Problems with new boot.bin
Hi guys,
     I am using ARRV9008-2 eval board with EVAL-TPG-ZYNQ3.
     TES works well by default when I use the ADRV9009-SDCARD(JUNE 2018 rev 1.0 for use with Windows-based TES).
     I wanna do some change for PL, So I compile the BOOT.bin and replace the boot.bin in ADRV9009-SDCRAD.
     (reference wiki.analog.com/.../build-the-zynq-boot-image)
     I used the command "px -x", I cannot see the cmd_server run backgroud,so I run cmd_server manually.
     But this time, TES cannot connect with EVAL-TPG-ZYNQ3 again,the  cmd_server prompt me error:
   “cannot open EEPROM file /sys/devices/fpga-axi.4/41600000.i2c/i2c-0/i2c-6/6-0050/eeprom”
     Here is my dmesg log.
U-Boot 2019.01-00272-g3ccf78ee29-dirty (Dec 05 2019 - 19:33:17 -0800) Xilinx Zynq ZC706
CPU:   Zynq 7z045
Silicon: v3.1
Model: Xilinx ZC706 board
DRAM:  ECC disabled 1 GiB
MMC:   mmc@e0100000: 0
Loading Environment from SPI Flash... SF: Detected s25fl128s_64k with page size 512 Bytes, erase size 128 KiB, total 32 MiB
OK
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Net:   ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
eth0: ethernet@e000b000
Hit any key to stop autoboot:  0
Device: mmc@e0100000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
379 bytes read in 8 ms (45.9 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
2999904 bytes read in 204 ms (14 MiB/s)
11848 bytes read in 13 ms (889.6 KiB/s)
** Unable to read file uramdisk.image.gz **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.14.0-g5ea3bc9
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2999840 Bytes = 2.9 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Device Tree to 1fffa000, end 1ffffe47 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 3.14.0-g5ea3bc9 (jeckard@hotel.adral.analog.com) (gcc version 4.7.3 (Sourcery CodeBench Lite 2013.05-40) ) #1 SMP PREEMPT Thu May 1 08:26:35 EDT 2014
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Xilinx Zynq ZC706
bootconsole [earlycon0] enabled
cma: CMA: reserved 40 MiB at 2d000000
Memory policy: Data cache writealloc
PERCPU: Embedded 7 pages/cpu @ec7c8000 s7680 r8192 d12800 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260624
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 992360K/1048576K available (3984K kernel code, 213K rwdata, 1512K rodata, 183K init, 126K bss, 56216K reserved, 270336K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0566420   (5498 kB)
      .init : 0xc0567000 - 0xc0594e00   ( 184 kB)
      .data : 0xc0596000 - 0xc05cb400   ( 213 kB)
       .bss : 0xc05cb40c - 0xc05eacd4   ( 127 kB)
Preemptible hierarchical RCU implementation.
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0004000
zynq_clock_init: clkc starts at f0004100
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207951633ns
timer #0 at f0006000, irq=43
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x3c3eb8 - 0x3c3eec
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72760000, Cache size: 512 kB
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
syscon f8000000.slcr: regmap [mem 0xf8000000-0xf8000fff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce pool size: 64 pages
msgmni has been set to 1490
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-2364208
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
���k鬽���[ttyPS0] enabledMMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xuartps
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
[drm] Initialized drm 1.1.0 20060810
drivers/gpu/drm/adi_axi_hdmi/axi_hdmi_drv.c:axi_hdmi_platform_probe[176]
platform 70e00000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
cdns-spi e0006000.spi: at 0xE0006000 mapped to 0xF0016000, irq=58
cdns-spi e0007000.spi: at 0xE0007000 mapped to 0xF0018000, irq=81
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
pca954x 0-0074: probe failed
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
platform leds.2: Driver leds-gpio requests probe deferral
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SL08G 7.40 GiB
adv7511-hdmi-snd adv7511_hdmi_snd.6: ASoC: CODEC (null) not registered
platform adv7511_hdmi_snd.6: Driver adv7511-hdmi-snd requests probe deferral
 mmcblk0: p1 p2
TCP: cubic registered
Registering SWP/SWPB emulation handler
regulator-dummy: disabling
drivers/gpu/drm/adi_axi_hdmi/axi_hdmi_drv.c:axi_hdmi_platform_probe[197]
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
  No soundcards found.
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 180K (c0567000 - c0594000)
��+ˋ� ureadahead main process (686) terminated with status 5
Last login: Wed Dec 31 19:00:06 EST 1969 on tty1
Welcome to Linaro 12.11 (GNU/Linux 3.14.0-g5ea3bc9 armv7l)
 * Documentation:  https://wiki.linaro.org/
root@linaro-ubuntu-desktop:~# ps -x
Warning: bad ps syntax, perhaps a bogus '-'? See http://procps.sf.net/faq.html
  PID TTY      STAT   TIME COMMAND
    1 ?        Ss     0:01 /sbin/init
    2 ?        S      0:00 [kthreadd]
    3 ?        S      0:00 [ksoftirqd/0]
    4 ?        S      0:00 [kworker/0:0]
    5 ?        S<     0:00 [kworker/0:0H]
    6 ?        S      0:00 [kworker/u4:0]
    7 ?        S      0:00 [rcu_preempt]
    8 ?        S      0:00 [rcu_sched]
    9 ?        S      0:00 [rcu_bh]
   10 ?        S      0:00 [migration/0]
   11 ?        S      0:00 [migration/1]
   12 ?        S      0:00 [ksoftirqd/1]
   13 ?        S      0:00 [kworker/1:0]
   14 ?        S<     0:00 [kworker/1:0H]
   15 ?        S<     0:00 [khelper]
   16 ?        S      0:00 [kdevtmpfs]
   17 ?        S      0:00 [kworker/u4:1]
  206 ?        S<     0:00 [writeback]
  208 ?        S<     0:00 [bioset]
  209 ?        S<     0:00 [kblockd]
  227 ?        S      0:00 [khubd]
  327 ?        S      0:00 [kworker/0:1]
  337 ?        S      0:00 [khungtaskd]
  342 ?        S      0:00 [kswapd0]
  343 ?        S      0:00 [fsnotify_mark]
  430 ?        S      0:00 [spi32766]
  444 ?        S      0:00 [spi32765]
  480 ?        S<     0:00 [xemacps]
  504 ?        S<     0:00 [kpsmoused]
  522 ?        S      0:00 [kworker/u4:2]
  626 ?        S      0:00 [irq/39-f8007100]
  656 ?        S      0:00 [mmcqd/0]
  675 ?        S      0:00 [kworker/1:1]
  679 ?        S<     0:00 [deferwq]
  680 ?        S<     0:00 [kworker/0:1H]
  681 ?        S      0:00 [jbd2/mmcblk0p2-]
  682 ?        S<     0:00 [ext4-rsv-conver]
  710 ?        S<     0:00 [kworker/1:1H]
  755 ?        S      0:00 upstart-udev-bridge --daemon
  769 ?        Ss     0:00 /usr/sbin/sshd -D
  778 ?        Ss     0:00 /sbin/udevd --daemon
 1019 ?        Ss     0:00 /usr/sbin/modem-manager
 1069 ?        Ss     0:00 /usr/sbin/cupsd -F
 1081 ?        S      0:00 /sbin/udevd --daemon
 1082 ?        S      0:00 /sbin/udevd --daemon
 1109 ?        Ssl    0:01 NetworkManager
 1177 ?        Sl     0:00 /usr/lib/policykit-1/polkitd --no-debug
 1205 ?        Ss     0:00 smbd -F
 1218 ?        S      0:00 upstart-socket-bridge --daemon
 1237 tty4     Ss+    0:00 /sbin/getty -8 38400 tty4
 1241 tty5     Ss+    0:00 /sbin/getty -8 38400 tty5
 1242 ttyPS0   Ss     0:00 /bin/login -f
 1251 tty2     Ss+    0:00 /sbin/getty -8 38400 tty2
 1253 tty3     Ss+    0:00 /sbin/getty -8 38400 tty3
 1256 tty6     Ss+    0:00 /sbin/getty -8 38400 tty6
 1280 ?        Ss     0:00 anacron -s
 1282 ?        Rs     0:34 cron
 1298 ?        S      0:00 /bin/sh /etc/init.d/ondemand background
 1305 ?        S      0:00 sleep 60
 1340 tty1     Ss     0:00 /bin/login -f
 1407 ?        Sl     0:00 /usr/sbin/console-kit-daemon --no-daemon
 1505 ttyPS0   S      0:00 -bash
 1517 tty1     S+     0:00 -bash
 1526 ?        S      0:00 smbd -F
 1582 ?        Ss     0:00 nmbd -D
 1599 ttyPS0   R+     0:00 ps -x
root@linaro-ubuntu-desktop:~# /home/analog/cmd_server/cmd_server &
[1] 1601
Server-Using 0.0.0.0 and port 55555...
root@linaro-ubuntu-desktop:~# Cannot open EEPROM file '/sys/devices/fpga-axi.4/41600000.i2c/i2c-0/i2c-6/6-0050/eeprom'
root@linaro-ubuntu-desktop:~# dmesg
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat c05ca7c0, node_mem_map ec7e4000
  Normal zone: 1520 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 194560 pages, LIFO batch:31
  HighMem zone: 528 pages used for memmap
  HighMem zone: 67584 pages, LIFO batch:15
pcpu-alloc: s7680 r8192 d12800 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Zynq clock init
Brought up 2 CPUs
e0001000.uart: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xuartps
brd: module loaded
loop: module loaded
 mmcblk0: p1 p2
ALSA device list:
devtmpfs: mounted
random: init urandom read with 18 bits of entropy available
init: ureadahead main process (686) terminated with status 5
udevd[778]: starting version 175
init: gator-daemon main process (771) terminated with status 1
init: Failed to spawn bluetooth main process: unable to execute: No such file or directory
init: udev-fallback-graphics main process (1148) terminated with status 1
init: failsafe main process (1186) killed by TERM signal
init: alsa-restore main process (1243) terminated with status 19
init: hybrid-gfx main process (1260) terminated with status 1
init: tty1 main process (1318) killed by TERM signal
init: lightdm main process (1281) terminated with status 1
random: nonblocking pool is initialized
xemacps e000b000.eth: Set clk to 124999998 Hz
xemacps e000b000.eth: link up (1000/FULL)
init: failsafe-x main process (1366) terminated with status 1
     Thanks in advance.
