Building the modified reference design
I am using HDL reference design 2018_r2 for ADRV9364_Z7020-BOB_LVDS. Now, to modify or customize the reference design I followed Analog Wiki: Integrate FIR Filters into the FMCOMMS2 HDL design. I am able to generate bitstream, hdf,  and new BOOT.bin as well by following Analog WIki: How to build the Zynq boot image BOOT.BIN.
Since, I am using 2021-07-28-ADI_KUIPER_FULL image in the sd card. I would like to know what should be my next steps to run the aforementioned modified program on my hardware. Do I need to re-build the devicetree and/or uImage? Or should I simply add the newly generated BOOT.bin in the boot partition of SD card? As when I copied this new BOOT.bin only in the boot partition of SD Card and and used existing devicetree.dtb and uImage, the "cfg done" blue LED on ADCR-BOB did not lit up.
Any help would be much appreciated.
Thanks!
DS
Top Replies
    Nov 24, 2021 +1 verified
    just generating a BOOT.bin and then copying it to the SD card is sufficient or not?
    I think it would be enough (from the HDL perspective) but regarding the software, as far as I know you h…
    on Nov 24, 2021 11:58 AM
    The first issue I see, is the mismatch between the versions: SD card image (2019_R2) and HDL (hdl_2018_r2). These should be  from the same release; either you pick an older version of the SD card image (which I do not recommend) or you pick hdl_2019_r2 branch for HDL.
    Iulia
  • Thanks for the prompt response. I will try with hdl_2019_r2 branch as well. But, can you also tell me if just generating a BOOT.bin and then copying it to the SD card is sufficient or not?
    Moreover, if I am only make small modifications in the design like simply adding an ILA core from Vivado, do I still need to create BOOT.bin every time to program the hardware?
    Thanks!
  • +1
    on Nov 24, 2021 1:06 PM
    I think it would be enough (from the HDL perspective) but regarding the software, as far as I know you have to modify the devicetree only if the new components added in HDL have an AXI interface. I believe it will require some edits, but just to make sure, you can ask about this on our Linux forum, and they will assist you with this part further.
    Yes, every time you modify something in the HDL.
    For now, I would try with the default devicetree.dtb and uImage, but let me know how it goes with hdl_2019_r2 and this version of the SD card.
