To find the current ,watt and AVA in ade7880 using arduino uno
Product Number: ADE7880
Software Version: I implemented the code for to find the voltage,frequency,current,watt and AVA.
Right now i am working on the ADE7880  coordination with arduino uno  for interfacing  i used spi communication.I did the voltage and frequency  based on which register they mentioned in datasheet  i am getting the output also. But when  i am reading the current (AIRMS,BIRMS,CIRMS)and watt (AWATT,BWATT,CWATT) registers   i am getting rawvalue is same only even i am giving load also using PDU(power distribution unit)  and based on the calibration value we need to get the data.
  • Is the run bit set in the RUN register?
    What is the state of the PSM0 and 1 pins?
    Dave
  • Thank you for your reply,
    Run register(0xE228)  i did bit is set to 1.
    and PSM0 is set to 1
    PSM1 is set to 0 then only  normal mode is activate.
    when i am reading the active power registers (0XE513,0XE514,0XE516) /(AWATT,BWATT,CWATT)  the raw data is same even i am giving the load through the PDU also.
    FOR EXAMPLE: reading register is AWATT  value is 257 decimal. after that i am giving the load is 100 watt and 200 watt , but i am getting the raw data is same only.
  • What are you writing to the registers after power up?
    can you provide a schematic of your board and a connection diagram of your source and load?
    Dave
  • Thanks for your reply
    when i am reading the current  register by the default its giving,
    AWATT=16777215;
    when i am giving the load like 100 watt 0r 200 watt ,the default value is decreasing like
    100 watt =1677098
    200 watt =16777012;
    my doubt is when we are giving the load the default value must be increase  and also i given absolute functon also.
    based on calibration value (constant->we can't change) only we need to get the watt.
    and also
    how to find the wthr, varthr, vathr  give any information  about this?
