Failed to load the ADRV9009 profile when we added a custom DMAC into the Block Design
Product Number: ADRV9009
Software Version: PetaLinux 2021.1
I'm using the ADRV9009 reference design for my project and we added some custom DMACs into the block design. Those DMACs are connected to a SXX_AXI Interface into the AXI SmartConnect (see image below). Since we added those DMACs into the project, we are not anymore able to update the ADRV9009 profile:
Does anyone have tried to used this reference design with adding some custom DMACs to the Block Design?
Can I shared the resources of one ADRV9009 DMAC and one custom DMAC into the same SmartConnect?
    If yes, Do I have to split the memory address range for those input Interface in the FPGA project or the software will handle this?
Any information, details and Linux examples would be greatly appreciated.
Thanks in advance for all support you guys provided
-Francis
    There is no validation done with the DMA that ca influence a profile loading. Your issue comes from somewhere else.
    What vivado version are you using?
    What FPGA/project?
    Is the profile you are loading a custom one?
    UART messages you get for entering
    dmesg
    jesd_status
    For jesd_status  check all links Rx/RxOBS/Tx.
    Andrei
  • Hi  ,
    Thanks for you reply.
    Vivado 2021.1.1
    What FPGA/project?
    https://github.com/analogdevicesinc/hdl/tree/master/projects/adrv9009/zcu102
    No, it is a generic one: (https://github.com/analogdevicesinc/no-OS/tree/master/projects/adrv9009/profiles/tx_bw100_ir122p88_rx_bw100_or122p88_orx_bw100_or122p88_dc122p88)
    dmesg:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.10.0-xilinx-v2021.1 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP Thu Apr 20 14:26:49 UTC 2023
    [    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
    [    0.000000] printk: bootconsole [cdns0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    [    0.000000] cma: Reserved 256 MiB at 0x000000006c000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
    [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
    [    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
    [    0.000000]   node   0: [mem 0x0000000800000000-0x000000087fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA zone: 4096 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 262144 pages, LIFO batch:63
    [    0.000000]   DMA32 zone: 4096 pages used for memmap
    [    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
    [    0.000000]   Normal zone: 8192 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50968 r8192 d30952 u90112
    [    0.000000] pcpu-alloc: s50968 r8192 d30952 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused uio_pdrv_genirq.of_id=generic-uio
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
    [    0.000000] Memory: 3725372K/4194304K available (15936K kernel code, 1722K rwdata, 12044K rodata, 2624K init, 658K bss, 206788K reserved, 262144K cma-reserved)
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x524 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
    [    0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
    [    0.008505] Console: colour dummy device 80x25
    [    0.012485] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
    [    0.022841] pid_max: default: 32768 minimum: 301
    [    0.027598] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.034790] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.043613] rcu: Hierarchical SRCU implementation.
    [    0.047613] EFI services will not be available.
    [    0.051964] smp: Bringing up secondary CPUs ...
    [    0.056703] Detected VIPT I-cache on CPU1
    [    0.056746] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.057147] Detected VIPT I-cache on CPU2
    [    0.057171] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.057555] Detected VIPT I-cache on CPU3
    [    0.057579] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.057627] smp: Brought up 1 node, 4 CPUs
    [    0.091780] SMP: Total of 4 processors activated.
    [    0.096453] CPU features: detected: 32-bit EL0 Support
    [    0.101556] CPU features: detected: CRC32 instructions
    [    0.106694] CPU: All CPU(s) started at EL2
    [    0.110737] alternatives: patching kernel code
    [    0.116293] devtmpfs: initialized
    [    0.126491] Registered cp15_barrier emulation handler
    [    0.126543] Registered setend emulation handler
    [    0.130527] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.140106] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.153519] pinctrl core: initialized pinctrl subsystem
    [    0.154216] NET: Registered protocol family 16
    [    0.158605] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.164596] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.172319] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.180136] audit: initializing netlink subsys (disabled)
    [    0.185604] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
    [    0.193179] cpuidle: using governor menu
    [    0.197122] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.203856] ASID allocator initialised with 65536 entries
    [    0.235656] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.236709] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.243380] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.250040] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    1.315787] DRBG: Continuing without Jitter RNG
    [    1.393532] raid6: neonx8   gen()  2144 MB/s
    [    1.461588] raid6: neonx8   xor()  1598 MB/s
    [    1.529655] raid6: neonx4   gen()  2193 MB/s
    [    1.597712] raid6: neonx4   xor()  1568 MB/s
    [    1.665792] raid6: neonx2   gen()  2077 MB/s
    [    1.733839] raid6: neonx2   xor()  1438 MB/s
    [    1.801911] raid6: neonx1   gen()  1774 MB/s
    [    1.869974] raid6: neonx1   xor()  1220 MB/s
    [    1.938033] raid6: int64x8  gen()  1438 MB/s
    [    2.006102] raid6: int64x8  xor()   771 MB/s
    [    2.074177] raid6: int64x4  gen()  1602 MB/s
    [    2.142242] raid6: int64x4  xor()   820 MB/s
    [    2.210321] raid6: int64x2  gen()  1398 MB/s
    [    2.278379] raid6: int64x2  xor()   749 MB/s
    [    2.346439] raid6: int64x1  gen()  1033 MB/s
    [    2.414517] raid6: int64x1  xor()   517 MB/s
    [    2.414555] raid6: using algorithm neonx4 gen() 2193 MB/s
    [    2.418509] raid6: .... xor() 1568 MB/s, rmw enabled
    [    2.423440] raid6: using neon recovery algorithm
    [    2.428571] iommu: Default domain type: Translated
    [    2.433088] SCSI subsystem initialized
    [    2.436607] libata version 3.00 loaded.
    [    2.436741] usbcore: registered new interface driver usbfs
    [    2.442065] usbcore: registered new interface driver hub
    [    2.447347] usbcore: registered new device driver usb
    [    2.452483] mc: Linux media interface: v0.10
    [    2.456587] videodev: Linux video capture interface: v2.00
    [    2.462085] EDAC MC: Ver: 3.0.0
    [    2.465540] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
    [    2.474116] jesd204: created con: id=0, topo=0, link=0, /axi/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-tx@84a80000
    [    2.484698] jesd204: created con: id=1, topo=0, link=2, /axi/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a50000
    [    2.496027] jesd204: created con: id=2, topo=0, link=1, /axi/spi@ff040000/ad9528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
    [    2.507097] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@84a50000 <-> /fpga-axi@0/axi-jesd204-rx-os@84ab0000
    [    2.519293] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84a80000 <-> /fpga-axi@0/axi-jesd204-tx@84a90000
    [    2.530970] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84aa0000
    [    2.542649] jesd204: created con: id=6, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a90000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
    [    2.554886] jesd204: created con: id=7, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84aa0000 <-> /axi/spi@ff040000/adrv9009-phy@1
    [    2.566357] jesd204: created con: id=8, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx-os@84ab0000 <-> /axi/spi@ff040000/adrv9009-phy@1
    [    2.578121] jesd204: created con: id=9, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /axi/spi@ff040000/adrv9009-phy@1
    [    2.590059] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:0] transition uninitialized -> initialized
    [    2.599738] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:1] transition uninitialized -> initialized
    [    2.609421] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:2] transition uninitialized -> initialized
    [    2.619104] jesd204: found 9 devices and 1 topologies
    [    2.624150] FPGA manager framework
    [    2.627650] Advanced Linux Sound Architecture Driver Initialized.
    [    2.633936] Bluetooth: Core ver 2.22
    [    2.637107] NET: Registered protocol family 31
    [    2.641508] Bluetooth: HCI device and connection manager initialized
    [    2.647826] Bluetooth: HCI socket layer initialized
    [    2.652668] Bluetooth: L2CAP socket layer initialized
    [    2.657689] Bluetooth: SCO socket layer initialized
    [    2.662856] clocksource: Switched to clocksource arch_sys_counter
    [    2.668731] VFS: Disk quotas dquot_6.6.0
    [    2.672521] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    2.683468] NET: Registered protocol family 2
    [    2.683976] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    2.692154] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    2.700183] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    2.707640] TCP: Hash tables configured (established 32768 bind 32768)
    [    2.713806] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.720469] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.727650] NET: Registered protocol family 1
    [    2.732121] RPC: Registered named UNIX socket transport module.
    [    2.737704] RPC: Registered udp transport module.
    [    2.742371] RPC: Registered tcp transport module.
    [    2.747042] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.754032] PCI: CLS 0 bytes, default 64
    [    2.757441] Trying to unpack rootfs image as initramfs...
    [    4.084126] Freeing initrd memory: 27072K
    [    4.084765] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    4.089798] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    4.098314] Initialise system trusted keyrings
    [    4.101888] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    4.108824] NFS: Registering the id_resolver key type
    [    4.113146] Key type id_resolver registered
    [    4.117285] Key type id_legacy registered
    [    4.121281] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    4.127938] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    [    4.135133] fuse: init (API version 7.32)
    [    4.174824] NET: Registered protocol family 38
    [    4.174875] xor: measuring software checksum speed
    [    4.182551]    8regs           :  2363 MB/sec
    [    4.186225]    32regs          :  2799 MB/sec
    [    4.191171]    arm64_neon      :  2380 MB/sec
    [    4.191357] xor: using function: 32regs (2799 MB/sec)
    [    4.196383] Key type asymmetric registered
    [    4.200445] Asymmetric key parser 'x509' registered
    [    4.205308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    4.212643] io scheduler mq-deadline registered
    [    4.217138] io scheduler kyber registered
    [    4.248439] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    4.254375] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    4.259717] brd: module loaded
    [    4.264224] loop: module loaded
    [    4.264589] Registered mathworks_ip class
    [    4.268450] libphy: Fixed MDIO Bus: probed
    [    4.270808] tun: Universal TUN/TAP device driver, 1.6
    [    4.274930] CAN device driver interface
    [    4.279695] usbcore: registered new interface driver asix
    [    4.284010] usbcore: registered new interface driver ax88179_178a
    [    4.290046] usbcore: registered new interface driver cdc_ether
    [    4.295843] usbcore: registered new interface driver net1080
    [    4.301463] usbcore: registered new interface driver cdc_subset
    [    4.307346] usbcore: registered new interface driver zaurus
    [    4.312890] usbcore: registered new interface driver cdc_ncm
    [    4.319539] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    4.324973] ehci-pci: EHCI PCI platform driver
    [    4.329853] usbcore: registered new interface driver uas
    [    4.334689] usbcore: registered new interface driver usb-storage
    [    4.340678] usbcore: registered new interface driver usbserial_generic
    [    4.347130] usbserial: USB Serial support registered for generic
    [    4.353104] usbcore: registered new interface driver ftdi_sio
    [    4.358804] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    4.366083] usbcore: registered new interface driver upd78f0730
    [    4.371953] usbserial: USB Serial support registered for upd78f0730
    [    4.379902] rtc_zynqmp ffa60000.rtc: registered as rtc0
    [    4.383379] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-05-24T19:51:01 UTC (1684957861)
    [    4.392245] i2c /dev entries driver
    [    4.397955] usbcore: registered new interface driver uvcvideo
    [    4.401352] USB Video Class driver (1.1.1)
    [    4.407091] Bluetooth: HCI UART driver ver 2.3
    [    4.409823] Bluetooth: HCI UART protocol H4 registered
    [    4.414934] Bluetooth: HCI UART protocol BCSP registered
    [    4.420222] Bluetooth: HCI UART protocol LL registered
    [    4.425310] Bluetooth: HCI UART protocol ATH3K registered
    [    4.430686] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    4.436947] Bluetooth: HCI UART protocol Intel registered
    [    4.442276] Bluetooth: HCI UART protocol QCA registered
    [    4.447478] usbcore: registered new interface driver bcm203x
    [    4.453100] usbcore: registered new interface driver bpa10x
    [    4.458635] usbcore: registered new interface driver bfusb
    [    4.464087] usbcore: registered new interface driver btusb
    [    4.469548] usbcore: registered new interface driver ath3k
    [    4.475045] EDAC MC: ECC not enabled
    [    4.478676] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    4.491037] sdhci: Secure Digital Host Controller Interface driver
    [    4.496759] sdhci: Copyright(c) Pierre Ossman
    [    4.501084] sdhci-pltfm: SDHCI platform and OF driver helper
    [    4.507242] ledtrig-cpu: registered to indicate activity on CPUs
    [    4.512691] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    4.519115] zynqmp_firmware_probe Platform Management API v1.1
    [    4.524876] zynqmp_firmware_probe Trustzone version v1.0
    [    4.574625] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
    [    4.629903] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
    [    4.652170] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    4.652927] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    4.658406] usbcore: registered new interface driver usbhid
    [    4.663786] usbhid: USB HID core driver
    [    4.676421] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    4.678782] axi_sysid 85000000.axi-sysid-0: [adrv9009] on [zcu102] git branch <hdl_2021_r1> git <bd8ec2ac42f6faadfa67d62eda56f8dce160e4e1> clean [2023-02-15 23:33:42] UTC
    [    4.694319] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    4.700721] usbcore: registered new interface driver snd-usb-audio
    [    4.708373] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    4.714428] Initializing XFRM netlink socket
    [    4.718118] NET: Registered protocol family 10
    [    4.722878] Segment Routing with IPv6
    [    4.726250] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    4.732312] NET: Registered protocol family 17
    [    4.736397] NET: Registered protocol family 15
    [    4.740865] can: controller area network core
    [    4.745147] NET: Registered protocol family 29
    [    4.749536] can: raw protocol
    [    4.752472] can: broadcast manager protocol
    [    4.756627] can: netlink gateway - max_hops=1
    [    4.761023] Bluetooth: RFCOMM TTY layer initialized
    [    4.765803] Bluetooth: RFCOMM socket layer initialized
    [    4.770912] Bluetooth: RFCOMM ver 1.11
    [    4.774614] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    4.779892] Bluetooth: BNEP filters: protocol multicast
    [    4.785085] Bluetooth: BNEP socket layer initialized
    [    4.790011] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    4.795895] Bluetooth: HIDP socket layer initialized
    [    4.800975] 9pnet: Installing 9P2000 support
    [    4.805089] NET: Registered protocol family 36
    [    4.809491] Key type dns_resolver registered
    [    4.813906] registered taskstats version 1
    [    4.817788] Loading compiled-in X.509 certificates
    [    4.822921] Btrfs loaded, crc32c=crc32c-generic
    [    4.836233] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 51, base_baud = 6249999) is a xuartps
    [    4.845253] printk: console [ttyPS0] enabled
    [    4.849549] printk: bootconsole [cdns0] disabled
    [    4.859200] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 52, base_baud = 6249999) is a xuartps
    [    4.872399] of-fpga-region fpga-full: FPGA Region probed
    [    4.879405] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
    [    4.886304] nwl-pcie fd0e0000.pcie:      MEM 0x00e0000000..0x00efffffff -> 0x00e0000000
    [    4.894309] nwl-pcie fd0e0000.pcie:      MEM 0x0600000000..0x07ffffffff -> 0x0600000000
    [    4.902373] nwl-pcie fd0e0000.pcie: Link is DOWN
    [    4.907134] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
    [    4.913312] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    4.918795] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
    [    4.925659] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
    [    4.933163] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
    [    4.939228] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
    [    4.950615] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
    [    4.957378] axi_dmac_detect_caps line 925
    [    4.961476] axi_dmac_detect_caps line 959
    [    4.965572] axi_dmac_detect_caps line 964
    [    4.969902] axi_dmac_detect_caps line 925
    [    4.973992] axi_dmac_detect_caps line 959
    [    4.978085] axi_dmac_detect_caps line 964
    [    4.982385] axi_dmac_detect_caps line 925
    [    4.986480] axi_dmac_detect_caps line 959
    [    4.990565] axi_dmac_detect_caps line 964
    [    4.995045] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
    [    5.002222] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
    [    5.009399] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
    [    5.016578] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
    [    5.023756] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
    [    5.030939] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
    [    5.038110] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
    [    5.045289] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
    [    5.052696] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
    [    5.061123] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
    [    5.068671] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
    [    5.077455] ad9528 spi2.0: supply vcc not found, using dummy regulator
    [    5.108387] jesd204: /axi/spi@ff040000/ad9528-1@0,jesd204:0,parent=spi2.0: Using as SYSREF provider
    [    5.117799] adrv9009 spi2.1: adrv9009_probe : enter
    [    5.128993] spi-nor spi0.0: SPI-NOR-UniqueID 2c349600021600210006b9178c84
    [    5.135790] spi-nor spi0.0: found mt25qu512a, expected m25p80
    [    5.142097] spi-nor spi0.0: trying to lock already unlocked area
    [    5.148110] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
    [    5.153265] 4 fixed-partitions partitions found on MTD device spi0.0
    [    5.159611] Creating 4 MTD partitions on "spi0.0":
    [    5.164401] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    5.171047] 0x000000100000-0x000000600000 : "qspi-linux"
    [    5.177048] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    5.183568] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    5.192257] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    5.199789] libphy: MACB_mii_bus: probed
    [    5.207892] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 33 (6a:63:57:05:61:38)
    [    5.218242] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    5.224856] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    5.231406] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    5.237950] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    5.251017] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    5.257714] pca953x 0-0020: using no AI
    [    5.262189] gpio-496 (sel0): hogged as output/low
    [    5.267091] gpio-497 (sel1): hogged as output/high
    [    5.272088] gpio-498 (sel2): hogged as output/high
    [    5.277071] gpio-499 (sel3): hogged as output/high
    [    5.282261] pca953x 0-0021: supply vcc not found, using dummy regulator
    [    5.288940] pca953x 0-0021: using no AI
    [    5.294753] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.301796] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.308827] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.315863] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.322911] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.329941] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.336983] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.344075] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.351120] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.358154] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.364561] i2c i2c-0: Added multiplexed i2c bus 2
    [    5.370161] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
    [    5.377204] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.384237] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.391273] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.398317] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.405194] random: fast init done
    [    5.408667] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.415700] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.422738] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.429135] i2c i2c-0: Added multiplexed i2c bus 3
    [    5.485145] i2c i2c-0: Added multiplexed i2c bus 4
    [    5.490087] i2c i2c-0: Added multiplexed i2c bus 5
    [    5.494880] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
    [    5.502230] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 35
    [    5.510084] at24 6-0054: supply vcc not found, using dummy regulator
    [    5.516983] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
    [    5.523732] i2c i2c-1: Added multiplexed i2c bus 6
    [    5.530010] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 1
    [    5.567601] i2c i2c-1: Added multiplexed i2c bus 7
    [    5.575263] si570 8-005d: registered, current frequency 300000000 Hz
    [    5.581670] i2c i2c-1: Added multiplexed i2c bus 8
    [    5.601462] si570 9-005d: registered, current frequency 148500000 Hz
    [    5.607871] i2c i2c-1: Added multiplexed i2c bus 9
    [    5.612917] si5324 10-0069: si5328 probed
    [    5.679190] si5324 10-0069: si5328 probe successful
    [    5.684119] i2c i2c-1: Added multiplexed i2c bus 10
    [    5.689165] i2c i2c-1: Added multiplexed i2c bus 11
    [    5.694193] i2c i2c-1: Added multiplexed i2c bus 12
    [    5.699221] i2c i2c-1: Added multiplexed i2c bus 13
    [    5.704095] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
    [    5.712133] i2c i2c-1: Added multiplexed i2c bus 14
    [    5.718379] at24 15-0050: supply vcc not found, using dummy regulator
    [    5.725179] at24 15-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    [    5.731929] i2c i2c-1: Added multiplexed i2c bus 15
    [    5.736979] i2c i2c-1: Added multiplexed i2c bus 16
    [    5.742015] i2c i2c-1: Added multiplexed i2c bus 17
    [    5.747057] i2c i2c-1: Added multiplexed i2c bus 18
    [    5.752096] i2c i2c-1: Added multiplexed i2c bus 19
    [    5.757137] i2c i2c-1: Added multiplexed i2c bus 20
    [    5.762179] i2c i2c-1: Added multiplexed i2c bus 21
    [    5.767059] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
    [    5.774668] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 36
    [    5.784832] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    5.813940] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x(____ptrval____), probed ADC ADRV9009 as MASTER
    [    5.826745] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    5.847317] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS AD9371
    [    5.864082] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 2.
    [    5.877701] axi_adxcvr 84a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A50000. Number of lanes: 2.
    [    5.890163] axi_adxcvr 84a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTH4 at 0x84A80000. Number of lanes: 4.
    [    5.904501] axi_dmac_detect_caps line 925
    [    5.908601] axi_dmac_detect_caps line 933
    [    5.912700] axi_dmac_detect_caps line 959
    [    5.916794] axi_dmac_detect_caps line 964
    [    5.921152] axi_dmac_detect_caps line 925
    [    5.925240] axi_dmac_detect_caps line 933
    [    5.929325] axi_dmac_detect_caps line 959
    [    5.933412] axi_dmac_detect_caps line 964
    [    5.938500] zynqmp-display fd4a0000.display: vtc bridge property not present
    [    5.946676] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13
    [    5.956362] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    5.965861] xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_codec0 failed with error -22
    [    5.975426] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    5.983613] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    5.991900] OF: graph: no port node found in /axi/display@fd4a0000
    [    5.998332] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc0110f0348)
    [    6.006512] mmc0: new high speed SDHC card at address aaaa
    [    6.012398] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
    [    6.021711]  mmcblk0: p1
    [    7.082877] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
    [    7.090510] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
    [    7.098005] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
    [    7.106424] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
    [    7.113973] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
    [    7.121432] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
    [    7.139341] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
    [    7.148302] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
    [    7.158796] scsi host0: ahci-ceva
    [    7.162416] scsi host1: ahci-ceva
    [    7.165843] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 48
    [    7.173754] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 48
    [    7.185410] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.190916] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    7.198680] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010810
    [    7.208102] xhci-hcd xhci-hcd.1.auto: irq 63, io mem 0xfe200000
    [    7.214260] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    7.222524] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.229742] usb usb1: Product: xHCI Host Controller
    [    7.234616] usb usb1: Manufacturer: Linux 5.10.0-xilinx-v2021.1 xhci-hcd
    [    7.241308] usb usb1: SerialNumber: xhci-hcd.1.auto
    [    7.246509] hub 1-0:1.0: USB hub found
    [    7.250273] hub 1-0:1.0: 1 port detected
    [    7.254387] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.259878] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    7.267529] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [    7.274170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    7.282431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.289652] usb usb2: Product: xHCI Host Controller
    [    7.294527] usb usb2: Manufacturer: Linux 5.10.0-xilinx-v2021.1 xhci-hcd
    [    7.301224] usb usb2: SerialNumber: xhci-hcd.1.auto
    [    7.306357] hub 2-0:1.0: USB hub found
    [    7.310123] hub 2-0:1.0: 1 port detected
    [    7.318684] axi-jesd204-rx 84aa0000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84AA0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
    [    7.331648] axi-jesd204-rx 84ab0000.axi-jesd204-rx-os: AXI-JESD204-RX (1.07.a) at 0x84AB0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
    [    7.344793] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition initialized -> probed
    [    7.356008] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition initialized -> probed
    [    7.367218] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition initialized -> probed
    [    7.378442] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition probed -> idle
    [    7.389046] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition probed -> idle
    [    7.399657] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition probed -> idle
    [    7.410268] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition idle -> device_init
    [    7.421312] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition idle -> device_init
    [    7.432357] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition idle -> device_init
    [    7.443402] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> link_init
    [    7.454876] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> link_init
    [    7.466352] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> link_init
    [    7.477838] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> link_supported
    [    7.489569] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> link_supported
    [    7.493076] ata1: SATA link down (SStatus 0 SControl 330)
    [    7.501308] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> link_supported
    [    7.506710] ata2: SATA link down (SStatus 0 SControl 330)
    [    7.518901] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_pre_setup
    [    7.535974] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_pre_setup
    [    7.548143] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_pre_setup
    [    7.560466] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
    [    7.572728] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_pre_setup -> clk_sync_stage1
    [    7.584981] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
    [    7.597242] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.609580] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.621925] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.634273] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.646620] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.658961] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.673340] adrv9009 spi2.1: ADIHAL_resetHw
    [    8.005887] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage3 -> link_setup
    [    8.017800] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage3 -> link_setup
    [    8.029710] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage3 -> link_setup
    [    8.041816] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_setup -> opt_setup_stage1
    [    8.053817] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_setup -> opt_setup_stage1
    [    8.065816] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_setup -> opt_setup_stage1
    [    8.227418] random: crng init done
    [    8.322880] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
    [   10.264786] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
    [   10.277307] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage1 -> opt_setup_stage2
    [   10.289827] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2
    [   10.302543] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
    [   10.315061] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage2 -> opt_setup_stage3
    [   10.327573] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3
    [   10.340309] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
    [   10.352828] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage3 -> opt_setup_stage4
    [   10.365341] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4
    [   15.379932] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
    [   15.392456] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage4 -> opt_setup_stage5
    [   15.404979] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5
    [   15.417899] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
    [   15.430158] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage5 -> clocks_enable
    [   15.442417] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable
    [   15.458861] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clocks_enable -> link_enable
    [   15.470684] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clocks_enable -> link_enable
    [   15.482505] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clocks_enable -> link_enable
    [   15.527063] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_enable -> link_running
    [   15.538798] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_enable -> link_running
    [   15.550530] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_enable -> link_running
    [   15.664579] adrv9009 spi2.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.2.1 API version: 3.6.2.1 successfully initialized via jesd204-fsm
    [   15.677012] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_running -> opt_post_running_stage
    [   15.689706] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_running -> opt_post_running_stage
    [   15.702395] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_running -> opt_post_running_stage
    [   15.715093] axi-jesd204-tx 84a90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [   15.738011] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [   15.745159] of_cfs_init
    [   15.747634] of_cfs_init: OK
    [   15.750646] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   15.891955] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   15.898493] clk: Not disabling unused clocks
    [   15.903035] ALSA device list:
    [   15.905990]   No soundcards found.
    [   15.909669] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [   15.918277] cfg80211: failed to load regulatory.db
    [   15.923837] Freeing unused kernel memory: 2624K
    [   15.958930] Run /init as init process
    [   15.962575]   with arguments:
    [   15.962578]     /init
    [   15.962580]   with environment:
    [   15.962582]     HOME=/
    [   15.962584]     TERM=linux
    [   16.036431] /dev/root: Can't open blockdev
    [   16.072403] udevd[169]: starting version 3.2.9
    [   16.082120] udevd[170]: starting eudev-3.2.9
    [   16.224413] onedtransfer: loading out-of-tree module taints kernel.
    [   16.225671] twodtransfer: loading out-of-tree module taints kernel.
    [   16.242686] twodtransfer twodtransfer@10: Device Tree Probing 'twodtransfer'
    [   16.242690] onedtransfer onedtransfer@10: Device Tree Probing 'onedtransfer'
    [   16.242958] twodtransfer twodtransfer@10: Device Tree Probing end
    [   16.244966] onedtransfer onedtransfer@10: Device Tree Probing end
    [   16.467214] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   16.857417] macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:0c] driver [TI DP83867] (irq=POLL)
    [   16.857428] macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
    [   20.952528] macb ff0e0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
    [   20.952553] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   15.962578]     /init
    [   15.962582]     HOME=/
    [  459.797425] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_post_running_stage -> opt_post_running_stage
    [  459.797440] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_post_running_stage -> opt_post_running_stage
    [  459.797450] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_post_running_stage -> opt_post_running_stage
    [  459.797468] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_post_running_stage -> link_running
    [  459.797478] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_post_running_stage -> link_running
    [  459.797488] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_post_running_stage -> link_running
    [  459.797516] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_running -> link_enable
    [  459.797525] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_running -> link_enable
    [  459.797534] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_running -> link_enable
    [  459.797553] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_enable -> clocks_enable
    [  459.797562] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_enable -> clocks_enable
    [  459.797571] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_enable -> clocks_enable
    [  459.797584] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clocks_enable -> opt_setup_stage5
    [  459.797594] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clocks_enable -> opt_setup_stage5
    [  459.797603] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clocks_enable -> opt_setup_stage5
    [  459.797617] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage5 -> opt_setup_stage4
    [  459.797626] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage5 -> opt_setup_stage4
    [  459.797635] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage5 -> opt_setup_stage4
    [  459.797648] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage3
    [  459.797657] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage4 -> opt_setup_stage3
    [  459.797666] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage3
    [  459.797680] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage2
    [  459.797689] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage3 -> opt_setup_stage2
    [  459.797698] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage2
    [  459.797711] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage1
    [  459.797720] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage2 -> opt_setup_stage1
    [  459.797729] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage1
    [  459.797748] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition opt_setup_stage1 -> link_setup
    [  459.797757] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition opt_setup_stage1 -> link_setup
    [  459.797766] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition opt_setup_stage1 -> link_setup
    [  459.797779] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_setup -> clk_sync_stage3
    [  459.797788] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_setup -> clk_sync_stage3
    [  459.797797] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_setup -> clk_sync_stage3
    [  459.797810] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage2
    [  459.797819] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage3 -> clk_sync_stage2
    [  459.797828] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage2
    [  459.797841] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage1
    [  459.797850] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage1
    [  459.797859] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage1
    [  459.797867] adrv9009 spi2.1: ADIHAL_resetHw
    [  459.799113] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition clk_sync_stage1 -> link_pre_setup
    [  459.799123] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition clk_sync_stage1 -> link_pre_setup
    [  459.799139] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition clk_sync_stage1 -> link_pre_setup
    [  459.799159] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_pre_setup -> link_supported
    [  459.799168] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_pre_setup -> link_supported
    [  459.799178] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_pre_setup -> link_supported
    [  459.799192] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_init
    [  459.799201] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_init
    [  459.799210] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_init
    [  459.799223] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> device_init
    [  459.799238] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> device_init
    [  459.799253] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> device_init
    [  459.799267] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> idle
    [  459.799277] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> idle
    [  459.799286] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> idle
    [  459.799306] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition idle -> idle
    [  459.799315] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition idle -> idle
    [  459.799324] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition idle -> idle
    [  459.799345] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition idle -> device_init
    [  459.799359] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition idle -> device_init
    [  459.799368] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition idle -> device_init
    [  459.799383] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> link_init
    [  459.799392] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> link_init
    [  459.799401] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> link_init
    [  459.799421] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> link_supported
    [  459.799437] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> link_supported
    [  459.799451] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> link_supported
    [  459.799543] axi-jesd204-rx 84aa0000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link1 set device clock rate 122880000 Hz failed (-16)
    [  459.812510] jesd204: /fpga-axi@0/axi-jesd204-rx@84aa0000,jesd204:3,parent=84aa0000.axi-jesd204-rx: JESD204[0:1] In link_pre_setup got error from cb: -16
    [  459.826164] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: Rolling back from 'link_supported', got error -16
    [  459.837722] adrv9009 spi2.1: ADIHAL_resetHw
    [  459.838846] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_pre_setup
    [  459.838871] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_pre_setup
    [  459.838883] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_pre_setup
    [  459.838897] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_pre_setup -> link_supported
    [  459.838906] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_pre_setup -> link_supported
    [  459.838916] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_pre_setup -> link_supported
    [  459.838934] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_init
    [  459.838944] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_init
    [  459.838953] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_init
    [  459.838965] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> device_init
    [  459.838979] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> device_init
    [  459.838993] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> device_init
    [  459.839008] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> idle
    [  459.839017] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> idle
    [  459.839026] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> idle
    [  459.839035] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: FSM completed with error -16
    [  459.848787] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> idle
    [  459.848796] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> idle
    [  459.848805] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> idle
    [  459.848823] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition idle -> idle
    [  459.848832] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition idle -> idle
    [  459.848841] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition idle -> idle
    [  459.848854] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition idle -> device_init
    [  459.848863] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition idle -> device_init
    [  459.848873] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition idle -> device_init
    [  459.848886] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> link_init
    [  459.848895] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> link_init
    [  459.848904] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> link_init
    [  459.848921] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> link_supported
    [  459.848930] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> link_supported
    [  459.848940] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> link_supported
    [  459.849016] axi-jesd204-rx 84aa0000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link1 set device clock rate 122880000 Hz failed (-16)
    [  459.861971] jesd204: /fpga-axi@0/axi-jesd204-rx@84aa0000,jesd204:3,parent=84aa0000.axi-jesd204-rx: JESD204[0:1] In link_pre_setup got error from cb: -16
    [  459.875621] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: Rolling back from 'link_supported', got error -16
    [  459.887179] adrv9009 spi2.1: ADIHAL_resetHw
    [  459.888246] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_pre_setup
    [  459.888257] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_pre_setup
    [  459.888266] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_pre_setup
    [  459.888280] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_pre_setup -> link_supported
    [  459.888289] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_pre_setup -> link_supported
    [  459.888298] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_pre_setup -> link_supported
    [  459.888311] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_supported -> link_init
    [  459.888320] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_supported -> link_init
    [  459.888329] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_supported -> link_init
    [  459.888341] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition link_init -> device_init
    [  459.888351] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition link_init -> device_init
    [  459.888360] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition link_init -> device_init
    [  459.888373] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:2] transition device_init -> idle
    [  459.888382] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:1] transition device_init -> idle
    [  459.888391] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: JESD204[0:0] transition device_init -> idle
    [  459.888399] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi2.1: FSM completed with error -16
    Looks I got stuck at LINK_SUPPORTED state into the JESD204-FSM when I'm trying to upload the profile with my custom DMACs into this ADRV9009 reference design:
    Any idea how I can solve or investigate further this problem?
  • The device clock in that profile is too slow for HDL designs in master. Try one from here: https://github.com/analogdevicesinc/iio-oscilloscope/tree/master/filters/adrv9009 with 2x the device clocks.
    -Travis
  • Hi  ,
    Sorry I forgot to mention that I'm using the hdl_2021_r1 branch.
    Note: When I remove my custom DMACs into the block design, this profile is updated successfully.
    Do you still think I should increased the device clock?
    -Francis
  • The old 122.88DC based profiles were removed for this reason. Using that clock rate was not reliable.
    Please try the ones I listed and let us know if that helps your custom design.
    -Travis
  • Hi
    It works well with this profile: Tx_BW200_IR245p76_Rx_BW200_OR245p76_ORx_BW200_OR245p76_DC245p76.txt
    Good tip for myself next time is check the history of this repo Slight smile
    Thanks again!
