FMCDAQ3 on KCU105
Hi
I'm working with the FMCDAQ3 on the KCU105 board from Xilinx.
Using the Prebuild image found on the website is working fine ( no Hardware issue ) my indication is the II oscilloscope detect the waves with a SMA loopback .
When trying to compile the project by myself
1- the HDL project give me timing clean and i was able to generate the bit stream
2-using microblaze and linux version i was also able to compile the boot image (.strip and .unstrip)
When trying to use the project with the compiled image the II Oscilloscope does not detect my device and i have attached the "working terra term output Vs the non working "
not_working.txt
Ramdisk addr 0x00000000,
Compiled-in FDT at 0x804721bc
Linux version 4.19.0-g64ea0d3-dirty (bassem.sleiman@colossus.fidus.ca) (gcc version 8.2.0 (crosstool-NG 1.20.0)) #17 Mon Oct 5 13:39:56 EDT 2020
setup_memory: max_mapnr: 0x30000
setup_memory: min_low_pfn: 0x80000
setup_memory: max_low_pfn: 0xb0000
setup_memory: max_pfn: 0xb0000
Zone ranges:
  DMA      [mem 0x0000000080000000-0x00000000afffffff]
  Normal   empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000080000000-0x00000000ffffefff]
Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffefff]
On node 0 totalpages: 196608
  DMA zone: 1536 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 196608 pages, LIFO batch:63
setup_cpuinfo: initialising
setup_cpuinfo: Using full CPU PVR support
ERROR: Microblaze HW_MUL-different for PVR and DTS
wt_msr_noirq
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on.  Total pages: 195072
Kernel command line: console=ttyUL0,115200
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 766144K/786432K available (4552K kernel code, 505K rwdata, 4412K rodata, 2888K init, 92K bss, 20288K reserved, 0K cma-reserved)
Kernel virtual memory layout:
  * 0xffffe000..0xfffff000  : fixmap
  * 0xffffe000..0xffffe000  : early ioremap
  * 0xb0000000..0xffffe000  : vmalloc & ioremap
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
irq-xilinx: /amba_pl/interrupt-controller@41200000: num_irq=16, edge=0x410
/amba_pl/timer@41c00000: irq=1
clocksource: xilinx_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
xilinx_timer_shutdown
xilinx_timer_set_periodic
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
Calibrating delay loop... 49.35 BogoMIPS (lpj=246784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
devtmpfs: initialized
random: get_random_u32 called from bucket_table_alloc.isra.6+0x1e8/0x218 with crng_init=0
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 256 (order: -1, 3072 bytes)
NET: Registered protocol family 16
jesd204: found 0 devices and 0 topologies
clocksource: Switched to clocksource xilinx_clocksource
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
random: fast init done
Skipping unavailable RESET gpio -2 (reset)
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
io scheduler mq-deadline registered
io scheduler kyber registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
40600000.serial: ttyUL0 at MMIO 0x40600000 (irq = 5, base_baud = 0) is a uartlite
console [ttyUL0] enabled
brd: module loaded
Xilinx SystemACE device driver, major=254
xilinx_spi 44a70000.axi_quad_spi: no CS gpios available
libphy: Fixed MDIO Bus: probed
xilinx_axienet 40e00000.ethernet: TX_CSUM 2
xilinx_axienet 40e00000.ethernet: RX_CSUM 2
xilinx_axienet 40e00000.ethernet: missing/invalid xlnx,addrwidth property, using default
libphy: Xilinx Axi Ethernet MDIO: probed
i2c /dev entries driver
i2c i2c-0: Added multiplexed i2c bus 1
at24 2-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
ad9528 spi0.0: spi0.0 supply vcc not found, using dummy regulator
ad9528 spi0.0: Linked as a consumer to regulator.0
axi_adxcvr 44a50000.axi-ad9680-adxcvr: adxcvr_enforce_settings: Rate 12333333 Hz Parent Rate 616666666 Hz, error: -22
axi_adxcvr 44a50000.axi-ad9680-adxcvr: AXI-ADXCVR-RX (17.01.a) using GTH3 at 0x44A50000 mapped to 0x(ptrval). Number of lanes: 4.
axi_adxcvr 44a60000.axi-ad9152-adxcvr: adxcvr_enforce_settings: Rate 12333333 Hz Parent Rate 616666666 Hz, error: -22
axi_adxcvr 44a60000.axi-ad9152-adxcvr: AXI-ADXCVR-TX (17.01.a) using GTH3 at 0x44A60000 mapped to 0x(ptrval). Number of lanes: 4.
axi_sysid 45000000.axi-sysid-0: [daq3] [sys rom custom string placeholder] on [kcu105] git <e759c1855b0762b9220cde7b2c1ba70905207275> clean [2020-        09-30 17:01:31] UTC
ad9680 spi0.2: Failed to set lane rate to 12333333 kHz: -22
ad9680 spi0.2: Failed to initialize: -22
ad9680: probe of spi0.2 failed with error -22
ad9144 spi0.1: Failed to set lane rate to 12333333 kHz: -22
ad9144: probe of spi0.1 failed with error -22
Freeing unused kernel memory: 2888K
This architecture does not have kernel memory protection.
Run /init as init process
Starting logging: OK
Initializing random number generator... random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: udhcpc: started, v1.27.2
net eth0: Promiscuous mode disabled.
udhcpc: sending discover
xilinx_axienet 40e00000.ethernet eth0: Link is Down
xilinx_axienet 40e00000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
udhcpc: sending select for 192.168.0.19
udhcpc: lease of 192.168.0.19 obtained, lease time 604800
deleting routers
adding dns 192.168.0.1
Starting dropbear sshd:
random: dropbear: uninitialized urandom read (32 bytes read)
OK
Starting IIO Server Daemon
Welcome to Buildroot
buildroot login:
working.txt
Ramdisk addr 0x00000000, alized urandom read (32 bytes read)
Compiled-in FDT at 803e38e8
Linux version 4.9.0-g87beab60b2b9 (dragos@debian) (gcc version 5.2.0 (crosstool-NG 1.20.0) ) #162 Tue May 8 11:53:50 EEST 2018
wt_msr_noirqgin:
Zone ranges:
  Normal   empty
free_area_init_node: node 0, pgdat 8057b3e0, node_mem_map 808d5000
  DMA zone: 196608 pages, LIFO batch:31
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 195072
PID hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 769632K/786432K available (3982K kernel code, 143K rwdata, 1448K rodata, 3292K init, 100K bss, 16800K reserved, 0K cma-reserved)
NR_IRQS:128
brd: module loaded
axi_adxcvr 44a50000.axi-ad9680-adxcvr: cpll: fb_div_N1=5
cpll: fb_div_N2=2
cpll: refclk_div=1
cpll: fb_div_N2=2
cpll: refclk_div=1
axi_adxcvr 44a50000.axi-ad9680-adxcvr: AXI-ADXCVR-RX (16.01.a) using GTH3 at 0x44A50000 mapped to 0xb0190000. Number of lanes: 4.
axi_adxcvr 44a60000.axi-ad9152-adxcvr: qpll: fb_div=20, qpll: refclk_div=1
axi_adxcvr 44a60000.axi-ad9152-adxcvr: AXI-ADXCVR-TX (16.01.a) using GTH3 at 0x44A60000 mapped to 0xb01b0000. Number of lanes: 4.
ad9680 spi0.2: AD9680 PLL LOCKED
cf_axi_adc 44a10000.axi-ad9680-hpc: ADI AIM (10.00.b) at 0x44A10000 mapped to 0xb01f0000, probed ADC AD9680 as MASTER
cf_axi_dds 44a04000.axi-ad9152-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.00.b) at 0x44A04000 mapped to 0xb0210000, probed DDS AD9152
Freeing unused kernel memory: 3292K (8057c000 - 808b3000)
Initializing random number generator... done.
Starting network: OK
Starting network...
udhcpc: started, v1.25.0
xilinx_axienet 40e00000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
deleting routers
Starting dropbear sshd: OK
buildroot login:
Thanks for your help !
