I made a custom PCB with following the datasheet reference diagram.
I have tested PCB with connected AC Neutral to DGND
DGND to AGND for a common ground reference.
Also removed the 1K (R14) resistor to feed neutral directly to the Metering IC.
On the IC Pins I checked the voltage level,
Since testing with single phase AC on VAP for now.
At 240VAC, on the IC pin 16 VAP i got 0.240V AC (Checked with multimeter from the Neutral and DGND)
Getting random voltage reading from IC, it reading random values even when no AC input.04:08:44.097 -> ADE debug registers:04:08:44.129 -> VERSION: 0x204:08:44.129 -> OPMODE : 0x404:08:44.161 -> STATUS : 0xC0E0004:08:44.161 -> RSTATUS: 0xC0E0004:08:44.193 -> AIRMS : 68104:08:44.193 -> BIRMS : 5D104:08:44.226 -> CIRMS : 10F804:08:44.226 -> AVRMS : 17CBD904:08:44.259 -> BVRMS : 188CEE04:08:44.259 -> CVRMS : F3B7904:08:44.291 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug04:08:52.771 -> VOLTAGE RMS readings for each phase:04:08:53.702 -> 180.7304:08:54.602 -> 193.0604:08:55.533 -> 110.7404:08:55.533 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug04:09:16.945 -> VOLTAGE RMS readings for each phase:04:09:17.862 -> 181.2304:09:18.822 -> 170.6004:09:19.707 -> 110.1104:09:19.707 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug04:09:21.014 -> VOLTAGE RMS readings for each phase:04:09:21.952 -> 182.6404:09:22.865 -> 189.4404:09:23.770 -> 108.6904:09:23.770 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug04:09:24.064 -> VOLTAGE RMS readings for each phase:04:09:24.971 -> 185.5504:09:25.924 -> 166.7504:09:26.829 -> 108.3704:09:26.829 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug04:09:27.939 -> VOLTAGE RMS readings for each phase:04:09:28.890 -> 185.7304:09:29.769 -> 188.5604:09:30.717 -> 109.9604:09:30.717 -> Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug
Here is the code I'm testing with
#include "Arduino.h"#include <SPI.h>#include "ADE7758Lib.h"char inputChar = 0;bool rx = false;ADE7758 myADE(&SPI,5);void runSPITest() { const int samples = 50; uint8_t version0 = myADE.read8bits(VERSION); uint8_t opmode0 = myADE.read8bits(OPMODE); int versionMismatch = 0; int opmodeMismatch = 0; for (int i = 0; i < samples; i++) { if (myADE.read8bits(VERSION) != version0) { versionMismatch++; } if (myADE.read8bits(OPMODE) != opmode0) { opmodeMismatch++; } (void)myADE.read8bits(MMODE); delay(1); } uint8_t mmodeOriginal = myADE.read8bits(MMODE); uint8_t mmodeTest = (uint8_t)(mmodeOriginal ^ 0x01); myADE.write8bits(MMODE, mmodeTest); delay(2); uint8_t mmodeReadback = myADE.read8bits(MMODE); myADE.write8bits(MMODE, mmodeOriginal); delay(2); uint8_t mmodeRestored = myADE.read8bits(MMODE); Serial.println("SPI self-test:"); Serial.print("VERSION fixed: 0x"); Serial.print(version0, HEX); Serial.print(" mismatches="); Serial.println(versionMismatch); Serial.print("OPMODE fixed: 0x"); Serial.print(opmode0, HEX); Serial.print(" mismatches="); Serial.println(opmodeMismatch); Serial.print("MMODE write/read: wrote 0x"); Serial.print(mmodeTest, HEX); Serial.print(" read 0x"); Serial.println(mmodeReadback, HEX); Serial.print("MMODE restore : 0x"); Serial.println(mmodeRestored, HEX); bool pass = (versionMismatch == 0) && (opmodeMismatch == 0) && (mmodeReadback == mmodeTest) && (mmodeRestored == mmodeOriginal); Serial.println(pass ? "SPI RESULT: PASS" : "SPI RESULT: FAIL");}void setup(){ Serial.begin(9600); SPI.begin(); myADE.begin(); Serial.println("ADE7758 begins operating"); Serial.println("Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug, s=spi-test"); delay(1000);}void loop(){ if (Serial.available() > 0) { inputChar = (char)Serial.read(); if (inputChar != '\r' && inputChar != '\n' && inputChar != ' ') { rx = true; } } if (rx) { switch(inputChar){ case 'a': Serial.println("ENERGY readings for each phase:"); Serial.println(myADE.getWattHR(PHASE_A), HEX); Serial.println(myADE.getWattHR(PHASE_B), HEX); Serial.println(myADE.getWattHR(PHASE_C), HEX); break; case 'b': Serial.println("CURRENT RMS readings for each phase:"); Serial.println(myADE.IRMS(PHASE_A), HEX); Serial.println(myADE.IRMS(PHASE_B), HEX); Serial.println(myADE.IRMS(PHASE_C), HEX); break; case 'c': Serial.println("VOLTAGE RMS readings for each phase:"); Serial.println((float)myADE.VRMS(PHASE_A) * 0.000159024, 2); Serial.println((float)myADE.VRMS(PHASE_B) * 0.000159024, 2); Serial.println((float)myADE.VRMS(PHASE_C) * 0.000159024, 2); // Serial.println(myADE.VRMS(PHASE_B), HEX); // Serial.println(myADE.VRMS(PHASE_C), HEX); break; case 'd': Serial.println("Complex Energy readings for each phase:"); Serial.println(myADE.getVAHR(PHASE_A), HEX); Serial.println(myADE.getVAHR(PHASE_B), HEX); Serial.println(myADE.getVAHR(PHASE_C), HEX); break; case 'v': Serial.println("ADE debug registers:"); Serial.print("VERSION: 0x"); Serial.println(myADE.read8bits(VERSION), HEX); Serial.print("OPMODE : 0x"); Serial.println(myADE.read8bits(OPMODE), HEX); Serial.print("STATUS : 0x"); Serial.println(myADE.getInterruptStatus(), HEX); Serial.print("RSTATUS: 0x"); Serial.println(myADE.getResetInterruptStatus(), HEX); Serial.print("AIRMS : "); Serial.println(myADE.getIRMS(PHASE_A), HEX); Serial.print("BIRMS : "); Serial.println(myADE.getIRMS(PHASE_B), HEX); Serial.print("CIRMS : "); Serial.println(myADE.getIRMS(PHASE_C), HEX); Serial.print("AVRMS : "); Serial.println(myADE.getVRMS(PHASE_A), HEX); Serial.print("BVRMS : "); Serial.println(myADE.getVRMS(PHASE_B), HEX); Serial.print("CVRMS : "); Serial.println(myADE.getVRMS(PHASE_C), HEX); break; case 's': runSPITest(); break; default: Serial.println("unknown command"); } rx = false; Serial.println("Send command: a=Wh, b=Irms, c=Vrms, d=VAh, v=debug, s=spi-test"); }}
//ADE7758Lib.h
#ifndef _ADE7758LIB_h#define _ADE7758LIB_h#include <SPI.h>#define AWATTHR 0x01#define BWATTHR 0x02#define CWATTHR 0x03#define AVARHR 0x04#define BVARHR 0x05#define CVARHR 0x06#define AVAHR 0x07#define BVAHR 0x08#define CVAHR 0x09#define AIRMS 0x0A#define BIRMS 0x0B#define CIRMS 0x0C#define AVRMS 0x0D#define BVRMS 0x0E#define CVRMS 0x0F#define FREQ 0x10#define TEMP 0x11#define WFORM 0x12#define OPMODE 0x13#define MMODE 0x14#define WAVMODE 0x15#define COMPMODE 0x16#define LCYCMODE 0x17#define MASK 0x18#define STATUS 0x19#define RSTATUS 0x1A#define ZXTOUT 0x1B#define LINECYC 0x1C#define SAGCYC 0x1D#define SAGLVL 0x1E#define VPINTLVL 0x1F#define IPINTLVL 0x20#define VPEAK 0x21#define IPEAK 0x22#define GAIN 0x23#define AVRMSGAIN 0x24#define BVRMSGAIN 0x25#define CVRMSGAIN 0x26#define AIGAIN 0x27#define BIGAIN 0x28#define CIGAIN 0x29#define AWG 0x2A#define BWG 0x2B#define CWG 0x2C#define AVARG 0x2D#define BVARG 0x2E#define CVARG 0x2F#define AVAG 0x30#define BVAG 0x31#define CVAG 0x32#define AVRMSOS 0x33#define BVRMSOS 0x34#define CVRMSOS 0x35#define AIRMSOS 0x36#define BIRMSOS 0x37#define CIRMSOS 0x38#define AWAITOS 0x39#define BWAITOS 0x3A#define CWAITOS 0x3B#define AVAROS 0x3C#define BVAROS 0x3D#define CVAROS 0x3E#define APHCAL 0x3F#define BPHCAL 0x40#define CPHCAL 0x41#define WDIV 0x42#define VADIV 0x44#define VARDIV 0x43#define APCFNUM 0x45#define APCFDEN 0x46#define VARCFNUM 0x47#define VARCFDEN 0x48#define CHKSUM 0x7E#define VERSION 0x7F#define REG_READ(reg) reg#define REG_WRITE(reg) (unsigned char)((reg) | 0x80)//PHASE_SEL#define PHASE_A 0#define PHASE_B 1#define PHASE_C 2//WAV_SEL#define CURRENT 0#define VOLTAGE 1#define ACT_PWR 2#define REACT_PWR 3#define APP_PWR 4//interrupt mask/status bit#define AEHF 0#define REHF 1#define VAEHF 2#define SAGA 3#define SAGB 4#define SAGC 5#define ZXTOA 6#define ZXTOB 7#define ZXTOC 8#define ZXA 9#define ZXB 10#define ZXC 11#define LENERGY 12#define RESET 13#define PKV 14#define PKI 15#define WFSM 16#define REVPAP 17#define REVPRP 18#define SEQERR 19#define WAVMODE_VALUE(phase, wave) (((wave)<<2)|(phase))class ADE7758{ public: ADE7758 (SPIClass *,int ); void begin(); int WattHR(char ); int VARHR(char ); int VAHR(char ); long VRMS(char ); long IRMS(char ); long waveform(char ,char ); int lineFreq(char ); void accumulateEnergy(); void powerOff(); void powerON(); void sleep(); void wakeUp(); long getInterruptStatus(void); long getResetInterruptStatus(void); void enableChip(); void disableChip(); void write8bits(char , unsigned char ); void write16bits(char , unsigned int ); unsigned char read8bits(char ); unsigned int read16bits(char ); unsigned long read24bits(char ); long getIRMS(char ); long getVRMS(char ); int getWattHR(char ); int getVARHR(char ); int getVAHR(char ); private: SPIClass *_ADE7758SPI; int _SSpin; long accuWattHRA; long accuWattHRB; long accuVARHRA; long accuVARHRB; long accuVAHRA; long accuVAHRB;};#endif
//ADE7758Lib.cpp
#include <Arduino.h>#include <SPI.h>#include "ADE7758Lib.h"#if !defined(MSBFIRST) && defined(SPI_MSBFIRST)#define MSBFIRST SPI_MSBFIRST#endifextern void isrGDO0event(void);SPISettings ADESETTINGS(125000, MSBFIRST, SPI_MODE1);//publicADE7758::ADE7758(SPIClass *ADESPI, int SSpin){ _ADE7758SPI=ADESPI; _SSpin=SSpin; digitalWrite(_SSpin, HIGH); //Ensure Chip select pin is output pinMode(_SSpin, OUTPUT); }void ADE7758::begin(){ // Allow device power-up to settle before first config write. delay(20); // Normal operating mode. write8bits(OPMODE, 0x04); delay(10); // Read reset/status once to clear startup latched flags. (void)getResetInterruptStatus(); (void)getInterruptStatus();}int ADE7758::getWattHR(char phase){ return read16bits(AWATTHR+phase);}int ADE7758::getVARHR(char phase){ return read16bits(AVARHR+phase);}int ADE7758::getVAHR(char phase){ return read16bits(AVAHR+phase);}long ADE7758::VRMS(char phase){ long volts = 0; int samples = 50; getVRMS(phase); // Dummy read to clear old data for(int i = 0; i < samples; i++) { volts += getVRMS(phase); delayMicroseconds(1000); // 1ms delay * 50 = 50ms averaging window } return volts / samples;}long ADE7758::IRMS(char phase){ char i=0; long current=0; getIRMS(phase);//Ignore first reading for(i=0;i<10;++i){ current+=getIRMS(phase); delayMicroseconds(50); } //average return current/10;}void ADE7758::accumulateEnergy(){ accuWattHRA += getWattHR(PHASE_A); accuWattHRB += getWattHR(PHASE_B); // Add Phase C if needed accuVAHRA += getVAHR(PHASE_A); accuVAHRB += getVAHR(PHASE_B);}long ADE7758::waveform(char phase,char source){}void ADE7758::powerOff(){}void ADE7758::powerON(){}void ADE7758::sleep(){}void ADE7758::wakeUp(){}long ADE7758::getInterruptStatus(void){ return read24bits(STATUS);}long ADE7758::getResetInterruptStatus(void){ return read24bits(RSTATUS);}int ADE7758::lineFreq(char phase){ uint8_t mmode; mmode = read8bits(MMODE); write8bits(MMODE,(mmode&0x11111100 )| phase); delay(10); return read16bits(FREQ);}//privatevoid ADE7758::enableChip(){ digitalWrite(_SSpin, LOW);}void ADE7758::disableChip(){ digitalWrite(_SSpin, HIGH);}void ADE7758::write8bits(char reg, unsigned char data){ _ADE7758SPI->beginTransaction(ADESETTINGS); enableChip(); delay(10); _ADE7758SPI->transfer(REG_WRITE(reg)); delay(2); _ADE7758SPI->transfer(data); delay(1); disableChip(); _ADE7758SPI->endTransaction();}void ADE7758::write16bits(char reg, unsigned int data){ _ADE7758SPI->beginTransaction(ADESETTINGS); enableChip(); delay(10); _ADE7758SPI->transfer(REG_WRITE(reg)); delay(2); _ADE7758SPI->transfer((unsigned char)((data>>8)&0xFF)); delay(2); _ADE7758SPI->transfer((unsigned char)(data&0xFF)); delay(1); disableChip(); _ADE7758SPI->endTransaction();}unsigned char ADE7758::read8bits(char reg){ _ADE7758SPI->beginTransaction(ADESETTINGS); enableChip(); unsigned char ret; delay(10); _ADE7758SPI->transfer(REG_READ(reg)); delay(2); ret=_ADE7758SPI->transfer(0x00); delay(1); disableChip(); _ADE7758SPI->endTransaction(); return ret;}unsigned int ADE7758::read16bits(char reg){ _ADE7758SPI->beginTransaction(ADESETTINGS); enableChip(); unsigned int ret=0; unsigned char ret0=0; delay(10); _ADE7758SPI->transfer(REG_READ(reg)); delay(2); ret=_ADE7758SPI->transfer(0x00); delay(2); ret0=_ADE7758SPI->transfer(0x00); delay(1); disableChip(); _ADE7758SPI->endTransaction(); ret= (ret<<8)|ret0; return ret;}unsigned long ADE7758::read24bits(char reg){ _ADE7758SPI->beginTransaction(ADESETTINGS); enableChip(); unsigned long ret=0; unsigned int ret1=0; unsigned char ret0=0; delay(10); _ADE7758SPI->transfer(REG_READ(reg)); delay(2); ret=_ADE7758SPI->transfer(0x00); delay(2); ret1=_ADE7758SPI->transfer(0x00); delay(2); ret0=_ADE7758SPI->transfer(0x00); delay(1); disableChip(); _ADE7758SPI->endTransaction(); ret= (ret<<16)|(ret1<<8)|ret0; return ret;}long ADE7758::getIRMS(char phase){ return read24bits(AIRMS+phase);}long ADE7758::getVRMS(char phase){ return read24bits(AVRMS+phase);}
