This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
The value of current is incorrect after current calibration.
The user is experiencing incorrect current readings on a new meter calibrated with an ADE7880 IC reference meter. The issue is that the new meter's calibration is load-dependent, showing accurate readings only within the load range used during calibration. The final answer suggests not duplicating the issue in different forum areas and requests a more specific response to the calibration problem.
Product Number: ADE7880
We have a reference meter that uses the ADE7880 IC to measure various power quality parameters. The reference meter’s gain (voltage and current) and phase (power factor) are calibrated using ADE7880 register values. It provides correct measurements under all load conditions.
Now, we calibrated a new meter using this reference meter. However, the problem is that when we calibrate the current at a low load (such as 1A or 2A), the new meter gives correct values only for low loads (1A to 3A). When the load goes above 10A, the new meter shows incorrect current values (e.g., 6A or 7A instead of the actual 10A).
Similarly, when we calibrate the new meter at a high load (10A or 12A), the readings are correct at higher loads. But when a low load is applied, the meter shows incorrect values (for example, it shows 3–4A when the actual load is only 1.5A).
We performed calibration of the new meter using the Gain registers of the ADE7880.
Please let us know how we can sort out this issue.
Thanks & Regards
Suman
Edit Notes
[locked by: jnaso at 5:56 PM (GMT -4) on 6 Oct 2025]
