HI all,
I am modifying the project of the XC706/AD9371 setup up to verify our design that uses AD9371 and the FPGA XC7030. I am doing it to make sure the design routes and the new pins we are selecting are valid.
For example: When I look at the block diagram I see
rx_data_0_p, rx_data_0_n
rx_data_1_p, rx_data_1_n
rx_data_2_p, rx_data_2_n
rx_data_3_p, rx_data_3_n
But in constraint file they are referenced to as:
rx_data_p[0], rx_data_n[0]
rx_data_p[1], rx_data_n[1]
rx_data_p[2], rx_data_n[2]
rx_data_p[3], rx_data_n[3]
Are these the same MGTs pins? Any help is greatly appreciated.
>>>>>>>>>>>> From the constraint file
set_property -dict {PACKAGE_PIN AJ8 } [get_ports rx_data_p[0]] ; ## A02 FMC_HPC_DP1_M2C_P
set_property -dict {PACKAGE_PIN AJ7 } [get_ports rx_data_n[0]] ; ## A03 FMC_HPC_DP1_M2C_N
set_property -dict {PACKAGE_PIN AG8 } [get_ports rx_data_p[1]] ; ## A06 FMC_HPC_DP2_M2C_P
set_property -dict {PACKAGE_PIN AG7 } [get_ports rx_data_n[1]] ; ## A07 FMC_HPC_DP2_M2C_N
set_property -dict {PACKAGE_PIN AH10} [get_ports rx_data_p[2]] ; ## C06 FMC_HPC_DP0_M2C_P
set_property -dict {PACKAGE_PIN AH9 } [get_ports rx_data_n[2]] ; ## C07 FMC_HPC_DP0_M2C_N
set_property -dict {PACKAGE_PIN AE8 } [get_ports rx_data_p[3]] ; ## A10 FMC_HPC_DP3_M2C_P
set_property -dict {PACKAGE_PIN AE7 } [get_ports rx_data_n[3]] ; ## A11 FMC_HPC_DP3_M2C_N
set_property -dict {PACKAGE_PIN AK6 } [get_ports tx_data_p[0]] ; ## A22 FMC_HPC_DP1_C2M_P (tx_data_p[3])
set_property -dict {PACKAGE_PIN AK5 } [get_ports tx_data_n[0]] ; ## A23 FMC_HPC_DP1_C2M_N (tx_data_n[3])
set_property -dict {PACKAGE_PIN AJ4 } [get_ports tx_data_p[1]] ; ## A26 FMC_HPC_DP2_C2M_P (tx_data_p[0])
set_property -dict {PACKAGE_PIN AJ3 } [get_ports tx_data_n[1]] ; ## A27 FMC_HPC_DP2_C2M_N (tx_data_n[0])
set_property -dict {PACKAGE_PIN AK10} [get_ports tx_data_p[2]] ; ## C02 FMC_HPC_DP0_C2M_P (tx_data_p[1])
set_property -dict {PACKAGE_PIN AK9 } [get_ports tx_data_n[2]] ; ## C03 FMC_HPC_DP0_C2M_N (tx_data_n[1])
set_property -dict {PACKAGE_PIN AK2 } [get_ports tx_data_p[3]] ; ## A30 FMC_HPC_DP3_C2M_P (tx_data_p[2])
set_property -dict {PACKAGE_PIN AK1 } [get_ports tx_data_n[3]]
Cherif
