As per my information, ADC of the EVAL-AD9081 has a maximum sample rate of 4GSPS.
At what other sample rates, we can operate this card?
Is it possible to operate this card at 1GSPS or less sample rates?
AD9081
Recommended for New Designs
The AD9081 mixed signal front end (MxFE®) is a highly integrated device with four 16-bit, 12 GSPS maximum sample rate, RF digital-to-analog converter...
Datasheet
AD9081 on Analog.com
Hi Waqas_Rehman,
You can see the supported modes for the AD9081 in the following user guide: https://www.analog.com/media/en/technical-documentation/user-guides/ad9081-ad9082-ug-1578.pdf (starting from page 94). There is also example "Example 5: 4D2A Single Band, DAC in 1 GSPS I/Q Mode, ADC in 1 GSPS I/Q Mode" at page 239.
Please note that you will need to modify the JESD parameters & clocks in the devicetree, the JESD parameters inside the system_project.tcl file and (possibly) the timing_constr.xdc file with your clock values before building the HDL.
Bogdan
Hi Waqas_Rehman,
Bogdan
