ADRV9009-ZU11EG Multi-SOM: "Re-initialization due to lock-up" issues before "Unable to initialize"
I had a working multi-som system last Thursday, but today I'm seeing errors when trying to connect to the SOMs:
--Connecting to device(s)
Re-initializing due to lock-up
Exception in Tkinter callback
Traceback (most recent call last):
  File "/usr/lib/python3.8/tkinter/__init__.py", line 1892, in __call__
    return self.func(*args)
  File "./MultiSOM.py", line 120, in <lambda>
    TxApplyB = tk.Button(root, text='Apply', command= lambda: setTx(), width=9, bg='green')
  File "./MultiSOM.py", line 808, in setTx
    connectSOMs()
  File "./multiSOM.py", line 1182, in connectSOMs
    multi.rx()
  File "/usr/local/lib/python3.8/dist-packages/pyadi_iio-0.0.8-py3.8.egg/adi/adrv9009_zu11eg_multi.py", line 424, in rx
    self._pre_rx_setup()
  File "/usr/local/lib/python3.8/dist-packages/pyadi_iio-0.0.8-py3.8.egg/adi/adrv9009_zu11eg_multi.py", line 412, in _pre_rx_setup
    raise Exception("Unable to initialize (Board reboot required)")
Exception: Unable to initialize (Board reboot required)
I'm running my software on Ubuntu 20.04.2 LTS and as far as I know the system has been turned off except for the Ubuntu machine.
Is it possible an automatic update has broken something?
Are there any steps I can take to help troubleshoot the problem?
Top Replies
    on Jun 22, 2021 1:09 AM
    I highly doubt this unless auto-update changes the kernel and/or libiio.
    Can you provide the output of dmesg?
    -Travis
  • Thank you for getting back so fast Travis.
    The hardware had been moved for a demo.  Upon moving it again it appears to be working, so I think I have a hardware issue to track down instead of a software one.
  • One more follow-up.
    Upon bringing the hardware back outside, the problem returned.
    We believe we have narrowed it down to a thermal issue with the HMC7044 chips, both on the carrier boards and on the external HMC7044 Clock Board.
    We will be heat-sinking the parts and adding airflow to see if this solves the problem.
  • Reviving this issue because it isn't solved.  We think it may be thermal but are hoping you may be able to shed light on the failure based on dmesg data.
    More info:
    1.) We moved the working unit outside for a demo and couldn't connect to the SOMs.
    2.) Moved it back inside and it worked.
    3.) Outside again - failure. (Overcast day, ~85degrees F)
    4.) Cold spray on the hmc7044 chip on the carrier and on the external clock board yielded better connection successes.
    5.) Added heatsinks and fans to blow on hmc7044-ext and all hmc7044-ext chips.
    6.) Back outside, mostly connection successes, but (right before we had to abort due to rain) the connection issues returned.  The system was in the shade, with ~80degrees F.
    Here is dmesg of the failure when outside.  SOMs were powered on, then the script was run, and dmesg was collected from the Primary SOM once it failed out.
    [    3.389693] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    3.389868] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    3.397121] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    3.403326] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    3.408868] usbcore: registered new interface driver usbhid
    [    3.414189] usbhid: USB HID core driver
    [    3.423998] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    3.426350] axi_sysid 85000000.axi-sysid-0: [(null)] on [adrv9009zu11eg] git branch <master> git <0ad691a6035e4a28a2a9ee4d98c7e21aeb8b01f3> clean [2021-05-14 17:29:07] UTC
    [    3.441807] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    3.448155] usbcore: registered new interface driver snd-usb-audio
    [    3.455527] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    3.461962] Initializing XFRM netlink socket
    [    3.465785] NET: Registered protocol family 10
    [    3.470479] Segment Routing with IPv6
    [    3.473850] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.479927] NET: Registered protocol family 17
    [    3.484056] NET: Registered protocol family 15
    [    3.488468] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    3.501403] can: controller area network core (rev 20170425 abi 9)
    [    3.507517] NET: Registered protocol family 29
    [    3.511898] can: raw protocol (rev 20170425)
    [    3.516134] can: broadcast manager protocol (rev 20170425 t)
    [    3.521759] can: netlink gateway (rev 20190810) max_hops=1
    [    3.527281] Bluetooth: RFCOMM TTY layer initialized
    [    3.532057] Bluetooth: RFCOMM socket layer initialized
    [    3.537167] Bluetooth: RFCOMM ver 1.11
    [    3.540877] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    3.546151] Bluetooth: BNEP filters: protocol multicast
    [    3.551342] Bluetooth: BNEP socket layer initialized
    [    3.556270] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.562154] Bluetooth: HIDP socket layer initialized
    [    3.567205] 9pnet: Installing 9P2000 support
    [    3.571347] NET: Registered protocol family 36
    [    3.575751] Key type dns_resolver registered
    [    3.580236] registered taskstats version 1
    [    3.584043] Loading compiled-in X.509 certificates
    [    3.589146] Btrfs loaded, crc32c=crc32c-generic
    [    3.601165] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 23, base_baud = 6249999) is a xuartps
    [    3.610179] printk: console [ttyPS0] enabled
    [    3.614473] printk: bootconsole [cdns0] disabled
    [    3.623625] of-fpga-region fpga-full: FPGA Region probed
    [    3.634071] GPIO line 13 (ulpi-phy-reset) hogged as output/high
    [    3.641334] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    3.648031] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    3.657380] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    3.667488] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
    [    3.677542] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    3.685582] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    3.693628] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    3.704298] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    3.711272] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.717873] [drm] No driver support for vblank timestamp query.
    [    3.723844] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffffc010eddf20)
    [    4.811242] [drm] Cannot find any crtc or sizes
    [    4.815977] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    4.824070] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    4.833474] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.839233] adrv9009 spi1.1: adrv9009_probe : enter
    [    4.929180] random: fast init done
    [    4.948815] jesd204: /amba/spi@ff040000/hmc7044-ext@4,jesd204:4,parent=spi1.4: Using as SYSREF provider
    [    4.959123] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    4.966004] spi-nor: probe of spi0.0 failed with error -2
    [    4.973242] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    4.980601] libphy: MACB_mii_bus: probed
    [    4.985790] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
    [    4.999697] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 13 (52:4c:50:57:17:10)
    [    5.009769] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    5.016268] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    5.022726] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    5.029184] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    5.037018] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    5.042788] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
    [    5.052839] OF: graph: no port node found in /amba/zynqmp_phy@fd400000/lane1
    [    5.151315] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
    [    5.158048] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 15
    [    5.165201] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.395458] ad9545 4-004a: System PLL unlocked.
    [    5.400110] ad9545: probe of 4-004a failed with error -5
    [    5.405530] i2c i2c-1: Added multiplexed i2c bus 4
    [    5.410459] i2c i2c-1: Added multiplexed i2c bus 5
    [    5.446409] i2c i2c-1: Added multiplexed i2c bus 6
    [    5.482362] i2c i2c-1: Added multiplexed i2c bus 7
    [    5.517942] i2c i2c-1: Added multiplexed i2c bus 8
    [    5.522867] i2c i2c-1: Added multiplexed i2c bus 9
    [    5.527791] i2c i2c-1: Added multiplexed i2c bus 10
    [    5.532670] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
    [    5.540270] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 16
    [    5.546498] axi_fan_control_driver 80000000.axi-fan-control: Failed to initialize device
    [    5.554619] axi_fan_control_driver: probe of 80000000.axi-fan-control failed with error -22
    [    5.563347] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    5.570895] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333 KHz
    [    5.578296] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.587029] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
    [    5.595556] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.637173] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    5.648012] axi-i2s 82000000.axi-i2s-adi: probed, capture enabled, playback enabled
    [    5.655841] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.666614] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.672170] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.725435] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    5.732817] libphy: MACB_mii_bus: probed
    [    5.737247] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
    [    5.751148] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 12 (42:34:35:5e:a1:ca)
    [    5.763521] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A40000. Number of lanes: 4.
    [    5.776828] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
    [    5.789241] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.03.a) using QPLL on GTH4 at 0x84A20000. Number of lanes: 8.
    [    5.800860] axi-jesd204-rx 84a50000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A50000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.813641] axi-jesd204-rx 84a70000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A70000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.826363] axi-jesd204-tx 84a30000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A30000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
    [    5.839910] asoc-simple-card talise_sound: adau-hifi <-> 82000000.axi-i2s-adi mapping ok
    [    5.851889] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.862678] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.872710] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.903628] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x(____ptrval____), probed ADC ADRV9009-X2 as MASTER
    [    5.927770] mmc0: new high speed SDHC card at address 5048
    [    5.933641] mmcblk0: mmc0:5048 SD16G 14.4 GiB
    [    5.939148] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS ADRV9009-X2
    [    5.953969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    5.965093] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    5.976219] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    5.987352] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    5.997867] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    6.008378] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.018903] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.029852] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    6.040798] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.051758] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.063140] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    6.074521] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.085919] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.097558] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    6.109197] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.120882] [drm] Cannot find any crtc or sizes
    [    6.126513]  mmcblk0: p1 p2
    [    6.130122] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    6.142207] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    6.154284] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    6.199245] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    6.211408] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    6.223569] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    6.235737] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [    6.246768] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [    6.257800] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [    6.269215] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.280018] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.293276] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    6.300163] hctosys: unable to open rtc device (rtc0)
    [    6.305217] of_cfs_init
    [    6.307673] of_cfs_init: OK
    [    6.310655] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.318700] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.445090] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.451612] clk: Not disabling unused clocks
    [    6.455878] ALSA device list:
    [    6.458832]   #0: ADRV9009 ZU11EG ADAU1761
    [    6.463175] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.471786] cfg80211: failed to load regulatory.db
    [    6.486576] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.494677] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    6.502024] devtmpfs: mounted
    [    6.505153] Freeing unused kernel memory: 768K
    [    6.519278] Run /sbin/init as init process
    [    6.992188] udevd[168]: starting version 3.2.8
    [    7.004231] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.011628] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.019046] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.051436] udevd[169]: starting eudev-3.2.8
    [    7.598133] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    7.997086] pps pps0: new PPS source ptp0
    [    8.001150] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    8.064711] urandom_read: 5 callbacks suppressed
    [    8.064715] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.086516] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.843797] random: crng init done
    [   10.043997] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [   10.049675] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  105.003048] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [  105.014448] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [  105.025575] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [  105.036698] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [  105.047836] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.060081] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.072331] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.084600] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  105.096767] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  105.108934] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  105.121115] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  105.133194] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  105.145271] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  105.157363] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  105.169008] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  105.180657] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  105.192313] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  105.203694] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  105.215076] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  105.226472] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  105.237419] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  105.248370] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  107.854163] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  107.865119] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  107.876074] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  107.887082] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  107.897423] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  107.907769] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  107.918128] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  107.929075] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  107.940025] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  107.950991] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  107.962377] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  107.973762] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  107.985162] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  107.996807] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  108.008449] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  108.020600] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  108.032680] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  108.044757] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  108.091244] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  108.103409] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  108.115569] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  108.127739] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  108.138782] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  108.149819] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  109.835244] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  109.847502] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  109.859754] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  110.065755] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  110.078011] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  110.090267] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  113.848566] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  113.863793] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  113.879070] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  113.895508] adrv9009 spi1.1: ADIHAL_resetHw
    [  114.225438] adrv9009 spi1.0: ADIHAL_resetHw
    [  114.556482] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  114.568303] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  114.580127] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  114.780310] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  114.792218] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  114.804127] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  140.981516] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  140.993944] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  141.006373] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  141.215460] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  141.227890] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  141.240320] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  141.448910] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  141.461344] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  141.473775] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [  142.591412] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [  142.602798] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [  142.613927] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [  142.625049] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [  142.636183] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.648608] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.661031] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.673469] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.685900] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.698329] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.710759] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.723187] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.735613] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.748047] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.760471] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.772896] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.785342] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
    [  142.797245] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> link_setup
    [  142.809149] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
    [  142.821065] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [  142.832889] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [  142.844707] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [  142.856534] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.868786] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.881040] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.893300] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.905550] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.917802] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.930063] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  142.942228] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  142.954393] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  142.966569] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  142.978645] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  142.990723] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  143.002811] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  143.014455] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  143.026099] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  143.037758] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  143.049147] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  143.060529] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  143.071921] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  143.082872] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  143.093820] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  146.504238] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  146.515192] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  146.526147] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  146.537152] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  146.547497] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  146.557839] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  146.568193] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  146.579141] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  146.590091] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  146.601056] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  146.612442] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  146.623827] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  146.635234] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  146.646872] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  146.658516] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  146.670635] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  146.682719] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  146.694794] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  146.739243] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  146.751409] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  146.763577] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  146.775747] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  146.786781] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  146.797821] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  148.483242] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.495501] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.507754] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.712883] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  148.725141] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  148.737398] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  152.494181] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  152.509403] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  152.524612] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  152.540924] adrv9009 spi1.1: ADIHAL_resetHw
    [  152.871165] adrv9009 spi1.0: ADIHAL_resetHw
    [  153.201988] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  153.213804] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  153.225624] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  153.425382] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  153.437293] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  153.449201] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  179.497114] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  179.509545] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  179.521974] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  179.730796] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.743231] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.755663] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.964169] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  179.976597] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  179.989026] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [  181.106567] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [  181.117958] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [  181.129083] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [  181.140208] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [  181.151344] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
    [  181.163767] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> opt_setup_stage4
    [  181.176192] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
    [  181.188629] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
    [  181.201057] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage3
    [  181.213481] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
    [  181.225918] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
    [  181.238349] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage2
    [  181.250777] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
    [  181.263208] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
    [  181.275636] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage1
    [  181.288060] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
    [  181.300506] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
    [  181.312409] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> link_setup
    [  181.324313] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
    [  181.336228] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [  181.348044] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [  181.359863] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [  181.371691] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [  181.383941] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [  181.396194] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [  181.408452] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  181.420709] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  181.432963] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  181.445221] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  181.457389] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  181.469552] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  181.481730] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  181.493812] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  181.505893] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  181.517979] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  181.529624] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  181.541266] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  181.552927] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  181.564314] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  181.575698] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  181.587089] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  181.598039] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  181.608989] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  185.018601] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  185.029553] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  185.040508] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  185.051513] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  185.061859] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  185.072201] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  185.082552] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  185.093503] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  185.104451] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  185.115416] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  185.126803] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  185.138188] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  185.149588] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  185.161234] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  185.172878] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  185.185004] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  185.197090] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  185.209166] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  185.255243] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  185.267410] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  185.279579] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  185.291749] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  185.302783] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  185.313821] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  186.999242] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  187.011494] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  187.023749] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  187.228942] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  187.241195] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  187.253452] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  191.030639] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  191.045868] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  191.061083] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  191.077444] adrv9009 spi1.1: ADIHAL_resetHw
    [  191.407643] adrv9009 spi1.0: ADIHAL_resetHw
    [  191.738637] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  191.750453] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  191.762269] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  191.962020] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  191.973927] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  191.985835] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  219.224526] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  219.236958] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  219.249386] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  219.458502] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.470931] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.483362] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.692117] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  219.704550] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  219.716979] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    Secondary SOM once it failed out:
    [    5.649920] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    5.661046] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    5.671558] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    5.682069] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    5.692591] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    5.703535] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    5.714479] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    5.725437] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    5.736814] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    5.748194] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    5.759590] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    5.771232] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    5.782871] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    5.795126] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    5.807221] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    5.819293] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    5.831391]  mmcblk0: p1 p2
    [    5.857183] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    5.869354] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    5.881520] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    5.893686] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [    5.904725] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [    5.915764] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [    5.927182] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.938015] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.951296] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    5.958193] hctosys: unable to open rtc device (rtc0)
    [    5.963242] of_cfs_init
    [    5.965695] of_cfs_init: OK
    [    5.968672] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.976759] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.045188] [drm] Cannot find any crtc or sizes
    [    6.103246] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.109766] clk: Not disabling unused clocks
    [    6.114032] ALSA device list:
    [    6.116985]   #0: ADRV9009 ZU11EG ADAU1761
    [    6.121331] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.129939] cfg80211: failed to load regulatory.db
    [    6.144807] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.152914] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    6.160333] devtmpfs: mounted
    [    6.163467] Freeing unused kernel memory: 768K
    [    6.181218] Run /sbin/init as init process
    [    6.650691] udevd[168]: starting version 3.2.8
    [    6.662411] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.669762] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.677117] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.710202] udevd[169]: starting eudev-3.2.8
    [    7.304096] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    7.705622] pps pps0: new PPS source ptp0
    [    7.709643] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    7.772954] urandom_read: 5 callbacks suppressed
    [    7.772958] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    7.795242] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.556667] random: crng init done
    [   10.781932] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [   10.787611] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  105.161036] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [  105.172433] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [  105.183557] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [  105.194683] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [  105.205817] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.218065] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.230315] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  105.242579] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  105.254744] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  105.266909] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  105.279079] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  105.291153] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  105.303229] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  105.315318] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  105.326959] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  105.338606] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  105.350260] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  105.361644] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  105.373023] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  105.384418] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  105.395366] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  105.406322] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  108.062494] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  108.073445] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  108.084397] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  108.095382] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  108.105723] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  108.116070] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  108.126416] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  108.137361] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  108.148310] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  108.159271] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  108.170654] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  108.182038] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  108.193436] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  108.205079] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  108.216723] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  108.228595] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  108.240676] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  108.252755] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  108.285183] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  108.297346] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  108.309515] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  108.321683] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  108.332718] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  108.343757] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  109.538481] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  109.550736] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  109.562988] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  109.777222] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  109.789482] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  109.801734] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  110.007542] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  110.022761] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  110.038035] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  110.054412] adrv9009 spi1.1: ADIHAL_resetHw
    [  110.384425] adrv9009 spi1.0: ADIHAL_resetHw
    [  110.715434] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  110.727250] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  110.739074] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  114.497388] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  114.509296] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  114.521202] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  118.875793] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  118.888226] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  118.900656] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  140.924243] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  140.936674] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  140.949099] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  141.157688] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  141.170115] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  141.182544] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [  141.891121] adrv9009 spi1.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
    [  141.904242] adrv9009 spi1.1: ERROR: 131086: Talise init calibration error encountered
    [  141.912069] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:5957 (ret 6)
    [  141.918682] jesd204: /amba/spi@ff040000/adrv9009-phy-b@1,jesd204:1,parent=spi1.1: JESD204[1] got error from cb: -14
    [  141.929119] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'opt_setup_stage4', got error -14
    [  141.940941] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [  141.953370] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [  141.965795] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [  141.978219] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state opt_setup_stage4
    [  141.989691] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state opt_setup_stage4
    [  142.001160] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state opt_setup_stage4
    [  142.012639] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.025065] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.037494] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
    [  142.049930] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.062352] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.074778] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
    [  142.087211] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.099636] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.112063] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
    [  142.124493] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.136914] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.149340] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
    [  142.161779] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
    [  142.173686] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> link_setup
    [  142.185592] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
    [  142.197502] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [  142.209315] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [  142.221131] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [  142.232958] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.245212] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.257463] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [  142.269719] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.281967] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.294217] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  142.306478] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  142.318643] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  142.330813] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  142.342989] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  142.355063] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  142.367136] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  142.379219] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  142.390859] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  142.402500] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  142.414158] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  142.425547] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  142.436932] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  142.448320] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  142.459266] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  142.470215] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  142.481169] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -14
    [  143.006091] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  143.017045] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  143.027999] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  146.709962] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  146.720915] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  146.731868] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  146.742849] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  146.753195] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  146.763539] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  146.773885] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  146.784833] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  146.795780] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  146.806745] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  146.818133] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  146.829517] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  146.840915] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  146.852554] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  146.864196] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  146.876064] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  146.888150] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  146.900226] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  146.933182] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  146.945346] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  146.957514] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  146.969683] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  146.980719] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  146.991755] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  148.185000] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.197265] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.209516] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  148.424624] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  148.436884] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  148.449140] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  148.654135] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  148.669355] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  148.684565] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  148.700865] adrv9009 spi1.1: ADIHAL_resetHw
    [  149.031278] adrv9009 spi1.0: ADIHAL_resetHw
    [  149.362658] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  149.374476] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  149.386290] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  153.142267] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  153.154178] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  153.166085] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  157.473193] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  157.485618] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  157.498040] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  179.439295] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.451729] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.464158] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  179.672589] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  179.685023] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  179.697453] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [  180.405854] adrv9009 spi1.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
    [  180.418976] adrv9009 spi1.1: ERROR: 131086: Talise init calibration error encountered
    [  180.426804] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:5957 (ret 6)
    [  180.433415] jesd204: /amba/spi@ff040000/adrv9009-phy-b@1,jesd204:1,parent=spi1.1: JESD204[1] got error from cb: -14
    [  180.443844] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'opt_setup_stage4', got error -14
    [  180.455667] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [  180.468092] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [  180.480521] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [  180.492945] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state opt_setup_stage4
    [  180.504417] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state opt_setup_stage4
    [  180.515886] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state opt_setup_stage4
    [  180.527365] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
    [  180.539791] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> opt_setup_stage4
    [  180.552218] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
    [  180.564647] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
    [  180.577069] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage3
    [  180.589496] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
    [  180.601928] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
    [  180.614354] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage2
    [  180.626780] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
    [  180.639210] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
    [  180.651631] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage1
    [  180.664055] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
    [  180.676496] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
    [  180.688403] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> link_setup
    [  180.700309] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
    [  180.712219] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [  180.724032] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [  180.735848] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [  180.747675] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [  180.759927] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [  180.772180] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [  180.784436] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  180.796684] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  180.808935] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  180.821196] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  180.833360] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  180.845529] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  180.857706] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  180.869779] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  180.881856] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  180.893945] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  180.905588] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  180.917233] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  180.928886] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  180.940270] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  180.951653] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  180.963044] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  180.973995] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  180.984947] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  180.995892] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -14
    [  181.520773] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  181.531727] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  181.542679] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  185.225527] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  185.236482] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  185.247436] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  185.258416] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [  185.268764] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [  185.279107] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [  185.289454] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [  185.300401] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [  185.311349] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [  185.322309] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [  185.333691] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [  185.345077] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [  185.356473] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [  185.368113] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [  185.379756] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [  185.391663] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [  185.403750] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [  185.415827] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [  185.449182] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [  185.461347] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [  185.473511] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [  185.485677] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [  185.496712] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [  185.507749] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [  186.700537] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [  186.712795] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [  186.725050] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [  186.940220] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [  186.952478] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [  186.964733] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [  187.169722] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [  187.184940] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [  187.200155] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [  187.216459] adrv9009 spi1.1: ADIHAL_resetHw
    [  187.555784] adrv9009 spi1.0: ADIHAL_resetHw
    [  187.895704] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [  187.907526] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [  187.919347] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [  191.678536] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [  191.690441] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [  191.702350] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [  197.124611] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [  197.137037] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [  197.149472] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [  219.166271] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.178707] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.191132] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [  219.399918] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [  219.412347] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [  219.424777] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [  220.133464] adrv9009 spi1.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
    [  220.146585] adrv9009 spi1.1: ERROR: 131086: Talise init calibration error encountered
    [  220.154415] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:5957 (ret 6)
    [  220.161026] jesd204: /amba/spi@ff040000/adrv9009-phy-b@1,jesd204:1,parent=spi1.1: JESD204[1] got error from cb: -14
    [  220.171456] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'opt_setup_stage4', got error -14
    [  220.183279] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [  220.195706] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [  220.208132] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [  220.220556] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state opt_setup_stage4
    [  220.232029] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state opt_setup_stage4
    [  220.243495] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state opt_setup_stage4
    [  220.254969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
    [  220.267393] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> opt_setup_stage4
    [  220.279815] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
    [  220.292249] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
    [  220.304675] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage3
    [  220.317103] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
    [  220.329535] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
    [  220.341962] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage2
    [  220.354385] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
    [  220.366821] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
    [  220.379247] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage1
    [  220.391673] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
    [  220.404109] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
    [  220.416012] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> link_setup
    [  220.427915] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
    [  220.439831] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
    [  220.451643] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> clk_sync_stage3
    [  220.463460] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
    [  220.475288] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
    [  220.487535] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> clk_sync_stage2
    [  220.499785] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
    [  220.512047] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [  220.524298] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [  220.536551] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [  220.548808] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [  220.560969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [  220.573132] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [  220.585310] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [  220.597394] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [  220.609474] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [  220.621555] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [  220.633201] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [  220.644844] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [  220.656497] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [  220.667882] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [  220.679264] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [  220.690656] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [  220.701608] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [  220.712558] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [  220.723506] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -14
    Here is dmesg of the same process, performed inside without failures.
    Primary SOM:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.4.0-xilinx-v2020.1 (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP Tue May 25 16:16:00 UTC 2021
    [    0.000000] Machine model: Analog Devices ADRV9009-ZU11EG Rev.B
    [    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
    [    0.000000] printk: bootconsole [cdns0] enabled
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA32 zone: 8192 pages used for memmap
    [    0.000000]   DMA32 zone: 0 pages reserved
    [    0.000000]   DMA32 zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 8192 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.1
    [    0.000000] percpu: Embedded 22 pages/cpu s49944 r8192 d31976 u90112
    [    0.000000] pcpu-alloc: s49944 r8192 d31976 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] Speculative Store Bypass Disable mitigation not required
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line:  earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x6c000000-0x70000000] (64MB)
    [    0.000000] Memory: 3757380K/4194304K available (13884K kernel code, 1566K rwdata, 11592K rodata, 768K init, 339K bss, 174780K reserved, 262144K cma-reserved)
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x2a8/0x42c with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns
    [    0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
    [    0.008308] Console: colour dummy device 80x25
    [    0.012389] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
    [    0.022667] pid_max: default: 32768 minimum: 301
    [    0.027376] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.034614] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.043254] ASID allocator initialised with 32768 entries
    [    0.047806] rcu: Hierarchical SRCU implementation.
    [    0.052747] EFI services will not be available.
    [    0.057130] smp: Bringing up secondary CPUs ...
    [    0.061816] Detected VIPT I-cache on CPU1
    [    0.061845] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.062168] Detected VIPT I-cache on CPU2
    [    0.062185] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.062482] Detected VIPT I-cache on CPU3
    [    0.062499] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.062541] smp: Brought up 1 node, 4 CPUs
    [    0.096970] SMP: Total of 4 processors activated.
    [    0.101642] CPU features: detected: 32-bit EL0 Support
    [    0.106746] CPU features: detected: CRC32 instructions
    [    0.111875] CPU: All CPU(s) started at EL2
    [    0.115924] alternatives: patching kernel code
    [    0.121338] devtmpfs: initialized
    [    0.130825] Registered cp15_barrier emulation handler
    [    0.130872] Registered setend emulation handler
    [    0.134850] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.144437] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.156764] xor: measuring software checksum speed
    [    0.195326]    8regs     :  2639.000 MB/sec
    [    0.235349]    32regs    :  3027.000 MB/sec
    [    0.275377]    arm64_neon:  2628.000 MB/sec
    [    0.275412] xor: using function: 32regs (3027.000 MB/sec)
    [    0.279282] pinctrl core: initialized pinctrl subsystem
    [    0.285024] NET: Registered protocol family 16
    [    0.289769] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.294955] audit: initializing netlink subsys (disabled)
    [    0.300409] audit: type=2000 audit(0.236:1): state=initialized audit_enabled=0 res=1
    [    0.308015] cpuidle: using governor menu
    [    0.312031] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.329391] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.330442] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.337110] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.343767] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    1.316450] DRBG: Continuing without Jitter RNG
    [    1.393141] raid6: neonx8   gen()  1738 MB/s
    [    1.461167] raid6: neonx8   xor()  1629 MB/s
    [    1.529207] raid6: neonx4   gen()  1649 MB/s
    [    1.597236] raid6: neonx4   xor()  1589 MB/s
    [    1.665268] raid6: neonx2   gen()  1260 MB/s
    [    1.733307] raid6: neonx2   xor()  1322 MB/s
    [    1.801369] raid6: neonx1   gen()   823 MB/s
    [    1.869388] raid6: neonx1   xor()   995 MB/s
    [    1.937435] raid6: int64x8  gen()  1293 MB/s
    [    2.005475] raid6: int64x8  xor()   848 MB/s
    [    2.073545] raid6: int64x4  gen()  1093 MB/s
    [    2.141567] raid6: int64x4  xor()   822 MB/s
    [    2.209641] raid6: int64x2  gen()   760 MB/s
    [    2.277637] raid6: int64x2  xor()   667 MB/s
    [    2.345783] raid6: int64x1  gen()   503 MB/s
    [    2.413725] raid6: int64x1  xor()   513 MB/s
    [    2.413760] raid6: using algorithm neonx8 gen() 1738 MB/s
    [    2.417720] raid6: .... xor() 1629 MB/s, rmw enabled
    [    2.422649] raid6: using neon recovery algorithm
    [    2.427602] iommu: Default domain type: Translated
    [    2.432269] SCSI subsystem initialized
    [    2.435816] libata version 3.00 loaded.
    [    2.435931] usbcore: registered new interface driver usbfs
    [    2.441272] usbcore: registered new interface driver hub
    [    2.446544] usbcore: registered new device driver usb
    [    2.451665] mc: Linux media interface: v0.10
    [    2.455794] videodev: Linux video capture interface: v2.00
    [    2.461261] pps_core: LinuxPPS API ver. 1 registered
    [    2.466160] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    2.475255] PTP clock support registered
    [    2.479144] EDAC MC: Ver: 3.0.0
    [    2.482587] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
    [    2.491011] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'clk_sync_stage1'
    [    2.498513] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'clk_sync_stage2'
    [    2.506297] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'clk_sync_stage3'
    [    2.514081] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'link_setup'
    [    2.521433] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage1'
    [    2.529305] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage2'
    [    2.537177] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage3'
    [    2.545048] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage4'
    [    2.552920] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage5'
    [    2.560791] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'clocks_enable'
    [    2.568403] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'link_enable'
    [    2.576022] jesd204: created con: id=0, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a30000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
    [    2.588047] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84a20000 <-> /fpga-axi@0/axi-jesd204-tx@84a30000
    [    2.599724] jesd204: created con: id=2, topo=0, link=0, /amba/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-tx@84a20000
    [    2.610795] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a70000
    [    2.622733] jesd204: created con: id=4, topo=0, link=2, /amba/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a60000
    [    2.634066] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a40000 <-> /fpga-axi@0/axi-jesd204-rx@84a50000
    [    2.645742] jesd204: created con: id=6, topo=0, link=1, /amba/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-rx@84a40000
    [    2.656818] jesd204: created con: id=7, topo=0, link=1, /amba/spi@ff040000/hmc7044-ext@4 <-> /amba/spi@ff040000/hmc7044-car@3
    [    2.668059] jesd204: created con: id=8, topo=0, link=2, /amba/spi@ff040000/hmc7044-ext@4 <-> /amba/spi@ff040000/hmc7044-car@3
    [    2.679304] jesd204: created con: id=9, topo=0, link=0, /amba/spi@ff040000/hmc7044-ext@4 <-> /amba/spi@ff040000/hmc7044-car@3
    [    2.690554] jesd204: created con: id=10, topo=0, link=1, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.701534] jesd204: created con: id=11, topo=0, link=2, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.712521] jesd204: created con: id=12, topo=0, link=0, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.723521] jesd204: created con: id=13, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84a50000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.735367] jesd204: created con: id=14, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a70000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.747215] jesd204: created con: id=15, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.759534] jesd204: created con: id=16, topo=0, link=1, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.771189] jesd204: created con: id=17, topo=0, link=2, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.782874] jesd204: created con: id=18, topo=0, link=0, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.794541] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[0] transition uninitialized -> initialized
    [    2.804120] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[1] transition uninitialized -> initialized
    [    2.813721] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[2] transition uninitialized -> initialized
    [    2.823321] jesd204: found 12 devices and 1 topologies
    [    2.828456] FPGA manager framework
    [    2.831915] Advanced Linux Sound Architecture Driver Initialized.
    [    2.838102] Bluetooth: Core ver 2.22
    [    2.841410] NET: Registered protocol family 31
    [    2.845813] Bluetooth: HCI device and connection manager initialized
    [    2.852129] Bluetooth: HCI socket layer initialized
    [    2.856972] Bluetooth: L2CAP socket layer initialized
    [    2.861993] Bluetooth: SCO socket layer initialized
    [    2.867193] clocksource: Switched to clocksource arch_sys_counter
    [    2.872990] VFS: Disk quotas dquot_6.6.0
    [    2.876820] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    2.887215] NET: Registered protocol family 2
    [    2.888238] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    2.896456] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    2.904469] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    2.911898] TCP: Hash tables configured (established 32768 bind 32768)
    [    2.918099] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.924765] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.931933] NET: Registered protocol family 1
    [    2.936363] RPC: Registered named UNIX socket transport module.
    [    2.942008] RPC: Registered udp transport module.
    [    2.946675] RPC: Registered tcp transport module.
    [    2.951346] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.957963] PCI: CLS 0 bytes, default 64
    [    2.962044] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    2.968869] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    2.977097] Initialise system trusted keyrings
    [    2.980916] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    2.987913] NFS: Registering the id_resolver key type
    [    2.992269] Key type id_resolver registered
    [    2.996412] Key type id_legacy registered
    [    3.000397] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    3.007064] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
    [    3.025080] NET: Registered protocol family 38
    [    3.025119] Key type asymmetric registered
    [    3.027952] Asymmetric key parser 'x509' registered
    [    3.032811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    3.040148] io scheduler mq-deadline registered
    [    3.044645] io scheduler kyber registered
    [    3.071533] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    3.075060] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    3.082056] brd: module loaded
    [    3.085998] loop: module loaded
    [    3.086247] Registered mathworks_ip class
    [    3.089987] libphy: Fixed MDIO Bus: probed
    [    3.093335] tun: Universal TUN/TAP device driver, 1.6
    [    3.097574] CAN device driver interface
    [    3.101934] usbcore: registered new interface driver asix
    [    3.106712] usbcore: registered new interface driver ax88179_178a
    [    3.112748] usbcore: registered new interface driver cdc_ether
    [    3.118541] usbcore: registered new interface driver net1080
    [    3.124164] usbcore: registered new interface driver cdc_subset
    [    3.130048] usbcore: registered new interface driver zaurus
    [    3.135594] usbcore: registered new interface driver cdc_ncm
    [    3.141752] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.147677] ehci-pci: EHCI PCI platform driver
    [    3.152294] usbcore: registered new interface driver uas
    [    3.157388] usbcore: registered new interface driver usb-storage
    [    3.163378] usbcore: registered new interface driver usbserial_generic
    [    3.169834] usbserial: USB Serial support registered for generic
    [    3.175804] usbcore: registered new interface driver ftdi_sio
    [    3.181511] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    3.188778] usbcore: registered new interface driver upd78f0730
    [    3.194658] usbserial: USB Serial support registered for upd78f0730
    [    3.201774] i2c /dev entries driver
    [    3.205838] usbcore: registered new interface driver uvcvideo
    [    3.210044] USB Video Class driver (1.1.1)
    [    3.214480] axi_fan_control_driver 80000000.axi-fan-control: clk_get failed with -517
    [    3.222445] Bluetooth: HCI UART driver ver 2.3
    [    3.226311] Bluetooth: HCI UART protocol H4 registered
    [    3.231414] Bluetooth: HCI UART protocol BCSP registered
    [    3.236700] Bluetooth: HCI UART protocol LL registered
    [    3.241788] Bluetooth: HCI UART protocol ATH3K registered
    [    3.247163] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    3.253410] Bluetooth: HCI UART protocol Intel registered
    [    3.258753] Bluetooth: HCI UART protocol QCA registered
    [    3.263953] usbcore: registered new interface driver bcm203x
    [    3.269579] usbcore: registered new interface driver bpa10x
    [    3.275111] usbcore: registered new interface driver bfusb
    [    3.280561] usbcore: registered new interface driver btusb
    [    3.286024] usbcore: registered new interface driver ath3k
    [    3.291579] EDAC MC0: 13 UE BankGroup Number 0 Block Number 0 on mc#0csrow#0channel#0 (csrow:0 channel:0 page:0x0 offset:0x0 grain:1)
    [    3.291659] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
    [    3.313547] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    3.325860] sdhci: Secure Digital Host Controller Interface driver
    [    3.331668] sdhci: Copyright(c) Pierre Ossman
    [    3.335987] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.341929] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.347618] zynqmp_firmware_probe Platform Management API v1.1
    [    3.353377] zynqmp_firmware_probe Trustzone version v1.0
    [    3.361606] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
    [    3.389030] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    3.389210] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    3.396467] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    3.402657] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    3.408213] usbcore: registered new interface driver usbhid
    [    3.413530] usbhid: USB HID core driver
    [    3.423351] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    3.425713] axi_sysid 85000000.axi-sysid-0: [(null)] on [adrv9009zu11eg] git branch <master> git <0ad691a6035e4a28a2a9ee4d98c7e21aeb8b01f3> clean [2021-05-14 17:29:07] UTC
    [    3.441163] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    3.447516] usbcore: registered new interface driver snd-usb-audio
    [    3.454884] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    3.461317] Initializing XFRM netlink socket
    [    3.465139] NET: Registered protocol family 10
    [    3.469844] Segment Routing with IPv6
    [    3.473214] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.479297] NET: Registered protocol family 17
    [    3.483413] NET: Registered protocol family 15
    [    3.487828] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    3.500764] can: controller area network core (rev 20170425 abi 9)
    [    3.506868] NET: Registered protocol family 29
    [    3.511258] can: raw protocol (rev 20170425)
    [    3.515495] can: broadcast manager protocol (rev 20170425 t)
    [    3.521119] can: netlink gateway (rev 20190810) max_hops=1
    [    3.526637] Bluetooth: RFCOMM TTY layer initialized
    [    3.531418] Bluetooth: RFCOMM socket layer initialized
    [    3.536525] Bluetooth: RFCOMM ver 1.11
    [    3.540237] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    3.545510] Bluetooth: BNEP filters: protocol multicast
    [    3.550701] Bluetooth: BNEP socket layer initialized
    [    3.555630] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.561515] Bluetooth: HIDP socket layer initialized
    [    3.566556] 9pnet: Installing 9P2000 support
    [    3.570708] NET: Registered protocol family 36
    [    3.575111] Key type dns_resolver registered
    [    3.579587] registered taskstats version 1
    [    3.583403] Loading compiled-in X.509 certificates
    [    3.588515] Btrfs loaded, crc32c=crc32c-generic
    [    3.600518] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 23, base_baud = 6249999) is a xuartps
    [    3.609531] printk: console [ttyPS0] enabled
    [    3.613825] printk: bootconsole [cdns0] disabled
    [    3.622990] of-fpga-region fpga-full: FPGA Region probed
    [    3.633404] GPIO line 13 (ulpi-phy-reset) hogged as output/high
    [    3.640662] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    3.647361] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    3.656691] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    3.666797] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
    [    3.676849] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    3.684894] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    3.692938] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    3.703606] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    3.710571] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.717174] [drm] No driver support for vblank timestamp query.
    [    3.723140] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffffc010eddf20)
    [    4.807216] [drm] Cannot find any crtc or sizes
    [    4.811949] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    4.820044] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    4.829442] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.835200] adrv9009 spi1.1: adrv9009_probe : enter
    [    4.925214] random: fast init done
    [    4.944841] jesd204: /amba/spi@ff040000/hmc7044-ext@4,jesd204:4,parent=spi1.4: Using as SYSREF provider
    [    4.955152] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    4.962031] spi-nor: probe of spi0.0 failed with error -2
    [    4.969258] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    4.976623] libphy: MACB_mii_bus: probed
    [    4.981831] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
    [    4.995733] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 13 (f6:37:4c:ca:ae:ee)
    [    5.005813] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    5.012301] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    5.018765] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    5.025226] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    5.033046] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    5.038820] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
    [    5.048881] OF: graph: no port node found in /amba/zynqmp_phy@fd400000/lane1
    [    5.150108] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
    [    5.156845] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 15
    [    5.164016] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.391421] ad9545 4-004a: System PLL unlocked.
    [    5.396075] ad9545: probe of 4-004a failed with error -5
    [    5.401501] i2c i2c-1: Added multiplexed i2c bus 4
    [    5.406436] i2c i2c-1: Added multiplexed i2c bus 5
    [    5.442022] i2c i2c-1: Added multiplexed i2c bus 6
    [    5.473109] i2c i2c-1: Added multiplexed i2c bus 7
    [    5.505808] i2c i2c-1: Added multiplexed i2c bus 8
    [    5.510730] i2c i2c-1: Added multiplexed i2c bus 9
    [    5.515654] i2c i2c-1: Added multiplexed i2c bus 10
    [    5.520530] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
    [    5.528130] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 16
    [    5.534367] axi_fan_control_driver 80000000.axi-fan-control: Failed to initialize device
    [    5.542486] axi_fan_control_driver: probe of 80000000.axi-fan-control failed with error -22
    [    5.551227] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    5.558770] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333 KHz
    [    5.566164] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.574897] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
    [    5.583424] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.625038] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    5.635879] axi-i2s 82000000.axi-i2s-adi: probed, capture enabled, playback enabled
    [    5.643708] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.654484] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.660045] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.713505] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    5.720875] libphy: MACB_mii_bus: probed
    [    5.725303] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
    [    5.739209] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 12 (f6:38:56:4e:4a:ac)
    [    5.751576] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A40000. Number of lanes: 4.
    [    5.764893] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
    [    5.777301] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.03.a) using QPLL on GTH4 at 0x84A20000. Number of lanes: 8.
    [    5.788918] axi-jesd204-rx 84a50000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A50000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.801702] axi-jesd204-rx 84a70000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A70000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.814434] axi-jesd204-tx 84a30000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A30000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
    [    5.827973] asoc-simple-card talise_sound: adau-hifi <-> 82000000.axi-i2s-adi mapping ok
    [    5.839974] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.850770] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.860785] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.891792] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x(____ptrval____), probed ADC ADRV9009-X2 as MASTER
    [    5.915950] mmc0: new high speed SDHC card at address 5048
    [    5.921812] mmcblk0: mmc0:5048 SD16G 14.4 GiB
    [    5.927332] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS ADRV9009-X2
    [    5.942147] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    5.953273] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    5.964392] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    5.975522] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    5.986038] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    5.996550] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    6.007074] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    6.018025] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    6.028969] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    6.039930] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    6.051312] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    6.062691] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    6.074093] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    6.085738] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    6.097377] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    6.109063] [drm] Cannot find any crtc or sizes
    [    6.114694]  mmcblk0: p1 p2
    [    6.118340] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    6.130422] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    6.142498] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    6.187208] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    6.199371] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    6.211532] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    6.223700] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [    6.234731] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [    6.245764] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [    6.257172] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.267975] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.281231] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    6.288135] hctosys: unable to open rtc device (rtc0)
    [    6.293190] of_cfs_init
    [    6.295649] of_cfs_init: OK
    [    6.298623] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.306674] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.433098] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.439621] clk: Not disabling unused clocks
    [    6.443886] ALSA device list:
    [    6.446838]   #0: ADRV9009 ZU11EG ADAU1761
    [    6.451196] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.459801] cfg80211: failed to load regulatory.db
    [    6.500689] EXT4-fs (mmcblk0p2): recovery complete
    [    6.506784] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.514894] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    6.522252] devtmpfs: mounted
    [    6.525386] Freeing unused kernel memory: 768K
    [    6.529885] Run /sbin/init as init process
    [    6.995378] udevd[169]: starting version 3.2.8
    [    7.007536] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.014942] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.022359] random: udevd: uninitialized urandom read (16 bytes read)
    [    7.054868] udevd[170]: starting eudev-3.2.8
    [    7.576053] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    7.653980] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    8.051175] pps pps0: new PPS source ptp0
    [    8.055189] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    8.118823] urandom_read: 5 callbacks suppressed
    [    8.118827] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.134706] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.893510] random: crng init done
    [   10.075956] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [   10.081634] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   51.094999] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [   51.106404] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [   51.117529] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [   51.128653] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [   51.139797] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.152046] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.164296] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.176563] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [   51.188731] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [   51.200897] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [   51.213071] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [   51.225152] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [   51.237233] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [   51.249318] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [   51.260966] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [   51.272613] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [   51.284268] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [   51.295654] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [   51.307036] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [   51.318428] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [   51.329380] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [   51.340328] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [   53.945425] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [   53.956378] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [   53.967333] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [   53.978340] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [   53.988680] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [   53.999019] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [   54.009375] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [   54.020320] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [   54.031268] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [   54.042235] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [   54.053620] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [   54.065006] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [   54.076408] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [   54.088051] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [   54.099693] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [   54.111829] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [   54.123915] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [   54.135990] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [   54.183208] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [   54.195373] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [   54.207542] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [   54.219712] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [   54.230751] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [   54.241792] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [   55.927210] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [   55.939466] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [   55.951722] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [   56.157007] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [   56.169263] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [   56.181519] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [   59.940616] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [   59.955833] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [   59.971103] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [   59.987492] adrv9009 spi1.1: ADIHAL_resetHw
    [   60.318170] adrv9009 spi1.0: ADIHAL_resetHw
    [   60.649594] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [   60.661413] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [   60.673238] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [   60.873392] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [   60.885305] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [   60.897214] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [   86.941892] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [   86.954326] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [   86.966755] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [   87.175970] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [   87.188404] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [   87.200834] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [   87.409508] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [   87.421942] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [   87.434372] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [   92.645160] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.657591] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.670018] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.894505] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    [   92.906668] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> clocks_enable
    [   92.918836] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    [   93.117825] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
    [   93.129560] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clocks_enable -> link_enable
    [   93.141294] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
    [   94.947667] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
    [   94.959318] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_enable -> link_running
    [   94.970971] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
    [   94.982615] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_enable
    [   94.993657] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_enable
    [   95.004695] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_enable
    [   95.117959] adrv9009 spi1.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   95.232566] adrv9009 spi1.0: adrv9009_info: adrv9009-x2 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   95.245258] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> opt_post_running_stage
    [   95.257863] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_running -> opt_post_running_stage
    [   95.270461] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> opt_post_running_stage
    Secondary SOM:
    [    0.008321] Console: colour dummy device 80x25
    [    0.012388] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
    [    0.027379] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.043256] ASID allocator initialised with 32768 entries
    [    0.052758] EFI services will not be available.
    [    0.057129] smp: Bringing up secondary CPUs ...
    [    0.061814] Detected VIPT I-cache on CPU1
    [    0.061843] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.062166] Detected VIPT I-cache on CPU2
    [    0.062183] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.062481] Detected VIPT I-cache on CPU3
    [    0.062498] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.111876] CPU: All CPU(s) started at EL2
    [    0.121339] devtmpfs: initialized
    [    0.130806] Registered cp15_barrier emulation handler
    [    0.130853] Registered setend emulation handler
    [    0.134815] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.144411] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.156758] xor: measuring software checksum speed
    [    0.195301]    8regs     :  2639.000 MB/sec
    [    0.235324]    32regs    :  3027.000 MB/sec
    [    0.275351]    arm64_neon:  2628.000 MB/sec
    [    0.275387] xor: using function: 32regs (3027.000 MB/sec)
    [    0.279256] pinctrl core: initialized pinctrl subsystem
    [    0.284995] NET: Registered protocol family 16
    [    0.289745] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.294928] audit: initializing netlink subsys (disabled)
    [    0.300383] audit: type=2000 audit(0.236:1): state=initialized audit_enabled=0 res=1
    [    0.307989] cpuidle: using governor menu
    [    0.312004] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.329432] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.330485] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.337153] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.343810] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    1.317100] DRBG: Continuing without Jitter RNG
    [    1.393105] raid6: neonx8   gen()  1738 MB/s
    [    1.461137] raid6: neonx8   xor()  1629 MB/s
    [    1.529179] raid6: neonx4   gen()  1649 MB/s
    [    1.597201] raid6: neonx4   xor()  1589 MB/s
    [    1.665236] raid6: neonx2   gen()  1260 MB/s
    [    1.733283] raid6: neonx2   xor()  1321 MB/s
    [    1.801319] raid6: neonx1   gen()   823 MB/s
    [    1.869367] raid6: neonx1   xor()   995 MB/s
    [    1.937401] raid6: int64x8  gen()  1293 MB/s
    [    2.005446] raid6: int64x8  xor()   848 MB/s
    [    2.073505] raid6: int64x4  gen()  1093 MB/s
    [    2.141521] raid6: int64x4  xor()   822 MB/s
    [    2.209623] raid6: int64x2  gen()   760 MB/s
    [    2.277633] raid6: int64x2  xor()   668 MB/s
    [    2.345641] raid6: int64x1  gen()   502 MB/s
    [    2.413730] raid6: int64x1  xor()   512 MB/s
    [    2.413765] raid6: using algorithm neonx8 gen() 1738 MB/s
    [    2.417719] raid6: .... xor() 1629 MB/s, rmw enabled
    [    2.427610] iommu: Default domain type: Translated
    [    2.432271] SCSI subsystem initialized
    [    2.435930] usbcore: registered new interface driver usbfs
    [    2.451659] mc: Linux media interface: v0.10
    [    2.455795] videodev: Linux video capture interface: v2.00
    [    2.461264] pps_core: LinuxPPS API ver. 1 registered
    [    2.479145] EDAC MC: Ver: 3.0.0
    [    2.491006] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'clk_sync_stage1'
    [    2.521434] jesd204: /amba/spi@ff040000/adrv9009-phy@0: stop state: 'opt_setup_stage1'
    [    2.576013] jesd204: created con: id=0, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a30000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
    [    2.634064] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a40000 <-> /fpga-axi@0/axi-jesd204-rx@84a50000
    [    2.656819] jesd204: created con: id=7, topo=0, link=1, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.667713] jesd204: created con: id=8, topo=0, link=2, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.678612] jesd204: created con: id=9, topo=0, link=0, /amba/spi@ff040000/hmc7044-car@3 <-> /amba/spi@ff040000/hmc7044@2
    [    2.689527] jesd204: created con: id=10, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84a50000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.701368] jesd204: created con: id=11, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a70000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.713219] jesd204: created con: id=12, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /amba/spi@ff040000/adrv9009-phy-b@1
    [    2.725539] jesd204: created con: id=13, topo=0, link=1, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.737197] jesd204: created con: id=14, topo=0, link=2, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.748880] jesd204: created con: id=15, topo=0, link=0, /amba/spi@ff040000/adrv9009-phy-b@1 <-> /amba/spi@ff040000/adrv9009-phy@0
    [    2.760541] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[0] transition uninitialized -> initialized
    [    2.770125] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[1] transition uninitialized -> initialized
    [    2.779726] jesd204: /amba/spi@ff040000/adrv9009-phy@0: JESD204[2] transition uninitialized -> initialized
    [    2.789326] jesd204: found 12 devices and 1 topologies
    [    2.794459] FPGA manager framework
    [    2.797925] Advanced Linux Sound Architecture Driver Initialized.
    [    2.804108] Bluetooth: Core ver 2.22
    [    2.807417] NET: Registered protocol family 31
    [    2.811818] Bluetooth: HCI device and connection manager initialized
    [    2.818135] Bluetooth: HCI socket layer initialized
    [    2.822977] Bluetooth: L2CAP socket layer initialized
    [    2.827998] Bluetooth: SCO socket layer initialized
    [    2.833202] clocksource: Switched to clocksource arch_sys_counter
    [    2.838993] VFS: Disk quotas dquot_6.6.0
    [    2.842824] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    2.853216] NET: Registered protocol family 2
    [    2.854243] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    2.862461] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    2.870474] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    2.877902] TCP: Hash tables configured (established 32768 bind 32768)
    [    2.884103] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.890770] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.897939] NET: Registered protocol family 1
    [    2.902372] RPC: Registered named UNIX socket transport module.
    [    2.908012] RPC: Registered udp transport module.
    [    2.912679] RPC: Registered tcp transport module.
    [    2.917350] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.923972] PCI: CLS 0 bytes, default 64
    [    2.928053] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    2.934875] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    2.943121] Initialise system trusted keyrings
    [    2.946915] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    2.953924] NFS: Registering the id_resolver key type
    [    2.958276] Key type id_resolver registered
    [    2.962417] Key type id_legacy registered
    [    2.966400] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    2.973069] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
    [    2.991525] NET: Registered protocol family 38
    [    2.991564] Key type asymmetric registered
    [    2.994398] Asymmetric key parser 'x509' registered
    [    2.999257] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    3.006594] io scheduler mq-deadline registered
    [    3.011090] io scheduler kyber registered
    [    3.038419] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    3.042265] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    3.048911] brd: module loaded
    [    3.052857] loop: module loaded
    [    3.053112] Registered mathworks_ip class
    [    3.056905] libphy: Fixed MDIO Bus: probed
    [    3.060210] tun: Universal TUN/TAP device driver, 1.6
    [    3.064455] CAN device driver interface
    [    3.068895] usbcore: registered new interface driver asix
    [    3.073586] usbcore: registered new interface driver ax88179_178a
    [    3.079626] usbcore: registered new interface driver cdc_ether
    [    3.085421] usbcore: registered new interface driver net1080
    [    3.091042] usbcore: registered new interface driver cdc_subset
    [    3.096927] usbcore: registered new interface driver zaurus
    [    3.102471] usbcore: registered new interface driver cdc_ncm
    [    3.108688] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.114555] ehci-pci: EHCI PCI platform driver
    [    3.119199] usbcore: registered new interface driver uas
    [    3.124268] usbcore: registered new interface driver usb-storage
    [    3.130256] usbcore: registered new interface driver usbserial_generic
    [    3.136713] usbserial: USB Serial support registered for generic
    [    3.142687] usbcore: registered new interface driver ftdi_sio
    [    3.148388] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    3.155659] usbcore: registered new interface driver upd78f0730
    [    3.161536] usbserial: USB Serial support registered for upd78f0730
    [    3.168727] i2c /dev entries driver
    [    3.172818] usbcore: registered new interface driver uvcvideo
    [    3.176923] USB Video Class driver (1.1.1)
    [    3.181377] axi_fan_control_driver 80000000.axi-fan-control: clk_get failed with -517
    [    3.189332] Bluetooth: HCI UART driver ver 2.3
    [    3.193179] Bluetooth: HCI UART protocol H4 registered
    [    3.198292] Bluetooth: HCI UART protocol BCSP registered
    [    3.203578] Bluetooth: HCI UART protocol LL registered
    [    3.208666] Bluetooth: HCI UART protocol ATH3K registered
    [    3.214040] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    3.220289] Bluetooth: HCI UART protocol Intel registered
    [    3.225633] Bluetooth: HCI UART protocol QCA registered
    [    3.230834] usbcore: registered new interface driver bcm203x
    [    3.236455] usbcore: registered new interface driver bpa10x
    [    3.241990] usbcore: registered new interface driver bfusb
    [    3.247443] usbcore: registered new interface driver btusb
    [    3.252903] usbcore: registered new interface driver ath3k
    [    3.258458] EDAC MC0: 13 UE BankGroup Number 0 Block Number 0 on mc#0csrow#0channel#0 (csrow:0 channel:0 page:0x0 offset:0x0 grain:1)
    [    3.270344] EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
    [    3.280430] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    3.292757] sdhci: Secure Digital Host Controller Interface driver
    [    3.298543] sdhci: Copyright(c) Pierre Ossman
    [    3.302865] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.308824] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.314498] zynqmp_firmware_probe Platform Management API v1.1
    [    3.320256] zynqmp_firmware_probe Trustzone version v1.0
    [    3.328497] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
    [    3.355843] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
    [    3.356018] zynqmp_aes zynqmp_aes: AES Successfully Registered
    [    3.363273] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    3.369476] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    3.375031] usbcore: registered new interface driver usbhid
    [    3.380339] usbhid: USB HID core driver
    [    3.390306] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    3.392658] axi_sysid 85000000.axi-sysid-0: [(null)] on [adrv9009zu11eg] git branch <master> git <0ad691a6035e4a28a2a9ee4d98c7e21aeb8b01f3> clean [2021-05-14 17:29:07] UTC
    [    3.408121] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    3.414472] usbcore: registered new interface driver snd-usb-audio
    [    3.421882] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    3.428277] Initializing XFRM netlink socket
    [    3.432085] NET: Registered protocol family 10
    [    3.436795] Segment Routing with IPv6
    [    3.440158] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.446240] NET: Registered protocol family 17
    [    3.450362] NET: Registered protocol family 15
    [    3.454777] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    3.467710] can: controller area network core (rev 20170425 abi 9)
    [    3.473816] NET: Registered protocol family 29
    [    3.478207] can: raw protocol (rev 20170425)
    [    3.482442] can: broadcast manager protocol (rev 20170425 t)
    [    3.488069] can: netlink gateway (rev 20190810) max_hops=1
    [    3.493576] Bluetooth: RFCOMM TTY layer initialized
    [    3.498365] Bluetooth: RFCOMM socket layer initialized
    [    3.503471] Bluetooth: RFCOMM ver 1.11
    [    3.507185] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    3.512458] Bluetooth: BNEP filters: protocol multicast
    [    3.517650] Bluetooth: BNEP socket layer initialized
    [    3.522578] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.528462] Bluetooth: HIDP socket layer initialized
    [    3.533505] 9pnet: Installing 9P2000 support
    [    3.537655] NET: Registered protocol family 36
    [    3.542058] Key type dns_resolver registered
    [    3.546535] registered taskstats version 1
    [    3.550350] Loading compiled-in X.509 certificates
    [    3.555466] Btrfs loaded, crc32c=crc32c-generic
    [    3.567447] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 23, base_baud = 6249999) is a xuartps
    [    3.576461] printk: console [ttyPS0] enabled
    [    3.580755] printk: bootconsole [cdns0] disabled
    [    3.589906] of-fpga-region fpga-full: FPGA Region probed
    [    3.600332] GPIO line 13 (ulpi-phy-reset) hogged as output/high
    [    3.607601] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    3.614297] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
    [    3.623635] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    3.633744] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
    [    3.643819] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    3.651888] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    3.659943] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    3.670615] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    3.677579] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.684183] [drm] No driver support for vblank timestamp query.
    [    3.690153] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffffc010eddf20)
    [    4.777225] [drm] Cannot find any crtc or sizes
    [    4.781955] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    4.790048] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    4.799465] adrv9009 spi1.0: adrv9009_probe : enter
    [    4.805221] adrv9009 spi1.1: adrv9009_probe : enter
    [    4.858065] jesd204: /amba/spi@ff040000/hmc7044-car@3,jesd204:3,parent=spi1.3: Using as sec SYSREF provider
    [    4.868680] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    4.875551] spi-nor: probe of spi0.0 failed with error -2
    [    4.882780] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    4.890142] libphy: MACB_mii_bus: probed
    [    4.895343] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
    [    4.909248] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 13 (b6:98:17:c2:52:93)
    [    4.919331] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    4.925838] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    4.932319] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    4.938785] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    4.946624] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
    [    4.952394] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
    [    4.962459] OF: graph: no port node found in /amba/zynqmp_phy@fd400000/lane1
    [    4.982347] random: fast init done
    [    5.067543] at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
    [    5.074287] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 15
    [    5.081502] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.086768] i2c i2c-1: Added multiplexed i2c bus 4
    [    5.091704] i2c i2c-1: Added multiplexed i2c bus 5
    [    5.123939] i2c i2c-1: Added multiplexed i2c bus 6
    [    5.155053] i2c i2c-1: Added multiplexed i2c bus 7
    [    5.187762] i2c i2c-1: Added multiplexed i2c bus 8
    [    5.192683] i2c i2c-1: Added multiplexed i2c bus 9
    [    5.197618] i2c i2c-1: Added multiplexed i2c bus 10
    [    5.202493] pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
    [    5.210094] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 16
    [    5.216315] axi_fan_control_driver 80000000.axi-fan-control: Failed to initialize device
    [    5.224461] axi_fan_control_driver: probe of 80000000.axi-fan-control failed with error -22
    [    5.233208] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    5.240752] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1333333 KHz
    [    5.248145] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.256876] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
    [    5.265406] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1333333320 (-34)
    [    5.305762] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    5.316791] axi-i2s 82000000.axi-i2s-adi: probed, capture enabled, playback enabled
    [    5.324646] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.335431] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.341007] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.394501] macb ff0b0000.ethernet: Not enabling partial store and forward
    [    5.401867] libphy: MACB_mii_bus: probed
    [    5.406355] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
    [    5.420263] macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 12 (fa:7f:ba:86:77:96)
    [    5.432720] axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A40000. Number of lanes: 4.
    [    5.446080] axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.03.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
    [    5.458475] axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.03.a) using QPLL on GTH4 at 0x84A20000. Number of lanes: 8.
    [    5.470114] axi-jesd204-rx 84a50000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A50000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.482931] axi-jesd204-rx 84a70000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A70000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    [    5.495675] axi-jesd204-tx 84a30000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A30000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
    [    5.509218] asoc-simple-card talise_sound: adau-hifi <-> 82000000.axi-i2s-adi mapping ok
    [    5.517892] adau1761 3-003b: Unable to sync registers 0x4002-0x4002. -6
    [    5.525037] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.535835] adrv9009 spi1.0: adrv9009_probe : enter
    [    5.545807] adrv9009 spi1.1: adrv9009_probe : enter
    [    5.576568] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x(____ptrval____), probed ADC ADRV9009-X2 as MASTER
    [    5.599859] mmc0: new high speed SDHC card at address 5048
    [    5.605714] mmcblk0: mmc0:5048 SD16G 14.4 GiB
    [    5.611237] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS ADRV9009-X2
    [    5.626048] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
    [    5.637172] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition initialized -> probed
    [    5.648289] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
    [    5.659418] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
    [    5.669928] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition probed -> idle
    [    5.680440] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
    [    5.690960] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [    5.701908] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [    5.712852] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [    5.723809] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [    5.735195] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [    5.746574] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [    5.757968] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [    5.769611] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [    5.781251] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [    5.793536] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [    5.805628] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [    5.817707] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [    5.829834]  mmcblk0: p1 p2
    [    5.853213] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [    5.865381] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [    5.877548] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [    5.889714] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [    5.900752] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [    5.911791] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [    5.923194] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.934017] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    5.947295] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    5.954201] hctosys: unable to open rtc device (rtc0)
    [    5.959251] of_cfs_init
    [    5.961711] of_cfs_init: OK
    [    5.964681] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.972765] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: failed to init link xilinx-dp0: -517
    [    6.041218] [drm] Cannot find any crtc or sizes
    [    6.099158] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.105684] clk: Not disabling unused clocks
    [    6.109946] ALSA device list:
    [    6.112900]   #0: ADRV9009 ZU11EG ADAU1761
    [    6.117266] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.125871] cfg80211: failed to load regulatory.db
    [    6.167483] EXT4-fs (mmcblk0p2): recovery complete
    [    6.173575] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.181679] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    6.189091] devtmpfs: mounted
    [    6.192222] Freeing unused kernel memory: 768K
    [    6.196715] Run /sbin/init as init process
    [    6.662616] udevd[169]: starting version 3.2.8
    [    6.674415] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.681751] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.689106] random: udevd: uninitialized urandom read (16 bytes read)
    [    6.722342] udevd[170]: starting eudev-3.2.8
    [    7.230107] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    7.311939] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    7.709481] pps pps0: new PPS source ptp0
    [    7.713507] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    7.776714] urandom_read: 5 callbacks suppressed
    [    7.776719] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    7.792907] random: dbus-daemon: uninitialized urandom read (12 bytes read)
    [    8.552964] random: crng init done
    [    9.757963] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [    9.763638] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   51.345902] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] FSM is paused; a resume is required
    [   51.357298] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_running
    [   51.368427] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_running
    [   51.379552] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_running
    [   51.390691] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.402943] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.415195] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
    [   51.427457] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
    [   51.439620] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> link_pre_setup
    [   51.451787] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
    [   51.463956] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
    [   51.476029] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> link_supported
    [   51.488107] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
    [   51.500196] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
    [   51.511837] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_init
    [   51.523484] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
    [   51.535136] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
    [   51.546525] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> device_init
    [   51.557911] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
    [   51.569304] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [   51.580255] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [   51.591205] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [   54.247356] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
    [   54.258316] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> idle
    [   54.269267] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
    [   54.280249] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
    [   54.290595] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> idle
    [   54.300939] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
    [   54.311287] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
    [   54.322239] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition idle -> device_init
    [   54.333187] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
    [   54.344149] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
    [   54.355530] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition device_init -> link_init
    [   54.366914] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
    [   54.378314] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
    [   54.389960] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_init -> link_supported
    [   54.401604] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
    [   54.413517] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
    [   54.425599] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_supported -> link_pre_setup
    [   54.437679] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
    [   54.473213] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
    [   54.485374] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_pre_setup -> clk_sync_stage1
    [   54.497544] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
    [   54.509712] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] paused at state clk_sync_stage1
    [   54.520749] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] paused at state clk_sync_stage1
    [   54.531785] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] paused at state clk_sync_stage1
    [   55.722811] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
    [   55.735067] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage1 -> clk_sync_stage2
    [   55.747319] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
    [   55.961916] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
    [   55.974168] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage2 -> clk_sync_stage3
    [   55.986424] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
    [   56.191735] jesd204: /fpga-axi@0/axi-jesd204-rx@84a50000,jesd204:6,parent=84a50000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[1] lanes 2
    [   56.206954] jesd204: /fpga-axi@0/axi-jesd204-rx@84a70000,jesd204:8,parent=84a70000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 4, Link[2] lanes 2
    [   56.222223] jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:10,parent=84a30000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [   56.238647] adrv9009 spi1.1: ADIHAL_resetHw
    [   56.577823] adrv9009 spi1.0: ADIHAL_resetHw
    [   56.917360] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
    [   56.929175] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clk_sync_stage3 -> link_setup
    [   56.940996] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
    [   60.683439] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
    [   60.695345] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_setup -> opt_setup_stage1
    [   60.707251] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
    [   66.135014] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
    [   66.147446] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage1 -> opt_setup_stage2
    [   66.159874] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
    [   86.977801] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
    [   86.990237] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage2 -> opt_setup_stage3
    [   87.002664] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
    [   87.211299] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
    [   87.223730] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage3 -> opt_setup_stage4
    [   87.236160] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
    [   92.446984] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.459410] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.471839] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
    [   92.683778] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
    [   92.695943] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition opt_setup_stage5 -> clocks_enable
    [   92.708112] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
    [   92.928962] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
    [   92.940697] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition clocks_enable -> link_enable
    [   92.952432] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
    [   93.185800] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
    [   93.197443] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_enable -> link_running
    [   93.209093] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
    [   93.220737] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] resuming from state link_enable
    [   93.231770] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] resuming from state link_enable
    [   93.242810] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] resuming from state link_enable
    [   93.256837] adrv9009 spi1.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   93.371861] adrv9009 spi1.0: adrv9009_info: adrv9009-x2 Rev 192, Firmware 6.0.2 API version: 3.6.0.5 successfully initialized via jesd204-fsm
    [   93.384554] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> opt_post_running_stage
    [   93.397157] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[1] transition link_running -> opt_post_running_stage
    [   93.409755] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> opt_post_running_stage
    It looks like the failed pass never makes it into "transition opt_setup_stage4 -> opt_setup_stage5"
    on Jun 29, 2021 9:07 AM in reply to mstone
    The issue is on the secondary SOM:
    [  180.405854] adrv9009 spi1.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
    [  180.418976] adrv9009 spi1.1: ERROR: 131086: Talise init calibration error encountered
    [  180.426804] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:5957 (ret 6)
    [  180.433415] jesd204: /amba/spi@ff040000/adrv9009-phy-b@1,jesd204:1,parent=spi1.1: JESD204[1] got error from cb: -14
    [  180.443844] jesd204: /amba/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'opt_setup_stage4', got error -14
    This error is typically not Sync related. And I would check what other conditions exists in your field testing.
    Below is a list of instances when I have been running into this before:
    1) During init calibration, there must not be strong signals on the RX input. And ideally RX is terminated during Init Calibration. We've seen this when a large 1GHz tone was injected during cal. Lowering the amplitude or changing the LO or tone frequency made the error go away.
    2) Something access the IIO device while the device in not yet fully initialized. For example OSC is starting in the background. And there is a /root/.osc_profile.ini or /home/analog/.osc_profile.ini file. Remove OSC from autostart.
    3) In the office we have lots of people who scan IIO devices on the network. iio_info for example will read all the device files. Which then also causes issues on the pre-init setups. What we did in the LAB is to isolate the networks. So that nothing else can connect to the boards.
    4) Some invalid Talise profile configuration can also trigger this error.
    -Michael
