weird phenomenon with the 7z035+adrv9001 reference design
Hi all,
we are using the 7z035+adrv9001 reference design provided by analog devices and we got some weird events that are describes below.
First of all as part of our project we build Tx custom IP cores which comes after the util_dac_2_upack IP (the tx2 transmit chain) , furthermore when we want to operate the board we execute ELF file which operates the TX libiio devices. ->the result of this part is successful.
But after that  we also adding in the Rx2 chain a Rx custom IP which is obviously separate in every aspect from the Tx2 logic (they use different clocks, resets and etc....) , now with the modified reference design which include the Tx2 custom logic and the Rx2 custom logic when we execute the same ELF file as earlier (which use only the tx2 libiio devices and the other devices are shutdown) the signal we get from tx2 port is very disturbed and noisy(while in the Tx2 only reference design the tx2 signal is detectible and cleaner)
with the assumption and verification that the tx and rx logics are separated(in reference design terms) what can be the reason  for the different outcomes?
with best regards .
Dror & Raz
  • Hi Dror,
    check your timing constraints.
    What is your target sample rate ?
    Can you please share the output of the report_timing_summary command from an implemented design ?
    Laszlo
  • Hi Dror,
    Laszlo
  • Hi Laszlo,
    Laszlo
    basicly our  two custom IP cores( the extended logic besides the ADI reference design logic) are needs to have clock of 51.2MHz , the "source" of this clock is generated via the dac_2_clk & adc_2_clk ports of the AXI_ADRV9002 IP , but before the clocks are getting into the two custom IP clock ports ( RX IP and TX IP custom logic) we need to empeshize that the clock which the axi_adrv9002 is generate is not 51.2MHz but actual 102.4MHz( due to the profile file that we load into the PS ) and therefore what we did is to export the  dac_2_clk & adc_2_clk ports outside of the wrapper level into the top level and divide the clock by 2 via BUFR and after that BUFG modules and then import the new clock signals into the relevant clocks which needed the 51.2MHz clock.
    thanks.
    Dror & Raz
  • The output of report_timing_summary tcl command is a detailed text format.  The capture you shared is only a summary.   Please share at least the "Clock summary" tab. The complete text file would be ideal.
    Thank you,
    Laszlo
  • Hi Laszlo this is the compelte texet file of the command
    INFO: [Timing 38-91] UpdateTimingParams: Speed grade: -2L, Delay Type: min_max.
    INFO: [Timing 38-191] Multithreading enabled for timing update using a maximum of 2 CPUs
    WARNING: [Timing 38-436] There are set_bus_skew constraint(s) in this design. Please run report_bus_skew to ensure that bus skew requirements are met.
    Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
    | Tool Version : Vivado v.2019.1 (win64) Build 2552052 Fri May 24 14:49:42 MDT 2019
    | Date         : Tue Dec 14 12:09:14 2021
    | Host         : DESKTOP-VVL5N7G running 64-bit major release  (build 9200)
    | Command      : report_timing_summary
    | Design       : system_top
    | Device       : 7z035i-fbg676
    | Speed File   : -2L  PRODUCTION 1.11 2014-09-11
    Timing Summary Report
    | Timer Settings
      Enable Multi Corner Analysis               :  Yes
      Enable Pessimism Removal                   :  Yes
      Pessimism Removal Resolution               :  Nearest Common Node
      Enable Input Delay Default Clock           :  No
      Enable Preset / Clear Arcs                 :  No
      Disable Flight Delays                      :  No
      Ignore I/O Paths                           :  No
      Timing Early Launch at Borrowing Latches   :  No
      Borrow Time for Max Delay Exceptions       :  Yes
      Corner  Analyze    Analyze
      Name    Max Paths  Min Paths
      Slow    Yes        Yes
      Fast    Yes        Yes
    check_timing report
    Table of Contents
    1. checking no_clock
    2. checking constant_clock
    3. checking pulse_width_clock
    4. checking unconstrained_internal_endpoints
    5. checking no_input_delay
    6. checking no_output_delay
    7. checking multiple_clock
    8. checking generated_clocks
    9. checking loops
    10. checking partial_input_delay
    11. checking partial_output_delay
    12. checking latch_loops
     There are 1121 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport0_o[1] (HIGH)
     There are 1302 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport1_o[1] (HIGH)
     There are 1445 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport2_o[1] (HIGH)
     There are 1365 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport3_o[1] (HIGH)
     There are 1254 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport4_o[1] (HIGH)
     There are 1146 register/latch pins with no clock driven by root clock pin: dbg_hub/sl_iport5_o[1] (HIGH)
     There are 0 register/latch pins with constant_clock.
     There are 0 register/latch pins which need pulse_width check
     There are 12047 pins that are not constrained for maximum delay. (HIGH)
     There are 0 pins that are not constrained for maximum delay due to constant clock.
     There are 12 input ports with no input delay specified. (HIGH)
     There are 0 input ports with no input delay but user has a false path constraint.
     There are 51 ports with no output delay specified. (HIGH)
     There are 0 ports with no output delay but user has a false path constraint
     There are 0 ports with no output delay but with a timing clock defined on it or propagating through it
     There are 0 register/latch pins with multiple clocks.
     There are 0 generated clocks that are not connected to a clock source.
    9. checking loops
     There are 0 combinational loops in the design.
     There are 0 input ports with partial input delay specified.
     There are 0 ports with partial output delay specified.
     There are 0 combinational latch loops in the design through latch input
    | Design Timing Summary
        WNS(ns)      TNS(ns)  TNS Failing Endpoints  TNS Total Endpoints      WHS(ns)      THS(ns)  THS Failing Endpoints  THS Total Endpoints     WPWS(ns)     TPWS(ns)  TPWS Failing Endpoints  TPWS Total Endpoints
          3.502        0.000                      0               395750       -3.402     -633.956                  20367               395441        0.264        0.000                       0                167209
    Timing constraints are not met.
    | Clock Summary
    Clock                                 Waveform(ns)         Period(ns)      Frequency(MHz)
    clk_fpga_0                            {0.000 5.000}        10.000          100.000
    clk_fpga_1                            {0.000 2.500}        5.000           200.000
      clk_out1_system_sys_audio_clkgen_0  {0.000 40.690}       81.380          12.288
      clkfbout_system_sys_audio_clkgen_0  {0.000 22.500}       45.000          22.222
      mmcm_clk_0_s                        {0.000 3.367}        6.735           148.485
      mmcm_clk_1_s                        {0.000 3.367}        6.735           148.485
      mmcm_clk_2_s                        {0.000 1.122}        2.245           445.455
      mmcm_fb_clk_s                       {0.000 27.500}       55.000          18.182
    rx1_dclk_out                          {0.000 6.250}        12.500          80.000
      adc_clk_div_s                       {0.000 25.000}       50.000          20.000
    rx2_dclk_out                          {0.000 6.250}        12.500          80.000
      adc_clk_div_s_1                     {0.000 25.000}       50.000          20.000
        adc_clk_in_s                      {0.000 50.000}       100.000         10.000
        dac_clk_in_s                      {0.000 50.000}       100.000         10.000
    spi0_clk                              {0.000 20.000}       40.000          25.000
    spi1_clk                              {0.000 20.000}       40.000          25.000
    tx1_dclk_out                          {0.000 6.250}        12.500          80.000
    tx2_dclk_out                          {0.000 6.250}        12.500          80.000
    | Intra Clock Table
    Clock                                     WNS(ns)      TNS(ns)  TNS Failing Endpoints  TNS Total Endpoints      WHS(ns)      THS(ns)  THS Failing Endpoints  THS Total Endpoints     WPWS(ns)     TPWS(ns)  TPWS Failing Endpoints  TPWS Total Endpoints
    clk_fpga_0                                  6.300        0.000                      0                61018       -0.091     -194.061                  10440                61018        2.500        0.000                       0                 21520
    clk_fpga_1                                  3.502        0.000                      0                   55       -0.006       -0.048                      8                   55        0.264        0.000                       0                    47
      clk_out1_system_sys_audio_clkgen_0       79.880        0.000                      0                   61       -0.057       -0.978                     22                   61       39.922        0.000                       0                    37
      clkfbout_system_sys_audio_clkgen_0        43.929        0.000                       0                     2
      mmcm_clk_0_s                              3.505        0.000                      0                 1418       -0.019       -0.338                     32                 1418        2.725        0.000                       0                   760
      mmcm_clk_1_s        5.326        0.000                       0                     2
      mmcm_clk_2_s        0.836        0.000                       0                     2
      mmcm_fb_clk_s        45.000        0.000                       0                     3
    rx1_dclk_out        11.251        0.000                       0                    12
      adc_clk_div_s                            47.272        0.000                      0                14540       -0.131      -12.607                    505                14540       24.232        0.000                       0                 12416
    rx2_dclk_out        11.251        0.000                       0                    12
      adc_clk_div_s_1                          47.332        0.000                      0                11574       -0.237      -19.889                    957                11574       24.358        0.000                       0                  9091
        adc_clk_in_s                           93.144        0.000                      0                73447       -0.091      -90.278                   4156                73447       49.232        0.000                       0                 23402
        dac_clk_in_s                           92.507        0.000                      0               227288       -0.043      -86.647                   4179               227288       49.232        0.000                       0                 99903
    | Inter Clock Table
    From Clock                          To Clock                                WNS(ns)      TNS(ns)  TNS Failing Endpoints  TNS Total Endpoints      WHS(ns)      THS(ns)  THS Failing Endpoints  THS Total Endpoints
    clk_out1_system_sys_audio_clkgen_0  clk_fpga_0                                9.082        0.000                      0                    4
    adc_clk_div_s                       clk_fpga_0                                8.253        0.000                      0                   61
    adc_clk_div_s_1                     clk_fpga_0                                9.249        0.000                      0                   11
    adc_clk_in_s                        clk_fpga_0                                8.253        0.000                      0                   51
    clk_fpga_0                          clk_out1_system_sys_audio_clkgen_0       80.462        0.000                      0                    5
    clk_fpga_0                          adc_clk_div_s                             9.426        0.000                      0                  129
    adc_clk_div_s_1                     adc_clk_div_s                            45.481        0.000                      0                   34       -3.402     -115.289                     34                   34
    clk_fpga_0                          adc_clk_div_s_1                           9.432        0.000                      0                   15
    adc_clk_div_s                       adc_clk_div_s_1                          45.476        0.000                      0                   34       -3.354     -113.821                     34                   34
    adc_clk_in_s                        adc_clk_div_s_1                          47.180        0.000                      0                   47        0.637        0.000                      0                    1
    dac_clk_in_s                        adc_clk_div_s_1                          99.485        0.000                      0                   40
    clk_fpga_0                          adc_clk_in_s                              9.426        0.000                      0                  119
    adc_clk_div_s_1                     adc_clk_in_s                             49.485        0.000                      0                   46
    adc_clk_div_s_1                     dac_clk_in_s                             49.485        0.000                      0                   40
    | Other Path Groups Table
    Path Group         From Clock         To Clock               WNS(ns)      TNS(ns)  TNS Failing Endpoints  TNS Total Endpoints      WHS(ns)      THS(ns)  THS Failing Endpoints  THS Total Endpoints
    **async_default**  adc_clk_div_s      adc_clk_div_s           48.491        0.000                      0                 1113        0.198        0.000                      0                 1113
    **async_default**  adc_clk_div_s_1    adc_clk_div_s_1         48.514        0.000                      0                  973        0.178        0.000                      0                  973
    **async_default**  adc_clk_in_s       adc_clk_in_s            99.008        0.000                      0                   66        0.176        0.000                      0                   66
    **async_default**  clk_fpga_0         clk_fpga_0               8.301        0.000                      0                 3529        0.178        0.000                      0                 3529
    **async_default**  dac_clk_in_s       dac_clk_in_s            99.008        0.000                      0                   66        0.176        0.000                      0                   66
    **async_default**  mmcm_clk_0_s       mmcm_clk_0_s             5.623        0.000                      0                  228        0.227        0.000                      0                  228
    | Timing Details
    From Clock:  clk_fpga_0
      To Clock:  clk_fpga_0
    Setup :            0  Failing Endpoints,  Worst Slack        6.300ns,  Total Violation        0.000ns
    Hold  :        10440  Failing Endpoints,  Worst Slack       -0.091ns,  Total Violation     -194.061ns
    PW    :            0  Failing Endpoints,  Worst Slack        2.500ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             6.300ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/INCLUDE_DPHASE_TIMER.dpto_cnt_reg[0]/C
                                (rising edge-triggered cell FDRE clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Destination:            i_system_wrapper/system_i/sys_ps7/inst/PS7_i/MAXIGP0WREADY
                                (rising edge-triggered cell PS7 clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Path Group:             clk_fpga_0
      Path Type:              Setup (Max at Slow Process Corner)
      Requirement:            10.000ns  (clk_fpga_0 rise@10.000ns - clk_fpga_0 rise@0.000ns)
      Data Path Delay:        2.856ns  (logic 0.575ns (20.130%)  route 2.281ns (79.870%))
      Logic Levels:           6  (LUT2=1 LUT4=2 LUT5=1 LUT6=2)
      Clock Path Skew:        -0.021ns (DCD - SCD + CPR)
        Destination Clock Delay (DCD):    0.880ns = ( 10.880 - 10.000 )
        Source Clock Delay      (SCD):    0.932ns
        Clock Pessimism Removal (CPR):    0.031ns
      Clock Uncertainty:      0.154ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
        Total System Jitter     (TSJ):    0.071ns
        Total Input Jitter      (TIJ):    0.300ns
        Discrete Jitter          (DJ):    0.000ns
        Phase Error              (PE):    0.000ns
        Location             Delay type                Incr(ns)  Path(ns)    Netlist Resource(s)
                             (clock clk_fpga_0 rise edge)
                                                          0.000     0.000 r
        PS7_X0Y0             PS7                          0.000     0.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[0]
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.419     0.932    i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/s_axi_aclk
                             FDRE                                         r  i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/INCLUDE_DPHASE_TIMER.dpto_cnt_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     1.165 f  i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/INCLUDE_DPHASE_TIMER.dpto_cnt_reg[0]/Q
                             net (fo=5, unplaced)         0.444     1.609    i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/I_DECODER/s_axi_awready_0[0]
                             LUT4 (Prop_lut4_I1_O)        0.123     1.732 f  i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/I_DECODER/s_axi_wready_INST_0_i_1/O
                             net (fo=2, unplaced)         0.281     2.013    i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/I_DECODER/s_axi_wready_INST_0_i_1_n_0
                             LUT4 (Prop_lut4_I0_O)        0.043     2.056 r  i_system_wrapper/system_i/axi_iic_fmc/U0/X_IIC/X_AXI_IPIF_SSP1/AXI_LITE_IPIF_I/I_SLAVE_ATTACHMENT/I_DECODER/s_axi_wready_INST_0/O
                             net (fo=7, unplaced)         0.305     2.361    i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/splitter_aw/m_axi_wready[5]
                             LUT6 (Prop_lut6_I0_O)        0.043     2.404 r  i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/splitter_aw/s_axi_wready[0]_INST_0_i_8/O
                             net (fo=2, unplaced)         0.281     2.685    i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/splitter_aw/m_axi_wready_7_sn_1
                             LUT5 (Prop_lut5_I4_O)        0.043     2.728 r  i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/splitter_aw/s_axi_wready[0]_INST_0_i_4/O
                             net (fo=1, unplaced)         0.270     2.998    i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/addr_arbiter_inst/s_axi_wready[0]_2
                             LUT6 (Prop_lut6_I3_O)        0.043     3.041 f  i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/addr_arbiter_inst/s_axi_wready[0]_INST_0_i_1/O
                             net (fo=2, unplaced)         0.281     3.322    i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/addr_arbiter_inst/m_ready_d_reg[1]
                             LUT2 (Prop_lut2_I1_O)        0.047     3.369 r  i_system_wrapper/system_i/axi_cpu_interconnect/xbar/inst/gen_sasd.crossbar_sasd_0/addr_arbiter_inst/s_axi_wready[0]_INST_0/O
                             net (fo=1, unplaced)         0.419     3.788    i_system_wrapper/system_i/sys_ps7/inst/M_AXI_GP0_WREADY
        PS7_X0Y0             PS7                                          r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/MAXIGP0WREADY
                                                         10.000    10.000 r
        PS7_X0Y0             PS7                          0.000    10.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[0]
                             net (fo=1, unplaced)         0.398    10.398    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.083    10.481 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.398    10.880    i_system_wrapper/system_i/sys_ps7/inst/M_AXI_GP0_ACLK
        PS7_X0Y0             PS7                                          r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/MAXIGP0ACLK
                             clock pessimism              0.031    10.911
                             clock uncertainty           -0.154    10.757
        PS7_X0Y0             PS7 (Setup_ps7_MAXIGP0ACLK_MAXIGP0WREADY)
                                                         -0.668    10.089    i_system_wrapper/system_i/sys_ps7/inst/PS7_i
                             required time                         10.089
                             arrival time                          -3.788
                             slack                                  6.300
    Min Delay Paths
    Slack (VIOLATED) :        -0.091ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_hp1_interconnect/inst/s02_entry_pipeline/s02_mmu/inst/r_sreg/m_vector_i_reg[1059]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/DIADI[0]
                                (rising edge-triggered cell RAMB36E1 clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Path Type:              Hold (Min at Fast Process Corner)
      Requirement:            0.000ns  (clk_fpga_0 rise@0.000ns - clk_fpga_0 rise@0.000ns)
      Data Path Delay:        0.312ns  (logic 0.104ns (33.332%)  route 0.208ns (66.668%))
      Logic Levels:           0
      Clock Path Skew:        0.145ns (DCD - SCD - CPR)
        Destination Clock Delay (DCD):    0.468ns
        Source Clock Delay      (SCD):    0.308ns
        Clock Pessimism Removal (CPR):    0.015ns
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.074     0.308    i_system_wrapper/system_i/axi_hp1_interconnect/inst/s02_entry_pipeline/s02_mmu/inst/r_sreg/aclk
                             FDRE                                         r  i_system_wrapper/system_i/axi_hp1_interconnect/inst/s02_entry_pipeline/s02_mmu/inst/r_sreg/m_vector_i_reg[1059]/C
                             FDRE (Prop_fdre_C_Q)         0.104     0.412 r  i_system_wrapper/system_i/axi_hp1_interconnect/inst/s02_entry_pipeline/s02_mmu/inst/r_sreg/m_vector_i_reg[1059]/Q
                             net (fo=1, unplaced)         0.208     0.620    i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_src_axi_rdata[0]
                             RAMB36E1                                     r  i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/DIADI[0]
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.219     0.468    i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_src_axi_aclk
                             RAMB36E1                                     r  i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/CLKBWRCLK
                             clock pessimism             -0.015     0.453
                             RAMB36E1 (Hold_ramb36e1_CLKBWRCLK_DIADI[0])
                                                          0.258     0.711    i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg
                             required time                         -0.711
                             arrival time                           0.620
                             slack                                 -0.091
    Pulse Width Checks
    Clock Name:         clk_fpga_0
    Waveform(ns):       { 0.000 5.000 }
    Period(ns):         10.000
    Sources:            { i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[0] }
    Check Type        Corner  Lib Pin          Reference Pin  Required(ns)  Actual(ns)  Slack(ns)  Location  Pin
    Min Period        n/a     MMCME2_ADV/DCLK  n/a            4.999         10.000      5.001                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/DCLK
    Low Pulse Width   Slow    MMCME2_ADV/DCLK  n/a            2.500         5.000       2.500                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/DCLK
    High Pulse Width  Slow    MMCME2_ADV/DCLK  n/a            2.500         5.000       2.501                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/DCLK
    From Clock:  clk_fpga_1
      To Clock:  clk_fpga_1
    Setup :            0  Failing Endpoints,  Worst Slack        3.502ns,  Total Violation        0.000ns
    Hold  :            8  Failing Endpoints,  Worst Slack       -0.006ns,  Total Violation       -0.048ns
    PW    :            0  Failing Endpoints,  Worst Slack        0.264ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             3.502ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/POR_SRL_I/CLK
                                (rising edge-triggered cell SRL16E clocked by clk_fpga_1  {rise@0.000ns fall@2.500ns period=5.000ns})
      Destination:            i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int_reg/D
                                (rising edge-triggered cell FDRE clocked by clk_fpga_1  {rise@0.000ns fall@2.500ns period=5.000ns})
      Path Group:             clk_fpga_1
      Requirement:            5.000ns  (clk_fpga_1 rise@5.000ns - clk_fpga_1 rise@0.000ns)
      Data Path Delay:        1.313ns  (logic 1.043ns (79.436%)  route 0.270ns (20.564%))
      Logic Levels:           1  (LUT4=1)
      Clock Path Skew:        -0.145ns (DCD - SCD + CPR)
        Destination Clock Delay (DCD):    0.920ns = ( 5.920 - 5.000 )
        Source Clock Delay      (SCD):    1.096ns
      Clock Uncertainty:      0.083ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
        Total Input Jitter      (TIJ):    0.150ns
                             (clock clk_fpga_1 rise edge)
                                                          0.000     0.000 r
        PS7_X0Y0             PS7                          0.000     0.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.584     1.096    i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/slowest_sync_clk
                             SRL16E                                       r  i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/POR_SRL_I/CLK
                             SRL16E (Prop_srl16e_CLK_Q)
                                                          1.000     2.096 r  i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/POR_SRL_I/Q
                             net (fo=1, unplaced)         0.270     2.366    i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/Q
                             LUT4 (Prop_lut4_I3_O)        0.043     2.409 r  i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int0/O
                             net (fo=1, unplaced)         0.000     2.409    i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int0__0
                             FDRE                                         r  i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int_reg/D
                                                          5.000     5.000 r
        PS7_X0Y0             PS7                          0.000     5.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.398     5.398    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.083     5.481 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.439     5.920    i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/slowest_sync_clk
                             FDRE                                         r  i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int_reg/C
                             clock pessimism              0.031     5.951
                             clock uncertainty           -0.083     5.869
                             FDRE (Setup_fdre_C_D)        0.043     5.912    i_system_wrapper/system_i/sys_200m_rstgen/U0/EXT_LPF/lpf_int_reg
                             required time                          5.912
                             arrival time                          -2.409
                             slack                                  3.502
    Min Delay Paths
    Slack (VIOLATED) :        -0.006ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d1_reg/C
                                (rising edge-triggered cell FDPE clocked by clk_fpga_1  {rise@0.000ns fall@2.500ns period=5.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d2_reg/D
      Requirement:            0.000ns  (clk_fpga_1 rise@0.000ns - clk_fpga_1 rise@0.000ns)
      Data Path Delay:        0.158ns  (logic 0.104ns (65.800%)  route 0.054ns (34.200%))
      Logic Levels:           0
        Destination Clock Delay (DCD):    0.508ns
        Source Clock Delay      (SCD):    0.348ns
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.114     0.348    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/delay_clk
                             FDPE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d1_reg/C
                             FDPE (Prop_fdpe_C_Q)         0.104     0.452 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d1_reg/Q
                             net (fo=1, unplaced)         0.054     0.506    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d1
                             FDPE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d2_reg/D
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.259     0.508    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/delay_clk
                             FDPE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d2_reg/C
                             clock pessimism             -0.015     0.493
                             FDPE (Hold_fdpe_C_D)         0.019     0.512    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_delay_cntrl_rx1/i_delay_rst_reg/rst_async_d2_reg
                             required time                         -0.512
                             arrival time                           0.506
                             slack                                 -0.006
    Pulse Width Checks
    Clock Name:         clk_fpga_1
    Waveform(ns):       { 0.000 2.500 }
    Period(ns):         5.000
    Sources:            { i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1] }
    Min Period        n/a     IDELAYCTRL/REFCLK  n/a            2.438         5.000       2.562                i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_serdes/i_delay_ctrl/REFCLK
    Max Period        n/a     IDELAYCTRL/REFCLK  n/a            5.264         5.000       0.264                i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_serdes/i_delay_ctrl/REFCLK
    Low Pulse Width   Fast    MMCME2_ADV/CLKIN1  n/a            1.400         2.500       1.100                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKIN1
    High Pulse Width  Slow    MMCME2_ADV/CLKIN1  n/a            1.400         2.500       1.100                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKIN1
    From Clock:  clk_out1_system_sys_audio_clkgen_0
      To Clock:  clk_out1_system_sys_audio_clkgen_0
    Setup :            0  Failing Endpoints,  Worst Slack       79.880ns,  Total Violation        0.000ns
    Hold  :           22  Failing Endpoints,  Worst Slack       -0.057ns,  Total Violation       -0.978ns
    PW    :            0  Failing Endpoints,  Worst Slack       39.922ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             79.880ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/cdc_sync_stage3_tick_reg/C
                                (rising edge-triggered cell FDRE clocked by clk_out1_system_sys_audio_clkgen_0  {rise@0.000ns fall@40.690ns period=81.380ns})
      Destination:            i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[0]/CE
      Path Group:             clk_out1_system_sys_audio_clkgen_0
      Requirement:            81.380ns  (clk_out1_system_sys_audio_clkgen_0 rise@81.380ns - clk_out1_system_sys_audio_clkgen_0 rise@0.000ns)
      Data Path Delay:        0.941ns  (logic 0.356ns (37.832%)  route 0.585ns (62.168%))
      Logic Levels:           1  (LUT2=1)
        Destination Clock Delay (DCD):    1.914ns = ( 83.294 - 81.380 )
        Source Clock Delay      (SCD):    2.270ns
        Clock Pessimism Removal (CPR):    0.211ns
      Clock Uncertainty:      0.215ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
        Discrete Jitter          (DJ):    0.424ns
                             (clock clk_out1_system_sys_audio_clkgen_0 rise edge)
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.584     1.096    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_in1
                             MMCME2_ADV (Prop_mmcme2_adv_CLKIN1_CLKOUT0)
                                                          0.077     1.173 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0
                             net (fo=1, unplaced)         0.419     1.593    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_out1_system_sys_audio_clkgen_0
                             BUFG (Prop_bufg_I_O)         0.093     1.686 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/clkout1_buf/O
                             net (fo=35, unplaced)        0.584     2.270    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/data_clk_i
                             FDRE                                         r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/cdc_sync_stage3_tick_reg/C
                             FDRE (Prop_fdre_C_Q)         0.233     2.503 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/cdc_sync_stage3_tick_reg/Q
                             net (fo=3, unplaced)         0.285     2.788    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/cdc_sync_stage3_tick_1
                             LUT2 (Prop_lut2_I0_O)        0.123     2.911 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data[4]_i_1/O
                             net (fo=5, unplaced)         0.300     3.211    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data[4]_i_1_n_0
                             FDRE                                         r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[0]/CE
                                                         81.380    81.380 r
        PS7_X0Y0             PS7                          0.000    81.380 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.398    81.779    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.083    81.862 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.439    82.301    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_in1
                                                          0.073    82.374 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0
                             net (fo=1, unplaced)         0.398    82.772    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_out1_system_sys_audio_clkgen_0
                             BUFG (Prop_bufg_I_O)         0.083    82.855 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/clkout1_buf/O
                             net (fo=35, unplaced)        0.439    83.294    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/data_clk_i
                             clock pessimism              0.211    83.505
                             clock uncertainty           -0.215    83.290
                             FDRE (Setup_fdre_C_CE)      -0.199    83.091    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[0]
                             required time                         83.091
                             arrival time                          -3.211
                             slack                                 79.880
    Min Delay Paths
    Slack (VIOLATED) :        -0.057ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/wr_addr_reg[1]/C
      Destination:            i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA/WADR1
                                (rising edge-triggered cell RAMD32 clocked by clk_out1_system_sys_audio_clkgen_0  {rise@0.000ns fall@40.690ns period=81.380ns})
      Requirement:            0.000ns  (clk_out1_system_sys_audio_clkgen_0 rise@0.000ns - clk_out1_system_sys_audio_clkgen_0 rise@0.000ns)
      Data Path Delay:        0.346ns  (logic 0.104ns (30.101%)  route 0.242ns (69.899%))
      Logic Levels:           0
        Destination Clock Delay (DCD):    1.069ns
        Source Clock Delay      (SCD):    0.746ns
        Clock Pessimism Removal (CPR):    0.178ns
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.114     0.348    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_in1
                                                          0.050     0.398 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0
                             net (fo=1, unplaced)         0.208     0.606    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_out1_system_sys_audio_clkgen_0
                             BUFG (Prop_bufg_I_O)         0.026     0.632 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/clkout1_buf/O
                             net (fo=35, unplaced)        0.114     0.746    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/data_clk_i
                             FDRE                                         r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/wr_addr_reg[1]/C
                             FDRE (Prop_fdre_C_Q)         0.104     0.850 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/wr_addr_reg[1]/Q
                             net (fo=9, unplaced)         0.242     1.092    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/ADDRD1
                             RAMD32                                       r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA/WADR1
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.259     0.508    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_in1
                                                          0.053     0.561 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0
                             net (fo=1, unplaced)         0.219     0.780    i_system_wrapper/system_i/sys_audio_clkgen/inst/clk_out1_system_sys_audio_clkgen_0
                             BUFG (Prop_bufg_I_O)         0.030     0.810 r  i_system_wrapper/system_i/sys_audio_clkgen/inst/clkout1_buf/O
                             net (fo=35, unplaced)        0.259     1.069    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/WCLK
                             RAMD32                                       r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA/CLK
                             clock pessimism             -0.178     0.891
                             RAMD32 (Hold_ramd32_CLK_WADR1)
                                                          0.258     1.149    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA
                             required time                         -1.149
                             arrival time                           1.092
                             slack                                 -0.057
    Pulse Width Checks
    Clock Name:         clk_out1_system_sys_audio_clkgen_0
    Waveform(ns):       { 0.000 40.690 }
    Period(ns):         81.380
    Sources:            { i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0 }
    Min Period        n/a     BUFG/I              n/a            1.409         81.380      79.972               i_system_wrapper/system_i/sys_audio_clkgen/inst/clkout1_buf/I
    Max Period        n/a     MMCME2_ADV/CLKOUT0  n/a            213.360       81.380      131.980              i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKOUT0
    Low Pulse Width   Fast    RAMD32/CLK          n/a            0.768         40.690      39.922               i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA/CLK
    High Pulse Width  Slow    RAMD32/CLK          n/a            0.768         40.690      39.922               i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMA/CLK
    From Clock:  clkfbout_system_sys_audio_clkgen_0
      To Clock:  clkfbout_system_sys_audio_clkgen_0
    Setup :           NA  Failing Endpoints,  Worst Slack           NA  ,  Total Violation           NA
    Hold  :           NA  Failing Endpoints,  Worst Slack           NA  ,  Total Violation           NA
    PW    :            0  Failing Endpoints,  Worst Slack       43.929ns,  Total Violation        0.000ns
    Pulse Width Checks
    Clock Name:         clkfbout_system_sys_audio_clkgen_0
    Waveform(ns):       { 0.000 22.500 }
    Period(ns):         45.000
    Sources:            { i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKFBOUT }
    Min Period  n/a     MMCME2_ADV/CLKFBOUT  n/a            1.071         45.000      43.929               i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKFBOUT
    Max Period  n/a     MMCME2_ADV/CLKFBIN   n/a            100.000       45.000      55.000               i_system_wrapper/system_i/sys_audio_clkgen/inst/mmcm_adv_inst/CLKFBIN
    From Clock:  mmcm_clk_0_s
      To Clock:  mmcm_clk_0_s
    Setup :            0  Failing Endpoints,  Worst Slack        3.505ns,  Total Violation        0.000ns
    Hold  :           32  Failing Endpoints,  Worst Slack       -0.019ns,  Total Violation       -0.338ns
    PW    :            0  Failing Endpoints,  Worst Slack        2.725ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             3.505ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_xfer_cntrl/d_data_cntrl_int_reg[176]/C
                                (rising edge-triggered cell FDCE clocked by mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Destination:            i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count_reg[0]/R
                                (rising edge-triggered cell FDRE clocked by mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Path Group:             mmcm_clk_0_s
      Requirement:            6.735ns  (mmcm_clk_0_s rise@6.735ns - mmcm_clk_0_s rise@0.000ns)
      Data Path Delay:        2.635ns  (logic 1.229ns (46.641%)  route 1.406ns (53.359%))
      Logic Levels:           6  (CARRY4=4 LUT2=1 LUT4=1)
        Destination Clock Delay (DCD):    0.920ns = ( 7.655 - 6.735 )
      Clock Uncertainty:      0.147ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
        Discrete Jitter          (DJ):    0.286ns
                             (clock mmcm_clk_0_s rise edge)
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.584     1.096    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -1.096     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.584     1.096    i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_xfer_cntrl/hdmi_clk
                             FDCE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_xfer_cntrl/d_data_cntrl_int_reg[176]/C
                             FDCE (Prop_fdce_C_Q)         0.233     1.329 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_xfer_cntrl/d_data_cntrl_int_reg[176]/Q
                             net (fo=3, unplaced)         0.207     1.536    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_16_vsync_data_e_d_reg_0[159]
                             CARRY4 (Prop_carry4_CYINIT_CO[3])
                                                          0.377     1.913 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s_carry/CO[3]
                             net (fo=1, unplaced)         0.007     1.920    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s_carry_n_0
                             CARRY4 (Prop_carry4_CI_CO[3])
                                                          0.054     1.974 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s_carry__0/CO[3]
                             net (fo=1, unplaced)         0.000     1.974    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s_carry__0_n_0
                             CARRY4 (Prop_carry4_CI_O[2])
                                                          0.120     2.094 f  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s_carry__1/O[2]
                             net (fo=2, unplaced)         0.253     2.347    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hl_width_s[11]
                             LUT4 (Prop_lut4_I1_O)        0.137     2.484 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_count0_carry__0_i_3/O
                             net (fo=1, unplaced)         0.000     2.484    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_count0_carry__0_i_3_n_0
                             CARRY4 (Prop_carry4_DI[1]_CO[3])
                                                          0.265     2.749 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_count0_carry__0/CO[3]
                             net (fo=33, unplaced)        0.497     3.246    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_count0_carry__0_n_0
                             LUT2 (Prop_lut2_I1_O)        0.043     3.289 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count[0]_i_1/O
                             net (fo=16, unplaced)        0.442     3.731    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count
                             FDRE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count_reg[0]/R
                                                          6.735     6.735 r
        PS7_X0Y0             PS7                          0.000     6.735 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.398     7.133    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.083     7.216 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.439     7.655    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.920     6.735 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.398     7.133    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.083     7.216 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.439     7.655    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_clk
                             FDRE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count_reg[0]/C
                             clock pessimism              0.031     7.686
                             clock uncertainty           -0.147     7.539
                             FDRE (Setup_fdre_C_R)       -0.302     7.237    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vs_count_reg[0]
                             required time                          7.237
                             arrival time                          -3.731
                             slack                                  3.505
    Min Delay Paths
    Slack (VIOLATED) :        -0.019ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vsync_data_e_reg/C
      Destination:            i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/sync_3_m_reg[1]_srl3/D
                                (rising edge-triggered cell SRL16E clocked by mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Requirement:            0.000ns  (mmcm_clk_0_s rise@0.000ns - mmcm_clk_0_s rise@0.000ns)
      Data Path Delay:        0.192ns  (logic 0.093ns (48.392%)  route 0.099ns (51.608%))
      Logic Levels:           0
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.114     0.348    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.348     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.114     0.348    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_clk
                             FDRE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vsync_data_e_reg/C
                             FDRE (Prop_fdre_C_Q)         0.093     0.441 r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_vsync_data_e_reg/Q
                             net (fo=2, unplaced)         0.099     0.540    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/hdmi_vsync_data_e
                             SRL16E                                       r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/sync_3_m_reg[1]_srl3/D
                                                          0.000     0.000 r
                             net (fo=46, unplaced)        0.259     0.508    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.508     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.259     0.508    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/hdmi_clk
                             SRL16E                                       r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/sync_3_m_reg[1]_srl3/CLK
                             SRL16E (Hold_srl16e_CLK_D)
                                                          0.066     0.559    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_csc_RGB2CrYCb/j_csc_1_Cr/sync_3_m_reg[1]_srl3
                             required time                         -0.559
                             arrival time                           0.540
                             slack                                 -0.019
    Pulse Width Checks
    Clock Name:         mmcm_clk_0_s
    Waveform(ns):       { 0.000 3.367 }
    Period(ns):         6.735
    Sources:            { i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0 }
    Min Period        n/a     RAMB36E1/CLKARDCLK  n/a            1.839         6.735       4.896                i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/i_mem/m_ram_reg/CLKARDCLK
    Max Period        n/a     MMCME2_ADV/CLKOUT0  n/a            213.360       6.735       206.625              i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
    Low Pulse Width   Slow    SRL16E/CLK          n/a            0.642         3.367       2.725                i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_2d_reg_srl3/CLK
    High Pulse Width  Slow    SRL16E/CLK          n/a            0.642         3.367       2.725                i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_hs_2d_reg_srl3/CLK
    From Clock:  mmcm_clk_1_s
      To Clock:  mmcm_clk_1_s
    PW    :            0  Failing Endpoints,  Worst Slack        5.326ns,  Total Violation        0.000ns
    Pulse Width Checks
    Clock Name:         mmcm_clk_1_s
    Period(ns):         6.735
    Sources:            { i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT1 }
    Min Period  n/a     BUFG/I              n/a            1.409         6.735       5.326                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_1_bufg/I
    Max Period  n/a     MMCME2_ADV/CLKOUT1  n/a            213.360       6.735       206.625              i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT1
    From Clock:  mmcm_clk_2_s
      To Clock:  mmcm_clk_2_s
    PW    :            0  Failing Endpoints,  Worst Slack        0.836ns,  Total Violation        0.000ns
    Pulse Width Checks
    Clock Name:         mmcm_clk_2_s
    Waveform(ns):       { 0.000 1.122 }
    Period(ns):         2.245
    Sources:            { i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT2 }
    Min Period  n/a     BUFG/I              n/a            1.409         2.245       0.836                i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_2_bufg/I
    Max Period  n/a     MMCME2_ADV/CLKOUT2  n/a            213.360       2.245       211.115              i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT2
    From Clock:  mmcm_fb_clk_s
      To Clock:  mmcm_fb_clk_s
    PW    :            0  Failing Endpoints,  Worst Slack       45.000ns,  Total Violation        0.000ns
    Pulse Width Checks
    Clock Name:         mmcm_fb_clk_s
    Waveform(ns):       { 0.000 27.500 }
    Period(ns):         55.000
    Sources:            { i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKFBOUT }
    Min Period  n/a     BUFG/I              n/a            1.409         55.000      53.591               i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_fb_clk_bufg/I
    Max Period  n/a     MMCME2_ADV/CLKFBIN  n/a            100.000       55.000      45.000               i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKFBIN
    From Clock:  rx1_dclk_out
      To Clock:  rx1_dclk_out
    PW    :            0  Failing Endpoints,  Worst Slack       11.251ns,  Total Violation        0.000ns
    Pulse Width Checks
    Clock Name:         rx1_dclk_out
    Waveform(ns):       { 0.000 6.250 }
    Period(ns):         12.500
    Sources:            { rx1_dclk_in_p }
    Min Period  n/a     BUFIO/I  n/a            1.249         12.500      11.251     BUFIO_X1Y18  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_buf/I
    From Clock:  adc_clk_div_s
      To Clock:  adc_clk_div_s
    Setup :            0  Failing Endpoints,  Worst Slack       47.272ns,  Total Violation        0.000ns
    Hold  :          505  Failing Endpoints,  Worst Slack       -0.131ns,  Total Violation      -12.607ns
    PW    :            0  Failing Endpoints,  Worst Slack       24.232ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             47.272ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/CLKARDCLK
                                (rising edge-triggered cell RAMB36E1 clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/fifo_rd_data_reg[16]/D
                                (rising edge-triggered cell FDRE clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Path Group:             adc_clk_div_s
      Requirement:            50.000ns  (adc_clk_div_s rise@50.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        2.590ns  (logic 1.890ns (72.960%)  route 0.700ns (27.040%))
      Logic Levels:           2  (LUT3=1 LUT5=1)
        Destination Clock Delay (DCD):    4.388ns = ( 54.388 - 50.000 )
        Source Clock Delay      (SCD):    7.970ns
        Clock Pessimism Removal (CPR):    3.438ns
      Clock Uncertainty:      0.035ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
        Total Input Jitter      (TIJ):    0.000ns
                             (clock adc_clk_div_s rise edge)
                                                          0.000     0.000 r
                             clock source latency         5.000     5.000
        J4                                                0.000     5.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000     5.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.870     5.870 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.354     6.224    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.650     6.874 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.584     7.458    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.093     7.551 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.419     7.970    i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_axis_aclk
                             RAMB36E1                                     r  i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/CLKARDCLK
                             RAMB36E1 (Prop_ramb36e1_CLKARDCLK_DOADO[0])
                                                          1.800     9.770 r  i_system_wrapper/system_i/axi_adrv9001_tx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/DOADO[0]
                             net (fo=2, unplaced)         0.419    10.190    i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/i_pack_shell/gen_input_buffer.i_ext_ctrl_interconnect/s_axis_data[0]
                             LUT5 (Prop_lut5_I3_O)        0.043    10.233 r  i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/i_pack_shell/gen_input_buffer.i_ext_ctrl_interconnect/fifo_rd_data[0]_i_2/O
                             net (fo=2, unplaced)         0.281    10.514    i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/i_pack_shell/gen_input_buffer.i_ext_ctrl_interconnect/fifo_rd_data[0]_i_2_n_0
                             LUT3 (Prop_lut3_I2_O)        0.047    10.561 r  i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/i_pack_shell/gen_input_buffer.i_ext_ctrl_interconnect/fifo_rd_data[16]_i_1/O
                             net (fo=1, unplaced)         0.000    10.561    i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/deinterleaved_data[16]
                             FDRE                                         r  i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/fifo_rd_data_reg[16]/D
                                                         50.000    50.000 r
                             clock source latency         2.000    52.000
        J4                                                0.000    52.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000    52.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.768    52.768 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209    52.977    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614    53.591 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439    54.030    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083    54.113 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.274    54.388    i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/clk
                             FDRE                                         r  i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/fifo_rd_data_reg[16]/C
                             clock pessimism              3.438    57.825
                             clock uncertainty           -0.035    57.790
                             FDRE (Setup_fdre_C_D)        0.043    57.833    i_system_wrapper/system_i/util_dac_1_upack/inst/i_upack/fifo_rd_data_reg[16]
                             required time                         57.833
                             arrival time                         -10.561
                             slack                                 47.272
    Min Delay Paths
    Slack (VIOLATED) :        -0.131ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                                (rising edge-triggered cell FDCE clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/g_data[0].i_serdes/RST
                                (rising edge-triggered cell OSERDESE2 clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Requirement:            0.000ns  (adc_clk_div_s rise@0.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        0.621ns  (logic 0.168ns (27.032%)  route 0.453ns (72.968%))
      Logic Levels:           1  (LUT3=1)
        Destination Clock Delay (DCD):    6.378ns
        Source Clock Delay      (SCD):    2.830ns
        Clock Pessimism Removal (CPR):    3.403ns
                                                          0.000     0.000 r
                             clock source latency         2.000     2.000
        J4                                                0.000     2.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000     2.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.353     2.353 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.040     2.393    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.223     2.616 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.114     2.730    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.026     2.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.074     2.830    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/adc_clk_div
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                             FDCE (Prop_fdce_C_Q)         0.104     2.934 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/Q
                             net (fo=43, unplaced)        0.245     3.179    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/Q[0]
                             LUT3 (Prop_lut3_I0_O)        0.064     3.243 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/g_data[0].i_serdes_i_9/O
                             net (fo=4, unplaced)         0.208     3.451    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/RST0
        OLOGIC_X1Y242        OSERDESE2                                    r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/g_data[0].i_serdes/RST
                                                          0.000     0.000 r
        J4                   IBUFDS (Prop_ibufds_I_O)     0.434     5.434 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.185     5.619    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.251     5.870 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.259     6.129    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.030     6.159 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.219     6.378    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/tx1_dclk_out_p_dclk_out
        OLOGIC_X1Y242        OSERDESE2                                    r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/g_data[0].i_serdes/CLKDIV
                             clock pessimism             -3.403     2.975
        OLOGIC_X1Y242        OSERDESE2 (Hold_oserdese2_CLKDIV_RST)
                                                          0.607     3.582    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_1_phy/i_serdes/g_data[0].i_serdes
                             required time                         -3.582
                             arrival time                           3.451
                             slack                                 -0.131
    Pulse Width Checks
    Clock Name:         adc_clk_div_s
    Waveform(ns):       { 0.000 25.000 }
    Period(ns):         50.000
    Sources:            { i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O }
    Min Period        n/a     RAMB36E1/CLKBWRCLK  n/a            1.839         50.000      48.161               i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg/CLKBWRCLK
    Low Pulse Width   Fast    RAMD32/CLK          n/a            0.768         25.000      24.232               i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r1_0_15_0_0/DP/CLK
    High Pulse Width  Slow    RAMD32/CLK          n/a            0.768         25.000      24.232               i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r1_0_15_0_0/DP/CLK
    From Clock:  rx2_dclk_out
      To Clock:  rx2_dclk_out
    Pulse Width Checks
    Clock Name:         rx2_dclk_out
    Period(ns):         12.500
    Sources:            { rx2_dclk_in_p }
    Min Period  n/a     BUFIO/I  n/a            1.249         12.500      11.251     BUFIO_X1Y17  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_buf/I
    From Clock:  adc_clk_div_s_1
      To Clock:  adc_clk_div_s_1
    Setup :            0  Failing Endpoints,  Worst Slack       47.332ns,  Total Violation        0.000ns
    Hold  :          957  Failing Endpoints,  Worst Slack       -0.237ns,  Total Violation      -19.889ns
    PW    :            0  Failing Endpoints,  Worst Slack       24.358ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             47.332ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/ila_0/inst/ila_core_inst/en_adv_trigger_reg/C
                                (rising edge-triggered cell FDRE clocked by adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/iscnt_reg[0]/R
      Path Group:             adc_clk_div_s_1
      Requirement:            50.000ns  (adc_clk_div_s_1 rise@50.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        2.186ns  (logic 0.450ns (20.586%)  route 1.736ns (79.414%))
      Logic Levels:           3  (LUT3=2 SRLC32E=1)
        Destination Clock Delay (DCD):    4.375ns = ( 54.375 - 50.000 )
        Source Clock Delay      (SCD):    7.958ns
                             (clock adc_clk_div_s_1 rise edge)
                                                          0.000     0.000 r
        M6                                                0.000     5.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000     5.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.857     5.857 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.354     6.211    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.650     6.861 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.584     7.445    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.093     7.538 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.419     7.958    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/I_IS_TERMINATION_SLICE_W_OUTPUT_REG.DOUT_O_reg
                             FDRE                                         r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/en_adv_trigger_reg/C
                             FDRE (Prop_fdre_C_Q)         0.233     8.191 f  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/en_adv_trigger_reg/Q
                             net (fo=2, unplaced)         0.427     8.618    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/itrigger_out_reg_0
                             LUT3 (Prop_lut3_I0_O)        0.131     8.749 r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/trigger_i/O
                             net (fo=19, unplaced)        0.466     9.215    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCRST/A[2]
                             SRLC32E (Prop_srlc32e_A[2]_Q)
                                                          0.043     9.258 r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCRST/I_YESLUT6.U_SRL32_A/Q
                             net (fo=1, unplaced)         0.407     9.665    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCRST/I_YESLUT6.SRL_Q_1
                             LUT3 (Prop_lut3_I0_O)        0.043     9.708 r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCRST/iscnt[0]_i_1/O
                             net (fo=12, unplaced)        0.436    10.144    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/U_SCRST_n_2
                             FDRE                                         r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/iscnt_reg[0]/R
                                                         50.000    50.000 r
        M6                                                0.000    52.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000    52.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.756    52.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209    52.965    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614    53.579 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439    54.018    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083    54.101 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.274    54.375    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/probeDelay1_reg[11]
                             FDRE                                         r  i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/iscnt_reg[0]/C
                             clock pessimism              3.438    57.813
                             clock uncertainty           -0.035    57.778
                             FDRE (Setup_fdre_C_R)       -0.302    57.476    i_system_wrapper/system_i/ila_0/inst/ila_core_inst/u_ila_cap_ctrl/u_cap_addrgen/u_cap_sample_counter/iscnt_reg[0]
                             required time                         57.476
                             arrival time                         -10.144
                             slack                                 47.332
    Min Delay Paths
    Slack (VIOLATED) :        -0.237ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/cdc_sync_stage2_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/g_data[0].i_serdes/RST
                                (rising edge-triggered cell OSERDESE2 clocked by adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Requirement:            0.000ns  (adc_clk_div_s_1 rise@0.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        0.515ns  (logic 0.169ns (32.823%)  route 0.346ns (67.177%))
        Destination Clock Delay (DCD):    6.365ns
        Source Clock Delay      (SCD):    2.817ns
                                                          0.000     0.000 r
        M6                                                0.000     2.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000     2.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.341     2.341 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.040     2.381    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.223     2.604 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.114     2.718    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.026     2.744 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.074     2.817    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/cdc_sync_stage2_reg[3]_0
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/cdc_sync_stage2_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.104     2.921 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/cdc_sync_stage2_reg[0]/Q
                             net (fo=2, unplaced)         0.138     3.059    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/cdc_sync_stage2_reg_n_0_[0]
                             LUT4 (Prop_lut4_I2_O)        0.065     3.124 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1_ctrl_sync/g_data[0].i_serdes_i_9__0/O
                             net (fo=4, unplaced)         0.208     3.332    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/RST0_1
        OLOGIC_X1Y208        OSERDESE2                                    r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/g_data[0].i_serdes/RST
                                                          0.000     0.000 r
        M6                   IBUFDS (Prop_ibufds_I_O)     0.421     5.421 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.185     5.606    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.251     5.857 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.259     6.116    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.030     6.146 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.219     6.365    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/dac_clk_div
        OLOGIC_X1Y208        OSERDESE2                                    r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/g_data[0].i_serdes/CLKDIV
                             clock pessimism             -3.403     2.962
        OLOGIC_X1Y208        OSERDESE2 (Hold_oserdese2_CLKDIV_RST)
                                                          0.607     3.569    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_tx_2_phy/i_serdes/g_data[0].i_serdes
                             required time                         -3.569
                             arrival time                           3.332
                             slack                                 -0.237
    Pulse Width Checks
    Clock Name:         adc_clk_div_s_1
    Period(ns):         50.000
    Sources:            { i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O }
    Min Period        n/a     RAMB18E1/CLKARDCLK  n/a            2.095         50.000      47.905               i_system_wrapper/system_i/ila_0/inst/ila_core_inst/ila_trace_memory_inst/SUBCORE_RAM_BLK_MEM_1.trace_block_memory/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_7SERIES.NO_BMM_INFO.SDP.SIMPLE_PRIM18.ram/CLKARDCLK
    Low Pulse Width   Slow    SRL16E/CLK          n/a            0.642         25.000      24.358               i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmgb.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[2].ram.r/SAFETY_CKT_GEN.RSTA_SHFT_REG_reg[3]_srl3/CLK
    High Pulse Width  Slow    SRL16E/CLK          n/a            0.642         25.000      24.358               i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmgb.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[2].ram.r/SAFETY_CKT_GEN.RSTA_SHFT_REG_reg[3]_srl3/CLK
    From Clock:  adc_clk_in_s
      To Clock:  adc_clk_in_s
    Setup :            0  Failing Endpoints,  Worst Slack       93.144ns,  Total Violation        0.000ns
    Hold  :         4156  Failing Endpoints,  Worst Slack       -0.091ns,  Total Violation      -90.278ns
    PW    :            0  Failing Endpoints,  Worst Slack       49.232ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             93.144ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/Product_Im_1_reg[0]__0/CLK
                                (rising edge-triggered cell DSP48E1 clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][29]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0/D
                                (rising edge-triggered cell SRL16E clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Path Group:             adc_clk_in_s
      Requirement:            100.000ns  (adc_clk_in_s rise@100.000ns - adc_clk_in_s rise@0.000ns)
      Data Path Delay:        6.571ns  (logic 3.245ns (49.380%)  route 3.326ns (50.620%))
      Logic Levels:           22  (CARRY4=12 LUT2=1 LUT3=4 LUT4=3 LUT5=1 LUT6=1)
        Destination Clock Delay (DCD):    5.950ns = ( 105.950 - 100.000 )
        Source Clock Delay      (SCD):    9.869ns
        Clock Pessimism Removal (CPR):    3.774ns
                             (clock adc_clk_in_s rise edge)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.419     7.958    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.650     8.608 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.584     9.192    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.093     9.285 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.584     9.869    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/IPCORE_CLK
                             DSP48E1                                      r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/Product_Im_1_reg[0]__0/CLK
                             DSP48E1 (Prop_dsp48e1_CLK_P[0])
                                                          0.348    10.217 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/Product_Im_1_reg[0]__0/P[0]
                             net (fo=2, unplaced)         0.419    10.636    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/Product_Im_1_reg[0]__0_n_105
                             LUT2 (Prop_lut2_I0_O)        0.043    10.679 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_192/O
                             net (fo=1, unplaced)         0.000    10.679    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_192_n_0
                             CARRY4 (Prop_carry4_S[1]_CO[3])
                                                          0.256    10.935 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_185/CO[3]
                             net (fo=1, unplaced)         0.007    10.942    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_185_n_0
                                                          0.054    10.996 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_180/CO[3]
                             net (fo=1, unplaced)         0.000    10.996    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_180_n_0
                                                          0.054    11.050 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_175/CO[3]
                             net (fo=1, unplaced)         0.000    11.050    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_175_n_0
                             CARRY4 (Prop_carry4_CI_O[3])
                                                          0.157    11.207 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_174/O[3]
                             net (fo=2, unplaced)         0.302    11.509    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_174_n_4
                             LUT3 (Prop_lut3_I2_O)        0.120    11.629 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_169/O
                             net (fo=2, unplaced)         0.281    11.910    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_169_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    11.953 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_172/O
                             net (fo=1, unplaced)         0.000    11.953    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_172_n_0
                                                          0.256    12.209 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_159/CO[3]
                             net (fo=1, unplaced)         0.007    12.216    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][15]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_159_n_0
                                                          0.157    12.373 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_159/O[3]
                             net (fo=2, unplaced)         0.302    12.675    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_159_n_4
                             LUT3 (Prop_lut3_I1_O)        0.120    12.795 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_113/O
                             net (fo=2, unplaced)         0.281    13.076    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_113_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    13.119 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_117/O
                             net (fo=1, unplaced)         0.000    13.119    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_117_n_0
                             CARRY4 (Prop_carry4_S[0]_CO[3])
                                                          0.246    13.365 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_56/CO[3]
                             net (fo=1, unplaced)         0.000    13.365    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][19]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_56_n_0
                                                          0.157    13.522 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_PolyPhaseFIRFilter/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_56/O[3]
                             net (fo=2, unplaced)         0.302    13.824    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_15_0[3]
                             LUT3 (Prop_lut3_I0_O)        0.120    13.944 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_37/O
                             net (fo=2, unplaced)         0.281    14.225    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_37_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    14.268 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_41/O
                             net (fo=1, unplaced)         0.000    14.268    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_41_n_0
                                                          0.246    14.514 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_15/CO[3]
                             net (fo=1, unplaced)         0.000    14.514    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][23]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_15_n_0
                                                          0.157    14.671 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_15/O[3]
                             net (fo=3, unplaced)         0.309    14.980    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_15_n_4
                             LUT3 (Prop_lut3_I1_O)        0.120    15.100 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_17/O
                             net (fo=2, unplaced)         0.281    15.381    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_17_n_0
                             LUT5 (Prop_lut5_I1_O)        0.043    15.424 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_5/O
                             net (fo=2, unplaced)         0.253    15.677    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_5_n_0
                             LUT6 (Prop_lut6_I0_O)        0.043    15.720 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_9/O
                             net (fo=1, unplaced)         0.000    15.720    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_9_n_0
                                                          0.246    15.966 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_1/CO[3]
                             net (fo=1, unplaced)         0.000    15.966    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][27]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_1_n_0
                             CARRY4 (Prop_carry4_CI_O[1])
                                                          0.173    16.139 r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][31]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0_i_1/O[1]
                             net (fo=1, unplaced)         0.301    16.440    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/PolyPhaseFIRFilter_out1_im[29]
                             SRL16E                                       r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][29]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0/D
                                                        100.000   100.000 r
                             clock source latency         2.000   102.000
        M6                                                0.000   102.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000   102.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.756   102.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209   102.965    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614   103.579 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439   104.018    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083   104.101 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.274   104.375    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.614   104.989 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.439   105.428    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.083   105.511 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.439   105.950    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/IPCORE_CLK
                             SRL16E                                       r  i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][29]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0/CLK
                             clock pessimism              3.774   109.724
                             clock uncertainty           -0.035   109.689
                             SRL16E (Setup_srl16e_CLK_D)
                                                         -0.104   109.585    i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/intdelay_reg_1_reg[1][29]_srl2___U0_u_HDLRxIPCofinal_ip_dut_inst_u_HDLRxIPCofinal_ip_src_HDLRxIPCore_u_HDLRx_u_Channelizer_u_FFT_M_Point_u_FFT_HDL_Optimized1_intdelay_reg_5_reg_r_0
                             required time                        109.585
                             arrival time                         -16.440
                             slack                                 93.144
    Min Delay Paths
    Slack (VIOLATED) :        -0.091ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/util_adc_2_pack/inst/i_cpack/packed_fifo_wr_data_reg[0]/C
                                (rising edge-triggered cell FDRE clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg_bram_0/DIBDI[0]
                                (rising edge-triggered cell RAMB36E1 clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Path Type:              Hold (Min at Fast Process Corner)
      Requirement:            0.000ns  (adc_clk_in_s rise@0.000ns - adc_clk_in_s rise@0.000ns)
      Data Path Delay:        0.312ns  (logic 0.104ns (33.332%)  route 0.208ns (66.668%))
      Logic Levels:           0
      Clock Path Skew:        0.145ns (DCD - SCD - CPR)
        Destination Clock Delay (DCD):    7.164ns
        Source Clock Delay      (SCD):    3.294ns
        Clock Pessimism Removal (CPR):    3.725ns
        Location             Delay type                Incr(ns)  Path(ns)    Netlist Resource(s)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.074     2.817    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.223     3.040 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.114     3.154    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.026     3.180 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.114     3.294    i_system_wrapper/system_i/util_adc_2_pack/inst/i_cpack/clk
                             FDRE                                         r  i_system_wrapper/system_i/util_adc_2_pack/inst/i_cpack/packed_fifo_wr_data_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.104     3.398 r  i_system_wrapper/system_i/util_adc_2_pack/inst/i_cpack/packed_fifo_wr_data_reg[0]/Q
                             net (fo=1, unplaced)         0.208     3.607    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/fifo_wr_din[0]
                             RAMB36E1                                     r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg_bram_0/DIBDI[0]
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.251     6.616 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.259     6.875    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.030     6.905 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.259     7.164    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/fifo_wr_clk
                             RAMB36E1                                     r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg_bram_0/CLKBWRCLK
                             clock pessimism             -3.725     3.439
                             RAMB36E1 (Hold_ramb36e1_CLKBWRCLK_DIBDI[0])
                                                          0.258     3.697    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_mem/m_ram_reg_bram_0
                             required time                         -3.697
                             arrival time                           3.607
                             slack                                 -0.091
    Pulse Width Checks
    Clock Name:         adc_clk_in_s
    Waveform(ns):       { 0.000 50.000 }
    Period(ns):         100.000
    Sources:            { BUFR_inst2/O }
    Check Type        Corner  Lib Pin      Reference Pin  Required(ns)  Actual(ns)  Slack(ns)  Location  Pin
    Min Period        n/a     DSP48E1/CLK  n/a            2.772         100.000     97.228               i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/u_SDF1_7_1/u_MUL4/Complex4Multiply_mult1_re_pipe1_reg/CLK
    Low Pulse Width   Slow    RAMD32/CLK   n/a            0.768         50.000      49.232               i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/u_SDF1_7_1/u_SDFCOMMUTATOR_7/u_dataXMEM_im_0_7/ram_reg_0_7_0_5/RAMA/CLK
    High Pulse Width  Slow    RAMD32/CLK   n/a            0.768         50.000      49.232               i_system_wrapper/system_i/HDLRxIPCofinal_ip_0/U0/u_HDLRxIPCofinal_ip_dut_inst/u_HDLRxIPCofinal_ip_src_HDLRxIPCore/u_HDLRx/u_Channelizer/u_FFT_M_Point/u_FFT_HDL_Optimized1/u_SDF1_7_1/u_SDFCOMMUTATOR_7/u_dataXMEM_im_0_7/ram_reg_0_7_0_5/RAMA/CLK
    From Clock:  dac_clk_in_s
      To Clock:  dac_clk_in_s
    Setup :            0  Failing Endpoints,  Worst Slack       92.507ns,  Total Violation        0.000ns
    Hold  :         4179  Failing Endpoints,  Worst Slack       -0.043ns,  Total Violation      -86.647ns
    Max Delay Paths
    Slack (MET) :             92.507ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Product_Im_1_reg[0]__0/CLK
                                (rising edge-triggered cell DSP48E1 clocked by dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_7SERIES.NO_BMM_INFO.SDP.SIMPLE_PRIM18.ram/DIADI[13]
                                (rising edge-triggered cell RAMB18E1 clocked by dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Path Group:             dac_clk_in_s
      Path Type:              Setup (Max at Slow Process Corner)
      Requirement:            100.000ns  (dac_clk_in_s rise@100.000ns - dac_clk_in_s rise@0.000ns)
      Data Path Delay:        6.690ns  (logic 3.245ns (48.506%)  route 3.445ns (51.494%))
      Clock Path Skew:        -0.145ns (DCD - SCD + CPR)
        Total System Jitter     (TSJ):    0.071ns
        Discrete Jitter          (DJ):    0.000ns
        Phase Error              (PE):    0.000ns
                             (clock dac_clk_in_s rise edge)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.419     7.958    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.650     8.608 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.584     9.192    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.093     9.285 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.584     9.869    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/IPCORE_CLK
                             DSP48E1                                      r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Product_Im_1_reg[0]__0/CLK
                                                          0.348    10.217 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Product_Im_1_reg[0]__0/P[0]
                             net (fo=2, unplaced)         0.419    10.636    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Product_Im_1_reg[0]__0_n_105
                             LUT2 (Prop_lut2_I0_O)        0.043    10.679 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_570/O
                             net (fo=1, unplaced)         0.000    10.679    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_570_n_0
                                                          0.256    10.935 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_563/CO[3]
                             net (fo=1, unplaced)         0.007    10.942    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_563_n_0
                                                          0.054    10.996 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_558/CO[3]
                             net (fo=1, unplaced)         0.000    10.996    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_558_n_0
                                                          0.054    11.050 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_553/CO[3]
                             net (fo=1, unplaced)         0.000    11.050    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_553_n_0
                                                          0.157    11.207 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_548/O[3]
                             net (fo=2, unplaced)         0.302    11.509    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_548_n_4
                             LUT3 (Prop_lut3_I2_O)        0.120    11.629 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_542/O
                             net (fo=2, unplaced)         0.281    11.910    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_542_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    11.953 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_545/O
                             net (fo=1, unplaced)         0.000    11.953    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_545_n_0
                                                          0.256    12.209 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_516/CO[3]
                             net (fo=1, unplaced)         0.007    12.216    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_516_n_0
                                                          0.157    12.373 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_430/O[3]
                             net (fo=2, unplaced)         0.302    12.675    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_430_n_4
                             LUT3 (Prop_lut3_I1_O)        0.120    12.795 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_247/O
                             net (fo=2, unplaced)         0.281    13.076    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_247_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    13.119 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_251/O
                             net (fo=1, unplaced)         0.000    13.119    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_251_n_0
                                                          0.246    13.365 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_131/CO[3]
                             net (fo=1, unplaced)         0.000    13.365    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[0]_INST_0_i_131_n_0
                                                          0.157    13.522 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_PolyPhaseFIRFilter1/Imag_Out[4]_INST_0_i_55/O[3]
                             net (fo=2, unplaced)         0.302    13.824    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0_n_364
                             LUT3 (Prop_lut3_I0_O)        0.120    13.944 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_36/O
                             net (fo=2, unplaced)         0.281    14.225    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_36_n_0
                             LUT4 (Prop_lut4_I3_O)        0.043    14.268 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_40/O
                             net (fo=1, unplaced)         0.000    14.268    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_40_n_0
                                                          0.246    14.514 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_14/CO[3]
                             net (fo=1, unplaced)         0.000    14.514    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[4]_INST_0_i_14_n_0
                                                          0.157    14.671 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_14/O[3]
                             net (fo=3, unplaced)         0.309    14.980    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_14_n_4
                             LUT3 (Prop_lut3_I1_O)        0.120    15.100 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_16/O
                             net (fo=2, unplaced)         0.281    15.381    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_16_n_0
                             LUT5 (Prop_lut5_I1_O)        0.043    15.424 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_4/O
                             net (fo=2, unplaced)         0.253    15.677    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_4_n_0
                             LUT6 (Prop_lut6_I0_O)        0.043    15.720 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_8/O
                             net (fo=1, unplaced)         0.000    15.720    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_i_8_n_0
                                                          0.246    15.966 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0/CO[3]
                             net (fo=1, unplaced)         0.000    15.966    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[8]_INST_0_n_0
                                                          0.173    16.139 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/Imag_Out[12]_INST_0/O[1]
                             net (fo=3, unplaced)         0.419    16.559    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/din[13]
                             RAMB18E1                                     r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_7SERIES.NO_BMM_INFO.SDP.SIMPLE_PRIM18.ram/DIADI[13]
                                                        100.000   100.000 r
                             net (fo=9098, unplaced)      0.274   104.375    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.614   104.989 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.439   105.428    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.083   105.511 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.439   105.950    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/wr_clk
                             RAMB18E1                                     r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_7SERIES.NO_BMM_INFO.SDP.SIMPLE_PRIM18.ram/CLKARDCLK
                             RAMB18E1 (Setup_ramb18e1_CLKARDCLK_DIADI[13])
                                                         -0.623   109.066    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_Q/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gbm.gbmg.gbmga.ngecc.bmg/inst_blk_mem_gen/gnbram.gnativebmg.native_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_7SERIES.NO_BMM_INFO.SDP.SIMPLE_PRIM18.ram
                             required time                        109.066
                             arrival time                         -16.559
                             slack                                 92.507
    Min Delay Paths
    Slack (VIOLATED) :        -0.043ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/SDFCummutator_wrXData_im_reg_reg[2]/C
                                (rising edge-triggered cell FDRE clocked by dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/RAMB/I
                                (rising edge-triggered cell RAMD32 clocked by dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Requirement:            0.000ns  (dac_clk_in_s rise@0.000ns - dac_clk_in_s rise@0.000ns)
      Data Path Delay:        0.198ns  (logic 0.104ns (52.598%)  route 0.094ns (47.402%))
      Logic Levels:           0
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.074     2.817    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.223     3.040 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.114     3.154    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.026     3.180 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.114     3.294    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/IPCORE_CLK
                             FDRE                                         r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/SDFCummutator_wrXData_im_reg_reg[2]/C
                             FDRE (Prop_fdre_C_Q)         0.104     3.398 r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/SDFCummutator_wrXData_im_reg_reg[2]/Q
                             net (fo=1, unplaced)         0.094     3.492    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/DIB0
                             RAMD32                                       r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/RAMB/I
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.251     6.616 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.259     6.875    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.030     6.905 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.259     7.164    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/WCLK
                             RAMD32                                       r  i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/RAMB/CLK
                             RAMD32 (Hold_ramd32_CLK_I)
                                                          0.096     3.535    i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_1_1/u_SDFCOMMUTATOR_1/u_dataXMEM_im_0_1/ram_reg_0_7_0_5/RAMB
                             required time                         -3.535
                             arrival time                           3.492
                             slack                                 -0.043
    Pulse Width Checks
    Clock Name:         dac_clk_in_s
    Period(ns):         100.000
    Sources:            { BUFR_inst/O }
    Min Period        n/a     DSP48E1/CLK  n/a            2.772         100.000     97.228               i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_9_1/u_MUL4/Complex4Multiply_mult2_re_pipe1_reg/CLK
    Low Pulse Width   Slow    RAMD32/CLK   n/a            0.768         50.000      49.232               i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_9_1/u_SDFCOMMUTATOR_9/u_dataXMEM_im_0_9/ram_reg_0_7_0_5/RAMA/CLK
    High Pulse Width  Slow    RAMD32/CLK   n/a            0.768         50.000      49.232               i_system_wrapper/system_i/HDLTx_noaxi_int16IPC_0/U0/u_HDLTx_noaxi_int16IPCo_ip_dut_inst/u_HDLTx_noaxi_int16IPCo_ip_src_HDLTxIPCore/u_HDLTx/u_M_SynthesizerHDLOptimized2/u_IFFT_M_Point/u_IFFT_HDL_Optimized/u_SDF1_9_1/u_SDFCOMMUTATOR_9/u_dataXMEM_im_0_9/ram_reg_0_7_0_5/RAMA/CLK
    From Clock:  clk_out1_system_sys_audio_clkgen_0
      To Clock:  clk_fpga_0
    Setup :            0  Failing Endpoints,  Worst Slack        9.082ns,  Total Violation        0.000ns
    Hold  :           NA  Failing Endpoints,  Worst Slack           NA  ,  Total Violation           NA
    Max Delay Paths
    Slack (MET) :             9.082ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMB/CLK
                                (rising edge-triggered cell RAMD32 clocked by clk_out1_system_sys_audio_clkgen_0  {rise@0.000ns fall@40.690ns period=81.380ns})
      Destination:            i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/out_data_reg[2]/D
                                (rising edge-triggered cell FDRE clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Path Group:             clk_fpga_0
      Requirement:            10.000ns  (MaxDelay Path 10.000ns)
      Data Path Delay:        0.905ns  (logic 0.713ns (78.785%)  route 0.192ns (21.215%))
      Logic Levels:           0
      Timing Exception:       MaxDelay Path 10.000ns -datapath_only
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMB/CLK
                             RAMD32 (Prop_ramd32_CLK_O)
                                                          0.713     0.713 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/fifo_reg_0_3_0_4/RAMB/O
                             net (fo=1, unplaced)         0.192     0.905    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/out_data0__0[2]
                             FDRE                                         r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/out_data_reg[2]/D
                             max delay                   10.000    10.000
                             FDRE (Setup_fdre_C_D)       -0.013     9.987    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/rx_gen.rx_sync/out_data_reg[2]
                             required time                          9.987
                             arrival time                          -0.905
                             slack                                  9.082
    Setup :            0  Failing Endpoints,  Worst Slack        8.253ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             8.253ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/CLK
                                (rising edge-triggered cell RAMD32 clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]/S
                                (rising edge-triggered cell FDSE clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Data Path Delay:        1.445ns  (logic 0.739ns (51.142%)  route 0.706ns (48.858%))
      Logic Levels:           1  (LUT2=1)
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/CLK
                                                          0.696     0.696 f  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/O
                             net (fo=4, unplaced)         0.294     0.990    i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/dest_address_eot
                             LUT2 (Prop_lut2_I1_O)        0.043     1.033 r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length[3]_i_1/O
                             net (fo=4, unplaced)         0.412     1.445    i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length
                             FDSE                                         r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]/S
                             FDSE (Setup_fdse_C_S)       -0.302     9.698    i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]
                             required time                          9.698
                             arrival time                          -1.445
                             slack                                  8.253
    Setup :            0  Failing Endpoints,  Worst Slack        9.249ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             9.249ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo/cdc_sync_fifo_ram_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/req_eot_reg/D
      Data Path Delay:        0.794ns  (logic 0.360ns (45.340%)  route 0.434ns (54.660%))
      Logic Levels:           1  (LUT5=1)
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo/cdc_sync_fifo_ram_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo/cdc_sync_fifo_ram_reg[0]/Q
                             net (fo=1, unplaced)         0.434     0.667    i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo/i_waddr_sync/cdc_sync_fifo_ram
                             LUT5 (Prop_lut5_I0_O)        0.127     0.794 r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo/i_waddr_sync/req_eot_i_1/O
                             net (fo=1, unplaced)         0.000     0.794    i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/i_dest_response_fifo_n_5
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/req_eot_reg/D
                             FDRE (Setup_fdre_C_D)        0.043    10.043    i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_response_manager/req_eot_reg
                             required time                         10.043
                             arrival time                          -0.794
                             slack                                  9.249
    Max Delay Paths
      Source:                 i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/CLK
                                (rising edge-triggered cell RAMD32 clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]/S
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/CLK
                                                          0.696     0.696 f  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/eot_mem_dest_reg_r2_0_15_0_0/DP/O
                             net (fo=4, unplaced)         0.294     0.990    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/dest_address_eot
                             LUT2 (Prop_lut2_I1_O)        0.043     1.033 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length[3]_i_1/O
                             net (fo=4, unplaced)         0.412     1.445    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length
                             FDSE                                         r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]/S
                             FDSE (Setup_fdse_C_S)       -0.302     9.698    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_dest_dma_mm/i_addr_gen/length_reg[0]
                             required time                          9.698
                             arrival time                          -1.445
                             slack                                  8.253
    From Clock:  clk_fpga_0
      To Clock:  clk_out1_system_sys_audio_clkgen_0
    Setup :            0  Failing Endpoints,  Worst Slack       80.462ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             80.462ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/fifo_reg_0_3_0_4/RAMB/CLK
                                (rising edge-triggered cell RAMD32 clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Destination:            i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[2]/D
                                (rising edge-triggered cell FDRE clocked by clk_out1_system_sys_audio_clkgen_0  {rise@0.000ns fall@40.690ns period=81.380ns})
      Path Group:             clk_out1_system_sys_audio_clkgen_0
      Requirement:            81.380ns  (MaxDelay Path 81.380ns)
      Logic Levels:           0
      Timing Exception:       MaxDelay Path 81.380ns -datapath_only
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/fifo_reg_0_3_0_4/RAMB/CLK
                                                          0.713     0.713 r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/fifo_reg_0_3_0_4/RAMB/O
                             net (fo=1, unplaced)         0.192     0.905    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data0[2]
                             FDRE                                         r  i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[2]/D
                             max delay                   81.380    81.380
                             FDRE (Setup_fdre_C_D)       -0.013    81.367    i_system_wrapper/system_i/axi_i2s_adi/U0/ctrl/tx_sync/out_data_reg[2]
                             required time                         81.367
                             arrival time                          -0.905
                             slack                                 80.462
    Setup :            0  Failing Endpoints,  Worst Slack        9.426ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             9.426ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]/D
                                (rising edge-triggered cell FDRE clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Data Path Delay:        0.481ns  (logic 0.233ns (48.441%)  route 0.248ns (51.559%))
      Logic Levels:           0
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/Q
                             net (fo=19, unplaced)        0.248     0.481    i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/Q[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]/D
                             FDRE (Setup_fdre_C_D)       -0.093     9.907    i_system_wrapper/system_i/axi_adrv9001_rx1_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]
                             required time                          9.907
                             arrival time                          -0.481
                             slack                                  9.426
    From Clock:  adc_clk_div_s_1
      To Clock:  adc_clk_div_s
    Setup :            0  Failing Endpoints,  Worst Slack       45.481ns,  Total Violation        0.000ns
    Hold  :           34  Failing Endpoints,  Worst Slack       -3.402ns,  Total Violation     -115.289ns
    Max Delay Paths
    Slack (MET) :             45.481ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[38]/C
                                (rising edge-triggered cell FDCE clocked by adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_valid_in_d_reg/D
      Path Group:             adc_clk_div_s
      Requirement:            50.000ns  (adc_clk_div_s rise@50.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        0.956ns  (logic 0.356ns (37.238%)  route 0.600ns (62.761%))
      Logic Levels:           1  (LUT6=1)
      Clock Path Skew:        -3.570ns (DCD - SCD + CPR)
        Destination Clock Delay (DCD):    4.388ns = ( 54.388 - 50.000 )
        Source Clock Delay      (SCD):    7.958ns
        Clock Pessimism Removal (CPR):    0.000ns
      Clock Uncertainty:      0.035ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
        Total Input Jitter      (TIJ):    0.000ns
      Clock Domain Crossing:  Inter clock paths are considered valid unless explicitly excluded by timing constraints such as set_clock_groups or set_false_path.
                             (clock adc_clk_div_s_1 rise edge)
                                                          0.000     0.000 r
                             clock source latency         5.000     5.000
        M6                                                0.000     5.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000     5.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.857     5.857 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.354     6.211    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.650     6.861 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.584     7.445    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.093     7.538 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.419     7.958    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_xfer_toggle_reg_0
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[38]/C
                             FDCE (Prop_fdce_C_Q)         0.233     8.191 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[38]/Q
                             net (fo=35, unplaced)        0.600     8.791    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1_ctrl_sync/rx2_single_lane_loc
                             LUT6 (Prop_lut6_I0_O)        0.123     8.914 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1_ctrl_sync/adc_valid_in_d_i_1__0/O
                             net (fo=1, unplaced)         0.000     8.914    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_valid_B0
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_valid_in_d_reg/D
                             (clock adc_clk_div_s rise edge)
                                                         50.000    50.000 r
                             clock source latency         2.000    52.000
        J4                                                0.000    52.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000    52.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.768    52.768 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209    52.977    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614    53.591 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439    54.030    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083    54.113 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.274    54.388    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_clk_div
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_valid_in_d_reg/C
                             clock pessimism              0.000    54.388
                             clock uncertainty           -0.035    54.352
                             FDRE (Setup_fdre_C_D)        0.043    54.395    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_2/adc_valid_in_d_reg
                             required time                         54.395
                             arrival time                          -8.914
                             slack                                 45.481
    Min Delay Paths
    Slack (VIOLATED) :        -3.402ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_link/i_rx_pack_8_to_16_1/odata_reg[0]/C
                                (rising edge-triggered cell FDRE clocked by adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_data_in_d_reg[0]/D
      Requirement:            0.000ns  (adc_clk_div_s rise@0.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        0.263ns  (logic 0.168ns (63.947%)  route 0.095ns (36.053%))
      Clock Path Skew:        3.560ns (DCD - SCD - CPR)
        Destination Clock Delay (DCD):    6.378ns
        Source Clock Delay      (SCD):    2.817ns
        Clock Pessimism Removal (CPR):    -0.000ns
                                                          0.000     0.000 r
                             clock source latency         2.000     2.000
        M6                                                0.000     2.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000     2.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.341     2.341 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.040     2.381    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.223     2.604 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.114     2.718    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.026     2.744 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.074     2.817    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_link/i_rx_pack_8_to_16_1/CLK
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_link/i_rx_pack_8_to_16_1/odata_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.104     2.921 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_link/i_rx_pack_8_to_16_1/odata_reg[0]/Q
                             net (fo=1, unplaced)         0.095     3.016    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1_ctrl_sync/adc_data_in_d_reg[15]_1[0]
                             LUT5 (Prop_lut5_I4_O)        0.064     3.080 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1_ctrl_sync/adc_data_in_d[0]_i_1__0/O
                             net (fo=2, unplaced)         0.000     3.080    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_data_in_d_reg[15]_0[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_data_in_d_reg[0]/D
                                                          0.000     0.000 r
        J4                                                0.000     5.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000     5.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.434     5.434 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.185     5.619    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.251     5.870 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.259     6.129    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.030     6.159 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.219     6.378    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_clk_div
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_data_in_d_reg[0]/C
                             clock pessimism              0.000     6.378
                             clock uncertainty            0.035     6.413
                             FDRE (Hold_fdre_C_D)         0.069     6.482    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_rx_channel_3/adc_data_in_d_reg[0]
                             required time                         -6.482
                             arrival time                           3.080
                             slack                                 -3.402
      To Clock:  adc_clk_div_s_1
    Setup :            0  Failing Endpoints,  Worst Slack        9.432ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             9.432ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/src_id_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_dest_sync_id/cdc_sync_stage1_reg[0]/D
      Path Group:             adc_clk_div_s_1
      Data Path Delay:        0.475ns  (logic 0.233ns (49.053%)  route 0.242ns (50.947%))
      Logic Levels:           0
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/src_id_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/src_id_reg[0]/Q
                             net (fo=15, unplaced)        0.242     0.475    i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_dest_sync_id/cdc_sync_stage1_reg[3]_0[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_dest_sync_id/cdc_sync_stage1_reg[0]/D
                             FDRE (Setup_fdre_C_D)       -0.093     9.907    i_system_wrapper/system_i/axi_adrv9001_tx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_dest_sync_id/cdc_sync_stage1_reg[0]
                             required time                          9.907
                             arrival time                          -0.475
                             slack                                  9.432
    Setup :            0  Failing Endpoints,  Worst Slack       45.476ns,  Total Violation        0.000ns
    Hold  :           34  Failing Endpoints,  Worst Slack       -3.354ns,  Total Violation     -113.821ns
    Max Delay Paths
    Slack (MET) :             45.476ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/tdd_sync_cntr_reg/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/tdd_sync_d1_reg/D
      Requirement:            50.000ns  (adc_clk_div_s_1 rise@50.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        0.936ns  (logic 0.399ns (42.628%)  route 0.537ns (57.372%))
      Logic Levels:           2  (LUT2=2)
      Clock Path Skew:        -3.595ns (DCD - SCD + CPR)
        Destination Clock Delay (DCD):    4.375ns = ( 54.375 - 50.000 )
        Source Clock Delay      (SCD):    7.970ns
                                                          0.000     0.000 r
        J4                   IBUFDS (Prop_ibufds_I_O)     0.870     5.870 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.354     6.224    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.650     6.874 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.584     7.458    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.093     7.551 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.419     7.970    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/adc_clk_div
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/tdd_sync_cntr_reg/C
                             FDRE (Prop_fdre_C_Q)         0.233     8.203 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/tdd_sync_cntr_reg/Q
                             net (fo=1, unplaced)         0.267     8.470    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/tdd_sync_cntr1
                             LUT2 (Prop_lut2_I0_O)        0.123     8.593 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_1/tdd_sync_cntr_INST_0/O
                             net (fo=1, unplaced)         0.270     8.863    i_system_wrapper/tdd_sync_cntr
                             LUT2 (Prop_lut2_I1_O)        0.043     8.906 r  i_system_wrapper/system_i_i_34/O
                             net (fo=2, unplaced)         0.000     8.906    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/tdd_sync
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/tdd_sync_d1_reg/D
                                                         50.000    50.000 r
        M6                                                0.000    52.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000    52.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.756    52.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209    52.965    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614    53.579 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439    54.018    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083    54.101 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.274    54.375    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/out_reg[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/tdd_sync_d1_reg/C
                             clock pessimism              0.000    54.375
                             clock uncertainty           -0.035    54.340
                             FDRE (Setup_fdre_C_D)        0.043    54.383    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tdd_2/i_tdd_control/tdd_sync_d1_reg
                             required time                         54.383
                             arrival time                          -8.906
                             slack                                 45.476
    Min Delay Paths
    Slack (VIOLATED) :        -3.354ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/dac_data_iq_out_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/tx1_data_i_B_d_reg[0]/D
      Requirement:            0.000ns  (adc_clk_div_s_1 rise@0.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        0.203ns  (logic 0.104ns (51.186%)  route 0.099ns (48.814%))
      Logic Levels:           0
      Clock Path Skew:        3.535ns (DCD - SCD - CPR)
        Destination Clock Delay (DCD):    6.365ns
        Source Clock Delay      (SCD):    2.830ns
                                                          0.000     0.000 r
        J4                                                0.000     2.000 r  rx1_dclk_in_p (IN)
                             net (fo=0)                   0.000     2.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/rx1_dclk_in_p_dclk_in
        J4                   IBUFDS (Prop_ibufds_I_O)     0.353     2.353 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.040     2.393    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.223     2.616 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.114     2.730    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.026     2.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_1_phy/I_bufg/O
                             net (fo=12415, unplaced)     0.074     2.830    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/adc_clk_div
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/dac_data_iq_out_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.104     2.934 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/dac_data_iq_out_reg[0]/Q
                             net (fo=2, unplaced)         0.099     3.033    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/tx1_data_i_B[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/tx1_data_i_B_d_reg[0]/D
                                                          0.000     0.000 r
        M6                   IBUFDS (Prop_ibufds_I_O)     0.421     5.421 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.185     5.606    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.251     5.857 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.259     6.116    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.030     6.146 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.219     6.365    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/d_xfer_count_reg[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/tx1_data_i_B_d_reg[0]/C
                             clock pessimism              0.000     6.365
                             clock uncertainty            0.035     6.401
                             FDRE (Hold_fdre_C_D)        -0.013     6.388    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/tx1_data_i_B_d_reg[0]
                             required time                         -6.388
                             arrival time                           3.033
                             slack                                 -3.354
    From Clock:  adc_clk_in_s
    Setup :            0  Failing Endpoints,  Worst Slack       47.180ns,  Total Violation        0.000ns
    Hold  :            0  Failing Endpoints,  Worst Slack        0.637ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             47.180ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/overflow_reg/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data_reg[0]/D
      Requirement:            50.000ns  (adc_clk_div_s_1 rise@50.000ns - adc_clk_in_s rise@0.000ns)
      Data Path Delay:        0.772ns  (logic 0.356ns (46.114%)  route 0.416ns (53.886%))
      Clock Path Skew:        -2.056ns (DCD - SCD + CPR)
        Source Clock Delay      (SCD):    9.869ns
        Clock Pessimism Removal (CPR):    3.438ns
                             (clock adc_clk_in_s rise edge)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.419     7.958    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.650     8.608 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.584     9.192    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.093     9.285 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.584     9.869    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/fifo_wr_clk
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/overflow_reg/C
                             FDRE (Prop_fdre_C_Q)         0.233    10.102 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/overflow_reg/Q
                             net (fo=1, unplaced)         0.416    10.518    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/adc_2_dovf
                             LUT5 (Prop_lut5_I3_O)        0.123    10.641 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data[0]_i_1__2/O
                             net (fo=1, unplaced)         0.000    10.641    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data[0]
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data_reg[0]/D
                                                         50.000    50.000 r
                             net (fo=9098, unplaced)      0.274    54.375    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_xfer_state_reg_0
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data_reg[0]/C
                             clock pessimism              3.438    57.813
                             clock uncertainty           -0.035    57.778
                             FDCE (Setup_fdce_C_D)        0.043    57.821    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data_reg[0]
                             required time                         57.821
                             arrival time                         -10.641
                             slack                                 47.180
    Min Delay Paths
    Slack (MET) :             0.637ns  (arrival time - required time)
      Requirement:            0.000ns  (adc_clk_div_s_1 rise@0.000ns - adc_clk_in_s rise@0.000ns)
      Data Path Delay:        0.374ns  (logic 0.168ns (44.884%)  route 0.206ns (55.116%))
      Clock Path Skew:        -0.332ns (DCD - SCD - CPR)
        Clock Pessimism Removal (CPR):    3.403ns
                                                          0.000     0.000 r
                             net (fo=23764, unplaced)     0.114     3.294    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/fifo_wr_clk
                             FDRE (Prop_fdre_C_Q)         0.104     3.398 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_src_dma_fifo/overflow_reg/Q
                             net (fo=1, unplaced)         0.206     3.605    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/adc_2_dovf
                             LUT5 (Prop_lut5_I3_O)        0.064     3.669 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data[0]_i_1__2/O
                             net (fo=1, unplaced)         0.000     3.669    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data[0]
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_xfer_state_reg_0
                             clock pessimism             -3.403     2.962
                             FDCE (Hold_fdce_C_D)         0.069     3.031    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_status/d_acc_data_reg[0]
                             required time                         -3.031
                             arrival time                           3.669
                             slack                                  0.637
    Setup :            0  Failing Endpoints,  Worst Slack       99.485ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             99.485ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/C
      Destination:            i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
      Requirement:            100.000ns  (MaxDelay Path 100.000ns)
      Data Path Delay:        0.422ns  (logic 0.233ns (55.213%)  route 0.189ns (44.787%))
      Logic Levels:           0
      Timing Exception:       MaxDelay Path 100.000ns -datapath_only
                                                          0.000     0.000 r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/Q
                             net (fo=1, unplaced)         0.189     0.422    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/async_path[0]
                             FDRE                                         r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
                             max delay                  100.000   100.000
                             FDRE (Setup_fdre_C_D)       -0.093    99.907    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]
                             required time                         99.907
                             arrival time                          -0.422
                             slack                                 99.485
      To Clock:  adc_clk_in_s
    Max Delay Paths
      Source:                 i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]/D
      Path Group:             adc_clk_in_s
      Logic Levels:           0
                                                          0.000     0.000 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/dest_id_reg[0]/Q
                             net (fo=19, unplaced)        0.248     0.481    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/Q[0]
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]/D
                             FDRE (Setup_fdre_C_D)       -0.093     9.907    i_system_wrapper/system_i/axi_adrv9001_rx2_dma/inst/i_transfer/i_request_arb/i_store_and_forward/i_src_sync_id/cdc_sync_stage1_reg[0]
                             required time                          9.907
                             arrival time                          -0.481
                             slack                                  9.426
    Setup :            0  Failing Endpoints,  Worst Slack       49.485ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             49.485ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/C
      Destination:            i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
      Requirement:            50.000ns  (MaxDelay Path 50.000ns)
      Logic Levels:           0
      Timing Exception:       MaxDelay Path 50.000ns -datapath_only
                                                          0.000     0.000 r  i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/src_gray_ff_reg[0]/Q
                             net (fo=1, unplaced)         0.189     0.422    i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/async_path[0]
                             FDRE                                         r  i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
                             max delay                   50.000    50.000
                             FDRE (Setup_fdre_C_D)       -0.093    49.907    i_system_wrapper/system_i/FIFO_Delay_0/U0/FIFO_8192_16bit_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/wr_pntr_cdc_inst/dest_graysync_ff_reg[0][0]
                             required time                         49.907
                             arrival time                          -0.422
                             slack                                 49.485
    Max Delay Paths
      Source:                 i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/src_gray_ff_reg[0]/C
      Destination:            i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
      Logic Levels:           0
                                                          0.000     0.000 r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/src_gray_ff_reg[0]/C
                             FDRE (Prop_fdre_C_Q)         0.233     0.233 r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/src_gray_ff_reg[0]/Q
                             net (fo=1, unplaced)         0.189     0.422    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/async_path[0]
                             FDRE                                         r  i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/dest_graysync_ff_reg[0][0]/D
                             FDRE (Setup_fdre_C_D)       -0.093    49.907    i_system_wrapper/system_i/FIFO_Expander_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/rd_pntr_cdc_inst/dest_graysync_ff_reg[0][0]
                             arrival time                          -0.422
                             slack                                 49.485
    Path Group:  **async_default**
    Setup :            0  Failing Endpoints,  Worst Slack       48.491ns,  Total Violation        0.000ns
    Hold  :            0  Failing Endpoints,  Worst Slack        0.198ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             48.491ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                                (rising edge-triggered cell FDCE clocked by adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/CLR
                                (recovery check against rising-edge clock adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Path Type:              Recovery (Max at Slow Process Corner)
      Requirement:            50.000ns  (adc_clk_div_s rise@50.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        1.154ns  (logic 0.356ns (30.849%)  route 0.798ns (69.151%))
      Logic Levels:           1  (LUT1=1)
                                                          0.000     0.000 r
                             net (fo=12415, unplaced)     0.419     7.970    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/adc_clk_div
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                             FDCE (Prop_fdce_C_Q)         0.233     8.203 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/Q
                             net (fo=43, unplaced)        0.270     8.473    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/Q[0]
                             LUT1 (Prop_lut1_I0_O)        0.123     8.596 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/i_xfer_cntrl/dac_1_rst_INST_0/O
                             net (fo=591, unplaced)       0.528     9.124    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]_1
                             FDCE                                         f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/CLR
                                                         50.000    50.000 r
                             net (fo=12415, unplaced)     0.274    54.388    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/adc_clk_div
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                             clock pessimism              3.438    57.825
                             clock uncertainty           -0.035    57.790
                             FDCE (Recov_fdce_C_CLR)     -0.175    57.615    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_0/i_up_dac_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]
                             required time                         57.615
                             arrival time                          -9.124
                             slack                                 48.491
    Min Delay Paths
    Slack (MET) :             0.198ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_core_rst_reg/rst_reg/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/d_count_run_m1_reg/CLR
                                (removal check against rising-edge clock adc_clk_div_s  {rise@0.000ns fall@25.000ns period=50.000ns})
      Path Type:              Removal (Min at Fast Process Corner)
      Requirement:            0.000ns  (adc_clk_div_s rise@0.000ns - adc_clk_div_s rise@0.000ns)
      Data Path Delay:        0.239ns  (logic 0.104ns (43.535%)  route 0.135ns (56.465%))
      Logic Levels:           0
                                                          0.000     0.000 r
                             net (fo=12415, unplaced)     0.074     2.830    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_core_rst_reg/adc_clk_div
                             FDRE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_core_rst_reg/rst_reg/C
                             FDRE (Prop_fdre_C_Q)         0.104     2.934 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_core_rst_reg/rst_reg/Q
                             net (fo=23, unplaced)        0.135     3.069    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/AR[0]
                             FDCE                                         f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/d_count_run_m1_reg/CLR
                                                          0.000     0.000 r
                             net (fo=12415, unplaced)     0.219     6.378    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/adc_clk_div
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/d_count_run_m1_reg/C
                             clock pessimism             -3.403     2.975
                             FDCE (Remov_fdce_C_CLR)     -0.104     2.871    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx1/core_enabled.i_up_adc_common/i_clock_mon/d_count_run_m1_reg
                             required time                         -2.871
                             arrival time                           3.069
                             slack                                  0.198
    Setup :            0  Failing Endpoints,  Worst Slack       48.514ns,  Total Violation        0.000ns
    Hold  :            0  Failing Endpoints,  Worst Slack        0.178ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             48.514ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/CLR
                                (recovery check against rising-edge clock adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Requirement:            50.000ns  (adc_clk_div_s_1 rise@50.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        1.131ns  (logic 0.356ns (31.477%)  route 0.775ns (68.523%))
                                                          0.000     0.000 r
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                             FDCE (Prop_fdce_C_Q)         0.233     8.191 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]/Q
                             net (fo=17, unplaced)        0.247     8.438    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int_reg[0]_1
                             LUT1 (Prop_lut1_I0_O)        0.123     8.561 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_up_adc_common/i_xfer_cntrl/d_data_cntrl_int[72]_i_2/O
                             net (fo=574, unplaced)       0.528     9.089    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/AR[0]
                             FDCE                                         f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/CLR
                                                         50.000    50.000 r
                             net (fo=9098, unplaced)      0.274    54.375    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/d_xfer_toggle_reg_0
                             FDCE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]/C
                             FDCE (Recov_fdce_C_CLR)     -0.175    57.603    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_rx2/core_enabled.i_rx_channel_0/i_up_adc_channel/i_xfer_cntrl/d_data_cntrl_int_reg[0]
                             required time                         57.603
                             arrival time                          -9.089
                             slack                                 48.514
    Min Delay Paths
    Slack (MET) :             0.178ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/grstd1.grst_full.grst_f.rst_d2_reg/C
                                (rising edge-triggered cell FDPE clocked by adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Destination:            i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/ram_full_fb_i_reg/PRE
                                (removal check against rising-edge clock adc_clk_div_s_1  {rise@0.000ns fall@25.000ns period=50.000ns})
      Requirement:            0.000ns  (adc_clk_div_s_1 rise@0.000ns - adc_clk_div_s_1 rise@0.000ns)
      Data Path Delay:        0.217ns  (logic 0.104ns (48.021%)  route 0.113ns (51.979%))
      Logic Levels:           0
      Clock Path Skew:        0.145ns (DCD - SCD - CPR)
        Location             Delay type                Incr(ns)  Path(ns)    Netlist Resource(s)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.074     2.817    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/wr_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/grstd1.grst_full.grst_f.rst_d2_reg/C
                             FDPE (Prop_fdpe_C_Q)         0.104     2.921 f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/grstd1.grst_full.grst_f.rst_d2_reg/Q
                             net (fo=3, unplaced)         0.113     3.034    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/out
                             FDPE                                         f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/ram_full_fb_i_reg/PRE
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/wr_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/ram_full_fb_i_reg/C
                             FDPE (Remov_fdpe_C_PRE)     -0.106     2.856    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.wr/gwas.wsts/ram_full_fb_i_reg
                             required time                         -2.856
                             arrival time                           3.034
                             slack                                  0.178
    Setup :            0  Failing Endpoints,  Worst Slack       99.008ns,  Total Violation        0.000ns
    Hold  :            0  Failing Endpoints,  Worst Slack        0.176ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             99.008ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/C
                                (rising edge-triggered cell FDPE clocked by adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/PRE
                                (recovery check against rising-edge clock adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Requirement:            100.000ns  (adc_clk_in_s rise@100.000ns - adc_clk_in_s rise@0.000ns)
      Data Path Delay:        0.524ns  (logic 0.233ns (44.466%)  route 0.291ns (55.534%))
      Logic Levels:           0
      Clock Path Skew:        -0.145ns (DCD - SCD + CPR)
        Destination Clock Delay (DCD):    5.950ns = ( 105.950 - 100.000 )
        Clock Pessimism Removal (CPR):    3.774ns
        Total System Jitter     (TSJ):    0.071ns
        Discrete Jitter          (DJ):    0.000ns
        Phase Error              (PE):    0.000ns
                                                          0.000     0.000 r
                             net (fo=23764, unplaced)     0.584     9.869    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rd_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/C
                             FDPE (Prop_fdpe_C_Q)         0.233    10.102 f  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/Q
                             net (fo=50, unplaced)        0.291    10.393    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/AS[0]
                             FDPE                                         f  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/PRE
                                                        100.000   100.000 r
                             clock source latency         2.000   102.000
        M6                                                0.000   102.000 r  rx2_dclk_in_p (IN)
                             net (fo=0)                   0.000   102.000    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/rx2_dclk_in_p_dclk_in
        M6                   IBUFDS (Prop_ibufds_I_O)     0.756   102.756 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_clk_in_ibuf/O
                             net (fo=2, unplaced)         0.209   102.965    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/clk_in_s
                             BUFR (Prop_bufr_I_O)         0.614   103.579 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/i_div_clk_buf/O
                             net (fo=1, unplaced)         0.439   104.018    i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/adc_clk_div_s
                             BUFG (Prop_bufg_I_O)         0.083   104.101 r  i_system_wrapper/system_i/axi_adrv9001/inst/i_if/i_rx_2_phy/I_bufg/O
                             net (fo=9098, unplaced)      0.274   104.375    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.614   104.989 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.439   105.428    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.083   105.511 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.439   105.950    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/rd_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/C
                             clock pessimism              3.774   109.724
                             clock uncertainty           -0.035   109.689
                             FDPE (Recov_fdpe_C_PRE)     -0.288   109.401    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg
                             required time                        109.401
                             arrival time                         -10.393
                             slack                                 99.008
    Min Delay Paths
    Slack (MET) :             0.176ns  (arrival time - required time)
      Source:                 i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/C
      Destination:            i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/CLR
                                (removal check against rising-edge clock adc_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Requirement:            0.000ns  (adc_clk_in_s rise@0.000ns - adc_clk_in_s rise@0.000ns)
      Logic Levels:           0
        Destination Clock Delay (DCD):    7.164ns
        Source Clock Delay      (SCD):    3.294ns
        Clock Pessimism Removal (CPR):    3.725ns
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.074     2.817    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.223     3.040 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.114     3.154    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.026     3.180 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.114     3.294    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/dest_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/C
                             FDPE (Prop_fdpe_C_Q)         0.104     3.398 f  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/Q
                             net (fo=3, unplaced)         0.113     3.511    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rst_rd_reg2
                             FDCE                                         f  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/CLR
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    adc_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.251     6.616 r  BUFR_inst2/O
                             net (fo=1, unplaced)         0.259     6.875    adc_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.030     6.905 r  BUFG_inst2/O
                             net (fo=23764, unplaced)     0.259     7.164    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rd_clk
                             FDCE                                         r  i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/C
                             clock pessimism             -3.725     3.439
                             FDCE (Remov_fdce_C_CLR)     -0.104     3.335    i_system_wrapper/system_i/Streamer_Top_1/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]
                             required time                         -3.335
                             arrival time                           3.511
                             slack                                  0.176
    Setup :            0  Failing Endpoints,  Worst Slack        8.301ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             8.301ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/sys_rstgen/U0/ACTIVE_LOW_PR_OUT_DFF[0].FDRE_PER_N/C
      Destination:            i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/up_core_preset_reg/PRE
                                (recovery check against rising-edge clock clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Requirement:            10.000ns  (clk_fpga_0 rise@10.000ns - clk_fpga_0 rise@0.000ns)
      Data Path Delay:        1.192ns  (logic 0.356ns (29.866%)  route 0.836ns (70.134%))
        Destination Clock Delay (DCD):    0.756ns = ( 10.756 - 10.000 )
        Source Clock Delay      (SCD):    0.932ns
        Clock Pessimism Removal (CPR):    0.031ns
      Clock Uncertainty:      0.154ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
        Total Input Jitter      (TIJ):    0.300ns
                             (clock clk_fpga_0 rise edge)
                                                          0.000     0.000 r
        PS7_X0Y0             PS7                          0.000     0.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[0]
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.419     0.932    i_system_wrapper/system_i/sys_rstgen/U0/slowest_sync_clk
                             FDRE                                         r  i_system_wrapper/system_i/sys_rstgen/U0/ACTIVE_LOW_PR_OUT_DFF[0].FDRE_PER_N/C
                             FDRE (Prop_fdre_C_Q)         0.233     1.165 r  i_system_wrapper/system_i/sys_rstgen/U0/ACTIVE_LOW_PR_OUT_DFF[0].FDRE_PER_N/Q
                             net (fo=198, unplaced)       0.308     1.473    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/i_up_dac_channel/i_xfer_cntrl/s_axi_aresetn
                             LUT1 (Prop_lut1_I0_O)        0.123     1.596 f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_tx_channel_2/i_up_dac_channel/i_xfer_cntrl/up_axi_awready_int_i_1/O
                             net (fo=5494, unplaced)      0.528     2.124    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/up_xfer_toggle_m1_reg
                             FDPE                                         f  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/up_core_preset_reg/PRE
                                                         10.000    10.000 r
        PS7_X0Y0             PS7                          0.000    10.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[0]
                             net (fo=1, unplaced)         0.398    10.398    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.083    10.481 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.274    10.756    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/s_axi_aclk
                             FDPE                                         r  i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/up_core_preset_reg/C
                             clock pessimism              0.031    10.787
                             clock uncertainty           -0.154    10.633
                             FDPE (Recov_fdpe_C_PRE)     -0.208    10.425    i_system_wrapper/system_i/axi_adrv9001/inst/i_core/i_tx1/core_enabled.i_up_dac_common/up_core_preset_reg
                             required time                         10.425
                             arrival time                          -2.124
                             slack                                  8.301
    Min Delay Paths
      Source:                 i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/up_mmcm_preset_reg/C
                                (rising edge-triggered cell FDPE clocked by clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Destination:            i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/rst_async_d1_reg/PRE
                                (removal check against rising-edge clock clk_fpga_0  {rise@0.000ns fall@5.000ns period=10.000ns})
      Requirement:            0.000ns  (clk_fpga_0 rise@0.000ns - clk_fpga_0 rise@0.000ns)
      Logic Levels:           0
        Destination Clock Delay (DCD):    0.468ns
        Source Clock Delay      (SCD):    0.308ns
        Clock Pessimism Removal (CPR):    0.015ns
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.074     0.308    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/s_axi_aclk
                             FDPE                                         r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/up_mmcm_preset_reg/C
                             FDPE (Prop_fdpe_C_Q)         0.104     0.412 f  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/up_mmcm_preset_reg/Q
                             net (fo=3, unplaced)         0.113     0.525    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/up_mmcm_preset
                             FDPE                                         f  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/rst_async_d1_reg/PRE
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[0]
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_0.FCLK_CLK_0_BUFG/O
                             net (fo=21577, unplaced)     0.219     0.468    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/s_axi_aclk
                             FDPE                                         r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/rst_async_d1_reg/C
                             clock pessimism             -0.015     0.453
                             FDPE (Remov_fdpe_C_PRE)     -0.106     0.347    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_up_clkgen/i_mmcm_rst_reg/rst_async_d1_reg
                             required time                         -0.347
                             arrival time                           0.525
                             slack                                  0.178
    From Clock:  dac_clk_in_s
      To Clock:  dac_clk_in_s
    Max Delay Paths
      Source:                 i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/C
                                (rising edge-triggered cell FDPE clocked by dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Destination:            i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/PRE
                                (recovery check against rising-edge clock dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Requirement:            100.000ns  (dac_clk_in_s rise@100.000ns - dac_clk_in_s rise@0.000ns)
      Logic Levels:           0
                             (clock dac_clk_in_s rise edge)
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.419     7.958    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.650     8.608 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.584     9.192    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.093     9.285 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.584     9.869    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rd_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/C
                             FDPE (Prop_fdpe_C_Q)         0.233    10.102 f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.sckt_rd_rst_ic_reg/Q
                             net (fo=50, unplaced)        0.291    10.393    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/AS[0]
                             FDPE                                         f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/PRE
                                                        100.000   100.000 r
                             net (fo=9098, unplaced)      0.274   104.375    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.614   104.989 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.439   105.428    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.083   105.511 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.439   105.950    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/rd_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg/C
                             FDPE (Recov_fdpe_C_PRE)     -0.288   109.401    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft/aempty_fwft_fb_i_reg
                             slack                                 99.008
    Min Delay Paths
      Source:                 i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/C
      Destination:            i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/CLR
                                (removal check against rising-edge clock dac_clk_in_s  {rise@0.000ns fall@50.000ns period=100.000ns})
      Requirement:            0.000ns  (dac_clk_in_s rise@0.000ns - dac_clk_in_s rise@0.000ns)
      Logic Levels:           0
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.074     2.817    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.223     3.040 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.114     3.154    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.026     3.180 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.114     3.294    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/dest_clk
                             FDPE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/C
                             FDPE (Prop_fdpe_C_Q)         0.104     3.398 f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.rst_rd_reg2_inst/arststages_ff_reg[1]/Q
                             net (fo=3, unplaced)         0.113     3.511    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rst_rd_reg2
                             FDCE                                         f  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/CLR
                                                          0.000     0.000 r
                             net (fo=9098, unplaced)      0.219     6.365    dac_clk_out_s
                             BUFR (Prop_bufr_I_O)         0.251     6.616 r  BUFR_inst/O
                             net (fo=1, unplaced)         0.259     6.875    dac_clk_in_s
                             BUFG (Prop_bufg_I_O)         0.030     6.905 r  BUFG_inst/O
                             net (fo=100264, unplaced)    0.259     7.164    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/rd_clk
                             FDCE                                         r  i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]/C
                             FDCE (Remov_fdce_C_CLR)     -0.104     3.335    i_system_wrapper/system_i/Streamer_Top_0/U0/FIFO_Data_I/U0/inst_fifo_gen/gconvfifo.rf/grf.rf/rstblk/ngwrdrst.grst.g7serrst.gnsckt_wrst.gic_rst.wr_rst_rd_ext_reg[0]
                             arrival time                           3.511
                             slack                                  0.176
    From Clock:  mmcm_clk_0_s
      To Clock:  mmcm_clk_0_s
    Setup :            0  Failing Endpoints,  Worst Slack        5.623ns,  Total Violation        0.000ns
    Hold  :            0  Failing Endpoints,  Worst Slack        0.227ns,  Total Violation        0.000ns
    Max Delay Paths
    Slack (MET) :             5.623ns  (required time - arrival time)
      Source:                 i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/rst_reg/C
                                (rising edge-triggered cell FDRE clocked by mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Destination:            i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_fs_ret_toggle_m1_reg/CLR
                                (recovery check against rising-edge clock mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Requirement:            6.735ns  (mmcm_clk_0_s rise@6.735ns - mmcm_clk_0_s rise@0.000ns)
      Data Path Delay:        0.564ns  (logic 0.233ns (41.312%)  route 0.331ns (58.688%))
      Logic Levels:           0
        Destination Clock Delay (DCD):    0.920ns = ( 7.655 - 6.735 )
        Source Clock Delay      (SCD):    1.096ns
      Clock Uncertainty:      0.147ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
        Discrete Jitter          (DJ):    0.286ns
                             (clock mmcm_clk_0_s rise edge)
                                                          0.000     0.000 r
        PS7_X0Y0             PS7                          0.000     0.000 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.584     1.096    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                             MMCME2_ADV (Prop_mmcme2_adv_CLKIN1_CLKOUT0)
                                                         -1.096     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.419     0.419    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.093     0.512 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.584     1.096    i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/hdmi_clk
                             FDRE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/rst_reg/C
                             FDRE (Prop_fdre_C_Q)         0.233     1.329 f  i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/rst_reg/Q
                             net (fo=243, unplaced)       0.331     1.660    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_rst
                             FDCE                                         f  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_fs_ret_toggle_m1_reg/CLR
                                                          6.735     6.735 r
        PS7_X0Y0             PS7                          0.000     6.735 r  i_system_wrapper/system_i/sys_ps7/inst/PS7_i/FCLKCLK[1]
                             net (fo=1, unplaced)         0.398     7.133    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.083     7.216 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.439     7.655    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.920     6.735 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.398     7.133    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.083     7.216 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.439     7.655    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_clk
                             FDCE                                         r  i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_fs_ret_toggle_m1_reg/C
                             clock pessimism              0.031     7.686
                             clock uncertainty           -0.147     7.539
                             FDCE (Recov_fdce_C_CLR)     -0.255     7.284    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_fs_ret_toggle_m1_reg
                             required time                          7.284
                             arrival time                          -1.660
                             slack                                  5.623
    Min Delay Paths
    Slack (MET) :             0.227ns  (arrival time - required time)
                                (removal check against rising-edge clock mmcm_clk_0_s  {rise@0.000ns fall@3.367ns period=6.735ns})
      Requirement:            0.000ns  (mmcm_clk_0_s rise@0.000ns - mmcm_clk_0_s rise@0.000ns)
      Data Path Delay:        0.268ns  (logic 0.104ns (38.785%)  route 0.164ns (61.215%))
      Logic Levels:           0
        Destination Clock Delay (DCD):    0.508ns
        Source Clock Delay      (SCD):    0.348ns
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.114     0.348    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.348     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.208     0.208    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.026     0.234 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.114     0.348    i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/hdmi_clk
                             FDRE (Prop_fdre_C_Q)         0.104     0.452 f  i_system_wrapper/system_i/axi_hdmi_core/inst/i_up/i_core_rst_reg/rst_reg/Q
                             net (fo=243, unplaced)       0.164     0.616    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_rst
                                                          0.000     0.000 r
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/sys_ps7/inst/FCLK_CLK_unbuffered[1]
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/sys_ps7/inst/buffer_fclk_clk_1.FCLK_CLK_1_BUFG/O
                             net (fo=46, unplaced)        0.259     0.508    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/clk
                                                         -0.508     0.000 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_mmcm/CLKOUT0
                             net (fo=1, unplaced)         0.219     0.219    i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/mmcm_clk_0_s
                             BUFG (Prop_bufg_I_O)         0.030     0.249 r  i_system_wrapper/system_i/axi_hdmi_clkgen/inst/i_mmcm_drp/i_clk_0_bufg/O
                             net (fo=758, unplaced)       0.259     0.508    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_clk
                             clock pessimism             -0.015     0.493
                             FDCE (Remov_fdce_C_CLR)     -0.104     0.389    i_system_wrapper/system_i/axi_hdmi_core/inst/i_tx_core/hdmi_fs_ret_toggle_m1_reg
                             required time                         -0.389
                             arrival time                           0.616
                             slack                                  0.227
    report_timing_summary: Time (s): cpu = 00:00:17 ; elapsed = 00:00:12 . Memory (MB): peak = 8679.270 ; gain = 0.000
