I want to transfer data from PL to PS. But there are some data being loss in the process. How can I ensure that the data is continuously being uploaded into the buffer?
AD9361
Recommended for New Designs
The AD9361 is a high performance, highly integrated radio
frequency (RF) Agile Transceiverâ„¢ designed for use in 3G and
4G base station applications....
Datasheet
AD9361 on Analog.com
srimoyi - Moved from Design Support AD9361/AD9363/AD9364 to FPGA Reference Designs. Post date updated from Tuesday, July 2, 2024 11:50 AM UTC to Wednesday, July 3, 2024 5:42 AM UTC to reflect the move.
Moving to FPGA reference designs forum.
Yes I am working on FMCOMMS3 Board and its reference design for Linux.
The data being transferred to PS using ADC DMA is not continuous. it is being dropped. I want to know how to find out about buffer length so the data is not dropped. I also have to perform FFT processing on the data samples. This takes certain time. so how to do processing and continuously read data from buffers without losing samples. the main issue I am facing is not about data loss rather the next read cycle begins from arbitrary location. I need to read data from certain location every time. one option is to read data continuously. other option is to generate trigger but hoe to do it in HDL??
Could you take a look at this thread? Continuously Stream Rx data to PS using ADI AXI DMA
Iulia
I am still unable to understand objectively that what should be the buffer length, if an 'x' time is used for processing??
Is there any formula, the link you posted only tells me that what can be the maximum buffer length? is there any way I can find it myself?
Can we not do it in PyADI IIO???
Yes you can, just be aware that python is interpreted and performance may be worse due to the evaluation.
Do you have any example in C which runs on Linux?
