HDL make error 127
I'm attempting to build the hdl for the master branch with cygwin on windows 7.
Whenever I run make I come across the following error:
there doesn't seem to be any errors in the vivado.log file. I've seen this may be related to a bad PATH but mine seems ok. In my bashrc file it looks as such:
export PATH=$PATH:/cygdrive/c/Xilinx/Vivado/2019.1/bin/
Running "which vivado" also shows the the path is correct.
What am I missing here?
Ryne
Parents Reply
  • Hello,
    I have fixed my issue! I reinstalled cygwin and successfully built the project.
    I had tried your suggested fix removing the slash at the end before to no avail. I believe the core issue was that I was not restarting the cygwin environment after making changes to the .bashrc file.
    Thanks for the help!
    -Ryne
Children
No Data
