Exact connection topology for measuring voltage on 3-phase Delta AC circuit
Product Number: ADE7933
     The normal ADE7933 device-datasheet 3-φ Delta 3-wire circuit illustration (figure 113) is too abstract to show the actual voltage-divider and anti-aliasing networks in detail:
      I have been assuming a topology that incorporates “some” elements of app-note AN-1333,  particularly with regard to the R-dividers and capacitors.   However, AN-1333 is really oriented to a 4-conductor system, not specifically a 3-φ delta system.
     For the 2 instances of ADE7933 in my 3-wire 3-phase Delta circuit,  I so far have mimicked this part of AN-1333, applied individually to both the V1P pin and to the VM pin.    The question has come up, should I use this topology?  Or should I make V1P and VM as a true differential input, with the R/C load circuit placed (differentially & groundlessly) across V1P / VM,  rather than bypassing each V1P and VM individually to the ADE7933’s ISO_GND?
For my part I did some simulation, and I *think* we need to bypass each of the V1P and VM pins to the respective-IC’s ISO_GND, to avoid overloading the ADC’s.
Advice will be greatly appreciated!
  • From the datasheet ADE7978/ADE7933/ADE7932/ADE7923 (Rev. D)
    Here are the connections for a 3 wire Delta configuration
    Dave
  • Hello Dave, Thank you for the response.      To continue the discussion and sanity-check my hoookup;
    - Our application is not measuring Currents at all, so we don't have shunt resistors, nor are we very much familiar with them as shown in Analog's documents.   We have a circuit board in planning that is just going to measure all 3 phases of AC voltage levels,  from a 3-wire-only hookup.
    - With regard to the "3-wire-only" delta AC circuit.    Right now my basic hookup is like shown here.   The Phase A and Phase C lines are resistor-divided to feed the respective ADE7933 V1P pins.  I didn't feel comfortable taking the  "B phase" line(s) straight to the respective [bypassed] ADE7933 VM pins, so I have resistor divider networks as shown.    Provided I work out the resistive-division simulation math, is this topology acceptable?   If not, could you mark-up with a recommendation?
    Chris
  • This is the recommended connection to measure 3 phase delta. Phase b goes to each voltage divider. The iso ground for each ADE7933 is connected to Phase A and Phase C.
    What you have will work so you can decide which to use. I don't see an issue with your method.
    Dave
  • Hello Dave,     thank you for your prompt replies.    I think we'll stick with our topology, and if we would find an advantage to changing some of our 330kOhm cascades to 0 Ohms instead, we could still do that with our same planned copper.
    Chris
