Changing Sampling rate AD9680-KC705 combo
FPGA Board : KC705
EVM : AD-FMCDAQ2-EBZ
Hdl version : hdl_2019_r1
I am trying to change the sampling rate for AD9680 by following the procedure given in https://wiki.analog.com/resources/eval/user-guides/ad-fmcdaq2-ebz/clocking
After booting linux while connecting to IIO scope I receive the following print in terminal
"ad9680 spi0.2: Failed to set lane rate to 10000000 kHz: -22""
I am attaching here with modified  dts and trace print received.
Am I following the correct steps??
------------[ cut here ]------------
WARNING: CPU: 0 PID: 112 at drivers/clk/clk.c:622 clk_core_disable+0x34/0x90
Modules linked in:
CPU: 0 PID: 112 Comm: iiod Not tainted 4.14.0-gb6e379910a11-dirty #3
Kernel Stack:
ac0e7cbc: 8000a3c0
ac0e7cc0: 000f4240 00000000 ac0e7d14 ac0e7d14 00000000 8046e5d8 8000a464 8042a7e0
ac0e7ce0: 00000000 00000070 8046e5d8 0000026e 8022dbd4 ac1f1800 ac1ef60c 3b9aca00
ac0e7d00: 3b9aca00 ac1f6274 ac0e7f4c 8022dbd4 00000000 ac0e7cc8 ac0e7cc8 ac17a200
ac0e7d20: 00000000 80293584 8022ef78 00000003 00000003 00000000 ac0e7d38 ac0e7d38
ac0e7d40: 00000000 000065a2 8022efb0 ffffffff ac1ef60c 3b9aca00 3b9aca00 ac1f6274
ac0e7d60: ac0e7f4c ac1f1800 ac1f51c0 802fda3c ffffffff 00000000 00000000 00000000
ac0e7d80: ffffffff ac157105 802c206c 800a1e8c ac0e7e8c 00000000 ac23f0c0 800ae930
ac0e7da0: 800c4c40 0000a068 ac23f0c0 ac1f6000 ac246d20 0000000a ac1f6000 ac1f600c
ac0e7dc0: ac0e7f4c 802b81a0 3178cb80 00000032 ac1f3780 ac246d20 0000000a ac1f6000
ac0e7de0: ac1f600c ac0e7f4c 315ff920 ac1f3780 ac246d20 0000000a 8025f45c 801093dc
ac0e7e00: ac0e7dfc ac229e10 aa04a180 aa04c440 00000000 00000000 3b9aca00 0000000a
ac0e7e20: ffffffea ac248120 ac246d20 ac248130 8010d71c ac0e7f20 00000001 0000000a
ac0e7e40: 8010c374 3178cb80 aa04c440 8010c3b4 ac1fba80 800aa280 800a987c 0000000a
ac0e7e60: 31608ac8 ac248120 800a4eb0 aa04ca80 00000011 00000000 00000e18 00000000
ac0e7e80: 000081a4 ac23f0c0 0000000a 00000000 ac0e7f4c 31608ac8 fffff000 800a51f0
ac0e7ea0: 00001000 00000000 00001000 00000000 00000000 00000000 00000032 2e0854fc
ac0e7ec0: 00000032 3178cb80 800a518c 3178cb80 00000000 00000000 315fdeec 301e24c0
ac0e7ee0: 800a51dc 800a2380 ac23f0c0 0000000a fffffff2 ac23f0c0 0000000a 800a5408
ac0e7f00: 000081a4 00000001 800c1cfc 800c25f8 800a53d4 00000000 ac23f0c0 ac23f0c3
ac0e7f20: fffffff7 00000000 0000000a fffff000 80005488 00001000 00000000 00000032
ac0e7f40: 2e0854fc 00000032 3178cb80 00000000 00000000 31608ac8 0000000a 0000000a
ac0e7f60: 31608ac8 00000009 00000004 315fdf14 00000000 00000000 00000000 00000009
ac0e7f80: 31608ac8 0000000a 00000000 3003d7f2 00000000 31608ac0 00000004 00000000
ac0e7fa0: 00000000 3014cae0 00000000 3014ca68 ffffff04 0000000a 301e6ff4 315ff920
ac0e7fc0: 31608ac8 00000009 00000000 0000000a fffff000 315ff920 31604670 00000024
ac0e7fe0: 315ff920 00000000 3014cb00 000055aa 31609a2c 00000c72 00000000 00000000
Call Trace:
[<80003b74>] microblaze_unwind+0x58/0x68
[<8000388c>] show_stack+0x118/0x158
[<803f8afc>] dump_stack+0x20/0x38
[<8000a3bc>] __warn+0x120/0x130
[<8000a460>] warn_slowpath_null+0x10/0x28
[<8022dbd0>] clk_core_disable+0x30/0x90
[<8022ef74>] clk_core_disable_lock+0x14/0x38
[<8022efac>] clk_disable+0x14/0x34
[<802fda38>] ad9680_write_raw+0x188/0x40c
[<802c2068>] axiadc_write_raw+0x370/0x38c
[<802b819c>] iio_write_channel_info+0x9c/0xfc
[<8025f458>] dev_attr_store+0xc/0x2c
[<8010d718>] sysfs_kf_write+0x34/0x54
[<8010c3b0>] kernfs_fop_write+0x160/0x200
[<800a4eac>] __vfs_write+0x18/0x174
[<800a51ec>] vfs_write+0xe8/0x1c0
[<800a5404>] SyS_write+0x4c/0xb8
SYSCALL
---[ end trace aff60efdcc2f8749 ]---
WARNING: CPU: 0 PID: 112 at drivers/clk/clk.c:504 clk_core_unprepare+0x34/0xac
Modules linked in:
CPU: 0 PID: 112 Comm: iiod Tainted: G        W       4.14.0-gb6e379910a11-dirty #3
Kernel Stack:
ac0e7cdc: 8000a3c0
ac0e7ce0: 301e6ff4 00000000 ac1ef60c 3b9aca00 00000000 8046e5d8 8000a464 8042a7e0
ac0e7d00: 00000000 00000070 8046e5d8 000001f8 8022d9f0 ac1f1800 ac1ef60c 3b9aca00
ac0e7d20: 3b9aca00 ac1f6274 ac0e7f4c 8022d9f0 00000003 00000000 ac0e7d38 ac0e7d38
ac0e7d40: 00000000 000065a2 8022f20c 8022f204 ac1ef60c 3b9aca00 3b9aca00 ac1f6274
ac0e7d60: ac0e7f4c ac1f1800 802fda48 802fda3c ffffffff 00000000 00000000 00000000
ac0e7d80: ffffffff ac1f51c0 802c206c 800a1e8c ac0e7e8c 00000000 ac23f0c0 800ae930
Call Trace:
[<8022d9ec>] clk_core_unprepare+0x30/0xac
[<8022f208>] clk_unprepare+0x20/0x4c
[<802fda44>] ad9680_write_raw+0x194/0x40c
SYSCALL
---[ end trace aff60efdcc2f874a ]---
Modules linked in:
Kernel Stack:
ac0e7cbc: 8000a3c0
ac0e7cc0: 8000a24c 00000000 00000000 8046e5d8 00000000 8046e5d8 8000a464 8042a7e0
ac0e7ce0: 00000000 00000070 8046e5d8 0000026e 8022dbd4 ac1f1e80 ac1ef60c 3b9aca00
ac0e7d00: 3b9aca00 ac1f6274 ac0e7f4c 8022dbd4 8022d9f0 ac1f1800 ac1ef60c 3b9aca00
ac0e7d20: 3b9aca00 ac1f6274 8022ef78 8022d9f0 00000003 00000000 ac0e7d38 ac0e7d38
ac0e7d40: 00000000 000065a2 8022efb0 8022f214 ac1ef60c 3b9aca00 3b9aca00 ac1f6274
ac0e7d60: ac0e7f4c ac1f1e80 ac1f5240 802fda58 ffffffff 00000000 00000000 00000000
Call Trace:
[<802fda54>] ad9680_write_raw+0x1a4/0x40c
SYSCALL
---[ end trace aff60efdcc2f874b ]---
Modules linked in:
Kernel Stack:
ac0e7cdc: 8000a3c0
ac0e7d00: 00000000 00000070 8046e5d8 000001f8 8022d9f0 ac1f1e80 ac1ef60c 3b9aca00
ac0e7d60: ac0e7f4c ac1f1e80 802fda64 802fda58 ffffffff 00000000 00000000 00000000
ac0e7d80: ffffffff ac1f5240 802c206c 800a1e8c ac0e7e8c 00000000 ac23f0c0 800ae930
Call Trace:
[<802fda60>] ad9680_write_raw+0x1b0/0x40c
SYSCALL
---[ end trace aff60efdcc2f874c ]---
Modules linked in:
Kernel Stack:
ac0e7cbc: 8000a3c0
ac0e7ce0: 00000000 00000070 8046e5d8 0000026e 8022dbd4 ac1f1c00 ac1ef60c 3b9aca00
ac0e7d00: 3b9aca00 ac1f6274 ac0e7f4c 8022dbd4 8022d9f0 ac1f1e80 ac1ef60c 3b9aca00
ac0e7d60: ac0e7f4c ac1f1c00 ac1f5200 802fda74 ffffffff 00000000 00000000 00000000
Call Trace:
[<802fda70>] ad9680_write_raw+0x1c0/0x40c
SYSCALL
---[ end trace aff60efdcc2f874d ]---
Modules linked in:
Kernel Stack:
ac0e7cdc: 8000a3c0
ac0e7d00: 00000000 00000070 8046e5d8 000001f8 8022d9f0 ac1f1c00 ac1ef60c 3b9aca00
ac0e7d60: ac0e7f4c ac1f1c00 802fda80 802fda74 ffffffff 00000000 00000000 00000000
ac0e7d80: ffffffff ac1f5200 802c206c 800a1e8c ac0e7e8c 00000000 ac23f0c0 800ae930
Call Trace:
[<802fda7c>] ad9680_write_raw+0x1cc/0x40c
SYSCALL
---[ end trace aff60efdcc2f874e ]---
&fmc_spi {
	clk0_ad9523: ad9523-1@0 {
		#address-cells = <1>;
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "ad9523-1";
		reg = <0>;
		spi-cpol;
		spi-cpha;
		spi-max-frequency = <10000000>;
		clock-output-names = "ad9523-1_out0", "ad9523-1_out1", "ad9523-1_out2", "ad9523-1_out3", "ad9523-1_out4", "ad9523-1_out5", "ad9523-1_out6", "ad9523-1_out7", "ad9523-1_out8", "ad9523-1_out9", "ad9523-1_out10", "ad9523-1_out11", "ad9523-1_out12", "ad9523-1_out13";
		adi,vcxo-freq = <125000000>;
		adi,spi-3wire-enable;
		adi,pll1-bypass-enable;
		adi,osc-in-diff-enable;
		adi,pll2-charge-pump-current-nA = <413000>;
		 * Valid ranges based on VCO locking range:
		 *    980.00 MHz - 1033.33 MHz
		 *    735.00 MHz -  775.00 MHz
		 *    588.00 MHz -  620.00 MHz
		adi,pll2-m1-freq = <1000000000>;
		/* Manual PLL2 divider configuration */
		//adi,pll2-ndiv-a-cnt = <0>;
		//adi,pll2-ndiv-b-cnt = <6>;
		//adi,pll2-r2-div = <1>;
		//adi,pll2-vco-div-m1 = <3>;
		adi,rpole2 = <0>;
		adi,rzero = <7>;
		adi,cpole1 = <2>;
		ad9523_0_c1:channel@1 {
			reg = <1>;
			adi,extended-name = "DAC_CLK";
			adi,driver-mode = <3>;
			adi,divider-phase = <1>;
			adi,channel-divider = <3>;
//			adi,output-dis;
		ad9523_0_c4:channel@4 {
			reg = <4>;
			adi,extended-name = "ADC_CLK_FMC";
			adi,channel-divider = <4>;
//			adi,output-dis;
		ad9523_0_c5:channel@5 {
			reg = <5>;
			adi,extended-name = "ADC_SYSREF";
			adi,channel-divider = <256>;
//			adi,output-dis;
		ad9523_0_c6:channel@6 {
			reg = <6>;
			adi,extended-name = "CLKD_ADC_SYSREF";
//			adi,output-dis;
		ad9523_0_c7:channel@7 {
			reg = <7>;
			adi,extended-name = "CLKD_DAC_SYSREF";
			adi,channel-divider = <384>;
//			adi,output-dis;
		ad9523_0_c8:channel@8 {
			reg = <8>;
			adi,extended-name = "DAC_SYSREF";
//			adi,output-dis;
		ad9523_0_c9:channel@9 {
			reg = <9>;
			adi,extended-name = "FMC_DAC_REF_CLK";
			adi,channel-divider = <6>;
//			adi,output-dis;
		ad9523_0_c13:channel@13 {
			reg = <13>;
			adi,extended-name = "ADC_CLK";
			adi,channel-divider = <2>;
//			adi,output-dis;
	dac0_ad9144: ad9144@1 {
		#size-cells = <0>;
		compatible = "ad9144";
		reg = <1>;
		spi-cpol;
		spi-cpha;
		spi-max-frequency = <1000000>;
		clocks = <&axi_ad9144_jesd>, <&clk0_ad9523 1>, <&clk0_ad9523 8>;
		clock-names = "jesd_dac_clk", "dac_clk", "dac_sysref";
	adc0_ad9680: ad9680@2 {
		#size-cells = <0>;
		compatible = "ad9680";
		reg = <2>;
		spi-cpol;
		spi-cpha;
		clocks = <&axi_ad9680_jesd>, <&clk0_ad9523 13>, <&clk0_ad9523 5>;
		clock-names = "jesd_adc_clk", "adc_clk", "adc_sysref";
