HELLO ALL!
Kindly tell me about the trigger port on fmcjesdadc1 board. please elaborate its functionality, Can it be used to trigger all 4 channels at same time?In library folder there is an ip axi_adc_trigger, as shown in figure,
kindly tell me its integration in HDL referance design for 4 channel synchronized triggering.
Thanks Andrei for your message. We resolved the issue of getting noisy output as the trigger pin of the ADC board was not given in the constraint file. We have redone the whole trigger input mechanism…
Hi,I think you can use it. You need 2 axi_adc_trigger instances for all 4 channels.Connect the trigger_out_la of the first to the trigger_in of the second. This is the sync between the channels part.
The purpose of axi_adc_trigegr is to generate the sync signal(start capture) for the DMA signal.
You will also need the util_var_fifo and a BRM memory for history(samples before the trigger).We can only offer limited support regarding this since the core is design for M2k(adalm2000).Take a look at how it is integrated into the M2k. The easiest way is to build the project.
wiki.analog.com/.../axi_adc_triggerwiki.analog.com/.../util_var_fifowiki.analog.com/.../m2k
If you browse the wiki and github the m2k example is probably the answer for 90% of the questions regarding this.The axi_adc_trigger does not work on its own, you need software for it( wiki and github).
Andrei
Hello. i had modified the hdl-master-2018_r2 block diagram as
from adc_core_0 i take the data_a which is the data of channel A0, and split it into 2 16 bit chunks and give these two to adc_trigger_v1 and connect its triger pin with the G3 and G4 ports in constraint file. then i take the output of trigger core and concatinate them and insert it in adc_ad2950_cpack. After creating bit stream i make no-OS-master by providing its bit file and run the code. then i connect a trigger pulse with signal generator and provide a 1 Vpp and 500mVpp offset and 1kHz frequency. Ramp test runs successfully (without any inclution of trigger bit in data )and when i close test and just start adc then data is just noise in memory.
this is the data of ramp test in memory but when i omit test then
kindly guide the proper steps to deal with the setup.
Hi,Please use the hdl_2019_r1 release(Vivado 2018.3). The trigger bit is no longer present in the data. And the HDL is reflected in the latest axi_adc_trigger documentation.After the above can you share the tcl code (export from block design), much more details and easier to follow than a screenshot .Andrei
Thanks Andrei for your message. We resolved the issue of getting noisy output as the trigger pin of the ADC board was not given in the constraint file. We have redone the whole trigger input mechanism and still unable to get the trigger signal. Since our current issue was very different from this one, we have posted it as a separate question. Please review.
https://ez.analog.com/fpga/f/discussions/121443/trigger-signal-acquisition-kc705-ad-fmcjesdadc1-ebz
