Hello
Does ADE7880 support 0.001kwh measurement resolution or not? Thank you.
BR
Patrick
ADE7880
Production
The ADE7880 is high accuracy, 3-phase electrical energy measurement IC with serial interfaces and three flexible pulse outputs. The ADE7880 device incorporates...
Datasheet
ADE7880 on Analog.com
Hello
BR
Patrick
Hello
Have any comments for above?
if customer would like to use ADE7880 for EVSE charging station. Is it a suitable solution to meet 0.001kwh measurement resolution (3 digit below decimal point on display ) ? Thank you.
BR
Patrick
HI Patrick
what is the voltage, max current , nominal current , do they require a specific imp/Kwh, sensor if ct what is the burden value?
Dave
Hello Dave
Please refer to below specification. Thank you.
Voltage: 220V/380V AC
MAX Current: 40A
nominal current: 32A
specific imp/Kwh: For ADI default, not spcific
CT burden value: 2.2ohm
BR
Patrick
Hello Dave
Per my understanding, ADE7880 could support 0.001kwh measurement resolution on display, right? Thank you.
BR
Patrick
Using 220 and 40amps Max and 35amps nom with a 2 ohm burden and 1000:1 = .08mvrms to the current channel adc
using a WTHR of 3 I get these conversions constants
IRMS/LSB | 4.701150E-05 |
VRMS/LSB | 9.394577E-05 |
WATT/LSB | 0.002311321 |
WATT_HR/LSB | 0.000252458 |
220 * 35 = 7,700watt
over 1 hr you will get 7700 / 0.000252458 =30,500,122 LSB at Inom
over 1 sec you will get 30,500,122/3600 = 8,472 codes
watthr register over 1 sec = 8,472 * 0.000252458 = 2.138824176 watt/hr accumulation over 1 sec
This is at I nom(35amps) as you go down in dynamic range the number of lsbs goes down.
at 1000:1 the lsb in 1 sec will be 8472/1000 or 8.472lsbs
So the question is over time yes you can display .001WHRs but at first you may not have enough bits but as you accumulate energy you will get the resolution you require.
I hope I didn't drag this out maybe just the 0.000252458 WHR/LSB was enough
Dave
