FMCJESDADC and KC705 data acquisition
Hello!
I have KC705 and Ad-fmcjesdadc1-ebz boards. I have built the Vivado project from the GITHUB repo below:
https://wiki.analog.com/resources/fpga/xilinx/fmc/ad-fmcjesdadc1-ebz
I have already acquired the signal using IIO Oscilloscope. Now, I want to write ADC-0 data to DDR memory and process it in a small program executed on Microblaze. I have the following queries:
1. I downloaded the bit file and now want to write a C program that can run on Microblaze? Can anyone guide me through the process or point out where the process is given.
2. Do we manually need to trigger ADC in C program to write it on the DDR memory before reading it or as soon as I download the bit file made from the project available on GITHUB, the ADCs are triggered automatically.
3. When I open the Vivado project, the following is displayed:
The image shows that the output of the two cpacks (which are essentially FIFOs as per my understanding) is written to DDR through DMA controllers. Can anybody guide how different samples are written in the memory.
For example, starting from an offset, the first two bytes (16bits) may come from ADC0, the next two bytes may come from ADC1, the next two bytes from ADC2 and so on. Can anybody give me a clue how different samples will be arranged in the memory.
Added more detail to the question.
[edited by: sheikh fahad at 7:14 AM (GMT 0) on 19 Nov 2019]
  • +1
    on Nov 25, 2019 1:28 PM
    Hello.
    Basic software etup is described here: https://wiki.analog.com/resources/fpga/xilinx/software_setup.
    The software for microblaze is: https://github.com/analogdevicesinc/no-OS/tree/master/ad-fmcjesdadc1-ebz
    Have you looked over: https://github.com/analogdevicesinc/no-OS/blob/master/ad-fmcjesdadc1-ebz/ad_fmcjesdadc1_ebz.c ? The default reference design will setup both ADC9250s to capture data on all channels. When the DMA is started, it will capture the data from ADCs to te configured start address. There, by default will be stored as 16 bits, sample 0/channl0,sample 0/channel1, sample 1/channel0/ sample 1/channel 1 ...etc.
    Adrian
    on Dec 10, 2019 3:13 PM in reply to sheikh fahad
    Sorry for the late reply.
    I made a test with the changes described above... worked for me.
    I will attach the results tor a 2 MHz sine on the ch0.
    Can you check again that you changed everything described above?
    3808.capture_ch1_125MSPS.txt
    4128
    3910
    3854
    4050
    4333
    4807
    5420
    6197
    6992
    7867
    57920
    58783
    59564
    60283
    60902
    61304
    61587
    61684
    61588
    61367
    60933
    60360
    59661
    58873
    58006
    7972
    7087
    6243
    5523
    4889
    4372
    4067
    3912
    3894
    4082
    4467
    5012
    5594
    6391
    7270
    8139
    58205
    59039
    59779
    60425
    61023
    61427
    61634
    61708
    61562
    61262
    60727
    60171
    59445
    58612
    57755
    7710
    6818
    6066
    5330
    4701
    4234
    3960
    3896
    3917
    4175
    4591
    5129
    5889
    6643
    7444
    57525
    58398
    59286
    59965
    60620
    61113
    61474
    61653
    61661
    61472
    61136
    60585
    59966
    59205
    58381
    57465
    7451
    6604
    5827
    5175
    4570
    4165
    3912
    3860
    3944
    4265
    4751
    5353
    6037
    6882
    7732
    57773
    58598
    59482
    60196
    60788
    61274
    61531
    61682
    61621
    61400
    60996
    60457
    59795
    58988
    58110
    8115
    7228
    6421
    5628
    4958
    4467
    4046
    3883
    3864
    4049
    4369
    4890
    5540
    6286
    7092
    7933
    58000
    58861
    59629
    60349
    60912
    61376
    61602
    61736
    61577
    61320
    60873
    60250
    59547
    58796
    57880
    7843
    7028
    6147
    5428
    4797
    4380
    4003
    3902
    3938
    4124
    4564
    5078
    5735
    6502
    7329
    57419
    58287
    59101
    59866
    60520
    61037
    61439
    61635
    61688
    61538
    61212
    60676
    60071
    59360
    58518
    57705
    7612
    6736
    5940
    5263
    4668
    4225
    3964
    3847
    3939
    4214
    4682
    5226
    5955
    6721
    7580
    57596
    58543
    59302
    60109
    60669
    61207
    61522
    61714
    61657
    61443
    61054
    60549
    59883
    59135
    58239
    57410
    7346
    6506
    5746
    5061
    4505
    4159
    3911
    3860
    3976
    4323
    4810
    5378
    6161
    6958
    7840
    57841
    58749
    59594
    60259
    60851
    61314
    61593
    61698
    61575
    61340
    60954
    60386
    59689
    58888
    58033
    7975
    7129
    6308
    5559
    4915
    4367
    4034
    3843
    3891
    4081
    4409
    4973
    5608
    6361
    7199
    8112
    58120
    58971
    59784
    60403
    61004
    61399
    61635
    61745
    61568
    61286
    60788
    60181
    59422
    58632
    57809
    7734
    6877
    6085
    5378
    4749
    4280
    3991
    3869
    3906
    4196
    4592
    5119
    5854
    6633
    7461
    57493
    58344
    59228
    59972
    60608
    61104
    61499
    61668
    61655
    61459
    61191
    60643
    59995
    59233
    58431
    57557
    7524
    6638
    5856
    5221
    4610
    4176
    3964
    3906
    3956
    4291
    4718
    5285
    6030
    6850
    7668
    57728
    58625
    59417
    60165
    60737
    61242
    61547
    61683
    61620
    61394
    61042
    60467
    59774
    58999
    58107
    8138
    7222
    6392
    5670
    5056
    4479
    4058
    3906
    3884
    4018
    4387
    4836
    5509
    6257
    7075
    7953
    57972
    58852
    59644
    60369
    60887
    61348
    61579
    61683
    61581
    61332
    60833
    60299
    59565
    58772
    57940
    7928
    7004
    6161
    5460
    4811
    4383
    4022
    3845
    3873
    4121
    4486
    5066
    5673
    6507
    7315
    8184
    58215
    59057
    59884
    60498
    61058
    61432
    61657
    61673
    61543
    61210
    60753
    60115
    59378
    58534
    57696
    7660
    6737
    5994
    5297
    4722
    4215
    3963
    3890
    3922
    4218
    4649
    5145
    5917
    6694
    7556
    57574
    58526
    59301
    60078
    60683
    61143
    61531
    61716
    61652
    61440
    61084
    60607
    59926
    59106
    58281
    57431
    7386
    6539
    5772
    5083
    4561
    4144
    3948
    3841
    4002
    4285
    4790
    5384
    6166
    6958
    7788
    57819
    58710
    59519
    60231
    60836
    61284
    61601
    61669
    61614
    61375
    60954
    60362
    59727
    58909
    58066
    8001
    7118
    6342
    5579
    4975
    4400
    4048
    3881
    3885
    4053
    4405
    4961
    5586
    6322
    7192
    8062
    58055
    58979
    59753
    60417
    60940
    61411
    61597
    61674
    61553
    61258
    60792
    60224
    59482
    58702
    57827
    7790
    6918
    6132
    5373
    4771
    4329
    3982
    3858
    3906
    4130
    4553
    5088
    5784
    6575
    7414
    57453
    58306
    59210
    59919
    60603
    61077
    61467
    61679
    61645
    61528
    61166
    60632
    60009
    59305
    58423
    57628
    7516
    6672
    5907
    5196
    4609
    4204
    3956
    3860
    3959
    4266
    4691
    5334
    5980
    6804
    7654
    57722
    58582
    59383
    60136
    60735
    61204
    61521
    61671
    61644
    61422
    61050
    60524
    59791
    59058
    58201
    57345
    7276
    6475
    5696
    5014
    4515
    4140
    3910
    3897
    4064
    4308
    4847
    5496
    6216
    7017
    7920
    57894
    58843
    59594
    60339
    60902
    61297
    61589
    61719
    61612
    61306
    60887
    60336
    59617
    58828
    57969
    7926
    6999
    6197
    5496
    4835
    4375
    4047
    3887
    3935
    4094
    4509
    5015
    5657
    6410
    7305
    8167
    58169
    59023
    59835
    60468
    61014
    61411
    61617
    61682
    61576
    61216
    60710
    60137
    59387
    58580
    57733
    7675
    6821
    6019
    5352
    4697
    4273
    3968
    3880
    3948
    4180
    4610
    5165
    5895
    6685
    7526
    57560
    58449
    59240
    60027
    60640
    61149
    61533
    61704
    61676
    61499
    61141
    60566
    59919
    59188
    58338
    57470
    7401
    6555
    5817
    5159
    4551
    4167
    3937
    3871
    3937
    4297
    4745
    5331
    6072
    6903
    7716
    57836
    58650
    59498
    60222
    60787
    61241
    61562
    61675
    61629
    61408
    60987
    60428
    59744
    58921
    58107
    8068
    7196
    6346
    5586
    4973
    4416
    4101
    3870
    3846
    4080
    4370
    4933
    5563
    6275
    7124
    8006
    58043
    58883
    59674
    60422
    60904
    61378
    61595
    61727
    61585
    61294
    60880
    60211
    59535
    58714
    57860
    7818
    6951
    6156
    5419
    4787
    4328
    4000
    3898
    3916
    4154
    4579
    5075
    5779
    6530
    7388
    57402
    58321
    59170
    59850
    60536
    61114
    61426
    61624
    61641
    61500
    61164
    60638
    60064
    59292
    58473
    57626
    7560
    6708
    5880
    5253
    4635
    4239
    3951
    3866
    3950
    4271
    4659
    5270
    5980
    6781
    7626
    57659
    58532
    59349
    60132
    60707
    61193
    61519
    61711
    61636
    61416
    60997
    60508
    59852
    59089
    58230
    57430
    7283
    6493
    5727
    5059
    4544
    4143
    3934
    3868
    4023
    4351
    4803
    5448
    6207
    6975
    7848
    57890
    58813
    59606
    60263
    60870
    61293
    61592
    61718
    61597
    61364
    60918
    60341
    59655
    58858
    57992
    7957
    7089
    6269
    5550
    4917
    4358
    4050
    3874
    3863
    4067
    4464
    4976
    5615
    6385
    7239
    8088
    58127
    58977
    59821
    60497
    61021
    61399
    61658
    61687
    61567
    61262
    60794
    60170
    59462
    58597
    57743
    7700
    6849
    6062
    5343
    4727
    4277
    4042
    3840
    3919
    4195
    4605
    5160
    5870
    6642
    7518
    57523
    58427
    59249
    60022
    60635
    61156
    61540
    61666
    61653
    61496
    61149
    60610
    59967
    59205
    58357
    57485
    7451
    6602
    5852
    5168
    4568
    4151
    3928
    3871
    3977
    4276
    4723
    5319
    6075
    6869
    7722
    57796
    58628
    59430
    60182
    60823
    61245
    61523
    61706
    61627
    61405
    60980
    60421
    59771
    58993
    58109
    8109
    7175
    6403
    5614
    4992
    4431
    4092
    3936
    3874
    4034
    4454
    4851
    5510
    6287
    7116
    7979
    57976
    58915
    59671
    60355
    60887
    61319
    61591
    61701
    61570
    61300
    60843
    60303
    59554
    58760
    57879
    7869
    6977
    6159
    5441
    4791
    4303
    4004
    3871
    3892
    4123
    4502
    5070
    5773
    6499
    7327
    57398
    58251
    59124
    59849
    60500
    61076
    61417
    61660
    61691
    61544
    61183
    60661
    60090
    59359
    58507
    57648
    7566
    6743
    5952
    5263
    4703
    4226
    3973
    3858
    3915
    4234
    4663
    5182
    5952
    6755
    7594
    57604
    58548
    59326
    60074
    60714
    61221
    61515
    61652
    61622
    61421
    61076
    60528
    59862
    59132
    58244
    57403
    7371
    6498
    5752
    5072
    4514
    4117
    3960
    3852
    4012
    4316
    4825
    5406
    6151
    6924
    7841
    57850
    58778
    59569
    60259
    60861
    61286
    61578
    61653
    61589
    61370
    60954
    60340
    59698
    58853
    58057
    8018
    7088
    6303
    5526
    4905
    4389
    3995
    3862
    3851
    4068
    4445
    4977
    5597
    6386
    7212
    8069
    58140
    58980
    59740
    60430
    60966
    61385
    61654
    61668
    61533
    61234
    60752
    60238
    59458
    58711
    57751
    7778
    6879
    6078
    5357
    4753
    4314
    3970
    3907
    3918
    4190
    4584
    5146
    5828
    6618
    7480
    57460
    58382
    59242
    59943
    60630
    61095
    61465
    61667
    61643
    61490
    61173
    60657
    59943
    59241
    58423
    57538
    7500
    6640
    5848
    5210
    4584
    4203
    3940
    3846
    3954
    4270
    4700
    5308
    6011
    6831
    7669
    57737
    58616
    59418
    60204
    60723
    61234
    61519
    61683
    61621
    61415
    61013
    60490
    59800
    59029
    58170
    8166
    7245
    6447
    5668
    5011
    4502
    4096
    3905
    3893
    4079
    4339
    4868
    5515
    6260
    7104
    7972
    57941
    58848
    59622
    60379
    60929
    61348
    61631
    61717
    61596
    61369
    60875
    60304
    59585
    58798
    57927
    7899
    6974
    6189
    5488
    4845
    4369
    4045
    3915
    3897
    4134
    4496
    5062
    5697
    6507
    7315
    57351
    58228
    59059
    59843
    60508
    61054
    61393
    61633
    61659
    61508
    61225
    60700
    60092
    59362
    58523
    57720
    7659
    6786
    5978
    5276
    4687
    4235
    3989
    3900
    3942
    4230
    4647
    5216
    5936
    6704
    7586
    57548
    58507
    59272
    60054
    60614
    61184
    61512
    61674
    61668
    61450
    61071
    60567
    59913
    59122
    58281
    57407
    7354
    6555
    5807
    5110
    4521
    4137
    3899
    3902
    3982
    4314
    4809
    5362
    6113
    6944
    7779
    57839
    58707
    59550
    60259
    60846
    61250
    61575
    61678
    61609
    61383
    60962
    60394
    59702
    58891
    58084
    8040
    7163
    6310
    5586
    4921
    4406
    4048
    3887
    3871
    4062
    4424
    4953
    5582
    6352
    7160
    8031
    58067
    58951
    59697
    60390
    60956
    61401
    61590
    61674
    61577
    61283
    60803
    60223
    59502
    58669
    57817
    7799
    6860
    6081
    5396
    4755
    4310
    3984
    3843
    3878
    4136
    4589
    5102
    5792
    6542
    7432
    57436
    58299
    59176
    59902
    60567
    61094
    61448
    61616
    61695
    61461
    61148
    60637
    60018
    59259
    58453
    57576
    7562
    6676
    5863
    5204
    4587
    4213
    3918
    3864
    3955
    4279
    4693
    5341
    5982
    6823
    7639
    57729
    58597
    59387
    60151
    60688
    61220
    61559
    61717
    61634
    61444
    61018
    60482
    59868
    59029
    58228
    8179
    7267
    6445
    5701
    5006
    4452
    4116
    3922
    3888
    4003
    4416
    4798
    5498
    6240
    7033
    7922
    57943
    58821
    59634
    60282
    60902
    61323
    61593
    61694
    61592
    61319
    60863
    60338
    59605
    58788
    57976
    7943
    7081
    6229
    5509
    4847
    4393
    4015
    3875
    3863
    4101
    4441
    5059
    5695
    6470
    7263
    8147
    58229
    59022
    59833
    60451
    61018
    61427
    61662
    61697
    61522
    61211
    60740
    60106
    59361
    58569
    57703
    7656
    6826
    5991
    5264
    4716
    4263
    4010
    3870
    3956
    4185
    4626
    5156
    5856
    6659
    7532
    57571
    58453
    59275
    60025
    60635
    61122
    61553
    61620
    61676
    61445
    61140
    60574
    59932
    59167
    58334
    57457
    7426
    6537
    5841
    5147
    4550
    4199
    3910
    3871
    4015
    4300
    4751
    5326
    6115
    6919
    7761
    57817
    58658
    59514
    60203
    60807
    61263
    61585
    61679
    61661
    61398
    60970
    60427
    59711
    58947
    58113
    8038
    7162
    6350
    5613
    4962
    4430
    4062
    3852
    3876
    4019
    4387
    4923
    5573
    6324
    7161
    8018
    58047
    58896
    59744
    60407
    60925
    61380
    61592
    61701
    61577
    61292
    60834
    60231
    59519
    58733
    57851
    7842
    6955
    6150
    5388
    4789
    4327
    3993
    3867
    3908
    4121
    4562
    5087
    5768
    6540
    7383
    57455
    58251
    59139
    59912
    60533
    61097
    61462
    61644
    61672
    61546
    61169
    60645
    60057
    59293
    58471
    57622
    7577
    6705
    5923
    5243
    4637
    4242
    3952
    3888
    3949
    4265
    4683
    5262
    5933
    6754
    7631
    57659
    58568
    59346
    60113
    60677
    61208
    61511
    61699
    61633
    61399
    61084
    60513
    59842
    59077
    58241
    57402
    7340
    6504
    5715
    5077
    4489
    4143
    3925
    3881
    4052
    4351
    4834
    5437
    6188
    6988
    7885
    57930
    58819
    59580
    60321
    60871
    61275
    61584
    61676
    61602
    61367
    60929
    60343
    59659
    58842
    57999
    7978
    7071
    6274
    5551
    4888
    4369
    4042
    3841
    3893
    4086
    4503
    4996
    5662
    6363
    7251
    8129
    58163
    59002
    59803
    60439
    61012
    61412
    61634
    61664
    61556
    61232
    60725
    60176
    59455
    58634
    57799
    7698
    6853
    6047
    5323
    4689
    4301
    3986
    3905
    3906
    4173
    4559
    5132
    5876
    6636
    7511
    57516
    58397
    59295
    59961
    60614
    61107
    61487
    61631
    61686
    61490
    61137
    60591
    59974
    59149
    58343
    57491
    7442
    6597
    5852
    5171
    4568
    4166
    3914
    3877
    3935
    4289
    4721
    5347
    6070
    6877
    7701
    57742
    58632
    59487
    60178
    60790
    61260
    61550
    61669
    61640
    61404
    60999
    60463
    59734
    58992
    58114
    8151
    7187
    6390
    5672
    4965
    4442
    4091
    3897
    3881
    4092
    4398
    4879
    5544
    6275
    7067
    7961
    58024
    58851
    59640
    60356
    60897
    61351
    61562
    61715
    61611
    61338
    60853
    60256
    59563
    58752
    57878
    7832
    6961
    6143
    5436
    4795
    4304
    4030
    3888
    3868
    4089
    4502
    5051
    5764
    6508
    7336
    57401
    58265
    59143
    59868
    60565
    61086
    61409
    61644
    61665
    61520
    61214
    60651
    60092
    59367
    58500
    57694
    7616
    6731
    5910
    5286
    4688
    4233
    3956
    3870
    3965
    4213
    4662
    5262
    6019
    6740
    7556
    57634
    58566
    59300
    60092
    60708
    61219
    61531
    61667
    61659
    61485
    61047
    60548
    59883
    59129
    58282
    57405
    7310
    6538
    5772
    5064
    4542
    4121
    3928
    3850
    3984
    4342
    4818
    5398
    6157
    6918
    7824
    57857
    58740
    59556
    60237
    60828
    61256
    61557
    61695
    61600
    61379
    60934
    60374
    59660
    58906
    58013
    7983
    7143
    6303
    5573
    4930
    4411
    4010
    3886
    3893
    4108
    4454
    4982
    5628
    6411
    7201
    8082
    58109
    58964
    59748
    60436
    60969
    61357
    61674
    61688
    61563
    61236
    60807
    60197
    59486
    58652
    57800
    7728
    6870
    6074
    5345
    4747
    4285
    4014
    3881
    3918
    4161
    4544
    5131
    5807
    6609
    7476
    57491
    58352
    59185
    59960
    60585
    61100
    61500
    61634
    61700
    61464
    61140
    60649
    59972
    59251
    58432
    57570
    7504
    6630
    5836
    5163
    4589
    4188
    3965
    3862
    3968
    4239
    4706
    5328
    6006
    6816
    7679
    57747
    58607
    59417
    60173
    60796
    61234
    61552
    61665
    61626
    61401
    61006
    60456
    59763
    58999
    58128
    8145
    7232
    6393
    5653
    4997
    4534
    4098
    3915
    3870
    4019
    4368
    4877
    5518
    6238
    7099
    7979
    57954
    58864
    59642
    60353
    60906
    61353
    61584
    61685
    61564
    61362
    60880
    60305
    59558
    58785
    57933
    7888
    7017
    6197
    5462
    4830
    4343
    4030
    3900
    3893
    4105
    4426
    5050
    5686
    6503
    7313
    8189
    58214
    59085
    59839
    60481
    61047
    61388
    61645
    61671
    61570
    61176
    60681
    60100
    59376
    58566
    57703
    7600
    6763
    5992
    5300
    4716
    4250
    3973
    3834
    3940
    4259
    4609
    5169
    5954
    6698
    7581
    57556
    58512
    59338
    60086
    60684
    61156
    61498
    61659
    61640
    61409
    61069
    60561
    59884
    59108
    58297
    57407
    7404
    6530
    5790
    5097
    4522
    4164
    3904
    3865
    4003
    4294
    4754
    5367
    6127
    6940
    7774
    57843
    58705
    59560
    60243
    60792
    61265
    61591
    61724
    61598
    61386
    60950
    60347
    59725
    58887
    58081
    8029
    7132
    6329
    5575
    4927
    4410
    4044
    3908
    3884
    4065
    4399
    4957
    5619
    6365
    7229
    8012
    58106
    58937
    59702
    60406
    60940
    61403
    61616
    61701
    61575
    61268
    60833
    60253
    59493
    58700
    57831
    7778
    6938
    6088
    5411
    4740
    4296
    3961
    3860
    3907
    4124
    4540
    5084
    5832
    6604
    7399
    57454
    58282
    59194
    59937
    60597
    61110
    61469
    61662
    61681
    61524
    61181
    60640
    60042
    59275
    58435
    57589
    7521
    6679
    5860
    5213
    4607
    4247
    3943
    3881
    3978
    4277
    4664
    5316
    5990
    6808
    7655
    57706
    58582
    59395
    60112
    60723
    61212
    61552
    61646
    61579
    61380
    61037
    60486
    59810
    59015
    58193
    8161
    7314
    6468
    5678
    5013
    4464
    4096
    3886
    3847
    4045
    4361
    4847
    5518
    6234
    7032
    7889
    57927
    58821
    59587
    60291
    60919
    61318
    61584
    61722
    61606
    61298
    60893
    60311
    59599
    58826
    57998
    7944
    7038
    6207
    5507
    4853
    4349
    4046
    3871
    3909
    4089
    4458
    5014
    5681
    6431
    7280
    8166
    58222
    59037
    59830
    60459
    61031
    61426
    61614
    61680
    61532
    61183
    60720
    60174
    59421
    58546
    57723
    7723
    6816
    5978
    5313
    4707
    4270
    3957
    3885
    3929
    4194
    4598
    5183
    5872
    6665
    7559
    57540
    58459
    59256
    60019
    60658
    61190
    61549
    61725
    61647
    61445
    61122
    60612
    59905
    59155
    58331
    57438
    7400
    6557
    5790
    5109
    4548
    4185
    3916
    3911
    3965
    4310
    4785
    5333
    6091
    6919
    7736
    57767
    58680
    59549
    60229
    60806
    61267
    61583
    61729
    61642
    61388
    60968
    60459
    59742
    58932
    58083
    8065
    7171
    6346
    5604
    4976
    4400
    4062
    3905
    3891
    4075
    4377
    4895
    5557
    6321
    7146
    8046
    58008
    58866
    59645
    60404
    60906
    61371
    61598
    61729
    61572
    61265
    60834
    60203
    59518
    58723
    57823
    7831
    6947
    6112
    5426
    4776
    4336
    3992
    3867
    3935
    4139
    4542
    5073
    5734
    6551
    7397
    57452
    58324
    59136
    59905
    60555
    61106
    61486
    61645
    61680
    61501
    61185
    60665
    60065
    59324
    58470
    57611
    7544
    6727
    5948
    5225
    4623
    4245
    3928
    3882
    3948
    4236
    4657
    5246
    6000
    6774
    7650
    57674
    58559
    59341
    60106
    60722
    61205
    61544
    61685
    61634
    61421
    61040
    60537
    59855
    59098
    58263
    57376
    7300
    6460
    5710
    5047
    4522
    4116
    3885
    3842
    3955
    4348
    4844
    5439
    6193
    7029
    7861
    57887
    58798
    59629
    60260
    60897
    61318
    61567
    61690
    61605
    61311
    60925
    60367
    59677
    58852
    57963
    7969
    7081
    6228
    5574
    4874
    4399
    4069
    3887
    3869
    4073
    4452
    4987
    5622
    6465
    7223
    8032
    58130
    58982
    59818
    60496
    61013
    61403
    61640
    61661
    61550
    61264
    60773
    60178
    59455
    58613
    57763
    7739
    6837
    6039
    5317
    4722
    4276
    4033
    3878
    3944
    4189
    4594
    5140
    5854
    6631
    7452
    57516
    58365
    59269
    59990
    60663
    61095
    61475
    61619
    61670
    61470
    61096
    60606
    59978
    59187
    58348
    57495
    7450
    6565
    5824
    5151
    4582
    4206
    3910
    3899
    3991
    4242
    4737
    5348
    6070
    6868
    7679
    57738
    58652
    59512
    60173
    60785
    61257
    61547
    61705
    61613
    61391
    60961
    60446
    59750
    59006
    58127
    8144
    7180
    6380
    5649
    4986
    4449
    4052
    3910
    3858
    3994
    4391
    4891
    5550
    6278
    7154
    7989
    57988
    58898
    59679
    60400
    60934
    61367
    61569
    61686
    61577
    61303
    60807
    60273
    59565
    58786
    57875
    7872
    6999
    6118
    5466
    4823
    4327
    3967
    3887
    3902
    4158
    4507
    5085
    5732
    6544
    7357
    57399
    58255
    59129
    59882
    60492
    61089
    61463
    61657
    61678
    61525
    61209
    60726
    60059
    59354
    58497
    57631
    7599
    6778
    5922
    5242
    4652
    4220
    3959
    3852
    3963
    4250
    4644
    5264
    5929
    6745
    7584
    57611
    58509
    59339
    60087
    60712
    61183
    61542
    61651
    61675
    61408
    61043
    60550
    59850
    59119
    58239
    57379
    7382
    6522
    5743
    5046
    4560
    4143
    3918
    3867
    4028
    4307
    4784
    5404
    6187
    6955
    7821
    57857
    58766
    59534
    60272
    60875
    61301
    61593
    61664
    61617
    61386
    60935
    60348
    59718
    58882
    58013
    7990
    7115
    6308
    5538
    4919
    4411
    4080
    3902
    3899
    4064
    4443
    4999
    5588
    6369
    7232
    8046
    58102
    58953
    59785
    60427
    60964
    61390
    61593
    61701
    61525
    61266
    60804
    60182
    59471
    58673
    57819
    7777
    6912
    6067
    5353
    4733
    4267
    4005
    3911
    3936
    4143
    4580
    5148
    5814
    6579
    7417
    57461
    58325
    59231
    59973
    60648
    61109
    61502
    61708
    61656
    61509
    61150
    60616
    59947
    59227
    58378
    57555
    7470
    6624
    5849
    5163
    4601
    4225
    3955
    3830
    3987
    4276
    4707
    5306
    6012
    6844
    7671
    57732
    58583
    59435
    60195
    60801
    61242
    61551
    61682
    61629
    61421
    61012
    60436
    59831
    59025
    58168
    8190
    7252
    6394
    5653
    5028
    4465
    4137
    3888
    3881
    4034
    4347
    4858
    5490
    6240
    7068
    7945
    57955
    58904
    59624
    60360
    60890
    61327
    61568
    61712
    61609
    61287
    60890
    60276
    59602
    58826
    57928
    7911
    6993
    6164
    5473
    4830
    4375
    4064
    3838
    3907
    4117
    4512
    5040
    5710
    6535
    7349
    8166
    58254
    59089
    59859
    60495
    61075
    61411
    61628
    61664
    61516
    61246
    60671
    60103
    59351
    58574
    57677
    7659
    6752
    5983
    5301
    4684
    4261
    3958
    3839
    3918
    4173
    4617
    5228
    5928
    6691
    7578
    57560
    58469
    59258
    60026
    60626
    61174
    61533
    61694
    61672
    61484
    61086
    60582
    59939
    59160
    58308
    57423
    7354
    6525
    5813
    5103
    4559
    4161
    3920
    3829
    4008
    4320
    4780
    5382
    6128
    6909
    7773
    57824
    58719
    59530
    60213
    60812
    61277
    61567
    61673
    61572
    61388
    60949
    60371
    59709
    58864
    58070
    8033
    7124
    6318
    5574
    4916
    4385
    4090
    3873
    3882
    4081
    4396
    4956
    5576
    6369
    7200
    8065
    58115
    58961
    59727
    60396
    60976
    61396
    61578
    61698
    61554
    61310
    60843
    60187
    59445
    58701
    57807
    7800
    6871
    6109
    5376
    4761
    4322
    4033
    3854
    3915
    4152
    4576
    5082
    5832
    6570
    7434
    57448
    58352
    59190
    59965
    60585
    61110
    61452
    61662
    61661
    61477
    61128
    60656
    60033
    59261
    58454
    57538
    7554
    6695
    5919
    5197
    4595
    4216
    3946
    3891
    3990
    4231
    4680
    5293
    5995
    6811
    7622
    57676
    58583
    59411
    60144
    60746
    61244
    61519
    61693
    61694
    61414
    61010
    60497
    59813
    59013
    58176
    57352
    7269
    6452
    5702
    5036
    4486
    4088
    3923
    3871
    4010
    4362
    4827
    5464
    6240
    7038
    7916
    57913
    58843
    59590
    60284
    60888
    61305
    61576
    61686
    61576
    61323
    60886
    60338
    59647
    58822
    57978
    7927
    7104
    6175
    5516
    4871
    4347
    4021
    3860
    3907
    4067
    4430
    5017
    5645
    6473
    7265
    8150
    58164
    59019
    59823
    60439
    61040
    61410
    61647
    61700
    61580
    61253
    60729
    60109
    59422
    58555
    57719
    7669
    6776
    5994
    5326
    4707
    4282
    3988
    3868
    3944
    4233
    4621
    5190
    5898
    6638
    7539
    57546
    58457
    59254
    60016
    60644
    61160
    61505
    61605
    61670
    61453
    61090
    60612
    59994
    59141
    58334
    57471
    7420
    6560
    5834
    5136
    4529
    4196
    3914
    3859
    3997
    4263
    4766
    5391
    6092
    6884
    7739
    57791
    58674
    59472
    60209
    60842
    61259
    61545
    61698
    61633
    61375
    60985
    60455
    59751
    58947
    58085
    8081
    7177
    6382
    5548
    4975
    4421
    4087
    3887
    3897
    4011
    4411
    4927
    5626
    6326
    7169
    8016
    58065
    58929
    59713
    60425
    60951
    61381
    61594
    61688
    61587
    61277
    60799
    60226
    59537
    58711
    57830
    7852
    6969
    6086
    5399
    4752
    4301
    3987
    3886
    3910
    4129
    4496
    5114
    5781
    6585
    7362
    57418
    58264
    59159
    59885
    60557
    61126
    61438
    61698
    61669
    61523
    61159
    60663
    60067
    59297
    58444
    57642
    7535
    6692
    5907
    5228
    4613
    4207
    3958
    3873
    3944
    4198
    4631
    5269
    5991
    6799
    7633
    57662
    58567
    59369
    60100
    60696
    61231
    61515
    61655
    61661
    61406
    61031
    60554
    59850
    59063
    58205
    57345
    7324
    6485
    5726
    5037
    4495
    4149
    3901
    3875
    4015
    4334
    4806
    5477
    6207
    7013
    7901
    57893
    58820
    59572
    60273
    60862
    61293
    61559
    61710
    61605
    61339
    60916
    60346
    59663
    58831
    58009
    7961
    7045
    6273
    5510
    4884
    4422
    4070
    3884
    3897
    4061
    4444
    4988
    5662
    6397
    7282
    8140
    58198
    59001
    59805
    60490
    61016
    61397
    61605
    61701
    61547
    61252
    60711
    60143
    59411
    58612
    57725
    7743
    6835
    6035
    5316
    4740
    4290
    3991
    3838
    3917
    4192
    4618
    5159
    5861
    6674
    7455
    57529
    58408
    59258
    59966
    60665
    61174
    61518
    61669
    61634
    61505
    61133
    60615
    59983
    59192
    58355
    57504
    7441
    6590
    5852
    5144
    4552
    4189
    3958
    3887
    3997
    4311
    4719
    5297
    6070
    6888
    7730
    57779
    58625
    59491
    60229
    60801
    61251
    61566
    61695
    61666
    61382
    60982
    60437
    59797
    59008
    58129
    8150
    7196
    6387
    5622
    5000
    4452
    4094
    3905
    3884
    4031
    4363
    4904
    5518
    6286
    7115
    7947
    58005
    58898
    59667
    60366
    60876
    61398
    61601
    61686
    61598
    61280
    60871
    60240
    59519
    58767
    57893
    7841
    6982
    6133
    5448
    4785
    4333
    4004
    3906
    3925
    4116
    4566
    5061
    5743
    6524
    7313
    57388
    58266
    59112
    59863
    60532
    61056
    61456
    61636
    61666
    61484
    61187
    60668
    60079
    59343
    58500
    57640
    7614
    6733
    5953
    5263
    4666
    4223
    3926
    3867
    3936
    4204
    4614
    5223
    5975
    6737
    7546
    57601
    58517
    59330
    60071
    60709
    61174
    61503
    61688
    61639
    61437
    61043
    60503
    59858
    59127
    58251
    57403
    7329
    6489
    5777
    5080
    4513
    4134
    3940
    3868
    3976
    4329
    4802
    5419
    6200
    6991
    7840
    57870
    58768
    59579
    60224
    60843
    61271
    61546
    61699
    61576
    61382
    60892
    60373
    59662
    58877
    58053
    7994
    7136
    6298
    5551
    4899
    4364
    4058
    3862
    3839
    4071
    4427
    4999
    5618
    6345
    7208
    8065
    58137
    58922
    59753
    60458
    60983
    61388
    61629
    61711
    61593
    61260
    60795
    60138
    59461
    58637
    57825
    7788
    6860
    6067
    5359
    4751
    4297
    4016
    3899
    3943
    4204
    4576
    5176
    5821
    6598
    7445
    57484
    58382
    59215
    59965
    60587
    61137
    61509
    61659
    61675
    61450
    61132
    60636
    60021
    59221
    58421
    57543
    7497
    6596
    5863
    5181
    4580
    4191
    3932
    3837
    3972
    4249
    4690
    5331
    6040
    6845
    7683
    57753
    58629
    59442
    60138
    60763
    61253
    61518
    61702
    61622
    61409
    61034
    60471
    59811
    59002
    58155
    8153
    7212
    6387
    5605
    5012
    4474
    4084
    3894
    3865
    3999
    4382
    4865
    5529
    6232
    7083
    7961
    57959
    58882
    59681
    60335
    60892
    61349
    61619
    61709
    61579
    61340
    60835
    60310
    59588
    58814
    57930
    7860
    7026
    6181
    5482
    4798
    4371
    3984
    3903
    3921
    4151
    4482
    5068
    5677
    6496
    7335
    57347
    58202
    59078
    59836
    60514
    61051
    61444
    61645
    61673
    61524
    61206
    60720
    60103
    59370
    58567
    57720
    7621
    6775
    5981
    5277
    4673
    4269
    3970
    3865
    3928
    4240
    4643
    5201
    5891
    6738
    7550
    57568
    58479
    59289
    60063
    60651
    61138
    61516
    61659
    61635
    61415
    61060
    60589
    59873
    59165
    58336
    57401
    7416
    6536
    5802
    5049
    4561
    4156
    3945
    3861
    4002
    4291
    4766
    5385
    6140
    6943
    7791
    57844
    58694
    59545
    60218
    60830
    61286
    61571
    61699
    61628
    61387
    60947
    60385
    59682
    58932
    58083
    8001
    7141
    6349
    5566
    4912
    4398
    4029
    3887
    3875
    4065
    4443
    4989
    5560
    6355
    7191
    8025
    58086
    58942
    59716
    60407
    60954
    61380
    61629
    61687
    61536
    61280
    60785
    60253
    59516
    58698
    57832
    7816
    6869
    6084
    5405
    4726
    4291
    3981
    3903
    3948
    4102
    4509
    5088
    5807
    6573
    7372
    57473
    58325
    59187
    59906
    60598
    61098
    61475
    61659
    61660
    61528
    61173
    60638
    60008
    59245
    58441
    57585
    7535
    6666
    5873
    5214
    4599
    4202
    3941
    3899
    3953
    4282
    4670
    5285
    5960
    6825
    7621
    57742
    58591
    59441
    60155
    60770
    61178
    61514
    61698
    61661
    61396
    61034
    60499
    59781
    59029
    58170
    8176
    7273
    6454
    5678
    5005
    4466
    4098
    3918
    3902
    4025
    4351
    4844
    5465
    6286
    7032
    7942
    57908
    58782
    59600
    60348
    60888
    61313
    61574
    61720
    61630
    61337
    60899
    60299
    59553
    58841
    57941
    7911
    7051
    6205
    5482
    4861
    4390
    4024
    3878
    3867
    4072
    4518
    5034
    5706
    6463
    7294
    8183
    58218
    59037
    59821
    60461
    61042
    61420
    61631
    61688
    61542
    61217
    60700
    60127
    59429
    58567
    57744
    7713
    6803
    6017
    5272
    4722
    4289
    3999
    3905
    3896
    4194
    4615
    5163
    5902
    6629
    7509
    57537
    58438
    59242
    60010
    60630
    61130
    61499
    61659
    61668
    61492
    61110
    60578
    59946
    59217
    58316
    57446
    7409
    6543
    5776
    5112
    4496
    4176
    3914
    3872
    3981
    4312
    4749
    5374
    6110
    6893
    7761
    57819
    58685
    59517
    60238
    60822
    61272
    61571
    61698
    61625
    61354
    60967
    60421
    59772
    58923
    58119
    8110
    7185
    6370
    5613
    4967
    4416
    4090
    3897
    3859
    4076
    4369
    4872
    5547
    6314
    7140
    8020
    58065
    58929
    59703
    60378
    60921
    61368
    61587
    61672
    61563
    61280
    60836
    60227
    59498
    58729
    57846
    7818
    6926
    6102
    5408
    4795
    4321
    3961
    3855
    3871
    4126
    4520
    5096
    5779
    6564
    7396
    57418
    58317
    59124
    59883
    60583
    61053
    61482
    61672
    61658
    61540
    61204
    60650
    60076
    59309
    58457
    57631
    7549
    6722
    5900
    5225
    4648
    4227
    3962
    3852
    3965
    4232
    4696
    5276
    5971
    6781
    7633
    57665
    58556
    59334
    60098
    60727
    61234
    61535
    61701
    61622
    61453
    61031
    60526
    59873
    59060
    58210
    57368
    7273
    6498
    5763
    5027
    4519
    4142
    3943
    3891
    4028
    4397
    4848
    5433
    6197
    6987
    7917
    57899
    58814
    59597
    60272
    60865
    61327
    61609
    61711
    61590
    61319
    60877
    60377
    59671
    58872
    58025
    7942
    7108
    6265
    5551
    4906
    4384
    4041
    3898
    3848
    4119
    4454
    4992
    5593
    6437
    7267
    8128
    58131
    58996
    59775
    60454
    60986
    61394
    61681
    61704
    61565
    61228
    60784
    60142
    59445
    58593
    57745
    7730
    6834
    6059
    5319
    4760
    4299
    4028
    3868
    3940
    4181
    4579
    5128
    5822
    6640
    7490
    57494
    58397
    59236
    59994
    60592
    61108
    61517
    61645
    61658
    61437
    61128
    60581
    60000
    59182
    58370
    57471
    7474
    6599
    5841
    5144
    4583
    4198
    3932
    3860
    3988
    4276
    4761
    5343
    6041
    6882
    7741
    57802
    58581
    59463
    60183
    60753
    61261
    61555
    61725
    61634
    61391
    60969
    60418
    59771
    58971
    58126
    8128
    7179
    6404
    5634
    4980
    4472
    4071
    3897
    3887
    4037
    4418
    4884
    5515
    6273
    7092
    7967
    58027
    58871
    59705
    60357
    60894
    61348
    61590
    61686
    61551
    61310
    60815
    60274
    59532
    58739
    57877
    7827
    7001
    6130
    5468
    4820
    4347
    3998
    3915
    3912
    4109
    4503
    5082
    5719
    6522
    7307
    57410
    58233
    59092
    59915
    60520
    61072
    61433
    61637
    61661
    61533
    61202
    60690
    60075
    59313
    58490
    57696
    7568
    6707
    5947
    5303
    4715
    4239
    3955
    3866
    3920
    4213
    4655
    5230
    5938
    6741
    7618
    57620
    58525
    59324
    60078
    60696
    61161
    61532
    61674
    61647
    61403
    61052
    60520
    59864
    59127
    58270
    57378
    7365
    6506
    5757
    5052
    4515
    4116
    3940
    3871
    4032
    4333
    4805
    5388
    6213
    6942
    7863
    57875
    58736
    59481
    60278
    60844
    61278
    61567
    61668
    61582
    61351
    60946
    60342
    59682
    58849
    58054
    7983
    7103
    6249
    5550
    4898
    4430
    4049
    3867
    3903
    4028
    4456
    4953
    5629
    6379
    7210
    8076
    58172
    58936
    59759
    60433
    60980
    61420
    61644
    61697
    61543
    61228
    60763
    60208
    59458
    58656
    57774
    7750
    6904
    6047
    5352
    4720
    4251
    3980
    3884
    3892
    4201
    4640
    5130
    5835
    6640
    7452
    57515
    58386
    59234
    59933
    60639
    61108
    61467
    61683
    61654
    61513
    61137
    60617
    59987
    59225
    58371
    57551
    7467
    6594
    5867
    5179
    4584
    4241
    3936
    3870
    3949
    4270
    4707
    5295
    6046
    6843
    7666
    57732
    58594
    59423
    60206
    60758
    61215
    61538
    61700
    61653
    61409
    61032
    60482
    59779
    58992
    58165
    8168
    7292
    6421
    5673
    5021
    4466
    4086
    3907
    3844
    4051
    4384
    4859
    5515
    6240
    7106
    7992
    57967
    58873
    59586
    60296
    60887
    61365
    61610
    61677
    61629
    61350
    60885
    60278
    59582
    58753
    57873
    7883
    7001
    6165
    5472
    4826
    4367
    4017
    3890
    3898
    4092
    4483
    5044
    5686
    6483
    7308
    57371
    58230
    59057
    59886
    60526
    61079
    61401
    61637
    61659
    61527
    61217
    60733
    60089
    59366
    58537
    57690
    7679
    6769
    6029
    5260
    4674
    4289
    3936
    3872
    3921
    4195
    4604
    5214
    5922
    6707
    7584
    57577
    58497
    59275
    60063
    60673
    61193
    61514
    61694
    61659
    61467
    61080
    60573
    59902
    59144
    58317
    57403
    7359
    6542
    5807
    5085
    4547
    4150
    3915
    3879
    3979
    4348
    4798
    5367
    6118
    6918
    7780
    57840
    58720
    59521
    60215
    60790
    61272
    61625
    61663
    61645
    61383
    60943
    60387
    59730
    58899
    58029
    8005
    7198
    6319
    5544
    4905
    4397
    4009
    3944
    3894
    4072
    4413
    4932
    5578
    6364
    7169
    8015
    58093
    58953
    59771
    60428
    60950
    61400
    61592
    61686
    61606
    61279
    60811
    60216
    59479
    58669
    57815
    7771
    6899
    6100
    5376
    4775
    4292
    4026
    3908
    3927
    4130
    4562
    5125
    5755
    6581
    7434
    57469
    58326
    59209
    59884
    60593
    61113
    61458
    61676
    61664
    61492
    61150
    60590
    59990
    59251
    58424
    57564
    7563
    6668
    5881
    5221
    4598
    4213
    3908
    3884
    3983
    4262
    4695
    5292
    6023
    6806
    7631
    57673
    58586
    59380
    60164
    60730
    61245
    61552
    61727
    61635
    61399
    61052
    60470
    59803
    59080
    58187
    8148
    7240
    6450
    5712
    5046
    4523
    4114
    3886
    3829
    4026
    4403
    4847
    5494
    6202
    7023
    7954
    57922
    58823
    59607
    60306
    60911
    61332
    61603
    61660
    61615
    61316
    60868
    60310
    59627
    58803
    57995
    7928
    7033
    6223
    5473
    4839
    4394
    4024
    3861
    3891
    4077
    4435
    4997
    5679
    6470
    7292
    8153
    58194
    59021
    59784
    60476
    61013
    61388
    61641
    61704
    61584
    61196
    60759
    60115
    59407
    58555
    57718
    7660
    6821
    5992
    5303
    4696
    4237
    3977
    3873
    3912
    4216
    4601
    5156
    5879
    6676
    7542
    57553
    58426
    59273
    60048
    60675
    61141
    61484
    61662
    61665
    61490
    61067
    60596
    59925
    59137
    58306
    57415
    7460
    6586
    5819
    5123
    4574
    4199
    3935
    3891
    4007
    4261
    4769
    5334
    6123
    6923
    7781
    57808
    58651
    59505
    60238
    60796
    61249
    61590
    61732
    61647
    61377
    60984
    60426
    59750
    58957
    58070
    8046
    7159
    6342
    5611
    4967
    4398
    4057
    3912
    3886
    4044
    4443
    4912
    5542
    6284
    7157
    7990
    58059
    58895
    59678
    60387
    60954
    61384
    61602
    61699
    61576
    61282
    60823
    60264
    59539
    58714
    57849
    7845
    6956
    6096
    5414
    4763
    4312
    3994
    3895
    3944
    4113
    4528
    5071
    5782
    6545
    7390
    57460
    58246
    59144
    59919
    60579
    61079
    61444
    61683
    61675
    61490
    61186
    60640
    60082
    59300
    58492
    57625
    7505
    6684
    5926
    5239
    4610
    4226
    3958
    3856
    3958
    4270
    4681
    5249
    5953
    6847
    7608
    57661
    58590
    59341
    60138
    60702
    61206
    61525
    61647
    61667
    61377
    61065
    60519
    59838
    59084
    58223
    57364
    7355
    6515
    5725
    5037
    4488
    4140
    3914
    3874
    4002
    4366
    4812
    5455
    6218
    6961
    7875
    57898
    58790
    59602
    60301
    60882
    61326
    61578
    61692
    61648
    61400
    60926
    60322
    59665
    58845
    58040
    7956
    7061
    6196
    5548
    4890
    4377
    4048
    3918
    3867
    4062
    4462
    4977
    5638
    6376
    7246
    8106
    58214
    58999
    59804
    60463
    60964
    61408
    61651
    61660
    61571
    61253
    60732
    60189
    59439
    58610
    57751
    7721
    6821
    6053
    5308
    4714
    4250
    3974
    3871
    3896
    4166
    4620
    5141
    5883
    6647
    7524
    57509
    58415
    59290
    59953
    60632
    61104
    61526
    61686
    61671
    61501
    61143
    60595
    60002
    59200
    58383
    57463
    7450
    6564
    5809
    5116
    4563
    4181
    3929
    3835
    4008
    4291
    4732
    5362
    6083
    6884
    7733
    57768
    58602
    59502
    60170
    60755
    61230
    61537
    61671
    61664
    61371
    60951
    60455
    59784
    58999
    58081
    8140
    7212
    6381
    5600
    5021
    4406
    4076
    3906
    3851
    4058
    4383
    4846
    5546
    6295
    7085
    7974
    58012
    58888
    59671
    60372
    60941
    61370
    61592
    61654
    61570
    61291
    60874
    60250
    59542
    58771
    57896
    7885
    7005
    6129
    5445
    4828
    4318
    4015
    3896
    3902
    4122
    4528
    5070
    5736
    6547
    7345
    57382
    58310
    59119
    59901
    60537
    61075
    61461
    61649
    61668
    61476
    61184
    60673
    60086
    59344
    58441
    57667
    7602
    6743
    5954
    5236
    4685
    4198
    3954
    3865
    3953
    4196
    4647
    5234
    5946
    6729
    7599
    57645
    58515
    59326
    60071
    60704
    61204
    61539
    61706
    61662
    61482
    61063
    60535
    59893
    59132
    58202
    57404
    7347
    6523
    5776
    5068
    4545
    4152
    3882
    3875
    4015
    4335
    4811
    5406
    6166
    6976
    7857
    57862
    58745
    59575
    60226
    60869
    61326
    61559
    61698
    61575
    61362
    60954
    60321
    59683
    58849
    58069
    7954
    7149
    6297
    5521
    4909
    4391
    4027
    3895
    3924
    4100
    4445
    5019
    5601
    6381
    7222
    8061
    58102
    58943
    59773
    60461
    60984
    61377
    61624
    61664
    61558
    61260
    60771
    60168
    59456
    58647
    57788
    7762
    6890
    6082
    5354
    4754
    4268
    3998
    3876
    3927
    4160
    4580
    5136
    5845
    6599
    7457
    57485
    58409
    59211
    59939
    60609
    61116
    61497
    61636
    61675
    61465
    61138
    60577
    59988
    59202
    58396
    57546
    7502
    6631
    5854
    5194
    4590
    4189
    3913
    3876
    3968
    4252
    4732
    5271
    6025
    6850
    7699
    57736
    58593
    59422
    60167
    60768
    61227
    61512
    61686
    61601
    61427
    60993
    60468
    59767
    58998
    58164
    8105
    7227
    6404
    5695
    5050
    4458
    4074
    3867
    3881
    4026
    4434
    4881
    5465
    6246
    7077
    7967
    57959
    58869
    59646
    60373
    60884
    61354
    61631
    61729
    61593
    61317
    60867
    60303
    59532
    58798
    57938
    7919
    7020
    6192
    5476
    4808
    4376
    3984
    3872
    3890
    4114
    4438
    5044
    5705
    6478
    7339
    57347
    58239
    59085
    59857
    60470
    61076
    61446
    61673
    61696
    61519
    61175
    60730
    60057
    59374
    58562
    57697
    7617
    6802
    6017
    5245
    4709
    4253
    3989
    3864
    3936
    4227
    4650
    5204
    5956
    6737
    7558
    57575
    58456
    59269
    60067
    60689
    61167
    61520
    61680
    61640
    61396
    61082
    60540
    59911
    59151
    58261
    57426
    7398
    6514
    5797
    5083
    4553
    4193
    3943
    3867
    4004
    4300
    4793
    5404
    6132
    6990
    7780
    57800
    58724
    59539
    60182
    60825
    61252
    61550
    61679
    61614
    61398
    60927
    60359
    59678
    58903
    58047
    8028
    7132
    6283
    5581
    4920
    4443
    4078
    3912
    3891
    4052
    4447
    4933
    5616
    6366
    7216
    8031
    58149
    58922
    59777
    60405
    60977
    61402
    61588
    61701
    61547
    61289
    60793
    60230
    59501
    58692
    57785
    7768
    6894
    6100
    5380
    4781
    4277
    3962
    3857
    3935
    4171
    4542
    5122
    5833
    6603
    7393
    57477
    58292
    59178
    59930
    60570
    61096
    61502
    61682
    61627
    61525
    61152
    60641
    60047
    59268
    58447
    57561
    7503
    6681
    5860
    5192
    4619
    4187
    3938
    3870
    3958
    4256
    4665
    5311
    6013
    6833
    7650
    57719
    58565
    59412
    60156
    60726
    61234
    61546
    61685
    61615
    61397
    61005
    60513
    59798
    59053
    58211
    57354
    7302
    6448
    5691
    5056
    4499
    4084
    3912
    3885
    4035
    4368
    4860
    5474
    6232
    7007
    7947
    57938
    58836
    59557
    60280
    60897
    61323
    61578
    61690
    61591
    61334
    60878
    60295
    59588
    58811
    57966
    7946
    7050
    6196
    5534
    4850
    4383
    4032
    3909
    3907
    4092
    4457
    5011
    5695
    6452
    7297
    8171
    58199
    59047
    59816
    60479
    61023
    61425
    61626
    61691
    61533
    61251
    60721
    60149
    59397
    58585
    57740
    7688
    6818
    6005
    5282
    4706
    4248
    3986
    3867
    3928
    4212
    4635
    5190
    5893
    6672
    7576
    57525
    58455
    59293
    60010
    60627
    61139
    61515
    61700
    61609
    61449
    61114
    60615
    59910
    59192
    58329
    57474
    7399
    6566
    5821
    5146
    4556
    4194
    3920
    3861
    3983
    4286
    4778
    5359
    6111
    6906
    7774
    57808
    58678
    59509
    60205
    60789
    61264
    61562
    61703
    61577
    61356
    60937
    60436
    59752
    58943
    58095
    8104
    7156
    6331
    5571
    4951
    4405
    4070
    3909
    3851
    4073
    4412
    4904
    5534
    6292
    7146
    8056
    58042
    58914
    59691
    60407
    60922
    61389
    61601
    61681
    61604
    61277
    60827
    60218
    59512
    58730
    57834
    7824
    6940
    6139
    5456
    4759
    4318
    3991
    3860
    3904
    4136
    4532
    5070
    5751
    6573
    7367
    57431
    58304
    59134
    59905
    60591
    61089
    61463
    61645
    61657
    61479
    61145
    60668
    60057
    59271
    58480
    57613
    7568
    6671
    5944
    5215
    4631
    4231
    3926
    3864
    3946
    4220
    4697
    5250
    5969
    6787
    7591
    57678
    58544
    59331
    60111
    60723
    61227
    61527
    61697
    61635
    61428
    61101
    60511
    59820
    59078
    58200
    57369
    7295
    6504
    5738
    5049
    4518
    4125
    3954
    3864
    4007
    4344
    4822
    5439
    6192
    7010
    7861
    57903
    58793
    59626
    60299
    60871
    61346
    61588
    61675
    61592
    61354
    60891
    60370
    59644
    58834
    58001
    7966
    7082
    6258
    5505
    4897
    4390
    4054
    3874
    3937
    4093
    4477
    5046
    5670
    6439
    7265
    8096
    58186
    59015
    59794
    60496
    61009
    61407
    61634
    61675
    61566
    61225
    60750
    60114
    59436
    58625
    57756
    7703
    6844
    6019
    5314
    4711
    4244
    3998
    3906
    3911
    4191
    4591
    5162
    5826
    6635
    7500
    57566
    58414
    59245
    59979
    60632
    61172
    61517
    61682
    61643
    61466
    61120
    60580
    59970
    59207
    58411
    57508
    7420
    6610
    5807
    5129
    4568
    4224
    3927
    3872
    3999
    4322
    4766
    5337
    6028
    6897
    7715
    57770
    58641
    59474
    60196
    60784
    61265
    61548
    61710
    61664
    61385
    60978
    60451
    59734
    58984
    58136
    8092
    7182
    6359
    5629
    4982
    4444
    4083
    3923
    3844
    4061
    4425
    4904
    5540
    6300
    7104
    7992
    58027
    58880
    59671
    60391
    60877
    61338
    61607
    61670
    61536
    61320
    60822
    60248
    59566
    58750
    57890
    7874
    6987
    6094
    5471
    4801
    4354
    4003
    3846
    3878
    4110
    4469
    5065
    5768
    6546
    7372
    57408
    58264
    59134
    59866
    60472
    61087
    61443
    61643
    61686
    61505
    61209
    60690
    60049
    59349
    58495
    57660
    7605
    6706
    5942
    5227
    4655
    4188
    3974
    3876
    3916
    4256
    4676
    5254
    5951
    6741
    7585
    57573
    58543
    59329
    60100
    60703
    61242
    61538
    61655
    61662
    61423
    61069
    60566
    59880
    59107
    58254
    57382
    7345
    6468
    5730
    5057
    4539
    4141
    3941
    3875
    4024
    4307
    4811
    5394
    6161
    6943
    7841
    57864
    58762
    59523
    60233
    60865
    61285
    61573
    61715
    61611
    61347
    60932
    60345
    59696
    58876
    58044
    7999
    7101
    6314
    5562
    4940
    4395
    4060
    3879
    3903
    4085
    4425
    4981
    5603
    6407
    7210
    8067
    58126
    58957
    59761
    60417
    60998
    61388
    61607
    61683
    61564
    61232
    60781
    60174
    59487
    58646
    57749
    7762
    6872
    6079
    5336
    4769
    4265
    3949
    3877
    3903
    4163
    4554
    5165
    5808
    6613
    7419
    57515
    58379
    59246
    59976
    60610
    61102
    61488
    61721
    61685
    61464
    61123
    60616
    59974
    59224
    58389
    57522
    7487
    6636
    5865
    5180
    4592
    4208
    3950
    3889
    3943
    4314
    4696
    5325
    6050
    6879
    7690
    57765
    58666
    59404
    60172
    60721
    61271
    61550
    61678
    61660
    61401
    60991
    60475
    59774
    58992
    58155
    8103
    7248
    6412
    5670
    5014
    4479
    4064
    3915
    3868
    4048
    4372
    4894
    5468
    6270
    7060
    7961
    57965
    58868
    59598
    60325
    60894
    61338
    61612
    61725
    61604
    61307
    60848
    60244
    59570
    58814
    57936
    7899
    6982
    6188
    5485
    4829
    4346
    4030
    3917
    3879
    4117
    4516
    5039
    5710
    6514
    7324
    57344
    58285
    59077
    59862
    60470
    61046
    61426
    61645
    61667
    61511
    61194
    60696
    60126
    59353
    58537
    57697
    7619
    6759
    5987
    5286
    4668
    4272
    3974
    3837
    3962
    4208
    4618
    5192
    5918
    6763
    7568
    57616
    58503
    59290
    60080
    60683
    61135
    61521
    61684
    61685
    61444
    61090
    60582
    59873
    59124
    58268
    57412
    7375
    6535
    5788
    5052
    4577
    4157
    3931
    3860
    4003
    4328
    4745
    5387
    6185
    6948
    7794
    57814
    58743
    59549
    60220
    60866
    61274
    61569
    61704
    61613
    61354
    60917
    60369
    59706
    58915
    58053
    8011
    7145
    6323
    5573
    4930
    4385
    4050
    3910
    3900
    4071
    4378
    4958
    5585
    6354
    7172
    8027
    58095
    58907
    59741
    60416
    60960
    61402
    61586
    61699
    61565
    61294
    60799
    60165
    59508
    58677
    57817
    7756
    6894
    6109
    5409
    4786
    4298
    4000
    3857
    3928
    4154
    4559
    5113
    5826
    6578
    7417
    57469
    58341
    59196
    59959
    60595
    61106
    61494
    61688
    61647
    61454
    61179
    60631
    60022
    59224
    58431
    57605
    7536
    6662
    5891
    5183
    4602
    4229
    3919
    3866
    3988
    4277
    4680
    5268
    6020
    6824
    7645
    57689
    58590
    59405
    60134
    60712
    61191
    61549
    61703
    61647
    61439
    61030
    60486
    59819
    59071
    58176
    57353
    7224
    6420
    5723
    4987
    4469
    4127
    3905
    3872
    4030
    4404
    4836
    5487
    6223
    7019
    7957
    57927
    58803
    59623
    60341
    60925
    61330
    61610
    61681
    61592
    61316
    60883
    60324
    59560
    58816
    57931
    7912
    7079
    6194
    5483
    4807
    4368
    4000
    3834
    3907
    4088
    4472
    5035
    5657
    6475
    7271
    8169
    58189
    59025
    59817
    60476
    61059
    61385
    61617
    61722
    61556
    61241
    60718
    60142
    59404
    58586
    57717
    7670
    6828
    6031
    5292
    4702
    4263
    3986
    3845
    3901
    4229
    4631
    5167
    5914
    6667
    7539
    57549
    58483
    59267
    60015
    60607
    61155
    61502
    61637
    61678
    61467
    61126
    60594
    59970
    59151
    58328
    57456
    7416
    6556
    5846
    5119
    4562
    4154
    3907
    3854
    4038
    4260
    4719
    5372
    6114
    6901
    7759
    57765
    58655
    59514
    60202
    60805
    61261
    61542
    61711
    61619
    61387
    60965
    60391
    59719
    58966
    58092
    8070
    7175
    6349
    5608
    4953
    4461
    4063
    3882
    3857
    4071
    4422
    4916
    5589
    6329
    7179
    8049
    58092
    58904
    59682
    60381
    60944
    61372
    61617
    61696
    61573
    61279
    60831
    60249
    59507
    58693
    57834
    7821
    6952
    6145
    5397
    4776
    4331
    4016
    3866
    3864
    4133
    4521
    5069
    5774
    6599
    7405
    57434
    58290
    59173
    59918
    60548
    61108
    61465
    61679
    61677
    61515
    61200
    60694
    60072
    59293
    58477
    57592
    7568
    6717
    5900
    5221
    4654
    4232
    3996
    3877
    3938
    4239
    4653
    5281
    5987
    6798
    7609
    57677
    58550
    59365
    60125
    60688
    61181
    61490
    61686
    61669
    61397
    61023
    60519
    59845
    59050
    58200
    57366
    7335
    6475
    5733
    5033
    4524
    4091
    3937
    3860
    4032
    4324
    4809
    5473
    6181
    7012
    7881
    57903
    58819
    59574
    60280
    60825
    61292
    61600
    61699
    61613
    61391
    60934
    60326
    59653
    58845
    57964
    7950
    7103
    6251
    5539
    4879
    4358
    4072
    3868
    3895
    4070
    4497
    4983
    5653
    6389
    7228
    8106
    58186
    58986
    59816
    60457
    61016
    61449
    61643
    61691
    61556
    61269
    60738
    60141
    59390
    58604
    57757
    7733
    6818
    6082
    5334
    4688
    4257
    3955
    3886
    3911
    4184
    4559
    5151
    5875
    6647
    7503
    57526
    58430
    59245
    60025
    60622
    61134
    61523
    61675
    61659
    61473
    61139
    60567
    60024
    59241
    58369
    57442
    7464
    6547
    5824
    5122
    4583
    4193
    3931
    3862
    3950
    4278
    4742
    5350
    6088
    6891
    7718
    57809
    58623
    59489
    60181
    60785
    61221
    61542
    61723
    61653
    61405
    60969
    60454
    59775
    58988
    58103
    8161
    7201
    6379
    5657
    4978
    4427
    4094
    3892
    3856
    4055
    4374
    4882
    5509
    6278
    7135
    7955
    58018
    58923
    59689
    60395
    60927
    61349
    61622
    61687
    61590
    61294
    60849
    60261
    59553
    58723
    57904
    7853
    6979
    6144
    5455
    4815
    4313
    4027
    3891
    3897
    4111
    4537
    5051
    5711
    6521
    7344
    57372
    58225
    59102
    59881
    60573
    61085
    61448
    61658
    61671
    61501
    61208
    60702
    60119
    59371
    58490
    57673
    7603
    6761
    5933
    5287
    4631
    4224
    3949
    3848
    3945
    4225
    4652
    5270
    5966
    6729
    7565
    57665
    58559
    59315
    60079
    60698
    61176
    61512
    61714
    61653
    61473
    61059
    60534
    59886
    59109
    58283
    57397
    7355
    6475
    5767
    5097
    4518
    4154
    3922
    3883
    4043
    4329
    4808
    5422
    6179
    6971
    7862
    57866
    58791
    59552
    60259
    60845
    61262
    61599
    61694
    61597
    61342
    60906
    60372
    59675
    58849
    58014
    7990
    7157
    6270
    5530
    4912
    4361
    4043
    3885
    3858
    4093
    4463
    4981
    5619
    6392
    7246
    8063
    58150
    58985
    59757
    60431
    60992
    61390
    61655
    61686
    61578
    61281
    60755
    60180
    59471
    58689
    57799
    7763
    6877
    6052
    5339
    4761
    4290
    4026
    3850
    3920
    4174
    4581
    5117
    5850
    6600
    7458
    57530
    58377
    59254
    60003
    60619
    61099
    61481
    61676
    61671
    61456
    61117
    60623
    59990
    59220
    58433
    57546
    7523
    6614
    5831
    5168
    4596
    4148
    3944
    3849
    3975
    4235
    4737
    5299
    6008
    6854
    7655
    57743
    58585
    59404
    60205
    60822
    61239
    61531
    61701
    61625
    61405
    60983
    60481
    59819
    59030
    58181
    8157
    7215
    6412
    5666
    5007
    4472
    4097
    3911
    3858
    4031
    4406
    4872
    5513
    6258
    7081
    7946
    57972
    58901
    59666
    60344
    60913
    61341
    61607
    61691
    61584
    61288
    60843
    60311
    59546
    58795
    57898
    7858
    7016
    6171
    5479
    4835
    4363
    4004
    3884
    3919
    4098
    4489
    5068
    5698
    6489
    7321
    8167
    58193
    59094
    59885
    60509
    61031
    61427
    61685
    61671
    61543
    61200
    60704
    60081
    59365
    58528
    57679
    7636
    6741
    5983
    5294
    4659
    4261
    4008
    3876
    3928
    4211
    4649
    5223
    5891
    6724
    7539
    57564
    58502
    59279
    60042
    60717
    61187
    61506
    61674
    61620
    61445
    61045
    60560
    59909
    59136
    58292
    57430
    7437
    6512
    5806
    5071
    4520
    4185
    3922
    3875
    4003
    4309
    4795
    5380
    6120
    6939
    7792
    57846
    58736
    59533
    60222
    60808
    61261
    61589
    61696
    61581
    61371
    60988
    60415
    59700
    58904
    58055
    8011
    7148
    6363
    5560
    4938
    4407
    4048
    3874
    3876
    4094
    4453
    4924
    5584
    6357
    7201
    8060
    58149
    58928
    59722
    60417
    60969
    61429
    61601
    61735
    61576
    61257
    60795
    60187
    59453
    58698
    57818
    7770
    6880
    6105
    5405
    4750
    4323
    3963
    3893
    3923
    4181
    4574
    5101
    5822
    6611
    7437
    57458
    58290
    59214
    59930
    60594
    61111
    61472
    61674
    61649
    61494
    61183
    60639
    60019
    59256
    58368
    57557
    7517
    6672
    5891
    5194
    4598
    4250
    3944
    3877
    3975
    4273
    4689
    5300
    6004
    6827
    7679
    57717
    58595
    59396
    60143
    60709
    61251
    61556
    61681
    61634
    61393
    61040
    60512
    59813
    59038
    58140
    8175
    7255
    6453
    5672
    5015
    4502
    4117
    3916
    3888
    4032
    4367
    4858
    5476
    6229
    7055
    7931
    57927
    58827
    59601
    60333
    60884
    61332
    61579
    61690
    61588
    61342
    60920
    60296
    59626
    58808
    57918
    7942
    7029
    6189
    5507
    4860
    4368
    4066
    3885
    3923
    4089
    4490
    5015
    5687
    6486
    7287
    8164
    58202
    59017
    59837
    60488
    61032
    61419
    61654
    61708
    61531
    61228
    60736
    60151
    59405
    58564
    57718
    7675
    6818
    6015
    5303
    4704
    4240
    3987
    3855
    3929
    4195
    4638
    5179
    5922
    6670
    7515
    57536
    58484
    59291
    60031
    60656
    61180
    61529
    61718
    61669
    61454
    61080
    60563
    59917
    59190
    58318
    57485
    7420
    6545
    5789
    5102
    4575
    4178
    3966
    3838
    3973
    4308
    4730
    5349
    6167
    6937
    7756
    57823
    58669
    59537
    60219
    60796
    61263
    61591
    61693
    61581
    61397
    60958
    60404
    59704
    58922
    58107
    8091
    7173
    6356
    5625
    4970
    4450
    4068
    3882
    3866
    4046
    4410
    4901
    5573
    6309
    7149
    8022
    58019
    58920
    59682
    60408
    60931
    61387
    61598
    61688
    61590
    61278
    60842
    60222
    59509
    58730
    57839
    7811
    6922
    6123
    5429
    4760
    4350
    4002
    3882
    3900
    4123
    4550
    5091
    5776
    6536
    7359
    57429
    58321
    59098
    59870
    60552
    61074
    61468
    61675
    61648
    61486
    61173
    60626
    60018
    59319
    58432
    57627
    7583
    6698
    5912
    5224
    4605
    4230
    3949
    3894
    3953
    4237
    4675
    5256
    5968
    6772
    7616
    57680
    58546
    59379
    60143
    60676
    61212
    61537
    61726
    61641
    61426
    61035
    60538
    59838
    59072
    58209
    57356
    7301
    6457
    5747
    5011
    4503
    4122
    3878
    3873
    4021
    4349
    4836
    5452
    6213
    6957
    7894
    57895
    58776
    59580
    60273
    60867
    61303
    61555
    61684
    61640
    61331
    60914
    60354
    59649
    58855
    58006
    7940
    7127
    6211
    5508
    4893
    4406
    4036
    3895
    3870
    4092
    4432
    4998
    5633
    6461
    7264
    8092
    58158
    58997
    59776
    60471
    61042
    61399
    61625
    61713
    61559
    61215
    60760
    60162
    59452
    58628
    57770
    7720
    6784
    6027
    5296
    4716
    4271
    3997
    3863
    3934
    4215
    4609
    5177
    5878
    6611
    7527
    57557
    58407
    59254
    59985
    60608
    61131
    61501
    61666
    61669
    61444
    61132
    60624
    59982
    59201
    58365
    57495
    7450
    6589
    5818
    5183
    4558
    4185
    3892
    3834
    3951
    4276
    4797
    5368
    6030
    6909
    7729
    57760
    58631
    59435
    60204
    60823
    61263
    61559
    61698
    61616
    61399
    60976
    60412
    59759
    58986
    58118
    8070
    7219
    6366
    5611
    5036
    4448
    4074
    3935
    3855
    4052
    4434
    4934
    5546
    6299
    7112
    7977
    58017
    58909
    59685
    60380
    60903
    61355
    61605
    61697
    61582
    61295
    60827
    60222
    59527
    58753
    57897
    7852
    6978
    6150
    5430
    4785
    4359
    3970
    3868
    3910
    4165
    4528
    5094
    5761
    6551
    7369
    57395
    58260
    59111
    59911
    60516
    61062
    61479
    61635
    61670
    61514
    61163
    60663
    60086
    59320
    58477
    57673
    7606
    6739
    5917
    5265
    4661
    4214
    3966
    3872
    3893
    4227
    4644
    5204
    5938
    6726
    7586
    57615
    58505
    59314
    60084
    60682
    61195
    61546
    61662
    61613
    61401
    61083
    60546
    59882
    59115
    58241
    57353
    7379
    6484
    5747
    5062
    4491
    4147
    3894
    3869
    4009
    4326
    4786
    5398
    6189
    6951
    7844
    57855
    58745
    59533
    60283
    60838
    61302
    61577
    61689
    61603
    61365
    60955
    60370
    59696
    58824
    58057
    7982
    7074
    6309
    5562
    4916
    4378
    4068
    3901
    3858
    4057
    4451
    4970
    5633
    6398
    7227
    8081
    58199
    58965
    59765
    60423
    60974
    61409
    61622
    61720
    61526
    61269
    60754
    60166
    59498
    58642
    57792
    7738
    6872
    6088
    5342
    4734
    4294
    3970
    3861
    3909
    4157
    4592
    5136
    5873
    6589
    7480
    57470
    58401
    59177
    59952
    60607
    61102
    61492
    61697
    61631
    61475
    61155
    60612
    60013
    59251
    58410
    57559
    7504
    6606
    5859
    5194
    4581
    4203
    3923
    3848
    3942
    4280
    4719
    5324
    6028
    6866
    7689
    57742
    58603
    59434
    60134
    60783
    61264
    61528
    61668
    61639
    61408
    61018
    60452
    59793
    59014
    58165
    8137
    7243
    6390
    5653
    4993
    4441
    4102
    3899
    3863
    4065
    4381
    4859
    5464
    6279
    7083
    7928
    57928
    58865
    59617
    60359
    60915
    61327
    61627
    61708
    61599
    61320
    60885
    60287
    59606
    58758
    57905
    7920
    7023
    6182
    5464
    4838
    4371
    4023
    3879
    3905
    4080
    4513
    5059
    5672
    6487
    7284
    8160
    58209
    59054
    59856
    60498
    61049
    61459
    61659
    61693
    61523
    61228
    60680
    60100
    59372
    58538
    57675
    7620
    6751
    5962
    5289
    4672
    4268
    3944
    3870
    3934
    4223
    4636
    5181
    5931
    6684
    7576
    57593
    58485
    59286
    60099
    60681
    61154
    61541
    61682
    61673
    61462
    61062
    60593
    59893
    59141
    58300
    57452
    7371
    6512
    5776
    5107
    4557
    4163
    3965
    3868
    3972
    4322
    4798
    5347
    6160
    6960
    7843
    57837
    58754
    59544
    60251
    60856
    61280
    61593
    61706
    61582
    61377
    60935
    60399
    59679
    58909
    58029
    8041
    7184
    6299
    5581
    4928
    4391
    4075
    3866
    3878
    4048
    4405
    4945
    5594
    6334
    7197
    8024
    58101
    58974
    59756
    60445
    60940
    61374
    61607
    61687
    61578
    61276
    60804
    60218
    59435
    58707
    57835
    7754
    6904
    6114
    5405
    4764
    4312
    3994
    3898
    3923
    4168
    4600
    5110
    5807
    6562
    7401
    57463
    58297
    59194
    59940
    60582
    61093
    61500
    61667
    61670
    61468
    61147
    60590
    60027
    59240
    58449
    57592
    7527
    6642
    5873
    5228
    4565
    4206
    3940
    3862
    4004
    4250
    4683
    5295
    6010
    6823
    7635
    57721
    58594
    59411
    60175
    60716
    61235
    61533
    61681
    61662
    61404
    60980
    60493
    59787
    59025
    58185
    8174
    7240
    6449
    5678
    5039
    4494
    4131
    3944
    3870
    4032
    4364
    4824
    5484
    6232
    7053
    7915
    57937
    58836
    59616
    60311
    60886
    61337
    61589
    61726
    61586
    61319
    60903
    60344
    59611
    58799
    57997
    7896
    7081
    6181
    5490
    4840
    4400
    4018
    3902
    3948
    4098
    4445
    5029
    5675
    6449
    7290
    8140
    58214
    59073
    59817
    60431
    61007
    61420
    61653
    61663
    61521
    61205
    60775
    60082
    59394
    58533
    57694
    7643
    6821
    6004
    5258
    4738
    4262
    3979
    3862
    3934
    4210
    4614
    5159
    5866
    6654
    7488
    57542
    58453
    59300
    60016
    60632
    61170
    61524
    61629
    61669
    61451
    61085
    60606
    59919
    59185
    58346
    57437
    7449
    6564
    5786
    5131
    4558
    4198
    3919
    3876
    4026
    4284
    4787
    5368
    6089
    6909
    7753
    57807
    58675
    59503
    60195
    60773
    61279
    61569
    61712
    61630
    61412
    60963
    60378
    59699
    58928
    58108
    8036
    7155
    6348
    5596
    4960
    4399
    4069
    3879
    3885
    4055
    4411
    4925
    5588
    6301
    7138
    7988
    58076
    58898
    59674
    60373
    60938
    61392
    61642
    61695
    61519
    61291
    60846
    60241
    59524
    58723
    57836
    7829
    6925
    6141
    5410
    4763
    4303
    3974
    3854
    3888
    4156
    4537
    5068
    5774
    6520
    7339
    57431
    58247
    59128
    59935
    60563
    61083
    61470
    61709
    61692
    61495
    61162
    60663
    60049
    59319
    58502
    57598
    7559
    6681
    5941
    5236
    4592
    4227
    3973
    3866
    3941
    4305
    4636
    5236
    5983
    6762
    7601
    57719
    58566
    59362
    60133
    60689
    61227
    61511
    61674
    61647
    61409
    61020
    60530
    59870
    59057
    58222
    57347
    7314
    6487
    5711
    4983
    4497
    4127
    3934
    3880
    4035
    4341
    4801
    5403
    6206
    6986
    7854
    57889
    58798
    59593
    60283
    60936
    61306
    61583
    61685
    61586
    61335
    60934
    60331
    59629
    58858
    58035
    7952
    7062
    6254
    5543
    4878
    4382
    4048
    3890
    3885
    4082
    4457
    5009
    5633
    6403
    7251
    8142
    58189
    59005
    59826
    60456
    61009
    61411
    61638
    61680
    61522
    61244
    60739
    60152
    59448
    58588
    57756
    7690
    6845
    5983
    5316
    4718
    4277
    3974
    3851
    3917
    4179
    4608
    5159
    5864
    6636
    7496
    57549
    58450
    59241
    59974
    60614
    61175
    61551
    61704
    61688
    61520
    61089
    60611
    59952
    59201
    58366
    57515
    7458
    6583
    5812
    5153
    4560
    4191
    3938
    3859
    3959
    4279
    4755
    5350
    6061
    6880
    7693
    57788
    58651
    59511
    60181
    60781
    61220
    61592
    61681
    61601
    61399
    60980
    60409
    59772
    58941
    58123
    8128
    7179
    6429
    5620
    4995
    4419
    4078
    3882
    3891
    4074
    4399
    4922
    5516
    6279
    7156
    7971
    58005
    58920
    59657
    60375
    60924
    61387
    61604
    61708
    61607
    61308
    60878
    60229
    59520
    58767
    57888
    7832
    6984
    6133
    5435
    4757
    4321
    3980
    3873
    3915
    4121
    4527
    5080
    5737
    6501
    7376
    57398
    58290
    59134
    59896
    60538
    61036
    61431
    61646
    61690
    61471
    61199
    60672
    60056
    59320
    58459
    57672
    7606
    6739
    5935
    5241
    4654
    4205
    3953
    3869
    3948
    4202
    4650
    5267
    5962
    6723
    7557
    57626
    58542
    59345
    60071
    60681
    61203
    61583
    61691
    61681
    61487
    61119
    60522
    59887
    59088
    58221
    57392
    7345
    6527
    5745
    5062
    4502
    4123
    3933
    3852
    4001
    4341
    4816
    5369
    6191
    6932
    7848
    57860
    58774
    59608
    60229
    60845
    61289
    61562
    61698
    61603
    61358
    60912
    60359
    59689
    58813
    58011
    7974
    7158
    6252
    5544
    4887
    4383
    4066
    3894
    3883
    4093
    4431
    4975
    5611
    6362
    7246
    8068
    58112
    58959
    59775
    60487
    60996
    61400
    61603
    61686
    61569
    61265
    60787
    60221
    59480
    58659
    57793
    7767
    6880
    6055
    5325
    4734
    4283
    3997
    3843
    3925
    4130
    4603
    5133
    5865
    6603
    7452
    57473
    58416
    59251
    59961
    60603
    61103
    61452
    61653
    61659
    61450
    61122
    60637
    60001
    59248
    58384
    57539
    7523
    6614
    5848
    5140
    4586
    4209
    3919
    3879
    3998
    4238
    4736
    5327
    6037
    6828
    7679
    57745
    58635
    59407
    60155
    60740
    61236
    61585
    61666
    61634
    61383
    60999
    60476
    59761
    59018
    58152
    8164
    7251
    6388
    5628
    5009
    4456
    4073
    3918
    3880
    4027
    4457
    4862
    5529
    6268
    7029
    7974
    57967
    58868
    59675
    60334
    60898
    61351
    61587
    61730
    61569
    61281
    60855
    60293
    59554
    58774
    57899
    7883
    7029
    6164
    5472
    4781
    4377
    4012
    3880
    3905
    4139
    4501
    5058
    5695
    6480
    7312
    57350
    58214
    59091
    59845
    60481
    61043
    61426
    61674
    61680
    61517
    61152
    60730
    60092
    59337
    58551
    57709
    7603
    6736
    5988
    5260
    4676
    4223
    3964
    3840
    3936
    4256
    4644
    5209
    5923
    6730
    7573
    57602
    58506
    59306
    60033
    60695
    61175
    61527
    61636
    61650
    61461
    61082
    60578
    59932
    59121
    58298
    57450
    7415
    6563
    5785
    5085
    4511
    4182
    3936
    3861
    3972
    4284
    4785
    5402
    6130
    6920
    7816
    57833
    58742
    59540
    60243
    60796
    61274
    61546
    61724
    61603
    61360
    60951
    60344
    59741
    58912
    58071
    8006
    7101
    6336
    5554
    4937
    4387
    4071
    3875
    3864
    4050
    4449
    4951
    5565
    6338
    7171
    8056
    58119
    58942
    59758
    60404
    60958
    61370
    61616
    61724
    61524
    61252
    60783
    60239
    59482
    58668
    57827
    7804
    6898
    6100
    5370
    4767
    4297
    3977
    3864
    3881
    4130
    4537
    5104
    5846
    6555
    7399
    57472
    58316
    59179
    59945
    60604
    61097
    61484
    61660
    61638
    61494
    61151
    5444.capture_ch1_250MSPS.txt
    57995
    57609
    8017
    7553
    7148
    6778
    6390
    6037
    5689
    5359
    5071
    4820
    4591
    4448
    4275
    4187
    4124
    4113
    4168
    4198
    4311
    4456
    4642
    4853
    5133
    5465
    5763
    6109
    6487
    6920
    7259
    7665
    8067
    57676
    58084
    58482
    58882
    59256
    59642
    60002
    60257
    60543
    60755
    61005
    61171
    61302
    61386
    61428
    61465
    61409
    61307
    61176
    61074
    60836
    60582
    60340
    60031
    59720
    59356
    58970
    58581
    58153
    57768
    57365
    7772
    7378
    6944
    6559
    6185
    5849
    5516
    5214
    4938
    4717
    4472
    4299
    4200
    4167
    4113
    4117
    4137
    4256
    4382
    4553
    4758
    4992
    5300
    5596
    5965
    6309
    6696
    7088
    7464
    7909
    57471
    57872
    58319
    58729
    59113
    59485
    59821
    60110
    60456
    60644
    60884
    61120
    61284
    61372
    61459
    61437
    61431
    61400
    61254
    61145
    60933
    60742
    60449
    60172
    59838
    59518
    59177
    58749
    58350
    57966
    57548
    7955
    7492
    7167
    6727
    6350
    5973
    5677
    5353
    5030
    4774
    4576
    4438
    4262
    4188
    4102
    4094
    4105
    4169
    4311
    4493
    4691
    4891
    5193
    5471
    5771
    6162
    6506
    6898
    7322
    7671
    8135
    57689
    58151
    58525
    58909
    59325
    59658
    60028
    60272
    60558
    60838
    61009
    61207
    61295
    61389
    61453
    61443
    61402
    61313
    61177
    61025
    60798
    60536
    60292
    59958
    59664
    59298
    58915
    58517
    58120
    57740
    8141
    7722
    7311
    6875
    6539
    6184
    5782
    5489
    5168
    4893
    4690
    4449
    4348
    4192
    4113
    4107
    4106
    4119
    4261
    4366
    4581
    4808
    5078
    5292
    5664
    6055
    6373
    6747
    7123
    7522
    7966
    57511
    57892
    58380
    58783
    59161
    59473
    59855
    60194
    60420
    60671
    60933
    61167
    61294
    61345
    61451
    61460
    61392
    61370
    61235
    61107
    60903
    60665
    60388
    60103
    59820
    59478
    59082
    58754
    58287
    57899
    57471
    7889
    7474
    7056
    6684
    6269
    5968
    5653
    5281
    5034
    4742
    4572
    4401
    4263
    4147
    4108
    4109
    4116
    4212
    4350
    4530
    4659
    4901
    5206
    5503
    5818
    6183
    6577
    6979
    7382
    7763
    57350
    57757
    58186
    58574
    58973
    59350
    59714
    60031
    60342
    60618
    60837
    61075
    61222
    61350
    61411
    61456
    61465
    61356
    61309
    61171
    60997
    60783
    60536
    60262
    59961
    59626
    59260
    58892
    58436
    58128
    57647
    8117
    7645
    7249
    6851
    6490
    6074
    5762
    5427
    5118
    4852
    4641
    4451
    4274
    4191
    4117
    4107
    4147
    4150
    4249
    4449
    4590
    4799
    5049
    5378
    5684
    6034
    6365
    6788
    7191
    7586
    8014
    57576
    57960
    58406
    58796
    59187
    59556
    59930
    60206
    60471
    60739
    60952
    61160
    61302
    61364
    61456
    61466
    61406
    61390
    61227
    61075
    60839
    60657
    60390
    60086
    59781
    59414
    59045
    58650
    58299
    57838
    57430
    7858
    7437
    7046
    6641
    6253
    5914
    5587
    5281
    4949
    4770
    4550
    4372
    4219
    4151
    4113
    4132
    4141
    4179
    4336
    4520
    4751
    4988
    5249
    5554
    5878
    6271
    6608
    6992
    7385
    7832
    57430
    57801
    58244
    58644
    59032
    59437
    59738
    60058
    60360
    60625
    60882
    61066
    61195
    61354
    61439
    61485
    61409
    61353
    61263
    61156
    60978
    60768
    60476
    60232
    59931
    59554
    59202
    58837
    58452
    58026
    57667
    8034
    7671
    7235
    6827
    6453
    6039
    5696
    5410
    5127
    4840
    4604
    4402
    4294
    4180
    4136
    4099
    4157
    4191
    4275
    4450
    4634
    4852
    5135
    5404
    5717
    6097
    6432
    6806
    7237
    7624
    8044
    57645
    58067
    58475
    58871
    59240
    59605
    60002
    60252
    60502
    60793
    61027
    61170
    61329
    61392
    61465
    61480
    61428
    61356
    61244
    61065
    60831
    60654
    60351
    60056
    59771
    59379
    59001
    58608
    58183
    57801
    57423
    7825
    7355
    6980
    6570
    6223
    5840
    5571
    5210
    4972
    4725
    4549
    4341
    4265
    4160
    4097
    4098
    4174
    4235
    4381
    4606
    4749
    4999
    5279
    5578
    5915
    6277
    6654
    7052
    7455
    7861
    57435
    57821
    58302
    58681
    59099
    59439
    59782
    60091
    60399
    60678
    60901
    61040
    61215
    61367
    61413
    61425
    61398
    61347
    61257
    61173
    60936
    60734
    60480
    60200
    59872
    59510
    59158
    58748
    58367
    57984
    57547
    7988
    7545
    7180
    6716
    6398
    5990
    5708
    5363
    5075
    4810
    4564
    4411
    4291
    4161
    4125
    4128
    4099
    4229
    4284
    4496
    4629
    4901
    5155
    5406
    5738
    6129
    6525
    6896
    7269
    7630
    8085
    57677
    58124
    58544
    58883
    59262
    59660
    60016
    60283
    60527
    60815
    61046
    61209
    61318
    61406
    61456
    61489
    61411
    61322
    61194
    61056
    60836
    60598
    60319
    60010
    59705
    59358
    58945
    58570
    58153
    57778
    8191
    7760
    7310
    6929
    6527
    6182
    5815
    5489
    5195
    4933
    4672
    4515
    4348
    4240
    4127
    4113
    4093
    4172
    4244
    4406
    4585
    4800
    5039
    5276
    5627
    6015
    6354
    6692
    7071
    7500
    7926
    57527
    57884
    58332
    58768
    59099
    59469
    59810
    60116
    60430
    60703
    60934
    61124
    61262
    61355
    61441
    61447
    61413
    61404
    61229
    61084
    60923
    60735
    60439
    60168
    59849
    59487
    59098
    58733
    58380
    57959
    57531
    7954
    7497
    7076
    6726
    6282
    6016
    5636
    5343
    5026
    4766
    4566
    4431
    4226
    4153
    4111
    4109
    4146
    4245
    4354
    4481
    4642
    4934
    5183
    5478
    5828
    6145
    6565
    6923
    7341
    7704
    8148
    57713
    58127
    58558
    58943
    59330
    59689
    60023
    60283
    60547
    60839
    61047
    61181
    61304
    61399
    61466
    61436
    61379
    61337
    61163
    61007
    60760
    60529
    60268
    59956
    59655
    59324
    58922
    58473
    58084
    57682
    8106
    7720
    7199
    6887
    6500
    6158
    5771
    5440
    5153
    4884
    4662
    4463
    4305
    4218
    4172
    4105
    4120
    4168
    4257
    4413
    4600
    4786
    5083
    5281
    5639
    6050
    6356
    6734
    7128
    7545
    7979
    57561
    57978
    58403
    58751
    59180
    59541
    59864
    60196
    60455
    60698
    60941
    61124
    61267
    61379
    61403
    61459
    61416
    61341
    61249
    61089
    60888
    60640
    60432
    60136
    59801
    59435
    59073
    58718
    58245
    57873
    57457
    7903
    7470
    7047
    6663
    6281
    5964
    5625
    5314
    5015
    4750
    4552
    4381
    4241
    4152
    4134
    4085
    4119
    4189
    4317
    4466
    4674
    4948
    5243
    5533
    5826
    6217
    6598
    6966
    7353
    7774
    57382
    57792
    58182
    58563
    59030
    59375
    59732
    60065
    60348
    60593
    60840
    61060
    61236
    61358
    61416
    61467
    61440
    61390
    61274
    61163
    60944
    60770
    60536
    60252
    59951
    59594
    59250
    58834
    58512
    58027
    57653
    8089
    7609
    7237
    6816
    6474
    6111
    5757
    5445
    5126
    4889
    4640
    4460
    4286
    4188
    4139
    4096
    4118
    4152
    4271
    4457
    4616
    4820
    5083
    5371
    5715
    6055
    6408
    6821
    7210
    7572
    7997
    57594
    58016
    58428
    58811
    59169
    59610
    59896
    60213
    60498
    60741
    61009
    61151
    61316
    61383
    61413
    61477
    61410
    61298
    61189
    61052
    60866
    60613
    60394
    60095
    59737
    59403
    59027
    58648
    58214
    57836
    57436
    7878
    7427
    7013
    6582
    6239
    5896
    5581
    5232
    4956
    4748
    4532
    4395
    4223
    4151
    4101
    4096
    4161
    4207
    4361
    4508
    4728
    4956
    5257
    5528
    5907
    6259
    6653
    6990
    7410
    7819
    57421
    57811
    58198
    58618
    59065
    59432
    59747
    60080
    60418
    60633
    60924
    61077
    61261
    61351
    61428
    61463
    61463
    61385
    61296
    61160
    60970
    60777
    60480
    60235
    59938
    59555
    59222
    58837
    58437
    58014
    57571
    8035
    7585
    7206
    6810
    6425
    6064
    5710
    5432
    5142
    4827
    4610
    4446
    4298
    4196
    4132
    4106
    4119
    4179
    4302
    4463
    4662
    4866
    5150
    5476
    5757
    6063
    6490
    6877
    7228
    7649
    8040
    57615
    58105
    58494
    58869
    59247
    59610
    59992
    60277
    60515
    60784
    60976
    61137
    61296
    61381
    61428
    61455
    61415
    61322
    61180
    61076
    60865
    60611
    60336
    60069
    59707
    59371
    58968
    58586
    58227
    57779
    57365
    7792
    7350
    6943
    6575
    6214
    5860
    5509
    5245
    4945
    4712
    4515
    4358
    4230
    4155
    4090
    4123
    4129
    4235
    4383
    4519
    4741
    4991
    5261
    5578
    5974
    6322
    6681
    7017
    7457
    7889
    57452
    57865
    58278
    58723
    59123
    59447
    59775
    60105
    60445
    60696
    60940
    61107
    61282
    61345
    61429
    61459
    61418
    61377
    61275
    61136
    60970
    60743
    60482
    60165
    59873
    59527
    59155
    58790
    58371
    57966
    57518
    7955
    7540
    7178
    6758
    6347
    5986
    5714
    5337
    5075
    4814
    4586
    4425
    4275
    4170
    4119
    4096
    4110
    4198
    4319
    4471
    4680
    4907
    5166
    5452
    5791
    6147
    6470
    6917
    7304
    7702
    8105
    57704
    58086
    58523
    58917
    59248
    59707
    59999
    60247
    60543
    60778
    61001
    61205
    61331
    61407
    61470
    61450
    61386
    61318
    61167
    61016
    60809
    60520
    60323
    60007
    59688
    59338
    58938
    58531
    58148
    57734
    57369
    7766
    7309
    6926
    6527
    6210
    5783
    5471
    5178
    4924
    4718
    4484
    4302
    4206
    4144
    4099
    4076
    4175
    4257
    4371
    4568
    4784
    5056
    5262
    5642
    5948
    6364
    6711
    7111
    7557
    7951
    57492
    57847
    58389
    58754
    59137
    59477
    59830
    60169
    60464
    60701
    60906
    61092
    61265
    61365
    61427
    61468
    61451
    61381
    61266
    61128
    60914
    60709
    60450
    60128
    59798
    59466
    59064
    58725
    58333
    57921
    57505
    7932
    7508
    7090
    6688
    6292
    5961
    5634
    5320
    5073
    4793
    4553
    4396
    4245
    4170
    4115
    4079
    4128
    4187
    4357
    4548
    4698
    4950
    5198
    5520
    5774
    6137
    6556
    6938
    7334
    7744
    8184
    57744
    58153
    58549
    58910
    59371
    59719
    60036
    60282
    60581
    60826
    61037
    61210
    61311
    61392
    61425
    61421
    61394
    61267
    61189
    61021
    60774
    60495
    60288
    59980
    59631
    59266
    58888
    58514
    58097
    57703
    8111
    7673
    7277
    6850
    6478
    6109
    5713
    5487
    5180
    4847
    4676
    4477
    4308
    4144
    4151
    4121
    4137
    4214
    4278
    4427
    4588
    4816
    5055
    5349
    5688
    6021
    6373
    6751
    7196
    7575
    7993
    57529
    57966
    58379
    58788
    59201
    59525
    59884
    60222
    60439
    60728
    60980
    61164
    61307
    61375
    61490
    61453
    61407
    61383
    61227
    61103
    60909
    60656
    60416
    60105
    59793
    59415
    59061
    58706
    58271
    57831
    57442
    7859
    7487
    7040
    6636
    6234
    5931
    5611
    5286
    4964
    4751
    4548
    4377
    4201
    4173
    4109
    4099
    4143
    4200
    4362
    4498
    4711
    4948
    5222
    5515
    5839
    6204
    6598
    6966
    7388
    7780
    57386
    57784
    58175
    58610
    59009
    59413
    59713
    60040
    60353
    60635
    60835
    61072
    61202
    61332
    61430
    61488
    61433
    61395
    61317
    61161
    60982
    60725
    60496
    60240
    59939
    59634
    59253
    58858
    58432
    58086
    57642
    8099
    7652
    7243
    6819
    6458
    6070
    5729
    5413
    5180
    4878
    4624
    4449
    4301
    4215
    4141
    4048
    4090
    4162
    4295
    4441
    4604
    4855
    5075
    5384
    5742
    6086
    6396
    6803
    7195
    7610
    8016
    57632
    58052
    58479
    58845
    59220
    59576
    59952
    60238
    60496
    60736
    60969
    61179
    61318
    61404
    61443
    61441
    61420
    61376
    61225
    61048
    60853
    60648
    60371
    60057
    59719
    59340
    59034
    58643
    58194
    57789
    57394
    7852
    7400
    6989
    6610
    6248
    5866
    5550
    5254
    4957
    4684
    4531
    4386
    4226
    4115
    4120
    4120
    4144
    4244
    4346
    4538
    4726
    4976
    5275
    5556
    5901
    6274
    6655
    7022
    7454
    7839
    57459
    57831
    58236
    58664
    59059
    59444
    59772
    60063
    60405
    60663
    60904
    61070
    61238
    61334
    61433
    61434
    61421
    61340
    61270
    61143
    60975
    60703
    60449
    60231
    59876
    59570
    59167
    58797
    58408
    57976
    57624
    7995
    7584
    7202
    6762
    6385
    5998
    5706
    5397
    5085
    4834
    4581
    4445
    4276
    4190
    4125
    4073
    4117
    4192
    4324
    4472
    4652
    4863
    5177
    5440
    5784
    6073
    6533
    6865
    7261
    7642
    8050
    57660
    58089
    58511
    58883
    59228
    59627
    59964
    60270
    60557
    60790
    60991
    61158
    61324
    61403
    61466
    61465
    61413
    61338
    61234
    61040
    60849
    60637
    60338
    60067
    59671
    59355
    58982
    58570
    58175
    57748
    57364
    7802
    7329
    6935
    6577
    6211
    5842
    5501
    5215
    4922
    4706
    4479
    4350
    4231
    4136
    4126
    4105
    4120
    4241
    4379
    4571
    4742
    5018
    5277
    5617
    5937
    6304
    6674
    7074
    7480
    7912
    57456
    57861
    58282
    58746
    59125
    59492
    59777
    60123
    60433
    60697
    60920
    61088
    61302
    61373
    61441
    61447
    61422
    61377
    61238
    61139
    60925
    60711
    60473
    60158
    59826
    59510
    59128
    58750
    58354
    57917
    57560
    7949
    7563
    7152
    6706
    6320
    6022
    5667
    5353
    5031
    4783
    4622
    4417
    4246
    4176
    4097
    4114
    4140
    4208
    4357
    4480
    4659
    4934
    5203
    5474
    5763
    6157
    6505
    6930
    7300
    7709
    8106
    57717
    58116
    58539
    58918
    59284
    59674
    59994
    60287
    60571
    60781
    61061
    61151
    61319
    61443
    61478
    61439
    61412
    61335
    61206
    61035
    60806
    60584
    60318
    59979
    59682
    59324
    58910
    58524
    58109
    57731
    8148
    7727
    7255
    6898
    6515
    6151
    5799
    5491
    5188
    4922
    4667
    4475
    4382
    4254
    4157
    4120
    4126
    4173
    4243
    4419
    4636
    4828
    5036
    5316
    5660
    5997
    6346
    6729
    7149
    7541
    7966
    57530
    57948
    58363
    58791
    59199
    59454
    59860
    60176
    60469
    60705
    60908
    61103
    61261
    61326
    61426
    61483
    61407
    61371
    61238
    61106
    60919
    60660
    60413
    60136
    59847
    59448
    59055
    58708
    58282
    57884
    57449
    7924
    7490
    7095
    6648
    6300
    5984
    5601
    5288
    4970
    4785
    4533
    4423
    4227
    4150
    4085
    4079
    4149
    4192
    4342
    4461
    4701
    4948
    5217
    5534
    5802
    6196
    6557
    6956
    7375
    7754
    8176
    57723
    58145
    58599
    58961
    59337
    59715
    60059
    60334
    60616
    60865
    61087
    61211
    61328
    61445
    61479
    61457
    61391
    61288
    61176
    61003
    60782
    60539
    60259
    59941
    59614
    59257
    58894
    58507
    58062
    57672
    8101
    7669
    7217
    6832
    6453
    6137
    5763
    5434
    5163
    4916
    4638
    4476
    4292
    4243
    4124
    4100
    4111
    4186
    4246
    4448
    4630
    4826
    5093
    5357
    5702
    6066
    6379
    6788
    7190
    7589
    8010
    57558
    58022
    58429
    58832
    59192
    59550
    59914
    60206
    60475
    60729
    60955
    61162
    61261
    61377
    61407
    61456
    61398
    61359
    61227
    61061
    60882
    60613
    60416
    60081
    59736
    59418
    59019
    58678
    58237
    57834
    57386
    7855
    7483
    7010
    6608
    6272
    5952
    5592
    5289
    4974
    4740
    4523
    4362
    4234
    4167
    4107
    4087
    4145
    4204
    4347
    4496
    4705
    4981
    5260
    5549
    5879
    6269
    6619
    7010
    7403
    7801
    57414
    57786
    58232
    58656
    59072
    59430
    59782
    60077
    60352
    60607
    60874
    61075
    61215
    61346
    61434
    61464
    61411
    61379
    61316
    61140
    60994
    60751
    60491
    60208
    59900
    59595
    59190
    58828
    58413
    58016
    57633
    8029
    7615
    7240
    6812
    6431
    6065
    5756
    5396
    5142
    4841
    4606
    4460
    4273
    4186
    4127
    4133
    4138
    4178
    4278
    4457
    4654
    4858
    5116
    5390
    5725
    6080
    6417
    6838
    7248
    7646
    8002
    57637
    58067
    58475
    58869
    59214
    59631
    59973
    60252
    60497
    60758
    60965
    61196
    61285
    61357
    61426
    61427
    61391
    61313
    61206
    61069
    60827
    60612
    60351
    60047
    59730
    59359
    58983
    58643
    58196
    57796
    57377
    7823
    7390
    6977
    6617
    6213
    5869
    5525
    5203
    4947
    4720
    4513
    4330
    4224
    4169
    4087
    4074
    4122
    4278
    4404
    4526
    4747
    4978
    5275
    5569
    5932
    6287
    6675
    7034
    7424
    7882
    57436
    57880
    58242
    58683
    59078
    59443
    59793
    60106
    60400
    60664
    60885
    61082
    61248
    61352
    61460
    61437
    61398
    61380
    61268
    61134
    60942
    60731
    60487
    60200
    59879
    59564
    59141
    58771
    58427
    57979
    57595
    7976
    7548
    7164
    6763
    6397
    6076
    5691
    5355
    5057
    4783
    4592
    4422
    4293
    4197
    4108
    4100
    4101
    4173
    4296
    4471
    4667
    4883
    5182
    5434
    5762
    6121
    6516
    6865
    7268
    7662
    8090
    57681
    58105
    58544
    58879
    59287
    59653
    59965
    60266
    60539
    60786
    61017
    61187
    61305
    61367
    61426
    61446
    61418
    61301
    61172
    61016
    60831
    60574
    60333
    60050
    59716
    59316
    58968
    58556
    58145
    57761
    8177
    7757
    7340
    6941
    6543
    6180
    5848
    5485
    5164
    4915
    4689
    4513
    4328
    4164
    4104
    4090
    4060
    4105
    4299
    4416
    4589
    4777
    5027
    5310
    5577
    5986
    6349
    6696
    7114
    7547
    7960
    57525
    57881
    58343
    58770
    59110
    59447
    59834
    60156
    60428
    60688
    60896
    61092
    61264
    61356
    61471
    61447
    61436
    61408
    61280
    61130
    60937
    60700
    60462
    60145
    59841
    59495
    59126
    58747
    58343
    57949
    57544
    7954
    7492
    7117
    6710
    6308
    5967
    5651
    5318
    5021
    4788
    4582
    4388
    4251
    4167
    4143
    4087
    4118
    4174
    4311
    4489
    4722
    4926
    5185
    5452
    5813
    6187
    6576
    6922
    7338
    7745
    8152
    57731
    58155
    58545
    58948
    59342
    59699
    60016
    60352
    60569
    60865
    61034
    61219
    61322
    61417
    61419
    61425
    61393
    61306
    61187
    61007
    60808
    60561
    60301
    60003
    59648
    59290
    58901
    58530
    58098
    57694
    8137
    7746
    7281
    6907
    6494
    6128
    5757
    5437
    5181
    4899
    4662
    4452
    4326
    4208
    4115
    4125
    4112
    4176
    4284
    4420
    4557
    4786
    5070
    5327
    5659
    6023
    6375
    6747
    7157
    7516
    8036
    57521
    57919
    58400
    58783
    59190
    59518
    59906
    60186
    60442
    60716
    60927
    61117
    61299
    61370
    61445
    61442
    61444
    61353
    61255
    61085
    60917
    60718
    60381
    60107
    59787
    59437
    59071
    58698
    58280
    57847
    57463
    7897
    7470
    7025
    6653
    6299
    5914
    5657
    5298
    5002
    4723
    4571
    4393
    4237
    4156
    4151
    4083
    4121
    4178
    4345
    4516
    4733
    4945
    5229
    5492
    5843
    6211
    6613
    6973
    7361
    7748
    57368
    57799
    58215
    58573
    58958
    59367
    59745
    60078
    60327
    60627
    60843
    61062
    61229
    61316
    61387
    61462
    61428
    61381
    61292
    61149
    60991
    60770
    60522
    60245
    59970
    59601
    59239
    58867
    58461
    58038
    57660
    8070
    7647
    7204
    6813
    6459
    6084
    5760
    5423
    5147
    4863
    4652
    4437
    4296
    4190
    4154
    4097
    4099
    4151
    4270
    4444
    4576
    4862
    5081
    5383
    5696
    6089
    6428
    6784
    7207
    7604
    8025
    57584
    57981
    58426
    58810
    59199
    59558
    59907
    60197
    60494
    60723
    60990
    61177
    61295
    61356
    61432
    61485
    61435
    61324
    61281
    61083
    60891
    60661
    60393
    60071
    59736
    59386
    59046
    58630
    58221
    57831
    57429
    7879
    7419
    6996
    6630
    6248
    5895
    5598
    5261
    4973
    4720
    4548
    4360
    4255
    4155
    4106
    4083
    4191
    4254
    4357
    4534
    4735
    4969
    5247
    5514
    5905
    6260
    6632
    7021
    7429
    7800
    57424
    57801
    58235
    58691
    59036
    59421
    59794
    60087
    60388
    60645
    60901
    61073
    61220
    61342
    61436
    61468
    61450
    61374
    61254
    61136
    60950
    60733
    60475
    60232
    59899
    59581
    59228
    58789
    58424
    58041
    57615
    8049
    7606
    7209
    6791
    6402
    6044
    5708
    5377
    5109
    4809
    4603
    4471
    4270
    4207
    4128
    4139
    4137
    4180
    4307
    4476
    4650
    4848
    5155
    5416
    5764
    6119
    6470
    6857
    7290
    7619
    8006
    57651
    58055
    58509
    58893
    59242
    59587
    59944
    60243
    60542
    60764
    61018
    61187
    61321
    61376
    61468
    61451
    61383
    61353
    61265
    61054
    60839
    60634
    60348
    60042
    59707
    59371
    58992
    58581
    58198
    57777
    57374
    7784
    7360
    6947
    6564
    6209
    5857
    5547
    5235
    4942
    4705
    4490
    4343
    4207
    4139
    4108
    4101
    4121
    4234
    4393
    4558
    4773
    4980
    5292
    5581
    5960
    6277
    6698
    7060
    7480
    7881
    57490
    57851
    58309
    58719
    59106
    59494
    59747
    60129
    60419
    60680
    60920
    61097
    61249
    61372
    61444
    61462
    61430
    61336
    61241
    61093
    60949
    60715
    60481
    60181
    59837
    59525
    59094
    58738
    58381
    57927
    57572
    7975
    7562
    7148
    6754
    6346
    5994
    5678
    5356
    5023
    4795
    4605
    4416
    4228
    4182
    4084
    4128
    4116
    4193
    4345
    4478
    4632
    4927
    5192
    5480
    5739
    6147
    6526
    6941
    7267
    7662
    8124
    57709
    58121
    58524
    58940
    59258
    59685
    60002
    60285
    60553
    60783
    61046
    61192
    61317
    61402
    61467
    61453
    61378
    61301
    61204
    61023
    60815
    60563
    60307
    60016
    59676
    59326
    58947
    58562
    58130
    57726
    8182
    7749
    7329
    6897
    6535
    6137
    5827
    5493
    5231
    4954
    4680
    4509
    4319
    4238
    4160
    4124
    4114
    4169
    4234
    4421
    4611
    4782
    5026
    5321
    5617
    6008
    6355
    6735
    7126
    7523
    7943
    57541
    57926
    58350
    58766
    59143
    59493
    59820
    60166
    60420
    60713
    60918
    61127
    61288
    61351
    61402
    61469
    61409
    61351
    61223
    61115
    60892
    60675
    60446
    60151
    59836
    59499
    59117
    58752
    58326
    57923
    57496
    7914
    7507
    7121
    6708
    6306
    5958
    5630
    5330
    5010
    4781
    4574
    4403
    4234
    4172
    4111
    4090
    4144
    4167
    4307
    4442
    4650
    4913
    5210
    5461
    5809
    6162
    6565
    6955
    7373
    7753
    8143
    57728
    58115
    58564
    58957
    59317
    59670
    60015
    60293
    60611
    60846
    61040
    61185
    61283
    61437
    61490
    61418
    61404
    61340
    61151
    60977
    60774
    60574
    60253
    59944
    59617
    59265
    58905
    58491
    58113
    57711
    8086
    7677
    7270
    6858
    6498
    6150
    5762
    5441
    5175
    4910
    4632
    4422
    4288
    4188
    4159
    4080
    4132
    4159
    4249
    4436
    4619
    4819
    5025
    5339
    5681
    6024
    6381
    6728
    7156
    7581
    7977
    57538
    57993
    58413
    58789
    59194
    59539
    59881
    60224
    60480
    60688
    60923
    61174
    61327
    61358
    61458
    61484
    61410
    61344
    61226
    61052
    60886
    60641
    60414
    60109
    59784
    59431
    59082
    58700
    58293
    57840
    57444
    7902
    7462
    7030
    6648
    6279
    5954
    5625
    5312
    4969
    4752
    4554
    4398
    4216
    4178
    4114
    4082
    4150
    4238
    4365
    4524
    4684
    4934
    5269
    5514
    5861
    6211
    6610
    7002
    7376
    7777
    57384
    57782
    58156
    58622
    59000
    59393
    59786
    60064
    60362
    60620
    60870
    61037
    61193
    61348
    61396
    61451
    61440
    61383
    61284
    61157
    60989
    60745
    60517
    60231
    59911
    59624
    59214
    58818
    58428
    58082
    57591
    8117
    7634
    7169
    6814
    6458
    6081
    5687
    5445
    5130
    4852
    4611
    4436
    4283
    4196
    4146
    4102
    4107
    4166
    4281
    4473
    4623
    4835
    5093
    5387
    5702
    6061
    6435
    6837
    7209
    7615
    8022
    57593
    58082
    58472
    58830
    59205
    59586
    59918
    60210
    60476
    60706
    60982
    61164
    61319
    61379
    61460
    61438
    61405
    61313
    61209
    61082
    60880
    60627
    60362
    60093
    59751
    59403
    59022
    58665
    58192
    57783
    57378
    7811
    7413
    7008
    6625
    6227
    5884
    5553
    5245
    4972
    4730
    4547
    4347
    4233
    4175
    4107
    4113
    4168
    4278
    4358
    4536
    4741
    5036
    5271
    5555
    5917
    6271
    6667
    7038
    7435
    7834
    57455
    57875
    58251
    58673
    59080
    59410
    59767
    60056
    60366
    60620
    60877
    61085
    61228
    61349
    61420
    61456
    61440
    61394
    61325
    61184
    60957
    60731
    60473
    60166
    59906
    59545
    59175
    58808
    58409
    57988
    57588
    8012
    7587
    7184
    6773
    6382
    6021
    5694
    5361
    5089
    4800
    4611
    4449
    4308
    4195
    4112
    4082
    4129
    4185
    4296
    4456
    4659
    4862
    5180
    5438
    5740
    6101
    6449
    6881
    7260
    7665
    8047
    57665
    58091
    58534
    58880
    59246
    59609
    59970
    60241
    60499
    60793
    60997
    61167
    61305
    61377
    61442
    61451
    61415
    61304
    61187
    61030
    60832
    60580
    60330
    60036
    59729
    59358
    58971
    58603
    58167
    57793
    57352
    7787
    7358
    6957
    6557
    6192
    5828
    5492
    5212
    4950
    4729
    4509
    4372
    4177
    4157
    4136
    4102
    4135
    4275
    4383
    4531
    4787
    5028
    5317
    5596
    5948
    6324
    6698
    7059
    7518
    7926
    57476
    57881
    58276
    58736
    59093
    59432
    59830
    60121
    60444
    60694
    60927
    61077
    61278
    61388
    61420
    61424
    61424
    61350
    61295
    61132
    60954
    60745
    60471
    60138
    59853
    59525
    59123
    58742
    58373
    57924
    57532
    7960
    7512
    7137
    6705
    6336
    6000
    5673
    5355
    5022
    4786
    4603
    4420
    4282
    4185
    4132
    4106
    4132
    4213
    4307
    4459
    4681
    4894
    5179
    5482
    5759
    6161
    6536
    6914
    7296
    7732
    8156
    57715
    58098
    58544
    58910
    59287
    59699
    60043
    60321
    60592
    60825
    61075
    61189
    61310
    61435
    61425
    61465
    61432
    61315
    61191
    61048
    60794
    60561
    60325
    59994
    59669
    59305
    58898
    58546
    58147
    57761
    8169
    7740
    7300
    6888
    6505
    6132
    5826
    5496
    5184
    4876
    4710
    4470
    4316
    4183
    4154
    4093
    4112
    4155
    4318
    4390
    4570
    4795
    5044
    5330
    5668
    6001
    6369
    6715
    7178
    7526
    7986
    57491
    57929
    58340
    58781
    59153
    59481
    59847
    60187
    60466
    60702
    60904
    61124
    61279
    61385
    61429
    61487
    61381
    61369
    61272
    61100
    60891
    60698
    60410
    60124
    59787
    59431
    59060
    58722
    58322
    57889
    57434
    7916
    7441
    7049
    6646
    6284
    5976
    5607
    5317
    5019
    4758
    4570
    4442
    4263
    4178
    4124
    4120
    4147
    4183
    4374
    4504
    4694
    4944
    5209
    5480
    5820
    6154
    6555
    6956
    7364
    7732
    57353
    57762
    58162
    58596
    58960
    59391
    59719
    60040
    60351
    60617
    60864
    61046
    61236
    61357
    61420
    61467
    61455
    61364
    61279
    61170
    61021
    60762
    60530
    60260
    59929
    59632
    59266
    58877
    58457
    58107
    57643
    8097
    7680
    7217
    6862
    6487
    6109
    5721
    5433
    5147
    4862
    4667
    4437
    4270
    4170
    4108
    4089
    4135
    4161
    4264
    4396
    4593
    4841
    5079
    5373
    5691
    6035
    6380
    6821
    7230
    7597
    7983
    57586
    58044
    58431
    58832
    59171
    59506
    59927
    60221
    60490
    60740
    60983
    61150
    61276
    61357
    61466
    61446
    61428
    61339
    61242
    61075
    60880
    60663
    60421
    60078
    59766
    59414
    59043
    58689
    58232
    57831
    57417
    7909
    7451
    7041
    6639
    6271
    5896
    5612
    5289
    4988
    4739
    4567
    4366
    4249
    4181
    4096
    4089
    4118
    4194
    4371
    4521
    4718
    4973
    5263
    5525
    5869
    6239
    6670
    7002
    7360
    7800
    57422
    57779
    58180
    58628
    59053
    59420
    59745
    60062
    60369
    60627
    60865
    61053
    61226
    61326
    61411
    61423
    61431
    61380
    61256
    61143
    60974
    60706
    60492
    60257
    59933
    59602
    59232
    58854
    58416
    58011
    57638
    8031
    7629
    7214
    6802
    6415
    6043
    5713
    5431
    5112
    4827
    4611
    4433
    4277
    4208
    4137
    4072
    4129
    4159
    4320
    4452
    4602
    4844
    5111
    5412
    5732
    6098
    6465
    6845
    7239
    7656
    8027
    57589
    58029
    58483
    58848
    59213
    59571
    59945
    60277
    60530
    60739
    60993
    61139
    61322
    61368
    61438
    61427
    61421
    61340
    61208
    61050
    60861
    60625
    60383
    60027
    59722
    59358
    59012
    58631
    58167
    57780
    57385
    7813
    7364
    6967
    6579
    6211
    5867
    5546
    5243
    4970
    4682
    4531
    4353
    4221
    4166
    4086
    4100
    4149
    4251
    4379
    4560
    4754
    4975
    5275
    5544
    5905
    6296
    6659
    7043
    7449
    7869
    57465
    57808
    58251
    58694
    59088
    59466
    59785
    60110
    60403
    60682
    60888
    61090
    61205
    61357
    61405
    61425
    61450
    61402
    61271
    61133
    60967
    60730
    60466
    60166
    59896
    59523
    59145
    58740
    58352
    57966
    57566
    7992
    7537
    7215
    6772
    6379
    6017
    5689
    5393
    5093
    4790
    4598
    4442
    4267
    4173
    4125
    4119
    4149
    4208
    4290
    4445
    4616
    4915
    5167
    5438
    5741
    6162
    6495
    6889
    7299
    7676
    8079
    57679
    58083
    58526
    58876
    59260
    59642
    59997
    60255
    60551
    60821
    61048
    61155
    61312
    61414
    61425
    61443
    61396
    61333
    61245
    61015
    60833
    60596
    60335
    60042
    59696
    59363
    58960
    58576
    58142
    57782
    57353
    7730
    7323
    6956
    6534
    6210
    5846
    5525
    5205
    4956
    4672
    4489
    4335
    4256
    4119
    4120
    4132
    4154
    4225
    4414
    4546
    4815
    4992
    5315
    5632
    5997
    6329
    6678
    7074
    7521
    7960
    57483
    57925
    58327
    58721
    59108
    59507
    59823
    60153
    60477
    60708
    60905
    61110
    61290
    61336
    61461
    61467
    61450
    61386
    61271
    61084
    60964
    60677
    60428
    60155
    59839
    59465
    59088
    58743
    58322
    57933
    57507
    7939
    7525
    7159
    6691
    6328
    5974
    5641
    5319
    5029
    4776
    4578
    4431
    4244
    4166
    4111
    4089
    4149
    4213
    4328
    4495
    4631
    4908
    5201
    5478
    5769
    6172
    6544
    6956
    7341
    7715
    8145
    57729
    58114
    58579
    58961
    59341
    59679
    60015
    60282
    60598
    60817
    61051
    61178
    61316
    61412
    61506
    61478
    61398
    61355
    61171
    61013
    60830
    60539
    60257
    59988
    59635
    59224
    58903
    58501
    58122
    57714
    8142
    7702
    7296
    6898
    6499
    6164
    5814
    5452
    5164
    4883
    4660
    4483
    4321
    4245
    4121
    4122
    4121
    4160
    4184
    4434
    4597
    4802
    5079
    5315
    5693
    6003
    6362
    6752
    7161
    7548
    8004
    57529
    57992
    58381
    58806
    59166
    59522
    59861
    60220
    60466
    60720
    60902
    61120
    61292
    61348
    61427
    61443
    61358
    61354
    61240
    61081
    60898
    60657
    60404
    60141
    59809
    59436
    59079
    58693
    58318
    57867
    57451
    7896
    7474
    7083
    6637
    6283
    6008
    5603
    5286
    4996
    4754
    4594
    4391
    4229
    4144
    4095
    4076
    4160
    4223
    4370
    4484
    4679
    4965
    5226
    5503
    5857
    6221
    6588
    6991
    7378
    7775
    57345
    57760
    58162
    58588
    59004
    59378
    59732
    60035
    60303
    60595
    60900
    61032
    61182
    61334
    61431
    61453
    61405
    61400
    61290
    61178
    60994
    60770
    60512
    60211
    59956
    59595
    59269
    58887
    58472
    58079
    57661
    8118
    7647
    7205
    6850
    6481
    6115
    5730
    5395
    5147
    4848
    4645
    4515
    4294
    4192
    4143
    4109
    4116
    4163
    4298
    4474
    4632
    4836
    5085
    5355
    5733
    6071
    6424
    6795
    7219
    7602
    8046
    57588
    58037
    58462
    58810
    59191
    59589
    59914
    60250
    60484
    60716
    60945
    61171
    61312
    61358
    61432
    61438
    61435
    61334
    61186
    61081
    60876
    60605
    60389
    60108
    59773
    59412
    59063
    58644
    58264
    57821
    57399
    7838
    7439
    7008
    6615
    6248
    5907
    5568
    5263
    4989
    4763
    4561
    4350
    4221
    4169
    4133
    4089
    4113
    4248
    4336
    4516
    4723
    4992
    5273
    5543
    5931
    6288
    6613
    7003
    7394
    7853
    57372
    57832
    58205
    58659
    59053
    59389
    59746
    60089
    60366
    60623
    60880
    61031
    61248
    61362
    61427
    61439
    61429
    61396
    61290
    61174
    60975
    60716
    60519
    60212
    59898
    59533
    59210
    58807
    58403
    58021
    57633
    8035
    7603
    7200
    6755
    6442
    6030
    5720
    5368
    5104
    4847
    4617
    4476
    4285
    4191
    4105
    4096
    4134
    4209
    4306
    4485
    4647
    4878
    5135
    5416
    5726
    6090
    6487
    6860
    7240
    7628
    8029
    57629
    58079
    58478
    58893
    59242
    59624
    59935
    60240
    60486
    60822
    61005
    61162
    61312
    61354
    61454
    61482
    61443
    61313
    61220
    61062
    60831
    60586
    60348
    60033
    59713
    59359
    59009
    58619
    58166
    57750
    57356
    7812
    7390
    6952
    6581
    6237
    5868
    5498
    5195
    4921
    4714
    4494
    4322
    4197
    4130
    4091
    4109
    4114
    4233
    4379
    4560
    4761
    5001
    5278
    5570
    5932
    6305
    6679
    7030
    7487
    7868
    57474
    57876
    58308
    58731
    59072
    59453
    59762
    60142
    60408
    60716
    60900
    61092
    61230
    61355
    61494
    61453
    61428
    61364
    61260
    61103
    60935
    60768
    60426
    60162
    59863
    59517
    59157
    58772
    58374
    57973
    57552
    7970
    7518
    7105
    6730
    6361
    5983
    5684
    5334
    5084
    4770
    4579
    4457
    4268
    4210
    4132
    4126
    4129
    4199
    4300
    4493
    4678
    4895
    5147
    5473
    5771
    6152
    6513
    6883
    7283
    7681
    8140
    57673
    58150
    58523
    58869
    59301
    59687
    60003
    60278
    60507
    60799
    61043
    61229
    61298
    61380
    61468
    61456
    61393
    61303
    61206
    60999
    60817
    60544
    60307
    59991
    59733
    59310
    58924
    58568
    58141
    57731
    8162
    7736
    7305
    6915
    6568
    6198
    5795
    5459
    5174
    4933
    4691
    4462
    4335
    4176
    4132
    4119
    4140
    4157
    4241
    4377
    4581
    4789
    5027
    5308
    5609
    6001
    6325
    6729
    7100
    7552
    7945
    57517
    57906
    58318
    58776
    59162
    59483
    59827
    60166
    60515
    60690
    60895
    61103
    61271
    61358
    61447
    61455
    61423
    61372
    61249
    61101
    60937
    60706
    60437
    60124
    59854
    59489
    59106
    58745
    58315
    57920
    57496
    7917
    7464
    7060
    6713
    6278
    5948
    5666
    5342
    5009
    4774
    4562
    4432
    4272
    4200
    4127
    4095
    4120
    4203
    4307
    4492
    4691
    4935
    5219
    5508
    5846
    6213
    6533
    6919
    7370
    7724
    8189
    57768
    58194
    58585
    58943
    59347
    59713
    60027
    60328
    60597
    60822
    61045
    61194
    61338
    61392
    61434
    61503
    61381
    61297
    61153
    61031
    60779
    60546
    60316
    59941
    59607
    59299
    58901
    58504
    58105
    57696
    8121
    7709
    7274
    6842
    6487
    6124
    5761
    5438
    5140
    4881
    4640
    4489
    4318
    4178
    4138
    4088
    4116
    4196
    4297
    4413
    4582
    4783
    5047
    5358
    5663
    6015
    6372
    6800
    7176
    7569
    7998
    57536
    57959
    58415
    58808
    59167
    59539
    59869
    60186
    60487
    60715
    60947
    61148
    61295
    61384
    61451
    61469
    61394
    61365
    61247
    61082
    60894
    60657
    60414
    60082
    59811
    59446
    59046
    58643
    58283
    57849
    57437
    7895
    7401
    7069
    6609
    6271
    5961
    5630
    5241
    4991
    4781
    4560
    4419
    4259
    4140
    4125
    4078
    4155
    4218
    4371
    4489
    4746
    4989
    5223
    5488
    5863
    6277
    6606
    6980
    7398
    7796
    57363
    57779
    58240
    58602
    59034
    59384
    59764
    60042
    60366
    60651
    60894
    61051
    61196
    61347
    61406
    61451
    61441
    61363
    61277
    61147
    60975
    60740
    60522
    60244
    59951
    59614
    59219
    58848
    58433
    58058
    57652
    8076
    7583
    7255
    6793
    6437
    6075
    5716
    5411
    5152
    4839
    4655
    4478
    4275
    4205
    4153
    4091
    4099
    4181
    4276
    4431
    4615
    4803
    5117
    5360
    5719
    6104
    6405
    6812
    7231
    7599
    8012
    57586
    58032
    58447
    58833
    59241
    59567
    59928
    60275
    60497
    60719
    60992
    61136
    61288
    61365
    61438
    61445
    61438
    61374
    61260
    61042
    60849
    60675
    60377
    60083
    59726
    59413
    59032
    58636
    58210
    57795
    57370
    7820
    7378
    7007
    6609
    6225
    5907
    5620
    5232
    4968
    4723
    4554
    4343
    4257
    4186
    4089
    4075
    4165
    4215
    4362
    4553
    4740
    5008
    5278
    5555
    5887
    6275
    6624
    7042
    7458
    7878
    57433
    57836
    58249
    58667
    59089
    59467
    59780
    60062
    60382
    60685
    60893
    61088
    61247
    61335
    61426
    61420
    61432
    61369
    61265
    61174
    60974
    60720
    60468
    60208
    59895
    59566
    59206
    58757
    58405
    57987
    57573
    8005
    7591
    7199
    6792
    6377
    6009
    5701
    5378
    5088
    4800
    4650
    4440
    4226
    4183
    4092
    4085
    4137
    4193
    4333
    4454
    4645
    4859
    5175
    5426
    5773
    6071
    6462
    6840
    7260
    7662
    8074
    57689
    58085
    58505
    58893
    59259
    59601
    59973
    60275
    60529
    60801
    61043
    61195
    61303
    61398
    61433
    61455
    61419
    61317
    61187
    61007
    60825
    60620
    60358
    60000
    59719
    59396
    58941
    58578
    58154
    57730
    8180
    7755
    7327
    6909
    6564
    6191
    5865
    5495
    5172
    4928
    4708
    4482
    4325
    4248
    4131
    4090
    4108
    4152
    4237
    4390
    4589
    4745
    5036
    5288
    5601
    5971
    6336
    6694
    7069
    7507
    7919
    57485
    57869
    58318
    58753
    59165
    59459
    59796
    60129
    60424
    60668
    60886
    61094
    61273
    61360
    61409
    61446
    61426
    61341
    61243
    61121
    60969
    60705
    60456
    60151
    59887
    59542
    59145
    58755
    58346
    57934
    57506
    7975
    7563
    7165
    6705
    6335
    5979
    5690
    5346
    5053
    4784
    4577
    4392
    4232
    4165
    4099
    4128
    4148
    4208
    4315
    4465
    4677
    4914
    5179
    5475
    5782
    6128
    6561
    6952
    7308
    7711
    8121
    57673
    58075
    58546
    58928
    59301
    59679
    60017
    60316
    60569
    60806
    61016
    61221
    61297
    61404
    61466
    61439
    61361
    61310
    61208
    61037
    60827
    60572
    60299
    59968
    59674
    59236
    58942
    58528
    58102
    57701
    8154
    7716
    7292
    6898
    6507
    6154
    5819
    5466
    5141
    4913
    4724
    4450
    4305
    4233
    4175
    4106
    4121
    4194
    4219
    4418
    4643
    4771
    5042
    5300
    5667
    6011
    6342
    6748
    7100
    7543
    7967
    57524
    57950
    58350
    58757
    59153
    59484
    59905
    60215
    60466
    60685
    60931
    61121
    61288
    61378
    61438
    61489
    61419
    61339
    61241
    61114
    60927
    60692
    60416
    60165
    59803
    59471
    59081
    58717
    58327
    57896
    57503
    7926
    7528
    7071
    6664
    6305
    5954
    5667
    5316
    4988
    4764
    4582
    4418
    4227
    4168
    4122
    4074
    4132
    4184
    4317
    4501
    4643
    4928
    5225
    5501
    5838
    6190
    6593
    6996
    7332
    7750
    57348
    57745
    58180
    58609
    58954
    59376
    59737
    60046
    60306
    60605
    60883
    61045
    61200
    61342
    61426
    61486
    61448
    61370
    61296
    61196
    60980
    60794
    60542
    60240
    59951
    59642
    59273
    58868
    58495
    58063
    57667
    8126
    7657
    7253
    6835
    6492
    6097
    5762
    5439
    5142
    4871
    4603
    4468
    4337
    4214
    4162
    4108
    4139
    4156
    4292
    4417
    4637
    4832
    5080
    5384
    5699
    6075
    6402
    6800
    7190
    7592
    7993
    57552
    58041
    58403
    58838
    59171
    59590
    59942
    60226
    60490
    60757
    60934
    61161
    61325
    61396
    61421
    61450
    61428
    61342
    61229
    61068
    60897
    60645
    60394
    60113
    59780
    59412
    59052
    58639
    58266
    57851
    57428
    7859
    7417
    7025
    6614
    6230
    5939
    5588
    5260
    4963
    4776
    4565
    4346
    4199
    4163
    4111
    4084
    4131
    4240
    4343
    4497
    4696
    4966
    5244
    5534
    5890
    6208
    6637
    6997
    7413
    7828
    57425
    57813
    58196
    58628
    59031
    59387
    59743
    60070
    60368
    60632
    60853
    61052
    61234
    61353
    61407
    61483
    61438
    61373
    61264
    61155
    60961
    60749
    60496
    60209
    59888
    59592
    59213
    58839
    58375
    58051
    57592
    8015
    7580
    7177
    6800
    6407
    6051
    5720
    5413
    5152
    4833
    4593
    4447
    4280
    4205
    4109
    4112
    4100
    4173
    4267
    4494
    4651
    4899
    5165
    5431
    5718
    6099
    6418
    6830
    7229
    7638
    8016
    57593
    58044
    58513
    58856
    59264
    59600
    59938
    60249
    60532
    60778
    61001
    61190
    61305
    61389
    61458
    61458
    61400
    61330
    61205
    61049
    60838
    60607
    60346
    60050
    59713
    59376
    59016
    58615
    58202
    57795
    57405
    7820
    7414
    7003
    6626
    6193
    5908
    5557
    5258
    4927
    4701
    4489
    4343
    4204
    4163
    4123
    4102
    4102
    4257
    4385
    4551
    4755
    5002
    5277
    5543
    5943
    6307
    6649
    7019
    7460
    7886
    57446
    57849
    58274
    58695
    59086
    59447
    59810
    60078
    60427
    60682
    60874
    61078
    61284
    61351
    61437
    61466
    61407
    61356
    61246
    61156
    60969
    60715
    60464
    60162
    59872
    59539
    59153
    58808
    58369
    58007
    57593
    8006
    7572
    7162
    6738
    6360
    6021
    5721
    5373
    5072
    4800
    4593
    4430
    4250
    4199
    4099
    4084
    4126
    4191
    4310
    4482
    4656
    4883
    5161
    5484
    5792
    6110
    6482
    6893
    7312
    7660
    8103
    57688
    58122
    58491
    58890
    59296
    59650
    59950
    60268
    60533
    60804
    61001
    61191
    61305
    61420
    61440
    61445
    61460
    61296
    61164
    61017
    60834
    60540
    60339
    60022
    59667
    59340
    58955
    58558
    58142
    57740
    57353
    7751
    7347
    6899
    6559
    6142
    5818
    5489
    5183
    4940
    4694
    4507
    4347
    4194
    4177
    4103
    4088
    4142
    4270
    4411
    4549
    4819
    5008
    5307
    5648
    5999
    6319
    6730
    7099
    7534
    7931
    57500
    57887
    58320
    58716
    59141
    59472
    59827
    60165
    60440
    60737
    60923
    61120
    61248
    61347
    61452
    61441
    61422
    61331
    61295
    61088
    60929
    60740
    60420
    60148
    59856
    59533
    59116
    58745
    58322
    57902
    57515
    7947
    7491
    7140
    6690
    6335
    6006
    5662
    5339
    5003
    4787
    4601
    4431
    4285
    4194
    4126
    4124
    4096
    4202
    4276
    4498
    4664
    4922
    5174
    5467
    5796
    6142
    6562
    6927
    7323
    7714
    8148
    57708
    58114
    58552
    58951
    59350
    59677
    60032
    60292
    60602
    60848
    61066
    61184
    61333
    61386
    61479
    61437
    61360
    61315
    61179
    61018
    60819
    60513
    60309
    59980
    59687
    59287
    58896
    58483
    58136
    57692
    8115
    7696
    7286
    6898
    6492
    6118
    5798
    5459
    5191
    4903
    4656
    4493
    4298
    4183
    4154
    4092
    4129
    4151
    4268
    4421
    4557
    4828
    5058
    5327
    5650
    6011
    6369
    6726
    7159
    7565
    7965
    57512
    57930
    58403
    58789
    59173
    59492
    59880
    60160
    60482
    60729
    60936
    61129
    61292
    61381
    61456
    61419
    61396
    61364
    61240
    61083
    60917
    60699
    60426
    60091
    59814
    59410
    59084
    58701
    58267
    57908
    57435
    7903
    7414
    7069
    6655
    6287
    5956
    5614
    5326
    5008
    4766
    4596
    4406
    4251
    4167
    4149
    4085
    4136
    4207
    4348
    4490
    4714
    4950
    5204
    5510
    5862
    6223
    6614
    6993
    7352
    7777
    57386
    57764
    58183
    58604
    58990
    59404
    59731
    60050
    60346
    60599
    60844
    61050
    61199
    61347
    61411
    61436
    61424
    61358
    61290
    61177
    60999
    60794
    60471
    60278
    59917
    59595
    59223
    58842
    58450
    58048
    57662
    8081
    7686
    7229
    6877
    6488
    6072
    5737
    5474
    5139
    4860
    4630
    4455
    4307
    4199
    4148
    4130
    4113
    4157
    4287
    4418
    4616
    4832
    5085
    5353
    5696
    6074
    6411
    6799
    7205
    7596
    8031
    57581
    58040
    58420
    58837
    59177
    59524
    59937
    60220
    60483
    60738
    60965
    61199
    61260
    61345
    61465
    61477
    61435
    61382
    61223
    61074
    60897
    60687
    60358
    60106
    59720
    59351
    59026
    58663
    58248
    57793
    57423
    7839
    7370
    7026
    6614
    6226
    5916
    5566
    5224
    4966
    4694
    4553
    4353
    4230
    4125
    4108
    4087
    4135
    4248
    4345
    4529
    4725
    4983
    5262
    5543
    5920
    6246
    6635
    7036
    7443
    7839
    57412
    57815
    58204
    58667
    59079
    59421
    59758
    60064
    60399
    60654
    60883
    61050
    61222
    61336
    61432
    61490
    61419
    61372
    61259
    61179
    60955
    60766
    60512
    60253
    59900
    59584
    59208
    58836
    58393
    58018
    57597
    8050
    7589
    7225
    6816
    6394
    6023
    5723
    5408
    5096
    4802
    4616
    4428
    4308
    4193
    4120
    4131
    4120
    4154
    4321
    4456
    4647
    4859
    5129
    5389
    5753
    6088
    6468
    6841
    7289
    7653
    8061
    57632
    58046
    58503
    58843
    59249
    59614
    60014
    60248
    60514
    60759
    60984
    61233
    61273
    61426
    61466
    61474
    61418
    61368
    61197
    61047
    60815
    60598
    60335
    60029
    59716
    59383
    58991
    58597
    58169
    57816
    57392
    7812
    7329
    6942
    6550
    6201
    5867
    5578
    5204
    4948
    4715
    4521
    4345
    4232
    4165
    4085
    4119
    4177
    4244
    4376
    4563
    4756
    4993
    5281
    5604
    5958
    6294
    6721
    7064
    7456
    7905
    57444
    57836
    58263
    58739
    59079
    59497
    59789
    60131
    60437
    60680
    60888
    61082
    61278
    61329
    61437
    61451
    61443
    61360
    61266
    61103
    60916
    60705
    60461
    60154
    59841
    59552
    59144
    58760
    58378
    57950
    57573
    7984
    7562
    7175
    6729
    6368
    5970
    5687
    5369
    5068
    4788
    4602
    4395
    4275
    4166
    4126
    4100
    4138
    4271
    4346
    4435
    4613
    4873
    5166
    5484
    5770
    6121
    6513
    6943
    7314
    7662
    8137
    57712
    58094
    58539
    58921
    59291
    59667
    60028
    60297
    60573
    60830
    61014
    61178
    61309
    61412
    61455
    61442
    61408
    61340
    61167
    61038
    60808
    60564
    60312
    60011
    59690
    59341
    58920
    58546
    58111
    57722
    57373
    7736
    7300
    6877
    6538
    6163
    5802
    5467
    5160
    4948
    4689
    4447
    4330
    4228
    4139
    4105
    4129
    4124
    4216
    4421
    4580
    4782
    5027
    5313
    5617
    6017
    6353
    6708
    7100
    7545
    7970
    57501
    57904
    58363
    58754
    59157
    59481
    59860
    60169
    60432
    60686
    60976
    61116
    61269
    61328
    61420
    61448
    61406
    61351
    61234
    61093
    60933
    60702
    60411
    60154
    59831
    59489
    59120
    58738
    58330
    57901
    57469
    7913
    7492
    7079
    6710
    6296
    5963
    5645
    5364
    5013
    4763
    4575
    4416
    4263
    4169
    4127
    4118
    4135
    4184
    4338
    4499
    4701
    4947
    5230
    5487
    5825
    6158
    6573
    6937
    7342
    7771
    8174
    57747
    58147
    58594
    58976
    59326
    59731
    59987
    60285
    60611
    60861
    61017
    61220
    61324
    61426
    61467
    61445
    61381
    61327
    61183
    61032
    60813
    60568
    60280
    59942
    59600
    59275
    58899
    58489
    58085
    57690
    8111
    7667
    7235
    6879
    6487
    6116
    5782
    5436
    5174
    4924
    4651
    4465
    4303
    4223
    4136
    4095
    4094
    4140
    4263
    4430
    4626
    4828
    5068
    5339
    5655
    6048
    6349
    6763
    7184
    7573
    7983
    57530
    58001
    58384
    58805
    59216
    59557
    59918
    60187
    60462
    60719
    60934
    61139
    61300
    61398
    61435
    61476
    61432
    61319
    61232
    61092
    60914
    60651
    60415
    60147
    59786
    59429
    59069
    58707
    58260
    57851
    57429
    7902
    7444
    7087
    6637
    6252
    5921
    5592
    5283
    4986
    4753
    4567
    4368
    4220
    4145
    4114
    4083
    4141
    4221
    4367
    4487
    4684
    4938
    5263
    5535
    5842
    6229
    6579
    7030
    7367
    7805
    57414
    57816
    58186
    58602
    59003
    59387
    59757
    60051
    60380
    60618
    60889
    61067
    61204
    61312
    61440
    61476
    61433
    61420
    61312
    61156
    60947
    60757
    60507
    60254
    59935
    59605
    59228
    58806
    58439
    58068
    57634
    8055
    7630
    7195
    6809
    6432
    6074
    5752
    5425
    5114
    4875
    4629
    4428
    4281
    4188
    4157
    4131
    4161
    4189
    4277
    4468
    4627
    4835
    5104
    5399
    5728
    6083
    6422
    6787
    7210
    7629
    8021
    57579
    58077
    58498
    58808
    59221
    59603
    59968
    60254
    60492
    60788
    60996
    61159
    61284
    61364
    61444
    61429
    61399
    61333
    61211
    61049
    60870
    60637
    60379
    60085
    59743
    59374
    59042
    58622
    58212
    57781
    57403
    7803
    7445
    6991
    6625
    6256
    5876
    5584
    5211
    4947
    4742
    4522
    4325
    4218
    4158
    4084
    4123
    4159
    4245
    4364
    4521
    4741
    4969
    5232
    5525
    5927
    6254
    6646
    7028
    7423
    7884
    57445
    57841
    58228
    58679
    59081
    59397
    59771
    60112
    60364
    60666
    60884
    61045
    61284
    61352
    61454
    61502
    61442
    61360
    61286
    61139
    60931
    60736
    60463
    60215
    59915
    59571
    59175
    58784
    58406
    57998
    57586
    8016
    7552
    7169
    6741
    6391
    6007
    5683
    5386
    5093
    4776
    4580
    4447
    4272
    4155
    4115
    4095
    4135
    4170
    4285
    4452
    4615
    4867
    5159
    5457
    5742
    6119
    6478
    6851
    7249
    7654
    8087
    57648
    58117
    58512
    58884
    59295
    59654
    59938
    60273
    60540
    60806
    61007
    61181
    61292
    61345
    61439
    61447
    61391
    61321
    61157
    61031
    60834
    60596
    60340
    60033
    59691
    59330
    58967
    58606
    58145
    57793
    8182
    7775
    7362
    6919
    6552
    6211
    5882
    5519
    5235
    4935
    4686
    4504
    4295
    4187
    4131
    4111
    4086
    4139
    4269
    4354
    4559
    4771
    5024
    5269
    5584
    5964
    6309
    6695
    7072
    7500
    7896
    57502
    57846
    58315
    58712
    59119
    59481
    59799
    60122
    60437
    60692
    60857
    61101
    61271
    61358
    61462
    61487
    61448
    61363
    61297
    61123
    60919
    60758
    60474
    60169
    59874
    59516
    59115
    58746
    58359
    57947
    57575
    7980
    7531
    7141
    6707
    6317
    6014
    5686
    5384
    5060
    4811
    4590
    4462
    4247
    4191
    4134
    4127
    4146
    4202
    4310
    4476
    4675
    4908
    5198
    5482
    5790
    6161
    6510
    6917
    7338
    7721
    8133
    57714
    58158
    58550
    58891
    59310
    59699
    60012
    60299
    60575
    60794
    61047
    61164
    61320
    61388
    61428
    61457
    61413
    61327
    61164
    61035
    60833
    60552
    60312
    59987
    59635
    59328
    58925
    58526
    58123
    57696
    8158
    7750
    7310
    6902
    6531
    6172
    5806
    5449
    5171
    4911
    4678
    4471
    4313
    4190
    4156
    4078
    4111
    4158
    4306
    4400
    4578
    4798
    5038
    5343
    5626
    6041
    6385
    6707
    7140
    7541
    7936
    57519
    57944
    58377
    58766
    59181
    59483
    59866
    60173
    60472
    60723
    60949
    61135
    61303
    61381
    61447
    61469
    61405
    61395
    61257
    61118
    60905
    60713
    60426
    60124
    59796
    59457
    59096
    58727
    58321
    57878
    57471
    7926
    7461
    7052
    6699
    6262
    5958
    5621
    5292
    4997
    4756
    4570
    4392
    4242
    4167
    4124
    4097
    4176
    4185
    4375
    4519
    4697
    4904
    5255
    5505
    5847
    6201
    6612
    6953
    7360
    7767
    8174
    57770
    58209
    58545
    58973
    59348
    59694
    60049
    60295
    60572
    60846
    61040
    61208
    61328
    61411
    61439
    61428
    61393
    61293
    61152
    61012
    60779
    60537
    60252
    59916
    59614
    59271
    58874
    58450
    58079
    57686
    8126
    7697
    7266
    6857
    6479
    6090
    5763
    5424
    5123
    4888
    4647
    4459
    4319
    4191
    4138
    4071
    4097
    4156
    4319
    4454
    4586
    4823
    5096
    5355
    5698
    6028
    6387
    6788
    7185
    7615
    7984
    57528
    57978
    58430
    58801
    59187
    59535
    59912
    60229
    60500
    60683
    60922
    61133
    61302
    61359
    61460
    61484
    61420
    61388
    61252
    61063
    60871
    60677
    60374
    60096
    59761
    59381
    59054
    58628
    58267
    57807
    57389
    7878
    7415
    7003
    6621
    6246
    5924
    5586
    5250
    4967
    4771
    4566
    4369
    4228
    4161
    4083
    4092
    4159
    4222
    4328
    4517
    4740
    4980
    5260
    5514
    5876
    6245
    6616
    7039
    7393
    7803
    57432
    57822
    58224
    58636
    59016
    59406
    59741
    60057
    60348
    60651
    60878
    61048
    61208
    61349
    61421
    61476
    61420
    61371
    61254
    61173
    60977
    60776
    60497
    60238
    59924
    59577
    59210
    58826
    58399
    58042
    57671
    8051
    7648
    7228
    6799
    6430
    6064
    5718
    5429
    5083
    4892
    4615
    4432
    4288
    4208
    4130
    4079
    4136
    4164
    4274
    4439
    4600
    4848
    5135
    5394
    5740
    6112
    6436
    6837
    7239
    7662
    8086
    57663
    58021
    58497
    58860
    59231
    59606
    59944
    60257
    60512
    60765
    60997
    61180
    61346
    61368
    61441
    61456
    61396
    61319
    61229
    61077
    60850
    60633
    60334
    60049
    59723
    59381
    59025
    58626
    58190
    57807
    57396
    7798
    7380
    6990
    6584
    6228
    5902
    5567
    5219
    4952
    4750
    4497
    4367
    4235
    4146
    4140
    4091
    4133
    4213
    4377
    4565
    4762
    5003
    5295
    5544
    5932
    6273
    6652
    7034
    7474
    7869
    57468
    57859
    58226
    58692
    59111
    59470
    59802
    60073
    60429
    60678
    60878
    61097
    61213
    61367
    61399
    61431
    61408
    61367
    61231
    61150
    60945
    60739
    60465
    60176
    59900
    59560
    59149
    58771
    58369
    57970
    57615
    7989
    7574
    7190
    6766
    6374
    6017
    5711
    5388
    5079
    4790
    4591
    4459
    4252
    4185
    4099
    4102
    4124
    4220
    4344
    4464
    4636
    4861
    5160
    5453
    5766
    6128
    6510
    6874
    7300
    7675
    8096
    57675
    58108
    58523
    58890
    59276
    59661
    59960
    60276
    60564
    60783
    61024
    61180
    61291
    61392
    61507
    61455
    61403
    61327
    61229
    61067
    60854
    60601
    60290
    59973
    59687
    59347
    58938
    58588
    58119
    57727
    57353
    7743
    7346
    6907
    6532
    6145
    5847
    5502
    5193
    4974
    4690
    4488
    4309
    4262
    4131
    4077
    4091
    4148
    4216
    4395
    4569
    4809
    5036
    5278
    5587
    5963
    6334
    6708
    7087
    7477
    7926
    57515
    57976
    58314
    58747
    59144
    59473
    59836
    60158
    60428
    60672
    60904
    61109
    61263
    61326
    61393
    61471
    61443
    61353
    61238
    61087
    60952
    60697
    60431
    60167
    59842
    59498
    59109
    58750
    58357
    57923
    57495
    7922
    7509
    7109
    6698
    6316
    5963
    5645
    5348
    5052
    4746
    4597
    4391
    4273
    4140
    4122
    4108
    4112
    4212
    4308
    4477
    4655
    4903
    5207
    5469
    5807
    6170
    6553
    6928
    7337
    7696
    8149
    57783
    58147
    58522
    58949
    59315
    59708
    59985
    60259
    60590
    60811
    61035
    61208
    61319
    61418
    61458
    61433
    61354
    61317
    61167
    61025
    60807
    60573
    60292
    59950
    59644
    59265
    58908
    58490
    58063
    57728
    8153
    7675
    7278
    6876
    6528
    6110
    5774
    5474
    5163
    4918
    4659
    4448
    4304
    4222
    4173
    4084
    4114
    4129
    4252
    4460
    4582
    4819
    5035
    5335
    5654
    6014
    6355
    6702
    7135
    7575
    7978
    57514
    57943
    58408
    58798
    59151
    59500
    59894
    60214
    60443
    60707
    60951
    61119
    61283
    61350
    61412
    61438
    61404
    61310
    61202
    61112
    60905
    60670
    60381
    60131
    59810
    59423
    59087
    58699
    58283
    57872
    57455
    7906
    7491
    7071
    6663
    6282
    5957
    5603
    5320
    5005
    4768
    4573
    4423
    4232
    4143
    4118
    4083
    4114
    4241
    4369
    4504
    4702
    4939
    5238
    5497
    5809
    6212
    6615
    6968
    7370
    7781
    8189
    57756
    58186
    58614
    59011
    59362
    59730
    60046
    60344
    60598
    60875
    61042
    61229
    61349
    61398
    61438
    61459
    61367
    61310
    61191
    60984
    60767
    60517
    60245
    59948
    59618
    59266
    58842
    58475
    58095
    57667
    8089
    7616
    7194
    6866
    6473
    6075
    5735
    5427
    5158
    4880
    4619
    4457
    4302
    4209
    4136
    4118
    4100
    4178
    4274
    4458
    4623
    4842
    5097
    5412
    5681
    6036
    6440
    6829
    7220
    7616
    7978
    57557
    58011
    58491
    58809
    59193
    59533
    59947
    60254
    60510
    60710
    60962
    61161
    61299
    61387
    61446
    61439
    61416
    61340
    61176
    61078
    60895
    60636
    60386
    60093
    59765
    59430
    59037
    58645
    58226
    57831
    57460
    7885
    7434
    7002
    6612
    6268
    5904
    5586
    5246
    4980
    4697
    4546
    4366
    4257
    4162
    4117
    4112
    4128
    4244
    4367
    4516
    4719
    4993
    5272
    5537
    5921
    6245
    6649
    7014
    7424
    7817
    57436
    57826
    58227
    58654
    59058
    59428
    59765
    60080
    60387
    60659
    60878
    61045
    61239
    61356
    61436
    61453
    61424
    61374
    61256
    61127
    60956
    60724
    60475
    60177
    59935
    59606
    59210
    58767
    58403
    58028
    57609
    8014
    7560
    7151
    6775
    6400
    6070
    5708
    5372
    5110
    4801
    4600
    4415
    4281
    4214
    4142
    4107
    4122
    4166
    4326
    4507
    4676
    4843
    5145
    5428
    5735
    6064
    6427
    6852
    7260
    7687
    8077
    57648
    58073
    58511
    58851
    59243
    59631
    59968
    60284
    60489
    60764
    61022
    61177
    61305
    61374
    61402
    61433
    61444
    61315
    61193
    61052
    60840
    60595
    60337
    60098
    59713
    59367
    58946
    58615
    58190
    57772
    57374
    7795
    7394
    6971
    6596
    6183
    5852
    5506
    5231
    4957
    4725
    4510
    4326
    4222
    4133
    4107
    4108
    4190
    4246
    4377
    4584
    4714
    5022
    5269
    5586
    5962
    6348
    6684
    7089
    7478
    7908
    57468
    57857
    58287
    58721
    59094
    59429
    59786
    60145
    60428
    60667
    60892
    61085
    61244
    61378
    61468
    61475
    61434
    61381
    61273
    61144
    60975
    60693
    60461
    60167
    59829
    59548
    59132
    58775
    58339
    57988
    57562
    7987
    7522
    7133
    6710
    6325
    6027
    5693
    5350
    5038
    4793
    4625
    4421
    4269
    4189
    4096
    4097
    4112
    4195
    4302
    4514
    4648
    4898
    5214
    5430
    5827
    6121
    6513
    6912
    7328
    7714
    8125
    57707
    58124
    58548
    58918
    59287
    59668
    60011
    60290
    60567
    60798
    61033
    61192
    61296
    61387
    61427
    61443
    61423
    61319
    61187
    61031
    60804
    60561
    60294
    59975
    59650
    59339
    58956
    58565
    58123
    57757
    8145
    7747
    7310
    6870
    6552
    6161
    5788
    5499
    5183
    4942
    4684
    4491
    4290
    4191
    4125
    4113
    4119
    4155
    4283
    4371
    4599
    4811
    5039
    5255
    5626
    5971
    6363
    6709
    7106
    7512
    7947
    57527
    57907
    58343
    58777
    59154
    59480
    59859
    60184
    60455
    60696
    60896
    61137
    61265
    61347
    61473
    61443
    61402
    61416
    61222
    61113
    60888
    60695
    60407
    60118
    59832
    59476
    59128
    58716
    58335
    57890
    57499
    7906
    7471
    7071
    6641
    6322
    5932
    5657
    5293
    4998
    4763
    4561
    4435
    4240
    4138
    4088
    4109
    4129
    4235
    4289
    4528
    4700
    4924
    5205
    5473
    5824
    6143
    6550
    6938
    7367
    7726
    8177
    57752
    58159
    58566
    58925
    59386
    59691
    60023
    60339
    60573
    60850
    61057
    61201
    61310
    61396
    61469
    61447
    61408
    61309
    61177
    61007
    60797
    60541
    60272
    59956
    59627
    59271
    58890
    58470
    58104
    57719
    8137
    7672
    7275
    6856
    6502
    6139
    5816
    5450
    5153
    4911
    4659
    4426
    4299
    4242
    4135
    4085
    4122
    4153
    4274
    4415
    4605
    4814
    5082
    5348
    5678
    6035
    6374
    6789
    7204
    7587
    7994
    57534
    57977
    58429
    58790
    59177
    59526
    59885
    60166
    60454
    60736
    60940
    61174
    61291
    61388
    61438
    61467
    61421
    61350
    61243
    61063
    60909
    60686
    60402
    60089
    59768
    59408
    59068
    58673
    58276
    57855
    57432
    7889
    7441
    7032
    6631
    6277
    5935
    5604
    5243
    4996
    4758
    4558
    4367
    4222
    4173
    4145
    4094
    4149
    4192
    4367
    4548
    4717
    4931
    5207
    5473
    5856
    6206
    6613
    6973
    7380
    7769
    57385
    57789
    58172
    58595
    58996
    59435
    59733
    60049
    60357
    60640
    60846
    61064
    61208
    61296
    61410
    61481
    61438
    61333
    61290
    61160
    61011
    60752
    60503
    60250
    59928
    59618
    59229
    58877
    58418
    58051
    57659
    8120
    7635
    7221
    6818
    6421
    6059
    5708
    5431
    5119
    4820
    4617
    4480
    4315
    4195
    4144
    4096
    4113
    4166
    4290
    4447
    4606
    4849
    5075
    5430
    5728
    6056
    6437
    6793
    7228
    7625
    8067
    57607
    58027
    58454
    58863
    59235
    59612
    59912
    60207
    60480
    60745
    60973
    61152
    61332
    61394
    61448
    61453
    61414
    61354
    61205
    61009
    60843
    60690
    60394
    60033
    59749
    59378
    59025
    58645
    58231
    57835
    57393
    7836
    7430
    6977
    6585
    6222
    5909
    5574
    5241
    4971
    4710
    4540
    4375
    4235
    4167
    4096
    4109
    4162
    4210
    4389
    4535
    4738
    4971
    5257
    5578
    5889
    6281
    6654
    7034
    7454
    7859
    57454
    57808
    58303
    58671
    59094
    59421
    59771
    60055
    60412
    60655
    60886
    61070
    61228
    61368
    61434
    61467
    61444
    61381
    61270
    61133
    60982
    60747
    60486
    60212
    59891
    59576
    59196
    58789
    58380
    57959
    57576
    8014
    7610
    7191
    6752
    6366
    6032
    5716
    5375
    5142
    4819
    4628
    4423
    4300
    4185
    4124
    4106
    4137
    4215
    4306
    4490
    4657
    4888
    5156
    5424
    5782
    6115
    6499
    6905
    7285
    7681
    8061
    57678
    58085
    58496
    58888
    59230
    59639
    59961
    60280
    60567
    60774
    61037
    61184
    61326
    61366
    61492
    61423
    61425
    61341
    61215
    61031
    60858
    60580
    60329
    60020
    59724
    59336
    58973
    58575
    58166
    57743
    8181
    7774
    7363
    6922
    6548
    6186
    5864
    5499
    5185
    4905
    4744
    4492
    4359
    4222
    4155
    4100
    4071
    4134
    4255
    4378
    4583
    4744
    5004
    5305
    5596
    5998
    6327
    6695
    7060
    7509
    7941
    57502
    57861
    58344
    58699
    59146
    59459
    59820
    60128
    60423
    60742
    60922
    61092
    61276
    61345
    61407
    61446
    61455
    61337
    61245
    61085
    60912
    60678
    60427
    60182
    59818
    59514
    59123
    58702
    58362
    57954
    57560
    7926
    7578
    7106
    6697
    6351
    5949
    5683
    5351
    5060
    4790
    4613
    4428
    4216
    4160
    4156
    4113
    4147
    4219
    4289
    4486
    4638
    4869
    5169
    5489
    5764
    6168
    6578
    6911
    7304
    7704
    8159
    57731
    58122
    58595
    58945
    59275
    59694
    60018
    60266
    60618
    60789
    61028
    61160
    61317
    61415
    61467
    61461
    61402
    61289
    61177
    61059
    60798
    60557
    60289
    60009
    59635
    59315
    58920
    58517
    58101
    57741
    8143
    7721
    7256
    6888
    6515
    6145
    5820
    5458
    5194
    4898
    4699
    4477
    4341
    4239
    4164
    4118
    4111
    4167
    4250
    4404
    4603
    4823
    5038
    5309
    5647
    6012
    6381
    6740
    7156
    7543
    7971
    57488
    57942
    58325
    58796
    59180
    59526
    59873
    60183
    60417
    60708
    60943
    61148
    61297
    61334
    61410
    61438
    61413
    61328
    61284
    61112
    60850
    60657
    60440
    60129
    59791
    59457
    59095
    58699
    58296
    57893
    57475
    7901
    7473
    7096
    6654
    6266
    5953
    5604
    5297
    4981
    4798
    4589
    4406
    4244
    4178
    4119
    4091
    4132
    4238
    4328
    4473
    4628
    4921
    5218
    5501
    5854
    6187
    6594
    6938
    7335
    7756
    57370
    57759
    58152
    58591
    58981
    59378
    59682
    60021
    60310
    60643
    60847
    61053
    61201
    61319
    61435
    61444
    61461
    61396
    61318
    61229
    61027
    60779
    60523
    60274
    59955
    59634
    59255
    58888
    58470
    58048
    57653
    8145
    7679
    7207
    6843
    6451
    6137
    5759
    5448
    5185
    4861
    4656
    4424
    4284
    4176
    4157
    4112
    4126
    4137
    4264
    4449
    4658
    4796
    5095
    5366
    5705
    6060
    6396
    6785
    7181
    7626
    8022
    57542
    57979
    58433
    58830
    59225
    59534
    59929
    60205
    60477
    60731
    61001
    61123
    61264
    61374
    61435
    61446
    61405
    61327
    61244
    61053
    60856
    60634
    60371
    60091
    59805
    59390
    59045
    58683
    58239
    57823
    57417
    7872
    7456
    7038
    6613
    6264
    5956
    5599
    5274
    4981
    4705
    4524
    4381
    4230
    4164
    4103
    4093
    4126
    4209
    4365
    4495
    4698
    4953
    5239
    5535
    5917
    6254
    6609
    7018
    7384
    7778
    57427
    57789
    58216
    58628
    59025
    59396
    59797
    60068
    60352
    60644
    60905
    61077
    61222
    61321
    61466
    61455
    61419
    61387
    61310
    61172
    60950
    60740
    60505
    60212
    59942
    59548
    59236
    58838
    58425
    58031
    57640
    8056
    7587
    7188
    6805
    6430
    6045
    5720
    5430
    5131
    4848
    4628
    4453
    4278
    4176
    4129
    4085
    4127
    4185
    4284
    4455
    4670
    4808
    5151
    5408
    5750
    6058
    6456
    6839
    7234
    7653
    8049
    57617
    58073
    58498
    58895
    59238
    59600
    59953
    60226
    60540
    60788
    60999
    61164
    61326
    61392
    61397
    61450
    61429
    61300
    61194
    61050
    60829
    60598
    60376
    60068
    59732
    59391
    59012
    58629
    58215
    57785
    57390
    7790
    7376
    7019
    6568
    6205
    5894
    5552
    5246
    4945
    4717
    4515
    4363
    4195
    4142
    4108
    4119
    4154
    4294
    Andrei
