Hello to everyone,
It seems that disabling the high-pass filter on all current and voltage channels (setting HPFDIS bit in CONFIG0 register) the ADE9153A should work with a DC source (400Vdc) and a shunt.
Datasheet does not specify any limitation RMS calculations if the input voltage and current are DC.
Can ADE9153A work in DC disabling the High-Pass Filter (1.25 Hz)?
Thank you
Luigi
