ade7758 random vrms issue
Product Number: ade7758
Software Version: arduino IDE
Guys,.. I'm interfacing ADE7758 with Arduino MEGA2560. Now i'm facing issues on values of Vrms. I'm getting strange values which vary each time.SPI communication is alright I tryed to get default values of some registers i got it right. But when i read terms like frequency,Temperature the also show similar values like vrms.
Temperature 8650751
Vrms phase 14096
Temperature 8650751
Vrms phase 14096
Temperature 8650751
Vrms phase 14096
I'm using circuit on  data sheet but I connected VN and floating ground. otherwise I will get fluctuating values.
Parents
  • The image provided is difficult to read can you upload a better picture?
    What is your current sensor?
    For the voltage divider you should use multiple resistors for 220v or 120V for example 3X330K and a 1K resistor?
    Are your register values raw register values?
    The temperature register is 8 bits are you reading 8 bits?
    Is this a conversion error?
    Dave
  • Now I'm just measuring  Vrms. I didn't use a current sensor.
    The about register values they  are raw values.
    I was reading temperature register as 24bits by mistake now I corrected, still the values doesn't make sense .
    Now i just grounded all pins to make sure they return register but unfortunately they read some random values.
  • Its the circuit but later I had made changes
  • taking reference from (ez.analog.com/.../ade7758-rms-calibration-help-me  ) I connected VN with AGND and DGND.
    I need to see more data read VRMS 20 times at 2 different voltages if possible.
    read these registers with your line voltage on the  voltage channel
    mmode      // freq sel  the  appropriate votlage channel.
    LCYCMODE
    FREQ
  • With 220v /1000  or 220mvRMS I get AVRMS = 1605625 AIRMS = 871 using the example in the TXT file
    // Required Registers for 7758
    #define res       0x00
    #define AWATTHR   0x01  //16
    #define BWATTHR   0x02  //16
    #define CWATTHR   0x03  //16
    #define AVARHR    0x04   //16
    #define BVARHR    0x05   //16
    #define CVARHR    0x06   //16
    #define AVAHR     0x07    //16
    #define BVAHR     0x08    //16
    #define CVAHR     0x09    //16
    #define AIRMS     0x0A  //24
    #define BIRMS     0x0B  //24
    #define CIRMS     0x0C  //24
    #define AVRMS     0x0D  //24
    #define BVRMS     0x0E  //24
    #define CVRMS     0x0F  //24
    #define FREQ      0x10  //16
    #define TEMP      0x11  //8
    #define WFORM     0x12  //24
    #define OPMODE    0x13  //8
    #define MMODE     0x14  //8
    #define WAVMODE   0x15  //8
    #define COMPMODE  0x16  //8
    #define LCYCMODE  0x17  //8
    #define MASK      0x18  //24
    #define STATUS    0X19  //24
    #define RSTATUS   0x1A  //24
    #define ZXTOUT    0x1B  //16
    #define LINECYC   0x1C  //16
    #define SAGCYC    0x1D  //8
    #define SAGLVL    0x1E  //8
    #define VPINTLVL  0x1F  //8
    #define IPINTLVL  0x20  //8
    #define VPEAK     0x21  //8
    #define IPEAK     0x22  //8
    #define GAIN      0x23  //8
    #define AVRMSGAIN 0x24  //16
    #define BVRMSGAIN 0x25  //16
    #define CVRMSGAIN 0x26  //16
    #define AIGAIN    0x27  //16
    #define BIGAIN    0x28  //16
    #define CIGAIN    0x29  //16
    #define AWG       0x2A  //16
    #define BWG       0x2B  //16
    #define CWG       0x2C  //16
    #define AVARG     0x2D  //16
    #define BVARG     0x2E  //16
    #define CVARG     0x2F  //16
    #define AVAG      0x30  //16
    #define BVAG      0x31  //16
    #define CVAG      0x32  //16
    #define AVRMSOS   0x33  //16
    #define BVRMSOS   0x34  //16
    #define CVRMSOS   0x35  //16
    #define AIRMSOS   0x36  //16
    #define BIRMSOS   0x37  //16
    #define CIRMSOS   0x38  //16
    #define AWATTOS   0x39  //16
    #define BWATTOS   0x3A  //16
    #define CWATTOS   0x3B  //16
    #define AVAROS    0x3C  //16
    #define BVAROS    0x3D  //16
    #define CVAROS    0x3E  //16
    #define APHCAL    0x3F  //8
    #define BPHCAL    0x40  //8
    #define CPHCAL    0x41  //8
    #define WDIV      0x42  //8
    #define VARDIV    0x43  //8
    #define VADIV     0x44  //8
    #define APCFNUM   0x45  //16
    #define APCFDEN   0x46  //16
    #define VARCFNUM  0x47  //16
    #define VARCFDEN  0x48  //16
    #define CHKSUM    0x7E  //8
    #define VERSION   0x7F  //8
    //blue pill powers iso side only need 5v for ade7758
    #include <SPI.h>
    #include "ADE7758_reg.h"
    void ADE7758_SPI_WRITE(uint8_t Address , uint32_t Data , uint8_t Number_of_bytes);
    uint32_t ADE7758_SPI_READ (uint8_t Address, uint8_t Number_of_bytes);
    void ADE7758_reg_config();
    //outputs
    #define PM_0 PB15
    #define PM_1 PA8
    #define RESET_B PB3
    #define SSB_A PA4
    #define SSB_B PB5
    #define SSB_C PB4
    //inputs
    #define CF1 PB6
    #define CF2 PB7
    #define CF3 PC14
    #define IRQ0 PB14
    #define IRQ1 PB13
    #define DREADY PB12
    #define FLAG PB0
    #define SSB_A PA4
    //SPI_1 Chip Select pin is PA4. You can change it to the STM32 pin you want.
    //LED1=PC_13  SERIAL_TX=PA_2  I2C_SCL=PB_8  SPI_MOSI=PA_7  PWM_OUT=PB_3
    //            SERIAL_RX=PA_3  I2C_SDA=PB_9  SPI_MISO=PA_6
    //                                          SPI_SCK =PA_5
    // bluepill      ADE7758
    //PA4  > SSB_A   >> SSB
    //PB5  > SSB_B
    //PB4  > SSB_C
    //PA2 > tx       >> TX
    //PA3 > rx       >> RX
    //PA5  > sclk    >> SCLK
    //PA6  > miso    >> MISO
    //PA7  > mosi    >> MOSI
    //PA8  > PM1     >>
    //PB15 > PM0     >>
    //PB14 > IRQ0    >> IRQ
    //PB13 > IRQ1    >> ZX
    //PB9  > sda     >> SDA
    //PB8  > scl     >> SCL
    //PB3  > RSTB    >>RESETB
    //PB12 > DREADY  >> ZX_I
    //PB6  > CF1
    //PB7  > CF2
    //PC14 > CF3
    byte data;
    uint32_t count;
    int32_t ARRAY[3250];
    int i = 0;
    void setup() {
      // put your setup code here, to run once:
      Serial.begin(2000000);
      while (!Serial);  // wait for serial to be configured
      pinMode(SSB_A, OUTPUT);
      pinMode(RESET_B, OUTPUT);
      pinMode(MOSI, OUTPUT);
      pinMode(MISO, OUTPUT);
      pinMode(FLAG, OUTPUT);
      digitalWrite(SSB_A, LOW);   // sets up I/o state for spi coms before reset
      digitalWrite(MISO, LOW);
      digitalWrite(MOSI, LOW);
      digitalWrite(FLAG, LOW);
      //reset part
      delay(1000); // fixed delay will addin IRQ monitor later
      // pinMode(MOSI, INPUT);  // change mode for spi not sure if needed
      pinMode(MISO, INPUT);  // change mode for spi not sure if needed
      pinMode(IRQ0, INPUT);
      digitalWrite(SSB_A, HIGH);
      SPI.begin(); //Initialize the SPI_1 port
      SPI.setBitOrder(MSBFIRST); // Set the SPI_1 bit order
      SPI.setDataMode(SPI_MODE1); //Set the SPI_2 data mode 0
      SPI.setClockDivider(SPI_CLOCK_DIV16);      // Slow speed (72 / 16 = 4.5 MHz SPI_1 speed)
      Serial.println("Begin Setup");
      //ADE7758_SPI_READ(RSTATUS, 3); //clr startup IRQ
      //ADE7758_reg_config();
      delay(1000);
      //attachInterrupt(digitalPinToInterrupt(IRQ0), IRQ_irq, FALLING );
      //attachInterrupt(digitalPinToInterrupt(IRQ1), ZX_irq, FALLING );
    void loop(){
            Serial.print("AVRMS = ");Serial.print(ADE7758_SPI_READ(AVRMS, 3)); Serial.print(" AIRMS = ");Serial.println(ADE7758_SPI_READ(AIRMS, 3));
            Serial.print("BVRMS = ");Serial.print(ADE7758_SPI_READ(BVRMS, 3)); Serial.print(" BIRMS = ");Serial.println(ADE7758_SPI_READ(BIRMS, 3));
            Serial.print("CVRMS = ");Serial.print(ADE7758_SPI_READ(CVRMS, 3)); Serial.print(" CIRMS = ");Serial.println(ADE7758_SPI_READ(CIRMS, 3));
            delay(1000);
    void IRQ_irq() {Serial.print('IRQ Status : ');ADE7758_SPI_READ(RSTATUS, 3);}
    void ZX_irq() {Serial.println("ZX tetected");}
     // ADE7758_SPI_WRITE(LCYCMODE, 0x77, 1);
      Serial.print("LCYCMODE=");
      Serial.println(ADE7758_SPI_READ(LCYCMODE, 1), HEX);
      uint8_t mhb = 0, hb = 0, mb = 0, lb = 0, p = 0;
      uint32_t j;
      lb = (uint8_t)(Data & 0xff);
      mb = (uint8_t)((Data & 0xff00) >> 8);
      hb = (uint8_t)((Data & 0xff0000) >> 16);
      mhb =(uint8_t)((Data & 0xff000000) >> 24);
      digitalWrite(SSB_A, LOW);   //set csb low
      SPI.transfer((0x7f & Address)| 0x80);      // send write bit and address
      //send requested number of bytes
      switch (Number_of_bytes) {
        case 4:
          SPI.transfer(mhb);
        case 3:
          SPI.transfer(hb);
        case 2:
          SPI.transfer(mb);
        case 1:
          SPI.transfer(lb);
        default:
          break;
      digitalWrite(SSB_A, HIGH);  //set csb high
      uint8_t mhb = 0, hb = 0, mb = 0, lb = 0;
      uint32_t j=0;
      SPI.transfer(0x7f & Address);      // send read bit and address
        case 4:
          mhb = SPI.transfer(0);   // dummy write
        case 3:
        case 2:
          mb = SPI.transfer(0);
        case 1:
          lb = SPI.transfer(0);
        default:
        break;
          j = (mhb << 24);
          j = j + (hb << 16);
          j = j + (mb << 8);
          j = j + (lb);
      return (j);
  • I am using the ADE7758 evaluation board with a bluepill and Arduino IDE
    Dave
  • Thanks bro due to some production reasons I had switched the Microcontroller to PIC . My code runs well but I have issues on response while reading V peak(0x21) I'm getting -1 as output.
Reply Children
