Hardware: AD-PQMON-SL
Goal:
Pass the Epoch timestamp from no-OS to Windows OS
Expected Result on Windows OS:
waveform[0]: -16634
waveform[1]: 5558
waveform[2]: 417
waveform[3]: 0
Error Result on Windows OS:
waveform[0]: -8
waveform[1]: -13
waveform[2]: -3
waveform[3]: -5
Error Video:
Troubleshooting step that has taken:
Asked GitHub Copilot where to insert my code in no-OS, same file and same line.
Code Snippet on no-OS:
no-OS/projects/eval-pqmon/src/common/pqlib_afe.c at dev/pqmon-zephyr-ptp · analogdevicesinc/no-OS
status = afe_read_waveform(
(uint16_t *)&(pqlibExample.inputWaveform.waveform),
ADI_PQLIB_WAVEFORM_BLOCK_SIZE
* ADI_PQLIB_TOTAL_WAVEFORM_CHANNELS);
// Testing
ADI_PQLIB_TIME waveform_start_epoch_time;
waveform_start_epoch_time = 1791365660422;
// Split the timestamp and store in the first 4 positions of the waveform array,
pqlibExample.inputWaveform.waveform[0] = (int16_t)(waveform_start_epoch_time & 0xFFFF);
pqlibExample.inputWaveform.waveform[1] = (int16_t)((waveform_start_epoch_time >> 16) & 0xFFFF);
pqlibExample.inputWaveform.waveform[2] = (int16_t)((waveform_start_epoch_time >> 32) & 0xFFFF);
pqlibExample.inputWaveform.waveform[3] = (int16_t)((waveform_start_epoch_time >> 48) & 0xFFFF);
// Result
printf("waveform[0]: %"PRId16"\n", pqlibExample.inputWaveform.waveform[0]);
printf("waveform[1]: %"PRId16"\n", pqlibExample.inputWaveform.waveform[1]);
printf("waveform[2]: %"PRId16"\n", pqlibExample.inputWaveform.waveform[2]);
printf("waveform[3]: %"PRId16"\n", pqlibExample.inputWaveform.waveform[3]);
pWaveform->isDataProcessed = 0;
pWaveform->sequenceNumber++;
Full Code on Windows OS:
#include <stdio.h>
#include <stdlib.h>
#include <inttypes.h>
#include "include/iio.h"
int main() {
// Step 1: Create a context from the serial port
struct iio_context* ctx = iio_create_context_from_uri("serial:COM4,115200,8n1");
const struct iio_device* dev = iio_context_get_device(ctx, 0);
// Step 2 Set process_data = 0
iio_device_attr_write_double(dev, "process_data", 0);
// Step 3 Enable all channels
for (unsigned int chn_index = 0; chn_index < iio_device_get_channels_count(dev); chn_index++) {
struct iio_channel* chn_enabled = iio_device_get_channel(dev, chn_index);
if (iio_channel_is_output(chn_enabled) == 0) {
iio_channel_enable(chn_enabled);
// Step 4 Set waveform_capture_mode = continuous
iio_device_attr_write(dev, "waveform_capture_mode", "continuous");
// Step 5 Create a buffer to read data from the device
struct iio_buffer* buffer = iio_device_create_buffer(dev, 256, false);
iio_buffer_refill(buffer);
int16_t* waveform = (int16_t*)iio_buffer_start(buffer);
// Step 6 Result
printf("waveform[0]: %"PRId16"\n", waveform[0]);
printf("waveform[1]: %"PRId16"\n", waveform[1]);
printf("waveform[2]: %"PRId16"\n", waveform[2]);
printf("waveform[3]: %"PRId16"\n", waveform[3]);
// Step 7 Clean up
iio_buffer_destroy(buffer);
iio_context_destroy(ctx);
Edit Notes
Update data type of[edited by: YongLawrence at 12:22 AM (GMT -4) on 9 Oct 2026]
