Reading Methods for Converting IRMSA_32 Register Raw Data to Real Measurements in Energy Meters
Category: Datasheet/Specs
Product Number: ADE7953
Hello ,
"I am currently working with the ADE7953 metering IC. I have reviewed the datasheet, but I have not found any guidance on how to convert the raw reading from the IRMSA_32 register into an actual value."  please hep me .
  • quick and dirty.
    supply test current         rms/lsb = test current / codes in rms register.
    This requires the test current to be accurate. More accurate than your accuracy requirement.
    I have attached some example code using arduino and a bluepill stm32f103. This code works thru calibration doc with known current and voltage.
    ade7953_bluepill_spi_cal_5_17p5_23.TXT
    Dave
    //Table	13	8-Bit	Registers	Address	Register	Name	//	R/W	Default	Type	Register	Description
    #define	SAGCYC		0x000	//	R/W	0x00	Unsigned	Sag	line	cycles
    #define	DISNOLOAD	0x001	//	R/W	0x00	Unsigned	No-load	detection	disable	(see	Table	16)
    #define	LCYCMODE	0x004	//	R/W	0x40	Unsigned	Line	cycle	accumulation	mode	configuration	(see	Table	17)
    #define	PGA_V		0x007	//	R/W	0x00	Unsigned	Voltage	channel	gain	configuration	(Bits[2:0])
    #define	PGA_IA		0x008	//	R/W	0x00	Unsigned	Current	Channel	A	gain	configuration	(Bits[2:0])
    #define	PGA_IB		0x009	//	R/W	0x00	Unsigned	Current	Channel	B	gain	configuration	(Bits[2:0])
    #define	WRITE_PROTECT	0x040	//	R/W	0x00	Unsigned	Write	protection	bits	(Bits[2:0])
    #define	LAST_OP		0x0FD	//	R	0x00	Unsigned	Contains	the	type	(read	or	write)	of	the	last	successful	communication	(0x35	=	read;	0xCA	=	write)
    #define	LAST_RWDATA	0x0FF	//	R	0x00	Unsigned	Contains	the	data	from	the	last	successful	8-bit	register	communication
    #define	Version	        0x702	//	R	N/A	Unsigned	Contains	the	silicon	version	number
    #define	EX_REF		0x800	//	R/W	0x00	Unsigned	Reference	input	configuration:	set	to	0	for	internal;set	to	1	for	external
    //Table	14	16-Bit	Registers	Address	Register	Name	//	R/W	Default	Type	Register	Description
    #define	ZXTOUT		0x100	//	R/W	0xFFFF	Unsigned	Zero-crossing	timeout
    #define	LINECYC		0x101	//	R/W	0x0000	Unsigned	Number	of	half	line	cycles	for	line	cycle	energy	accumulation	mode
    #define	CONFIG		0x102	//	R/W	0x8004	Unsigned	Configuration	register	(see	Table	18)
    #define	CF1DEN		0x103	//	R/W	0x003F	Unsigned	CF1	frequency	divider	denominator.	When	modifying	this	"register,two"	sequential	write	operations	must	be	performed	to	ensure	that	the	write	is	successful.
    #define	CF2DEN		0x104	//	R/W	0x003F	Unsigned	CF2	frequency	divider	denominator.	When	modifying	this	"register,two"	sequential	write	operations	must	be	performed	to	ensure	that	the	write	is	successful.
    #define	CFMODE		0x107	//	R/W	0x0300	Unsigned	CF	output	selection	(see	Table	19)
    #define	PHCALA		0x108	//	R/W	0x0000	Signed	Phase	calibration	register	(Current	Channel	A).	This	register	is	in	sign	magnitude	format.
    #define	PHCALB		0x109	//	R/W	0x0000	Signed	Phase	calibration	register	(Current	Channel	B).	This	register	is	in	sign	magnitude	format.
    #define	PFA		0x10A	//	R	0x0000	Signed	Power	factor	(Current	Channel	A)
    #define	PFB		0x10B	//	R	0x0000	Signed	Power	factor	(Current	Channel	B)
    #define	ANGLE_A		0x10C	//	R	0x0000	Signed	Angle	between	the	voltage	input	and	the	Current	Channel	A	input
    #define	ANGLE_B		0x10D	//	R	0x0000	Signed	Angle	between	the	voltage	input	and	the	Current	Channel	B	input
    #define	Period		0x10E	//	R	0x0000	Unsigned	Period	register
    #define	ALT_OUTPUT	0x110	//	R/W	0x0000	Unsigned	Alternative	output	functions	(see	Table	20)
    #define	LAST_ADD	0x1FE	//	R	0x0000	Unsigned	Contains	the	address	of	the	last	successful	communication
    #define	LAST_RWDATA	0x1FF	//	R	0x0000	Unsigned	Contains	the	data	from	the	last	successful	16-bit	register	communication
    #define	Reserved	0x120	//	R/W	0x0000	Unsigned	This	register	should	be	set	to	30h	to	meet	the	performance	specified	in	Table	1	To	modify	this	"register,"	it	must	be	unlocked	by	setting	Register	Address	0xFE	to	0xAD	immediately	prior.
    //24-Bit	32-Bit	Registers	","	r/w	","	default	","	description
    #define	SAGLVL_24	0x200
    #define	SAGLVL_32	0x300	//R/W	0x000000	Unsigned	Sag	voltage	level
    #define	ACCMODE_24	0x201
    #define	ACCMODE_32	0x301	//R/W	0x000000	Unsigned	Accumulation	mode	(see	Table	21)
    #define	AP_NOLOAD_24	0x203
    #define	AP_NOLOAD_32	0x303	//R/W	0x00E419	Unsigned	Active	power	no-load	level
    #define	VAR_NOLOAD_24	0x204
    #define	VAR_NOLOAD_32	0x304	//R/W	0x00E419	Unsigned	Reactive	power	no-load	level
    #define	VA_NOLOAD_24	0x205
    #define	VA_NOLOAD_32	0x305	//R/W	0x000000	Unsigned	Apparent	power	no-load	level
    #define	AVA_24		0x210
    #define	AVA_32		0x310	//	R	0x000000	Signed	Instantaneous	apparent	power	(Current	Channel	A)
    #define	BVA_24		0x211
    #define	BVA_32		0x311	//	R	0x000000	Signed	Instantaneous	apparent	power	(Current	Channel	B)
    #define	AWATT_24	0x212
    #define	AWATT_32	0x312	//	R	0x000000	Signed	Instantaneous	active	power	(Current	Channel	A)
    #define	BWATT_24	0x213
    #define	BWATT_32	0x313	//	R	0x000000	Signed	Instantaneous	active	power	(Current	Channel	B)
    #define	AVAR_24		0x214
    #define	AVAR_32		0x314	//	R	0x000000	Signed	Instantaneous	reactive	power	(Current	Channel	A)
    #define	BVAR_24		0x215
    #define	BVAR_32		0x315	//	R	0x000000	Signed	Instantaneous	reactive	power	(Current	Channel	B)
    #define	IA_24		0x216
    #define	IA_32		0x316	//	R	0x000000	Signed	Instantaneous	current	(Current	Channel	A)
    #define	IB_24		0x217
    #define	IB_32		0x317	//	R	0x000000	Signed	Instantaneous	current	(Current	Channel	B)
    #define	V_24		0x218
    #define	V_32		0x318	//	R	0x000000	Signed	Instantaneous	voltage	(voltage	channel)
    #define	IRMSA_24	0x21A
    #define	IRMSA_32	0x31A	//	R	0x000000	Unsigned	IRMS	register	(Current	Channel	A)
    #define	IRMSB_24	0x21B
    #define	IRMSB_32	0x31B	//	R	0x000000	Unsigned	IRMS	register	(Current	Channel	B)
    #define	VRMS_24		0x21C
    #define	VRMS_32		0x31C	//	R	0x000000	Unsigned	VRMS	register
    #define	AENERGYA_24	0x21E
    #define	AENERGYA_32	0x31E	//	R	0x000000	Signed	Active	energy	(Current	Channel	A)
    #define	AENERGYB_24	0x21F
    #define	AENERGYB_32	0x31F	//	R	0x000000	Signed	Active	energy	(Current	Channel	B)
    #define	RENERGYA_24	0x220
    #define	RENERGYA_32	0x320	//	R	0x000000	Signed	Reactive	energy	(Current	Channel	A)
    #define	RENERGYB_24	0x221
    #define	RENERGYB_32	0x321	//	R	0x000000	Signed	Reactive	energy	(Current	Channel	B)
    #define	APENERGYA_24	0x222
    #define	APENERGYA_32	0x322	//	R	0x000000	Signed	Apparent	energy	(Current	Channel	A)
    #define	APENERGYB_24	0x223
    #define	APENERGYB_32	0x323	//	R	0x000000	Signed	Apparent	energy	(Current	Channel	B)
    #define	OVLVL_24	0x224
    #define	OVLVL_32	0x324	//	R/W	0xFFFFFF	Unsigned	Overvoltage	level
    #define	OILVL_24	0x225
    #define	OILVL_32	0x325	//	R/W	0xFFFFFF	Unsigned	Overcurrent	level
    #define	VPEAK_24	0x226
    #define	VPEAK_32	0x326	//	R	0x000000	Unsigned	Voltage	channel	peak
    #define	RSTVPEAK_24	0x227
    #define	RSTVPEAK_32	0x327	//	R	0x000000	Unsigned	Read	voltage	peak	with	reset
    #define	IAPEAK_24	0x228
    #define	IAPEAK_32	0x328	//	R	0x000000	Unsigned	Current	Channel	A	peak
    #define	RSTIAPEAK_24	0x229
    #define	RSTIAPEAK_32	0x329	//	R	0x000000	Unsigned	Read	Current	Channel	A	peak	with	reset
    #define	IBPEAK_24	0x22A
    #define	IBPEAK_32	0x32A	//	R	0x000000	Unsigned	Current	Channel	B	peak
    #define	RSTIBPEAK_24	0x22B
    #define	RSTIBPEAK_32	0x32B	//	R	0x000000	Unsigned	Read	Current	Channel	B	peak	with	reset
    #define	IRQENA_24	0x22C
    #define	IRQENA_32	0x32C	//	R/W	0x100000	Unsigned	Interrupt	enable	(Current	Channel	"A,"	see	Table	22)
    #define	IRQSTATA_24	0x22D
    #define	IRQSTATA_32	0x32D	//	R	0x000000	Unsigned	Interrupt	status	(Current	Channel	"A,"	see	Table	23)
    #define	RSTIRQSTATA_24	0x22E
    #define	RSTIRQSTATA_32	0x32E	//	R	0x000000	Unsigned	Reset	interrupt	status	(Current	Channel	A)
    #define	IRQENB_24	0x22F
    #define	IRQENB_32	0x32F	//	R/W	0x000000	Unsigned	Interrupt	enable	(Current	Channel	"B,"	see	Table	24)
    #define	IRQSTATB_24	0x230
    #define	IRQSTATB_32	0x330	//	R	0x000000	Unsigned	Interrupt	status	(Current	Channel	"B,"	see	Table	25)
    #define	RSTIRQSTATB_24	0x231
    #define	RSTIRQSTATB_32	0x331	//	R	0x000000	Unsigned	Reset	interrupt	status	(Current	Channel	B)	N/A	0x37F	CRC	//	R	0xFFFFFFFF	Unsigned	Checksum
    #define	AIGAIN_24	0x280
    #define	AIGAIN_32	0x380	//	R/W	0x400000	Unsigned	Current	channel	gain	(Current	Channel	A)
    #define	AVGAIN_24	0x281
    #define	AVGAIN_32	0x381	//	R/W	0x400000	Unsigned	Voltage	channel	gain
    #define	AWGAIN_24	0x282
    #define	AWGAIN_32	0x382	//	R/W	0x400000	Unsigned	Active	power	gain	(Current	Channel	A)
    #define	AVARGAIN_24	0x283
    #define	AVARGAIN_32	0x383	//	R/W	0x400000	Unsigned	Reactive	power	gain	(Current	Channel	A)
    #define	AVAGAIN_24	0x284
    #define	AVAGAIN_32	0x384	//	R/W	0x400000	Unsigned	Apparent	power	gain	(Current	Channel	A)
    //0x285	Reserved_24
    //0x385	Reserved_32	//	R/W	0x000000	Signed	This	register	should	not	be	modified.
    #define	AIRMSOS_24	0x286
    #define	AIRMSOS_32	0x386	//	R/W	0x000000	Signed	IRMS	offset	(Current	Channel	A)
    //0x287	Reserved_24
    //0x387	Reserved_32	//	R/W	0x000000	Signed	This	register	should	not	be	modified.
    #define	VRMSOS_24	0x288
    #define	VRMSOS_32	0x388	//	R/W	0x000000	Signed	VRMS	offset
    #define	AWATTOS_24	0x289
    #define	AWATTOS_32	0x389	//	R/W	0x000000	Signed	Active	power	offset	correction	(Current	Channel	A)
    #define	AVAROS_24	0x28A
    #define	AVAROS_32	0x38A	//	R/W	0x000000	Signed	Reactive	power	offset	correction	(Current	Channel	A)
    #define	AVAOS_24	0x28B
    #define	AVAOS_32	0x38B	//	R/W	0x000000	Signed	Apparent	power	offset	correction	(Current	Channel	A)
    //24-Bit	32-Bit	Register	Name	//	R/W	Default	Type	Register	Description
    #define	BIGAIN_24	0x28C
    #define	BIGAIN_32	0x38C	//	R/W	0x400000	Unsigned	Current	channel	gain	(Current	Channel	B)
    #define	BVGAIN_24	0x28D
    #define	BVGAIN_32	0x38D	//	R/W	0x400000	Unsigned	This	register	should	not	be	modified.
    #define	BWGAIN_24	0x28E
    #define	BWGAIN_32	0x38E	//	R/W	0x400000	Unsigned	Active	power	gain	(Current	Channel	B)
    #define	BVARGAIN_24	0x28F
    #define	BVARGAIN_32	0x38F	//	R/W	0x400000	Unsigned	Reactive	power	gain	(Current	Channel	B)
    #define	BVAGAIN_24	0x290
    #define	BVAGAIN_32	0x390	//	R/W	0x400000	Unsigned	Apparent	power	gain	(Current	Channel	B)
    //0x291	Reserved_24
    //0x391	Reserved_32	//	R/W	0x000000	Signed	This	register	should	not	be	modified.
    #define	BIRMSOS_24	0x292
    #define	BIRMSOS_32	0x392	//	R/W	0x000000	Signed	IRMS	offset	(Current	Channel	B)
    //0x293	Reserved_24
    //0x393	Reserved_32	//	R/W	0x000000	Unsigned	This	register	should	not	be	modified.
    //0x294	Reserved_24
    //0x394	Reserved_32	//	R/W	0x000000	Unsigned	This	register	should	not	be	modified.
    #define	BWATTOS_24	0x295
    #define	BWATTOS_32	0x395	//	R/W	0x000000	Signed	Active	power	offset	correction	(Current	Channel	B)
    #define	BVAROS_24	0x296
    #define	BVAROS_32	0x396	//	R/W	0x000000	Signed	Reactive	power	offset	correction	(Current	Channel	B)
    #define	BVAOS_24	0x297
    #define	BVAOS_24	0x397	//	R/W	0x000000	Signed	Apparent	power	offset	correction	(Current	Channel	B)
    #define	LAST_RWDATA_24	0x2FF
    #define	LAST_RWDATA_32	0x3FF	//	R	0x000000	Unsigned	Contains	the	data	from	the	last	successful	24-bit/32-bit	register	communication
  • thank you sir for giving your value able time .
    Now  i am getting reading . I am using CT at channel A and Shunt of 300micor ohm for channel b . Channel A is working fine . But channel B is giving non linear reading of current . Please check schematic . Is there any correction required .
