AD9371 ILAS reboot
Hi Sir,
We met the issue of AD9371 ILAS reboot on board which the log is as below. Would you kind to have some recommends for this ? Thanks.
warning_and_reboot.txt
    3.988905] ad9371 spi1.0: ad9371_probe : enter
[    3.993430] enter
[    3.995362] devm_clk_get
[    3.997905] devm_iio_device_alloc
[    4.001230] ad9371_alloc_mykonos_device
[    4.005786] ad9371_phy_parse_dt
[    4.018937] phy->reset_gpio
[    4.021730] phy->sysref_req_gpio
[    4.024965] phy->jesd_rx_clk
[    4.027859] phy->jesd_rx_os_clk
[    4.031016] dev_clk
[    4.033134] fmc_clk
[    4.035299] ad9371_setup: dev_clk=153600000 ,fmc_clk=153600000
[    4.041128] rx->rxProfile->iqRate_kHz=153600
[    4.045387] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.050950] obsRx->orxProfile->iqRate_kHz=307200
[    4.055559] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.061122] tx->txProfile->iqRate_kHz=307200
[    4.065385] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.810795] MYKONOS_checkPllsLockStatus: pllLock=1
[    4.815713] ad9371_sysref_req:ad9371_sysref_req_mode=2
[    4.820845] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[    5.263540] MYKONOS_setRfPllFrequency: rxpllLock=3
[    5.291540] MYKONOS_setRfPllFrequency: txpllLock=7
[    5.319540] WT:obsRxpllfreq=555032704
[    5.323277] MYKONOS_setRfPllFrequency: obspllLock=15
[    5.328434] MYKONOS_checkPllsLockStatus: pllLock=15
[   14.811540] TX_LO_LEAKAGE_INTERNAL1 ok
[   14.817581] ad9371_sysref_req:ad9371_sysref_req_mode=0
[   14.822714] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[   14.832201] ad9371_sysref_req:ad9371_sysref_req_mode=1
[   14.837327] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[   14.842866] Check Mykonos Framer Status: framerStatus=62
[   14.848317] WT: Check Mykonos OrxFramer Status: framerStatus=62
[   14.854372] ad9371 spi1.0: deframerStatus (0x21)
[   14.858986] Check Mykonos Framer Status: deframerStatus=33
[   14.865814] WARNING: 136: Mismatch detected in MYKONOS_jesd204bIlasCheck()
[   14.872686] ad9371 spi1.0: ILAS mismatch: c7f8
[   14.877116] Check Mykonos mismatch: mismatch=51192
[   14.881987] ad9371 spi1.0: ILAS lanes per converter did not match
[   14.888071] ad9371 spi1.0: ILAS scrambling did not match
[   14.893375] ad9371 spi1.0: ILAS octets per frame did not match
[   14.899199] ad9371 spi1.0: ILAS frames per multiframe did not match
[   14.905459] ad9371 spi1.0: ILAS number of converters did not match
[   14.911630] ad9371 spi1.0: ILAS sample resolution did not match
[   14.917540] ad9371 spi1.0: ILAS control bits per sample did not match
[   14.923972] ad9371 spi1.0: ILAS bits per sample did not match
[   14.929709] ad9371 spi1.0: ILAS checksum did not match
[   14.969488] random: crng init done
[   15.020013] ad9371_setup
[   15.024802] ad9371 spi1.0: ad9371_probe : AD9370 Rev 4, Firmware 5.2.2 API version: 1.5.2.3566 successfully initialized
[ 3.993430] enter
[ 4.031016] dev_clk
[ 4.033134] fmc_clk
Top Replies
