I have a AD9081-FMCA-EBZ mounted on a ZC706 board. I'm trying to set the data rate for TX and RX as slow as possible. The purpose is enable the transmission of data via Ethernet (limited bandwidth), without developing an extra interpolator and decimator on the PL. The goal would be to use the maximum decimation for the ADC (96x) while using all 8 converters, and something similar for the DAC path too.
I'm using the Petalinux flow to build the SW, using the meta-adi repository. I started from the reference design (hdl repo maaster branch, folder hdl/projects/ad9081_fmca_ebz/zc706 + petalinux + meta-adi maaster branch with KERNEL_DTB="zynq-zc706-adv7511-ad9081").
I compiled reference design without modifications and it worked ok (DAC: 12 GSa/s, ADC: 4 GSa/s, DAC interpolation: 48, ADC decimation:16, data rate after decimation: 250 MSa/s for both ADC and DAC).
I tried to halve the sample speed first (DAC: 6 GSa/s, ADC: 2 GSa/s) without changing the HDL and everything seems to work OK (using QPLL for both). The data rate (after decimation/interpolation) goes from 250 MSa/s to 125 MSa/s for both TX and RX. The JESD lanes are working at 5 GHz.
The reference design uses the QPLL for both adxcvr instances (tx and rx). In order to decrease the ADC data rate further for the RX channel, I tried to switch to CPLL for RX. I modified the hdl and connected the hmc7044 channel 8 (unused in the reference design) to the CPLL input. I recompiled the JESD link with 2 lanes instead of 4 and in the device tree I used JESD mode 4.00 for the ADC path that supports 2 lanes, 8 converters, 16 bit per sample with the 4x8 decimation. This configuration also seems to work fine, however jesd_status complains about "measured link clock" (shown in red in the status, it's not equal to the "reported link clock"). Am I missing something here? By the way, the systems seems to work fine (FFT looks ok with the IIO oscilloscope).
The diff for the HDL project is the following
diff --git a/projects/ad9081_fmca_ebz/common/ad9081_fmca_ebz_bd.tcl b/projects/ad9081_fmca_ebz/common/ad9081_fmca_ebz_bd.tcl index 48fbbcb21..f3c224669 100644 --- a/projects/ad9081_fmca_ebz/common/ad9081_fmca_ebz_bd.tcl +++ b/projects/ad9081_fmca_ebz/common/ad9081_fmca_ebz_bd.tcl @@ -269,7 +269,8 @@ create_bd_port -dir I ref_clk_q1 if {$ADI_PHY_SEL == 1} { for {set i 0} {$i < [expr max($TX_NUM_OF_LANES,$RX_NUM_OF_LANES)]} {incr i} { set quad_index [expr int($i / 4)] - ad_xcvrpll ref_clk_q$quad_index util_mxfe_xcvr/cpll_ref_clk_$i + #ad_xcvrpll ref_clk_q$quad_index util_mxfe_xcvr/cpll_ref_clk_$i + ad_xcvrpll ref_clk_q1 util_mxfe_xcvr/cpll_ref_clk_$i if {[expr $i % 4] == 0} { ad_xcvrpll ref_clk_q$quad_index util_mxfe_xcvr/qpll_ref_clk_$i } diff --git a/projects/ad9081_fmca_ebz/zc706/system_constr.xdc b/projects/ad9081_fmca_ebz/zc706/system_constr.xdc index a3edb067d..f8dba9cd0 100644 --- a/projects/ad9081_fmca_ebz/zc706/system_constr.xdc +++ b/projects/ad9081_fmca_ebz/zc706/system_constr.xdc @@ -16,6 +16,8 @@ set_property -dict {PACKAGE_PIN U27 IOSTANDARD LVDS_25 DIFF_TERM TRUE set_property -dict {PACKAGE_PIN U26 IOSTANDARD LVDS_25 DIFF_TERM TRUE} [get_ports clkin6_p ] ; ## FMC0_CLK1_M2C_P IO_L12P_T1_MRCC_13 set_property -dict {PACKAGE_PIN AD9 } [get_ports fpga_refclk_in_n ] ; ## FMC0_GBTCLK0_M2C_N MGTREFCLK0N_109 set_property -dict {PACKAGE_PIN AD10 } [get_ports fpga_refclk_in_p ] ; ## FMC0_GBTCLK0_M2C_P MGTREFCLK0P_109 +set_property -dict {PACKAGE_PIN AA7 } [get_ports fpga_refclk2_in_n ] ; +set_property -dict {PACKAGE_PIN AA8 } [get_ports fpga_refclk2_in_p ] ; set_property -quiet -dict {PACKAGE_PIN AG7 } [get_ports rx_data_n[2] ] ; ## FMC0_DP2_M2C_N MGTXRXN2_109 FPGA_SERDIN_0_N set_property -quiet -dict {PACKAGE_PIN AG8 } [get_ports rx_data_p[2] ] ; ## FMC0_DP2_M2C_P MGTXRXP2_109 FPGA_SERDIN_0_P set_property -quiet -dict {PACKAGE_PIN AH9 } [get_ports rx_data_n[0] ] ; ## FMC0_DP0_M2C_N MGTXRXN0_109 FPGA_SERDIN_1_N diff --git a/projects/ad9081_fmca_ebz/zc706/system_project.tcl b/projects/ad9081_fmca_ebz/zc706/system_project.tcl index cbdbf89fa..37b9db85f 100644 --- a/projects/ad9081_fmca_ebz/zc706/system_project.tcl +++ b/projects/ad9081_fmca_ebz/zc706/system_project.tcl @@ -31,10 +31,10 @@ source $ad_hdl_dir/projects/scripts/adi_board.tcl adi_project ad9081_fmca_ebz_zc706 0 [list \ JESD_MODE 8B10B \ - RX_LANE_RATE [get_env_param RX_RATE 10 ] \ - TX_LANE_RATE [get_env_param TX_RATE 10 ] \ + RX_LANE_RATE [get_env_param RX_RATE 5 ] \ + TX_LANE_RATE [get_env_param TX_RATE 5 ] \ RX_JESD_M [get_env_param RX_JESD_M 8 ] \ - RX_JESD_L [get_env_param RX_JESD_L 4 ] \ + RX_JESD_L [get_env_param RX_JESD_L 2 ] \ RX_JESD_S [get_env_param RX_JESD_S 1 ] \ RX_JESD_NP [get_env_param RX_JESD_NP 16] \ RX_NUM_LINKS [get_env_param RX_NUM_LINKS 1 ] \
system-user.dtsi
/include/ "system-conf.dtsi" / { }; &hmc7044 { channel@12 { adi,divider = <24>; //TX REF CLK }; channel@8 { adi,divider = <48>; //RX REF CLK }; }; &axi_ad9081_adxcvr_rx { clocks = <&hmc7044 8>; //change source clock to channel 8 of hmc7044 adi,sys-clk-select = <XCVR_CPLL>; }; &ad9081_adc0 { adi,decimation = <4>; }; &ad9081_adc1 { adi,decimation = <4>; }; &ad9081_adc2 { adi,decimation = <4>; }; &ad9081_adc3 { adi,decimation = <4>; }; &ad9081_rx_fddc_chan0 { adi,decimation = <8>; }; &ad9081_rx_fddc_chan1 { adi,decimation = <8>; }; &ad9081_rx_fddc_chan4 { adi,decimation = <8>; }; &ad9081_rx_fddc_chan5 { adi,decimation = <8>; }; &trx0_ad9081 { adi,tx-dacs { adi,dac-frequency-hz = /bits/ 64 <6000000000>; }; adi,rx-adcs { adi,adc-frequency-hz = /bits/ 64 <2000000000>; adi,jesd-links { link@0 { //test with two lanes L=2 M=8, mode 4 //see https://www.analog.com/media/en/technical-documentation/user-guides/ad9081-ad9082-ug-1578.pdf page 130 adi,link-mode = <4>; // JESD Quick Configuration Mode adi,subclass = <1>; // JESD SUBCLASS 0,1,2 adi,version = <1>; // JESD VERSION 0=204A,1=204B,2=204C adi,dual-link = <0>; // JESD Dual Link Mode adi,converters-per-device = <8>; // JESD M adi,octets-per-frame = <8>; // JESD F adi,frames-per-multiframe = <32>; // JESD K adi,converter-resolution = <16>; // JESD N adi,bits-per-sample = <16>; // JESD NP' adi,control-bits-per-sample = <0>; // JESD CS adi,lanes-per-device = <2>; // JESD L adi,samples-per-converter-per-frame = <1>; // JESD S adi,high-density = <0>; // JESD HD }; }; }; };
Relevant part of the dmesg output:
hmc7044 spi1.0: PLL1: Locked, CLKIN0 @ 100000000 Hz, PFD: 10000 kHz - PLL2: Locked @ 3000.000000 MHz jesd204: /axi/spi@e0007000/hmc7044@0,jesd204:1,parent=spi1.0: Using as SYSREF provider axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTX2 at 0x44A60000. Number of lanes: 2. axi_adxcvr 44b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTX2 at 0x44B60000. Number of lanes: 4. axi-jesd204-rx 44a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44A90000. Encoder 8b10b, width 4/8, lanes 2, jesd204-fsm. axi-jesd204-tx 44b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x44B90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm. axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found axi_sysid 45000000.axi-sysid-0: [ad9081_fmca_ebz] on [zc706] git branch <master> git <a0098acc5a49d49677ddb86a5bd0bd4abacf4b08> clean [2022-05-03 08:50:06] UTC fpga_manager fpga0: Xilinx Zynq FPGA Manager registered usbcore: registered new interface driver snd-usb-audio NET: Registered protocol family 10 Segment Routing with IPv6 sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 36 Key type dns_resolver registered Registering SWP/SWPB emulation handler of-fpga-region fpga-full: FPGA Region probed [drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0 Console: switching to colour frame buffer device 240x67 axi-hdmi 70e00000.axi_hdmi: [drm] fb0: axi_hdmi_drmdrm frame buffer device ad9081 spi0.0: supply vdd not found, using dummy regulator usb 1-1: new high-speed USB device number 2 using ci_hdrc usb 1-1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: USB2.0 Hub usb 1-1: Manufacturer: VIA Labs, Inc. hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected usb 1-1.1: new low-speed USB device number 3 using ci_hdrc usb 1-1.1: New USB device found, idVendor=046d, idProduct=c00e, bcdDevice=11.10 usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1.1: Product: USB-PS/2 Optical Mouse usb 1-1.1: Manufacturer: Logitech input: Logitech USB-PS/2 Optical Mouse as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C00E.0001/input/input0 hid-generic 0003:046D:C00E.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-ci_hdrc.0-1.1/input0 usb 1-1.2: new low-speed USB device number 4 using ci_hdrc usb 1-1.2: New USB device found, idVendor=09da, idProduct=0260, bcdDevice= 2.50 usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1.2: Product: USB Keyboard usb 1-1.2: Manufacturer: input: USB Keyboard as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:09DA:0260.0002/input/input1 hid-generic 0003:09DA:0260.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-ci_hdrc.0-1.2/input0 input: USB Keyboard System Control as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:09DA:0260.0003/input/input2 input: USB Keyboard Consumer Control as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:09DA:0260.0003/input/input3 hid-generic 0003:09DA:0260.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-ci_hdrc.0-1.2/input1 ad9081 spi0.0: AD9081 Rev. 3 Grade 10 (API 1.2.2) probed cf_axi_dds 44b10000.axi-ad9081-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x44B10000 mapped to 0xf1f310c6, probed DDS AD9081 cf_axi_adc 44a10000.axi-ad9081-rx-hpc: ADI AIM (10.01.b) at 0x44A10000 mapped to 0xbf799acc, probed ADC AD9081 as MASTER jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition initialized -> probed jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition initialized -> probed jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition probed -> idle jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition probed -> idle jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition idle -> device_init jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition idle -> device_init jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition device_init -> link_init jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition device_init -> link_init jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_init -> link_supported jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_init -> link_supported hmc7044 spi1.0: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_supported -> link_pre_setup jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_supported -> link_pre_setup jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition clk_sync_stage3 -> link_setup jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition clk_sync_stage3 -> link_setup jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_setup -> opt_setup_stage1 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_setup -> opt_setup_stage1 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5 jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition clocks_enable -> link_enable jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition clocks_enable -> link_enable ad9081 spi0.0: JESD RX (JTX) Link2 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid ad9081 spi0.0: JESD TX (JRX) Link0 0xF lanes in DATA jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_enable -> link_running jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_enable -> link_running jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:2] transition link_running -> opt_post_running_stage jesd204: /axi/spi@e0006000/ad9081@0,jesd204:0,parent=spi0.0: JESD204[0:0] transition link_running -> opt_post_running_stage input: gpio_keys as /devices/soc0/gpio_keys/input/input4 of_cfs_init of_cfs_init: OK ALSA device list: #0: HDMI monitor Warning: unable to open an initial console. Freeing unused kernel memory: 40960K Run /init as init process with arguments: /init with environment: HOME=/ TERM=linux udevd[92]: starting version 3.2.9 udevd[93]: starting eudev-3.2.9 FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) macb e000b000.ethernet eth0: PHY [e000b000.ethernet-ffffffff:07] driver [Marvell 88E1116R] (irq=POLL) macb e000b000.ethernet eth0: configuring for phy/rgmii-id link mode macb e000b000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
So the questions are:
1) is the configuration ok so far (see the measured link clock problem)?
2) how could I increase the decimation? I will put the information about the current failed attempt in a separate message.
