I'm trying to configure I2C for a custom platform with an FMCOMMS5, but am not getting any signals on either SDA or SCL when I connect them up to an oscilloscope.
I have the following constraints set:
# IIC set_property -dict {PACKAGE_PIN AA11 IOSTANDARD LVCMOS25 PULLTYPE PULLUP} [get_ports iic_scl] set_property -dict {PACKAGE_PIN AA12 IOSTANDARD LVCMOS25 PULLTYPE PULLUP} [get_ports iic_sda]
And the following in my .tcl file:
... create_bd_intf_port -mode Master -vlnv xilinx.com:interface:iic_rtl:1.0 iic_main ... ad_ip_instance axi_iic axi_iic_main ... ad_connect iic_main axi_iic_main/iic ... ad_connect sys_concat_intc/In14 axi_iic_main/iic2intc_irpt ... ad_cpu_interconnect 0x41600000 axi_iic_main
My system_top.v:
module system_top ( ... inout iic_scl, inout iic_sda, ... ); ... system_wrapper i_system_wrapper ( ... .iic_main_scl_io (iic_scl), .iic_main_sda_io (iic_sda), ... ); endmodule
Finally, my device tree:
amba_pl { #address-cells = <0x1>; #size-cells = <0x1>; compatible = "simple-bus"; ranges; ... i2c@41600000 { #address-cells = <0x1>; #size-cells = <0x0>; clock-names = "s_axi_aclk"; clocks = <0x1 0xf>; compatible = "xlnx,xps-iic-2.00.a"; interrupt-names = "iic2intc_irpt"; interrupt-parent = <0x4>; interrupts = <0x0 0x21 0x4>; reg = <0x41600000 0x10000>; eeprom@50 { compatible = "at24,24c02"; reg = <0x50>; }; }; };
Am I missing a setting somewhere for running I2C on any two arbitrary pins? I've already checked for any conflicts in the constraints and those pins are free.
