I am not using the transmit chain in the adrv9009/zcu102 reference design. What steps should i follow to safely remove the chain and free up FPGA resources?
Andy
ADRV9009
Recommended for New Designs
The ADRV9009 is a highly integrated, radio frequency (RF), agile transceiver offering dual transmitters and receivers, integrated synthesizers, and digital...
Datasheet
ADRV9009 on Analog.com
Andy
Hi Andy,
Remove all IPs from the Tx path starting from the DMA untill the jesd_link.
Similar thread on removing the Rx and using Tx.
Andrei
Hi Andrei,
Thanks for your response. A couple of clarifications:
1) So in the block diagram within Vivado I can remove the axi_hp3_interconnect and the tx_adrv9009_tpl_core and all blocks in between these?
2) I think i then need to remove the corresponding blocks in /linux-xlnx/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-adrv9009.dts? Do i need to do anything with /linux-xlnx/arch/arm64/boot/dts/xilinx/adi-adrv9009.dtsi or any other files?
3) Will the scope on IIO_Oscilloscope still work?
Thanks
ADRV9009 without TX is effectively a ADRV9008-1.
Please use this device tree instead:
OSC will still work.
-Michael
Hi
This does not seem to work.
I opened the block diagram in vivado and removed the dma to the jesd link. I also replaced zynqmp-zcu102-rev10-adrv9009.dts for zcu102-rev10-adrv9008-1. All builds fine, but when the kernel starts it hangs (see below). Any ideas?
6.818785] Synchronous External Abort: synchronous external abort (0x96000010) at 0xffffff800d274048
[ 6.827999] Internal error: : 96000010 [#1] SMP
[ 6.832514] Modules linked in:
[ 6.835556] CPU: 1 PID: 125 Comm: kworker/1:1 Not tainted 4.14.0 #1
[ 6.841811] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[ 6.846768] Workqueue: events deferred_probe_work_func
[ 6.851890] task: ffffffc87b01a100 task.stack: ffffff80093c0000
[ 6.857798] PC is at adrv9009_post_setup+0x30/0xd8
[ 6.862578] LR is at axiadc_probe+0x360/0x6d8
[ 6.866917] pc : [<ffffff80087c6568>] lr : [<ffffff8008788148>] pstate: 40000045
[ 6.874295] sp : ffffff80093c3b80
[ 6.877594] x29: ffffff80093c3b90 x28: ffffff8008c5b0b0
[ 6.882889] x27: ffffff8008bb1000 x26: 0000000000000004
[ 6.888184] x25: ffffffc87b007e80 x24: 0000000000000001
[ 6.893480] x23: ffffffc87b0b0010 x22: ffffffc87a5ddc18
[ 6.898775] x21: ffffffc87b0b0000 x20: ffffffc87a91a000
[ 6.904070] x19: ffffffc87a91a500 x18: 0000000000000001
[ 6.909365] x17: 0000000000000000 x16: 0000000000000000
[ 6.914661] x15: ffffffffffffffff x14: 0000000000000000
[ 6.919956] x13: 0000000000000000 x12: 0000000000000000
[ 6.925252] x11: 0000000000000000 x10: 0000000000000000
[ 6.930547] x9 : 0000000000000000 x8 : 0000000000000003
[ 6.935842] x7 : 0000000000000000 x6 : 0000000000000004
[ 6.941137] x5 : 000000000000000a x4 : ffffffc87a91a858
[ 6.946433] x3 : ffffffc87a91a500 x2 : 0000000000004048
[ 6.951728] x1 : ffffffc87a5ddc18 x0 : ffffff800d274048
[ 6.957025] Process kworker/1:1 (pid: 125, stack limit = 0xffffff80093c0000)
[ 6.964055] Call trace:
[ 6.966488] Exception stack(0xffffff80093c3a40 to 0xffffff80093c3b80)
[ 6.972912] 3a40: ffffff800d274048 ffffffc87a5ddc18 0000000000004048 ffffffc87a91a500
[ 6.980724] 3a60: ffffffc87a91a858 000000000000000a 0000000000000004 0000000000000000
[ 6.988537] 3a80: 0000000000000003 0000000000000000 0000000000000000 0000000000000000
[ 6.996350] 3aa0: 0000000000000000 0000000000000000 0000000000000000 ffffffffffffffff
[ 7.004163] 3ac0: 0000000000000000 0000000000000000 0000000000000001 ffffffc87a91a500
[ 7.011976] 3ae0: ffffffc87a91a000 ffffffc87b0b0000 ffffffc87a5ddc18 ffffffc87b0b0010
[ 7.019788] 3b00: 0000000000000001 ffffffc87b007e80 0000000000000004 ffffff8008bb1000
[ 7.027601] 3b20: ffffff8008c5b0b0 ffffff80093c3b90 ffffff8008788148 ffffff80093c3b80
[ 7.035414] 3b40: ffffff80087c6568 0000000040000045 ffffffc87a91a500 ffffffc87a91a000
[ 7.043227] 3b60: ffffffffffffffff ffffffc87a5ddc18 ffffff80093c3b90 ffffff80087c6568
[ 7.051040] [<ffffff80087c6568>] adrv9009_post_setup+0x30/0xd8
[ 7.056857] [<ffffff800855faf8>] platform_drv_probe+0x58/0xb8
[ 7.062594] [<ffffff800855dee4>] driver_probe_device+0x22c/0x2d8
[ 7.068584] [<ffffff800855e0ec>] __device_attach_driver+0x9c/0xf8
[ 7.074660] [<ffffff800855c0e4>] bus_for_each_drv+0x4c/0x98
[ 7.080216] [<ffffff800855db88>] __device_attach+0xc0/0x138
[ 7.085772] [<ffffff800855e1a8>] device_initial_probe+0x10/0x18
[ 7.091675] [<ffffff800855d044>] bus_probe_device+0x94/0xa0
[ 7.097231] [<ffffff800855d4f8>] deferred_probe_work_func+0xa0/0x148
[ 7.103569] [<ffffff80080b22bc>] process_one_work+0x1dc/0x348
[ 7.109306] [<ffffff80080b2674>] worker_thread+0x24c/0x488
[ 7.114775] [<ffffff80080b8104>] kthread+0x12c/0x130
[ 7.119723] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[ 7.125019] Code: b900001f f9405860 d2880902 8b020000 (b9400000)
[ 7.131103] ---[ end trace fae3c0a0f9484eb2 ]---
Hi
