AD9082 + ZCU102 'HMC_STATUS' Red LED is On
I followed the steps in "AD9081/AD9082 Zynq UltraScale+ MPSoC ZCU102 Quick Start Guide": https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/quickstart/zynqmp to boot the ZCU102 board on Linux and use the AD9082 Evaluation Board.
The ZCU102 boots successfully. All other LEDs are on and green on the AD9082 Eval Board, but the HMC_STATUS LED  is on and red:
Running
iio_info | grep iio:device
 shows only:
And the IIO Oscilopce software on the ZCU102 cannot detect the AD9082 Eval board.
I followed the Start Guide steps using the pre-built SD card that came within the AD9082 package. I also did them again using a brand new SD card building the latest lease (2019_R2), but the HMC_STATUS led is always red. The start guide mentions some VXCO variations (100mhz and 122.88mhz) for the device tree file. I tried them both, but it didn't show any difference. I need some help to troubleshoot this problem.
Also, I am a bit confused about the board-specific files. The start guide says copying 3 files from
zynqmp-zcu102-rev10-ad9081-m8-l4
directory to the BOOT partition of the SD card. Is AD9082 using the same files as the AD9081?
  • Can you provide the full output from dmesg?
    -Travis
  • Hi Travis, here is the boot message (the .txt has the same information):
    Xilinx Zynq MP First Stage Boot Loader
    Release 2019.1   Feb 19 2021  -  15:58:23
    NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
    NOTICE:  BL31: Secure code at 0x0
    NOTICE:  BL31: Non secure code at 0x8000000
    NOTICE:  BL31: v2.0(release):xilinx-v2019.2
    NOTICE:  BL31: Built : 10:19:24, Jan 13 2020
    PMUFW:  v1.1
    U-Boot 2018.01-21436-gbba91bc203 (Jan 13 2020 - 10:50:58 +0200) Xilinx Zynq        MP ZCU102 rev1.0, Build: jenkins-development-build_uboot-1
    I2C:   ready
    DRAM:  4 GiB
    EL Level:       EL2
    Chip ID:        zu9eg
    MMC:   sdhci@ff170000: 0 (SD)
    *** Warning - bad CRC, using default environment
    In:    serial@ff000000
    Out:   serial@ff000000
    Err:   serial@ff000000
    Bootmode: LVL_SHFT_SD_MODE1
    Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
    Warning: ethernet@ff0e0000 using MAC address from ROM
    eth0: ethernet@ff0e0000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    Device: sdhci@ff170000
    Manufacturer ID: 3
    OEM: 5344
    Tran Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 14.8 GiB
    Bus Width: 4-bit
    Erase Group Size: 512 Bytes
    reading uEnv.txt
    433 bytes read in 16 ms (26.4 KiB/s)
    Loaded environment from uEnv.txt
    Importing environment from SD ...
    ## Error: Can't overwrite "ethaddr"
    himport_r: can't insert "ethaddr=00:0a:35:05:38:d3" into hash table
    Running uenvcmd ...
    Copying Linux from SD to RAM...
    ** No boot file defined **
    reading system.dtb
    44731 bytes read in 31 ms (1.4 MiB/s)
    reading Image
    29737472 bytes read in 1966 ms (14.4 MiB/s)
    ## Flattened Device Tree blob at 04000000
       Booting using the fdt blob at 0x4000000
       Loading Device Tree to 000000000fff2000, end 000000000ffffeba ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 4.19.0-ga6ef26d (jenkins@romlxbuild1.adlk.anal        og.com) (gcc version 8.2.0 (GCC)) #1105 SMP Fri Feb 19 16:51:27 GMT 2021
    [    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n        8')
    [    0.000000] bootconsole [cdns0] enabled
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.1
    [    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8        with crng_init=0
    [    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192        d29416 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Speculative Store Bypass Disable mitigation not required
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 10342        40
    [    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0        p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1 roo        t=/dev/mmcblk0p2 rw rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304        bytes)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 by        tes)
    [    0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB)
    [    0.000000] Memory: 3772348K/4194304K available (12796K kernel code, 152        0K rwdata, 13828K rodata, 832K init, 326K bss, 159812K reserved, 262144K cm        a-reserved)
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4        .
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cy        cles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
    [    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every        4398046511101ns
    [    0.008256] Console: colour dummy device 80x25
    [    0.012391] Calibrating delay loop (skipped), value calculated using tim        er frequency.. 199.98 BogoMIPS (lpj=399960)
    [    0.022757] pid_max: default: 32768 minimum: 301
    [    0.027451] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 b        ytes)
    [    0.041789] ASID allocator initialised with 32768 entries
    [    0.046507] rcu: Hierarchical SRCU implementation.
    [    0.051547] EFI services will not be available.
    [    0.055827] smp: Bringing up secondary CPUs ...
    [    0.060486] Detected VIPT I-cache on CPU1
    [    0.060516] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.060820] Detected VIPT I-cache on CPU2
    [    0.060840] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.061123] Detected VIPT I-cache on CPU3
    [    0.061141] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.061185] smp: Brought up 1 node, 4 CPUs
    [    0.095681] SMP: Total of 4 processors activated.
    [    0.100355] CPU features: detected: 32-bit EL0 Support
    [    0.106863] CPU: All CPU(s) started at EL2
    [    0.109534] alternatives: patching kernel code
    [    0.114847] devtmpfs: initialized
    [    0.122732] Registered cp15_barrier emulation handler
    [    0.122780] Registered setend emulation handler
    [    0.126849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xfffffff        f, max_idle_ns: 7645041785100000 ns
    [    0.136440] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.148132] xor: measuring software checksum speed
    [    0.186639]    8regs     :  2375.000 MB/sec
    [    0.226665]    8regs_prefetch:  2052.000 MB/sec
    [    0.266695]    32regs    :  2724.000 MB/sec
    [    0.306723]    32regs_prefetch:  2308.000 MB/sec
    [    0.306764] xor: using function: 32regs (2724.000 MB/sec)
    [    0.311068] pinctrl core: initialized pinctrl subsystem
    [    0.316855] NET: Registered protocol family 16
    [    0.321068] audit: initializing netlink subsys (disabled)
    [    0.326089] audit: type=2000 audit(0.272:1): state=initialized audit_ena        bled=0 res=1
    [    0.333728] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrv        al____))
    [    0.333733] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers        .
    [    0.348481] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.367473] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.436388] raid6: int64x1  gen()   444 MB/s
    [    0.504439] raid6: int64x1  xor()   451 MB/s
    [    0.572544] raid6: int64x2  gen()   679 MB/s
    [    0.640579] raid6: int64x2  xor()   600 MB/s
    [    0.708641] raid6: int64x4  gen()   981 MB/s
    [    0.776645] raid6: int64x4  xor()   737 MB/s
    [    0.844726] raid6: int64x8  gen()  1162 MB/s
    [    0.912756] raid6: int64x8  xor()   759 MB/s
    [    0.980826] raid6: neonx1   gen()   736 MB/s
    [    1.048877] raid6: neonx1   xor()   881 MB/s
    [    1.116936] raid6: neonx2   gen()  1129 MB/s
    [    1.184965] raid6: neonx2   xor()  1173 MB/s
    [    1.253025] raid6: neonx4   gen()  1479 MB/s
    [    1.321085] raid6: neonx4   xor()  1419 MB/s
    [    1.389127] raid6: neonx8   gen()  1552 MB/s
    [    1.457178] raid6: neonx8   xor()  1459 MB/s
    [    1.457216] raid6: using algorithm neonx8 gen() 1552 MB/s
    [    1.461168] raid6: .... xor() 1459 MB/s, rmw enabled
    [    1.466100] raid6: using neon recovery algorithm
    [    1.471396] SCSI subsystem initialized
    [    1.474570] usbcore: registered new interface driver usbfs
    [    1.479890] usbcore: registered new interface driver hub
    [    1.485162] usbcore: registered new device driver usb
    [    1.490306] media: Linux media interface: v0.10
    [    1.494669] videodev: Linux video capture interface: v2.00
    [    1.500151] pps_core: LinuxPPS API ver. 1 registered
    [    1.505029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo        Giometti <giometti@linux.it>
    [    1.514123] PTP clock support registered
    [    1.518020] EDAC MC: Ver: 3.0.0
    [    1.521493] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox        driver.
    [    1.528835] jesd204: created con: id=0, topo=0, link=0, /amba/spi@ff0500        00/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-tx@84b60000
    [    1.539468] jesd204: created con: id=1, topo=0, link=2, /amba/spi@ff0500        00/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
    [    1.550540] jesd204: created con: id=2, topo=0, link=0, /fpga-axi@0/axi-        adxcvr-tx@84b60000 <-> /fpga-axi@0/axi-jesd204-tx@84b90000
    [    1.562217] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-        adxcvr-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a90000
    [    1.573895] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-        jesd204-tx@84b90000 <-> /fpga-axi@0/axi-ad9081-tx-hpc@84b10000
    [    1.585919] jesd204: created con: id=5, topo=0, link=2, /fpga-axi@0/axi-        jesd204-rx@84a90000 <-> /fpga-axi@0/axi-ad9081-rx-hpc@84a10000
    [    1.597946] jesd204: created con: id=6, topo=0, link=2, /fpga-axi@0/axi-        ad9081-rx-hpc@84a10000 <-> /amba/spi@ff040000/ad9081@0
    [    1.609278] jesd204: created con: id=7, topo=0, link=0, /fpga-axi@0/axi-        ad9081-tx-hpc@84b10000 <-> /amba/spi@ff040000/ad9081@0
    [    1.620616] jesd204: /amba/spi@ff040000/ad9081@0: JESD204[2] transition        uninitialized -> initialized
    [    1.629693] jesd204: /amba/spi@ff040000/ad9081@0: JESD204[0] transition        uninitialized -> initialized
    [    1.638771] jesd204: found 8 devices and 1 topologies
    [    1.643824] FPGA manager framework
    [    1.647330] Advanced Linux Sound Architecture Driver Initialized.
    [    1.653492] Bluetooth: Core ver 2.22
    [    1.656778] NET: Registered protocol family 31
    [    1.661178] Bluetooth: HCI device and connection manager initialized
    [    1.667495] Bluetooth: HCI socket layer initialized
    [    1.672337] Bluetooth: L2CAP socket layer initialized
    [    1.677366] Bluetooth: SCO socket layer initialized
    [    1.682679] clocksource: Switched to clocksource arch_sys_counter
    [    1.688331] VFS: Disk quotas dquot_6.6.0
    [    1.692191] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 byte        s)
    [    1.703198] NET: Registered protocol family 2
    [    1.703645] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3,        32768 bytes)
    [    1.711136] TCP established hash table entries: 32768 (order: 6, 262144        bytes)
    [    1.718473] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [    1.725250] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.731396] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.737375] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.743861] NET: Registered protocol family 1
    [    1.748246] RPC: Registered named UNIX socket transport module.
    [    1.753918] RPC: Registered udp transport module.
    [    1.758586] RPC: Registered tcp transport module.
    [    1.763260] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.770419] hw perfevents: no interrupt-affinity property for /pmu, gues        sing.
    [    1.776897] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counte        rs available
    [    1.785282] Initialise system trusted keyrings
    [    1.788929] workingset: timestamp_bits=62 max_order=20 bucket_order=0
    [    1.795941] NFS: Registering the id_resolver key type
    [    1.800297] Key type id_resolver registered
    [    1.804436] Key type id_legacy registered
    [    1.808420] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.815088] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, I        nc.
    [    2.904063] NET: Registered protocol family 38
    [    2.961545] Key type asymmetric registered
    [    2.961583] Asymmetric key parser 'x509' registered
    [    2.964880] Block layer SCSI generic (bsg) driver version 0.4 loaded (ma        jor 246)
    [    2.972202] io scheduler noop registered
    [    2.976091] io scheduler deadline registered
    [    2.980352] io scheduler cfq registered (default)
    [    2.985003] io scheduler mq-deadline registered
    [    2.989500] io scheduler kyber registered
    [    3.021160] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    3.025248] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    3.032430] brd: module loaded
    [    3.036287] loop: module loaded
    [    3.036505] Registered mathworks_ip class
    [    3.038870] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    3.045938] libphy: Fixed MDIO Bus: probed
    [    3.049666] tun: Universal TUN/TAP device driver, 1.6
    [    3.053653] CAN device driver interface
    [    3.058264] usbcore: registered new interface driver asix
    [    3.062749] usbcore: registered new interface driver ax88179_178a
    [    3.068783] usbcore: registered new interface driver cdc_ether
    [    3.074580] usbcore: registered new interface driver net1080
    [    3.080201] usbcore: registered new interface driver cdc_subset
    [    3.086087] usbcore: registered new interface driver zaurus
    [    3.091629] usbcore: registered new interface driver cdc_ncm
    [    3.097905] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.103712] ehci-pci: EHCI PCI platform driver
    [    3.108376] usbcore: registered new interface driver uas
    [    3.113430] usbcore: registered new interface driver usb-storage
    [    3.119424] usbcore: registered new interface driver usbserial_generic
    [    3.125874] usbserial: USB Serial support registered for generic
    [    3.131849] usbcore: registered new interface driver ftdi_sio
    [    3.137552] usbserial: USB Serial support registered for FTDI USB Serial        Device
    [    3.144822] usbcore: registered new interface driver upd78f0730
    [    3.150700] usbserial: USB Serial support registered for upd78f0730
    [    3.158245] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc a        s rtc0
    [    3.164152] i2c /dev entries driver
    [    3.169519] usbcore: registered new interface driver uvcvideo
    [    3.173264] USB Video Class driver (1.1.1)
    [    3.178584] Bluetooth: HCI UART driver ver 2.3
    [    3.181748] Bluetooth: HCI UART protocol H4 registered
    [    3.186844] Bluetooth: HCI UART protocol BCSP registered
    [    3.192141] Bluetooth: HCI UART protocol LL registered
    [    3.197225] Bluetooth: HCI UART protocol ATH3K registered
    [    3.202605] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    3.208861] Bluetooth: HCI UART protocol Intel registered
    [    3.214198] Bluetooth: HCI UART protocol QCA registered
    [    3.219407] usbcore: registered new interface driver bcm203x
    [    3.225021] usbcore: registered new interface driver bpa10x
    [    3.230560] usbcore: registered new interface driver bfusb
    [    3.236009] usbcore: registered new interface driver btusb
    [    3.241431] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [    3.247097] usbcore: registered new interface driver ath3k
    [    3.252627] EDAC MC: ECC not enabled
    [    3.256229] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac co        ntroller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    3.268489] CPUidle arm: Failed to register cpuidle driver
    [    3.273782] sdhci: Secure Digital Host Controller Interface driver
    [    3.279755] sdhci: Copyright(c) Pierre Ossman
    [    3.284082] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.290082] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.295717] zynqmp_firmware_probe Platform Management API v1.1
    [    3.301471] zynqmp_firmware_probe Trustzone version v1.0
    [    3.309551] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinc        trl initialized
    [    3.336895] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_        wdt, ret = -22
    [    3.339602] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    3.344712] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    3.344712]
    [    3.352235] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    3.358360] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    3.363937] usbcore: registered new interface driver usbhid
    [    3.369268] usbhid: USB HID core driver
    [    3.380643] axi_sysid 85000000.axi-sysid-0: [ad9081_fmca_ebz] on [zcu102        ] git <7c86b9f84f75d6eaad0ef29a31e74b6f6f37c447> clean [2021-02-15 23:49:25        ] UTC
    [    3.388964] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    3.395538] usbcore: registered new interface driver snd-usb-audio
    [    3.402950] pktgen: Packet Generator for packet performance testing. Ver        sion: 2.75
    [    3.409078] Initializing XFRM netlink socket
    [    3.413009] NET: Registered protocol family 10
    [    3.417727] Segment Routing with IPv6
    [    3.421068] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.427213] NET: Registered protocol family 17
    [    3.431283] NET: Registered protocol family 15
    [    3.435700] bridge: filtering via arp/ip/ip6tables is no longer availabl        e by default. Update your scripts to load br_netfilter if you need this.
    [    3.448969] can: controller area network core (rev 20170425 abi 9)
    [    3.454751] NET: Registered protocol family 29
    [    3.459132] can: raw protocol (rev 20170425)
    [    3.463369] can: broadcast manager protocol (rev 20170425 t)
    [    3.468994] can: netlink gateway (rev 20170425) max_hops=1
    [    3.474506] Bluetooth: RFCOMM TTY layer initialized
    [    3.479294] Bluetooth: RFCOMM socket layer initialized
    [    3.484403] Bluetooth: RFCOMM ver 1.11
    [    3.488115] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    3.493387] Bluetooth: BNEP filters: protocol multicast
    [    3.498579] Bluetooth: BNEP socket layer initialized
    [    3.503508] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.509392] Bluetooth: HIDP socket layer initialized
    [    3.514423] 9pnet: Installing 9P2000 support
    [    3.518570] NET: Registered protocol family 36
    [    3.522987] Key type dns_resolver registered
    [    3.527766] registered taskstats version 1
    [    3.531284] Loading compiled-in X.509 certificates
    [    3.536359] Btrfs loaded, crc32c=crc32c-generic
    [    3.546986] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_b        aud = 6249999) is a xuartps
    [    3.556702] console [ttyPS0] enabled
    [    3.560303] bootconsole [cdns0] disabled
    [    3.568478] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 42, base_b        aud = 6249999) is a xuartps
    [    3.581763] of-fpga-region fpga-full: FPGA Region probed
    [    3.587599] nwl-pcie fd0e0000.pcie: Link is DOWN
    [    3.592245] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 rang        es:
    [    3.599214] nwl-pcie fd0e0000.pcie:   MEM 0xe0000000..0xefffffff -> 0xe0        000000
    [    3.606435] nwl-pcie fd0e0000.pcie:   MEM 0x600000000..0x7ffffffff -> 0x        600000000
    [    3.614017] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
    [    3.620193] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    3.625676] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xeffffff        f]
    [    3.632545] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7fffff        fff pref]
    [    3.644477] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
    [    3.650612] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    3.657194] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.664298] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.671402] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.678503] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.685614] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.692716] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.699820] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.706920] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe succ        ess
    [    3.714162] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 p        ll_locked:yes
    [    3.725540] zynqmp_clk_divider_set_rate() set divider failed for spi1_re        f_div1, ret = -13
    [    3.734219] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_co        dec0: Xilinx DisplayPort Sound Codec probed
    [    3.744985] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sou        nd PCM probed
    [    3.753065] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sou        nd PCM probed
    [    3.761504] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_car        d: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    3.773942] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_car        d: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    3.786640] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_car        d: Xilinx DisplayPort Sound Card probed
    [    3.796828] OF: graph: no port node found in /amba/zynqmp-display@fd4a00        00
    [    3.803846] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.810455] [drm] No driver support for vblank timestamp query.
    [    3.816451] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xff        ffff8008dc2e70)
    [    3.960766] Console: switching to colour frame buffer device 128x48
    [    3.980344] zynqmp-display fd4a0000.zynqmp-display: fb0:  frame buffer d        evice
    [    3.987704] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-di        splay on minor 0
    [    3.995808] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort S        ubsystem driver probed
    [    4.004849] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 p        ll_locked:yes
    [    4.012735] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 G        bps 0x3 impl platform mode
    [    4.021692] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only p        mp fbs pio slum part ccc sds apst
    [    4.032351] scsi host0: ahci-ceva
    [    4.035920] scsi host1: ahci-ceva
    [    4.039386] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] por        t 0x100 irq 37
    [    4.047300] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] por        t 0x180 irq 37
    [    4.106442] jesd204: /amba/spi@ff050000/hmc7044@0,jesd204:1,parent=spi2.        0: Using as SYSREF provider
    [    4.116094] m25p80 spi0.0: SPI-NOR-UniqueID 1044000af097001504001d005002        bfd1cd
    [    4.123317] m25p80 spi0.0: found n25q512a, expected m25p80
    [    4.129017] m25p80 spi0.0: n25q512a (131072 Kbytes)
    [    4.133915] 4 fixed-partitions partitions found on MTD device spi0.0
    [    4.140263] Creating 4 MTD partitions on "spi0.0":
    [    4.145056] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    4.151267] 0x000000100000-0x000000600000 : "qspi-linux"
    [    4.156975] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    4.163186] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    4.171058] macb ff0e0000.ethernet: Not enabling partial store and forwa        rd
    [    4.178417] libphy: MACB_mii_bus: probed
    [    4.182414] mdio_bus ff0e0000.ethernet-ffffffff: MDIO device at address        21 is missing.
    [    4.192622] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY drive        r [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
    [    4.205663] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0        xff0e0000 irq 22 (00:0a:35:05:38:d3)
    [    4.215803] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    4.222350] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    4.228854] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    4.235346] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    4.243184] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    4.249120] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 p        ll_locked:yes
    [    4.257396] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.262896] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned b        us number 1
    [    4.271481] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version        0x100 quirks 0x0000000202010810
    [    4.280897] xhci-hcd xhci-hcd.0.auto: irq 51, io mem 0xfe200000
    [    4.287028] usb usb1: New USB device found, idVendor=1d6b, idProduct=000        2, bcdDevice= 4.19
    [    4.295292] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNu        mber=1
    [    4.302506] usb usb1: Product: xHCI Host Controller
    [    4.307377] usb usb1: Manufacturer: Linux 4.19.0-ga6ef26d xhci-hcd
    [    4.313545] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    4.318713] hub 1-0:1.0: USB hub found
    [    4.322578] hub 1-0:1.0: 1 port detected
    [    4.326708] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.332198] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned b        us number 2
    [    4.339855] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
    [    4.346596] usb usb2: New USB device found, idVendor=1d6b, idProduct=000        3, bcdDevice= 4.19
    [    4.354856] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNu        mber=1
    [    4.362077] usb usb2: Product: xHCI Host Controller
    [    4.366952] usb usb2: Manufacturer: Linux 4.19.0-ga6ef26d xhci-hcd
    [    4.368872] ata1: SATA link down (SStatus 0 SControl 330)
    [    4.373128] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    4.378539] ata2: SATA link down (SStatus 0 SControl 330)
    [    4.383640] hub 2-0:1.0: USB hub found
    [    4.392982] hub 2-0:1.0: 1 port detected
    [    4.398188] pca953x 0-0020: 0-0020 supply vcc not found, using dummy reg        ulator
    [    4.405443] pca953x 0-0020: Linked as a consumer to regulator.0
    [    4.411429] random: fast init done
    [    4.415666] GPIO line 496 (sel0) hogged as output/low
    [    4.421044] GPIO line 497 (sel1) hogged as output/high
    [    4.426510] GPIO line 498 (sel2) hogged as output/high
    [    4.431979] GPIO line 499 (sel3) hogged as output/high
    [    4.437333] pca953x 0-0021: 0-0021 supply vcc not found, using dummy reg        ulator
    [    4.444577] pca953x 0-0021: Linked as a consumer to regulator.0
    [    4.452000] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.458817] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.465630] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.472444] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.479269] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.486083] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.492902] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.499714] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.506536] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.513350] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.519770] i2c i2c-0: Added multiplexed i2c bus 3
    [    4.525247] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
    [    4.532064] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.538884] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.545700] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.552510] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.559330] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.566137] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.572955] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.579358] i2c i2c-0: Added multiplexed i2c bus 4
    [    4.619220] i2c i2c-0: Added multiplexed i2c bus 5
    [    4.624212] i2c i2c-0: Added multiplexed i2c bus 6
    [    4.629006] pca954x 0-0075: registered 4 multiplexed busses for I2C mux        pca9544
    [    4.636364] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24
    [    4.644186] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
    [    4.650945] i2c i2c-1: Added multiplexed i2c bus 7
    [    4.656072] i2c i2c-1: Added multiplexed i2c bus 8
    [    4.662990] si570 9-005d: registered, current frequency 300000000 Hz
    [    4.669391] i2c i2c-1: Added multiplexed i2c bus 9
    [    4.688260] si570 10-005d: registered, current frequency 148500000 Hz
    [    4.694756] i2c i2c-1: Added multiplexed i2c bus 10
    [    4.699871] si5324 11-0069: si5328 probed
    [    4.762784] si5324 11-0069: si5328 probe successful
    [    4.767711] i2c i2c-1: Added multiplexed i2c bus 11
    [    4.772767] i2c i2c-1: Added multiplexed i2c bus 12
    [    4.777733] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci        -hcd
    [    4.784898] i2c i2c-1: Added multiplexed i2c bus 13
    [    4.789935] i2c i2c-1: Added multiplexed i2c bus 14
    [    4.794810] pca954x 1-0074: registered 8 multiplexed busses for I2C swit        ch pca9548
    [    4.803168] at24 15-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    [    4.809926] i2c i2c-1: Added multiplexed i2c bus 15
    [    4.814979] i2c i2c-1: Added multiplexed i2c bus 16
    [    4.820022] i2c i2c-1: Added multiplexed i2c bus 17
    [    4.825083] i2c i2c-1: Added multiplexed i2c bus 18
    [    4.830132] i2c i2c-1: Added multiplexed i2c bus 19
    [    4.835182] i2c i2c-1: Added multiplexed i2c bus 20
    [    4.840239] i2c i2c-1: Added multiplexed i2c bus 21
    [    4.845315] i2c i2c-1: Added multiplexed i2c bus 22
    [    4.850200] pca954x 1-0075: registered 8 multiplexed busses for I2C swit        ch pca9548
    [    4.857805] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25
    [    4.864192] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeo        ut 60s
    [    4.888701] usb 2-1: New USB device found, idVendor=2109, idProduct=0813        , bcdDevice=90.11
    [    4.896888] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNum        ber=0
    [    4.904023] usb 2-1: Product: USB3.0 Hub
    [    4.907942] usb 2-1: Manufacturer: VIA Labs, Inc.
    [    4.925328] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using        ADMA 64-bit
    [    4.941704] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) u        sing CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
    [    4.953669] axi_adxcvr 84b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) u        sing QPLL on GTH4 at 0x84B60000. Number of lanes: 4.
    [    4.986881] hub 2-1:1.0: USB hub found
    [    4.990708] hub 2-1:1.0: 4 ports detected
    [    5.064950] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
    [    5.072053] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
    [    5.080589]  mmcblk0: p1 p2 p3
    [    5.187063] ad9081 spi1.0: Unrecognized CHIP_ID 0x9082
    [    5.196415] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.203537] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-07        03:16:07 UTC (530167)
    [    5.212079] of_cfs_init
    [    5.214525] of_cfs_init: OK
    [    5.217455] cfg80211: Loading compiled-in X.509 certificates for regulat        ory database
    [    5.350692] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    5.357619] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.364146] clk: Not disabling unused clocks
    [    5.368415] ALSA device list:
    [    5.371378]   #0: DisplayPort monitor
    [    5.375369] platform regulatory.0: Direct firmware load for regulatory.d        b failed with error -2
    [    5.383983] cfg80211: failed to load regulatory.db
    [    5.504309] usb 1-1: New USB device found, idVendor=2109, idProduct=2813        , bcdDevice=90.11
    [    5.512499] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNum        ber=0
    [    5.519634] usb 1-1: Product: USB2.0 Hub
    [    5.523552] usb 1-1: Manufacturer: VIA Labs, Inc.
    [    5.562844] hub 1-1:1.0: USB hub found
    [    5.566782] hub 1-1:1.0: 4 ports detected
    [    5.573705] EXT4-fs (mmcblk0p2): recovery complete
    [    5.579689] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mo        de. Opts: (null)
    [    5.587802] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    5.599305] devtmpfs: mounted
    [    5.602437] Freeing unused kernel memory: 832K
    [    5.610718] Run /sbin/init as init process
    [    5.819517] systemd[1]: System time before build time, advancing clock.
    [    5.840832] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT        +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNU        TLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default        -hierarchy=hybrid)
    [    5.862590] systemd[1]: Detected architecture arm64.
    Welcome to Kuiper GNU/Linux 10 (buster)!
    [    5.883200] systemd[1]: Set hostname to <analog>.
    [    5.914744] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
    [    6.024488] systemd[1]: File /lib/systemd/system/systemd-journald.servic        e:12 configures an IP firewall (IPAddressDeny=any), but the local system do        es not support BPF/cgroup based firewalling.
    [    6.041536] systemd[1]: Proceeding WITHOUT firewalling in effect! (This        warning is only shown for the first loaded unit using IP firewalling.)
    [    6.082741] usb 1-1.1: New USB device found, idVendor=413c, idProduct=30        1a, bcdDevice= 1.00
    [    6.091109] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialN        umber=0
    [    6.098413] usb 1-1.1: Product: Dell MS116 USB Optical Mouse
    [    6.104068] usb 1-1.1: Manufacturer: PixArt
    [    6.173962] input: PixArt Dell MS116 USB Optical Mouse as /devices/platf        orm/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1        .0/0003:413C:301A.0001/input/input1
    [    6.190382] hid-generic 0003:413C:301A.0001: input: USB HID v1.11 Mouse        [PixArt Dell MS116 USB Optical Mouse] on usb-xhci-hcd.0.auto-1.1/input0
    [    6.223508] systemd[1]: /etc/systemd/system/tof-server.service:1: Assign        ment outside of section. Ignoring.
    [    6.233188] systemd[1]: /etc/systemd/system/tof-server.service:2: Assign        ment outside of section. Ignoring.
    [    6.334720] usb 1-1.2: new low-speed USB device number 4 using xhci-hcd
    [    6.388522] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.401408] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.412745] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    6.435047] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.441845] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    6.462774] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Listening on fsck to fsckd communication Socket.
    [    6.504781] usb 1-1.2: New USB device found, idVendor=413c, idProduct=21        13, bcdDevice= 1.08
    [    6.513130] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialN        umber=0
    [    6.520444] usb 1-1.2: Product: Dell KB216 Wired Keyboard
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.622498] input: Dell KB216 Wired Keyboard as /devices/platform/amba/f        f9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:41        3C:2113.0002/input/input2
    [  OK  ] Reached target Slices.
    [  OK  ] Listening on Journal Socket.
             Mounting POSIX Message Queue File System...
             Starting Set the console keyboard layout...
    [    6.699083] hid-generic 0003:413C:2113.0002: input: USB HID v1.11 Keyboa        rd [Dell KB216 Wired Keyboard] on usb-xhci-hcd.0.auto-1.2/input0
    [    6.717405] input: Dell KB216 Wired Keyboard System Control as /devices/        platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-        1.2:1.1/0003:413C:2113.0003/input/input3
             Starting Restore / save the current clock...
             Mounting Kernel Debug File System...
             Mounting Huge Pages File System...
             Starting Load Kernel Modules...
    [    6.790983] input: Dell KB216 Wired Keyboard Consumer Control as /device        s/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.2/        1-1.2:1.1/0003:413C:2113.0003/input/input4
    [    6.808092] hid-generic 0003:413C:2113.0003: input: USB HID v1.11 Device        [Dell KB216 Wired Keyboard] on usb-xhci-hcd.0.auto-1.2/input1
             Mounting RPC Pipe File System...
             Starting udev Coldplug all Devices...
    [  OK  ] Listening on Syslog Socket.
             Starting Journal Service...
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Started Restore / save the current clock.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Huge Pages File System.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Set the console keyboard layout.
    [  OK  ] Mounted RPC Pipe File System.
             Starting Apply Kernel Variables...
             Mounting Kernel Configuration File System...
             Starting Remount Root and Kernel File Systems...
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Starting Flush Journal to Persistent Storage...
             Starting Create System Users...
             Starting Load/Save Random Seed...
    [  OK  ] Started Create System Users.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started udev Coldplug all Devices.
             Starting Helper to synchronize boot up for ifupdown...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Started Helper to synchronize boot up for ifupdown.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Kernel Device Manager.
             Starting Show Plymouth Boot Screen...
    [  OK  ] Started Show Plymouth Boot Screen.
    [  OK  ] Reached target Local Encrypted Volumes.
    [  OK  ] Started Forward Password R…s to Plymouth Directory Watch.
    [   ***] (4 of 4) A start job is running for…tuuid/18f1f9d5-01 (11s / 1min        [  OK  ] Found device /dev/ttyS0.
    [  OK  ] Found device /dev/ttyPS0.
    [  OK  ] Found device /dev/disk/by-partuuid/18f1f9d5-01.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting File System Check…isk/by-partuuid/18f1f9d5-01...
    [***   ] (1 of 2) A start job is running for…rtuuid/18f1f9d5-01 (8s / no li        [**    ] (1 of 2) A start job is running for…rtuuid/18f1f9d5-01 (9s / no li        [*     ] (1 of 2) A start job is running for…rtuuid/18f1f9d5-01 (9s / no li        [  OK  ] Started File System Check …/disk/by-partuuid/18f1f9d5-01.
             Mounting /boot...
    [  OK  ] Started File System Check Daemon to report status.
    [  OK  ] Mounted /boot.
    [  OK  ] Reached target Local File Systems.
             Starting Tell Plymouth To Write Out Runtime Data...
             Starting Create Volatile Files and Directories...
             Starting Raise network interfaces...
             Starting Set console font and keymap...
             Starting Preprocess NFS configuration...
    [  OK  ] Started Set console font and keymap.
    [  OK  ] Started Preprocess NFS configuration.
    [  OK  ] Reached target NFS client services.
    [  OK  ] Reached target Remote File Systems (Pre).
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Started Tell Plymouth To Write Out Runtime Data.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Time Synchronization...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Raise network interfaces.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on triggerhappy.socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Started Daily man-db regeneration.
    [  OK  ] Listening on CUPS Scheduler.
    [  OK  ] Started Daily apt download activities.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
    [  OK  ] Reached target Sockets.
    [  OK  ] Started Daily apt upgrade and clean activities.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Started CUPS Scheduler.
    [  OK  ] Reached target Paths.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Regular background program processing daemon.
             Starting triggerhappy global hotkey daemon...
             Starting Check for Raspberry Pi EEPROM updates...
             Starting Login Service...
             Starting LSB: Switch to on…nless shift key is pressed)...
             Starting Disk Manager...
    [  OK  ] Started Manage Sound Card State (restore and store).
             Starting Save/Restore Sound Card State...
             Starting dhcpcd on all interfaces...
             Starting rng-tools.service...
             Starting System Logging Service...
    [  OK  ] Started tof-server.service.
             Starting dphys-swapfile - …unt, and delete a swap file...
             Starting Modem Manager...
    [  OK  ] Started D-Bus System Message Bus.
             Starting WPA supplicant...
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started triggerhappy global hotkey daemon.
    [  OK  ] Started Save/Restore Sound Card State.
    [FAILED] Failed to start rng-tools.service.
    See 'systemctl status rng-tools.service' for details.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Started Login Service.
    [  OK  ] Started System Logging Service.
    [FAILED] Failed to start Check for Raspberry Pi EEPROM updates.
    See 'systemctl status rpi-eeprom-update.service' for details.
    [  OK  ] Started dhcpcd on all interfaces.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started Make remote CUPS printers available locally.
    [  OK  ] Reached target Network.
             Starting /etc/rc.local Compatibility...
             Starting HTTP based time synchronization tool...
             Starting OpenBSD Secure Shell server...
    [  OK  ] Started IIO Daemon.
             Starting Permit User Sessions...
    [  OK  ] Started /etc/rc.local Compatibility.
             Starting Authorization Manager...
    [  OK  ] Started dphys-swapfile - s…mount, and delete a swap file.
    [  OK  ] Started HTTP based time synchronization tool.
    [  OK  ] Started Permit User Sessions.
             Starting Light Display Manager...
             Starting Hold until boot process finishes up...
    [  OK  ] Started OpenBSD Secure Shell server.
    [  OK  ] Started Authorization Manager.
    Raspbian GNU/Linux 10 analog ttyPS0
    analog login: root (automatic login)
    Last login: Wed Feb 24 03:08:25 GMT 2021 on ttyPS0
    Linux analog 4.19.0-ga6ef26d #1105 SMP Fri Feb 19 16:51:27 GMT 2021 aarch64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    root@analog:~#
    PMUFW: v1.1
    I2C: ready
    DRAM: 4 GiB
    EL Level: EL2
    Chip ID: zu9eg
    In: serial@ff000000
    Manufacturer ID: 3
    OEM: 5344
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 14.8 GiB
    Bus Width: 4-bit
    reading uEnv.txt
    Running uenvcmd ...
    reading system.dtb
    reading Image
    Starting kernel ...
    [ 3.344712]
    Mounting /boot...
    root@analog:~
    Jiachen
  • For AD9082 you need to use a different device tree and updated kernel since it was added post the 2019-R2 release. You will see the error in the log:
    The device tree you need is zynqmp-zcu102-rev10-ad9082-m4-l8.dtb built with these instructions: https://wiki.analog.com/resources/tools-software/linux-build/generic/zynqmp
    You will need the kernel from the build as well.
    Make sure you are using the master branch from github as the 2019-R2 branch does not contain this device tree and kernel updates.
    -Travis
  • It works! The device now shows up after using the new device tree and kernel.
    The HMC_STATUS LED is off now, but the IRQB0 LED is on and red. The device is shown as ad9081 instead of ad9082. The idle temperature is a bit high (~74°C) with the heatsink and fan. Do you know if they are normal?
    Jiachen
  • This is the startup message after using the new kernel and device tree:
    startup_newKernel.txt
  • [ 9.380428] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param L mismatch 4!=8*1
    [ 9.388949] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param M mismatch 8!=4*1
    [ 9.397465] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param F mismatch 4!=1
    [ 9.405808] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
    [ 9.415541] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param L mismatch 4!=8*1
    [ 9.424062] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param M mismatch 8!=4*1
    [ 9.432579] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param F mismatch 4!=1
    This indicates a mismatch between the devicetree and the HDL configuration being used.
    One is for 8 converters on 4 Lanes the other says 4 converter on 8 Lanes.
    -Michael
  • Hi Michael,
    What I missed was I didn't build a new BOOT.BIN which caused the mismatch between the device tree and HDL. 8M4L is for ad9081 and 4M8L is for ad9082. Then I followed the instruction here: https://wiki.analog.com/resources/tools-software/linux-build/generic/zynqmp
    t
    o build the HDL for AD9082+ZCU102, which is one of the parameters to build BOOT.BIN. For the u-boot.elf, the Xilinx Wiki page which shows how to build u-boot is not responding since last week, so I just used the u-boot.elf for AD9081+ZCU102 from the Quick Start Guide (https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/quickstart/zynqmp)
    Here is the boost message after using the newly built BOOT.BIN. The mismatch is gone but there are still some failures and errors.
    msg0713.txt
    The IRQB0 LED on board is still on and red and the IIO Oscilloscope software is not displaying any waveform.
    Jiachen
  • Tried on my side as well:
    root@analog:~# dmesg | grep -i -e ad908 -e jesd -e adxcvr
    [    2.614085] jesd204: created con: id=0, topo=0, link=0, /amba/spi@ff050000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-tx@84b60000
    [    2.624763] jesd204: created con: id=1, topo=0, link=2, /amba/spi@ff050000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
    [    2.635834] jesd204: created con: id=2, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84b60000 <-> /fpga-axi@0/axi-jesd204-tx@84b90000
    [    2.647511] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a90000
    [    2.659197] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84b90000 <-> /fpga-axi@0/axi-ad9081-tx-hpc@84b10000
    [    2.671214] jesd204: created con: id=5, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a90000 <-> /fpga-axi@0/axi-ad9081-rx-hpc@84a10000
    [    2.683241] jesd204: created con: id=6, topo=0, link=2, /fpga-axi@0/axi-ad9081-rx-hpc@84a10000 <-> /amba/spi@ff040000/ad9081@0
    [    2.694571] jesd204: created con: id=7, topo=0, link=0, /fpga-axi@0/axi-ad9081-tx-hpc@84b10000 <-> /amba/spi@ff040000/ad9081@0
    [    2.705911] jesd204: /amba/spi@ff040000/ad9081@0: JESD204[2] transition uninitialized -> initialized
    [    2.714984] jesd204: /amba/spi@ff040000/ad9081@0: JESD204[0] transition uninitialized -> initialized
    [    2.724065] jesd204: found 8 devices and 1 topologies
    [    3.312994] axi_sysid 85000000.axi-sysid-0: [ad9081_fmca_ebz] on [zcu102] git branch <master> git <6f4053f3b085e6be28ecdc6a5d4eeb16eb08d9a4> clean [2021-01-29 1
    3:06:20] UTC
    [    5.029637] jesd204: /amba/spi@ff050000/hmc7044@0,jesd204:1,parent=spi2.0: Using as SYSREF provider
    [    5.834634] axi_adxcvr 84a60000.axi-adxcvr-rx: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different
    instance
    [    5.851172] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84A60000. Number of lanes: 8.
    [    5.863269] axi_adxcvr 84b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84B60000. Number of lanes: 8.
    [    5.874937] axi-jesd204-rx 84a90000.axi-jesd204-rx: AXI-JESD204-RX (1.04.a) at 0x84A90000. Encoder 8b10b, width 4/0, lanes 8, jesd204-fsm.
    [    5.887721] axi-jesd204-tx 84b90000.axi-jesd204-tx: AXI-JESD204-TX (1.03.a) at 0x84B90000. Encoder 8b10b, width 4/0, lanes 8, jesd204-fsm.
    [    6.800308] ad9081 spi1.0: AD9081 Rev. 3 Grade 2 (API 1.1.0) probed
    [    6.831654] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: ADI AIM (10.01.b) at 0x84A10000 mapped to 0x(____ptrval____), probed ADC AD9081 as MASTER
    [    6.864433] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84B10000 mapped to 0x(____ptrval____), probed DDS AD9081
    [    6.878632] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    6.889236] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    6.899845] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.909841] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    6.919838] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.930268] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.940699] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.951563] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.962442] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.973568] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.984973] hmc7044 spi2.0: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode
    [    6.993891] hmc7044 spi2.0: hmc7044_jesd204_link_pre_setup: Link0 forcing continuous SYSREF mode
    [    7.002722] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    7.014283] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    7.025849] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    7.037493] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    7.049138] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.060871] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [    7.072603] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.084335] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [    7.097443] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [    7.108741] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [    7.124806] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [    7.136189] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [    7.152388] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [    7.164298] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [    7.176301] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [    7.188205] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [    7.200119] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [    7.212023] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [    7.223936] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [    7.235843] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [    7.252807] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    [    7.264455] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    [    7.276151] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
    [    7.287366] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
    [    7.320131] ad9081 spi1.0: JESD RX (JTX) Link2 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid
    [    7.330716] ad9081 spi1.0: JESD TX (JRX) Link0 0xFF lanes in DATA
    [    7.336804] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
    [    7.347930] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
    [    7.359055] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> opt_post_running_stage
    [    7.371135] jesd204: /amba/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> opt_post_running_stage
      (DEVICES) Found 2 JESD204 Link Layer peripherals
      (0): axi-jesd204-rx/84a90000.axi-jesd204-rx  [*]
      (1): axi-jesd204-tx/84b90000.axi-jesd204-tx
      (STATUS)
      Link is                      enabled
      Link Status                  DATA
      Measured Link Clock (MHz)    375.032
      Reported Link Clock (MHz)    375.000
      Measured Device Clock (MHz)  N/A
      Reported Device Clock (MHz)  N/A
      Desired Device Clock (MHz)   N/A
      Lane rate (MHz)              15000.000
      Lane rate / 40 (MHz)         375.000
      LMFC rate (MHz)              46.875
      SYSREF captured              Yes
      SYSREF alignment error       No
      SYNC~
      (LANE STATUS)
      Lane#                             0      1      2      3      4      5      6      7
      Errors                            0      0      0      0      0      0      0      0
      Latency (Multiframes/Octets)      3/20   3/20   3/20   3/18   3/18   3/17   3/20   3/17
      CGS State                         DATA   DATA   DATA   DATA   DATA   DATA   DATA   DATA
      Initial Frame Sync                Yes    Yes    Yes    Yes    Yes    Yes    Yes    Yes
      Initial Lane Alignment Sequence   Yes    Yes    Yes    Yes    Yes    Yes    Yes    Yes
    Can you try using my BOOT.BIN ?
    BOOT_zcu102_ad9082_fmca_ebz.zip
    -Michael
  • Your BOOT.BIN works! Before trying your BOOT.BIN, I built the u-boot.elf for zcu102 rev1.1 from this guide: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841973/Build+U-Boot. Using this u-boot.elf and the previous HDF, I got a new BOOT.BIN, but it was not functional at all after testing. Now I am just using your BOOT.BIN since yours worked. Thanks! May I know what is your procedure to build the BOOT.BIN? Which Vivado/PetaLinux version did you use? When you built the BOOT.BIN, did you specify it is for ZCU102 rev1.0 or rev1.1?
    I put the device tree file and Image file here as well in case other people need them:
    workedForZcu102Rev1p1-AD9082.zip
  • Sorry, I recently purchased zcu102 and ad9082. On the indicator lights, I also encountered that the hmc_status indicator light is red and the irqb0 light is not on. If I do not want to use the iio oscilloscope, will the abnormal indicator light affect my use? Thank you.
