Scalability of the IP core "util_adrv9009_xcvr" from managing 8 SoCs ADRV9009 to 4 SoCs ADRV9009
Product Number: util_adrv9009_xcvr
Good morning everyone,
I have taken over a project that features a JESD204 link with 16 channels (managing 8 ADRV9009 chips).
This project originated from Analog Devices' reference design, which was modified to work with 16 channels.
We are now creating a new project with a similar architecture, but the number of channels is reduced from 16 to 8, meaning we will only control 4 ADRV9009 chips.
The FPGA target is XCZU9EG-FFVB1156-2-e
Thus, the previous JESD204 parameters, which were:
  1. Number of Lanes (L) = 16
  2. Number of Converters (M) = 32
  3. Bits per Sample (N') = 16
  4. Converter Resolution (N) = 16
  5. Samples per Frame (S) = 1
  6. Octets per Beat = 4
have now been changed to:
  1. Number of Lanes (L) = 8
  2. Number of Converters (M) = 16
The outputs of the IP core "util_adrv9009_xcvr" (such as tx_0_p, tx_0_n, etc.) are connected to specific pins that are fixed at the PCB level and route the signals to the different ADRV9009 chips. Here’s the current mapping:
#set_property -dict {PACKAGE_PIN K6} [get_ports tx_data_a_p[0]] (tx_0_p)
#set_property -dict {PACKAGE_PIN K5} [get_ports tx_data_a_n[0]] (tx_0_n)
#set_property -dict {PACKAGE_PIN H6} [get_ports tx_data_a_p[1]] (tx_1_p)
#set_property -dict {PACKAGE_PIN H5} [get_ports tx_data_a_n[1]] (tx_1_n)
#set_property -dict {PACKAGE_PIN K2} [get_ports rx_data_a_p[0]] (rx_0_n)
#set_property -dict {PACKAGE_PIN K1} [get_ports rx_data_a_n[0]] (rx_0_n)
#set_property -dict {PACKAGE_PIN J4} [get_ports rx_data_a_p[1]] (rx_1_p)
#set_property -dict {PACKAGE_PIN J3} [get_ports rx_data_a_n[1]] (rx_1_n)
With this configuration, the project synthesizes successfully. However, I need to remap the tx_0_p, tx_0_n, etc., to different pins, such as the tx_data_c_p pins, and when I make this change, the project no longer implements, and I get the following error:
[Place 30-510] Unroutable Placement! A GTHE_COMMON / GTHE_CHANNEL clock component pair is not placed in a routable site pair. The GTHE_COMMON component can use the dedicated path between the GTHE_COMMON and the GTHE_CHANNEL if both are placed in the same clock region. If this suboptimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xcm_0/qpll2ch_clk] >
i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xcm_0/i_gthe4_common (GTHE4_COMMON.QPLL0OUTCLK) is provisionally placed by clockplacer on GTHE4_COMMON_X1Y3
i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xch_0/i_gthe4_channel (GTHE4_CHANNEL.QPLL0CLK) is locked to GTHE4_CHANNEL_X1Y5
i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xch_1/i_gthe4_channel (GTHE4_CHANNEL.QPLL0CLK) is locked to GTHE4_CHANNEL_X1Y4
i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xch_2/i_gthe4_channel (GTHE4_CHANNEL.QPLL0CLK) is locked to GTHE4_CHANNEL_X0Y9
i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xch_3/i_gthe4_channel (GTHE4_CHANNEL.QPLL0CLK) is locked to GTHE4_CHANNEL_X0Y8
I understand that there is an issue with the GTHE components, but I am unsure how to instruct Vivado which specific GTHE to use for the designated output pins. The "util_adrv9009_xcvr" IP core does not offer many configurable options beyond a few parameters related to frequency management. How should I proceed to resolve this issue?
I appreciate your help in advance.
Parents
    Apologies for the delayed reply.
    Could you take a look at page 29 and page 15? https://docs.amd.com/v/u/en-US/ug578-ultrascale-gty-transceivers
    And check carefully what quad you select since the clock and the data should be as close as possible.
    Using the GT Wizard from Vivado GUI might help you to choose the right pins/quads (looks like this https://docs.amd.com/viewer/attachment/U2GQR49CyPTcdLAya2_2Xg/ppnGOig73uz9Jtlw8tHPkw)
    Here we have an example with 4 devices: https://github.com/analogdevicesinc/hdl/blob/main/projects/adrv9009zu11eg/adrv2crr_fmcomms8/system_project.tcl
    Iulia
  • i need to force the util_adrv9009_xcvr ip core to use the following GTHE4 Channels:
    X1Y11; X1Y10 => QUAD X1Y2 => external clock coming to CLK0
    X1Y5; X1Y4    => QUAD X1Y1 => clock from CLK0 of QUAD X1Y2
    X0Y13; X0Y12 => QUAD X0Y3 => external clock coming to CLK0
    X0Y9; X0Y8    => QUAD X0Y2 => clock from CLK0 of QUAD X0Y3
    how i can achieve this configuration?
    thanks.
    It is just a mater of constraints, chose the corresponding pins.
    https://github.com/analogdevicesinc/hdl/blob/main/projects/adrv9009zu11eg/adrv2crr_fmcomms8/fmcomms8_constr.xdc#L29-L44
    As Iulia pointed out, you should check the transceiver user guide, You will find there that the reference clock from a quad can drive only the adjacent quads.
    Andrei
  • The UTIL_ADXCVR is a wrapper that instantiates transceiver quads, which are also full banks. For 4 channels it instantiates a quad common. The transceiver quads have fixed pinouts for each specific channel. When a channel is instantiated, the pinout for both TX and RX are fixed, there is not flexibility as compared with other general FPGA pins.
    When doing the PCB design, ideally you should use pins from the same quad and adjacent quads. The reference clock should come from the dedicated clock pins of the quad. Depending on the lane rate, you can use also clocks from the quad above and quad below or quad 2 positions above and below.
    Can you tell me what banks you have in your design and where does the clock comes from?
  • Certainly! Below is the FPGA pin configuration (xczu9eg-ffvb1156-2-e) used in conjunction with the GTH transceivers for the initial project, which featured a JESD204 interface driving 8 SoCs. This configuration has been tested and is functioning correctly:
    JESD204 DATA FPGA PIN
    FPGA BANK
    GTHE4
    QUAD
    CLOCK
    Util Xcvr TX0
    Util Xcvr RX0
    229
    X1Y9
    X1Y2
    REF_CLK_A
    Pin P => G8
    Pin N =>G7
    P
    N
    P
    N
    K6
    K5
    K2
    K1
    Util Xcvr TX1
    Util Xcvr RX1
    X1Y8
    P
    N
    P
    N
    H6
    H5
    J4
    J3
    Util Xcvr TX2
    Util Xcvr RX2
    X1Y11
    P
    N
    P
    N
    G4
    G3
    H2
    H1
    Util Xcvr TX3
    Util Xcvr RX3
    X1Y10
    P
    N
    P
    N
    F6
    F5
    F2
    F1
    Util Xcvr TX4
    Util Xcvr RX4
    228
    X1Y5
    X1Y1
    P
    N
    P
    N
    R4
    R3
    T2
    T1
    Util Xcvr TX5
    Util Xcvr RX5
    X1Y4
    P
    N
    P
    N
    P6
    P5
    P2
    P1
    Util Xcvr TX6
    Util Xcvr RX6
    X1Y7
    P
    N
    P
    N
    N4
    N3
    M2
    M1
    Util Xcvr TX7
    Util Xcvr RX7
    X1Y6
    P
    N
    P
    N
    M6
    M5
    L4
    L3
    Util Xcvr TX8
    Util Xcvr RX8
    130
    X0Y13
    X0Y3
    REF_CLK_B
    Pin P => G27
    Pin N =>G28
    P
    N
    P
    N
    F29
    F30
    E31
    E32
    Util Xcvr TX9
    Util Xcvr RX9
    X0Y12
    P
    N
    P
    N
    D29
    D30
    D33
    D34
    Util Xcvr TX10
    Util Xcvr RX10
    X0Y15
    P
    N
    P
    N
    B29
    B30
    C31
    C32
    Util Xcvr TX11
    Util Xcvr RX11
    X0Y14
    P
    N
    P
    N
    A31
    A32
    B33
    B34
    Util Xcvr TX12
    Util Xcvr RX12
    129
    X0Y9
    X0Y2
    P
    N
    P
    N
    K29
    K30
    L31
    L32
    Util Xcvr TX13
    Util Xcvr RX13
    X0Y8
    P
    N
    P
    N
    J31
    J32
    K33
    K34
    Util Xcvr TX14
    Util Xcvr RX14
    X0Y11
    P
    N
    P
    N
    M29
    M30
    M33
    M34
    Util Xcvr TX15
    Util Xcvr RX15
    X0Y10
    P
    N
    P
    N
    G31
    G32
    E33
    E34
    However, in the new project, the board will remain unchanged, but the FPGA configuration will be modified. The desired configuration is as follows:
    FPGA BANK
    GTHE4
    QUAD
    CLOCK
    229
    X1Y9
    X1Y2
    REF_CLK_A
    Pin P => G8
    Pin N =>G7
    X1Y8
    Util Xcvr TX0
    Util Xcvr RX0
    X1Y11
    P
    N
    P
    N
    G4
    G3
    H2
    H1
    Util Xcvr TX1
    Util Xcvr RX1
    X1Y10
    P
    N
    P
    N
    F6
    F5
    F2
    F1
    Util Xcvr TX2
    Util Xcvr RX2
    228
    X1Y5
    X1Y1
    Clock coming from QUAD X1Y2 (REF_CLK_A)
    P
    N
    P
    N
    R4
    R3
    T2
    T1
    Util Xcvr TX3
    Util Xcvr RX3
    X1Y4
    P
    N
    P
    N
    P6
    P5
    P2
    P1
    X1Y7
    X1Y6
    130
    X0Y13
    X0Y3
    REF_CLK_B
    Pin P => G27
    Pin N =>G28
    X0Y12
    Util Xcvr TX4
    Util Xcvr RX4
    X0Y15
    P
    N
    P
    N
    B29
    B30
    C31
    C32
    Util Xcvr TX5
    Util Xcvr RX5
    X0Y14
    P
    N
    P
    N
    A31
    A32
    B33
    B34
    Util Xcvr TX6
    Util Xcvr RX6
    129
    X0Y9
    X0Y2
    Clock coming from QUAD X0Y3 (REF_CLK_B)
    P
    N
    P
    N
    K29
    K30
    L31
    L32
    Util Xcvr TX7
    Util Xcvr RX7
    X0Y8
    P
    N
    P
    N
    J31
    J32
    K33
    K34
    X0Y11
    X0Y10
    But Vivado gives me an error when I try to synthesize and implement it this way... assuming I have configured the util_xcvr block correctly.
  • We need some tests, but for this pinout you'll need to instantiate all 4 quads and it will complicated to use the other transceivers for other applications.
    Is there any way to change the PCB pinout ?
    Adrian
  • Unfortunately, the board, and therefore the PCB, cannot be modified, meaning the routing of the various chips on the PCB cannot be changed. We need to explore an FPGA-based solution, where feasible, to implement the configuration outlined in the table.
  • One option would be to instantiate the util_adxcvr similar with the  older solution (16 channels) and only connect the pins you are using. Not sure how the tool will handle the other channels, so needs some exploration.
    Another option would be to split the design similar with what we've done here: AD9208-DUAL-EBZ HDL reference design [Analog Devices Wiki] so you'll have a physical layer per adjacent banks. in this case you can probably instantiate the number of lanes to 6 per util_adxcvr, which will allow you to have two quad common and 4 channels.
    On top of the vivado implication, there may be also software implications when you bring up the system.
    Adrian
  • Regarding the first option, we have already tried implementing a similar solution in Vivado, but it didn't work as expected. Vivado seems to struggle with it, and, from a software perspective, managing it would be overly complicated.
    The second option, splitting the design and following the AD9208-DUAL-EBZ HDL reference design approach, could be a viable path. However, this would require significant software development effort to accommodate the change, so it’s important to assess whether we can handle the workload involved.
    What I would like to understand more clearly is whether it is possible to synthesize and implement the project with the configuration we have in mind for the util_xcvr, as summarized in the simplified table below:
    • X1Y11; X1Y10 => QUAD X1Y2 => external clock to CLK0
    • X1Y5; X1Y4 => QUAD X1Y1 => clock from CLK0 of QUAD X1Y2
    • X0Y13; X0Y12 => QUAD X0Y3 => external clock to CLK0
    • X0Y9; X0Y8 => QUAD X0Y2 => clock from CLK0 of QUAD X0Y3
    I need to determine whether this configuration is feasible, as it directly impacts the project. If this approach is not possible, we would likely need to redesign the PCB, which would lead to significant development costs and delays. The sooner we can confirm this, the better.
    Additionally, I have another question: If we were to only implement the following configuration:
    Would Vivado be able to synthesize and implement this setup successfully? Understanding this will help us determine if the implementation issue is due to using adjacent QUADs. According to Vivado’s wizard for managing GTHE4, it should be possible to supply the clock from one QUAD to the next, either from above or below, so I’d like to confirm if this holds true in practice.
    I appreciate your insights on these points.
  • Regarding this:
    You mean to create 4 util_adxcvr's each with two channels ?  All of these inside a single util_adxcvr won't be possible, except when instantiating for 16 channels.
    I think the reference clocks should be fine when comming from adjacent quad.
    Adrian
  • No, I mean to create a single util_adxcvr that can manage the configuration I described to you.
    What solution would you suggest?
Reply Children
No Data
