO: [Common 17-17] undo 'set_property'
ERROR: [Common 17-55] 'set_property' expects at least one object.
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
    while executing
"source $ad_tb_dir/library/utilities/test_harness_system_bd.tcl"
    invoked from within
"if { ![info exists ad_project_params(CUSTOM_HARNESS)] || !$ad_project_params(CUSTOM_HARNESS) } {
    source $ad_tb_dir/library/utilities/test_harness_..."
    (procedure "adi_sim_project_xilinx" line 31)
    invoked from within
"adi_sim_project_xilinx $project_name "xczu9eg-ffvb1156-2-e""
    (file "system_project.tcl" line 17)
INFO: [Common 17-206] Exiting Vivado at Thu Oct 30 12:15:13 2025...
I am using AD's reference design for ad9361 reference design for the ADRV9364 board and ADRV1CRR-BOB carrier board with no os software
Hardware: https://github.com/analogdevicesinc/hdl/tree/master/projects/adrv9361z7020/ccfmc_lvds
software: https://github.com/analogdevicesinc/no-OS/blob/master/projects/ad9361/src/main.c
We are trying to understand the functional working of the IP core, so we clone the HDL rep and testbench rep inside the HDL rep, as mentioned in the readme file. And also taken reference from this post
link:   axi_ad9361 IP testing
while building the testbench, we are facing some errors in the make file.
We summarize the flow of what we have done.
  1. As per the documentation, we cloned both the repo from the above-mentioned link
  2. export ADI_HDL_DIR=$pwd/hdl-2023_R2_p1
  3. export ADI_TB_DIR=$pwd/hdl-2023_R2_p1/testbenches/
  4. export ADI_IGNORE_VERSION_CHECK=1  (Since we are using the Vivado 2021.1)(Also we are tried using the 2023.2 Still facing the same)
  5. then cd $pwd/hdl-2023_R2_p1/testbenches/testbenches/project/fmcomms2
  6. then we had to provide the $ make
Error:
Building io_vip library [/home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/library/vip/adi/io_vip/io_vip_ip.log] ... OK
Building cfg1 env [/home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log] ...
Build cfg1 env [/home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log] FAILED
For details see /home/rtl/kalainan/golden_file/hdl-2023_R2_p1/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log
Here also we are attaching the system log file  FYR
Thread Notes
  • Hello  ,
    We are currently looking into this issue. We'll get back at you soon.
    Kind regards,
    Stanca
  • Hi  ,
    I'm looking into the error logs and the details you wrote. There are a couple of things that are not clear to me, and because of that I can't really replicate the issue.
    What branch do you use for the HDL repository? The Hardware link you sent is out of date, since it's pointing to master branch, which was renamed to main a while ago. Your HDL repository is named hdl-2023_R2_p1, which is suggesting to me that you want to use the patched hdl_2023_r2 branch from the Releases?
    What branch do you use for the Testbenches repository?
    I tried to do some version testing, and it seems that there are some compatibility issues. But first, I'll have to ask you to provide the branches used for the simulation, so we can try to replicate the issue you're facing. The error you received is due to the fact that at some point in our development cycle of 2023.2, some of our core scripts were updated to add additional features. Because of it, the Testbenches repository was also affected, since it uses a some of those command as well.
    Note: we don't have Vivado 2021.1 installed at this point in time, but we can try it with 2023.2 or 2022.2, which is closer to 2021.1, although still not the same version.
    -Istvan
  • ****** Vivado v2021.1 (64-bit)
    ##   # Create project
    ##   lappend lib_dirs [file normalize "./../../../library"]
    ##   ## Create the bd
    ##   global sys_zynq
    ##   set sys_zynq -1
    ##     source ../../../library/utilities/test_harness_system_bd.tcl
    ##     } else {
    ##     } else {
    ##   close $outfile
    ##   save_bd_design
    ##   # Log all waves
    ##     } else {
    # source ../../../../scripts/adi_env.tcl
    ##   } else {
    ##     set config {}
    ##   set m_name ""
    ##   return $m_name
    ##   set m_name ""
    ##     return "const"
    ##   return "newnet"
    ##   switch $name {
    ##     GND {
    ##       set value 0
    ##     VCC {
    ##     default {
    ##   return $cell
    ##     return 1
    ##     newnet,newnet {
    ##     const,const {
    ##     bd_net,bd_net -
    ##     bd_net,newnet -
    ##     newnet,bd_net {
    ##     const,newnet -
    ##     newnet,const {
    ##     bd_pin,bd_pin {
    ##       return
    ##     bd_net,bd_pin {
    ##       return
    ##     bd_pin,bd_net {
    ##       return
    ##     bd_pin,newnet {
    ##       return
    ##     newnet,bd_pin {
    ##       return
    ##       return
    ##     const,bd_pin -
    ##     const,bd_net {
    ##     bd_net,const -
    ##     bd_pin,const {
    ##       # Swap vars
    ##       set tmp $obj_a
    ##       set obj_a $obj_b
    ##       set obj_b $tmp
    ##       set tmp $name_a
    ##       set name_b $tmp
    ##     default {
    ##     return
    ##     return
    ##     return
    ##   } else {
    ##   set txrx "rx"
    ##   set data_dir "I"
    ##   set ctrl_dir "O"
    ##     set txrx "tx"
    ##     set data_dir "O"
    ##     set ctrl_dir "I"
    ##   } else {
    ##   set use_2x_clk 0
    ##       set use_2x_clk 1
    ##     } else {
    ##       } else {
    ##   } else {
    ##   } else {
    ##         } else {
    ##         } else {
    ##         } else {
    ##           set phys_lane $m
    ##     } else {
    ##   } else {
    ##       } else {
    ##         set phys_lane $m
    ##         } else {
    ##         } else {
    ##       } else {
    ##         set phys_lane $m
    ##   } else {
    ##   global sys_zynq
    ##   global sys_zynq
    ##   global sys_zynq
    ##   global sys_zynq
    ##   global sys_zynq
    ##   global sys_zynq
    ##   global sys_zynq
    ##   } else {
    ##       } else {
    ##     } else {
    ##     } else {
    ##   global sys_zynq
    ##         NUM_MI 1 \
    ##         NUM_SI 1 \
    ##     } else {
    ##     } else {
    ##     # Trace back up
    ##   set p_index 0
    ##         } else {
    ##     } else {
    ##     incr p_index
    ##   global sys_zynq
    # if {$argc < 1} {
    #   exit 1
    # } else {
    INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/rtl/kalainan/golden_file/test/hdl/library'.
    INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/rtl/kalainan/golden_file/test/hdl/testbenches/library'.
    Wrote  : </home/rtl/kalainan/golden_file/test/hdl/testbenches/testbenches/project/fmcomms2/runs/cfg1/cfg1.srcs/sources_1/bd/test_harness/test_harness.bd>
    ##    HAS_BRESP {1} \
    ##    HAS_BURST {0} \
    ##    HAS_CACHE {0} \
    ##    HAS_LOCK {0} \
    ##    HAS_PROT {1} \
    ##    HAS_QOS {0} \
    ##    HAS_REGION {0} \
    ##    HAS_RRESP {1} \
    ##    HAS_WSTRB {1} \
    ##    ID_WIDTH {0} \
    ##   C_HAS_FAST 0 \
        while executing
    "source ../../../library/utilities/test_harness_system_bd.tcl"
        invoked from within
        source ../../../library/utilities/test_harness_sy..."
        (procedure "adi_sim_project_xilinx" line 27)
        invoked from within
        (file "system_project.tcl" line 19)
    INFO: [Common 17-206] Exiting Vivado at Sat Nov  1 10:13:23 2025...
    Hi ISzekely,
      As per your suggestion, we freshly downloaded the HDL and Testbench from the rep. But we are facing the same errors while running the make command
    Below, we attach the command and links we used for HDL and Testbench, and also the system log file for your reference.
    git clone https://github.com/analogdevicesinc/hdl.git
    cd hdl
    git checkout hdl_2023_r2
    git branch
    * hdl_2023_r2
      main
    git clone https://github.com/analogdevicesinc/testbenches.git
    cd testbenches/
    git checkout tb_2023_r2
    export ADI_HDL_DIR=/home/rtl/kalainan/golden_file/test/hdl/
    export ADI_TB_DIR=/home/rtl/kalainan/golden_file/test/hdl/testbenches/
    source /tools/Xilinx/Vivado/2021.1/settings64.sh
    cd testbenches/project/fmcomms2/
    make
    Building axi_ad9361 library [/home/rtl/kalainan/golden_file/test/hdl/library/axi_ad9361/axi_ad9361_ip.log] ... OK
    Building util_cdc library [/home/rtl/kalainan/golden_file/test/hdl/library/util_cdc/util_cdc_ip.log] ... OK
    Building util_axis_fifo library [/home/rtl/kalainan/golden_file/test/hdl/library/util_axis_fifo/util_axis_fifo_ip.log] ... OK
    Building axi_dmac library [/home/rtl/kalainan/golden_file/test/hdl/library/axi_dmac/axi_dmac_ip.log] ... OK
    Building axi_sysid library [/home/rtl/kalainan/golden_file/test/hdl/library/axi_sysid/axi_sysid_ip.log] ... OK
    Building sysid_rom library [/home/rtl/kalainan/golden_file/test/hdl/library/sysid_rom/sysid_rom_ip.log] ... OK
    Building util_cpack2 library [/home/rtl/kalainan/golden_file/test/hdl/library/util_pack/util_cpack2/util_cpack2_ip.log] ... OK
    Building util_upack2 library [/home/rtl/kalainan/golden_file/test/hdl/library/util_pack/util_upack2/util_upack2_ip.log] ... OK
    Building util_rfifo library [/home/rtl/kalainan/golden_file/test/hdl/library/util_rfifo/util_rfifo_ip.log] ... OK
    Building util_tdd_sync library [/home/rtl/kalainan/golden_file/test/hdl/library/util_tdd_sync/util_tdd_sync_ip.log] ... OK
    Building util_wfifo library [/home/rtl/kalainan/golden_file/test/hdl/library/util_wfifo/util_wfifo_ip.log] ... OK
    Building util_clkdiv library [/home/rtl/kalainan/golden_file/test/hdl/library/xilinx/util_clkdiv/util_clkdiv_ip.log] ... OK
    Building cfg1 env [/home/rtl/kalainan/golden_file/test/hdl/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log] ...
    Build cfg1 env [/home/rtl/kalainan/golden_file/test/hdl/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log] FAILED
    For details see /home/rtl/kalainan/golden_file/test/hdl/testbenches/testbenches/project/fmcomms2/runs/cfg1/system_project.log
    make: *** [../../../scripts/project-sim.mk:175: runs/cfg1/system_project.log] Error 1
  • Hi  ,
    I managed to replicate your issues on our side. The "fix" sadly enough is not a straight forward one. I'll explain what happened first, in case someone else stumbles upon this thread later on, and want an answer for it.
    When we do our usual release cycles, we create release branches, test them thoroughly, and once everything is done, we create the release and tag. When we started the release cycle on the HDL repository, the Testbenches repository was left behind for some reason, and it didn't receive its equivalent of release branch. Because of this, the HDL and the Testbenches got out of sync. The HDL got some patches to make sure that the 2023 release was stable and as bug-free as possible, while Testbenches was still paired with main. When the release cycle done for HDL, the release page and tag were created. In the same day, the Testbenches got their own branch, tag and release, which was synced to main, and not tested. This is why the IPs are building with no issue, however, the configuration of the testbench is failing.
    There is no simple way of fixing this issue with the release branches. It requires a lot of git commit tinkering, getting rid of the ones that are in conflict with the HDL and then probably fix the other issues that arise during this process.
    We know that the current HDL main branch works with the Testbenches main branch, an alternative route option is to use them, with export ADI_IGNORE_VERSION_CHECK=1 set. An important note: since Vivado 2025.1 did some changes to IP names and some other stuff, you'll have to use that version. If you don't want to / can't install Vivado 2025.1, you may try to undo this commit. git rebase -i 4058b88 will rebase the full main branch on one of the previous commits. Delete the first line (pick eadd7d695 Update utility cores to inline hdl variants), or change pick to drop or d on that same line, as this is the one that made the changes for Vivado 2025.1. Save and exit. All commits will be rebased on the main branch, with this one removed. I tested this with both branches being set to main with this workaround for HDL and Vivado version 2023.2. The testbench runs as expected.
    Let me know if you still experience some issues with running the testbench.
    -Istvan
  • Moved this thread back to the FPGA Reference Designs  group, since this is a testbench related issue that should be resolved here.
  • Hi ISzekely,
     We followed your guidelines and generated the testbench successfully without any errors. Thank you for your valuable support.
