Hi team
I am using ADI-FMCDAQ2 module and loopback test for my design to test the interoperability of DAC and ADC with our FPGA device. The data path is like ADC--> FPGA (loopback)-->DAC. I am providing clean analog input (sinewave, ramp, sqaure wave etc) at the input side (both port A and B or either of the them) of FMCDAQ2 and i received the below waveform from DAC when measured on oscilloscope. Sine wave doesn't look clean and there are spikes and dip.
Here is my configuration at the ADC and DAC side
ADC (AD9680) L=4, M=2, F=2 ,S=2, N'=16(reg 570=0x89), N=14(Converter resolution), subclass=0, reg 561=0
Lane Line Rate= M x N' x 1.25 x fout / L
where fout = fadc_clk/decimation ratio
fadc_clk=625 Mhz
decimation=1
so fout = 625 Mhz
Lane line rate = 6250 Mbps
DAC (AD9144) L=4, M=2, F=2,S=2,N'=16 (Mode 5) N=16 (converter resolution), subclass=0, binary format
DataRate = (DACRate)/(InterpolationFactor)
LaneRate = (20 × DataRate × M)/L
InterpolationFactor=1
if DACRate=625 Mhz
LaneRate= 6250 Mbps (design not working, DAC side link is down)
If DACRate=312.5 Mhz
LaneRate= 3125 Mbps (design is working, DAC side link is up and i see the attached waveform) but ADC lane rate not equal to DAC lane rate. This is strange for me. What i am missing here?
JESD Rx config (on FPGA) = ADC (JESD tx) config and JESD Tx (FPGA side) = DAC (JESD) config.
Any ideas or suggestions will be helpful. Looking forward to hear from the team.
-trs
Added some imp information
[edited by: Trs at 3:46 PM (GMT -5) on 11 Mar 2022]
