I am trying to port the reference design from the ZCU102 + AD9081-FMC-EBZ to a different carrier board - Enclustra Mercury+ XU8. The part has the following device on it: "XCZU7ev-fbvb900-2-i" This is a smaller part than the one on the ZCU102 for which the reference design was designed for.
I have followed Porting reference designs very closely. After the current reference design didn't fit due to the new device being smaller, I modified it by removing the RX part. The modified version was first tested on the zcu102 setup and it worked. Next, I successfully built the ported reference design for the Mercury+ XU8. The problem I currently have is that the UltraScale+ in the ported design for the Mercury+ XU8 lost all of its settings. I've attached an image of the block designs for the UltraScale+ so you can see the difference between the 2 setups: first is the original zcu102 setup, and below it is the ported design for the Mercury+ XU8 board. You can see that the settings were lost in the Mercury+ XU8 board. For example there is no UART enabled in the ported design. When I try to boot this design from the onboard SD card, obviously I get nothing on the terminal, but I suspect it might be because I have no UART setup in this ported design. Can you please help with this? Thank you.
