The make command fails to build the library! Plz guide me how to fix this error?
AD9361
Recommended for New Designs
The AD9361 is a high performance, highly integrated radio
frequency (RF) Agile Transceiver™ designed for use in 3G and
4G base station applications. Its...
Datasheet
AD9361 on Analog.com
Which hdl branch are you using? The 2019.1 vivado version is compatible with our HDL_2019_R2 release, so my first guess would be that you encountered a version mismatch.
Can you share the log…
hey Stanca! Thank you !
I am new to the environment! where can i get the log file?
In your screenshot, it says "For details see....". That's the log file.
Also, please check our guide on how to build a project, how you have to…
Can you share the log file?
Kind regards,
Stanca
Also, please check our guide on how to build a project, how you have to set up the environment, etc.: Building HDL wiki page
Iulia
you were right! it w`as a version mismatch
