I'm trying to simulate the AD9361 using the fmcomm2 testbench from the ADI testbenches repo. Following the instructions in the README, I cloned the testbenches repository into the root of the ADI hdl repo. I then run `make` from the fmcomms2 directory, and I get an error on line 2 of `system_project.tcl`. The tcl file attempts to source `../../scripts/adi_env.tcl`, which does not exist on that path. That script does exist on the path `../../projects/scripts/adi_env.tcl`. Does this indicate that I've cloned the testbenches repo into the wrong directory?
After updating the path to `adi_env.tcl` in the two project tcl files, I then get an error from the Makefile because the variable `use_smartconnect` has not been set. Should this variable get sourced from another tcl file that I'm missing somewhere? I solved this error by adding `set use_smartconnect 1` into `testbenches/fmcomms2/cfgs/cfg1.tcl`, but this did not seem like it should be required.
Once I added the `use_smartconnect` variable, the simulation actually launched, but terminated with the following error:
Is there something that I'm doing incorrectly here? I'd like to be able to simulate the AD9361 in a testbench under different configurations for developing signal processing IP cores.
Thank you!
