I am trying to read the Version of the IC ADE9078 (0x4FE) simply to verify if the SPI communication is correct, but it only returns 0xFFFF as a result.
I share my code and configuration for the SPI.
I would like to know if the configuration is correct and if the way to read the ADE9078 registers is correct.
I use STM32F103RBT6 (from STM32 CUBE IDE) and ADE9078.
static void MX_SPI2_Init(void)
/* USER CODE BEGIN SPI2_Init 0 */
/* USER CODE END SPI2_Init 0 */
/* USER CODE BEGIN SPI2_Init 1 */
/* USER CODE END SPI2_Init 1 */
/* SPI2 parameter configuration*/
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_MASTER;
hspi2.Init.Direction = SPI_DIRECTION_2LINES;
hspi2.Init.DataSize = SPI_DATASIZE_16BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi2.Init.NSS = SPI_NSS_SOFT;
hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI2_Init 2 */
/* USER CODE END SPI2_Init 2 */
void Receive (uint16_t myValue2){
char buffer2[10]; // Suficiente espacio para representar un uint16_t en formato hexadecimal
snprintf(buffer2, sizeof(buffer2), "0x%04X\r\n", myValue2);
HAL_UART_Transmit(&huart2, (uint8_t*)buffer2, strlen(buffer2), HAL_MAX_DELAY);
uint16_t registro = 0x4FE;
uint16_t cmd_hdr = (registro << 4) | 0x8;
uint8_t tx_buf[2] = {0};
tx_buf[0] = (uint8_t)(cmd_hdr >> 8);
tx_buf[1] = (uint8_t)(cmd_hdr);
uint8_t buffer[4] = {0};
uint16_t rec = 0;
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
HAL_GPIO_WritePin(GPIOC,PM1_Pin, GPIO_PIN_RESET); //pm1 bajo pc5
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_6, GPIO_PIN_RESET); //pm1 bajo pc6
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_7, GPIO_PIN_RESET); //Reset alto pc7
HAL_GPIO_WritePin(GPIOB,RESET_Pin, GPIO_PIN_SET); // reset alto
HAL_GPIO_WritePin(GPIOB, CS2_Pin, GPIO_PIN_RESET); //cs2 bajo
//HAL_GPIO_WritePin(GPIOB, CS1_Pin, GPIO_PIN_SET); //cs1 alto
HAL_SPI_Transmit(&hspi2, tx_buf, 1, 1000); //transmitir dato
while(HAL_SPI_GetState(&hspi2) != HAL_SPI_STATE_READY);
HAL_SPI_Receive(&hspi2, buffer, 4, 1000); // recibir el dato
rec = ((uint16_t)buffer[0] << 8) | buffer[1];
Receive(rec);
HAL_GPIO_WritePin(GPIOB, CS2_Pin, GPIO_PIN_SET); //cs2 alto
HAL_Delay(2000);
