JESD204 IP core - build
Hi all,
I try build IP core for JESD204 from AD (https://github.com/analogdevicesinc/hdl/tree/dev/library/jesd204)
but I get message e.g.:
make: Entering directory '/home/tomas/Dokumenty/hdl-dev/library/jesd204/jesd204_rx' make -C ../../jesd204/jesd204_common/ make[1]: Entering directory '/home/tomas/Dokumenty/hdl-dev/library/jesd204/jesd204_common' rm -rf *.cache *.data *.xpr *.log component.xml *.jou xgui *.ip_user_files *.srcs *.hw *.sim .Xil vivado -mode batch -source jesd204_common_ip.tcl  >> jesd204_common_ip.log 2>&1 Makefile:45: recipe for target 'jesd204_common.xpr' failed make[1]: *** [jesd204_common.xpr] Error 127 make[1]: Leaving directory '/home/tomas/Dokumenty/hdl-dev/library/jesd204/jesd204_common' Makefile:65: recipe for target 'dep' failed make: *** [dep] Error 2 make: Leaving directory '/home/tomas/Dokumenty/hdl-dev/library/jesd204/jesd204_rx
I tried it under Linux and also under Win, Vivado 17.4 and also 14.2
Do you have some experiences with building IP cores from AD?
Parents
  • Yes, i build all cores in JESD204 folder (jesd204_common, jesd204_rx/tx, axi jesd204 rx/tx, interfaces, etc.).
    I do not use specific project from your HDL projects examples, I create own design for AD9644.
    It sems, that files from jesd204_common is missing. I will try add these files manually.
Reply
Children
No Data
