ADE1201ACCZ conversion time
Product Number: ADE1201ACCZ
Hi Team,
i need ADE1201ACCZ  ADC Conversion Time for this chip ,
I used this chip in replacement of Si8900 - 2.5 μs conversion time  i have some issue in my logic convertion at the time of 1KHz Signal i need Positive reading only buit as ADC read faster i have both reading positive and 0 , and positive reading with longer delay .
any sugestation on this ?
Nikunj
    The ADE1201 converts at 100 kHz and the ADE1202 at 50 kHz.
  • Hi Dlath,
    thank you for the update ,
    should i consider 10usec conversation time ?
    at the star it require 150ms for power on reset then 320us for value sampled after that microprocessor can access value over SPI , once it start it require only 10usec to get the updated value right ?
    it it is correct then i can read 1KHz signal ( high pulse only ) without any delay right ?
    i have some problem in implementation when i go for read it always detect 0V and after 3-4 sec i get high pulse is there any guide for PWM sensing then please guide me . ( i will try Threshold sensing for batter result  )
    Nikunj
