Fast RMS over one line Cycle
The user is experiencing inconsistent RMS current measurements using the ADE9000's fast RMS (RMSOne) register, which should update every half cycle. The support engineer suggests using the Vpeak method and synchronizing with the zero-cross (ZX) status bit or IRQ for more accurate results. The RMSONERDY bit indicates when new RMSOne values are ready, but these values can vary due to the random start point of the capture.
Category: Datasheet/Specs
Product Number: ADE9000
Hi!
I'm dealing with a load controlled by a PWM controller. Sometimes the output of the controller can go to very small values, conducting only one linecycle. I tried to measure the RMS values using two strategies, one with fast RMS and the other one with Vpeak. Vpeak works perfectly but it requires me to calculate the values on Firmare to get the RMS value
Just found it weird that fast RMS register (AIRMSONE - 0x219) gives me about 4ARMS. The wave has a peak of about 7,59Amps so I was hoping to get  5,3ARMS or similar.
Sometimes  I can get the right value if I time the measurements using the IRQ0 interrupt by masking the RMSONERDY bit . Still, the ADE9000 gives me wrong values as well like 3,0 - 2.04 -4.05 etc. It never outputs clean 5.36ARMS
Can I be doing something wrong?
Currently I set RMS_SRC_SEL to one on the CONFIG0 reg(0x060) and thats just it I just write 1 to RUN register and start reading.
If somehow I can get the right measurment will other parameters follow? Like THDI, PF, THDV etc. Checking the datasheet I got confused, not sure if those registers can be updated so fast as well.
