I am trying to get the ZC706 with AD9136-FMC-EBZ running with the following settings:
DAC GOAL:
1 GSPS per channel (2 GSPS total)
AD9516 CLOCK SYNTHESIS SETTINGS
Root Oscillator: 250.0 MHz
DAC CLK+/CLK- (REFCLK): 125.0 MHz
DAC SYSREF: 15.625 MHz
FPGA SYSREF: 15.625 MHz
FPGA GTX REFCLK: 125.0 MHz
I am using the Analog Devices Reference design in non-OS mode (Linux is not supported yet), so it's utilizing the ADI blocks in the FPGA firmware. I have verified that I am getting the correct TXUSRCLK from the Zynq's GTX.
My problem is that I am getting a continual SYNC pulse from the DAC. In analyzing the registers, it appears that the "CODEGRPSYNC" flags (register 0x470) are going in and out for some lanes. I could not identify any obvious problem from other registers, except that it's not receiving any of the JESD204B parameters over the line (probably hasn't got far enough into the decoding process).
Any suggestions on troubleshooting this?
I have created a register dump printout for every single register that is being configured (including hardware and ADI AXI IP). Hopefully someone can spot a problem with this configuration:
REGISTER DUMP ==================================== AD9516 CLKGEN: Addr=0x0000. Data=0x99 AD9516 CLKGEN: Addr=0x0003. Data=0x41 AD9516 CLKGEN: Addr=0x0004. Data=0x01 AD9516 CLKGEN: Addr=0x0010. Data=0x7d AD9516 CLKGEN: Addr=0x0011. Data=0x01 AD9516 CLKGEN: Addr=0x0012. Data=0x00 AD9516 CLKGEN: Addr=0x0013. Data=0x00 AD9516 CLKGEN: Addr=0x0014. Data=0x03 AD9516 CLKGEN: Addr=0x0015. Data=0x00 AD9516 CLKGEN: Addr=0x0016. Data=0x06 AD9516 CLKGEN: Addr=0x0017. Data=0x00 AD9516 CLKGEN: Addr=0x0018. Data=0x01 AD9516 CLKGEN: Addr=0x0019. Data=0x00 AD9516 CLKGEN: Addr=0x001a. Data=0x00 AD9516 CLKGEN: Addr=0x001b. Data=0x00 AD9516 CLKGEN: Addr=0x001c. Data=0x00 AD9516 CLKGEN: Addr=0x001d. Data=0x00 AD9516 CLKGEN: Addr=0x001e. Data=0x00 AD9516 CLKGEN: Addr=0x001f. Data=0x0e AD9516 CLKGEN: Addr=0x00a0. Data=0x01 AD9516 CLKGEN: Addr=0x00a1. Data=0x00 AD9516 CLKGEN: Addr=0x00a2. Data=0x00 AD9516 CLKGEN: Addr=0x00a3. Data=0x01 AD9516 CLKGEN: Addr=0x00a4. Data=0x00 AD9516 CLKGEN: Addr=0x00a5. Data=0x00 AD9516 CLKGEN: Addr=0x00a6. Data=0x01 AD9516 CLKGEN: Addr=0x00a7. Data=0x00 AD9516 CLKGEN: Addr=0x00a8. Data=0x00 AD9516 CLKGEN: Addr=0x00a9. Data=0x01 AD9516 CLKGEN: Addr=0x00aa. Data=0x00 AD9516 CLKGEN: Addr=0x00ab. Data=0x00 AD9516 CLKGEN: Addr=0x00f0. Data=0x0a AD9516 CLKGEN: Addr=0x00f1. Data=0x08 AD9516 CLKGEN: Addr=0x00f2. Data=0x0a AD9516 CLKGEN: Addr=0x00f3. Data=0x0a AD9516 CLKGEN: Addr=0x00f4. Data=0x0a AD9516 CLKGEN: Addr=0x00f5. Data=0x0a AD9516 CLKGEN: Addr=0x0140. Data=0x42 AD9516 CLKGEN: Addr=0x0141. Data=0x42 AD9516 CLKGEN: Addr=0x0142. Data=0x43 AD9516 CLKGEN: Addr=0x0143. Data=0x42 AD9516 CLKGEN: Addr=0x0190. Data=0x00 AD9516 CLKGEN: Addr=0x0191. Data=0x80 AD9516 CLKGEN: Addr=0x0192. Data=0x01 AD9516 CLKGEN: Addr=0x0193. Data=0xbb AD9516 CLKGEN: Addr=0x0194. Data=0x00 AD9516 CLKGEN: Addr=0x0195. Data=0x00 AD9516 CLKGEN: Addr=0x0196. Data=0x33 AD9516 CLKGEN: Addr=0x0197. Data=0x00 AD9516 CLKGEN: Addr=0x0198. Data=0x00 AD9516 CLKGEN: Addr=0x0199. Data=0x00 AD9516 CLKGEN: Addr=0x019a. Data=0x00 AD9516 CLKGEN: Addr=0x019b. Data=0x11 AD9516 CLKGEN: Addr=0x019c. Data=0x00 AD9516 CLKGEN: Addr=0x019d. Data=0x00 AD9516 CLKGEN: Addr=0x019e. Data=0x00 AD9516 CLKGEN: Addr=0x019f. Data=0x00 AD9516 CLKGEN: Addr=0x01a0. Data=0x00 AD9516 CLKGEN: Addr=0x01a1. Data=0x30 AD9516 CLKGEN: Addr=0x01a2. Data=0x00 AD9516 CLKGEN: Addr=0x01e0. Data=0x00 AD9516 CLKGEN: Addr=0x01e1. Data=0x00 AD9516 CLKGEN: Addr=0x0230. Data=0x00 AD9516 CLKGEN: Addr=0x0232. Data=0x00 AD9136 DAC: Addr=0x0000. Data=0x18 AD9136 DAC: Addr=0x0003. Data=0x04 AD9136 DAC: Addr=0x0004. Data=0x44 AD9136 DAC: Addr=0x0005. Data=0x91 AD9136 DAC: Addr=0x0006. Data=0x68 AD9136 DAC: Addr=0x0008. Data=0x03 AD9136 DAC: Addr=0x000a. Data=0x00 AD9136 DAC: Addr=0x0011. Data=0x28 AD9136 DAC: Addr=0x0012. Data=0x00 AD9136 DAC: Addr=0x0013. Data=0x20 AD9136 DAC: Addr=0x0014. Data=0x88 AD9136 DAC: Addr=0x001f. Data=0x00 AD9136 DAC: Addr=0x0020. Data=0x00 AD9136 DAC: Addr=0x0021. Data=0x00 AD9136 DAC: Addr=0x0022. Data=0x00 AD9136 DAC: Addr=0x0023. Data=0x14 AD9136 DAC: Addr=0x0024. Data=0x00 AD9136 DAC: Addr=0x0025. Data=0x00 AD9136 DAC: Addr=0x0026. Data=0x00 AD9136 DAC: Addr=0x0030. Data=0x00 AD9136 DAC: Addr=0x0034. Data=0x00 AD9136 DAC: Addr=0x0038. Data=0xd8 AD9136 DAC: Addr=0x0039. Data=0x81 AD9136 DAC: Addr=0x003a. Data=0x81 AD9136 DAC: Addr=0x003b. Data=0x0d AD9136 DAC: Addr=0x003c. Data=0x00 AD9136 DAC: Addr=0x003d. Data=0x00 AD9136 DAC: Addr=0x0040. Data=0x00 AD9136 DAC: Addr=0x0041. Data=0x00 AD9136 DAC: Addr=0x0044. Data=0x00 AD9136 DAC: Addr=0x0045. Data=0x00 AD9136 DAC: Addr=0x0080. Data=0x00 AD9136 DAC: Addr=0x0081. Data=0x00 AD9136 DAC: Addr=0x0082. Data=0x00 AD9136 DAC: Addr=0x0083. Data=0x10 AD9136 DAC: Addr=0x0084. Data=0x22 AD9136 DAC: Addr=0x0085. Data=0x08 AD9136 DAC: Addr=0x0087. Data=0x62 AD9136 DAC: Addr=0x0088. Data=0xc9 AD9136 DAC: Addr=0x0089. Data=0x0e AD9136 DAC: Addr=0x008a. Data=0x12 AD9136 DAC: Addr=0x008b. Data=0x02 AD9136 DAC: Addr=0x008c. Data=0x01 AD9136 DAC: Addr=0x008d. Data=0x7b AD9136 DAC: Addr=0x00e2. Data=0x00 AD9136 DAC: Addr=0x00e7. Data=0x30 AD9136 DAC: Addr=0x00e8. Data=0x0f AD9136 DAC: Addr=0x00e9. Data=0x00 AD9136 DAC: Addr=0x00ed. Data=0xa6 AD9136 DAC: Addr=0x0110. Data=0x00 AD9136 DAC: Addr=0x0111. Data=0x00 AD9136 DAC: Addr=0x0112. Data=0x00 AD9136 DAC: Addr=0x011f. Data=0x83 AD9136 DAC: Addr=0x0121. Data=0x0f AD9136 DAC: Addr=0x0122. Data=0x00 AD9136 DAC: Addr=0x0123. Data=0xff AD9136 DAC: Addr=0x0124. Data=0xff AD9136 DAC: Addr=0x012d. Data=0x8b AD9136 DAC: Addr=0x012f. Data=0x20 AD9136 DAC: Addr=0x0132. Data=0x00 AD9136 DAC: Addr=0x0133. Data=0x00 AD9136 DAC: Addr=0x0134. Data=0x00 AD9136 DAC: Addr=0x0135. Data=0x00 AD9136 DAC: Addr=0x0136. Data=0x00 AD9136 DAC: Addr=0x0137. Data=0x00 AD9136 DAC: Addr=0x013a. Data=0x00 AD9136 DAC: Addr=0x013c. Data=0xea AD9136 DAC: Addr=0x013d. Data=0x0a AD9136 DAC: Addr=0x0140. Data=0x04 AD9136 DAC: Addr=0x0141. Data=0x00 AD9136 DAC: Addr=0x0142. Data=0x09 AD9136 DAC: Addr=0x0143. Data=0x00 AD9136 DAC: Addr=0x0146. Data=0x01 AD9136 DAC: Addr=0x0147. Data=0x4a AD9136 DAC: Addr=0x014b. Data=0xc5 AD9136 DAC: Addr=0x014c. Data=0x00 AD9136 DAC: Addr=0x01b0. Data=0x00 AD9136 DAC: Addr=0x01b5. Data=0x89 AD9136 DAC: Addr=0x01b9. Data=0x24 AD9136 DAC: Addr=0x01bb. Data=0x13 AD9136 DAC: Addr=0x01bc. Data=0x0d AD9136 DAC: Addr=0x01be. Data=0x02 AD9136 DAC: Addr=0x01bf. Data=0x8e AD9136 DAC: Addr=0x01c0. Data=0x2a AD9136 DAC: Addr=0x01c1. Data=0x2a AD9136 DAC: Addr=0x01c4. Data=0x7e AD9136 DAC: Addr=0x01c5. Data=0x06 AD9136 DAC: Addr=0x0200. Data=0x00 AD9136 DAC: Addr=0x0201. Data=0x00 AD9136 DAC: Addr=0x0203. Data=0x00 AD9136 DAC: Addr=0x0206. Data=0x01 AD9136 DAC: Addr=0x0230. Data=0x08 AD9136 DAC: Addr=0x0232. Data=0xff AD9136 DAC: Addr=0x0268. Data=0x62 AD9136 DAC: Addr=0x0280. Data=0x01 AD9136 DAC: Addr=0x0281. Data=0x0b AD9136 DAC: Addr=0x0284. Data=0x62 AD9136 DAC: Addr=0x0285. Data=0xc9 AD9136 DAC: Addr=0x0286. Data=0x0e AD9136 DAC: Addr=0x0287. Data=0x12 AD9136 DAC: Addr=0x0289. Data=0x05 AD9136 DAC: Addr=0x028a. Data=0x7b AD9136 DAC: Addr=0x028b. Data=0x00 AD9136 DAC: Addr=0x0290. Data=0x89 AD9136 DAC: Addr=0x0294. Data=0x24 AD9136 DAC: Addr=0x0296. Data=0x03 AD9136 DAC: Addr=0x0297. Data=0x0d AD9136 DAC: Addr=0x0299. Data=0x02 AD9136 DAC: Addr=0x029a. Data=0x8e AD9136 DAC: Addr=0x029c. Data=0x2a AD9136 DAC: Addr=0x029f. Data=0x78 AD9136 DAC: Addr=0x02a0. Data=0x06 AD9136 DAC: Addr=0x02a4. Data=0xff AD9136 DAC: Addr=0x02a5. Data=0x00 AD9136 DAC: Addr=0x02a7. Data=0x01 AD9136 DAC: Addr=0x02aa. Data=0xb7 AD9136 DAC: Addr=0x02ab. Data=0x87 AD9136 DAC: Addr=0x02ae. Data=0x01 AD9136 DAC: Addr=0x02b1. Data=0xb7 AD9136 DAC: Addr=0x02b2. Data=0x87 AD9136 DAC: Addr=0x0300. Data=0x01 AD9136 DAC: Addr=0x0301. Data=0x01 AD9136 DAC: Addr=0x0302. Data=0x00 AD9136 DAC: Addr=0x0303. Data=0x00 AD9136 DAC: Addr=0x0304. Data=0x00 AD9136 DAC: Addr=0x0305. Data=0x00 AD9136 DAC: Addr=0x0306. Data=0x0a AD9136 DAC: Addr=0x0307. Data=0x0a AD9136 DAC: Addr=0x0308. Data=0x08 AD9136 DAC: Addr=0x0309. Data=0x1a AD9136 DAC: Addr=0x030a. Data=0x2c AD9136 DAC: Addr=0x030b. Data=0x3e AD9136 DAC: Addr=0x030c. Data=0x00 AD9136 DAC: Addr=0x030d. Data=0x00 AD9136 DAC: Addr=0x0312. Data=0x00 AD9136 DAC: Addr=0x0314. Data=0x01 AD9136 DAC: Addr=0x0315. Data=0x00 AD9136 DAC: Addr=0x0316. Data=0x00 AD9136 DAC: Addr=0x0317. Data=0x00 AD9136 DAC: Addr=0x0318. Data=0x00 AD9136 DAC: Addr=0x0319. Data=0x00 AD9136 DAC: Addr=0x031a. Data=0x00 AD9136 DAC: Addr=0x031b. Data=0x00 AD9136 DAC: Addr=0x031c. Data=0x00 AD9136 DAC: Addr=0x031d. Data=0xff AD9136 DAC: Addr=0x032c. Data=0x00 AD9136 DAC: Addr=0x032d. Data=0x00 AD9136 DAC: Addr=0x032e. Data=0x00 AD9136 DAC: Addr=0x032f. Data=0x00 AD9136 DAC: Addr=0x0333. Data=0x01 AD9136 DAC: Addr=0x0334. Data=0x0f AD9136 DAC: Addr=0x0400. Data=0x00 AD9136 DAC: Addr=0x0401. Data=0x00 AD9136 DAC: Addr=0x0402. Data=0x00 AD9136 DAC: Addr=0x0403. Data=0x00 AD9136 DAC: Addr=0x0404. Data=0x00 AD9136 DAC: Addr=0x0405. Data=0x00 AD9136 DAC: Addr=0x0406. Data=0x00 AD9136 DAC: Addr=0x0407. Data=0x00 AD9136 DAC: Addr=0x0408. Data=0x00 AD9136 DAC: Addr=0x0409. Data=0x00 AD9136 DAC: Addr=0x040a. Data=0x00 AD9136 DAC: Addr=0x040b. Data=0x00 AD9136 DAC: Addr=0x040c. Data=0x00 AD9136 DAC: Addr=0x040d. Data=0x00 AD9136 DAC: Addr=0x040e. Data=0x00 AD9136 DAC: Addr=0x0412. Data=0x00 AD9136 DAC: Addr=0x0415. Data=0x00 AD9136 DAC: Addr=0x0416. Data=0x00 AD9136 DAC: Addr=0x041a. Data=0x00 AD9136 DAC: Addr=0x041d. Data=0x00 AD9136 DAC: Addr=0x041e. Data=0x00 AD9136 DAC: Addr=0x0422. Data=0x00 AD9136 DAC: Addr=0x0425. Data=0x00 AD9136 DAC: Addr=0x0426. Data=0x00 AD9136 DAC: Addr=0x042a. Data=0x00 AD9136 DAC: Addr=0x042d. Data=0x00 AD9136 DAC: Addr=0x042e. Data=0x00 AD9136 DAC: Addr=0x0432. Data=0x00 AD9136 DAC: Addr=0x0435. Data=0x00 AD9136 DAC: Addr=0x0436. Data=0x00 AD9136 DAC: Addr=0x043a. Data=0x00 AD9136 DAC: Addr=0x043d. Data=0x00 AD9136 DAC: Addr=0x043e. Data=0x00 AD9136 DAC: Addr=0x0442. Data=0x00 AD9136 DAC: Addr=0x0445. Data=0x00 AD9136 DAC: Addr=0x0446. Data=0x00 AD9136 DAC: Addr=0x0450. Data=0xab AD9136 DAC: Addr=0x0451. Data=0x02 AD9136 DAC: Addr=0x0452. Data=0x00 AD9136 DAC: Addr=0x0453. Data=0x83 AD9136 DAC: Addr=0x0454. Data=0x00 AD9136 DAC: Addr=0x0455. Data=0x1f AD9136 DAC: Addr=0x0456. Data=0x00 AD9136 DAC: Addr=0x0457. Data=0x0f AD9136 DAC: Addr=0x0458. Data=0x2f AD9136 DAC: Addr=0x0459. Data=0x21 AD9136 DAC: Addr=0x045a. Data=0x80 AD9136 DAC: Addr=0x045b. Data=0x00 AD9136 DAC: Addr=0x045c. Data=0x00 AD9136 DAC: Addr=0x045d. Data=0x33 AD9136 DAC: Addr=0x046b. Data=0x00 AD9136 DAC: Addr=0x046b. Data=0x00 AD9136 DAC: Addr=0x046c. Data=0xff AD9136 DAC: Addr=0x046d. Data=0x00 AD9136 DAC: Addr=0x046d. Data=0x00 AD9136 DAC: Addr=0x046e. Data=0x00 AD9136 DAC: Addr=0x046e. Data=0x00 AD9136 DAC: Addr=0x046f. Data=0x00 AD9136 DAC: Addr=0x046f. Data=0x00 AD9136 DAC: Addr=0x0470. Data=0x04 AD9136 DAC: Addr=0x0471. Data=0xff AD9136 DAC: Addr=0x0472. Data=0x00 AD9136 DAC: Addr=0x0473. Data=0x00 AD9136 DAC: Addr=0x0476. Data=0x01 AD9136 DAC: Addr=0x0477. Data=0x00 AD9136 DAC: Addr=0x0478. Data=0x01 AD9136 DAC: Addr=0x047a. Data=0x01 AD9136 DAC: Addr=0x047a. Data=0x01 AD9136 DAC: Addr=0x047b. Data=0x08 AD9136 DAC: Addr=0x047c. Data=0xff AD9136 DAC: Addr=0x047d. Data=0xff AD9136 DAC: Addr=0x047e. Data=0x00 AD9136 DAC: Addr=0x0520. Data=0x1c AD9136 DAC: Addr=0x0521. Data=0x00 AD9136 DAC: Addr=0x0522. Data=0x00 JESD204_TX: Addr=0x0000. Data=0x00010361 JESD204_TX: Addr=0x0004. Data=0x00000000 JESD204_TX: Addr=0x0008. Data=0x00000000 JESD204_TX: Addr=0x000c. Data=0x32303454 JESD204_TX: Addr=0x0010. Data=0x00000008 JESD204_TX: Addr=0x0014. Data=0x00000002 JESD204_TX: Addr=0x0018. Data=0x00000101 JESD204_TX: Addr=0x0080. Data=0x00000000 JESD204_TX: Addr=0x0084. Data=0x00000000 JESD204_TX: Addr=0x0088. Data=0x00000000 JESD204_TX: Addr=0x00c0. Data=0x00000000 JESD204_TX: Addr=0x00c4. Data=0x00000000 JESD204_TX: Addr=0x00c8. Data=0x00050004 JESD204_TX: Addr=0x0100. Data=0x00000000 JESD204_TX: Addr=0x0104. Data=0x00000000 JESD204_TX: Addr=0x0108. Data=0x00000003 JESD204_TX: Addr=0x0200. Data=0x00000000 JESD204_TX: Addr=0x0210. Data=0x0000001f JESD204_TX: Addr=0x0214. Data=0x00000002 JESD204_TX: Addr=0x0218. Data=0x00000000 JESD204_TX: Addr=0x0240. Data=0x00000000 JESD204_TX: Addr=0x0244. Data=0x00000003 JESD204_TX: Addr=0x0248. Data=0x00000000 JESD204_TX: Addr=0x0280. Data=0x00000001 JESD204_TX: Addr=0x0310. Data=0x02ab0000 JESD204_TX: Addr=0x0314. Data=0x00018800 JESD204_TX: Addr=0x0318. Data=0x22301002 JESD204_TX: Addr=0x031c. Data=0x3a000080 JESD204_TX: Addr=0x0330. Data=0x02ab0000 JESD204_TX: Addr=0x0334. Data=0x00018801 JESD204_TX: Addr=0x0338. Data=0x22301002 JESD204_TX: Addr=0x033c. Data=0x3b000080 JESD204_TX: Addr=0x0350. Data=0x02ab0000 JESD204_TX: Addr=0x0354. Data=0x00018802 JESD204_TX: Addr=0x0358. Data=0x22301002 JESD204_TX: Addr=0x035c. Data=0x3c000080 JESD204_TX: Addr=0x0370. Data=0x02ab0000 JESD204_TX: Addr=0x0374. Data=0x00018803 JESD204_TX: Addr=0x0378. Data=0x22301002 JESD204_TX: Addr=0x037c. Data=0x3d000080 JESD204_TX: Addr=0x0390. Data=0x02ab0000 JESD204_TX: Addr=0x0394. Data=0x00018804 JESD204_TX: Addr=0x0398. Data=0x22301002 JESD204_TX: Addr=0x039c. Data=0x3e000080 JESD204_TX: Addr=0x03b0. Data=0x02ab0000 JESD204_TX: Addr=0x03b4. Data=0x00018805 JESD204_TX: Addr=0x03b8. Data=0x22301002 JESD204_TX: Addr=0x03bc. Data=0x3f000080 JESD204_TX: Addr=0x03d0. Data=0x02ab0000 JESD204_TX: Addr=0x03d4. Data=0x00018806 JESD204_TX: Addr=0x03d8. Data=0x22301002 JESD204_TX: Addr=0x03dc. Data=0x40000080 JESD204_TX: Addr=0x03f0. Data=0x02ab0000 JESD204_TX: Addr=0x03f4. Data=0x00018807 JESD204_TX: Addr=0x03f8. Data=0x22301002 JESD204_TX: Addr=0x03fc. Data=0x41000080 JESD204_TPL: Addr=0x0000. Data=0x00090162 JESD204_TPL: Addr=0x0004. Data=0x00000000 JESD204_TPL: Addr=0x0008. Data=0x00000000 JESD204_TPL: Addr=0x000c. Data=0x00000001 JESD204_TPL: Addr=0x0010. Data=0x00000000 JESD204_TPL: Addr=0x001c. Data=0x00000000 JESD204_TPL: Addr=0x0040. Data=0x00000003 JESD204_TPL: Addr=0x0044. Data=0x00000000 JESD204_TPL: Addr=0x0048. Data=0x00000000 JESD204_TPL: Addr=0x004c. Data=0x00000001 JESD204_TPL: Addr=0x0050. Data=0x00000000 JESD204_TPL: Addr=0x0054. Data=0x00050005 JESD204_TPL: Addr=0x0058. Data=0x00000008 JESD204_TPL: Addr=0x005c. Data=0x00000001 JESD204_TPL: Addr=0x0060. Data=0x00000000 JESD204_TPL: Addr=0x0070. Data=0x00000000 JESD204_TPL: Addr=0x0074. Data=0x00020000 JESD204_TPL: Addr=0x0078. Data=0x00000000 JESD204_TPL: Addr=0x007c. Data=0x00000000 JESD204_TPL: Addr=0x0088. Data=0x00000000 JESD204_TPL: Addr=0x00a0. Data=0x00000002 JESD204_TPL: Addr=0x00b8. Data=0x00000000 JESD204_TPL: Addr=0x00bc. Data=0x00000000 JESD204_TPL: Addr=0x0200. Data=0x00000000 JESD204_TPL: Addr=0x0204. Data=0x00000001 JESD204_TPL: Addr=0x0240. Data=0x01020802 JESD204_TPL: Addr=0x0244. Data=0x00001010 JESD204_TPL: Addr=0x0400. Data=0x00000000 JESD204_TPL: Addr=0x0404. Data=0x00000000 JESD204_TPL: Addr=0x0408. Data=0x00000000 JESD204_TPL: Addr=0x040c. Data=0x00000000 JESD204_TPL: Addr=0x0410. Data=0x00000000 JESD204_TPL: Addr=0x0414. Data=0x00000000 JESD204_TPL: Addr=0x0418. Data=0x00000000 JESD204_TPL: Addr=0x041c. Data=0x00000000 JESD204_TPL: Addr=0x0420. Data=0x01001010 JESD204_TPL: Addr=0x0424. Data=0x00010001 JESD204_TPL: Addr=0x0428. Data=0x00000000 JESD204_TPL: Addr=0x0440. Data=0x00000000 JESD204_TPL: Addr=0x0444. Data=0x00000000 JESD204_TPL: Addr=0x0448. Data=0x00000000 JESD204_TPL: Addr=0x044c. Data=0x00000000 JESD204_TPL: Addr=0x0450. Data=0x00000000 JESD204_TPL: Addr=0x0454. Data=0x00000000 JESD204_TPL: Addr=0x0458. Data=0x00000000 JESD204_TPL: Addr=0x045c. Data=0x00000000 JESD204_TPL: Addr=0x0460. Data=0x01001010 JESD204_TPL: Addr=0x0464. Data=0x00010001 JESD204_TPL: Addr=0x0468. Data=0x00000000
