I am trying to build the software for the ADRV9002-ZCU102 from source. I have followed Building the ZynqMP / MPSoC Linux kernel and devicetrees from source with some luck but still having issues. I tried building with the Petalinux flow and with the open source linux flow using the ADI scripts. Attached are my notes and dmesg output logs for these builds along with the pre-built images from ADI. I am using Ubuntu 18.04 for host machine. Any help would be much appreciated.
Elliott
ADRV9002-ZCU102-OSL-2019.1.pdfPDF
Xilinx Zynq MP First Stage Boot Loader Release 2019.1 Mar 1 2021 - 19:06:13 NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000 NOTICE: BL31: Secure code at 0x0 NOTICE: BL31: Non secure code at 0x8000000 NOTICE: BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790 NOTICE: BL31: Built : 19:31:07, Mar 1 2021 PMUFW: v1.1 U-Boot 2018.01 (Jun 29 2018 - 13:20:51 +0200) Xilinx ZynqMP ZCU102 rev1.0 I2C: ready DRAM: 4 GiB EL Level: EL2 Chip ID: zu9eg MMC: sdhci@ff170000: 0 (SD) *** Warning - bad CRC, using default environment In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 Bootmode: LVL_SHFT_SD_MODE1 Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id Warning: ethernet@ff0e0000 using MAC address from ROM eth0: ethernet@ff0e0000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Device: sdhci@ff170000 Manufacturer ID: 3 OEM: 5344 Name: SL16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.8 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes reading uEnv.txt 392 bytes read in 11 ms (34.2 KiB/s) Loaded environment from uEnv.txt Importing environment from SD ... Running uenvcmd ... Copying Linux from SD to RAM... ** No boot file defined ** reading system.dtb 43253 bytes read in 24 ms (1.7 MiB/s) reading Image 29737472 bytes read in 1954 ms (14.5 MiB/s) ## Flattened Device Tree blob at 04000000 Booting using the fdt blob at 0x4000000 Loading Device Tree to 000000000fff2000, end 000000000ffff8f4 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-ged92237ed726 (enelson@elliott-linux) (gcc version 8.2.0 (GCC)) #1 SMP Mon Mar 1 18:29:55 CST 2021 [ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0 [ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8') [ 0.000000] bootconsole [cdns0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240 [ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait cpuidle.off=1 root=/dev/mmcblk0p2 rw rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB) [ 0.000000] Memory: 3772376K/4194304K available (12796K kernel code, 1520K rwdata, 13828K rodata, 832K init, 326K bss, 159784K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns [ 0.000004] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns [ 0.008270] Console: colour dummy device 80x25 [ 0.012392] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960) [ 0.022757] pid_max: default: 32768 minimum: 301 [ 0.027450] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.041796] ASID allocator initialised with 32768 entries [ 0.046510] rcu: Hierarchical SRCU implementation. [ 0.051556] EFI services will not be available. [ 0.055827] smp: Bringing up secondary CPUs ... [ 0.060487] Detected VIPT I-cache on CPU1 [ 0.060515] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.060819] Detected VIPT I-cache on CPU2 [ 0.060839] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.061122] Detected VIPT I-cache on CPU3 [ 0.061141] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.061185] smp: Brought up 1 node, 4 CPUs [ 0.095681] SMP: Total of 4 processors activated. [ 0.100355] CPU features: detected: 32-bit EL0 Support [ 0.106867] CPU: All CPU(s) started at EL2 [ 0.109534] alternatives: patching kernel code [ 0.114850] devtmpfs: initialized [ 0.122447] Registered cp15_barrier emulation handler [ 0.122495] Registered setend emulation handler [ 0.126851] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.136437] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.148116] xor: measuring software checksum speed [ 0.186642] 8regs : 2375.000 MB/sec [ 0.226671] 8regs_prefetch: 2052.000 MB/sec [ 0.266701] 32regs : 2724.000 MB/sec [ 0.306730] 32regs_prefetch: 2308.000 MB/sec [ 0.306770] xor: using function: 32regs (2724.000 MB/sec) [ 0.311077] pinctrl core: initialized pinctrl subsystem [ 0.316865] NET: Registered protocol family 16 [ 0.321061] audit: initializing netlink subsys (disabled) [ 0.326098] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1 [ 0.333737] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.333742] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.348492] DMA: preallocated 256 KiB pool for atomic allocations [ 0.367893] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.436481] raid6: int64x1 gen() 445 MB/s [ 0.504461] raid6: int64x1 xor() 451 MB/s [ 0.572496] raid6: int64x2 gen() 679 MB/s [ 0.640544] raid6: int64x2 xor() 599 MB/s [ 0.708593] raid6: int64x4 gen() 980 MB/s [ 0.776677] raid6: int64x4 xor() 737 MB/s [ 0.844692] raid6: int64x8 gen() 1162 MB/s [ 0.912757] raid6: int64x8 xor() 759 MB/s [ 0.980855] raid6: neonx1 gen() 736 MB/s [ 1.048849] raid6: neonx1 xor() 880 MB/s [ 1.116938] raid6: neonx2 gen() 1129 MB/s [ 1.184965] raid6: neonx2 xor() 1174 MB/s [ 1.253045] raid6: neonx4 gen() 1479 MB/s [ 1.321070] raid6: neonx4 xor() 1418 MB/s [ 1.389108] raid6: neonx8 gen() 1551 MB/s [ 1.457173] raid6: neonx8 xor() 1459 MB/s [ 1.457211] raid6: using algorithm neonx8 gen() 1551 MB/s [ 1.461169] raid6: .... xor() 1459 MB/s, rmw enabled [ 1.466100] raid6: using neon recovery algorithm [ 1.471426] SCSI subsystem initialized [ 1.474571] usbcore: registered new interface driver usbfs [ 1.479888] usbcore: registered new interface driver hub [ 1.485162] usbcore: registered new device driver usb [ 1.490313] media: Linux media interface: v0.10 [ 1.494669] videodev: Linux video capture interface: v2.00 [ 1.500150] pps_core: LinuxPPS API ver. 1 registered [ 1.505030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.514123] PTP clock support registered [ 1.518021] EDAC MC: Ver: 3.0.0 [ 1.521528] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 1.528800] jesd204: found 0 devices and 0 topologies [ 1.533441] FPGA manager framework [ 1.536945] Advanced Linux Sound Architecture Driver Initialized. [ 1.543106] Bluetooth: Core ver 2.22 [ 1.546393] NET: Registered protocol family 31 [ 1.550793] Bluetooth: HCI device and connection manager initialized [ 1.557110] Bluetooth: HCI socket layer initialized [ 1.561953] Bluetooth: L2CAP socket layer initialized [ 1.566981] Bluetooth: SCO socket layer initialized [ 1.572317] clocksource: Switched to clocksource arch_sys_counter [ 1.577958] VFS: Disk quotas dquot_6.6.0 [ 1.581810] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.593081] NET: Registered protocol family 2 [ 1.593462] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes) [ 1.600752] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.608089] TCP bind hash table entries: 32768 (order: 7, 524288 bytes) [ 1.614862] TCP: Hash tables configured (established 32768 bind 32768) [ 1.621012] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 1.626990] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 1.633474] NET: Registered protocol family 1 [ 1.637857] RPC: Registered named UNIX socket transport module. [ 1.643535] RPC: Registered udp transport module. [ 1.648202] RPC: Registered tcp transport module. [ 1.652874] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.660012] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 1.666512] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.674925] Initialise system trusted keyrings [ 1.678541] workingset: timestamp_bits=62 max_order=20 bucket_order=0 [ 1.685577] NFS: Registering the id_resolver key type [ 1.689911] Key type id_resolver registered [ 1.694051] Key type id_legacy registered [ 1.698036] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.704702] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 2.793303] NET: Registered protocol family 38 [ 2.852005] Key type asymmetric registered [ 2.852042] Asymmetric key parser 'x509' registered [ 2.855347] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.862664] io scheduler noop registered [ 2.866555] io scheduler deadline registered [ 2.870818] io scheduler cfq registered (default) [ 2.875467] io scheduler mq-deadline registered [ 2.879964] io scheduler kyber registered [ 2.913699] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.918134] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 2.924991] brd: module loaded [ 2.928923] loop: module loaded [ 2.929146] Registered mathworks_ip class [ 2.931457] mtdoops: mtd device (mtddev=name/number) must be supplied [ 2.938457] libphy: Fixed MDIO Bus: probed [ 2.942197] tun: Universal TUN/TAP device driver, 1.6 [ 2.946198] CAN device driver interface [ 2.950896] usbcore: registered new interface driver asix [ 2.955288] usbcore: registered new interface driver ax88179_178a [ 2.961325] usbcore: registered new interface driver cdc_ether [ 2.967117] usbcore: registered new interface driver net1080 [ 2.972740] usbcore: registered new interface driver cdc_subset [ 2.978623] usbcore: registered new interface driver zaurus [ 2.984167] usbcore: registered new interface driver cdc_ncm [ 2.990523] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.996251] ehci-pci: EHCI PCI platform driver [ 3.000949] usbcore: registered new interface driver uas [ 3.005969] usbcore: registered new interface driver usb-storage [ 3.011965] usbcore: registered new interface driver usbserial_generic [ 3.018416] usbserial: USB Serial support registered for generic [ 3.024385] usbcore: registered new interface driver ftdi_sio [ 3.030090] usbserial: USB Serial support registered for FTDI USB Serial Device [ 3.037361] usbcore: registered new interface driver upd78f0730 [ 3.043239] usbserial: USB Serial support registered for upd78f0730 [ 3.050882] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 3.056699] i2c /dev entries driver [ 3.062189] usbcore: registered new interface driver uvcvideo [ 3.065813] USB Video Class driver (1.1.1) [ 3.071294] Bluetooth: HCI UART driver ver 2.3 [ 3.074288] Bluetooth: HCI UART protocol H4 registered [ 3.079384] Bluetooth: HCI UART protocol BCSP registered [ 3.084681] Bluetooth: HCI UART protocol LL registered [ 3.089764] Bluetooth: HCI UART protocol ATH3K registered [ 3.095147] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 3.101397] Bluetooth: HCI UART protocol Intel registered [ 3.106739] Bluetooth: HCI UART protocol QCA registered [ 3.111945] usbcore: registered new interface driver bcm203x [ 3.117560] usbcore: registered new interface driver bpa10x [ 3.123098] usbcore: registered new interface driver bfusb [ 3.128547] usbcore: registered new interface driver btusb [ 3.133970] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 3.139636] usbcore: registered new interface driver ath3k [ 3.145170] EDAC MC: ECC not enabled [ 3.148872] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 3.161047] CPUidle arm: Failed to register cpuidle driver [ 3.166328] sdhci: Secure Digital Host Controller Interface driver [ 3.172294] sdhci: Copyright(c) Pierre Ossman [ 3.176618] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.182641] ledtrig-cpu: registered to indicate activity on CPUs [ 3.188258] zynqmp_firmware_probe Platform Management API v1.1 [ 3.194011] zynqmp_firmware_probe Trustzone version v1.0 [ 3.202145] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 3.229778] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 3.232495] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 3.237599] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 3.237599] [ 3.245117] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 3.251238] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 3.256838] usbcore: registered new interface driver usbhid [ 3.262154] usbhid: USB HID core driver [ 3.273085] axi_sysid 85000000.axi-sysid-0: [adrv9001] [CMOS_LVDS_N=0] on [zcu102] git <061d024d596ef84c6a819854bf2472e6b43a2d5d> clean [2021-03-02 00:02:39] UTC [ 3.282185] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 3.288793] usbcore: registered new interface driver snd-usb-audio [ 3.296223] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 3.302300] Initializing XFRM netlink socket [ 3.306225] NET: Registered protocol family 10 [ 3.310924] Segment Routing with IPv6 [ 3.314284] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.320445] NET: Registered protocol family 17 [ 3.324497] NET: Registered protocol family 15 [ 3.328914] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 3.342236] can: controller area network core (rev 20170425 abi 9) [ 3.347981] NET: Registered protocol family 29 [ 3.352346] can: raw protocol (rev 20170425) [ 3.356583] can: broadcast manager protocol (rev 20170425 t) [ 3.362208] can: netlink gateway (rev 20170425) max_hops=1 [ 3.367722] Bluetooth: RFCOMM TTY layer initialized [ 3.372509] Bluetooth: RFCOMM socket layer initialized [ 3.377627] Bluetooth: RFCOMM ver 1.11 [ 3.381329] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.386601] Bluetooth: BNEP filters: protocol multicast [ 3.391793] Bluetooth: BNEP socket layer initialized [ 3.396722] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.402606] Bluetooth: HIDP socket layer initialized [ 3.407638] 9pnet: Installing 9P2000 support [ 3.411783] NET: Registered protocol family 36 [ 3.416201] Key type dns_resolver registered [ 3.420930] registered taskstats version 1 [ 3.424497] Loading compiled-in X.509 certificates [ 3.429583] Btrfs loaded, crc32c=crc32c-generic [ 3.440183] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps [ 3.449335] console [ttyPS0] enabled [ 3.449335] console [ttyPS0] enabled [ 3.452937] bootconsole [cdns0] disabled [ 3.452937] bootconsole [cdns0] disabled [ 3.461032] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps [ 3.474374] of-fpga-region fpga-full: FPGA Region probed [ 3.480218] nwl-pcie fd0e0000.pcie: Link is DOWN [ 3.484872] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges: [ 3.491847] nwl-pcie fd0e0000.pcie: MEM 0xe0000000..0xefffffff -> 0xe0000000 [ 3.499068] nwl-pcie fd0e0000.pcie: MEM 0x600000000..0x7ffffffff -> 0x600000000 [ 3.506652] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00 [ 3.512835] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.518317] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff] [ 3.525186] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref] [ 3.537397] pci 0000:00:00.0: PCI bridge to [bus 01-0c] [ 3.543859] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed [ 3.550446] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 3.557557] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 3.564668] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 3.571773] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 3.578876] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 3.585987] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 3.593099] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 3.600206] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 3.607468] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes [ 3.618897] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13 [ 3.627578] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed [ 3.638384] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed [ 3.646499] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed [ 3.654994] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 3.667432] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 3.680115] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed [ 3.690303] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000 [ 3.697340] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.703950] [drm] No driver support for vblank timestamp query. [ 3.709929] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008dc2e70) [ 4.796328] [drm] Cannot find any crtc or sizes [ 4.801082] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0 [ 4.809189] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed [ 4.818176] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes [ 4.826063] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode [ 4.835017] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst [ 4.845459] scsi host0: ahci-ceva [ 4.849034] scsi host1: ahci-ceva [ 4.852487] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37 [ 4.860401] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37 [ 4.873061] m25p80 spi0.0: SPI-NOR-UniqueID 1044004eeb0300020b000d0044c4464ce7 [ 4.880290] m25p80 spi0.0: found n25q512a, expected m25p80 [ 4.886051] m25p80 spi0.0: n25q512a (131072 Kbytes) [ 4.890948] 4 fixed-partitions partitions found on MTD device spi0.0 [ 4.897296] Creating 4 MTD partitions on "spi0.0": [ 4.902082] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot" [ 4.908282] 0x000000100000-0x000000600000 : "qspi-linux" [ 4.913989] 0x000000600000-0x000000620000 : "qspi-device-tree" [ 4.920201] 0x000000620000-0x000000c00000 : "qspi-rootfs" [ 4.928073] macb ff0e0000.ethernet: Not enabling partial store and forward [ 4.935446] libphy: MACB_mii_bus: probed [ 4.939443] mdio_bus ff0e0000.ethernet-ffffffff: MDIO device at address 21 is missing. [ 4.949625] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL) [ 4.962664] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 22 (00:0a:35:07:0a:79) [ 4.972814] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 4.979345] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 4.985839] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 4.992346] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 5.000306] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2 [ 5.006156] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes [ 5.014513] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 5.020005] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 5.027991] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810 [ 5.037402] xhci-hcd xhci-hcd.0.auto: irq 50, io mem 0xfe200000 [ 5.043534] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 5.051796] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.059017] usb usb1: Product: xHCI Host Controller [ 5.063891] usb usb1: Manufacturer: Linux 4.19.0-ged92237ed726 xhci-hcd [ 5.070497] usb usb1: SerialNumber: xhci-hcd.0.auto [ 5.075639] hub 1-0:1.0: USB hub found [ 5.079410] hub 1-0:1.0: 1 port detected [ 5.083522] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 5.089005] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 5.096661] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 5.103384] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 5.111641] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.118859] usb usb2: Product: xHCI Host Controller [ 5.123728] usb usb2: Manufacturer: Linux 4.19.0-ged92237ed726 xhci-hcd [ 5.130335] usb usb2: SerialNumber: xhci-hcd.0.auto [ 5.135447] hub 2-0:1.0: USB hub found [ 5.139209] hub 2-0:1.0: 1 port detected [ 5.144375] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator [ 5.151624] pca953x 0-0020: Linked as a consumer to regulator.0 [ 5.158416] GPIO line 496 (sel0) hogged as output/low [ 5.163799] GPIO line 497 (sel1) hogged as output/high [ 5.169266] GPIO line 498 (sel2) hogged as output/high [ 5.174735] GPIO line 499 (sel3) hogged as output/high [ 5.180073] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator [ 5.182510] ata2: SATA link down (SStatus 0 SControl 330) [ 5.187327] pca953x 0-0021: Linked as a consumer to regulator.0 [ 5.192714] ata1: SATA link down (SStatus 0 SControl 330) [ 5.200121] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.210796] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.217607] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.224428] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.231245] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.238061] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.244879] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.251704] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.258519] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.265329] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.271740] i2c i2c-0: Added multiplexed i2c bus 3 [ 5.277210] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm) [ 5.284034] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.290849] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.297664] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.304482] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.311297] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.318111] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.324929] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.331337] i2c i2c-0: Added multiplexed i2c bus 4 [ 5.356214] random: fast init done [ 5.373830] i2c i2c-0: Added multiplexed i2c bus 5 [ 5.378800] i2c i2c-0: Added multiplexed i2c bus 6 [ 5.383587] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544 [ 5.390940] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24 [ 5.398766] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write [ 5.405522] i2c i2c-1: Added multiplexed i2c bus 7 [ 5.410658] i2c i2c-1: Added multiplexed i2c bus 8 [ 5.417579] si570 9-005d: registered, current frequency 300000000 Hz [ 5.423973] i2c i2c-1: Added multiplexed i2c bus 9 [ 5.442794] si570 10-005d: registered, current frequency 148500000 Hz [ 5.449281] i2c i2c-1: Added multiplexed i2c bus 10 [ 5.454369] si5324 11-0069: si5328 probed [ 5.516396] si5324 11-0069: si5328 probe successful [ 5.521323] i2c i2c-1: Added multiplexed i2c bus 11 [ 5.526365] i2c i2c-1: Added multiplexed i2c bus 12 [ 5.531402] i2c i2c-1: Added multiplexed i2c bus 13 [ 5.536444] i2c i2c-1: Added multiplexed i2c bus 14 [ 5.541319] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548 [ 5.549284] i2c i2c-1: Added multiplexed i2c bus 15 [ 5.581023] i2c i2c-1: Added multiplexed i2c bus 16 [ 5.586072] i2c i2c-1: Added multiplexed i2c bus 17 [ 5.591114] i2c i2c-1: Added multiplexed i2c bus 18 [ 5.596159] i2c i2c-1: Added multiplexed i2c bus 19 [ 5.601202] i2c i2c-1: Added multiplexed i2c bus 20 [ 5.606248] i2c i2c-1: Added multiplexed i2c bus 21 [ 5.611292] i2c i2c-1: Added multiplexed i2c bus 22 [ 5.616164] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548 [ 5.623777] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25 [ 5.630181] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s [ 5.670222] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 5.805605] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 5.812657] mmcblk0: mmc0:aaaa SL16G 14.8 GiB [ 5.822359] mmcblk0: p1 p2 p3 [ 5.960345] [drm] Cannot find any crtc or sizes [ 6.798012] random: crng init done [ 12.222337] adrv9002 spi1.0: [ERROR]: Error number 3 (0x00000003), Recovery action -101.In file drivers/iio/adc/navassa/devices/adrv9001/public/src/adi_adrv9001_arm.c, in function adi_adrv9001_arm_StartStatus_Check, in line 183, variable name device.Error message Timed out waiting for ARM bootup to happen. [ 12.249616] adrv9002 spi1.0: adrv9002_digital_init, 2102: failed with "Timed out waiting for ARM bootup to happen" (3) [ 18.714038] adrv9002 spi1.0: [ERROR]: Error number 3 (0x00000003), Recovery action -101.In file drivers/iio/adc/navassa/devices/adrv9001/public/src/adi_adrv9001_arm.c, in function adi_adrv9001_arm_StartStatus_Check, in line 183, variable name device.Error message Timed out waiting for ARM bootup to happen. [ 18.741317] adrv9002 spi1.0: adrv9002_digital_init, 2102: failed with "Timed out waiting for ARM bootup to happen" (3) [ 18.752034] cf_axi_adc: probe of 84a00000.axi-adrv9002-rx-lpc failed with error -14 [ 18.760882] cf_axi_tdd 84a0c800.axi-adrv9002-core-tdd1-lpc: Analog Devices CF_AXI_TDD MASTER (1.00.a) [ 18.770541] cf_axi_tdd 84a0cc00.axi-adrv9002-core-tdd2-lpc: Analog Devices CF_AXI_TDD MASTER (1.00.a) [ 18.796575] cf_axi_dds 84a0a000.axi-adrv9002-tx-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A0A000 mapped to 0x0000000047de9616, probed DDS ADRV9002 [ 18.828567] cf_axi_dds 84a0c000.axi-adrv9002-tx2-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A0C000 mapped to 0x00000000df57f049, probed DDS ADRV9002 [ 18.845665] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 18.852643] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-03-02 16:47:33 UTC (1614703653) [ 18.861514] of_cfs_init [ 18.863972] of_cfs_init: OK [ 18.866896] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 19.005820] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 19.012429] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13 [ 19.020255] ALSA device list: [ 19.023213] #0: DisplayPort monitor [ 19.027239] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 19.035850] cfg80211: failed to load regulatory.db [ 19.052063] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 19.060169] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 19.073057] devtmpfs: mounted [ 19.076187] Freeing unused kernel memory: 832K [ 19.092345] Run /sbin/init as init process Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory * Setting up X socket directories... [ OK ] * STARTDISTCC is set to false in /etc/default/distcc * /usr/bin/distccd not starting * Starting IIO Daemon iiod [ OK ] Last login: Tue Mar 2 16:43:17 UTC 2021 on tty1 Welcome to Linaro 14.04 (GNU/Linux 4.19.0-ged92237ed726 aarch64) * Documentation: https://wiki.analog.com/ https://ez.analog.com/ New release '16.04.7 LTS' available. Run 'do-release-upgrade' to upgrade to it. root@analog:~#
Xilinx Zynq MP First Stage Boot Loader Release 2019.1 Mar 2 2021 - 03:17:13 NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000 NOTICE: BL31: Secure code at 0x0 NOTICE: BL31: Non secure code at 0x8000000 NOTICE: BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790 NOTICE: BL31: Built : 03:13:47, Mar 2 2021 PMUFW: v1.1 U-Boot 2019.01 (Mar 02 2021 - 03:34:04 +0000) Model: ZynqMP ZCU102 Rev1.0 Board: Xilinx ZynqMP DRAM: 4 GiB EL Level: EL2 Chip ID: zu9eg MMC: mmc@ff170000: 0 Loading Environment from SPI Flash... SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB *** Warning - bad CRC, using default environment In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 Model: ZynqMP ZCU102 Rev1.0 Board: Xilinx ZynqMP Bootmode: LVL_SHFT_SD_MODE1 Reset reason: EXTERNAL Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id eth0: ethernet@ff0e0000 U-BOOT for petalinux-adi-1 ethernet@ff0e0000 Waiting for PHY auto negotiation to complete..... done BOOTP broadcast 1 DHCP client bound to address 192.168.1.11 (6 ms) Hit any key to stop autoboot: 0 392 bytes read in 9 ms (42 KiB/s) Loaded environment from uEnv.txt Importing environment from SD ... Running uenvcmd ... Copying Linux from SD to RAM... ** No boot file defined ** Device: mmc@ff170000 Manufacturer ID: 3 OEM: 5344 Name: SL16G Bus Speed: 100000000 Mode : UHS SDR50 (100MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.8 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes 38972876 bytes read in 2656 ms (14 MiB/s) ## Loading kernel from FIT Image at 10000000 ... Using 'conf@system-top.dtb' configuration Trying 'kernel@1' kernel subimage Description: Linux kernel Type: Kernel Image Compression: uncompressed Data Start: 0x10000104 Data Size: 30007808 Bytes = 28.6 MiB Architecture: AArch64 OS: Linux Load Address: 0x00080000 Entry Point: 0x00080000 Hash algo: sha1 Hash value: 48191dfa13ce482a08105a4a6b814b896f38b62b Verifying Hash Integrity ... sha1+ OK ## Loading ramdisk from FIT Image at 10000000 ... Using 'conf@system-top.dtb' configuration Trying 'ramdisk@1' ramdisk subimage Description: petalinux-user-image Type: RAMDisk Image Compression: gzip compressed Data Start: 0x11ca9ee8 Data Size: 8915284 Bytes = 8.5 MiB Architecture: AArch64 OS: Linux Load Address: unavailable Entry Point: unavailable Hash algo: sha1 Hash value: 769e4fe5338059343257a1b06a8673f689dfa8ec Verifying Hash Integrity ... sha1+ OK ## Loading fdt from FIT Image at 10000000 ... Using 'conf@system-top.dtb' configuration Trying 'fdt@system-top.dtb' fdt subimage Description: Flattened Device Tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x11c9e408 Data Size: 47643 Bytes = 46.5 KiB Architecture: AArch64 Hash algo: sha1 Hash value: 8d100ca73a2502a2b7b0fe6446638086c776c3ed Verifying Hash Integrity ... sha1+ OK Booting using the fdt blob at 0x11c9e408 Loading Kernel Image ... OK Loading Ramdisk to 0777f000, end 07fff954 ... OK Loading Device Tree to 0000000007770000, end 000000000777ea1a ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Tue Mar 2 03:31:46 UTC 2021 [ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0 [ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8') [ 0.000000] bootconsole [cdns0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0 [ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240 [ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait cpuidle.off=1 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB) [ 0.000000] Memory: 3763372K/4194304K available (12924K kernel code, 1528K rwdata, 13880K rodata, 896K init, 335K bss, 168788K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns [ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns [ 0.008270] Console: colour dummy device 80x25 [ 0.012393] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960) [ 0.022756] pid_max: default: 32768 minimum: 301 [ 0.027448] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.041789] ASID allocator initialised with 32768 entries [ 0.046509] rcu: Hierarchical SRCU implementation. [ 0.051556] EFI services will not be available. [ 0.055828] smp: Bringing up secondary CPUs ... [ 0.060486] Detected VIPT I-cache on CPU1 [ 0.060516] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.060822] Detected VIPT I-cache on CPU2 [ 0.060841] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.061124] Detected VIPT I-cache on CPU3 [ 0.061143] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.061186] smp: Brought up 1 node, 4 CPUs [ 0.095682] SMP: Total of 4 processors activated. [ 0.100355] CPU features: detected: 32-bit EL0 Support [ 0.106870] CPU: All CPU(s) started at EL2 [ 0.109534] alternatives: patching kernel code [ 0.114848] devtmpfs: initialized [ 0.122420] Registered cp15_barrier emulation handler [ 0.122468] Registered setend emulation handler [ 0.126852] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.136439] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.148109] xor: measuring software checksum speed [ 0.186641] 8regs : 2375.000 MB/sec [ 0.226668] 8regs_prefetch: 2051.000 MB/sec [ 0.266698] 32regs : 2724.000 MB/sec [ 0.306727] 32regs_prefetch: 2308.000 MB/sec [ 0.306769] xor: using function: 32regs (2724.000 MB/sec) [ 0.311078] pinctrl core: initialized pinctrl subsystem [ 0.316871] NET: Registered protocol family 16 [ 0.321007] audit: initializing netlink subsys (disabled) [ 0.326101] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1 [ 0.333737] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.333744] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.348513] DMA: preallocated 256 KiB pool for atomic allocations [ 0.367719] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.436502] raid6: int64x1 gen() 445 MB/s [ 0.504496] raid6: int64x1 xor() 450 MB/s [ 0.572557] raid6: int64x2 gen() 680 MB/s [ 0.640595] raid6: int64x2 xor() 599 MB/s [ 0.708601] raid6: int64x4 gen() 980 MB/s [ 0.776688] raid6: int64x4 xor() 737 MB/s [ 0.844736] raid6: int64x8 gen() 1162 MB/s [ 0.912764] raid6: int64x8 xor() 759 MB/s [ 0.980863] raid6: neonx1 gen() 735 MB/s [ 1.048891] raid6: neonx1 xor() 880 MB/s [ 1.116920] raid6: neonx2 gen() 1128 MB/s [ 1.184974] raid6: neonx2 xor() 1172 MB/s [ 1.253020] raid6: neonx4 gen() 1479 MB/s [ 1.321081] raid6: neonx4 xor() 1417 MB/s [ 1.389160] raid6: neonx8 gen() 1536 MB/s [ 1.457196] raid6: neonx8 xor() 1459 MB/s [ 1.457234] raid6: using algorithm neonx8 gen() 1536 MB/s [ 1.461186] raid6: .... xor() 1459 MB/s, rmw enabled [ 1.466116] raid6: using neon recovery algorithm [ 1.471499] SCSI subsystem initialized [ 1.474578] usbcore: registered new interface driver usbfs [ 1.479905] usbcore: registered new interface driver hub [ 1.485181] usbcore: registered new device driver usb [ 1.490335] media: Linux media interface: v0.10 [ 1.494688] videodev: Linux video capture interface: v2.00 [ 1.500164] pps_core: LinuxPPS API ver. 1 registered [ 1.505047] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.514140] PTP clock support registered [ 1.518038] EDAC MC: Ver: 3.0.0 [ 1.521529] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 1.528756] jesd204: found 0 devices and 0 topologies [ 1.533458] FPGA manager framework [ 1.536964] Advanced Linux Sound Architecture Driver Initialized. [ 1.543124] Bluetooth: Core ver 2.22 [ 1.546411] NET: Registered protocol family 31 [ 1.550811] Bluetooth: HCI device and connection manager initialized [ 1.557127] Bluetooth: HCI socket layer initialized [ 1.561970] Bluetooth: L2CAP socket layer initialized [ 1.566998] Bluetooth: SCO socket layer initialized [ 1.572259] clocksource: Switched to clocksource arch_sys_counter [ 1.577970] VFS: Disk quotas dquot_6.6.0 [ 1.581858] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.592854] NET: Registered protocol family 2 [ 1.593287] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes) [ 1.600771] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.608105] TCP bind hash table entries: 32768 (order: 7, 524288 bytes) [ 1.614877] TCP: Hash tables configured (established 32768 bind 32768) [ 1.621031] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 1.627008] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 1.633485] NET: Registered protocol family 1 [ 1.637878] RPC: Registered named UNIX socket transport module. [ 1.643553] RPC: Registered udp transport module. [ 1.648218] RPC: Registered tcp transport module. [ 1.652891] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.659631] Trying to unpack rootfs image as initramfs... [ 2.021089] Freeing initrd memory: 8704K [ 2.021544] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 2.026642] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 2.035100] Initialise system trusted keyrings [ 2.038651] workingset: timestamp_bits=62 max_order=20 bucket_order=0 [ 2.045692] NFS: Registering the id_resolver key type [ 2.050015] Key type id_resolver registered [ 2.054155] Key type id_legacy registered [ 2.058137] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.064804] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 3.160343] NET: Registered protocol family 38 [ 3.219990] Key type asymmetric registered [ 3.220029] Asymmetric key parser 'x509' registered [ 3.223333] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 3.230647] io scheduler noop registered [ 3.234536] io scheduler deadline registered [ 3.238806] io scheduler cfq registered (default) [ 3.243447] io scheduler mq-deadline registered [ 3.247945] io scheduler kyber registered [ 3.280435] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 3.285303] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 3.291666] brd: module loaded [ 3.295586] loop: module loaded [ 3.295812] Registered mathworks_ip class [ 3.298213] mtdoops: mtd device (mtddev=name/number) must be supplied [ 3.305244] libphy: Fixed MDIO Bus: probed [ 3.308992] tun: Universal TUN/TAP device driver, 1.6 [ 3.312926] CAN device driver interface [ 3.317659] usbcore: registered new interface driver asix [ 3.322022] usbcore: registered new interface driver ax88179_178a [ 3.328059] usbcore: registered new interface driver cdc_ether [ 3.333855] usbcore: registered new interface driver net1080 [ 3.339477] usbcore: registered new interface driver cdc_subset [ 3.345366] usbcore: registered new interface driver zaurus [ 3.350905] usbcore: registered new interface driver cdc_ncm [ 3.357263] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.362986] ehci-pci: EHCI PCI platform driver [ 3.367688] usbcore: registered new interface driver uas [ 3.372707] usbcore: registered new interface driver usb-storage [ 3.378702] usbcore: registered new interface driver usbserial_generic [ 3.385149] usbserial: USB Serial support registered for generic [ 3.391122] usbcore: registered new interface driver ftdi_sio [ 3.396827] usbserial: USB Serial support registered for FTDI USB Serial Device [ 3.404097] usbcore: registered new interface driver upd78f0730 [ 3.409979] usbserial: USB Serial support registered for upd78f0730 [ 3.417656] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 3.423433] i2c /dev entries driver [ 3.428964] usbcore: registered new interface driver uvcvideo [ 3.432538] USB Video Class driver (1.1.1) [ 3.438026] Bluetooth: HCI UART driver ver 2.3 [ 3.441022] Bluetooth: HCI UART protocol H4 registered [ 3.446120] Bluetooth: HCI UART protocol BCSP registered [ 3.451417] Bluetooth: HCI UART protocol LL registered [ 3.456500] Bluetooth: HCI UART protocol ATH3K registered [ 3.461880] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 3.468133] Bluetooth: HCI UART protocol Intel registered [ 3.473474] Bluetooth: HCI UART protocol QCA registered [ 3.478684] usbcore: registered new interface driver bcm203x [ 3.484297] usbcore: registered new interface driver bpa10x [ 3.489833] usbcore: registered new interface driver bfusb [ 3.495283] usbcore: registered new interface driver btusb [ 3.500707] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 3.506375] usbcore: registered new interface driver ath3k [ 3.511912] EDAC MC: ECC not enabled [ 3.515598] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 3.527779] CPUidle arm: Failed to register cpuidle driver [ 3.533066] sdhci: Secure Digital Host Controller Interface driver [ 3.539030] sdhci: Copyright(c) Pierre Ossman [ 3.543354] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.549395] ledtrig-cpu: registered to indicate activity on CPUs [ 3.554993] zynqmp_firmware_probe Platform Management API v1.1 [ 3.560748] zynqmp_firmware_probe Trustzone version v1.0 [ 3.568864] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 3.596430] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 3.599145] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 3.604282] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 3.604282] [ 3.611783] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 3.617908] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 3.623485] usbcore: registered new interface driver usbhid [ 3.628803] usbhid: USB HID core driver [ 3.639708] axi_sysid 85000000.axi-sysid-0: [adrv9001] [CMOS_LVDS_N=0] on [zcu102] git <4ae19031c0b8302472d081c01ca946cee3b84db7> clean [2021-03-02 00:55:45] UTC [ 3.648824] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 3.655409] usbcore: registered new interface driver snd-usb-audio [ 3.662851] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 3.668934] Initializing XFRM netlink socket [ 3.672862] NET: Registered protocol family 10 [ 3.677559] Segment Routing with IPv6 [ 3.680906] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.687047] NET: Registered protocol family 17 [ 3.691123] NET: Registered protocol family 15 [ 3.695539] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 3.708857] can: controller area network core (rev 20170425 abi 9) [ 3.714587] NET: Registered protocol family 29 [ 3.718970] can: raw protocol (rev 20170425) [ 3.723206] can: broadcast manager protocol (rev 20170425 t) [ 3.728832] can: netlink gateway (rev 20170425) max_hops=1 [ 3.734343] Bluetooth: RFCOMM TTY layer initialized [ 3.739132] Bluetooth: RFCOMM socket layer initialized [ 3.744243] Bluetooth: RFCOMM ver 1.11 [ 3.747952] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.753226] Bluetooth: BNEP filters: protocol multicast [ 3.758418] Bluetooth: BNEP socket layer initialized [ 3.763347] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.769232] Bluetooth: HIDP socket layer initialized [ 3.774270] 9pnet: Installing 9P2000 support [ 3.778409] NET: Registered protocol family 36 [ 3.782825] Key type dns_resolver registered [ 3.787518] registered taskstats version 1 [ 3.791122] Loading compiled-in X.509 certificates [ 3.796196] Btrfs loaded, crc32c=crc32c-generic [ 3.806885] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps [ 3.816273] console [ttyPS0] enabled [ 3.816273] console [ttyPS0] enabled [ 3.819865] bootconsole [cdns0] disabled [ 3.819865] bootconsole [cdns0] disabled [ 3.828112] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps [ 3.841330] of-fpga-region fpga-full: FPGA Region probed [ 3.847172] nwl-pcie fd0e0000.pcie: Link is DOWN [ 3.851817] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges: [ 3.858785] nwl-pcie fd0e0000.pcie: MEM 0xe0000000..0xefffffff -> 0xe0000000 [ 3.866006] nwl-pcie fd0e0000.pcie: MEM 0x600000000..0x7ffffffff -> 0x600000000 [ 3.873591] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00 [ 3.879773] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.885255] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff] [ 3.892125] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref] [ 3.904415] pci 0000:00:00.0: PCI bridge to [bus 01-0c] [ 3.910921] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed [ 3.917509] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 3.924614] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 3.931720] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 3.938825] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 3.945929] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 3.953037] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 3.960148] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 3.967257] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 3.974512] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes [ 3.986052] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13 [ 3.994734] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed [ 4.005531] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed [ 4.013642] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed [ 4.022364] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 4.034810] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 4.047487] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed [ 4.057679] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000 [ 4.064711] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 4.071320] [drm] No driver support for vblank timestamp query. [ 4.077294] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008de4370) [ 5.164272] [drm] Cannot find any crtc or sizes [ 5.169027] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0 [ 5.177136] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed [ 5.186125] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes [ 5.194007] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode [ 5.202962] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst [ 5.213416] scsi host0: ahci-ceva [ 5.216999] scsi host1: ahci-ceva [ 5.220459] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37 [ 5.228371] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37 [ 5.240988] m25p80 spi0.0: SPI-NOR-UniqueID 1044004eeb0300020b000d0044c4464ce7 [ 5.248208] m25p80 spi0.0: found n25q512a, expected m25p80 [ 5.253903] m25p80 spi0.0: n25q512a (131072 Kbytes) [ 5.258796] 4 fixed-partitions partitions found on MTD device spi0.0 [ 5.265137] Creating 4 MTD partitions on "spi0.0": [ 5.269923] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot" [ 5.276138] 0x000000100000-0x000000600000 : "qspi-linux" [ 5.281840] 0x000000600000-0x000000620000 : "qspi-device-tree" [ 5.288054] 0x000000620000-0x000000c00000 : "qspi-rootfs" [ 5.295932] macb ff0e0000.ethernet: Not enabling partial store and forward [ 5.303306] libphy: MACB_mii_bus: probed [ 5.307301] mdio_bus ff0e0000.ethernet-ffffffff: MDIO device at address 21 is missing. [ 5.320866] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL) [ 5.333908] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 22 (00:0a:35:00:22:01) [ 5.344147] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 5.350696] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 5.357184] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 5.363677] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 5.371732] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2 [ 5.377575] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes [ 5.385954] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 5.391448] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 5.399436] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810 [ 5.408846] xhci-hcd xhci-hcd.0.auto: irq 50, io mem 0xfe200000 [ 5.414978] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 5.423244] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.430458] usb usb1: Product: xHCI Host Controller [ 5.435326] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd [ 5.442018] usb usb1: SerialNumber: xhci-hcd.0.auto [ 5.447177] hub 1-0:1.0: USB hub found [ 5.450948] hub 1-0:1.0: 1 port detected [ 5.455058] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 5.460544] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 5.468198] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 5.474927] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 5.483188] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.490407] usb usb2: Product: xHCI Host Controller [ 5.495276] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd [ 5.501969] usb usb2: SerialNumber: xhci-hcd.0.auto [ 5.507077] hub 2-0:1.0: USB hub found [ 5.510845] hub 2-0:1.0: 1 port detected [ 5.516002] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator [ 5.523259] pca953x 0-0020: Linked as a consumer to regulator.0 [ 5.530055] GPIO line 496 (sel0) hogged as output/low [ 5.535434] GPIO line 497 (sel1) hogged as output/high [ 5.540900] GPIO line 498 (sel2) hogged as output/high [ 5.546365] GPIO line 499 (sel3) hogged as output/high [ 5.550464] ata2: SATA link down (SStatus 0 SControl 330) [ 5.551706] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator [ 5.556905] ata1: SATA link down (SStatus 0 SControl 330) [ 5.564117] pca953x 0-0021: Linked as a consumer to regulator.0 [ 5.576934] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.583760] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.590580] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.597395] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.604214] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.611027] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.617844] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.624663] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.631482] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.638294] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.644706] i2c i2c-0: Added multiplexed i2c bus 3 [ 5.650173] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm) [ 5.656999] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.663814] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.670631] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.677447] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.684270] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.691077] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.697896] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 5.704304] i2c i2c-0: Added multiplexed i2c bus 4 [ 5.729725] random: fast init done [ 5.747695] i2c i2c-0: Added multiplexed i2c bus 5 [ 5.752674] i2c i2c-0: Added multiplexed i2c bus 6 [ 5.757460] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544 [ 5.764813] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24 [ 5.772667] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write [ 5.779417] i2c i2c-1: Added multiplexed i2c bus 7 [ 5.784555] i2c i2c-1: Added multiplexed i2c bus 8 [ 5.791476] si570 9-005d: registered, current frequency 300000000 Hz [ 5.797874] i2c i2c-1: Added multiplexed i2c bus 9 [ 5.816694] si570 10-005d: registered, current frequency 148500000 Hz [ 5.823181] i2c i2c-1: Added multiplexed i2c bus 10 [ 5.828287] si5324 11-0069: si5328 probed [ 5.892346] si5324 11-0069: si5328 probe successful [ 5.897273] i2c i2c-1: Added multiplexed i2c bus 11 [ 5.902314] i2c i2c-1: Added multiplexed i2c bus 12 [ 5.907349] i2c i2c-1: Added multiplexed i2c bus 13 [ 5.912400] i2c i2c-1: Added multiplexed i2c bus 14 [ 5.917276] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548 [ 5.925246] i2c i2c-1: Added multiplexed i2c bus 15 [ 5.956996] i2c i2c-1: Added multiplexed i2c bus 16 [ 5.962045] i2c i2c-1: Added multiplexed i2c bus 17 [ 5.967089] i2c i2c-1: Added multiplexed i2c bus 18 [ 5.972134] i2c i2c-1: Added multiplexed i2c bus 19 [ 5.977189] i2c i2c-1: Added multiplexed i2c bus 20 [ 5.982232] i2c i2c-1: Added multiplexed i2c bus 21 [ 5.987273] i2c i2c-1: Added multiplexed i2c bus 22 [ 5.992147] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548 [ 5.999748] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25 [ 6.006138] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s [ 6.045982] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 6.170212] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 6.177241] mmcblk0: mmc0:aaaa SL16G 14.8 GiB [ 6.187398] mmcblk0: p1 p2 p3 [ 6.336294] [drm] Cannot find any crtc or sizes [ 7.159960] random: crng init done [ 12.540345] adrv9002 spi1.0: [ERROR]: Error number 3 (0x00000003), Recovery action -101.In file drivers/iio/adc/navassa/devices/adrv9001/public/src/adi_adrv9001_arm.c, in function adi_adrv9001_arm_StartStatus_Check, in line 183, variable name device.Error message Timed out waiting for ARM bootup to happen. [ 12.567620] adrv9002 spi1.0: adrv9002_digital_init, 2102: failed with "Timed out waiting for ARM bootup to happen" (3) [ 18.969669] adrv9002 spi1.0: [ERROR]: Error number 3 (0x00000003), Recovery action -101.In file drivers/iio/adc/navassa/devices/adrv9001/public/src/adi_adrv9001_arm.c, in function adi_adrv9001_arm_StartStatus_Check, in line 183, variable name device.Error message Timed out waiting for ARM bootup to happen. [ 18.996942] adrv9002 spi1.0: adrv9002_digital_init, 2102: failed with "Timed out waiting for ARM bootup to happen" (3) [ 19.007657] cf_axi_adc: probe of 84a00000.axi-adrv9002-rx-lpc failed with error -14 [ 19.016387] cf_axi_tdd 84a0c800.axi-adrv9002-core-tdd1-lpc: Major version mismatch between PCORE and driver. Driver expected 1.00.a, PCORE reported 173.222. [ 19.030777] cf_axi_tdd 84a0cc00.axi-adrv9002-core-tdd2-lpc: Major version mismatch between PCORE and driver. Driver expected 1.00.a, PCORE reported 173.222. [ 19.064547] cf_axi_dds 84a0a000.axi-adrv9002-tx-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A0A000 mapped to 0x000000007444548f, probed DDS ADRV9002 [ 19.096521] cf_axi_dds 84a0c000.axi-adrv9002-tx2-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A0C000 mapped to 0x00000000b41f3e6f, probed DDS ADRV9002 [ 19.113606] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 19.120553] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-03-02 16:52:09 UTC (1614703929) [ 19.129427] of_cfs_init [ 19.131881] of_cfs_init: OK [ 19.134803] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 19.280115] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 19.286729] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13 [ 19.294555] ALSA device list: [ 19.297517] #0: DisplayPort monitor [ 19.301481] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 19.310094] cfg80211: failed to load regulatory.db [ 19.315367] Freeing unused kernel memory: 896K [ 19.332290] Run /init as init process INIT: version 2.88 booting Starting udev [ 19.455717] udevd[2296]: starting version 3.2.5 [ 19.464702] udevd[2297]: starting eudev-3.2.5 [ 19.933012] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 19.946013] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Configuring packages on first boot.... (This may take several minutes. Please do not power off the machine.) Running postinst /etc/rpm-postinsts/100-sysvinit-inittab... update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing) INIT: Entering runlevel: 5 Configuring network interfaces... [ 20.369476] pps pps0: new PPS source ptp0 [ 20.373498] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered. [ 20.380201] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready udhcpc: started, v1.29.2 udhcpc: sending discover [ 21.400622] macb ff0e0000.ethernet eth0: link up (100/Full) [ 21.406208] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready udhcpc: sending discover udhcpc: sending select for 192.168.1.11 udhcpc: lease of 192.168.1.11 obtained, lease time 86400 /etc/udhcpc.d/50default: Adding DNS 192.168.1.1 done. Starting system message bus: dbus. Starting Dropbear SSH server: Generating 2048 bit rsa key, this may take a while... Public key portion is: ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCGsHI5SC7wNRlRUcYToNqH9jhOQL1dR+f058q593yancXnGwoM6WfayceNenA1NE+nWrfE3uXc2QMVmJfDGdnv7+t3D9Lu2X2+4z/pw4dU1y4dlLDppofvGD0VCCblvled6l5DOkeeWLHgcD2sjGYvq/iwERnf4/U4aNV5Y4oIT2KYqmvUS9yz8bYy0Yx8hcg5L58ACSPXprnDs0xB+YEoMBwCV0ujMg0xw3jpHL+DycbHcGFwH/P8c0kRfhrhj7IOjOZ60aUaspBclWQYchGVzj9O6fHnLA/dFbmxp7amrNOzh27NAymPXVmQgbMLhYJzP5OYmqHixLC4e6amPZ7/ root@petalinux-adi-1 Fingerprint: sha1!! 68:24:ff:06:d5:30:d3:cd:d2:ce:77:fc:f0:11:f6:65:66:41:3a:77 dropbear. Starting FANCONTROL Daemon: fancontrold Starting IIO Daemon: iiod Starting internet superserver: inetd. Starting syslogd/klogd: done Starting tcf-agent: OK PetaLinux 2019.1 petalinux-adi-1 /dev/ttyPS0 petalinux-adi-1 login:
Xilinx Zynq MP First Stage Boot Loader Release 2019.1 Jun 12 2020 - 15:24:33 NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000 NOTICE: BL31: Secure code at 0x0 NOTICE: BL31: Non secure code at 0x8000000 NOTICE: BL31: v2.0(release):xilinx-v2019.2 NOTICE: BL31: Built : 10:19:24, Jan 13 2020 PMUFW: v1.1 U-Boot 2018.01-21436-gbba91bc203 (Jan 13 2020 - 10:50:58 +0200) Xilinx ZynqMP ZCU102 rev1.0, Build: jenkins-development-build_uboot-1 I2C: ready DRAM: 4 GiB EL Level: EL2 Chip ID: zu9eg MMC: sdhci@ff170000: 0 (SD) *** Warning - bad CRC, using default environment In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 Bootmode: LVL_SHFT_SD_MODE1 Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id Warning: ethernet@ff0e0000 using MAC address from ROM eth0: ethernet@ff0e0000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Device: sdhci@ff170000 Manufacturer ID: 3 OEM: 5344 Name: SL16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.8 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes reading uEnv.txt 392 bytes read in 11 ms (34.2 KiB/s) Loaded environment from uEnv.txt Importing environment from SD ... Running uenvcmd ... Copying Linux from SD to RAM... ** No boot file defined ** reading system.dtb 42007 bytes read in 24 ms (1.7 MiB/s) reading Image 32354816 bytes read in 2116 ms (14.6 MiB/s) ## Flattened Device Tree blob at 04000000 Booting using the fdt blob at 0x4000000 Loading Device Tree to 000000000fff2000, end 000000000ffff416 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-29506-g6374347742fc (nunojsa@nunojsa-N551JK) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #84 SMP Fri Jun 19 14:16:29 CEST 2020 [ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0 [ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8') [ 0.000000] bootconsole [cdns0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240 [ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait cpuidle.off=1 root=/dev/mmcblk0p2 rw rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0x6bfff000-0x6ffff000] (64MB) [ 0.000000] Memory: 3769828K/4194304K available (14844K kernel code, 1452K rwdata, 14436K rodata, 832K init, 329K bss, 162332K reserved, 262144K cma-reserved) [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns [ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns [ 0.008246] Console: colour dummy device 80x25 [ 0.012392] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960) [ 0.022756] pid_max: default: 32768 minimum: 301 [ 0.027449] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.041792] ASID allocator initialised with 32768 entries [ 0.046510] rcu: Hierarchical SRCU implementation. [ 0.051535] EFI services will not be available. [ 0.055831] smp: Bringing up secondary CPUs ... [ 0.060486] Detected VIPT I-cache on CPU1 [ 0.060515] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.060823] Detected VIPT I-cache on CPU2 [ 0.060842] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.061130] Detected VIPT I-cache on CPU3 [ 0.061149] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.061192] smp: Brought up 1 node, 4 CPUs [ 0.095681] SMP: Total of 4 processors activated. [ 0.100355] CPU features: detected: 32-bit EL0 Support [ 0.106878] CPU: All CPU(s) started at EL2 [ 0.109535] alternatives: patching kernel code [ 0.114850] devtmpfs: initialized [ 0.122370] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.126921] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.138623] xor: measuring software checksum speed [ 0.177130] 8regs : 2374.000 MB/sec [ 0.217159] 8regs_prefetch: 2051.000 MB/sec [ 0.257190] 32regs : 2724.000 MB/sec [ 0.297220] 32regs_prefetch: 2308.000 MB/sec [ 0.297261] xor: using function: 32regs (2724.000 MB/sec) [ 0.301570] pinctrl core: initialized pinctrl subsystem [ 0.307377] NET: Registered protocol family 16 [ 0.311537] audit: initializing netlink subsys (disabled) [ 0.316595] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1 [ 0.324230] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.324234] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.338994] DMA: preallocated 256 KiB pool for atomic allocations [ 0.357543] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.426972] raid6: int64x1 gen() 445 MB/s [ 0.494934] raid6: int64x1 xor() 451 MB/s [ 0.562988] raid6: int64x2 gen() 680 MB/s [ 0.631034] raid6: int64x2 xor() 599 MB/s [ 0.699105] raid6: int64x4 gen() 981 MB/s [ 0.767152] raid6: int64x4 xor() 737 MB/s [ 0.835196] raid6: int64x8 gen() 1162 MB/s [ 0.903231] raid6: int64x8 xor() 759 MB/s [ 0.971326] raid6: neonx1 gen() 736 MB/s [ 1.039325] raid6: neonx1 xor() 880 MB/s [ 1.107369] raid6: neonx2 gen() 1128 MB/s [ 1.175414] raid6: neonx2 xor() 1174 MB/s [ 1.243498] raid6: neonx4 gen() 1479 MB/s [ 1.311526] raid6: neonx4 xor() 1419 MB/s [ 1.379578] raid6: neonx8 gen() 1553 MB/s [ 1.447605] raid6: neonx8 xor() 1459 MB/s [ 1.447643] raid6: using algorithm neonx8 gen() 1553 MB/s [ 1.451601] raid6: .... xor() 1459 MB/s, rmw enabled [ 1.456531] raid6: using neon recovery algorithm [ 1.461794] SCSI subsystem initialized [ 1.465009] usbcore: registered new interface driver usbfs [ 1.470317] usbcore: registered new interface driver hub [ 1.475594] usbcore: registered new device driver usb [ 1.480642] media: Linux media interface: v0.10 [ 1.485102] videodev: Linux video capture interface: v2.00 [ 1.490578] pps_core: LinuxPPS API ver. 1 registered [ 1.495461] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.504555] PTP clock support registered [ 1.508453] EDAC MC: Ver: 3.0.0 [ 1.511943] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver. [ 1.519180] jesd204: found 0 devices and 0 topologies [ 1.523870] FPGA manager framework [ 1.527385] Advanced Linux Sound Architecture Driver Initialized. [ 1.533534] Bluetooth: Core ver 2.22 [ 1.536830] NET: Registered protocol family 31 [ 1.541225] Bluetooth: HCI device and connection manager initialized [ 1.547542] Bluetooth: HCI socket layer initialized [ 1.552385] Bluetooth: L2CAP socket layer initialized [ 1.557413] Bluetooth: SCO socket layer initialized [ 1.562712] clocksource: Switched to clocksource arch_sys_counter [ 1.568421] VFS: Disk quotas dquot_6.6.0 [ 1.572236] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.583313] NET: Registered protocol family 2 [ 1.583700] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes) [ 1.591182] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.598519] TCP bind hash table entries: 32768 (order: 7, 524288 bytes) [ 1.605293] TCP: Hash tables configured (established 32768 bind 32768) [ 1.611446] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 1.617427] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 1.623908] NET: Registered protocol family 1 [ 1.628288] RPC: Registered named UNIX socket transport module. [ 1.633967] RPC: Registered udp transport module. [ 1.638634] RPC: Registered tcp transport module. [ 1.643307] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.650443] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 1.656951] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.665310] Initialise system trusted keyrings [ 1.668985] workingset: timestamp_bits=62 max_order=20 bucket_order=0 [ 1.675995] NFS: Registering the id_resolver key type [ 1.680348] Key type id_resolver registered [ 1.684483] Key type id_legacy registered [ 1.688469] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.695136] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 2.782030] NET: Registered protocol family 38 [ 2.842834] Key type asymmetric registered [ 2.842872] Asymmetric key parser 'x509' registered [ 2.846158] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.853505] io scheduler noop registered [ 2.857385] io scheduler deadline registered [ 2.861641] io scheduler cfq registered (default) [ 2.866296] io scheduler mq-deadline registered [ 2.870793] io scheduler kyber registered [ 2.902673] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.906588] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 2.914066] brd: module loaded [ 2.917955] loop: module loaded [ 2.918176] Registered mathworks_ip class [ 2.920355] mtdoops: mtd device (mtddev=name/number) must be supplied [ 2.927356] libphy: Fixed MDIO Bus: probed [ 2.931281] tun: Universal TUN/TAP device driver, 1.6 [ 2.935166] CAN device driver interface [ 2.939707] usbcore: registered new interface driver asix [ 2.944253] usbcore: registered new interface driver ax88179_178a [ 2.950302] usbcore: registered new interface driver cdc_ether [ 2.956096] usbcore: registered new interface driver net1080 [ 2.961722] usbcore: registered new interface driver cdc_subset [ 2.967602] usbcore: registered new interface driver zaurus [ 2.973146] usbcore: registered new interface driver cdc_ncm [ 2.979428] usbcore: registered new interface driver uas [ 2.984050] usbcore: registered new interface driver usb-storage [ 2.990043] usbcore: registered new interface driver upd78f0730 [ 2.995886] usbserial: USB Serial support registered for upd78f0730 [ 3.002800] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0 [ 3.009332] i2c /dev entries driver [ 3.014642] usbcore: registered new interface driver uvcvideo [ 3.018447] USB Video Class driver (1.1.1) [ 3.023721] Bluetooth: HCI UART driver ver 2.3 [ 3.026932] Bluetooth: HCI UART protocol H4 registered [ 3.032029] Bluetooth: HCI UART protocol BCSP registered [ 3.037326] Bluetooth: HCI UART protocol LL registered [ 3.042409] Bluetooth: HCI UART protocol ATH3K registered [ 3.047789] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 3.054042] Bluetooth: HCI UART protocol Intel registered [ 3.059382] Bluetooth: HCI UART protocol QCA registered [ 3.064592] usbcore: registered new interface driver bcm203x [ 3.070205] usbcore: registered new interface driver bpa10x [ 3.075742] usbcore: registered new interface driver bfusb [ 3.081193] usbcore: registered new interface driver btusb [ 3.086616] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 3.092282] usbcore: registered new interface driver ath3k [ 3.097812] EDAC MC: ECC not enabled [ 3.101468] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT) [ 3.113668] CPUidle arm: Failed to register cpuidle driver [ 3.118960] sdhci: Secure Digital Host Controller Interface driver [ 3.124939] sdhci: Copyright(c) Pierre Ossman [ 3.129263] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.135253] ledtrig-cpu: registered to indicate activity on CPUs [ 3.140902] zynqmp_firmware_probe Platform Management API v1.1 [ 3.146656] zynqmp_firmware_probe Trustzone version v1.0 [ 3.154759] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized [ 3.181973] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22 [ 3.184659] alg: No test for xilinx-zynqmp-aes (zynqmp-aes) [ 3.189791] zynqmp_aes zynqmp_aes: AES Successfully Registered [ 3.189791] [ 3.197311] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384) [ 3.203432] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa) [ 3.209106] usbcore: registered new interface driver usbhid [ 3.214348] usbhid: USB HID core driver [ 3.224539] axi_sysid 85000000.axi-sysid-0: [adrv9001] on [zcu102] git <4af529a57af7acda0a2971601e189df3f01628a5> clean [2020-06-12 14:04:04] UTC [ 3.232254] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered [ 3.238831] usbcore: registered new interface driver snd-usb-audio [ 3.246154] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 3.252365] Initializing XFRM netlink socket [ 3.256299] NET: Registered protocol family 10 [ 3.261020] Segment Routing with IPv6 [ 3.264360] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.270497] NET: Registered protocol family 17 [ 3.274573] NET: Registered protocol family 15 [ 3.278989] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 3.291902] can: controller area network core (rev 20170425 abi 9) [ 3.298037] NET: Registered protocol family 29 [ 3.302423] can: raw protocol (rev 20170425) [ 3.306660] can: broadcast manager protocol (rev 20170425 t) [ 3.312285] can: netlink gateway (rev 20170425) max_hops=1 [ 3.317793] Bluetooth: RFCOMM TTY layer initialized [ 3.322585] Bluetooth: RFCOMM socket layer initialized [ 3.327725] Bluetooth: RFCOMM ver 1.11 [ 3.331406] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.336676] Bluetooth: BNEP filters: protocol multicast [ 3.341870] Bluetooth: BNEP socket layer initialized [ 3.346800] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.352682] Bluetooth: HIDP socket layer initialized [ 3.357742] 9pnet: Installing 9P2000 support [ 3.361862] NET: Registered protocol family 36 [ 3.366277] Key type dns_resolver registered [ 3.371030] registered taskstats version 1 [ 3.374562] Loading compiled-in X.509 certificates [ 3.379651] Btrfs loaded, crc32c=crc32c-generic [ 3.390232] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps [ 3.399692] console [ttyPS0] enabled [ 3.399692] console [ttyPS0] enabled [ 3.403311] bootconsole [cdns0] disabled [ 3.403311] bootconsole [cdns0] disabled [ 3.411375] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps [ 3.424483] GPIO line 130 (output_enable) hogged as output/high [ 3.430658] of-fpga-region fpga-full: FPGA Region probed [ 3.436482] nwl-pcie fd0e0000.pcie: Link is DOWN [ 3.441136] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges: [ 3.448110] nwl-pcie fd0e0000.pcie: MEM 0xe0000000..0xefffffff -> 0xe0000000 [ 3.455329] nwl-pcie fd0e0000.pcie: MEM 0x600000000..0x7ffffffff -> 0x600000000 [ 3.462916] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00 [ 3.469097] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.474579] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff] [ 3.481444] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref] [ 3.493065] pci 0000:00:00.0: PCI bridge to [bus 01-0c] [ 3.499218] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed [ 3.505794] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success [ 3.512898] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success [ 3.520002] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success [ 3.527104] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success [ 3.534207] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success [ 3.541308] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success [ 3.548406] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success [ 3.555506] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success [ 3.562744] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes [ 3.574042] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13 [ 3.582723] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed [ 3.593473] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed [ 3.601547] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed [ 3.609937] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 3.622373] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok [ 3.635052] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed [ 3.645231] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000 [ 3.652246] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.658854] [drm] No driver support for vblank timestamp query. [ 3.664829] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008fc2930) [ 4.750724] [drm] Cannot find any crtc or sizes [ 4.755477] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0 [ 4.763584] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed [ 4.772559] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes [ 4.790495] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode [ 4.799457] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst [ 4.809826] scsi host0: ahci-ceva [ 4.813378] scsi host1: ahci-ceva [ 4.816834] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37 [ 4.824748] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37 [ 4.833812] API_LOG:adi_adrv9001_HwReset(...) [ 4.839190] API_LOG:adi_adrv9001_spi_Configure(...) [ 4.844156] API_LOG:adi_adrv9001_spi_Verify(...) [ 4.868734] random: fast init done [ 5.144946] ata2: SATA link down (SStatus 0 SControl 330) [ 5.150357] ata1: SATA link down (SStatus 0 SControl 330) [ 5.858726] [drm] Cannot find any crtc or sizes [ 10.348120] random: crng init done [ 13.202541] adrv9002 spi1.0: adrv9002-phy Rev 11.0, Firmware 0.9.2.16 API version: 14.3.9.0 successfully initialized [ 13.213798] m25p80 spi0.0: found n25q512a, expected m25p80 [ 13.219504] m25p80 spi0.0: n25q512a (131072 Kbytes) [ 13.224393] 4 fixed-partitions partitions found on MTD device spi0.0 [ 13.230742] Creating 4 MTD partitions on "spi0.0": [ 13.235527] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot" [ 13.241730] 0x000000100000-0x000000600000 : "qspi-linux" [ 13.247434] 0x000000600000-0x000000620000 : "qspi-device-tree" [ 13.253652] 0x000000620000-0x000000c00000 : "qspi-rootfs" [ 13.261541] macb ff0e0000.ethernet: Not enabling partial store and forward [ 13.268899] libphy: MACB_mii_bus: probed [ 13.272897] mdio_bus ff0e0000.ethernet-ffffffff: MDIO device at address 21 is missing. [ 13.282961] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL) [ 13.295994] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 22 (00:0a:35:07:0a:79) [ 13.306113] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM [ 13.312627] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM [ 13.319109] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM [ 13.325593] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM [ 13.333400] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2 [ 13.339254] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes [ 13.347506] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 13.352999] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 13.360977] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810 [ 13.370392] xhci-hcd xhci-hcd.0.auto: irq 48, io mem 0xfe200000 [ 13.376525] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 13.384791] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 13.392008] usb usb1: Product: xHCI Host Controller [ 13.396877] usb usb1: Manufacturer: Linux 4.19.0-29506-g6374347742fc xhci-hcd [ 13.404003] usb usb1: SerialNumber: xhci-hcd.0.auto [ 13.409164] hub 1-0:1.0: USB hub found [ 13.412933] hub 1-0:1.0: 1 port detected [ 13.417042] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 13.422529] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 13.430184] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 13.436914] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 13.445173] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 13.452392] usb usb2: Product: xHCI Host Controller [ 13.457261] usb usb2: Manufacturer: Linux 4.19.0-29506-g6374347742fc xhci-hcd [ 13.464387] usb usb2: SerialNumber: xhci-hcd.0.auto [ 13.469498] hub 2-0:1.0: USB hub found [ 13.473263] hub 2-0:1.0: 1 port detected [ 13.478387] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator [ 13.485641] pca953x 0-0020: Linked as a consumer to regulator.0 [ 13.492432] GPIO line 496 (sel0) hogged as output/low [ 13.497820] GPIO line 497 (sel1) hogged as output/high [ 13.503285] GPIO line 498 (sel2) hogged as output/high [ 13.508754] GPIO line 499 (sel3) hogged as output/high [ 13.514097] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator [ 13.521335] pca953x 0-0021: Linked as a consumer to regulator.0 [ 13.528748] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.535565] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.542369] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.549188] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.556002] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.562821] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.569624] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.576435] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.583246] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.590060] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.596475] i2c i2c-0: Added multiplexed i2c bus 3 [ 13.601953] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm) [ 13.608762] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.615571] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.622385] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.629196] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.636002] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.642809] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.649622] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm) [ 13.656024] i2c i2c-0: Added multiplexed i2c bus 4 [ 13.694821] i2c i2c-0: Added multiplexed i2c bus 5 [ 13.699793] i2c i2c-0: Added multiplexed i2c bus 6 [ 13.704588] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544 [ 13.711937] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24 [ 13.719734] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write [ 13.726482] i2c i2c-1: Added multiplexed i2c bus 7 [ 13.731597] i2c i2c-1: Added multiplexed i2c bus 8 [ 13.738523] si570 9-005d: registered, current frequency 300000000 Hz [ 13.744920] i2c i2c-1: Added multiplexed i2c bus 9 [ 13.763734] si570 10-005d: registered, current frequency 148500000 Hz [ 13.770224] i2c i2c-1: Added multiplexed i2c bus 10 [ 13.775324] si5324 11-0069: si5328 probed [ 13.838781] si5324 11-0069: si5328 probe successful [ 13.843707] i2c i2c-1: Added multiplexed i2c bus 11 [ 13.848754] i2c i2c-1: Added multiplexed i2c bus 12 [ 13.853791] i2c i2c-1: Added multiplexed i2c bus 13 [ 13.858842] i2c i2c-1: Added multiplexed i2c bus 14 [ 13.863723] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548 [ 13.871683] i2c i2c-1: Added multiplexed i2c bus 15 [ 13.903422] i2c i2c-1: Added multiplexed i2c bus 16 [ 13.908471] i2c i2c-1: Added multiplexed i2c bus 17 [ 13.913529] i2c i2c-1: Added multiplexed i2c bus 18 [ 13.918574] i2c i2c-1: Added multiplexed i2c bus 19 [ 13.923616] i2c i2c-1: Added multiplexed i2c bus 20 [ 13.928659] i2c i2c-1: Added multiplexed i2c bus 21 [ 13.933707] i2c i2c-1: Added multiplexed i2c bus 22 [ 13.938585] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548 [ 13.946195] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25 [ 13.952553] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s [ 13.992336] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit [ 14.026563] cf_axi_adc 84a00000.axi-adrv9002-rx-lpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0x00000000e905a436, probed ADC ADRV9002 as MASTER [ 14.087129] cf_axi_dds 84a02000.axi-adrv9002-tx-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A02000 mapped to 0x000000003c6e3973, probed DDS ADRV9002 [ 14.104126] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 14.111043] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-03-02 16:43:14 UTC (1614703394) [ 14.119918] of_cfs_init [ 14.122375] of_cfs_init: OK [ 14.125308] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 14.177259] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 14.184274] mmcblk0: mmc0:aaaa SL16G 14.8 GiB [ 14.193371] mmcblk0: p1 p2 p3 [ 14.264080] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 14.270683] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13 [ 14.278456] ALSA device list: [ 14.281415] #0: DisplayPort monitor [ 14.285399] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 14.294006] cfg80211: failed to load regulatory.db [ 14.313792] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 14.321893] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 14.334797] devtmpfs: mounted [ 14.337928] Freeing unused kernel memory: 832K [ 14.346748] Run /sbin/init as init process Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory [ 15.244115] systemd-udevd[3207]: could not open moddep file '/lib/modules/4.19.0-29506-g6374347742fc/modules.dep.bin' * Setting up X socket directories... [ OK ] * STARTDISTCC is set to false in /etc/default/distcc * /usr/bin/distccd not starting * Starting IIO Daemon iiod [ OK ] Last login: Tue Mar 2 05:13:15 UTC 2021 on tty1 Welcome to Linaro 14.04 (GNU/Linux 4.19.0-29506-g6374347742fc aarch64) * Documentation: https://wiki.analog.com/ https://ez.analog.com/ New release '16.04.7 LTS' available. Run 'do-release-upgrade' to upgrade to it. root@analog:~#
