axi_ad9361 IP testing
Product Number: AD9361
Software Version: VIvado 2021.2
I would like to know how can I test axi_ad9361 IP alone without Fmcomms OR AD9361 Hardware board. I came across ad9361_bist_loopback, and would appreciate help in the below.
1. Is FIFO required for this test?
2. Could I use this for testing the IP alone.
     If so will I  require IIO oscilloscope along with libiio text files for I,Q data (from github).
3. Can I test axi_ad9361 IP with ILA. Can I have AD9361 functionalities in the IP without decimator interpolator IP?
Thanks in advance
Jyothi
Thread Notes
    Thank you for the support from your side, I am having an idea of what has to be done, although I would really appreciate if you could help me understand a little more.
    As per my understanding the testbenches have its own project source and does not require any project as reference for carrying out simulation.  I need to give waveforms during simulation or in testbench soucre test_program.sv.
    Is my understanding correct? If so, the steps for cloning clearly states folder structure to be :
    • library
    • projects
    • testbenches
    I have followed the same for cloning the testbenches but it doesnt actually matter cause the testbench is having its own source ?
    I  would really appreciate to get to know about this test code, but I have not been able to find any source for it. Any link or data about this testcode would be of great help.
    Thanks & Regards
  • Yes, the folder structure is correct.
    The testbenches uses the IPs from the HDL repo and are automatically built when you do "make" in a testbench project.
    The Vivado flow copies the IPs source into the created testbench project, that means, vivado will "copy" the IP sources to these paths:
    hdl/testbenches/<TESTBENCH>/runs/cfg*/cfg*.ip_user_files/bd/test_harness/ipshared/*
    hdl/testbenches/<TESTBENCH>/runs/cfg*/cfg*.gen/sources_1/bd/test_harness/ipshared/*
    After the tb project is created, editing the hdl/library/<IP_CORE> sources won't automatically update the test program in execution, you have to either do "make" again (preferred) or patch the folders mentioned above (experienced). The only exception are the test_program.sv files.
    The testbench project may or may not use a hdl/projects/<PROJECT> source code; it really depends on the requirements and on what is being tested.
