Error 127 make HDL project with Cygwin in Windows.
Product Number: zcu102
Software Version: Vivado 2020.2 cygwin64
I get an error when I want to make a make command to generate the Refernce Design Project file.
I already tried everything what has been described in the "HDL make error 127" Q&A ( RE: HDL make error 127 ) from December 2020.
Unfortunately nothing helps any Idea what else I could try?
  • Hello,
    What branch are you using? It might be because we don't have Vivado 2020.2 in any of our releases, so I think it's failing because of version check. Can you also post the log here?
    You can find the log at the path specified after "For details see".
    Iulia
  • You are right seems like a version mismatch
    ****** Vivado v2020.2 (64-bit)
      **** SW Build 3064766 on Wed Nov 18 09:12:45 MST 2020
      **** IP Build 3064653 on Wed Nov 18 14:17:31 MST 2020
        ** Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_10.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_11.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_12.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_13.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_14.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_15.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_16.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_17.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_18.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_19.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_2.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_20.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_3.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_4.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_5.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_6.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_7.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_8.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    WARNING: [Runs 36-547] User Strategy 'Vivado Implementation Defaults' from file 'C:\Users\broennimann\AppData\Roaming/Xilinx/Vivado/2019.2/strategies/Vivado Implementation Defaults_9.Vivado Implementation 2015.psg' discarded because strategy with same name already parsed from 'C:/Xilinx/Vivado/2020.2/strategies/VDI2015.psg'
    source axi_clkgen_ip.tcl
    # source ../../scripts/adi_env.tcl
    ## set ad_hdl_dir [file normalize [file join [file dirname [info script]] "../"]]
    ## if [info exists ::env(ADI_HDL_DIR)] {
    ##   set ad_hdl_dir [file normalize $::env(ADI_HDL_DIR)]
    ## if [info exists ::env(ADI_GHDL_DIR)] {
    ##   set ad_ghdl_dir [file normalize $::env(ADI_GHDL_DIR)]
    ## set required_vivado_version "2021.2"
    ## if {[info exists ::env(REQUIRED_VIVADO_VERSION)]} {
    ##   set required_vivado_version $::env(REQUIRED_VIVADO_VERSION)
    ## } elseif {[info exists REQUIRED_VIVADO_VERSION]} {
    ##   set required_vivado_version $REQUIRED_VIVADO_VERSION
    ## if {[info exists ::env(ADI_IGNORE_VERSION_CHECK)]} {
    ##   set IGNORE_VERSION_CHECK 1
    ## } elseif {![info exists IGNORE_VERSION_CHECK]} {
    ##   set IGNORE_VERSION_CHECK 0
    ## if {![info exists REQUIRED_QUARTUS_VERSION]} {
    ##   set REQUIRED_QUARTUS_VERSION "21.4.0"
    ## proc get_env_param {name default_value} {
    ##   if [info exists ::env($name)] {
    ##     puts "Getting from environment the parameter: $name=$::env($name) "
    ##     return $::env($name)
    ##   } else {
    ##     return $default_value
    # source $ad_hdl_dir/library/scripts/adi_ip_xilinx.tcl
    ## source $ad_hdl_dir/library/scripts/adi_xilinx_device_info_enc.tcl
    ### variable auto_set_param_list
    ### variable auto_set_param_list_overwritable
    ### variable fpga_series_list
    ### variable fpga_family_list
    ### variable speed_grade_list
    ### variable dev_package_list
    ### variable xcvr_type_list
    ### variable fpga_voltage_list
    ### set auto_set_param_list { \
    ###           DEV_PACKAGE \
    ###           SPEED_GRADE \
    ###           FPGA_FAMILY \
    ###           FPGA_TECHNOLOGY }
    ### set auto_set_param_list_overwritable { \
    ###           FPGA_VOLTAGE \
    ###           XCVR_TYPE }
    ### set fpga_technology_list { \
    ###         { Unknown     0 } \
    ###         { 7series     1 } \
    ###         { ultrascale  2 } \
    ###         { ultrascale+ 3 } \
    ###         { versal      4 }}
    ### set fpga_family_list { \
    ###         { Unknown      0 } \
    ###         { artix        1 } \
    ###         { kintex       2 } \
    ###         { virtex       3 } \
    ###         { zynq         4 } \
    ###         { versalprime  5 } \
    ###         { versalaicore 6 } \
    ### set speed_grade_list { \
    ###         { Unknown 0  } \
    ###         { -1      10 } \
    ###         { -1L     11 } \
    ###         { -1H     12 } \
    ###         { -1HV    13 } \
    ###         { -1LV    14 } \
    ###         { -2      20 } \
    ###         { -2L     21 } \
    ###         { -2LV    22 } \
    ###         { -2MP    23 } \
    ###         { -3      30 }}
    ### set dev_package_list { \
    ###         { Unknown 0  } \
    ###         { rf      1  } \
    ###         { fl      2  } \
    ###         { ff      3  } \
    ###         { fb      4  } \
    ###         { hc      5  } \
    ###         { fh      6  } \
    ###         { cs      7  } \
    ###         { cp      8  } \
    ###         { ft      9  } \
    ###         { fg      10 } \
    ###         { sb      11 } \
    ###         { rb      12 } \
    ###         { rs      13 } \
    ###         { cl      14 } \
    ###         { sf      15 } \
    ###         { ba      16 } \
    ###         { fa      17 } \
    ###         { fs      18 } \
    ###         { fi      19 } \
    ###         { vs      20 }}
    ### set xcvr_type_list { \
    ###         { Unknown             0 } \
    ###         { GTPE2_NOT_SUPPORTED 1 } \
    ###         { GTXE2               2 } \
    ###         { GTHE2_NOT_SUPPORTED 3 } \
    ###         { GTZE2_NOT_SUPPORTED 4 } \
    ###         { GTHE3               5 } \
    ###         { GTYE3_NOT_SUPPORTED 6 } \
    ###         { GTRE4_NOT_SUPPORTED 7 } \
    ###         { GTHE4               8 } \
    ###         { GTYE4               9 } \
    ###         { GTME4_NOT_SUPPORTED 10}}
    ### set fpga_voltage_list {0 5000} ;
    ### proc adi_device_spec {cellpath param} {
    ###   set list_pointer [string tolower $param]
    ###   set list_pointer [append list_pointer "_list"]
    ###   upvar 1 $list_pointer $list_pointer
    ###   set ip [get_bd_cells $cellpath]
    ###   set part [get_property PART [current_project]]
    ###   switch -regexp -- $param {
    ###       FPGA_TECHNOLOGY {
    ###           switch  -regexp -- $part {
    ###              ^xc7          {set series_name 7series}
    ###              ^xczu         {set series_name ultrascale+}
    ###              ^xc.u..?p     {set series_name ultrascale+}
    ###              ^xck26        {set series_name ultrascale+}
    ###              ^xc.u         {set series_name ultrascale }
    ###              ^xcv[ecmph]   {set series_name versal}
    ###              default {
    ###                  puts "Undefined fpga technology for \"$part\"!"
    ###                  exit -1
    ###           return "$series_name"
    ###       FPGA_FAMILY {
    ###           set fpga_family [get_property FAMILY $part]
    ###           foreach i $fpga_family_list {
    ###               regexp ^[lindex $i 0] $fpga_family matched
    ###           return "$matched"
    ###       SPEED_GRADE {
    ###           set speed_grade [get_property SPEED $part]
    ###           return "$speed_grade"
    ###       DEV_PACKAGE {
    ###           set dev_package [get_property PACKAGE $part]
    ###           foreach i $dev_package_list {
    ###               regexp ^[lindex $i 0] $dev_package matched
    ###       XCVR_TYPE {
    ###           set matched ""
    ###           set dev_transcivers "none"
    ###           foreach x [list_property $part] {
    ###               regexp ^GT..._TRANSCEIVERS $x dev_transcivers
    ###           foreach i $xcvr_type_list {
    ###               regexp ^[lindex $i 0] $dev_transcivers matched
    ###           if { $matched eq "" } {
    ###                puts "CRITICAL WARNING: \"$dev_transcivers\" TYPE IS NOT SUPPORTED BY ADI!"
    ###       FPGA_VOLTAGE {
    ###           set fpga_voltage [get_property REF_OPERATING_VOLTAGE $part]
    ### 	  set fpga_voltage [expr int([expr $fpga_voltage * 1000])] ;# // V to mV conversion(integer val)
    ###           return "$fpga_voltage"
    ###       default {
    ###           puts "WARNING: UNDEFINED PARAMETER \"$param\" (adi_device_spec)!"
    ## if {[info exists ::env(ADI_VIVADO_IP_LIBRARY)]} {
    ##   set VIVADO_IP_LIBRARY $::env(ADI_VIVADO_IP_LIBRARY)
    ## } else {
    ##   set VIVADO_IP_LIBRARY user
    ## proc adi_ip_ttcl {ip_name ip_constr_files} {
    ##   set proj_filegroup [ipx::get_file_groups -of_objects [ipx::current_core] -filter {NAME =~ *synthesis*}]
    ##   set f [ipx::add_file $ip_constr_files $proj_filegroup]
    ##   set_property -dict [list \
    ##     type ttcl \
    ##   ] $f
    ##   ipx::reorder_files -front $ip_constr_files $proj_filegroup
    ## proc adi_ip_sim_ttcl {ip_name ip_files} {
    ##   set proj_filegroup [ipx::get_file_groups -of_objects [ipx::current_core] -filter {NAME =~ *simulation*}]
    ##   set f [ipx::add_file $ip_files $proj_filegroup]
    ##     type ttcl \
    ##   ] $f
    ##   ipx::reorder_files -front $ip_files $proj_filegroup
    ## proc adi_ip_bd {ip_name ip_bd_files} {
    ##   set proj_filegroup [ipx::get_file_groups xilinx_blockdiagram -of_objects [ipx::current_core]]
    ##   if {$proj_filegroup == {}} {
    ##     set proj_filegroup [ipx::add_file_group -type xilinx_blockdiagram "" [ipx::current_core]]
    ##   foreach file $ip_bd_files {
    ##     set f [ipx::add_file $file $proj_filegroup]
    ##       type tclSource \
    ##     ] $f
    ## proc adi_ip_infer_streaming_interfaces {ip_name} {
    ##   ipx::infer_bus_interfaces xilinx.com:interface:axis_rtl:1.0 [ipx::current_core]
    ## proc adi_ip_infer_mm_interfaces {ip_name} {
    ##   ipx::infer_bus_interfaces xilinx.com:interface:aximm_rtl:1.0 [ipx::current_core]
    ## proc adi_set_ports_dependency {port_prefix dependency {driver_value {}}} {
    ##   foreach port [ipx::get_ports [format "%s%s" $port_prefix "*"]] {
    ##     set_property ENABLEMENT_DEPENDENCY $dependency $port
    ##     if {$driver_value != {}} {
    ##       set_property DRIVER_VALUE $driver_value $port
    ## proc adi_set_bus_dependency {bus prefix dependency} {
    ##   set_property ENABLEMENT_DEPENDENCY $dependency [ipx::get_bus_interfaces $bus -of_objects [ipx::current_core]]
    ##   adi_set_ports_dependency $prefix $dependency 0
    ## proc adi_add_port_map {bus phys logic} {
    ##   set map [ipx::add_port_map $phys $bus]
    ##   set_property "PHYSICAL_NAME" $phys $map
    ##   set_property "LOGICAL_NAME" $logic $map
    ## proc adi_add_bus {bus_name mode abs_type bus_type port_maps} {
    ##   set bus [ipx::add_bus_interface $bus_name [ipx::current_core]]
    ##   set_property "ABSTRACTION_TYPE_VLNV" $abs_type $bus
    ##   set_property "BUS_TYPE_VLNV" $bus_type $bus
    ##   set_property "INTERFACE_MODE" $mode $bus
    ##   foreach port_map $port_maps {
    ##     adi_add_port_map $bus {*}$port_map
    ## proc adi_add_multi_bus {num bus_name_prefix mode abs_type bus_type port_maps dependency} {
    ##   for {set i 0} {$i < $num} {incr i} {
    ##     set bus_name [format "%s%d" $bus_name_prefix $i]
    ##     if {$dependency ne ""} {
    ##       set bus_dependency [string map [list "{i}" $i] $dependency]
    ##       set_property ENABLEMENT_DEPENDENCY $bus_dependency $bus
    ##       lassign $port_map phys logic width width_dep
    ##       set_property "PHYSICAL_RIGHT" [expr $i*$width] $map
    ##       set_property "PHYSICAL_LEFT" [expr ($i+1)*$width-1] $map
    ##       if {$width_dep ne ""} {
    ##         set_property "PHYSICAL_RIGHT_RESOLVE_TYPE" "dependent" $map
    ##         set_property "PHYSICAL_LEFT_RESOLVE_TYPE" "dependent" $map
    ##         set width_dep_r "(($width_dep) * $i)"
    ##         set width_dep_l "(($width_dep) * ($i + 1)-1)"
    ##         set_property "PHYSICAL_RIGHT_DEPENDENCY" $width_dep_r $map
    ##         set_property "PHYSICAL_LEFT_DEPENDENCY" $width_dep_l $map
    ## proc adi_add_bus_clock {clock_signal_name bus_inf_name {reset_signal_name ""} {reset_signal_mode "slave"}} {
    ##   set bus_inf_name_clean [string map {":" "_"} $bus_inf_name]
    ##   set clock_inf_name [format "%s%s" $bus_inf_name_clean "_signal_clock"]
    ##   set clock_inf [ipx::add_bus_interface $clock_inf_name [ipx::current_core]]
    ##   set_property abstraction_type_vlnv "xilinx.com:signal:clock_rtl:1.0" $clock_inf
    ##   set_property bus_type_vlnv "xilinx.com:signal:clock:1.0" $clock_inf
    ##   set_property display_name $clock_inf_name $clock_inf
    ##   set clock_map [ipx::add_port_map "CLK" $clock_inf]
    ##   set_property physical_name $clock_signal_name $clock_map
    ##   set assoc_busif [ipx::add_bus_parameter "ASSOCIATED_BUSIF" $clock_inf]
    ##   set_property value $bus_inf_name $assoc_busif
    ##   if { $reset_signal_name != "" } {
    ##     set assoc_reset [ipx::add_bus_parameter "ASSOCIATED_RESET" $clock_inf]
    ##     set_property value $reset_signal_name $assoc_reset
    ##     set reset_inf_name [format "%s%s" $bus_inf_name_clean "_signal_reset"]
    ##     set reset_inf [ipx::add_bus_interface $reset_inf_name [ipx::current_core]]
    ##     set_property abstraction_type_vlnv "xilinx.com:signal:reset_rtl:1.0" $reset_inf
    ##     set_property bus_type_vlnv "xilinx.com:signal:reset:1.0" $reset_inf
    ##     set_property display_name $reset_inf_name $reset_inf
    ##     set_property interface_mode $reset_signal_mode $reset_inf
    ##     set reset_map [ipx::add_port_map "RST" $reset_inf]
    ##     set_property physical_name $reset_signal_name $reset_map
    ##     set reset_polarity [ipx::add_bus_parameter "POLARITY" $reset_inf]
    ##     if {[string match {*[Nn]} $reset_signal_name] == 1} {
    ##       set_property value "ACTIVE_LOW" $reset_polarity
    ##     } else {
    ##       set_property value "ACTIVE_HIGH" $reset_polarity
    ## proc adi_ip_add_core_dependencies {vlnvs} {
    ##   foreach file_group [ipx::get_file_groups * -of_objects [ipx::current_core]] {
    ##     foreach vlnv $vlnvs {
    ##       ipx::add_subcore $vlnv $file_group
    ## proc adi_ip_create {ip_name} {
    ##   global ad_hdl_dir
    ##   global ad_ghdl_dir
    ##   global required_vivado_version
    ##   global IGNORE_VERSION_CHECK
    ##   set VIVADO_VERSION [version -short]
    ##   if {$IGNORE_VERSION_CHECK} {
    ##     if {[string compare $VIVADO_VERSION $required_vivado_version] != 0} {
    ##       puts -nonewline "CRITICAL WARNING: vivado version mismatch; "
    ##       puts -nonewline "expected $required_vivado_version, "
    ##       puts -nonewline "got $VIVADO_VERSION.\n"
    ##   } else {
    ##       puts -nonewline "ERROR: vivado version mismatch; "
    ##       puts -nonewline "This ERROR message can be down-graded to CRITICAL WARNING by setting ADI_IGNORE_VERSION_CHECK environment variable to 1. Be aware that ADI will not support you, if you are using a different tool version.\n"
    ##       exit 2
    ##   create_project $ip_name . -force
    ##   ## Load custom message severity definitions
    ##   if {![info exists ::env(ADI_DISABLE_MESSAGE_SUPPRESION)]} {
    ##     source $ad_hdl_dir/projects/scripts/adi_xilinx_msg.tcl
    ##   set lib_dirs $ad_hdl_dir/library
    ##   if {[info exists ::env(ADI_GHDL_DIR)]} {
    ##     if {$ad_hdl_dir ne $ad_ghdl_dir} {
    ##       lappend lib_dirs $ad_ghdl_dir/library
    ##   } else {
    ##     # puts -nonew-line "INFO: ADI_GHDL_DIR not defined.\n"
    ##   set_property ip_repo_paths $lib_dirs [current_fileset]
    ##   update_ip_catalog
    ## proc adi_ip_files {ip_name ip_files} {
    ##   set proj_fileset [get_filesets sources_1]
    ##   foreach m_file $ip_files {
    ##     if {[file extension $m_file] eq ".xdc"} {
    ##       add_files -norecurse -fileset constrs_1 $m_file
    ##     } else {
    ##       add_files -norecurse -scan_for_includes -fileset $proj_fileset $m_file
    ##   set_property "top" "$ip_name" $proj_fileset
    ## proc adi_ip_properties_lite {ip_name} {
    ##   global VIVADO_IP_LIBRARY
    ##   ipx::package_project -root_dir . -vendor analog.com -library $VIVADO_IP_LIBRARY -taxonomy /Analog_Devices
    ##   set_property name $ip_name [ipx::current_core]
    ##   set_property vendor_display_name {Analog Devices} [ipx::current_core]
    ##   set_property company_url {http://www.analog.com} [ipx::current_core]
    ##   set_property AUTO_FAMILY_SUPPORT_LEVEL level_2 [ipx::current_core]
    ##   ipx::save_core [ipx::current_core]
    ##   ipx::remove_all_bus_interface [ipx::current_core]
    ##   set memory_maps [ipx::get_memory_maps * -of_objects [ipx::current_core]]
    ##   foreach map $memory_maps {
    ##     ipx::remove_memory_map [lindex $map 2] [ipx::current_core]
    ##   ipx::update_checksums [ipx::current_core]
    ## proc adi_ip_properties {ip_name} {
    ##   adi_ip_properties_lite $ip_name
    ##   ipx::infer_bus_interface {\
    ##     s_axi_awvalid \
    ##     s_axi_awaddr \
    ##     s_axi_awprot \
    ##     s_axi_awready \
    ##     s_axi_wvalid \
    ##     s_axi_wdata \
    ##     s_axi_wstrb \
    ##     s_axi_wready \
    ##     s_axi_bvalid \
    ##     s_axi_bresp \
    ##     s_axi_bready \
    ##     s_axi_arvalid \
    ##     s_axi_araddr \
    ##     s_axi_arprot \
    ##     s_axi_arready \
    ##     s_axi_rvalid \
    ##     s_axi_rdata \
    ##     s_axi_rresp \
    ##     s_axi_rready} \
    ##   xilinx.com:interface:aximm_rtl:1.0 [ipx::current_core]
    ##   ipx::infer_bus_interface s_axi_aclk xilinx.com:signal:clock_rtl:1.0 [ipx::current_core]
    ##   ipx::infer_bus_interface s_axi_aresetn xilinx.com:signal:reset_rtl:1.0 [ipx::current_core]
    ##   set raddr_width [expr [get_property SIZE_LEFT [ipx::get_ports -nocase true s_axi_araddr -of_objects [ipx::current_core]]] + 1]
    ##   set waddr_width [expr [get_property SIZE_LEFT [ipx::get_ports -nocase true s_axi_awaddr -of_objects [ipx::current_core]]] + 1]
    ##   if {$raddr_width != $waddr_width} {
    ##     puts [format "WARNING: AXI address width mismatch for %s (r=%d, w=%d)" $ip_name $raddr_width, $waddr_width]
    ##     set range 65536
    ##   } else {
    ##     if {$raddr_width >= 16} {
    ##       set range 65536
    ##     } else {
    ##       set range [expr 1 << $raddr_width]
    ##   ipx::add_memory_map {s_axi} [ipx::current_core]
    ##   set_property slave_memory_map_ref {s_axi} [ipx::get_bus_interfaces s_axi -of_objects [ipx::current_core]]
    ##   ipx::add_address_block {axi_lite} [ipx::get_memory_maps s_axi -of_objects [ipx::current_core]]
    ##   set_property range $range [ipx::get_address_blocks axi_lite \
    ##     -of_objects [ipx::get_memory_maps s_axi -of_objects [ipx::current_core]]]
    ##   ipx::associate_bus_interfaces -clock s_axi_aclk -reset s_axi_aresetn [ipx::current_core]
    ##   ipx::save_core
    ## proc adi_init_bd_tcl {} {
    ##   global auto_set_param_list
    ##   global auto_set_param_list_overwritable
    ##   set cc [ipx::current_core]
    ##   if { [file exists bd] } {
    ##     file delete -force bd
    ##   file mkdir bd
    ##   set bd_tcl [open "bd/bd.tcl" w]
    ##   puts $bd_tcl "# SCRIPT AUTO-GENERATED AT BUILD, DO NOT MODIFY!"
    ##   puts $bd_tcl "proc init {cellpath otherInfo} {"
    ##   puts $bd_tcl "  set ip \[get_bd_cells \$cellpath\]"
    ##   puts $bd_tcl ""
    ##   set auto_set_param ""
    ##   foreach i $auto_set_param_list {
    ##     if { [ipx::get_user_parameters $i -of_objects $cc -quiet] ne "" } {
    ##       append auto_set_param "    $i \\\n"
    ##   if { $auto_set_param ne "" } {
    ##     puts $bd_tcl "  bd::mark_propagate_only \$ip \" \\"
    ##     regsub "${i} \\\\" $auto_set_param "$i\"" auto_set_param
    ##     puts $bd_tcl $auto_set_param
    ##   set auto_set_overwritable_param ""
    ##   foreach i $auto_set_param_list_overwritable {
    ##       append auto_set_overwritable_param "    $i \\\n"
    ##   if { $auto_set_overwritable_param ne "" } {
    ##     puts $bd_tcl "  bd::mark_propagate_override \$ip \" \\"
    ##     regsub "${i} \\\\" $auto_set_overwritable_param "$i\"" auto_set_overwritable_param
    ##     puts $bd_tcl $auto_set_overwritable_param
    ##   puts $bd_tcl "  adi_auto_assign_device_spec \$cellpath"
    ##   puts $bd_tcl "}"
    ##   puts $bd_tcl ""
    ##   puts $bd_tcl "# auto set parameters defined in auto_set_param_list (adi_xilinx_device_info_enc.tcl)"
    ##   puts $bd_tcl "proc adi_auto_assign_device_spec {cellpath} {"
    ##   puts $bd_tcl ""
    ##   puts $bd_tcl "  set ip_param_list \[list_property \$ip\]"
    ##   puts $bd_tcl "  set ip_path \[bd::get_vlnv_dir \[get_property VLNV \$ip\]\]"
    ##   puts $bd_tcl ""
    ##   puts $bd_tcl "  set parent_dir \"../\""
    ##   puts $bd_tcl "  for {set x 1} {\$x<=4} {incr x} {"
    ##   puts $bd_tcl "    set linkname \${ip_path}\${parent_dir}scripts/adi_xilinx_device_info_enc.tcl"
    ##   puts $bd_tcl "    if { \[file exists \$linkname\] } {"
    ##   puts $bd_tcl "      source \${ip_path}\${parent_dir}/scripts/adi_xilinx_device_info_enc.tcl"
    ##   puts $bd_tcl "      break"
    ##   puts $bd_tcl "    }"
    ##   puts $bd_tcl "    append parent_dir \"../\""
    ##   puts $bd_tcl ""
    ##   puts $bd_tcl "  # Find predefindes auto assignable parameters"
    ##   puts $bd_tcl "  foreach i \$auto_set_param_list {"
    ##   puts $bd_tcl "    if { \[lsearch \$ip_param_list \"CONFIG.\$i\"\] > 0 } {"
    ##   puts $bd_tcl "      set val \[adi_device_spec \$cellpath \$i\]"
    ##   puts $bd_tcl "      set_property CONFIG.\$i \$val \$ip"
    ##   puts $bd_tcl ""
    ##   puts $bd_tcl "  # Find predefindes auto assignable/overwritable parameters"
    ##   puts $bd_tcl "  foreach i \$auto_set_param_list_overwritable {"
    ##   puts $bd_tcl "}"
    ##   puts $bd_tcl ""
    ##   close $bd_tcl
    ##   add_files -norecurse -scan_for_includes -fileset $proj_fileset "bd/bd.tcl"
    ##   set local_mk [open "temporary_case_dependencies.mk" w]
    ##   seek $local_mk 0 start
    ##   puts $local_mk "CLEAN_TARGET += bd"
    ##   puts $local_mk "CLEAN_TARGET += temporary_case_dependencies.mk"
    ##   close $local_mk
    ## proc adi_add_auto_fpga_spec_params {} {
    ##     if { [ipx::get_user_parameters $i -of_objects $cc -quiet] ne ""} {
    ##       adi_add_device_spec_param $i
    ## proc adi_add_device_spec_param {ip_param} {
    ##   set list_pointer [string tolower $ip_param]
    ##   global $list_pointer
    ##   # set j 1D list from the original list
    ##   foreach i [subst $$list_pointer] {lappend j [lindex $i 0] [lindex $i 1]}
    ##   # set ranges or validation pairs (show x in GUI assign the corresponding y to HDL)
    ##   if { [llength [subst $$list_pointer]] == 2 && [llength $j] == 4} {
    ##       "value_validation_type" "range_long" \
    ##       "value_validation_range_minimum" [lindex [subst $$list_pointer] 0] \
    ##       "value_validation_range_maximum" [lindex [subst $$list_pointer] 1] ] \
    ##     [ipx::get_user_parameters $ip_param -of_objects $cc]
    ##   } else {
    ##       "value_validation_type" "pairs" \
    ##       "value_validation_pairs" $j ] \
    ##   # FPGA info grup
    ##   set info_group_name "FPGA info"
    ##   set info_group [ipgui::get_groupspec -name $info_group_name -component $cc -quiet]
    ##   if { [string trim $info_group] eq "" } {
    ##     set page0 [ipgui::get_pagespec -name "Page 0" -component $cc]
    ##     set info_group [ipgui::add_group -name $info_group_name -component $cc \
    ##         -parent $page0 -display_name $info_group_name]
    ##   set p [ipgui::get_guiparamspec -name $ip_param -component $cc]
    ##   set_property -dict [list "widget" "comboBox" ] $p
    ##   ipgui::move_param -component $cc -order 0 $p -parent $info_group
    ## proc adi_if_define {name} {
    ##   ipx::create_abstraction_definition analog.com interface ${name}_rtl 1.0
    ##   ipx::create_bus_definition analog.com interface $name 1.0
    ##   set_property xml_file_name ${name}_rtl.xml [ipx::current_busabs]
    ##   set_property xml_file_name ${name}.xml [ipx::current_busdef]
    ##   set_property bus_type_vlnv analog.com:interface:${name}:1.0 [ipx::current_busabs]
    ##   ipx::save_abstraction_definition [ipx::current_busabs]
    ##   ipx::save_bus_definition [ipx::current_busdef]
    ## proc adi_if_ports {dir width name {type none}} {
    ##   ipx::add_bus_abstraction_port $name [ipx::current_busabs]
    ##   set m_intf [ipx::get_bus_abstraction_ports $name -of_objects [ipx::current_busabs]]
    ##   set_property master_presence required $m_intf
    ##   set_property slave_presence  required $m_intf
    ##   set_property master_width $width $m_intf
    ##   set_property slave_width  $width $m_intf
    ##   set m_dir "in"
    ##   set s_dir "out"
    ##   if {$dir eq "output"} {
    ##     set m_dir "out"
    ##     set s_dir "in"
    ##   set_property master_direction $m_dir $m_intf
    ##   set_property slave_direction  $s_dir $m_intf
    ##   if {$type ne "none"} {
    ##     set_property is_${type} true $m_intf
    ## proc adi_if_infer_bus {if_name mode name maps} {
    ##   ipx::add_bus_interface $name [ipx::current_core]
    ##   set m_bus_if [ipx::get_bus_interfaces $name -of_objects [ipx::current_core]]
    ##   set_property abstraction_type_vlnv ${if_name}_rtl:1.0 $m_bus_if
    ##   set_property bus_type_vlnv ${if_name}:1.0 $m_bus_if
    ##   set_property interface_mode $mode $m_bus_if
    ##   foreach map $maps  {
    ##     set m_maps [regexp -all -inline {\S+} $map]
    ##     lassign $m_maps p_name p_map
    ##     ipx::add_port_map $p_name $m_bus_if
    ##     set_property physical_name $p_map [ipx::get_port_maps $p_name -of_objects $m_bus_if]
    # adi_ip_create axi_clkgen
    ERROR: vivado version mismatch; expected 2021.2, got 2020.2.
    INFO: [Common 17-206] Exiting Vivado at Wed Feb  1 15:24:24 2023...
  • Ok, so I see you're using the master branch. Then I suggest you to use what we use when testing the projects, which is 2021.2 if that's possible for you.
    If not, then take a look at our Releases page, and see which release branch was tested with which version of tools. I don't recommend using different version of tools since most of the times errors can occur because of this (not just the version mismatch).
    Iulia
  • Now with the correct Version of Vivado it is working. Many Thanks!
