Problem building HDL ARRADIO
Hi, I'm trying to build HDL project 2019_r1 using make on Linux with Quartus 19.1. But trying to build a project ends in failure.
Log results:
2019.11.12.14:31:51 Info: Doing: <b>qsys-script --script=system_qsys_script.tcl</b>
2019.11.12.14:31:55 Info: set_module_property NAME system_bd
2019.11.12.14:31:55 Info: set_project_property DEVICE_FAMILY Cyclone V
2019.11.12.14:31:55 Info: set_project_property DEVICE 5CSXFC6D6F31C8ES
2019.11.12.14:31:55 Info: add_instance sys_clk clock_source
2019.11.12.14:31:56 Info: set_instance_parameter_value sys_clk clockFrequency 50000000.0
2019.11.12.14:31:56 Info: set_instance_parameter_value sys_clk clockFrequencyKnown 1
2019.11.12.14:31:56 Info: set_instance_parameter_value sys_clk resetSynchronousEdges NONE
2019.11.12.14:31:56 Info: add_interface sys_clk clock sink
2019.11.12.14:31:56 Info: add_interface sys_rst reset sink
2019.11.12.14:31:56 Info: set_interface_property sys_clk EXPORT_OF sys_clk.clk_in
2019.11.12.14:31:56 Info: set_interface_property sys_rst EXPORT_OF sys_clk.clk_in_reset
2019.11.12.14:31:56 Info: add_instance sys_hps altera_hps
2019.11.12.14:32:06 Info: set_instance_parameter_value sys_hps MPU_EVENTS_Enable 0
2019.11.12.14:32:08 Info: set_instance_parameter_value sys_hps F2SDRAM_Type Avalon-MM\ Bidirectional AXI-3 AXI-3
2019.11.12.14:32:11 Info: set_instance_parameter_value sys_hps F2SDRAM_Width 64 64 64
2019.11.12.14:32:14 Info: set_instance_parameter_value sys_hps F2SINTERRUPT_Enable 1
2019.11.12.14:32:16 Info: set_instance_parameter_value sys_hps EMAC0_PinMuxing Unused
2019.11.12.14:32:16 Info: set_instance_parameter_value sys_hps EMAC0_Mode N/A
2019.11.12.14:32:16 Info: set_instance_parameter_value sys_hps EMAC1_PinMuxing HPS I/O Set 0
2019.11.12.14:32:20 Info: set_instance_parameter_value sys_hps EMAC1_Mode RGMII
2019.11.12.14:32:23 Info: set_instance_parameter_value sys_hps QSPI_PinMuxing HPS I/O Set 0
2019.11.12.14:32:27 Info: set_instance_parameter_value sys_hps QSPI_Mode 1 SS
2019.11.12.14:32:30 Info: set_instance_parameter_value sys_hps SDIO_PinMuxing HPS I/O Set 0
2019.11.12.14:32:34 Info: set_instance_parameter_value sys_hps SDIO_Mode 4-bit Data
2019.11.12.14:32:37 Info: set_instance_parameter_value sys_hps USB0_PinMuxing Unused
2019.11.12.14:32:37 Info: set_instance_parameter_value sys_hps USB0_Mode N/A
2019.11.12.14:32:37 Info: set_instance_parameter_value sys_hps USB1_PinMuxing HPS I/O Set 0
2019.11.12.14:32:40 Info: set_instance_parameter_value sys_hps USB1_Mode SDR
2019.11.12.14:32:44 Info: set_instance_parameter_value sys_hps SPIM0_PinMuxing Unused
2019.11.12.14:32:44 Info: set_instance_parameter_value sys_hps SPIM0_Mode N/A
2019.11.12.14:32:44 Info: set_instance_parameter_value sys_hps SPIM1_PinMuxing HPS I/O Set 0
2019.11.12.14:32:47 Info: set_instance_parameter_value sys_hps SPIM1_Mode Single Slave Select
2019.11.12.14:32:51 Info: set_instance_parameter_value sys_hps UART0_PinMuxing HPS I/O Set 0
2019.11.12.14:32:52 Info: set_instance_parameter_value sys_hps UART0_Mode No Flow Control
2019.11.12.14:32:56 Info: set_instance_parameter_value sys_hps UART1_PinMuxing Unused
2019.11.12.14:32:56 Info: set_instance_parameter_value sys_hps UART1_Mode N/A
2019.11.12.14:32:56 Info: set_instance_parameter_value sys_hps I2C0_PinMuxing FPGA
2019.11.12.14:32:58 Info: set_instance_parameter_value sys_hps I2C0_Mode Full
2019.11.12.14:32:59 Info: set_instance_parameter_value sys_hps desired_cfg_clk_mhz 80.0
2019.11.12.14:33:03 Info: set_instance_parameter_value sys_hps S2FCLK_USER0CLK_Enable 1
2019.11.12.14:33:05 Info: set_instance_parameter_value sys_hps S2FCLK_USER1CLK_Enable 0
2019.11.12.14:33:05 Info: set_instance_parameter_value sys_hps S2FCLK_USER1CLK_FREQ 100.0
2019.11.12.14:33:05 Info: set_instance_parameter_value sys_hps S2FCLK_USER2CLK_FREQ 100.0
2019.11.12.14:33:05 Info: set_instance_parameter_value sys_hps HPS_PROTOCOL DDR3
2019.11.12.14:33:05 Info: set_instance_parameter_value sys_hps MEM_CLK_FREQ 400.0
2019.11.12.14:33:08 Info: set_instance_parameter_value sys_hps REF_CLK_FREQ 25.0
2019.11.12.14:33:13 Info: set_instance_parameter_value sys_hps MEM_VOLTAGE 1.5V DDR3
2019.11.12.14:33:13 Info: set_instance_parameter_value sys_hps MEM_CLK_FREQ_MAX 800.0
2019.11.12.14:33:16 Info: set_instance_parameter_value sys_hps MEM_DQ_WIDTH 32
2019.11.12.14:33:20 Info: set_instance_parameter_value sys_hps MEM_ROW_ADDR_WIDTH 15
2019.11.12.14:33:23 Info: set_instance_parameter_value sys_hps MEM_COL_ADDR_WIDTH 10
2019.11.12.14:33:26 Info: set_instance_parameter_value sys_hps MEM_BANKADDR_WIDTH 3
2019.11.12.14:33:26 Info: set_instance_parameter_value sys_hps MEM_TCL 11
2019.11.12.14:33:30 Info: set_instance_parameter_value sys_hps MEM_DRV_STR RZQ/7
2019.11.12.14:33:33 Info: set_instance_parameter_value sys_hps MEM_RTT_NOM RZQ/4
2019.11.12.14:33:36 Info: set_instance_parameter_value sys_hps MEM_WTCL 8
2019.11.12.14:33:40 Info: set_instance_parameter_value sys_hps MEM_RTT_WR RZQ/4
2019.11.12.14:33:43 Info: set_instance_parameter_value sys_hps TIMING_TIS 180
2019.11.12.14:33:46 Info: set_instance_parameter_value sys_hps TIMING_TIH 140
2019.11.12.14:33:50 Info: set_instance_parameter_value sys_hps TIMING_TDS 30
2019.11.12.14:33:53 Info: set_instance_parameter_value sys_hps TIMING_TDH 65
2019.11.12.14:33:56 Info: set_instance_parameter_value sys_hps TIMING_TDQSQ 125
2019.11.12.14:33:58 Info: set_instance_parameter_value sys_hps TIMING_TQH 0.38
2019.11.12.14:33:58 Info: set_instance_parameter_value sys_hps TIMING_TDQSCK 255
2019.11.12.14:34:00 Info: set_instance_parameter_value sys_hps TIMING_TDQSS 0.25
2019.11.12.14:34:00 Info: set_instance_parameter_value sys_hps TIMING_TQSH 0.4
2019.11.12.14:34:01 Info: set_instance_parameter_value sys_hps TIMING_TDSH 0.2
2019.11.12.14:34:01 Info: set_instance_parameter_value sys_hps TIMING_TDSS 0.2
2019.11.12.14:34:01 Info: set_instance_parameter_value sys_hps MEM_TINIT_US 500
2019.11.12.14:34:05 Info: set_instance_parameter_value sys_hps MEM_TMRD_CK 4
2019.11.12.14:34:06 Info: set_instance_parameter_value sys_hps MEM_TRAS_NS 35.0
2019.11.12.14:34:09 Info: set_instance_parameter_value sys_hps MEM_TRCD_NS 13.75
2019.11.12.14:34:11 Info: set_instance_parameter_value sys_hps MEM_TRP_NS 13.75
2019.11.12.14:34:13 Info: set_instance_parameter_value sys_hps MEM_TREFI_US 7.8
2019.11.12.14:34:16 Info: set_instance_parameter_value sys_hps MEM_TRFC_NS 260.0
2019.11.12.14:34:19 Info: set_instance_parameter_value sys_hps MEM_TWR_NS 15.0
2019.11.12.14:34:19 Info: set_instance_parameter_value sys_hps MEM_TWTR 4
2019.11.12.14:34:23 Info: set_instance_parameter_value sys_hps MEM_TFAW_NS 30.0
2019.11.12.14:34:26 Info: set_instance_parameter_value sys_hps MEM_TRRD_NS 7.5
2019.11.12.14:34:26 Info: set_instance_parameter_value sys_hps MEM_TRTP_NS 7.5
2019.11.12.14:34:26 Info: set_instance_parameter_value sys_hps TIMING_BOARD_MAX_CK_DELAY 0.03
2019.11.12.14:34:27 Info: set_instance_parameter_value sys_hps TIMING_BOARD_MAX_DQS_DELAY 0.02
2019.11.12.14:34:29 Info: set_instance_parameter_value sys_hps TIMING_BOARD_SKEW_CKDQS_DIMM_MIN 0.09
2019.11.12.14:34:30 Info: set_instance_parameter_value sys_hps TIMING_BOARD_SKEW_CKDQS_DIMM_MAX 0.16
2019.11.12.14:34:34 Info: set_instance_parameter_value sys_hps TIMING_BOARD_SKEW_WITHIN_DQS 0.01
2019.11.12.14:34:35 Info: set_instance_parameter_value sys_hps TIMING_BOARD_SKEW_BETWEEN_DQS 0.08
2019.11.12.14:34:37 Info: set_instance_parameter_value sys_hps TIMING_BOARD_DQ_TO_DQS_SKEW 0.0
2019.11.12.14:34:37 Info: set_instance_parameter_value sys_hps TIMING_BOARD_AC_SKEW 0.03
2019.11.12.14:34:39 Info: set_instance_parameter_value sys_hps TIMING_BOARD_AC_TO_CK_SKEW 0.0
2019.11.12.14:34:39 Info: add_interface sys_hps_memory conduit end
2019.11.12.14:34:39 Info: set_interface_property sys_hps_memory EXPORT_OF sys_hps.memory
2019.11.12.14:34:39 Info: add_interface sys_hps_hps_io conduit end
2019.11.12.14:34:39 Info: set_interface_property sys_hps_hps_io EXPORT_OF sys_hps.hps_io
2019.11.12.14:34:39 Info: add_interface sys_hps_h2f_reset reset source
2019.11.12.14:34:39 Info: set_interface_property sys_hps_h2f_reset EXPORT_OF sys_hps.h2f_reset
2019.11.12.14:34:39 Info: add_connection sys_clk.clk sys_hps.f2h_sdram0_clock
2019.11.12.14:34:40 Info: add_connection sys_clk.clk sys_hps.h2f_axi_clock
2019.11.12.14:34:42 Info: add_connection sys_clk.clk sys_hps.f2h_axi_clock
2019.11.12.14:34:44 Info: add_connection sys_clk.clk sys_hps.h2f_lw_axi_clock
2019.11.12.14:34:45 Info: add_interface sys_hps_i2c0 conduit end
2019.11.12.14:34:45 Info: set_interface_property sys_hps_i2c0 EXPORT_OF sys_hps.i2c0
2019.11.12.14:34:45 Info: add_interface sys_hps_i2c0_clk clock source
2019.11.12.14:34:45 Info: set_interface_property sys_hps_i2c0_clk EXPORT_OF sys_hps.i2c0_clk
2019.11.12.14:34:45 Info: add_interface sys_hps_i2c0_scl_in clock sink
2019.11.12.14:34:45 Info: set_interface_property sys_hps_i2c0_scl_in EXPORT_OF sys_hps.i2c0_scl_in
2019.11.12.14:34:47 Info: add_instance sys_dma_clk clock_source
2019.11.12.14:34:47 Info: add_connection sys_hps.h2f_user0_clock sys_dma_clk.clk_in
2019.11.12.14:34:47 Info: add_connection sys_clk.clk_reset sys_dma_clk.clk_in_reset
2019.11.12.14:34:47 Info: add_connection sys_dma_clk.clk sys_hps.f2h_sdram1_clock
2019.11.12.14:34:49 Info: add_connection sys_dma_clk.clk sys_hps.f2h_sdram2_clock
2019.11.12.14:34:51 Info: add_instance sys_int_mem altera_avalon_onchip_memory2
2019.11.12.14:34:51 Info: set_instance_parameter_value sys_int_mem dualPort 0
2019.11.12.14:34:51 Info: set_instance_parameter_value sys_int_mem dataWidth 64
2019.11.12.14:34:51 Info: set_instance_parameter_value sys_int_mem memorySize 65536.0
2019.11.12.14:34:51 Info: set_instance_parameter_value sys_int_mem initMemContent 0
2019.11.12.14:34:51 Info: add_connection sys_clk.clk sys_int_mem.clk1
2019.11.12.14:34:51 Info: add_connection sys_clk.clk_reset sys_int_mem.reset1
2019.11.12.14:34:51 Info: add_connection sys_hps.h2f_axi_master sys_int_mem.s1
2019.11.12.14:34:51 Info: set_connection_parameter_value sys_hps.h2f_axi_master/sys_int_mem.s1 baseAddress 0x0000
2019.11.12.14:34:51 Info: add_instance vga_pll altera_pll
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_device_speed_grade 2
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_reference_clock_frequency 50.0
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_use_locked 0
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_number_of_clocks 2
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_output_clock_frequency0 85.5
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_pll gui_output_clock_frequency1 171.0
2019.11.12.14:34:52 Info: add_connection sys_clk.clk vga_pll.refclk
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset vga_pll.reset
2019.11.12.14:34:52 Info: add_instance vga_frame_reader alt_vip_vfr
2019.11.12.14:34:52 Error: add_instance vga_frame_reader alt_vip_vfr : No module type named alt_vip_vfr.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader BITS_PER_PIXEL_PER_COLOR_PLANE 8
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader BITS_PER_PIXEL_PER_COLOR_PLANE 8: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader NUMBER_OF_CHANNELS_IN_PARALLEL 4
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader NUMBER_OF_CHANNELS_IN_PARALLEL 4: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader NUMBER_OF_CHANNELS_IN_SEQUENCE 1
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader NUMBER_OF_CHANNELS_IN_SEQUENCE 1: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader MAX_IMAGE_WIDTH 1360
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader MAX_IMAGE_WIDTH 1360: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader MAX_IMAGE_HEIGHT 768
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader MAX_IMAGE_HEIGHT 768: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader MEM_PORT_WIDTH 128
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader MEM_PORT_WIDTH 128: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader RMASTER_FIFO_DEPTH 64
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader RMASTER_FIFO_DEPTH 64: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader RMASTER_BURST_TARGET 32
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader RMASTER_BURST_TARGET 32: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_frame_reader CLOCKS_ARE_SEPARATE 1
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_frame_reader CLOCKS_ARE_SEPARATE 1: No module named vga_frame_reader.
2019.11.12.14:34:52 Info: add_connection sys_clk.clk vga_frame_reader.clock_master
2019.11.12.14:34:52 Error: add_connection sys_clk.clk vga_frame_reader.clock_master: No interface named vga_frame_reader.clock_master.
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset vga_frame_reader.clock_master_reset
2019.11.12.14:34:52 Error: add_connection sys_clk.clk_reset vga_frame_reader.clock_master_reset: No interface named vga_frame_reader.clock_master_reset.
2019.11.12.14:34:52 Info: add_connection vga_frame_reader.avalon_master sys_hps.f2h_sdram0_data
2019.11.12.14:34:52 Error: add_connection vga_frame_reader.avalon_master sys_hps.f2h_sdram0_data: No interface named vga_frame_reader.avalon_master.
2019.11.12.14:34:52 Info: set_connection_parameter_value vga_frame_reader.avalon_master/sys_hps.f2h_sdram0_data baseAddress 0x0000
2019.11.12.14:34:52 Error: set_connection_parameter_value vga_frame_reader.avalon_master/sys_hps.f2h_sdram0_data baseAddress 0x0000: No interface named vga_frame_reader.avalon_master.
2019.11.12.14:34:52 Info: add_connection vga_pll.outclk0 vga_frame_reader.clock_reset
2019.11.12.14:34:52 Error: add_connection vga_pll.outclk0 vga_frame_reader.clock_reset: No interface named vga_frame_reader.clock_reset.
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset vga_frame_reader.clock_reset_reset
2019.11.12.14:34:52 Error: add_connection sys_clk.clk_reset vga_frame_reader.clock_reset_reset: No interface named vga_frame_reader.clock_reset_reset.
2019.11.12.14:34:52 Info: add_instance vga_out_clock altera_clock_bridge
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_clock NUM_CLOCK_OUTPUTS 1
2019.11.12.14:34:52 Info: add_connection vga_pll.outclk0 vga_out_clock.in_clk
2019.11.12.14:34:52 Info: add_interface vga_out_clk clock source
2019.11.12.14:34:52 Info: set_interface_property vga_out_clk EXPORT_OF vga_out_clock.out_clk
2019.11.12.14:34:52 Info: add_instance vga_out_data alt_vip_itc
2019.11.12.14:34:52 Error: add_instance vga_out_data alt_vip_itc : No module type named alt_vip_itc.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data H_ACTIVE_PIXELS 1360
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data H_ACTIVE_PIXELS 1360: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data V_ACTIVE_LINES 768
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data V_ACTIVE_LINES 768: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data BPS 8
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data BPS 8: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data NUMBER_OF_COLOUR_PLANES 4
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data NUMBER_OF_COLOUR_PLANES 4: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data COLOUR_PLANES_ARE_IN_PARALLEL 1
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data COLOUR_PLANES_ARE_IN_PARALLEL 1: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data ACCEPT_COLOURS_IN_SEQ 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data ACCEPT_COLOURS_IN_SEQ 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data INTERLACED 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data INTERLACED 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data USE_EMBEDDED_SYNCS 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data USE_EMBEDDED_SYNCS 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data AP_LINE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data AP_LINE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data ANC_LINE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data ANC_LINE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data H_BLANK 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data H_BLANK 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data V_BLANK 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data V_BLANK 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data H_SYNC_LENGTH 112
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data H_SYNC_LENGTH 112: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data H_FRONT_PORCH 64
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data H_FRONT_PORCH 64: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data H_BACK_PORCH 256
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data H_BACK_PORCH 256: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data V_SYNC_LENGTH 6
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data V_SYNC_LENGTH 6: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data V_FRONT_PORCH 3
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data V_FRONT_PORCH 3: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data V_BACK_PORCH 18
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data V_BACK_PORCH 18: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data F_RISING_EDGE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data F_RISING_EDGE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data F_FALLING_EDGE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data F_FALLING_EDGE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_V_RISING_EDGE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_V_RISING_EDGE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_ANC_LINE 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_ANC_LINE 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_V_BLANK 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_V_BLANK 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_V_SYNC_LENGTH 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_V_SYNC_LENGTH 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_V_FRONT_PORCH 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_V_FRONT_PORCH 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIELD0_V_BACK_PORCH 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIELD0_V_BACK_PORCH 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data FIFO_DEPTH 1920
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data FIFO_DEPTH 1920: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data THRESHOLD 1919
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data THRESHOLD 1919: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data CLOCKS_ARE_SAME 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data CLOCKS_ARE_SAME 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data USE_CONTROL 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data USE_CONTROL 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data GENERATE_SYNC 0
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data GENERATE_SYNC 0: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data NO_OF_MODES 1
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data NO_OF_MODES 1: No module named vga_out_data.
2019.11.12.14:34:52 Info: set_instance_parameter_value vga_out_data STD_WIDTH 1
2019.11.12.14:34:52 Error: set_instance_parameter_value vga_out_data STD_WIDTH 1: No module named vga_out_data.
2019.11.12.14:34:52 Info: add_connection vga_pll.outclk0 vga_out_data.is_clk_rst
2019.11.12.14:34:52 Error: add_connection vga_pll.outclk0 vga_out_data.is_clk_rst: No interface named vga_out_data.is_clk_rst.
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset vga_out_data.is_clk_rst_reset
2019.11.12.14:34:52 Error: add_connection sys_clk.clk_reset vga_out_data.is_clk_rst_reset: No interface named vga_out_data.is_clk_rst_reset.
2019.11.12.14:34:52 Info: add_connection vga_frame_reader.avalon_streaming_source vga_out_data.din
2019.11.12.14:34:52 Error: add_connection vga_frame_reader.avalon_streaming_source vga_out_data.din: No interface named vga_frame_reader.avalon_streaming_source.
2019.11.12.14:34:52 Info: add_interface vga_out_data conduit end
2019.11.12.14:34:52 Info: set_interface_property vga_out_data EXPORT_OF vga_out_data.clocked_video
2019.11.12.14:34:52 Error: set_interface_property vga_out_data EXPORT_OF vga_out_data.clocked_video: No interface named vga_out_data.clocked_video.
2019.11.12.14:34:52 Info: add_instance sys_id altera_avalon_sysid_qsys
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_id id -1395322110
2019.11.12.14:34:52 Info: add_connection sys_clk.clk sys_id.clk
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset sys_id.reset
2019.11.12.14:34:52 Info: add_instance sys_gpio_bd altera_avalon_pio
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_gpio_bd direction InOut
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_gpio_bd generateIRQ 1
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_gpio_bd width 32
2019.11.12.14:34:52 Info: add_connection sys_clk.clk sys_gpio_bd.clk
2019.11.12.14:34:52 Info: add_connection sys_clk.clk_reset sys_gpio_bd.reset
2019.11.12.14:34:52 Info: add_interface sys_gpio_bd conduit end
2019.11.12.14:34:52 Info: set_interface_property sys_gpio_bd EXPORT_OF sys_gpio_bd.external_connection
2019.11.12.14:34:52 Info: add_instance sys_gpio_in altera_avalon_pio
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_gpio_in direction Input
2019.11.12.14:34:52 Info: set_instance_parameter_value sys_gpio_in generateIRQ 1
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_gpio_in width 32
2019.11.12.14:34:53 Info: add_connection sys_clk.clk_reset sys_gpio_in.reset
2019.11.12.14:34:53 Info: add_connection sys_clk.clk sys_gpio_in.clk
2019.11.12.14:34:53 Info: add_interface sys_gpio_in conduit end
2019.11.12.14:34:53 Info: set_interface_property sys_gpio_in EXPORT_OF sys_gpio_in.external_connection
2019.11.12.14:34:53 Info: add_instance sys_gpio_out altera_avalon_pio
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_gpio_out direction Output
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_gpio_out generateIRQ 0
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_gpio_out width 32
2019.11.12.14:34:53 Info: add_connection sys_clk.clk_reset sys_gpio_out.reset
2019.11.12.14:34:53 Info: add_connection sys_clk.clk sys_gpio_out.clk
2019.11.12.14:34:53 Info: add_interface sys_gpio_out conduit end
2019.11.12.14:34:53 Info: set_interface_property sys_gpio_out EXPORT_OF sys_gpio_out.external_connection
2019.11.12.14:34:53 Info: add_instance sys_spi altera_avalon_spi
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi clockPhase 0
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi clockPolarity 1
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi dataWidth 8
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi masterSPI 1
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi numberOfSlaves 1
2019.11.12.14:34:53 Info: set_instance_parameter_value sys_spi targetClockRate 50000000.0
2019.11.12.14:34:53 Info: add_connection sys_clk.clk sys_spi.clk
2019.11.12.14:34:53 Info: add_connection sys_clk.clk_reset sys_spi.reset
2019.11.12.14:34:53 Info: add_interface sys_spi conduit end
2019.11.12.14:34:53 Info: set_interface_property sys_spi EXPORT_OF sys_spi.external
2019.11.12.14:34:53 Info: add_connection sys_hps.f2h_irq0 sys_gpio_bd.irq
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.f2h_irq0/sys_gpio_bd.irq irqNumber 0
2019.11.12.14:34:53 Info: add_connection sys_hps.f2h_irq0 sys_spi.irq
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.f2h_irq0/sys_spi.irq irqNumber 1
2019.11.12.14:34:53 Info: add_connection sys_hps.f2h_irq0 vga_frame_reader.interrupt_sender
2019.11.12.14:34:53 Error: add_connection sys_hps.f2h_irq0 vga_frame_reader.interrupt_sender: No interface named vga_frame_reader.interrupt_sender.
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.f2h_irq0/vga_frame_reader.interrupt_sender irqNumber 4
2019.11.12.14:34:53 Error: set_connection_parameter_value sys_hps.f2h_irq0/vga_frame_reader.interrupt_sender irqNumber 4: No interface named vga_frame_reader.interrupt_sender.
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master sys_spi.spi_control_port
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/sys_spi.spi_control_port baseAddress 0x00108000
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master vga_frame_reader.avalon_slave
2019.11.12.14:34:53 Error: add_connection sys_hps.h2f_lw_axi_master vga_frame_reader.avalon_slave: No interface named vga_frame_reader.avalon_slave.
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/vga_frame_reader.avalon_slave baseAddress 0x00009000
2019.11.12.14:34:53 Error: set_connection_parameter_value sys_hps.h2f_lw_axi_master/vga_frame_reader.avalon_slave baseAddress 0x00009000: No interface named vga_frame_reader.avalon_slave.
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master sys_id.control_slave
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/sys_id.control_slave baseAddress 0x00010000
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master sys_gpio_bd.s1
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/sys_gpio_bd.s1 baseAddress 0x00010080
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master sys_gpio_in.s1
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/sys_gpio_in.s1 baseAddress 0x00010100
2019.11.12.14:34:53 Info: add_connection sys_hps.h2f_lw_axi_master sys_gpio_out.s1
2019.11.12.14:34:53 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/sys_gpio_out.s1 baseAddress 0x00109000
2019.11.12.14:34:53 Info: add_instance axi_ad9361 axi_ad9361
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 ID 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 MODE_1R1T 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 TDD_DISABLE 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 CMOS_OR_LVDS_N 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 ADC_DATAPATH_DISABLE 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_ad9361 DAC_DATAPATH_DISABLE 0
2019.11.12.14:34:53 Info: add_interface axi_ad9361_device_if conduit end
2019.11.12.14:34:53 Info: set_interface_property axi_ad9361_device_if EXPORT_OF axi_ad9361.device_if
2019.11.12.14:34:53 Info: add_interface axi_ad9361_up_enable conduit end
2019.11.12.14:34:53 Info: set_interface_property axi_ad9361_up_enable EXPORT_OF axi_ad9361.if_up_enable
2019.11.12.14:34:53 Info: add_interface axi_ad9361_up_txnrx conduit end
2019.11.12.14:34:53 Info: set_interface_property axi_ad9361_up_txnrx EXPORT_OF axi_ad9361.if_up_txnrx
2019.11.12.14:34:53 Info: add_connection axi_ad9361.if_l_clk axi_ad9361.if_clk
2019.11.12.14:34:53 Info: add_connection sys_clk.clk axi_ad9361.if_delay_clk
2019.11.12.14:34:53 Info: add_connection sys_clk.clk axi_ad9361.s_axi_clock
2019.11.12.14:34:53 Info: add_connection sys_clk.clk_reset axi_ad9361.s_axi_reset
2019.11.12.14:34:53 Info: add_instance util_adc_wfifo util_wfifo
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_wfifo NUM_OF_CHANNELS 4
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_wfifo DIN_DATA_WIDTH 16
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_wfifo DOUT_DATA_WIDTH 16
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_wfifo DIN_ADDRESS_WIDTH 5
2019.11.12.14:34:53 Info: add_connection axi_ad9361.if_l_clk util_adc_wfifo.if_din_clk
2019.11.12.14:34:53 Info: add_connection axi_ad9361.if_rst util_adc_wfifo.if_din_rst
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk util_adc_wfifo.if_dout_clk
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk_reset util_adc_wfifo.if_dout_rstn
2019.11.12.14:34:53 Info: add_connection axi_ad9361.adc_ch_0 util_adc_wfifo.din_0
2019.11.12.14:34:53 Info: add_connection axi_ad9361.adc_ch_1 util_adc_wfifo.din_1
2019.11.12.14:34:53 Info: add_connection axi_ad9361.adc_ch_2 util_adc_wfifo.din_2
2019.11.12.14:34:53 Info: add_connection axi_ad9361.adc_ch_3 util_adc_wfifo.din_3
2019.11.12.14:34:53 Info: add_connection util_adc_wfifo.if_din_ovf axi_ad9361.if_adc_dovf
2019.11.12.14:34:53 Info: add_instance util_dac_rfifo util_rfifo
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_rfifo NUM_OF_CHANNELS 4
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_rfifo DIN_DATA_WIDTH 16
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_rfifo DOUT_DATA_WIDTH 16
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_rfifo DIN_ADDRESS_WIDTH 5
2019.11.12.14:34:53 Info: add_connection axi_ad9361.if_l_clk util_dac_rfifo.if_dout_clk
2019.11.12.14:34:53 Info: add_connection axi_ad9361.if_rst util_dac_rfifo.if_dout_rst
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk util_dac_rfifo.if_din_clk
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk_reset util_dac_rfifo.if_din_rstn
2019.11.12.14:34:53 Info: add_connection util_dac_rfifo.dout_0 axi_ad9361.dac_ch_0
2019.11.12.14:34:53 Info: add_connection util_dac_rfifo.dout_1 axi_ad9361.dac_ch_1
2019.11.12.14:34:53 Info: add_connection util_dac_rfifo.dout_2 axi_ad9361.dac_ch_2
2019.11.12.14:34:53 Info: add_connection util_dac_rfifo.dout_3 axi_ad9361.dac_ch_3
2019.11.12.14:34:53 Info: add_connection util_dac_rfifo.if_dout_unf axi_ad9361.if_dac_dunf
2019.11.12.14:34:53 Info: add_instance util_adc_pack util_cpack2
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_pack NUM_OF_CHANNELS 4
2019.11.12.14:34:53 Info: set_instance_parameter_value util_adc_pack SAMPLE_DATA_WIDTH 16
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk util_adc_pack.clk
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk_reset util_adc_pack.reset
2019.11.12.14:34:53 Info: add_connection util_adc_wfifo.dout_0 util_adc_pack.adc_ch_0
2019.11.12.14:34:53 Info: add_connection util_adc_wfifo.dout_1 util_adc_pack.adc_ch_1
2019.11.12.14:34:53 Info: add_connection util_adc_wfifo.dout_2 util_adc_pack.adc_ch_2
2019.11.12.14:34:53 Info: add_connection util_adc_wfifo.dout_3 util_adc_pack.adc_ch_3
2019.11.12.14:34:53 Info: add_connection util_adc_pack.if_fifo_wr_overflow util_adc_wfifo.if_dout_ovf
2019.11.12.14:34:53 Info: add_instance util_dac_upack util_upack2
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_upack NUM_OF_CHANNELS 4
2019.11.12.14:34:53 Info: set_instance_parameter_value util_dac_upack SAMPLE_DATA_WIDTH 16
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk util_dac_upack.clk
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk_reset util_dac_upack.reset
2019.11.12.14:34:53 Info: add_connection util_dac_upack.dac_ch_0 util_dac_rfifo.din_0
2019.11.12.14:34:53 Info: add_connection util_dac_upack.dac_ch_1 util_dac_rfifo.din_1
2019.11.12.14:34:53 Info: add_connection util_dac_upack.dac_ch_2 util_dac_rfifo.din_2
2019.11.12.14:34:53 Info: add_connection util_dac_upack.dac_ch_3 util_dac_rfifo.din_3
2019.11.12.14:34:53 Info: add_connection util_dac_upack.if_fifo_rd_underflow util_dac_rfifo.if_din_unf
2019.11.12.14:34:53 Info: add_instance axi_adc_dma axi_dmac
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma ID 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_DATA_WIDTH_SRC 64
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_DATA_WIDTH_DEST 128
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_LENGTH_WIDTH 24
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_2D_TRANSFER 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma AXI_SLICE_DEST 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma AXI_SLICE_SRC 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma SYNC_TRANSFER_START 1
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma CYCLIC 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_TYPE_DEST 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma DMA_TYPE_SRC 2
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_adc_dma FIFO_SIZE 4
2019.11.12.14:34:53 Info: add_connection sys_clk.clk axi_adc_dma.s_axi_clock
2019.11.12.14:34:53 Info: add_connection sys_clk.clk_reset axi_adc_dma.s_axi_reset
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk axi_adc_dma.m_dest_axi_clock
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk_reset axi_adc_dma.m_dest_axi_reset
2019.11.12.14:34:53 Info: add_connection sys_dma_clk.clk axi_adc_dma.if_fifo_wr_clk
2019.11.12.14:34:53 Info: add_connection util_adc_pack.if_packed_fifo_wr_en axi_adc_dma.if_fifo_wr_en
2019.11.12.14:34:53 Info: add_connection util_adc_pack.if_packed_fifo_wr_sync axi_adc_dma.if_fifo_wr_sync
2019.11.12.14:34:53 Info: add_connection util_adc_pack.if_packed_fifo_wr_data axi_adc_dma.if_fifo_wr_din
2019.11.12.14:34:53 Info: add_connection axi_adc_dma.if_fifo_wr_overflow util_adc_pack.if_packed_fifo_wr_overflow
2019.11.12.14:34:53 Info: add_instance axi_dac_dma axi_dmac
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma ID 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma DMA_DATA_WIDTH_SRC 64
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma DMA_DATA_WIDTH_DEST 64
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma DMA_LENGTH_WIDTH 24
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma DMA_2D_TRANSFER 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma AXI_SLICE_DEST 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma AXI_SLICE_SRC 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma SYNC_TRANSFER_START 0
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma CYCLIC 1
2019.11.12.14:34:53 Info: set_instance_parameter_value axi_dac_dma DMA_TYPE_DEST 1
2019.11.12.14:34:54 Info: set_instance_parameter_value axi_dac_dma DMA_TYPE_SRC 0
2019.11.12.14:34:54 Info: set_instance_parameter_value axi_dac_dma FIFO_SIZE 4
2019.11.12.14:34:54 Info: add_connection sys_clk.clk axi_dac_dma.s_axi_clock
2019.11.12.14:34:54 Info: add_connection sys_clk.clk_reset axi_dac_dma.s_axi_reset
2019.11.12.14:34:54 Info: add_connection sys_dma_clk.clk axi_dac_dma.m_src_axi_clock
2019.11.12.14:34:54 Info: add_connection sys_dma_clk.clk_reset axi_dac_dma.m_src_axi_reset
2019.11.12.14:34:54 Info: add_connection sys_dma_clk.clk axi_dac_dma.if_m_axis_aclk
2019.11.12.14:34:54 Info: add_connection axi_dac_dma.m_axis util_dac_upack.s_axis
2019.11.12.14:34:54 Error: add_connection axi_dac_dma.m_axis util_dac_upack.s_axis: No interface named axi_dac_dma.m_axis.
2019.11.12.14:34:54 Info: add_connection sys_hps.f2h_irq0 axi_adc_dma.interrupt_sender
2019.11.12.14:34:54 Info: set_connection_parameter_value sys_hps.f2h_irq0/axi_adc_dma.interrupt_sender irqNumber 2
2019.11.12.14:34:54 Info: add_connection sys_hps.f2h_irq0 axi_dac_dma.interrupt_sender
2019.11.12.14:34:54 Info: set_connection_parameter_value sys_hps.f2h_irq0/axi_dac_dma.interrupt_sender irqNumber 3
2019.11.12.14:34:54 Info: add_connection sys_hps.h2f_lw_axi_master axi_ad9361.s_axi
2019.11.12.14:34:54 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/axi_ad9361.s_axi baseAddress 0x00120000
2019.11.12.14:34:54 Info: add_connection sys_hps.h2f_lw_axi_master axi_adc_dma.s_axi
2019.11.12.14:34:54 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/axi_adc_dma.s_axi baseAddress 0x00100000
2019.11.12.14:34:54 Info: add_connection sys_hps.h2f_lw_axi_master axi_dac_dma.s_axi
2019.11.12.14:34:54 Info: set_connection_parameter_value sys_hps.h2f_lw_axi_master/axi_dac_dma.s_axi baseAddress 0x00104000
2019.11.12.14:34:54 Info: set_instance_parameter_value sys_hps F2SDRAM_Width 64 128 64
2019.11.12.14:34:57 Info: add_connection axi_adc_dma.m_dest_axi sys_hps.f2h_sdram1_data
2019.11.12.14:34:57 Info: set_connection_parameter_value axi_adc_dma.m_dest_axi/sys_hps.f2h_sdram1_data baseAddress 0x0000
2019.11.12.14:34:57 Info: add_connection axi_dac_dma.m_src_axi sys_hps.f2h_sdram2_data
2019.11.12.14:34:57 Info: set_connection_parameter_value axi_dac_dma.m_src_axi/sys_hps.f2h_sdram2_data baseAddress 0x0000
2019.11.12.14:34:57 Info: set_interconnect_requirement $system qsys_mm.clockCrossingAdapter AUTO
2019.11.12.14:34:57 Info: set_interconnect_requirement $system qsys_mm.burstAdapterImplementation PER_BURST_TYPE_CONVERTER
2019.11.12.14:34:57 Info: set_interconnect_requirement $system qsys_mm.maxAdditionalLatency 4
2019.11.12.14:34:57 Info: save_system system_bd.qsys
Info: *******************************************************************
Info: Running Quartus Prime Shell
    Info: Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition
    Info: Copyright (C) 2019  Intel Corporation. All rights reserved.
    Info: Your use of Intel Corporation's design tools, logic functions
    Info: and other software and tools, and any partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Intel Program License
    Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
    Info: the Intel FPGA IP License Agreement, or other applicable license
    Info: agreement, including, without limitation, that your use is for
    Info: the sole purpose of programming logic devices manufactured by
    Info: Intel and sold by Intel or its authorized distributors.  Please
    Info: refer to the applicable agreement for further details, at
    Info: https://fpgasoftware.intel.com/eula.
    Info: Processing started: Tue Nov 12 14:31:51 2019
Info: Command: quartus_sh --64bit -t system_project.tcl
Critical Warning: quartus version mismatch; expected 18.1.0, got 19.1.0.
ERROR: Device family can not be determined
ERROR: The minimum delay difference between CK and DQS must be less than or equal to the maximum delay difference between CK and DQS
child process exited abnormally
    while executing
"exec -ignorestderr $quartus(quartus_rootpath)/sopc_builder/bin/qsys-script  --script=system_qsys_script.tcl"
    (procedure "adi_project" line 98)
    invoked from within
"adi_project arradio_c5soc"
    (file "system_project.tcl" line 5)
Error (23031): Evaluation of Tcl script system_project.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 1 error, 0 warnings
    Error: Peak virtual memory: 808 megabytes
    Error: Processing ended: Tue Nov 12 14:34:58 2019
    Error: Elapsed time: 00:03:07
    Error: Total CPU time (on all processors): 00:03:50
But on Win 7 it's work perfectly.
Thanks!
