Hi
Does the ADE7912 need to be calibrated ?
If yes, can i do it without a load ?
ADE7912
Production
The ADE7912 / ADE7913 are isolated, 3-channel Σ-Δ ADCs for a variety of applications such as shunt-based polyphase meters, power quality monitoring...
Datasheet
ADE7912 on Analog.com
Hi
You will need to perform calibration when using the ADE7912 to make any energy measurements, how good your calibration is will depend on how accurate your source/load is. What is the context that you are using the ADE7912?
-David M
So i want to measure the energy of a washmashine. But i will be easier for me if i can calibrate somehow before installing the energy meter.
Is it possible to write the values down to the registers(so its calibrate), without any load on it ? So without installing it in the maschine ?
