make build error in git cloned repository for ad9371
Product Number: ad9371
I am trying to build the git cloned repository for ad9371. link for the repository is given below
git clone https://github.com/analogdevicesinc/hdl.git
link for HDL environment build
Building HDL [Analog Devices Wiki]
after I follow all the steps as per the link given above for building HDL environment, I try to use the make command and I get the following error
$ make
Building adrv9371x_zc706 project [/home/User/adi/hdl/projects/adrv9371x/zc706/adrv9371x_zc706_vivado.log] ... FAILED
For details see /home/User/adi/hdl/projects/adrv9371x/zc706/adrv9371x_zc706_vivado.log
make: *** [../../scripts/project-xilinx.mk:65: adrv9371x_zc706.sdk/system_top.xsa] Error 1
on checking the log file I get the following information
ERROR: [IP_Flow 19-3452] Invalid long/float value 'ff' specified for parameter 'Dev Package(DEV_PACKAGE)' for BD Cell 'rx_ad9371_tpl_core/adc_tpl_core'.
INFO: [IP_Flow 19-3438] Customization errors found on 'rx_ad9371_tpl_core/adc_tpl_core'. Restoring to previous valid configuration.
ERROR: [BD 41-245] set_property error - Invalid long/float value 'ff' specified for parameter 'Dev Package(DEV_PACKAGE)' for BD Cell 'rx_ad9371_tpl_core/adc_tpl_core'.
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
ERROR: [BD 41-1273] Error running init TCL procedure: ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
adi_auto_assign_device_spec Line 18
what should I do to build the repository successfully
