Square wave output using fmcdaq2
The user wanted to output a 1 kHz square wave from the AD9144 DAC on the FMCDAQ2 board. The solution involved modifying the HDL to add a square wave generator using the `dac_dds_phase_0_0` signal and setting the `dac_data_sel_s` to `4'h3` to select the square wave output. The user also needed to ensure the JESD link was properly configured and the DDS frequency was set correctly. Oscillations in the square wave output were resolved by further adjustments to the HDL and ensuring the DAC's output filters were appropriate for the low-frequency square wave.
Dear EngineerZone community
Please support.
I am currently creating a communication system.
The concept is to generate an information signal with vc707 and output it as a Square wave from the DAC (ad 9144) of fmcdaq2. Then, the output Square wave is input to the modulator and communication is carried out.
Before that, I am trying to output a Square wave of 1 kHz (offset 0V) from DAC (AD9144) of fmcdaq2.
How can I do it?
Can you create a design as per the user guide and store a Square wave in the buffer?
I can use both Linux / no-OS.
Yuta
    I'm confused, ad9144 is a high speed dac (1GSPS), why do you want it to output a squarewave of 1KHz?
    The daq2 board has some filters on the output, you will have to change those to be able to transmit a sqare wave.
    Take a look at https://ez.analog.com/fpga/f/q-a/81027/daq2-kcu105-send-data-to-dac
    Are you familiar with our RF designs? If not, it may be of interest to you.
    www.analog.com/en/products/adrv9008-2.html
    www.analog.com/.../ad9361.html
    wiki.analog.com/.../adrv936x_rfsom
    Andrei
  • Thank you,Andrei
    I am sorry for confusing you.I wanted to generate a square wave of 1 kHz because the modulator used operates by inputting a square wave of about 1 kHz to 2 kHz.
    However, since the ADC/DAC I have is fmcdaq2, I would like to know haw to output a 1 kHz Square wave using fmcdaq2.
    I'm sorry. I looked at https://ez.analog.com/fpga/f/q-a/81027/daq2-kcu105-send-data-to-dac and I saw the URL and could understand changing the filter of fmcdaq2, but I could not understand which part to change specifically.
    Please tell me.
    Yuta
  • You have 2 options:
    Add code in hdl to generate a square wave, you can use, change directly the dds.
    Replace the sine_lut from no-Os with your own square wave.
    https://github.com/analogdevicesinc/no-OS/blob/master/common_drivers/dac_buffer/dac_buffer.c
    Andrei
  • Thanks for the reply, Andrei.
    Sorry for the late reply.
     * @file dac_buffer.c
     * @brief Implementation of DAC LUT driver.
     * @author Istvan Csomortani (istvan.csomortani@analog.com)
     * Copyright 2014-2016(c) Analog Devices, Inc.
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions are met:
     * - Redistributions of source code must retain the above copyright
     * notice, this list of conditions and the following disclaimer.
     * - Redistributions in binary form must reproduce the above copyright
     * notice, this list of conditions and the following disclaimer in
     * the documentation and/or other materials provided with the
     * distribution.
     * - Neither the name of Analog Devices, Inc. nor the names of its
     * contributors may be used to endorse or promote products derived
     * from this software without specific prior written permission.
     * - The use of this software may or may not infringe the patent rights
     * of one or more patent holders. This license does not release you
     * from the requirement that you obtain separate licenses from these
     * patent holders to use this software.
     * - Use of the software either in source or binary form, must be run
     * on or directly connected to an Analog Devices Inc. component.
     * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
     * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
     * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
     * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
     * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
     * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
     * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
     * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "dac_buffer.h"
    /******************************* Constant definitions *************************/
    /* Sine Look Up Table */
    static const uint16_t sine_lut[1024] = {
    	0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
    		0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x7FFF,
    		0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,
    		0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF,0x7FFF};
    /************************ Functions Definitions *******************************/
    uint32_t dac_buffer_load(dac_core core, uint32_t start_address) {
    	uint32_t no_of_samples;
    	uint32_t index_i, index_q;
    	uint32_t index_mem = 0;
    	no_of_samples = sizeof(sine_lut) / sizeof(typeof(sine_lut[0]));
    	for (index_i = 0; index_i < no_of_samples; index_i++) {
    		 /* Phase shifted by 90 degree */
    		index_q = (index_i + 256) % no_of_samples;
    		switch (core.no_of_channels) {
    			case 1:
    				ad_reg_write_16(start_address + index_mem * 2, sine_lut[index_i]);
    				index_mem += 1;
    				break;
    			case 2:
    				ad_reg_write_16(start_address + (index_mem + 0) * 2, sine_lut[index_i]);
    				ad_reg_write_16(start_address + (index_mem + 1) * 2, sine_lut[index_q]);
    				index_mem += 2;
    				break;
    			case 4:
    				ad_reg_write_16(start_address + (index_mem + 2) * 2, sine_lut[index_i]);
    				ad_reg_write_16(start_address + (index_mem + 3) * 2, sine_lut[index_q]);
    				index_mem += 4;
    				break;
    			default:
    				ad_printf("Unsupported mode.\n\r");
    				return -1;
    	ad_dcache_flush();
    	return (core.no_of_channels * no_of_samples);
    I replaced sine_lut of no-Os with its own square wave as shown in attached dac_buffer.c.
    However, as a result of executing with SDK, Sin waveform was output.
    The run console display is as follows.
    Available sampling rates:
    1 - ADC 1000 MSPS; DAC 1000 MSPS
    2 - ADC 500 MSPS; DAC 1000 MSPS
    3 - ADC 500 MSPS; DAC 500 MSPS
    4 - ADC 600 MSPS; DAC 600 MSPS
    choose an option [default 1]:
    3
    ad9144_setup : Device descriptor failed!
    CPLL ENABLE
    CPLL ENABLE
    Tx link is enabled
    Measured Link Clock: 125 MHz
    Link status: DATA
    SYSREF captured: Yes
    Rx link is enabled
    Link status: DATA
    adc_setup adc core initialized (500 MHz).
    dac_setup dac core initialized (500 MHz).
    daq2: setup and configuration is done
    daq2: RX capture done.
    How can I output square wave? Please tell me.
    Yuta
  • Hi, Andrei
    After commenting out #define DMA_BUFFER 0 of L70 in fmcdaq2.c, I changed #if DMA_BUFFER in L640 to #define DMA_BUFFER and commented out from #else in L618 to #endif in L624.
    After that, I ran make with no-OS/fmcdaq2/vc 707, and as a result of running with SDK, it was displayed on the console as follows.
    How can I solve it? please teach me.
    4
    CPLL ENABLE
    xcvr_setup ERROR: XCVR initialization failed!
    CPLL ENABLE
    Tx link is disabled
    Measured Link Clock: off
    External reset is deasserted
    Rx link is disabled
    adc_setup adc core Status errors.
    dac_setup DAC Core Status errors.
  • That is a strange result.
    Correction, don't uncomment anything out, just change 0 to 1
    https://github.com/analogdevicesinc/no-OS/blob/master/fmcdaq2/fmcdaq2.c#L70
    Andrei
  • I just changed 0 to 1 of https://github.com/analogdevicesinc/no-OS/blob/master/fmcdaq2/fmcdaq2.c#L70.
    After that, I ran make with no-OS/fmcdaq2/vc 707, and as a result of running with SDK, it was displayed on the console as follows. The same error occurred
    1
    Tx link is disabled
    Rx link is disabled
    Also, CDT Build Console is as shown below.Are these errors caused?
    18:15:33 **** Incremental Build of configuration Debug for project sw ****
    make all
    'Building file: ../src/ad9144.c'
    'Invoking: MicroBlaze gcc compiler'
    mb-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/ad9144.o" -I../../bsp/sys_mb/include -mlittle-endian -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v10.0 -mno-xl-soft-mul -mxl-multiply-high -Wl,--no-relax -ffunction-sections -fdata-sections -MMD -MP -MF"src/ad9144.d" -MT"src/ad9144.o" -o "src/ad9144.o" "../src/ad9144.c"
    In file included from ../src/platform_drivers.h:47:0,
    from ../src/ad9144.c:46:
    ../src/config.h:70:9: error: expected declaration specifiers or '...' before string constant
    printf("\nWARNING no vendor defined in config.h (for carrier)\n");
    ../src/config.h:74:9: error: expected declaration specifiers or '...' before string constant
    printf("\nWARNING CPU arch defined in config.h\n");
    In file included from ../src/ad9144.c:46:0:
    ../src/ad9144.c: In function 'ad9144_spi_check_status':
    ../src/platform_drivers.h:111:23: warning: implicit declaration of function 'usleep' [-Wimplicit-function-declaration]
    #define mdelay(msecs) usleep(1000*msecs)
    ../src/ad9144.c:134:4: note: in expansion of macro 'mdelay'
    mdelay(1);
    ../src/ad9144.c: In function 'ad9144_short_pattern_test':
    ../src/ad9144.c:528:50: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t {aka long unsigned int}' [-Wformat=]
    printf("%s : short-pattern-test mismatch (0x%x, 0x%x 0x%x, 0x%x)!.\n",
    ../src/ad9144.c:528:56: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'uint32_t {aka long unsigned int}' [-Wformat=]
    ../src/ad9144.c:528:61: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'uint32_t {aka const long unsigned int}' [-Wformat=]
    make: *** [src/ad9144.o] error 1
    18:15:38 Build Finished (took 4s.496ms)
    What other changes have you made to the code?
    I see:
    https://github.com/analogdevicesinc/no-OS/blob/master/fmcdaq2/config.h#L69
    The in the make flow the XILINX, ZYNQ... are predefined https://github.com/analogdevicesinc/no-OS/blob/master/scripts/zynq.mk#L39
    There is something wrong with your build.
    See: https://wiki.analog.com/resources/fpga/quick_validation
    Andrei
  • Try not to use DEBUG, there will be conflicts with some xilinx files.
    Andrei
